    4. [Vorlage] Servicemeldungen Volume2
    • Eduard77
      Eduard77 @looxer01 last edited by Eduard77
      @looxer01
      ich habe die stelle ausgetauscht und bekomme beim Skriptstart folgende Fehler.
      javascript.0	20:54:51.514	info	Stopping script script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint
      javascript.0	20:56:05.774	info	Start JavaScript script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint (Javascript/js)
      javascript.0	20:56:05.778	error	script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint compile failed: at script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint:1173
      Und folgenses im LOG.
      2025-02-28 20:54:48.578 - info: admin.0 (329) ==> Connected system.user.admin from ::ffff:192.168.178.20
      2025-02-28 20:54:51.514 - info: javascript.0 (92966) Stopping script script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint
      2025-02-28 20:56:05.774 - info: javascript.0 (92966) Start JavaScript script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint (Javascript/js)
      2025-02-28 20:56:05.778 - error: javascript.0 (92966) script.js.Test_und_nicht_fertige_Skripte.Servicemeldungen_von_AccessPoint compile failed:
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) })();
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) ^
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) SyntaxError: Unexpected token '}'
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) at new Script (node:vm:117:7)
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1956:21)
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2224:37)
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) at /opt/iobroker/node_modules/iobroker.javascript/main.js:2322:17
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
      2025-02-28 20:56:05.779 - error: javascript.0 (92966) at processImmediate (node:internal/timers:485:21)
      2025-02-28 20:56:57.027 - info: admin.0 (329) <== Disconnect system.user.admin from ::ffff:192.168.178.20 javascript
        looxer01 @Eduard77 last edited by
        @edis77
        ja, ist nicht richtig reinkopiert. lösche die Zeilen 273 - 386
        und kopier nochmal die Sequenz wie zuvor gepostet.
        vG Looxer
        • Eduard77
          @looxer01
          Habe jetzt so gemacht wie du beschreiben hast, aber bekomme wieder Warnung.
          anbei mein geänderte Skript zur Prüfung.
          // Beschreibung des Scriptes: https://forum.iobroker.net/topic/77816/vorlage-servicemeldungen-volume2
          // Autor Looxer01 02.11.2024 Version 1.0 (initiale Version)
          // Version 3.00 - 05.01.2025 Variable MessageBeiKeinerSM in die Experteneinstellungen geschoben // Problem bei der Datumsberechnung behoben // Zaehler fuer Historie hinzugefuegt
          //                           die Datenpunkte fuer Text-Format werden jetzt optional gefuellt
          // Version 3.10 - 01.02.2024 Wartezeit fuer HM-Rega von 2 auf 3,5 Sekunden erhoeht - Funktion der Tabelle MessengerScope erweitert
          // Version 3.20 - 24.02.2024 Doppelte Nachrichten im messageCollector verhindern - Vermeidung Meldung "keine Servicemeldungen..." in der Historie wenn bereits vorhanden - Wartezeit für Rega-Trigger wieder auf 5s
          //                           StickyMessages koennen automatisch bestaetigt werden
          // Muss-Einstellungen                                 ( HM-Classic , HMIP, Wired - hier muessen zwingend die Instanzen stimmmen )
          // Im folgenden sind die Instanzen gelistet fuer die die Selektion erfolgt bzw nicht erfolgt (Filter)
          // bitte 9 Eintragen falls eine Instanz nicht relevant ist // Gruppeninstanzen sind normalerweise nicht relevant
          // CuxD Instanzen duerfen nicht eingetragen werden  --- ACHTUNG: bei HMIPAccessPoint-Nutzung muss GeraeteTriggerID auf true stehen
          const HMClassicInstanz      = 9;        // HM-Classic Instanz eintragen     // 9 = falls nicht relevant
          const HMIPInstanz           = 9;        // Homematic IP instanz             // 9 = falls nicht relevant
          const WiredIClassicInstanz  = 9;        // Wired Instanz                    // 9 = falls nicht relevant
          const GruppenInstanz        = 9;        // virtuelle GeraeteInstanz- 9 = nicht relevant - Die Gruppen werden i.d.R. nicht gebraucht - Empfehlung: 9
          let   HMIPAccessPoint       = 0;        // AccessPoint Servicemeldungen - (normalerweise instanz = 0) bei nicht Verwendung Instanz = 9
          // Kann-Einstellungen
          // Pfad kann angepasst werden fuer userdata pfad einfach // entfernen
          const path      = "javascript.0.ServicemeldungenVol2.";
          //const path    = "0_userdata.0.ServicemeldungenVol2."; // alternativ zum javascript pfad
          // schreibt das Protokoll der Servicemeldungen in ein externes file (Excel Format)
          const SMProtokoll = true;
          const PathSMLog = "/opt/iobroker/log/ServicemeldungenVol2.csv";             // Pfad und Dateiname des externen Logs
          //const PathSMLog = "/iobroker/log/ServicemeldungenVol2.csv";            // Pfad fuer Windows/  iobroker ist der angenommene iobroker home-pfad
          //Geraete die nicht ueberwacht werden sollen. Geraete-IDs eingeben - Komma getrennt erfassen
          const Ausschlussliste = ['0000D7099xxx26', '00091D8xxx7410']; // immer mit Komma trennen // Filter auf Einzel-IDs
          // debug level kann eingestellt werden - wenn alles laeuft dann 0 = ruhe im log
          // debug level 0   kein log // debug level 1 - nur die wichtigsten Meldungen werden gelistet // debug level 2 - mehr als nur die wichtigsten Meldungen aber ohne einzelne IDs
          // debug level 3 - hier werden auch einzelne IDs gelistet (koennten lange listen werden)
          const debugLevel = 2 ;     // Empfehlung = 1
          const SystemLog = false;  // schreib das Sytemprotokoll in ein externes log (sollte normalerweise deaktviert sein  nur bei Problemen verwenden)
          const PathSystemLog = "/opt/iobroker/log/ServicemeldungenSystemLog.csv";             // Pfad und Dateiname des externen Logs
          //const PathSystemLog = "/iobroker/log/ServicemeldungenSystemLog.csv";             // Pfad fuer Windows
          // wenn GeraeteIDTrigger auf true gestellt wird, dann wird fuer jeden Datenpukt mit Relevanz fuer eine Servicemeldung eine subscription angelegt.
          // Vorteile: mehr Details in der Historie von Servicemeldungen: Nachteil: bei 80 CCU Geraeten ungefaehr 300 Susbsriptions
          // Wenn die variable auf false steht, dann wird auf hm.rega.0.maintenance eine subsription angelegt: Vorteil: 1 Subscription , Nachteil: erweiterte Funktion fuer nicht CCU Datenpunkte nicht verfuegbar
          // bei HMIP AccessPoint Cloud HCU - funktioniert das nur bei GeraeteTrigger = true
          let GeraeteIDTrigger = false; // true = viele subscriptions aber praezise Historie der Servicemeldungen - false = 1 subscription - weniger praezise Historie - Empfehlung = false
          // Speicherung der Servicemeldungen im  Text-Format - Empfehlung = false // davon ausgehend, dass das JSON Format in der Visualisierung gut dargestellt werden kann
          const UpdateTEXT_Datenpunkte = false; // die kurz- und langen Servicemeldungen als auch die historischen werden immer im JSON Format abgelegt. Alternativ koennen diese auch in einem TEXT Format in Datenpunkten gespeichert werden
          // Speicherung der Servicemeldungen im  HTML-Format - Wird empfohlen zu nutzen, wenn es Problem bei der Visualisierung von JSON gibt.
          const UpdateHTML_Datenpunkte = true; // die langen Servicemeldungen als auch die historischen werden immer im JSON Format abgelegt. Alternativ koennen diese auch in einem HTML Format in Datenpunkten gespeichert werden
          // Die Autobestaetigung bestaetigt automatisch evt Sticky-Meldungen der CCU
          const AutoBestaetigungCCUMeldungen = true; // Empfehlung ist true - nur relevant fur HM-Classic Geraete //bei true sollte in der CCU die autobestaetigung ausgeschaltet werden
          //  fuer alle Spalten mit true werden die Nachrichten ueber den zugeordneten Dienst versendet, vorausgesetzt der Messenge Adapter ist in iobroker installiert/konfiguriert
              const services =               ['email',    'whatsApp',     'Signal',  'Telegram',    'Pushover', 'Pushsafer', 'Pushsafer',];
              const MessengerScope = {
              'UNREACH_ALARM':                [true,        false,          false,      true,          false,      false,       false,],
              'STICKY_UNREACH_ALARM':         [false,       false,          false,      false,          false,      false,       false,],   // Sticky sollte nicht gesendet werden - alles auf false setzen
              'LOWBAT_ALARM':                 [true,        false,          false,      true,          false,      false,       false,],
              'SABOTAGE_ALARM':               [true,        false,          false,      true,          false,      false,       false,],
              'STICKY_SABOTAGE_ALARM':        [false,       false,          false,      false,          false,      false,       false,],   // Sticky sollte nicht gesendet werden - alles auf false setzen
              'CONFIG_PENDING_ALARM':         [true,        false,          false,      true,          false,      false,       false,],
              'Sonstige':                     [true,        false,          false,      true,          false,      false,       false,], // text ist fest verdrahtet nicht ändern
              'keineSM':                      [true,        false,          false,      true,          false,      false,       false,], // text ist fest verdrahtet nicht ändern
              const MessengerInstanz =        [0,             0,               0,          0,              0,          0,            1,  ]; // Instanz des Messengers
              const TextTypeKurz      =       [false,        true,            true,       true,           true,      true,         false,]; // bei true wird der Kurztext gesendet - sonst der Langtext
          // email-Einstellungen
          let emailAddresse = "Vorname-Nachname@web.de"   // Empfängeraddresse
          const Headline = "ioBroker Servicemeldung";     // Ueberschrift Messages fuer email und Pushsafer
          // telegram Einstellungen
          const TelegramUser = "Eduard";
