    4. Test Adapter drops-weather 1.2.x
    • Winni
      Winni last edited by
      Hallo in die Runde, ich habe den Adapter installiert, dabei tritt folgendes Problem auf:
      host.raspberrypi
      2025-03-17 16:53:54.177	error	instance system.adapter.drops-weather.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      drops-weather.0
      2025-03-17 16:53:53.586	error	Failed to launch the browser process!/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������������������: not found/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted stringTROUBLESHOOTING: https://pptr.dev/troubleshooting
      drops-weather.0
      2025-03-17 16:53:53.586	error	Error: Failed to launch the browser process!/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������������������: not found/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted stringTROUBLESHOOTING: https://pptr.dev/troubleshooting at Interface.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:318:24) at Interface.emit (node:events:530:35) at Interface.close (node:internal/readline/interface:527:10) at Socket.onend (node:internal/readline/interface:253:10) at Socket.emit (node:events:530:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      drops-weather.0
      2025-03-17 16:53:53.585	error	unhandled promise rejection: Failed to launch the browser process!/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������������������: not found/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found/home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted stringTROUBLESHOOTING: https://pptr.dev/troubleshooting
      drops-weather.0
      2025-03-17 16:53:53.582	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch()
      Mein System ist aktuell, läuft ansonsten stabil und ohne Fehler. Raspi Pi5, Node.js: v20.18.3 und NPM: 10.8.2 Wenn weitere Infos gewünscht werden kann ich die gerne nachliefern.
      mcm1957 arteck 2 Replies Last reply Reply Quote 0
      • mcm1957
        mcm1957 @Winni last edited by mcm1957
        @arteck
        Da ich puppeteer nicht kenn kannst du da bitte mal schaun?
          arteck Developer Most Active @Winni last edited by
          @winni schaumal jetzt
          Winni mcm1957 2 Replies Last reply Reply Quote 1
          • Winni
            Winni @arteck last edited by
            @arteck leider immernoch..
            hatte den Adapter jetzt deinstalliert und dann neu über github installiert und dann den Citycode eingegeben.
            drops-weather.0
            2025-03-17 21:22:12.512	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
            drops-weather.0
            2025-03-17 21:22:12.460	error	adapter disabled
            drops-weather.0
            2025-03-17 21:21:40.749	info	terminating
            drops-weather.0
            2025-03-17 21:21:40.248	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            drops-weather.0
            2025-03-17 21:21:40.246	info	terminating
            drops-weather.0
            2025-03-17 21:21:40.243	error	Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������������������: not found /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted string TROUBLESHOOTING: https://pptr.dev/troubleshooting
            drops-weather.0
            2025-03-17 21:21:40.243	error	Error: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������������������: not found /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted string TROUBLESHOOTING: https://pptr.dev/troubleshooting at Interface.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:318:24) at Interface.emit (node:events:530:35) at Interface.close (node:internal/readline/interface:527:10) at Socket.onend (node:internal/readline/interface:253:10) at Socket.emit (node:events:530:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
            drops-weather.0
            2025-03-17 21:21:40.242	error	unhandled promise rejection: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������������������: not found /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found /home/iobroker/.cache/puppeteer/chrome/linux_arm-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted string TROUBLESHOOTING: https://pptr.dev/troubleshooting
            drops-weather.0
            2025-03-17 21:21:40.238	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            drops-weather.0
            2025-03-17 21:21:38.212	info	starting. Version 1.0.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.18.3, js-controller: 7.0.6
            • mcm1957
              mcm1957 @arteck last edited by
              @arteck
              Ich hab den Adapter mit puppeteer jetzt mal auf meienr Produktionsanlage (Rasperry Pi 4) installiert. Und leider muss ich sagen dass er da auch nicht funktioniert:
              Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: 1: ELF: not found /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: 1: %@@@�����X��X�������� �� ���������: not found /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: 2: Syntax error: Unterminated quoted string TROUBLESHOOTING: https://pptr.dev/troubleshooting
              @Arteck: Welche Hardware / Software ist bei dir im Einsatz?
              • mcm1957
                mcm1957 @mcm1957 last edited by
                @mcm1957
                Sieh irgendwie nach einem Fehler in puppeteer aus. Das file '/home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome' ist ein binärfile. Aber es hat ein ungültiges Format !?!?
