    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      tippy88 last edited by
      Servus zusammen,
      Mit welchen Einstellungen bekommt man den Cupra Born verbunden?
      Ich habe Typ Seat Cupra und die Alternative probiert, ohne Erfolg.
      Gruß,
      Tobi
      2025-03-15 20:03:46.834 - info: vw-connect.0 (368631) Login in with seatcupra
      2025-03-15 20:03:47.098 - debug: vw-connect.0 (368631) parseEmailForm
      2025-03-15 20:03:47.224 - debug: vw-connect.0 (368631) emailPasswordForm2
      2025-03-15 20:03:47.461 - debug: vw-connect.0 (368631) ""
      2025-03-15 20:03:47.462 - debug: vw-connect.0 (368631) {"date":"Sat, 15 Mar 2025 19:03:47 GMT","content-length":"0","connection":"keep-alive","apigw-requestid":"He1LEg7PliAEJyQ=","x-content-type-options":"nosniff","x-xss-protection":"0","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000; includeSubDomains; preload","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=3c756d46-f1ba-4d78-9f9a-cff0d5292d51@apps_vw-dilab_com&relayState=7d36211df11215fc80ff9dde4995b72eb04dd8aa&userId=640bb7cdee98cbf7ed283","content-language":"en-US"}
      2025-03-15 20:03:47.727 - debug: vw-connect.0 (368631) Error: Invalid protocol: cupra:
      2025-03-15 20:03:47.800 - info: vw-connect.0 (368631) Login successful
      2025-03-15 20:03:47.970 - error: vw-connect.0 (368631) {"timestamp":"2025-03-15T19:03:47.958942578Z","path":"/v1/users/a5ae66df-76d8-43e9-bc7a-1298db4f586d/garage/vehicles","status":404,"error":"Not Found","message":"No static resource v1/users/ae9-bc7a-1298db4f586d/garage/vehicles.","requestId":"53b38186"}
      2025-03-15 20:03:47.971 - error: vw-connect.0 (368631) 404
      2025-03-15 20:03:47.971 - error: vw-connect.0 (368631) Get Vehicles Failed
        tombox @BigTom91 last edited by
        @bigtom91 für wecharge bitte die GitHub version testen ob alle notwendige Daten da sind..
        Format hat sich geändert bitte checken ob was fehlt
        Wszene B M 3 Replies Last reply Reply Quote 0
        • Wszene
          Wszene @tombox last edited by
          @tombox
          Ich habe da mal noch eine Frage
          Bekommst du zufällig diesen Wert in den ioBroker
          Das ist die Restlaufzeit der Standklima
          in der "alten" Version gab es diesen Datenpunkt
          Danke im Voraus
          Marcel
            BigTom91 @tombox last edited by
            @tombox
            Vorher hatte ich ja unter vw-connect.0.wecharge.homecharging.records die einzelnen Ladungen sehen können
            • vw-connect.0.wecharge.homecharging.records.01
            • vw-connect.0.wecharge.homecharging.records.02
            Und unter vw-connect.0.wecharge.homecharging.records.latestItem hatte ich immer die letzte/aktuellste Ladung.
            Nun scheint es so, dass die Ladungen nun unter vw-connect.0.wecharge.history.home zu finden sind.
            • vw-connect.0.wecharge.history.home.items01
            • vw-connect.0.wecharge.history.home.items02
            Wobei item01 die Lademenge des aktuellen Monats ist und die einzelnen Ladungen erst ab items02 beginnt.
            Ich vermute, dass das nun so von VW/Elli kommt, oder?
            Macht natürlich aktuelle Automatisierungen kaputt, vor allem der fehlende latestItem Eintrag.
              tombox @Wszene last edited by
              @wszene ist das skoda? müsste unter mqtt live Daten sein
              Wszene 1 Reply Last reply Reply Quote 0
              • Wszene
                @tombox sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                Danke für die schnelle Antwort
                Ja das ist Skoda du hast auch die Zugangsdaten von mir bekommen
                Bei mir sind nur folgende DPs unter mqtt zu sehen
                  eb0klud @Wszene last edited by
                  @tombox
                  Login funktioniert wieder einwandfrei. Werte kommen auch. Den Rest werde ich testen. Herzlichen Dank für Deinen Einsatz.