          //Experten Einstellungen - Empfehlung:  Absprache mit dem Autor
          const MessageBeiKeinerSM = 'Derzeit keine Servicemeldungen'     // Text der erscheinen soll, wenn keine SM vorliegen Ein Kurztext ist erforderlich
          //const NichtRelevantText = 'n/a';                                // statt n/a kann ein beliebiger anderer Text in den JSON verwendet werden
          const NichtRelevantText = "......";
          // die folgenden Einstellungen sind nur relvant bei Verwendung von HTML als Datenpunkte
              // Definieren der Farbwerte für Kopfzeile, gerade und ungerade Zeilen
              const headerColor = '#333333';  // Standardfarbe (Fuellfarbe) für die Kopfzeile
              const evenRowColor = '#4e5049'; // Standardfarbe (Fuellfarbe) für gerade Zeilen
              const oddRowColor = '#333333';  // Standardfarbe (Fuellfarbe) für ungerade Zeilen
              // Definieren der Textfarben für Kopfzeile, gerade und ungerade Zeilen
              const headerTextColor = 'white'; // Textfarbe für Kopfzeile
              const evenRowTextColor = 'white'; // Textfarbe für gerade Zeilen
              const oddRowTextColor = 'white';  // Textfarbe für ungerade Zeilen
              // Definieren von Zellenumrandungseinstellungen
              const useBorderAll =    true; // true, wenn ein Gitternetz erzeugt werden soll
              const borderColor = '#000000'; // Farbe des Gitternetzes (Zellenumrandung)
              const borderWidth = '1px'; // Strichstärke der Zellenumrandung
          //Schedule Zeit fuer refresh der Historie
          const ScheduleAktiv = true;                         // Bei "false" wird der schedule nicht durchlaufen. Manuelles Löschen kann über den Datenpunkt id_Button_Refresh_Historie (Button) möglich
          const scheduleTimeClearSMTexte = "2 0 1 * *";       // am 1. tag des monats um 00:02 morgens sollen alle Servicemeldungen des Monats geloescht werden
          // const scheduleTimeClearSMTexte = "58 23 * * 0";  // alternative Sonntags um 23:58 Uhr sollen alle Servicemeldungen der Woche im datenpunkt der SM-Texte geloescht werden
          //Batterie-Zuordnungen fuer Servicmeldungen
          const batteryTypes = {
              '1x CR2016':    ['HM-RC-4', 'HM-RC-4-B', 'HM-RC-Key3', 'HM-RC-Key3-B', 'HM-RC-P1', 'HM-RC-Sec3', 'HM-RC-Sec3-B', 'ZEL STG RM HS 4'],
              '1x CR2032':    ['HM-PB-2-WM', 'HM-PB-4-WM', 'HM-PBI-4-FM', 'HM-SCI-3-FM', 'HM-Sec-TiS', 'HM-SwI-3-FM', 'HmIP-FCI1'],
              '2x LR14':      ['HM-Sec-Sir-WM', 'HM-OU-CFM-TW', 'HM-OU-CFM-Pl', 'HM-OU-CF-Pl'],
              '2x LR44/AG13': ['HM-Sec-SC', 'HM-Sec-SC2L', 'HM-Sec-SC-2', 'HM-Sec-RHS'],
              '2x LR6/AA':    ['HM-CC-VD', 'HM-CC-RT-DN', 'HM-Sec-WDS', 'HM-Sec-WDS-2', 'HM-CC-TC', 'HM-Dis-TD-T', 'HB-UW-Sen-THPL-I', 'HM-WDS40-TH-I', 'HM-WDS40-TH-I-2',
                               'HM-WDS10-TH-O', 'HmIP-SMI',                     'HMIP-eTRV', 'HM-WDS30-OT2-SM-2', 'HmIP-SMO', 'HmIP-SMO-A', 'HmIP-SPI', 'HmIP-eTRV-2',
                               'HmIP-SPDR', 'HmIP-STHO-A', 'HmIP-eTRV-B', 'HmIP-PCBS-BAT', 'HmIP-STHO', 'HmIP-eTRV-C',
                               'HmIP-WGC', 'HmIP-eTRV-C-2', 'HmIP-eTRV-E', 'HmIP-eTRV-2 I9F', 'HmIP-eTRV-E-S', 'ELV-SH-SW1-BAT'],
              '3x LR6/AA':    ['HmIP-SWO-PL', 'HM-Sec-MDIR', 'HM-Sec-MDIR-2', 'HM-Sec-SD', 'HM-Sec-Key', 'HM-Sec-Key-S', 'HM-Sec-Key-O', 'HM-Sen-Wa-Od', 'HM-Sen-MDIR',
                               'HM-Sen-MDIR-O', 'HM-Sen-MDIR-O-2', 'HM-WDS100-C6-O', 'HM-WDS100-C6-O-2', 'HmIP-ASIR', 'HmIP-SWO-B', 'HM-Sen-MDIR-O-3', 'HM-Sec-MDIR-3',
                               'HmIP-SWO-PR', 'HmIP-DLD', 'HmIP-ASIR-2'],
              '4x LR6/AA':    ['HM-CCU-1', 'HM-ES-TX-WM', 'HM-WDC7000'],
              '1x LR3/AAA':   ['HM-RC-4-2', 'HM-RC-4-3', 'HM-RC-Key4-2', 'HM-RC-Key4-3', 'HM-RC-Sec4-2', 'HM-RC-Sec4-3', 'HM-Sec-RHS-2', 'HM-Sec-SCo', 'HmIP-KRC4',
                               'HmIP-KRCA', 'HmIP-SRH', 'HMIP-SWDO', 'HmIP-DBB', 'HmIP-RCB1', 'HmIP-KRCK', 'HmIP-SWDO-2'],
              '2x LR3/AAA':   ['HmIP-WRCR', 'HmIP-SWD','HM-TC-IT-WM-W-EU', 'HM-Dis-WM55', 'HM-Dis-EP-WM55', 'HM-PB-2-WM55', 'HM-PB-2-WM55-2', 'HM-PB-6-WM55', 'HM-PBI-2-FM', 'HM-RC-8', 'HM-Sen-DB-PCB',
                              'HM-Sen-EP', 'HM-Sen-MDIR-SM', 'HM-Sen-MDIR-WM55', 'HM-WDS30-T-O', 'HM-WDS30-OT2-SM', 'HmIP-STH', 'HmIP-STHD', 'HmIP-WRC2', 'HmIP-WRC6', 'HmIP-WTH', 'HmIP-WTH-2',
                              'HmIP-SAM', 'HmIP-SLO', 'HMIP-SWDO-I', 'HmIP-FCI6', 'HmIP-SMI55', 'HM-PB-2-FM', 'HmIP-SWDM', 'HmIP-SCI', 'HmIP-SWDM-B2', 'HmIP-RC8', 'ALPHA-IP-RBG', 'HmIP-DSD-PCB',
                              'HmIP-WRCD', 'HmIP-WRC2-A', 'HmIP-WTH-B-2', 'HmIP-WTH-A', 'HmIP-STV', 'HmIP-WKP'],
              '3x LR3/AAA':   ['HM-PB-4Dis-WM', 'HM-PB-4Dis-WM-2', 'HM-RC-Dis-H-x-EU', 'HM-Sen-LI-O'],
              '3x AAA Akkus - bitte laden': ['HM-RC-19', 'HM-RC-19-B', 'HM-RC-12', 'HM-RC-12-B', 'HM-RC-12-W'],
              '3x LR14/C':    ['HmIP-MP3P'],
              '9Volt Block leer oder unbestimmt': ['HM-LC-Sw1-Ba-PCB', 'HM-LC-Sw4-PCB', 'HM-MOD-EM-8', 'HM-MOD-Re-8', 'HM-Sen-RD-O', 'HM-OU-CM-PCB', 'HM-LC-Sw4-WM'],
              'Festbatterie leer': ['HmIP-STE2-PCB', 'HM-Sec-SD-2', 'HmIP-SWSD', 'HmIP-PCBS'],
              'ohne Batterie': ['HM-LC-Sw1PBU-FM', 'HM-LC-Sw1-Pl-DN-R1', 'HM-LC-Sw1-DR', 'HM-LC-RGBW-WM', 'HM-LC-Sw1-Pl-CT-R1', 'HmIP-HEATING', 'HM-LC-Sw1-FM', 'HM-LC-Sw2-FM', 'HM-LC-Sw4-DR',
                                  'HM-LC-Sw1-Pl', 'HM-LC-Sw1-Pl-2', 'HM-LC-Sw4-Ba-PCB', 'HM-LC-Sw1-SM', 'HM-LC-Sw4-SM', 'HM-Sys-sRP-Pl', 'HM-LC-Sw2PBU-FM', 'HM-LC-Sw1-PCB', 'HM-LC-Sw4-DR-2'],
              'Akku entladen - bitte aufladen': ['HM-Sec-Win', 'HM-Sec-SFA-SM', 'HM-RC-19-SW']
          // Rega Pfad
          const PathRega = ['hm-rega.0.maintenance',];                            // Array um ggf die HCU zu konfigurieren
          // Pfade fuer die Speicherung aktueller und vergangener Servicemeldungen
          const id_Text_ServicemeldungLang        = path+'TextLangAktuelleSM';    // Objekt wo die Servicemeldung hingeschrieben werden soll (String) = path+'TextLang';
          const id_Text_ServicemeldungKurz        = path+'TextKurzAktuelleSM';    // Objekt wo die Servicemeldung hingeschrieben werden soll (String) - kurze Version
          const id_Text_Servicemeldung_History    = path+'TextLangVergangeneSM';  // Objekt wo die Servicemeldung hinzugefuegt werden soll (String) - Lange Version (es gibt nur lang)
          const id_HTML_Servicemeldung_Aktuell    = path+'HtmlAktuelleSM';        // Objekt wo die Servicemeldung hingeschrieben werden soll (HTML formatiere Tabelle) = path+'htmlLang';
          const id_HTML_Servicemeldung_History    = path+'HtmlVergangeneSM';      // Objekt wo die Servicemeldung hinzugefuegt werden soll ((HTML formatiere Tabelle) - Lange Version (es gibt nur lang)
          const id_JSON_Servicemeldung_Aktuell    = path+'JSONAktuelleSM';        // JSON Tabelle Datenpunkt Aktuelle SM
          const id_JSON_Servicemeldung_Historie   = path+'JSONVergangeneSM';      // JSON Tabelle Datenpunkt Historische SM
          const id_Button_Refresh_Historie        = path+'ButtonRefreshHistorie'; // Wenn DP auf true gesetzt wird, dann wird die historie refreshed (geloescht)
          // Count-Pfade  und counts in einer Tabelle - wird auch fuer CREATE STATES verwendet
          const Zaehler = [
            { alarmtype: 'UNREACH_ALARM',                    count: 0,                    Datenpunkt: path+'Anzahl_UNREACH' },
            { alarmtype: 'STICKY_UNREACH_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_STICKY_UNREACH' },
            { alarmtype: 'CONFIG_PENDING_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_CONFIG_PENDING' },
            { alarmtype: 'UPDATE_PENDING_ALARM',             count: 0,                    Datenpunkt: path+'Anzahl_Update_PENDING' },
            { alarmtype: 'LOWBAT_ALARM',                     count: 0,                    Datenpunkt: path+'Anzahl_LOWBAT' },
            { alarmtype: 'DEVICE_IN_BOOTLOADER_ALARM',       count: 0,                    Datenpunkt: path+'Anzahl_DEVICE_IN_BOOTLOADER' },
            { alarmtype: 'ERROR',                            count: 0,                    Datenpunkt: path+'Anzahl_in_ERROR' },
            { alarmtype: 'FAULT_REPORTING',                  count: 0,                    Datenpunkt: path+'Anzahl_FAULT_REPORTING' },
            { alarmtype: 'SABOTAGE_ALARM',                   count: 0,                    Datenpunkt: path+'Anzahl_SABOTAGE' },
            { alarmtype: 'ERROR_NON_FLAT_POSITIONING_ALARM', count: 0,                    Datenpunkt: path+'Anzahl_NON_FLAT_POSITIONING' },
            { alarmtype: 'STICKY_SABOTAGE_ALARM',            count: 0,                    Datenpunkt: path+'Anzahl_Sticky_SABOTAGE' },
            { alarmtype: 'SMAktuell',                        count: 0,                    Datenpunkt: path+'Anzahl_SM-Aktuell' },
            { alarmtype: 'SMHistorie',                       count: 0,                    Datenpunkt: path+'Anzahl_SM-Historie' },
            { alarmtype: 'Gesamt',                           count: 0,                    Datenpunkt: path+'Anzahl_GESAMT' }
          // statusmessages je messagetype und   adapter // Fallback ist fuer unbekannte messagetypes - z.B. alle Error Messages // FALLBACK repraesentiert Standardmessages
          const statusMessages = {
              UNREACH_ALARM:                    { "hm-rpc": { 0: "keine Kommunikationsfehler",     1: "Kommunikation gestoert",                            2: "Kommunikation war gestoert" } },
              STICKY_UNREACH_ALARM:             { "hm-rpc": { 0: "keine Kommunikationsfehler",     1: "Sticky Kommunikation gestoert",                     2: "Sticky Kommunikation war gestoert" } },
              SABOTAGE_ALARM:                   { "hm-rpc": { 0: "Keine Sabotage",                 1: "Sabotage",                                          2: "Sabotage aufgehoben" } },
              STICKY_SABOTAGE_ALARM:            { "hm-rpc": { 0: "Keine Sabotage",                 1: "Sticky Sabotage",                                   2: "Sticky Sabotage aufgehoben" } },
              LOWBAT_ALARM:                     { "hm-rpc": { 0: "Batterie ok",                    1: "Batterie niedrig",                                  2: "Batterie ok" } },
              LOW_BAT_ALARM:                    { "hm-rpc": { 0: "Batterie ok",                    1: "Batterie niedrig",                                  2: "Batterie ok" } },