                • mcm1957
                  mcm1957 @mcm1957 last edited by mcm1957
                  @arteck
                  Das file scheint jedenfalls nicht so ganz OK zu sein. Würde mich wundern wenn der Raspi ein x86-64 file ausführen kann !?!?
                  pi@pi4:~ $ file /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome
                  /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 3.2.0, BuildID[sha1]=91a83a3d679040baf2685bc4ed38d18480d9321d, stripped
                  https://github.com/puppeteer/puppeteer/issues/10172
                  https://github.com/puppeteer/puppeteer/issues/7740
                  https://chsamii.medium.com/puppeteer-on-raspbian-nodejs-3425ccea470e
                  Botspot created this issue in puppeteer/puppeteer
                  closed [Bug]: ARM support #10172
                  cdeutsch created this issue in puppeteer/puppeteer
                  open The chromium binary is not available for arm64 #7740
                    sigi234 Forum Testing Most Active @mcm1957 last edited by sigi234
                    @mcm1957 sagte in Test Adapter drops-weather 1.0.x:
                    Rückmeldungen aller Art - insbesondere auch Infos das der Adapter wie gewünscht funktioniert - sind herzlich willkommen.
                    Läuft bei mir einwandfrei. THX
                    Plattform: Windows
                    RAM: 15.9 GB
                    Node.js: v20.19.0
                    NPM: 10.8.2
                    Admin: 7.6.2
                    Drops: 1.0.0
                      achtet mal auf euren RAM.. bei mir schaukelt der sich hoch da der chrome prozess nicht beendet wird
                      muss ich noch schauen...
                      • mcm1957
                        mcm1957 @arteck last edited by mcm1957
                        @arteck
                        Bei mir startet der chrome gar nicht.
                        Hast du auf einem PI oder einer anderen arm Architektur getestet?
                        pupetteer installiert auch immer eine x85 chrome version statt einer arm Version.
                        Frage an alle:
                        Läuft bei irgendwem der Adapter auf einem Raspberry Pi / Arm ?
                        P.S. Und ja auf einem x86 Linux und auf Windows sollte er problemlos laufen.
                          A Former User @mcm1957 last edited by
                          @mcm1957 @arteck
                          Fragt mal @foxriver76 zu puppeteer, er maintained ja den Puppeteer-Adapter und kennt die Probleme mit Arm CPU's.. der lief ne zeitlang auch nicht auf Raspi's, bis es irgendein command - flag gab, das das kompatibel machte..
                          • mcm1957
                            mcm1957 @Guest last edited by
                            @neuschwansteini
                            Danke für den Hinweis.
                            Das Problem ist z.B. DA (https://github.com/foxriver76/ioBroker.puppeteer/issues/7) beschrieben. Im puppeteer Adapter wurde das so gelöst dass ein externer Browser erlaubt wird. Na ja- so richtig zum Jubeln ist die Lösung nicht. User sollten für einen 0815 Adapter nichts extra installieren müssen 😞
                            Daher die Frage an @arteck
                            Warum hast du auf puppeteer umgestellt? An sich hat der Adapter ja mit axios auch funktioniert?
                            Marty56 created this issue in foxriver76/ioBroker.puppeteer
                            closed Adapter stoppt mit Fehlermeldung sofort nach Start #7
                            • mcm1957
                              @arteck
                              Es liegt definitiv ein Problem mit dem von puppeteer installieren chrome image auf arm vor.
                              Ich habe jetzt mal so wie im puppetteer Adapter beschrieben (https://github.com/foxriver76/ioBroker.puppeteer/issues/13) chromium manuell installiert, d.h. sudo apt install chromium ausgeführt und dann im drops Adapter das chrome Image explizit angegeben. (Code im branch mcm195-work: https://github.com/iobroker-community-adapters/ioBroker.drops-weather/tree/mcm1957-work)
                              Der Adapter startet nun - ABER leider liefert er keinerlei Daten 😞
                              Bitte melde dich damit wir entscheiden können ob es nun sinnvoller ist das puppeteer Problem für arm zu lösen oder generell auf axios zurückzuwechseln.
                              kopierschnitte created this issue in foxriver76/ioBroker.puppeteer
                              closed Installation/Usage not possible on ARM64 platforms (RPi, etc.) #13
                              • icebear
                                icebear last edited by
                                @mcm1957
                                @arteck
                                Wenn ich mich dazu auch mal kurz melden darf, ich hatte erst den Adapter in der alten Version und hab dann den fix von @arteck drüber gebügelt, mit dem Erfolg das ich die die Meldung 'module puppeteer' not found bekam.