                  Gruß Gerhard
                  • AtrejuAZ
                    AtrejuAZ last edited by
                    @tombox Danke für die tolle Arbeit! Ich sehe meine Box, auch die Ladehistorie und die Verfügbarkeit. Aber ich finde den Datenpunkt nicht, mittels dem ich die Box zum Laden freigeben kann? Vielleicht liegt's an mir, dann freue ich mich über Erhellung 🙂
                    Danke und liebe Grüße,
                    Holger
                      Wolf1997 @tombox last edited by
                      @tombox Auch von mir: Danke für die tolle Arbeit! Ich sehe meine Box, auch die Ladehistorie und die Verfügbarkeit. Die Datenpunkt haben jetzt eine andere Struktur, aber damit kann ich umgehen!🙂
                      Thomas
                        SheepDog @Wolf1997 last edited by SheepDog
                        Hallo @tombox,
                        ich nutze den Adapter schon über ein Jahr und bin sehr zufrieden.
                        Ich würde gerne das "Update-Intervall in Minutes" in den Adaptereinstellungen per JavaScript ändern, d.h. von 15 Minute zeitweise auf 5 Minuten setzen, wenn eine wichtige Aktivität durchgeführt wird. Habe ich da eine Chance dies per JavaScript o.ä. umzusetzen?
                        Viele Grüße
                        Uwe
                          stefu87_CH last edited by stefu87_CH
                          Hallo
                          Ich habe einen Skoda Octavia Combi und seit der Umstellung der Abfrage, sind einige Infos nicht mehr vorhanden, bzw. Datenpunkte sind verschwunden.
                          Weiss jemand, unter welchem Datenpunkt ich den Oel Stand abfragen kann??
                          Vor der Umstellung war der unter:
                          vw-connect.0.TMBJR7NX7XXXXXX.status.data_0x0204040006.field_0x0204040006.value
                          • O
                            oxident @stefu87_CH last edited by
                            @stefu87_ch Ich kann zwar nicht genau helfen, aber bei meinem Seat habe ich diese Werte in einem ganz anderen Ordner wiedergefunden.
                            Such mal nach "service" oder ähnlich.
                              mikelchris @tombox last edited by
                              @tombox Vielen Dank für deine Hilfe die Ladehistorie wieder abrufen zu können. Allerdings hat sich die Struktur komplett verändert. Was kein Problem ist... allerdings fehlen bei den Ladevorgängen einige Werte vw-connect.0.wecharge.history.home.items02: z.B. authentication_method, auhorization_code, rfid_card_serial_number, start_date, end_date
                                tombox @mikelchris last edited by
                                @mikelchris sind denn diese werte in der app sichtbar wenn ja wo
                                • AtrejuAZ
                                  Hallo an alle, ich muss nochmal nachfragen, weil es tatsächlich für mich die wichtigste Funktion ist, und sie mir gerade sehr fehlt 🙂
                                  Ich finde den Datenpunkt nicht, mittels dem ich die Wallbox freischalten kann.
                                  Kann mir jemand helfen?
                                  Viele Grüße,
                                  Holger
                                    stefu87_CH @oxident last edited by
                                    @oxident Habe schon alle Datenpunkte durchgeschaut, aber nichts gefunden, was für den Oil Stand sein könnte.
                                      mikelchris @tombox last edited by Homoran
                                      @tombox
                                      Screenshot_20250319_180359_Volkswagen.jpg Screenshot_20250319_180410_Volkswagen.jpg Screenshot_20250319_180436_Volkswagen.jpg Screenshot_20250319__Volkswagen.jpg
                                      Ich habe mal einige Screenshots der VW app angehängt in denen die Ladevorgange sichtbar sind. Ich hoffe das hilft.
                                        tombox @AtrejuAZ last edited by
                                        @atrejuaz ich habe den Datenpunkt startcharging unter stations hinzugefügt bitte testen ob das geht
                                          @mikelchris di Einformation sollte unter history.home drin sein
                                            @atrejuaz bitte mal die aktuelle version testen ob startCharging geht
                                            AtrejuAZ 1 Reply Last reply Reply Quote 0
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            400
                                            3116
                                            1620678