              ERROR_NON_FLAT_POSITIONING_ALARM: { "hm-rpc": { 0: "Keine Meldung",                  1: "Geraet wurde angehoben.",                           2: "Geraet wurde angehoben: Bestaetigt" } },
              CONFIG_PENDING_ALARM:             { "hm-rpc": { 0: "keine Meldung",                  1: "Konfigurationsdaten stehen zur Uebertragung an",    2: "Konfigurationsdaten standen zur Uebertragung an",}, },
              UPDATE_PENDING_ALARM:             { "hm-rpc": { 0: "kein Update verfuegbar",         1: "Update verfuegbar",                                 2: "Update wurde eingespielt" } },
              ERROR_OVERHEAT_ALARM:             { "hm-rpc": { 0: "kein Overheat Alarm",            1: "Overheat gemeldet",                                 2: "Overheat geloest" } },
              ERROR_UNDERVOLTAGE_ALARM:         { "hm-rpc": { 0: "Kein Undervoltage Alarm",        1: "Undervoltage gemeldet",                             2: "Undervoltage geloest" } },
              DEVICE_IN_BOOTLOADER_ALARM:       { "hm-rpc": { 0: "Keine Meldung",                  1: "Geraet startet neu",                                2: "Geraet wurde neu gestartet" } },
              DUTY_CYCLE:                       { "hm-rpc": { false: "Geraete-Duty Cycle ok",      true: "Geraete-Duty Cycle erreicht",                    null: "unbekannter Status (Duty_Cycle" } },
              lowBat:                           { "hmip":   { false: "Batterie ok",                true: "Batterie niedrig",                               null: "Batterie ok" } },
              unreach:                          { "hmip":   { false: "keine Kommunikationsfehler", true: "Kommunikation gestoert",                         null: "Kommunikation war gestoert" } },
              sabotage:                         { "hmip":   { false: "Keine Sabotage",             true: "Sabotage",                                       null: "Sabotage aufgehoben" } },
              configPending:                    { "hmip":   { false: "Keine Meldung",              true: "Konfigurationsdaten stehen zur Uebertragung an", null: "Konfigurationsdaten standen zur Uebertragung an" } },
              FALLBACK:                         { "hm-rpc": { 0: "keine Stoerung",                 1: "Stoerung",                                          2: "Stoerung aufgehoben",
                                                              false: "Keine Stoerung",             true: "Stoerung",                                       null: "unbekannter Status Fallback"},
                                                  "hmip":   { false: "keine Stoerung",             true: "Stoerung",                                       null: "Stoerung aufgehoben" }, }
          //ErrorMessages fuer HM-Classic Geraete - Sonderfaelle
          const errorMessages = {
              'HM-Sec-RHS':   { 7: 'Sabotage' },
              'HM-Sec-RHS-2': { 7: 'Sabotage' },
              'HM-Sec-SC':    { 7: 'Sabotage' },
              'HM-Sec-SC-2':  { 7: 'Sabotage' },
              'HM-Sec-SCo':   { 7: 'Sabotage' },
              'HM-Sec-MD':    { 7: 'Sabotage' },
              'HM-Sec-MDIR':  { 7: 'Sabotage' },
              'HM-Sec-MDIR-2':{ 7: 'Sabotage' },
              'HM-Sec-Key':   { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
              'HM-Sec-Key-S': { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
              'HM-Sec-Key-O': { 1: 'Einkuppeln fehlgeschlagen', 2: 'Motorlauf abgebrochen' },
              'HM-CC-VD':     { 1: 'Ventil Antrieb blockiert',  2: 'Ventil nicht montiert', 3: 'Stellbereich zu klein', 4: 'Batteriezustand niedrig'
          //ErrorMessages fuer HM-Classic Geraet (Heizung) - Sonderfaelle
          const faultMessages = {
              'HM-CC-RT-DN': {
                  0: 'keine Stoerung',
                  1: 'Ventil blockiert',
                  2: 'Einstellbereich Ventil zu gross',
                  3: 'Einstellbereich Ventil zu klein',
                  4: 'Kommunikationsfehler',
                  6: 'Spannung Batterien/Akkus gering',
                  7: 'Fehlstellung Ventil'
          // hier koennen die Alarmgruppen ggf erweitert werden - Aus Alarmgruppe und Instanz wird der Selector gebastelt und in Tabelle Selectors gesammelt
          const alarmTypes = [
              { key: 'UNREACH_ALARM',                     suffixes: ['UNREACH_ALARM','unreach' ] },//UNREACH_ALARM = HM-Classic & HMIP-CCU - unreach = HMIP Accesspoint
             // { key: 'STICKY_UNREACH_ALARM',              suffixes: ['STICKY_UNREACH_ALARM'] },
              { key: 'CONFIG_PENDING_ALARM',              suffixes: ['CONFIG_PENDING_ALARM','configPending'] }, //configPending ist eine HMIP Meldung
              { key: 'UPDATE_PENDING_ALARM',              suffixes: ['UPDATE_PENDING_ALARM'] },
              { key: 'LOWBAT_ALARM',                      suffixes: ['LOWBAT_ALARM', 'LOW_BAT_ALARM','lowBat'] }, //LOWBAT_ALARM = HM-Classic - LOW_BAT_ALARM = HMIP CCU - lowBat = HMIP Accesspoint
              { key: 'DEVICE_IN_BOOTLOADER_ALARM',        suffixes: ['DEVICE_IN_BOOTLOADER_ALARM'] },
              { key: 'ERROR',                             suffixes: ['ERROR','DUTY_CYCLE'] },                  // error ist ein Sammler fuer hier nicht definierte Meldungen
              { key: 'FAULT_REPORTING',                   suffixes: ['FAULT_REPORTING'] },
              { key: 'SABOTAGE_ALARM',                    suffixes: ['SABOTAGE_ALARM','sabotage'] }, // sabotage ist eine HMIP Meldung
            //  { key: 'STICKY_SABOTAGE_ALARM',             suffixes: ['STICKY_SABOTAGE_ALARM'] },
              { key: 'ERROR_NON_FLAT_POSITIONING_ALARM',  suffixes: ['ERROR_NON_FLAT_POSITIONING_ALARM'] },
              { key: 'OVERHEAT_ALARM',                    suffixes: ['ERROR_OVERHEAT_ALARM'] },
              { key: 'UNDERVOLTAGE_ALARM',                suffixes: ['ERROR_UNDERVOLTAGE_ALARM'] },
          // Umlaut Umwandlung und entfernung PUnkte - kann aber auch erweitert werden
          const replacements = { '.': ' ', 'ä': 'ae', 'ü': 'ue', 'ö': 'oe', 'ß': 'ss' }; // Umwandlung fuer Namen der Geraete (common.name)
          // Definition der Datenstrukturen fuer MetaDaten je nach Adapter, da abweichend
          const StrukturDefinition = [
              { Adapter: 'hm-rpc',   GeraeteID: 2, AlarmFeld: 4, nativeType: 3,                                             common_name:  3 }, // die Ziffer ist die Positinierung des Feldes 'hm-rpc.1.00085D89B14067.0.UPDATE_PENDING_ALARM' 0=Adapter - 2 = ID 4= Feld Alarm / native Type = die ersten Strings bis zur dritten STelle fuer getObject
              { Adapter: 'hmip',     GeraeteID: 3, AlarmFeld: 6, nativeType: 'hmip.xinstancex.devices.xidx.info.modelType', common_name: 'hmip.xinstancex.devices.xidx.info.label' }, // Positionierung wie bei Rm-rpc - bei hmip wird native type aber ueber den DP ausgelesen und nicht getObject "xidx" wird dann mit der geraeteiD ersetzt
          // Moegliche Homematic Instanzen (CuxD ausgeschlossen) // Adapter hinzugefuegt um ggf HCU zu konfigurieren
          const instanceIds = [
              { name: 'HMClassicInstanz',     adapter: 'hm-rpc', Instanz: HMClassicInstanz     },
              { name: 'HMIPInstanz',          adapter: 'hm-rpc', Instanz: HMIPInstanz          },
              { name: 'GruppenInstanz',       adapter: 'hm-rpc', Instanz: GruppenInstanz       },
              { name: 'WiredIClassicInstanz', adapter: 'hm-rpc', Instanz: WiredIClassicInstanz },
              { name: 'HMIPAccessPoint',      adapter: 'hmip'  , Instanz: HMIPAccessPoint      },
          // Die StickingMappingsTabelle stellt sicher, dass die Sticky entsprechend dieser Regel bestaetigt werden kann
          const StickyMappings = {
              STICKY_UNREACH_ALARM:            ['UNREACH_ALARM'],
              STICKY_SABOTAGE_ALARM:           ['SABOTAGE_ALARM'],
          // Konfigurationsobjekt fuer Ausnahmen / es koennen Arlarmtypes je Instanz ausgeschlossen werden / Filter auf AlarmTypes
          const exceptions = {
              HMClassicInstanz:       [],
              HMIPInstanz:            ['DUTY_CYCLE'],
              GruppenInstanz:         ['ERROR_NON_FLAT_POSITIONING_ALARM'],
              WiredIClassicInstanz:   ['LOWBAT_ALARM', 'LOW_BAT_ALARM','ERROR_NON_FLAT_POSITIONING_ALARM'],
          //Ende Einstellungen
          LOG(`Script: Servicemeldungen Volume 2 - Autor: Looxer01 Datum: 24.02.2025 Version:3.20`,`Einstellungen`,`Start`,0 )
          if(HMIPAccessPoint !== 9 && !GeraeteIDTrigger) {
              GeraeteIDTrigger = true // Wenn der HMIPAccessPoint aktiv ist, dann funktioniert der REGA Trigger nicht. also setzen auf geraeteID Trigger=true
              LOG(`HMIP AccessPoint bzw Cloud HCU sind aktiv - GeraeteTriggerID muss aktiviert sein - wurde aktiviert. Bitte auch manuell korrigieren und auf GeraeteTriggerID = true setzen`,`Einstellungen`,`Start`,0 )
          LOG(`HMClassicInstanz: ${HMClassicInstanz}; HMIPInstanz: ${HMIPInstanz}; WiredIClassicInstanz: ${WiredIClassicInstanz}; GruppenInstanz: ${GruppenInstanz}`, "Einstellungen", "Start", 2);
          LOG(`Inhalt instanceIds: ${JSON.stringify(instanceIds)}`, "Einstellungen", "Start", 2);
          LOG(`GeraeteIDTrigger: ${GeraeteIDTrigger}`, "Einstellungen", "Start", 2);
          LOG(`Inhalt Messengerscope: ${JSON.stringify(MessengerScope)}`, "Einstellungen", "Start", 2);
          LOG(`Inhalt Services: ${JSON.stringify(services)}`, "Einstellungen", "Start", 2);
          LOG(`Inhalt Messenger-Instanzen: ${JSON.stringify(MessengerInstanz)}`, "Einstellungen", "Start", 2);
          LOG(`Inhalt TextTypeKurz: ${JSON.stringify(TextTypeKurz)}`, "Einstellungen", "Start", 2);
          let HistorischeMeldungenJSON = [], AktuelleMeldungenJSON = [], MessageSendCollector = {};
          // jetzt selectors fuellen anhand der Tabelle InstanceIDs, sowie der Auscchlusstabellen
          let totalIdsCount = 0;                                                  // Variable fuer die Gesamtzahl der IDs
          const selectors = alarmTypes.map(alarmType => {
              const collectedIds = [];
              instanceIds.forEach(instance => {
                  if (instance.Instanz !== 9) {                                   // Umbenennung von `instance.id` zu `instance.Instanz`
                      const excludedAlarmTypes = exceptions[instance.name] || []; // Hole Ausnahmen oder leere Liste