                                Ich hab dann den Adapter 'puppeteer' installiert, der aber bei mir (Synology NAS DS220+, Docker) direkt jede menge Browser-Fehler produzierte.
                                Hab dann den 'puppeteer' Adapter deaktiviert!!
                                Dann kam ja eure Version 1.0 vom drops-Adapter, die hab ich dann auch drüber gebügelt.
                                Der Adapter läuft jetzt bei mir ohne Fehlermeldung (puppeteer deaktiviert), aber ob er wirklich Daten empfängt kann ich noch nicht beurteilen, da weit und breit kein Regen in Sicht ist.
                                Er aktualisiert jeden Tag das Datum und meldet mir das es trocken bleibt. Deswegen kann ich halt noch nicht sagen ob es wirklich funktioniert.
                                mcm1957 Winni arteck 3 Replies Last reply Reply Quote 1
                                • mcm1957
                                  mcm1957 @icebear last edited by mcm1957
                                  @icebear said in Test Adapter drops-weather 1.0.x:
                                  @mcm1957
                                  @arteck
                                  Das lässt sich damit erklären dass in arteck's GitHUb repo die dependency eine Zeit lang gefehlt hat.
                                  Welche CPU Type hat die Synology? Ich vermute x86 - dann sollte er laufen.
                                  Das spricht dafür dass er läuft. Bei mir bleiben auf dem Pi alle Datenpunkte auf "null".,
                                  Der Adapter ioBroker.puppeteer spielt an sich nicht mit. Wenn du den nicht brauchst, dann kannst du ihn m.E: auch wieder deinstallieren.
                                  Jedenfalls DANKE für dein feedback.
                                  • Winni
                                    Winni @icebear last edited by
                                    @icebear sagte in Test Adapter drops-weather 1.0.x:
                                    Es gibt doch auch den Datenpunkt "chartTemperature", da müsste doch auch was drin stehen wenn kein Regen zu erwarten ist.
                                      arteck Developer Most Active @icebear last edited by arteck
                                      @icebear
                                      schau nach dem timestamp
                                      @mcm1957 mit axios bekam ich einen 403.. die Seite erlaubt nicht diese zu scrapen.. mit puppeteer funktioniert es..
                                      und könnten wir uns auf ein Kanal einigen.. also entweder hier oder GIT oder Telegramm.. ich mag nicht 1000 mal das gleiche schreiben
                                      aber du kannst ja den alten stand nehmen.. der mit axios und selber schauen
                                      https://github.com/arteck/ioBroker.drops-weather/tree/608ed1fcbbde3f59b6a09f2f188b92823481ae90
                                      das ist der letzte Stand vor meinen Umbau...
                                      • mcm1957
                                        @arteck
                                        gern u danke f i fo. dann ist puppeteer mal gesetzt.
                                        welcher kanal ist dir am liebsten?
                                        Chris76e 1 Reply Last reply Reply Quote 0
                                        • Chris76e
                                          Chris76e @mcm1957 last edited by
                                          auf meinem System läuft der auch nicht
                                          drops-weather.0
                                          	2025-03-18 17:09:17.166	error	Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                          drops-weather.0
                                          	2025-03-18 17:09:17.165	error	Error: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting at Interface.onClose (/opt/iobroker/node_modules/@puppeteer/browsers/lib/cjs/launch.js:318:24) at Interface.emit (node:events:530:35) at Interface.close (node:internal/readline/interface:527:10) at Socket.onend (node:internal/readline/interface:253:10) at Socket.emit (node:events:530:35) at endReadableNT (node:internal/streams/readable:1698:12) at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                                          drops-weather.0
                                          	2025-03-18 17:09:17.165	error	unhandled promise rejection: Failed to launch the browser process! /home/iobroker/.cache/puppeteer/chrome/linux-134.0.6998.35/chrome-linux64/chrome: error while loading shared libraries: libnss3.so: cannot open shared object file: No such file or directory TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                          drops-weather.0
                                          	2025-03-18 17:09:17.164	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          Habe ein IntelNuc i5-8259U
                                          Alte Version deinstalliert und neue Installiert
                                          mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                                          • mcm1957
                                            mcm1957 @Chris76e last edited by
                                            @chris76e
                                            intel nuc
                                            dürfte ja x86 sein -oder?
                                            welches os?
                                            drops-weather mcm1957
                                            21
                                            196
                                            25102