                      if (!excludedAlarmTypes.includes(alarmType.key)) {          // Wenn Alarmtype nicht in der Ausnahme
                          alarmType.suffixes.forEach(suffix => {                  // wenn suffix (meldungsart) nicht in der Ausnahme
                              if (!excludedAlarmTypes.includes(suffix)) {
                                  // IDs sammeln, ohne sofort zu filtern
                                  // @ts-ignore
                                  $(`state[id=${instance.adapter}.${instance.Instanz}.*.${suffix}]`).each(id => collectedIds.push(id));
              const filteredIds = collectedIds.filter(id => !id.includes("groups"));  // for accessPoint und HCU sollten die Ids, die "groups" enthalten ausgeschlossen werden . das sind z.B. Raeume
              const finalFilteredIds = filteredIds.filter(id => {                     // IDs anhand der Geraete-IDs in der Ausschlussliste filtern
                  const deviceId = id.split('.')[2];                                  // Geraete-ID aus der vollstaendigen ID extrahieren (z. B. "0000D7099xxx26" aus "hm-rpc.1.0000D7099xxx26.0.LOW_BAT_ALARM")
                  return !Ausschlussliste.includes(deviceId);                         // Behalten, wenn nicht in der Ausschlussliste
              totalIdsCount += finalFilteredIds.length;                                // IDs zur Gesamtzahl hinzufuegen
              return { name: alarmType.key, ids: finalFilteredIds };
              AktuelleMeldungenJSON = [];
              let jsonString = getState(id_JSON_Servicemeldung_Historie).val || '[]';    // Lade den aktuellen JSON-String des Historie-Datenpunkts
              HistorischeMeldungenJSON = JSON.parse(jsonString);
              Zaehler.forEach(entry => { entry.count = 0; }); // Alle count-Werte im Objekt auf 0 setzen
              for (let j = 0; j < selectors.length; j++) {
                  const selector = selectors[j];
                  if (selector.ids.length > 0) {
                      for (let i = 0; i < selector.ids.length; i++) {
                          let id = selector.ids[i], status = getState(id).val;
                          if (!existsState(id)) {
                              LOG(`Geraet ${obj.id} scheint zwischenzeitlich nicht mehr zu existieren - Empfehlung: script neu starten`, "WARN", "Check_All", 0, "warn");
                              continue;
                          switch (selector.name) {        // fuer alle alarmtypes - erst die Sonderfaelle
                              case 'ERROR':
                                  if (status >= 1 && status <= 7) {
                                      if (status === 7) { // Sonderfall bei HM-Classic
                                          processServiceMessage('SABOTAGE_ALARM', status, id,RunType);
                                      } else {
                                          processServiceMessage(selector.name, status, id,RunType);
                                  break;
                          default:                    // Standardfall fuer alle anderen alarmtypes
                                  if(status === 1 || status === true ) {processServiceMessage(selector.name, status, id,RunType);  } // bei status = true = AccessPoint
                                  break;
                          increaseCount('Gesamt');
                      } // Ende Loop der Mitglieder des Alarmtypes
                  }  // Endif selector ist gefuellt
              }    // Ende Loop ueber den Selector
              const AnzahlAktuellerSM = Zaehler.find(e => e.alarmtype === 'SMAktuell').count;
              // Sequenz zur Speicherung der aktuellen Servicemeldungen in die JSON -Datenpunkte--------------------------
              if (AnzahlAktuellerSM  === 0) {
                  AktuelleMeldungenJSON =CreateJsonEntry([] ,func_get_datum(),'', '', '','',func_get_datum() + " - " + MessageBeiKeinerSM,MessageBeiKeinerSM,null,false );  // Keine aktuellen Meldungen -> "Keine Meldungen" hinzufuegen
                  let jsonString = JSON.stringify(AktuelleMeldungenJSON);
                  setState(id_JSON_Servicemeldung_Aktuell, jsonString);           // Aktuelle SM wird in JSON-Datenpunkt als String gespeichert
              } else {
                  let jsonString = JSON.stringify(AktuelleMeldungenJSON);              // AktuelleMeldungenJSON wird in Funktion DefineServiceMessage gefuellt
              if (GeraeteIDTrigger && RunType === "trigger" && !existsState(obj.id)) { // obj.id nicht mehr in ioBroker aber noch im Selector
                  const GeraeteId = ExtractMetaData(obj.id, "GeraeteID");
                  LOG(`Geraet ${GeraeteId} scheint zwischenzeitlich nicht mehr zu existieren - Empfehlung: script neu starten`, "WARN", "Check_All", 0, "warn");
                  return;
              // Speziell fuer GerateIDTrigger = true ist, dass es "aufgehoben"-Meldungen gibt, die fuer REGA Trigger nicht ausgewertet werden koennen. diese duerfen auch nicht als aktuelle meldungen in den DP gelangen
              let ExtendedAktuelleMeldungenJSON = [...AktuelleMeldungenJSON]; // Erstelle eine flat copy
              if (GeraeteIDTrigger && RunType === "trigger") {
                  const status = obj.newState.val;
                  const common_name = ExtractMetaData(obj.id, "CommonName");
                  const native_type = ExtractMetaData(obj.id, "nativeType");
                  const meldungsart = ExtractMetaData(obj.id, "meldungsart");
                  let status_textLang = DefineServiceMessage(native_type, status, obj.id, "lang");
                  let status_textPure = DefineServiceMessage(native_type, status, obj.id, "pure");
                  if (!checkIFJSONfEntryExists(ExtendedAktuelleMeldungenJSON,func_get_datum(obj.id), GeraeteId,status, meldungsart) ) {       // checken ob ein Eintrag schon in der Historie ist, wenn nicht dann hinzufuegen
                      ExtendedAktuelleMeldungenJSON = CreateJsonEntry(ExtendedAktuelleMeldungenJSON, func_get_datum(obj.id), meldungsart, common_name, GeraeteId, status, status_textLang, status_textPure, func_Batterie(native_type), true)
              // Historische Meldungen hinzufuegen, wenn nicht bereits vorhanden
              ExtendedAktuelleMeldungenJSON.forEach(aktuelleMeldung => {        // Iteriere ueber alle aktuellen Meldungen und fuege aktuelle meldungen in die historie wenn noch nicht vorhanden
                  if (!checkIFJSONfEntryExists(HistorischeMeldungenJSON,aktuelleMeldung.datum_seit  ,aktuelleMeldung.GeraeteId, aktuelleMeldung.status, aktuelleMeldung.meldungsart) ) {       // checken ob ein Eintrag schon in der Historie ist, wenn nicht dann hinzufuegen
                      if(!isLatestEntryMessageBeiKeinerSM(ExtendedAktuelleMeldungenJSON)) {    // nicht wenn nicht "keine Servicemeldungen" in aktuellJSON vorhanden ist
                          const message_kurz = aktuelleMeldung.common_name + " " + aktuelleMeldung.status_message_Pure
                          addMessageToCollector(aktuelleMeldung.meldungsart, message_kurz, aktuelleMeldung.status_message_Lang);
                          HistorischeMeldungenJSON = CreateJsonEntry(HistorischeMeldungenJSON, aktuelleMeldung.datum_seit, aktuelleMeldung.meldungsart, aktuelleMeldung.common_name, aktuelleMeldung.GeraeteId, aktuelleMeldung.status, aktuelleMeldung.status_message_Lang, aktuelleMeldung.status_message_Pure, aktuelleMeldung.batterie_bezeichnung, true )
                          writelog(aktuelleMeldung.common_name, aktuelleMeldung.GeraeteId, aktuelleMeldung.meldungsart, aktuelleMeldung.status, aktuelleMeldung.status_message_Lang);       // externes log erzeugen
              // Handling "keine aktuellen Servicemeldungen"
              if (AnzahlAktuellerSM  === 0 && RunType === "trigger") {       // wenn keine SM vorliegen, die Meldung "keine Servicmeldungen" in die History
                  if(!isLatestEntryMessageBeiKeinerSM(HistorischeMeldungenJSON)) {    // nur  wenn  "keine Servicemeldungen" in Historische Meldung nicht bereits an erster Stelle vorhanden ist
                      HistorischeMeldungenJSON =CreateJsonEntry(HistorischeMeldungenJSON ,func_get_datum(),'', '', '','',func_get_datum() + " - " + MessageBeiKeinerSM,MessageBeiKeinerSM,null,false );  // Keine aktuellen Meldungen
                      writelog("", "", "", "", MessageBeiKeinerSM);       //  log erzeugen
                      addMessageToCollector('keineSM', MessageBeiKeinerSM, MessageBeiKeinerSM); // Vorbereitung Messagesending
                      sendMessage('keineSM');
              // AutoBestaetigung fuer StickyMessages, wenn diese nicht mehr aktuell sind. nur relevant fuer HM-Classic
              if (AutoBestaetigungCCUMeldungen ) {ConfirmStickyMessages() }
              // Messages senden fuer alle Faelle mit Servicemeldungen
              if (AnzahlAktuellerSM  > 0 && RunType ==="trigger") {            // Servicemeldungen versenden, falls servicemeldungen vorliegen
                  sendMessage();
              HistorischeMeldungenJSON = Markiere_HistSM_als_Aufgehoben(HistorischeMeldungenJSON) // markiert hist messages als erledigt falls nicht mehr in aktuelle meldungen enthalten
              jsonString = JSON.stringify(HistorischeMeldungenJSON);                  // Vorbereitung speichern
              setState(id_JSON_Servicemeldung_Historie, jsonString);                  // hist JSON-Daten speichern
              // falls so eingestellt werden jetzt die TEXTe aus den JSON (aktuell und historie) erzeugt und in die Datenpunkte geschrieben
              GenerateTEXT_Datenpunkte();
              generateHtmlTable(AktuelleMeldungenJSON,"AKT");                 // Aktuelle SM wird in HTML Format gespeichert falls so eingestellt
              generateHtmlTable(HistorischeMeldungenJSON,"HIST");             // Historische  SM wird in HTML Format gespeichert falls so eingestellt
              // anzahl der Eintraege in HistorischeMeldungenJSON ermitteln und alle counts in die Statistik schreiben
              let entry = Zaehler.find(item => item.alarmtype === "SMHistorie");
              if (entry) {entry.count = HistorischeMeldungenJSON.length;    }          // Wenn der Eintrag gefunden wird, aktualisiere den count-Wert
              Zaehler.forEach(entry => {    // JETZT: ZaehlerStaende in die ioBroker - Datenpunkte-------------------fuer aktuelle Meldungen
                  setState(entry.Datenpunkt, entry.count);
              // Log Ausgabe der Ergebnisse--------------------------------------------
              LOG(`Es wurden insgesamt ${Zaehler.find(e => e.alarmtype === 'Gesamt').count} IDs gecheckt - insgesamt gibt es ${AnzahlAktuellerSM} Servicemeldungen`, "Ergebnis", "Check_All", 2);
              Zaehler.forEach(({ alarmtype, count }) => {
                  LOG(`SMAktuell fuer alarmtype: ${alarmtype} insgesamt festgestellte Servicemeldungen: ${count}`, "Ergebnis", "Check_All", 2);
              LOG(`Zeitverbrauch fuer Routine Check_All: ${Date.now() - startTime} Millisekunden`, "Ergebnis", "Check_All", 1);
              AktuelleMeldungenJSON =[]; HistorischeMeldungenJSON = [];  MessageSendCollector = {};    // Speicher freigeben
          //  Function processServiceMessage // Zuordnung der richtigen Servicemeldung zum Alarmtype / Zaehlung der Faelle
          function processServiceMessage(alarmtype, status, id, RunType) {
              const native_type = ExtractMetaData(id, "nativeType");
              const meldungsart = ExtractMetaData(id, "meldungsart");
              const common_name = ReplaceString(ExtractMetaData(id, "CommonName"));
              const GeraeteId = ExtractMetaData(id, "GeraeteID");
              let ServiceMeldungTextLang = DefineServiceMessage(native_type, status, id, "lang");     // aktuelle Servicemeldung ableiten
              let ServiceMeldungTextPure = DefineServiceMessage(native_type, status, id, "pure");
              AktuelleMeldungenJSON = CreateJsonEntry(AktuelleMeldungenJSON, func_get_datum(id), meldungsart, common_name, GeraeteId, status, ServiceMeldungTextLang, ServiceMeldungTextPure, func_Batterie(native_type), true); // nur einmal unabhaengig der Version
              increaseCount(alarmtype); increaseCount('SMAktuell');
          // Funktion ConfirmStickyMessages Autoconfirm Servicemeldungen (STICKY bei HM-Classic)
          function ConfirmStickyMessages() {
              LOG("Routine ConfirmStickyMessages wird ausgeführt", "Ablauf", "ConfirmStickyMessages", 2);
              let Adapter, Instanz, StickyMeldungsart, StickyMappedString, ID_Constructed, GeraeteID;
              let AckFlag = false; let delay = 0;
              const foundInstance = instanceIds.find(item => item.name === 'HMClassicInstanz'); // die HMClassic Instanz wird ermittelt
              if (foundInstance) {
                  Adapter = foundInstance.adapter;
                  Instanz = foundInstance.Instanz;
              for (let i = 0; i < AktuelleMeldungenJSON.length; i++) {
                  const aktuelleMeldung = AktuelleMeldungenJSON[i];
                  StickyMeldungsart = aktuelleMeldung.meldungsart;
                  StickyMappedString = StickyMappings[StickyMeldungsart];
                  GeraeteID = aktuelleMeldung.GeraeteId;
                  if (StickyMappedString === undefined) { continue }
                  ID_Constructed = Adapter + "." + Instanz + "." + GeraeteID + ".0." + StickyMeldungsart; // Gilt nur bei HM-Classic
                  AckFlag = CheckStickyNochAktuell(StickyMappedString, GeraeteID); // kann die Message bestaetigt werden ? true = ja
                  if (AckFlag) {
                      setTimeout(() => {
                          setState(ID_Constructed, 2);
                          LOG("Eine Sticky Meldung wurde bestaetigt fuer ID " + ID_Constructed, "Ergebnis", "ConfirmStickyMessages", 2);
                      }, delay); //  Verzögerung
                      delay = delay + 500
                  } else {
                      LOG("Eine Sticky Meldung ist noch aktuell und wird nicht bestaetigt fuer ID " + ID_Constructed, "Ergebnis", "ConfirmStickyMessages", 2);
          // Funktion CheckStickyNochAktuell checked of Sticky Meldung bestaetigt werden kann
          function CheckStickyNochAktuell(MappedString, GeraeteID) {
              let AckFlag = true;
              MappedString = String(MappedString); // Wandelt MappedString in einen String um
              GeraeteID = String(GeraeteID); // Wandelt GeraeteID in einen String um
              for (let j = 0; j < AktuelleMeldungenJSON.length; j++) {    // Iteriere über alle aktuellen Meldungen, um nach einer Nicht-Sticky-Meldung zu suchen
                  const AktuelleMeldung = AktuelleMeldungenJSON[j];
                  const aktuelleMeldungsart = String(AktuelleMeldung.meldungsart).trim();
                  const aktuelleGeraeteId = String(AktuelleMeldung.GeraeteId).trim();
                  if (aktuelleMeldungsart === MappedString && aktuelleGeraeteId === GeraeteID) {  // ueberpruefen ob die Sticky message noch aktuell ist
                      AckFlag = false;
                      break; // Schleife abbrechen
              return AckFlag;
          // Function increaseCount // Diese Funktion reduziert Wiederholungen der Case abfragen in Check_ALL
          function increaseCount(alarmtype) {
              const entry = Zaehler.find(e => e.alarmtype === alarmtype);
              if (entry) entry.count++;
          // Funktion DefineServiceMessage  Message ERmittlung
          function DefineServiceMessage(native_type, status, id, version) {
              LOG(`Routine DefineServiceMessage wird ausgefuehrt meldungsart ${meldungsart} und ID:${id}`, "Ablauf", "DefineServiceMessage", 2);
              const adapter = ExtractMetaData(id, "adapter");
              const datum_seit = func_get_datum(id);
              let matchingAlarmType = meldungsart;
              let isValidMessageType = alarmTypes.some((type) => type.suffixes.includes(meldungsart));
              if (isValidMessageType) {    // Bestimmen des passenden Alarmtyps
                  matchingAlarmType = alarmTypes.find((type) => type.suffixes.includes(meldungsart)).key;
                  if (matchingAlarmType === "ERROR" && meldungsart !== "ERROR") {
              const createServiceMessage = (message) => {    // Hilfsfunktion zum Erzeugen der ServiceMessage
                  if (version === "lang") {        // Unterschiedliche Formate je nach Version
                      let Status_Message_Lang = `${datum_seit} - ${meldungsart} - ${common_name} - (${GeraeteId}) - ${status} - ${message}`;
                      return Status_Message_Lang;
                  } else if (version === "pure") {
                      return message;  // Nur die pure status Nachricht
                  } else {
                      return `${common_name} ${message}`;  // Kurze Nachricht, falls kurze Nachrichten gewuenscht fuer das messaging
              switch (matchingAlarmType) {    // Logik je nach meldungsart
                  case "LOWBAT_ALARM":
                      const lowBatMessage = `${getStatusMessage(meldungsart, status, adapter)} - Batteriebezeichnung: ${func_Batterie(native_type)}`;
                      return createServiceMessage(lowBatMessage);
                  case "ERROR":
                      if (status >= 1 && status <= 7 && errorMessages[native_type] && errorMessages[native_type][status]) {
                          return createServiceMessage(errorMessages[native_type][status]);
                      if (status === 0) {
                          const fallbackMessage = getStatusMessage("FALLBACK", status, adapter);
                          return createServiceMessage(fallbackMessage);
                      break;
                  case "FAULT_REPORTING":
                      if (faultMessages[native_type] && faultMessages[native_type][status]) {
                          return createServiceMessage(faultMessages[native_type][status]);
                      break;
                  default:
                          return createServiceMessage(getStatusMessage(meldungsart, status, adapter));
                      } else {
              return createServiceMessage(getStatusMessage("FALLBACK", status, adapter));    // kann eigentlich nicht aufteten
          //Funktion getStatusMessage zur Abfrage der Meldung je messageType, Adapter und Status (fuer Routine DefineServiceMessage)
          function getStatusMessage(messageType, statusKey, adapter) {
              if ( statusMessages[messageType] && statusMessages[messageType][adapter] &&statusMessages[messageType][adapter][statusKey] !== undefined  ) {    // Existenzpruefung- ggf regagieren
                  return statusMessages[messageType][adapter][statusKey];
              } else {
                  return `Keine passende Meldung fuer MessageType: "${messageType}", Adapter: "${adapter}", Status: "${statusKey}".`;
          // addMessageToCollector  Messages werden unter beruecksichtigung der folgenden Objekte in den MessageCollector genommen
          // MessengerScope, Services, AlarmTypes, TextTypeKurz
          function addMessageToCollector(messageType, MessageKurz, MessageLang) {
              let actualMessageType, matchingAlarmType;
              if (messageType !== "keineSM") {
                  let isValidMessageType = alarmTypes.some((type) => type.suffixes.includes(messageType));
                      matchingAlarmType = alarmTypes.find((type) => type.suffixes.includes(messageType)).key;
                      actualMessageType = messageType;
                  } else {
                      LOG(`MessageType: ${messageType} ist nicht konfiguriert in alarmTypes`, "WARN", "addMessageToCollector", 0);
              if (messageType === "keineSM") {
                  actualMessageType = "keineSM";
                  matchingAlarmType = "keineSM";
              if (!MessageSendCollector[actualMessageType]) {
                  MessageSendCollector[actualMessageType] = {};
              let messengerConfig = MessengerScope[matchingAlarmType] || MessengerScope['Sonstige'] || Array(services.length).fill(false);
              messengerConfig.forEach((isActive, index) => {
                  if (isActive) {
                      const service = services[index];
                      const instance = MessengerInstanz[index];
                      if (instance !== null && !isNaN(instance) && instance >= 0) {
                          if (!MessageSendCollector[actualMessageType][service]) {
                              MessageSendCollector[actualMessageType][service] = [];
                          const messageToAdd = TextTypeKurz[index] ? MessageKurz : MessageLang;
                          const existingMessages = MessageSendCollector[actualMessageType][service];
                          // **Doppelprüfung:** Gibt es bereits eine Nachricht mit demselben Text und Instanz?
                          const isDuplicate = existingMessages.some(msg => msg.message.trim() === messageToAdd.trim() && msg.instance === instance);
                          if (!isDuplicate) {
                              MessageSendCollector[actualMessageType][service].push({
                                  message: messageToAdd + '\n',
                                  instance: instance
                              LOG(`Nachricht hinzugefügt für ${actualMessageType} - Service: ${service} - Instanz: ${instance}`, "Ablauf", "addMessageToCollector", 3);
                          } else {
                              LOG(`Doppelte Nachricht erkannt und verworfen für ${actualMessageType} - Service: ${service} - Instanz: ${instance}`, "DEBUG", "addMessageToCollector", 3);
                      } else {
                          LOG(`Ungültige Instanz für Service: ${service} (Instanz: ${instance})`, "WARN", "addMessageToCollector", 0);
          // sendMessage  Hier werden die Nachrichten fuer den jeweiligen Service aufbereitet
          function sendMessage(messageType = null) {
              LOG(`Routine sendMessage wird ausgefuehrt, meldungsart: ${messageType}`, "Ablauf", "sendMessage", 2);
              const messageTypesToProcess = messageType ? [messageType] : Object.keys(MessageSendCollector);    // Bestimme die MessageTypes, die verarbeitet werden sollen
              messageTypesToProcess.forEach((type) => {
                  const messagesByService = MessageSendCollector[type];
                  if (messagesByService) {
                      Object.keys(messagesByService).forEach((service) => {
                          const serviceMessages = messagesByService[service];
                          let messagesToRemove = [];
                          serviceMessages.forEach((item) => {
                              const { message, instance } = item;
                              sendToService(service, message, instance);
                              messagesToRemove.push(item);
                          messagesToRemove.forEach((item) => {                // Entferne alle verarbeiteten Nachrichten
                              const serviceMessagesIndex = serviceMessages.indexOf(item);
                              if (serviceMessagesIndex > -1) {
                                  serviceMessages.splice(serviceMessagesIndex, 1);
          // sendToService    - hier wird der Versand vorgenommen
          // Reihenfolge:       Email, WhatsApp, Signal, Telegram, Pushover, Pushsafer
          // MessengerInstanz = [0,       0,        0,      0,         0,        0]    Instanzen der Messenger-Dienste in
          function sendToService(service, message, instance) {
          LOG(`Message wird versendet mit: ${service} : ${instance} : ${message}`, "Ablauf", "sendToService", 2);
              switch (service) {
                  case "email":
                      sendTo(`email.${instance}`, "send", {
                          text: message,
                          to: emailAddresse,
                          subject: Headline
                      break;
                  case "whatsApp":
                      sendTo(`whatsapp-cmb.${instance}`, "send", {
                          text: message
                      break;
                  case "Signal":
                      sendTo(`signal-cmb.${instance}`, "send", {
                          text: message
                      break;
                  case "Telegram":
                      sendTo(`telegram.${instance}`, "send", {
                          text: message,
                          user: TelegramUser  // Telegram User ID, um den Nachrichteneempfaenger festzulegen
                      break;
                  case "Pushover":
                      sendTo(`pushover.${instance}`, "send", {
                          message: message,
                          sound: ""
                      break;
                  case "Pushsafer":
                      sendTo(`pushsafer.${instance}`, "send", {
                          message: message,
                          title: Headline
                      break;
                  default:
                      LOG(`Unbekannter Service: ${service}`, "WARN", "sendToService", "warn");
          // Funktion ExtractMetaData  Verarbeitung des Datenpunkts zur Extraktion der Metadaten: GeraeteId, meldungsart
          function ExtractMetaData(datenpunkt, ExtractType) {
              LOG(`Routine ExtractMetaData wird ausgefuehrt datenpunkt fuer Metadaten ${datenpunkt} ExtractType ${ExtractType} `, "Ablauf", "ExtractMetaData", 2);
              ExtractType = ExtractType.toUpperCase();
              const teile = datenpunkt.split('.');                                        // Splitte den Datenpunkt in Teile
              const adapter = teile[0];                                                   // Der erste Teil ist immer der Adapter
              const instance = teile[1];                                                  // Der zweite  Teil ist immer die  Instance
              const struktur = StrukturDefinition.find(s => s.Adapter === adapter);       // Strukturzeile aus Tabelle StrukturDefinition fuer den Adapter aus dem uebergebenen DP
              const GeraeteID = teile[struktur.GeraeteID];                                // Extrahiere Felder basierend auf der Strukturdefinition
              if (!struktur) {
                  LOG(`Die Struktur fuer MetaDaten Extract ist nicht korrekt eingestellt. Der uebergebenen datenpunkt war:$(datenpunkt)- Abbruch`, "Fehler", "ExtractMetaData", 0);
                  return null;
              if(ExtractType === "ADAPTER") { return adapter; }
              if(ExtractType === "GERAETEID") { return GeraeteID; }
              if(ExtractType === "MELDUNGSART") {
                  const meldungsart = teile[struktur.AlarmFeld];                                       // Extrahiere Felder basierend auf der Strukturdefinition
                  return meldungsart;
              if(ExtractType === "NATIVETYPE" && typeof struktur.nativeType === 'number') {
                  const MetaDP = datenpunkt.split('.').slice(0, struktur.nativeType).join('.');        // ergibt den Datenpunkt fuer getObject z.B. hm-rpc.1.00085D89B14067
                  const nativeType  = getObject(MetaDP).native.TYPE;
                  return nativeType;
              if(ExtractType === "NATIVETYPE" && typeof struktur.nativeType === 'string') {           // bei string liegt der native-type im datenpunkt
                  let  DPNativeTypeDP = struktur.nativeType;
                  DPNativeTypeDP = DPNativeTypeDP.replace('xidx', GeraeteID);
                  DPNativeTypeDP = DPNativeTypeDP.replace('xinstancex', instance);
                  let nativeType = getState(DPNativeTypeDP).val
                  return nativeType;
              if(ExtractType === "COMMONNAME" && typeof struktur.common_name === 'number') {
                  const MetaDP = datenpunkt.split('.').slice(0, struktur.common_name).join('.');        // ergibt den Datenpunkt fuer getObject z.B. hm-rpc.1.00085D89B14067
                  const common_name  = getObject(MetaDP).common.name;
                  return common_name;
              if(ExtractType === "COMMONNAME" && typeof struktur.common_name === 'string') {           // bei string liegt der common_name im datenpunkt
                  let DPcommmon_name = struktur.common_name;
                  DPcommmon_name = DPcommmon_name.replace('xidx', GeraeteID).replace('xinstancex', instance);
                  let common_name = getState(DPcommmon_name).val
                  return common_name;
              LOG(`Der Datenpunkt/ExtractType, die erforderlich zur Ermittlung von Metadaten sind nicht bekannt Der Datenpunkt lautet ${datenpunkt} ExtractType ${ExtractType}  - Abbruch`, "Fehler", "ExtractMetaData", 0);
              return null
          // ReplaceString  // ersetzen  entsprechend tabelle replacements
          function ReplaceString(string) {
              for (const [key, value] of Object.entries(replacements)) {
                  // Escape den Punkt (.) fuer den regulaeren Ausdruck
                  const escapedKey = key.replace('.', '\\.');
                  string = string.replace(new RegExp(escapedKey, 'g'), value);
              return string;
          // func_get_datum  aktuelles Datum formatiert
          function func_get_datum(id) {
              let datum;
              if (id && getState(id)) {
                  datum = formatDate(getState(id).lc, "TT.MM.JJ SS:mm:ss");
              } else {
                  datum = formatDate(new Date(), "TT.MM.JJ SS:mm:ss"); // Aktuelles Datum
              let datumDate = new Date(datum); // korrekte verwendung des datumsformates
              let cutoffDate = new Date('1971-01-01T01:00:00');
              return datumDate < cutoffDate ? '' : `${datum} Uhr`;
          // func_Batterie Batterieermittlung
          function func_Batterie(native_type) {
              LOG(`Routine wird ausgefuehrt`, "Ablauf", "func_Batterie", 2);
              const normalizedType = native_type.toUpperCase();
              return Object.keys(batteryTypes).find(battery =>
                  batteryTypes[battery].some(device => device.toUpperCase() === normalizedType)
              ) || NichtRelevantText;
          // Funktion CreateJsonEntry erzeugen einer JSON Tabelle
          function CreateJsonEntry(existingJson = [], datum_seit = '', meldungsart = '', common_name = '', GeraeteId = '', status = '', Status_Lang = '', Status_Pure, Batterie = '',sortierung = false) {
              let parsedJson;
              if (Array.isArray(existingJson)) {     // ueberpruefen, ob existingJson bereits ein Array ist
                  parsedJson = existingJson; // Nur das Array uebernehmen
              } else {
                  parsedJson = [];  // Falls es kein Array ist, setze es auf ein leeres Array
              const neuerEintrag = {
                  datum_seit: datum_seit || func_get_datum(),     // Fallback auf aktuelles Datum
                  meldungsart: meldungsart || NichtRelevantText,
                  common_name: common_name || NichtRelevantText,
                  GeraeteId: GeraeteId || NichtRelevantText,
                  status: status || NichtRelevantText,                                // Status entweder number oder boolean
                  status_message_Lang: Status_Lang || 'Keine Meldung',    // Langer Text
                  status_message_Pure: Status_Pure || 'Keine Meldung',    // nur die Status aus den Status-Tabellen
                  batterie_bezeichnung: Batterie || NichtRelevantText,
                  SM_aufgehoben_seit:  "aktiv"          // status ob eine message bereits aufgeboben ist. wenn aufgehoben wird ein Datum eingestellt
              parsedJson.unshift(neuerEintrag);
              if(sortierung) { sortJason(parsedJson);}
              return parsedJson;  // Gib das aktualisierte Array zurueck
          // Funktion checkIfEntryExists Checken of ein Eintrag schon vorhanden ist
          function checkIFJSONfEntryExists(parsedJson, datum_seit, GeraeteId, status, meldungsart) {
              if (!Array.isArray(parsedJson)) { // Überprüfen, ob parsedJson ein Array ist
                  LOG(`parsedJson ist kein Array`, "WARN", "checkIFJSONfEntryExists", 1);
                  return false;
              for (let entry of parsedJson) { // Durch das Array iterieren und kriterien checken // meldungsart ist optional
                  if (entry.datum_seit === datum_seit && entry.GeraeteId === GeraeteId && entry.status === status && (meldungsart === undefined || entry.meldungsart === meldungsart)  ) {
                      return true; // Eintrag gefunden
              return false; // Kein passender Eintrag gefunden
          // Funktion isLatestEntryMessageBeiKeinerSM Checken ob die letzte message der variablen MessageBeiKeinerSM entspricht
          function isLatestEntryMessageBeiKeinerSM(existingJson = []) {
              if (!Array.isArray(existingJson) || existingJson.length === 0) {    // ueberpruefen, ob existingJson ein Array ist und Eintraege enthaelt
                  return false;
              const latestEntry = existingJson[0];    // Neuesten Eintrag extrahieren (erster Eintrag im Array)
              if (latestEntry.status_message_Lang && latestEntry.status_message_Lang.includes(MessageBeiKeinerSM)) {
                  return true;
              return false;
          // Funktion Markiere_HistSM_als_Aufgehoben Zuordnung von historischen Messages zu "aufgehoben" mit Datum der Zuordnung
          function Markiere_HistSM_als_Aufgehoben(HistorischeMeldungenJSON_transfer) {
              const maxTimeDiffMs = 1000; // z.B. 1000 ms fuer eine Sekunde Unterschied
              const nurKeineMeldungen = AktuelleMeldungenJSON[0].status_message_Lang.includes(MessageBeiKeinerSM);    // Pruefen, ob AktuelleMeldungenJSON nur eine Meldung mit "Derzeit keine Servicemeldungen" enthaelt
              if (nurKeineMeldungen) {
                  HistorischeMeldungenJSON_transfer.forEach(meldung => {        // Alle historischen Eintraege als aufgehoben markieren
                      if (meldung.SM_aufgehoben_seit === "aktiv") {
                          meldung.SM_aufgehoben_seit = func_get_datum();
                  return HistorischeMeldungenJSON_transfer;
              HistorischeMeldungenJSON_transfer.forEach(historischeMeldung => {    // Iteriere ueber alle historischen Meldungen (aeussere Schleife)
                  if (historischeMeldung.SM_aufgehoben_seit !== "aktiv") return; // Wenn die historische Meldung bereits aufgehoben wurde, ueberspringen
                  let zugeordnet = false;
                  const historischeDatum = extractDate(historischeMeldung.datum_seit);
                  AktuelleMeldungenJSON.forEach(aktuelleMeldung => {        // Iteriere ueber alle aktuellen Meldungen (innere Schleife)
                      const aktuelleDatum = extractDate(aktuelleMeldung.datum_seit);
                      const gleicheGeraeteID = historischeMeldung.GeraeteId === aktuelleMeldung.GeraeteId;
                      const gleicheStatusMessage = historischeMeldung.status_message_Pure === aktuelleMeldung.status_message_Pure;
                      const zeitDifferenz = Math.abs(aktuelleDatum.getTime() - historischeDatum.getTime());            // Berechne den Zeitunterschied in Millisekunden
                      const gleicheOderNaheZeit = zeitDifferenz <= maxTimeDiffMs;            // Pruefe, ob die Zeitdifferenz innerhalb des erlaubten Bereichs liegt
                      if (gleicheGeraeteID && gleicheStatusMessage && gleicheOderNaheZeit) {
                          historischeMeldung.SM_aufgehoben_seit = "aktiv"; // Als nicht aufgehoben markieren
                          zugeordnet = true
                  if (!zugeordnet) {
                      historischeMeldung.SM_aufgehoben_seit = func_get_datum() // kein pendant gefunden, also muss die message obsolet sein
          // Funktion sortJason zum Sortieren des History Jason nach datum
          function sortJason(parsedJson) {
              if (!Array.isArray(parsedJson)) { LOG("Die Eingabe fuer sortJason ist kein Array.", "Fehler", "sortJason", 2); return[] ;}
              const parseDate = (datum) => {
                  try {
                      const [date, time] = datum.split(' '); // Datum und Zeit trennen
                      const [day, month, year] = date.split('.'); // Datum aufteilen in Tag, Monat, Jahr
                      const [hours, minutes, seconds] = time.split(':'); // Zeit aufteilen in Stunden, Minuten, Sekunden
                      return new Date(`20${year}-${month}-${day}T${hours}:${minutes}:${seconds}`); // ISO-Format erstellen
                  } catch (error) {
                      LOG(`Fehler beim Parsen des Datums: ${datum}`, "Fehler", "sortJason", 1);
                      return null;  // Rueckgabe von null, wenn das Datum ungueltig ist
              return parsedJson.sort((a, b) => {
                  const dateA = parseDate(a.datum_seit);
                  const dateB = parseDate(b.datum_seit);
                  if (dateA === null && dateB === null) return 0; // Keine aenderung bei ungueltigen Datumswerten
                  if (dateA === null) return 1; // Null-Werte ans Ende verschieben
                  if (dateB === null) return -1;
                  return dateB.getTime() - dateA.getTime(); // Neueste zuerst
          // Funktion extractDatum // Hilfsfunktion zur Extraktion des Datums        // Beispieltext: "01.12.24 12:04:55 Uhr - SABOTAGE_ALARM ..."
          function extractDate(text) {
              if (!text || typeof text !== "string") {
                  LOG(`extractDate Fehler: Ungueltiger Eingabetext: ${text}`, "Fehler", "extractDate", 2);
                  return new Date(0); // Fallback auf ein Default-Datum
              const match = text.match(/^(\d{2})\.(\d{2})\.(\d{2}) (\d{2}):(\d{2}):(\d{2})/);    // Regulaerer Ausdruck, um Datum und Uhrzeit zu extrahieren
              if (!match) {
                  LOG(`extractDate Fehler: Kein gueltiges Datum gefunden: ${text}`, "Fehler", "extractDate", 2);
              const [_, day, month, year, hours, minutes, seconds] = match;    // Teile aus dem Match extrahieren
              const fullYear = year.length === 2 ? `20${year}` : year;    // Jahr vervollstaendigen, falls noetig
              const dateString = `${fullYear}-${month}-${day}T${hours}:${minutes}:${seconds}`;    // Erstellen des Datums im Format "YYYY-MM-DDTHH:mm:ss"
              const date = new Date(dateString);    // Umwandlung in ein Date-Objekt
              if (isNaN(date.getTime())) {    // ueberpruefen, ob das Datum gueltig ist
                  LOG(`extractDate Fehler: Ungueltiges Datum erzeugt: ${dateString}`, "Fehler", "extractDate", 2);
                  return new Date(0);
              return date;
          // Funktion GenerateTEXT_Datenpunkte // Generiert TEXT format aus den JSON Arrays und speichert diese in die Datenpunkte
          function GenerateTEXT_Datenpunkte() {
              LOG(`Routine wird ausgefuehrt`, "Ablauf", "GenerateTEXT_Datenpunkte", 2);
              if(!UpdateTEXT_Datenpunkte){return}; // wenn keine TEXT-Datenpunkte updates erfolgen sollen nicht ausfuehren
              let  SMAktuellMessageLangTEXT = [], SMHistMessageLangTEXT = [],SMAktuellMessageKurzTEXT = [];
              HistorischeMeldungenJSON.forEach(Meldung => {        // Iteriere durch HistorischeMeldungenJSON und extrahiere die status_message_Lang
                  SMHistMessageLangTEXT.push(Meldung.status_message_Lang + " - Meldung aufgehoben: " + Meldung.SM_aufgehoben_seit + "<br>");            // Status-Lang-Text extrahieren und ins Array pushen
              setState(id_Text_Servicemeldung_History, SMHistMessageLangTEXT.join(''));        // Umwandlung des Arrays in einen String und Speichern im Datenpunkt id_Text_ServicemeldungLang
              AktuelleMeldungenJSON.forEach(Meldung => {        // Iteriere durch AktuelleMeldungenJSON und extrahiere die status_message_Pure und status_message_Lang
                  if (Meldung.status_message_Pure) {
                      SMAktuellMessageKurzTEXT.push(Meldung.datum_seit + " " + Meldung.status_message_Pure + "<br>"); // Status-Kurz-Text extrahieren und ins Array pushen
                  if (Meldung.status_message_Lang) {
                      SMAktuellMessageLangTEXT.push(Meldung.status_message_Lang + "<br>"); // Status-Lang-Text extrahieren und ins Array pushen
              setState(id_Text_ServicemeldungKurz, SMAktuellMessageKurzTEXT.join(''));        // Umwandlung der Arrays in Strings und Speichern in den entsprechenden Datenpunkten
              setState(id_Text_ServicemeldungLang, SMAktuellMessageLangTEXT.join(''));
          // Funktion generateHtmlTable // Funktion, aus den JSON Tabellen ein HTML-Format erzeugt
          function generateHtmlTable(data, HistOderAkt) {
              if (!UpdateHTML_Datenpunkte) { return; }        // Keine Updates, wenn HTML-Datenpunkte deaktiviert sind
              const uniqueClass = "custom-table";    // Eindeutige Klasse für die Tabelle
              const cellPadding = '6px';
              // Baue die Tabelle mit einer eindeutigen Klasse auf
              let table = `
                  <table class="${uniqueClass}" style="
                      width: 100%;
                      border-collapse: collapse; /* Rahmen zusammenführen */
                      border-spacing: 0; /* Kein Abstand zwischen Zellen */
              // Scoped Stile für die Tabelle
              table += `
                  <style>
                      .${uniqueClass} th, .${uniqueClass} td {
                          padding: ${cellPadding};
                          ${useBorderAll ? `border: ${borderWidth} solid ${borderColor};` : 'border: none;'} /* Innerer Rahmen basierend auf useBorderAll */
                      .${uniqueClass} thead th {
                          position: sticky;
                          top: 0;
                          background-color: ${headerColor};
                          color: ${headerTextColor};
                          z-index: 1;
                  </style>
              // Kopfzeile
              table += `
                  <thead>
                  <tr>
                      <th style="text-align: left;">Datum_Seit</th>
                      <th style="text-align: left;">Meldungsart</th>
                      <th style="text-align: left;">Name</th>
                      <th style="text-align: left;">GeraeteId</th>
                      <th style="text-align: left;">Status</th>
                      <th style="text-align: left;">Batterie</th>
                      <th style="text-align: left;">SM_aufgehoben_seit</th>
                  </tr>
                  </thead>
              // Tabellenkörper
              table += '<tbody>';
              data.forEach((item, index) => {
                  const rowColor = index % 2 === 0 ? evenRowColor : oddRowColor; // Farben der Zeilen
                  const textColor = index % 2 === 0 ? evenRowTextColor : oddRowTextColor; // Textfarbe
                  table += `
                  <tr style="background-color: ${rowColor}; color: ${textColor};">
                      <td>${item.datum_seit}</td>
                      <td>${item.meldungsart}</td>
                      <td>${item.common_name}</td>
                      <td>${item.GeraeteId}</td>
                      <td>${item.status_message_Pure}</td>
                      <td>${item.batterie_bezeichnung}</td>
                      <td>${item.SM_aufgehoben_seit}</td>
                  </tr>
              table += '</tbody>';
              table += '</table>';
              // Zustand setzen je nach HistOderAkt
              if (HistOderAkt === "AKT") {
                  setState(id_HTML_Servicemeldung_Aktuell, table);
              } else {
                  setState(id_HTML_Servicemeldung_History, table);
          // Funktion Refresh_History loescht die Historie - Ausloeser entweder subcription oder schedule
          function Refresh_History() {
              let jsonString = getState(id_JSON_Servicemeldung_Historie).val || '[]'; // zunaechst die JSON Eintraege
              HistorischeMeldungenJSON = HistorischeMeldungenJSON.filter(meldung => meldung.SM_aufgehoben_seit === "aktiv");    // Filtern der Meldungen, um nur die zu behalten, die den Wert "aktiv" in "SM_aufgehoben_seit" haben
              let updatedJsonString = JSON.stringify(HistorischeMeldungenJSON);    // Speichern der gefilterten historischen Meldungen zurueck in den Datenpunkt
              setState(id_JSON_Servicemeldung_Historie, updatedJsonString);
              Check_All("init")
          // Funktion schreibt einen Logeintrag in das Filesystem und auch in das interne Log-System
          function writelog(Name, GeraeteId, SMType, SMStatus, SMStatus_Text) {
              if (!SMProtokoll) return;
              const fs = require('fs');                     // enable write fuer externes log
              const logdate = formatDate(new Date(), "TT.MM.JJJJ");
              const logtime = formatDate(new Date(), "SS:mm:ss");
              const logEntry = `${logdate} ;${logtime} ;${Name} ;${GeraeteId} ; ${SMType} ;${SMStatus} ;${SMStatus_Text}\n`;
              const headerLine = "Datum;Uhrzeit;Name;ID-Name;Meldungssart;Status;Servicemeldung\n";
              fs.readFile(PathSMLog, 'utf8', function(err, data) {
                  if (!err) {
                      fs.appendFileSync(PathSMLog, logEntry, 'utf8');
                  } else {
                      LOG(`Logfile nicht gefunden - wird angelegt`, "Ablauf", "writelog", 0);
                      fs.writeFileSync(PathSMLog, headerLine + logEntry, 'utf8');
          // Funktion schreibt die Syste-Log-Eintraege in ein externes CSV - File
          function LOG(Message,Kategorie,Routine, Level, type) {
              if(type !== "warn" && type !== "error") {type = "info"}
              if (!SystemLog && debugLevel >= Level) { log(Message+" Routine:"+Routine,type); return;}     // Wenn SystemLog false ist und der Debug-Level hoeher oder gleich dem uebergebenen Level, schreibe normalen Logeintrag
              if  (Level === 0) { log(Message+" Routine:"+Routine,type);} // bei level 0 soll auf jeden fall auch in das normale log geschrieben werden
              if (SystemLog && debugLevel >= Level) {         // Wenn SystemLog true ist und der Debug-Level hoeher oder gleich dem uebergebenen Level
                  const now = new Date();
                  const logdate = `${now.getDate().toString().padStart(2, '0')}.${(now.getMonth() + 1).toString().padStart(2, '0')}.${now.getFullYear()}`;
                  const logtime = `${now.getHours().toString().padStart(2, '0')}:${now.getMinutes().toString().padStart(2, '0')}:${now.getSeconds().toString().padStart(2, '0')}:${now.getMilliseconds().toString().padStart(3, '0')}`;
                  const logEntry = `${logdate};${logtime};${Level};${Kategorie};${Routine};${Message}\n`;
                  const headerLine = "Datum;Uhrzeit;Debug Level;Kategorie;Routine;Log-Message\n";
                  const logFilePath = PathSystemLog || './defaultLog.csv'; // falls PathSystemLog nicht definiert ist, standardmaessigen Pfad verwenden
                  try {
                      if (!fs.existsSync(logFilePath)) {
                          log(`Routine:LOG - Logfile nicht gefunden - wird angelegt`,"info")
                          fs.writeFileSync(logFilePath, headerLine + logEntry, 'utf8');  // Datei erstellen und Header hinzufuegen
                      } else {
                          fs.appendFileSync(logFilePath, logEntry, 'utf8'); // Eintrag zum Logfile hinzufuegen
                  } catch (err) {
                      log(`Routine:LOG - Fehler beim Schreiben in das Logfile: ${err}`, "error"); // Fehler beim Schreiben
          // Funktion Create States
          async function CreateStates(callback) {
              LOG(`Routine wird ausgefuehrt`, "Ablauf", "CreateStates", 2);
              try {
                  if(UpdateTEXT_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                      await createStateAsync(id_Text_ServicemeldungLang, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen LangText', desc: 'LangText Servicemeldung' });
                      await createStateAsync(id_Text_ServicemeldungKurz, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen KurzText', desc: 'KurzText Servicemeldung' });
                      await createStateAsync(id_Text_Servicemeldung_History, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen History', desc: 'History Servicemeldung' });
                  if(UpdateHTML_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                      await createStateAsync(id_HTML_Servicemeldung_Aktuell, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen HTML-Text', desc: 'HTML-Text Servicemeldung' });
                      await createStateAsync(id_HTML_Servicemeldung_History, "", { read: true, write: true, type: 'string', name: 'Servicemeldungen HTML-History', desc: 'HTML-History Servicemeldung' });
                  await createStateAsync(id_JSON_Servicemeldung_Aktuell, "", { read: true, write: true, type: 'string', name: 'Aktuelle Servicemeldungen als JSON', desc: 'Vergangene Servicemeldung JSON' });
                  await createStateAsync(id_JSON_Servicemeldung_Historie, "", { read: true, write: true, type: 'string',name: 'Servicemeldungen History', desc: 'History Servicemeldung' });
                  await createStateAsync(id_Button_Refresh_Historie, false, { read: true, write: true, type: 'boolean', name: 'Refresh Button History', desc: 'Loescht die Historie Servicemeldungem wenn true' });
                  for (const { alarmtype, count, Datenpunkt } of Zaehler) {               // Schleife ueber das Zaehler-Array und anlegen der States
                      await createStateAsync(Datenpunkt, count, {read: true, write: true,type: 'number',name: `Servicemeldungen Anzahl ${alarmtype}`,desc: `Anzahl ${alarmtype} Servicemeldungen`});
              if (callback) await callback();         // Aufruf des Callbacks nach Abschluss aller Operationen
                  } catch (error) {
                  LOG(`Kategorie:WARN; Routine:CreateStates; Routine Create States - Fehler beim Erstellen der Zustaende: ${error}`, 0, "warn");
              if (!UpdateTEXT_Datenpunkte) {
                  if (existsState(id_Text_ServicemeldungLang)) { deleteState(id_Text_ServicemeldungLang); }
                  if (existsState(id_Text_ServicemeldungKurz)) { deleteState(id_Text_ServicemeldungKurz); }
                  if (existsState(id_Text_Servicemeldung_History)) { deleteState(id_Text_Servicemeldung_History); }
              if(!UpdateHTML_Datenpunkte) {    // nur wenn Text-Datenpunkte auch gewuenscht sind
                  if (existsState(id_HTML_Servicemeldung_Aktuell)) { deleteState(id_HTML_Servicemeldung_Aktuell); }
                  if (existsState(id_HTML_Servicemeldung_History)) { deleteState(id_HTML_Servicemeldung_History); }
            looxer01 @Eduard77 last edited by
            @edis77
            ok, kein Problem. Ich erstelle eine Version, die aber dann schon final ist.
            Ich bin sicher, dass das beschriebene Problem damit behoben wird.
            kann aber Morgen werden.
            vG Looxer
              looxer01 last edited by looxer01
              Hi Version 3.21 ist online
              • ACHTUNG die JSON fuer aktuelle und historische Servicemeldungen wurde um ein Feld erweitert. Bitte sorgt dafür, dass ihr keine aktuellen STICKY-Meldungen habt, wenn diese Script-Version aktiviert wird (gibt dann Fehlermeldungen). Ansonsten kann die Version ohne Probleme aktiviert werden.
              • Tabelle "instanceIds" um feld "Messaging" erweitert(Ausschalten von Nachrichten Adapter/Instanz Kombi). Somit kann z.B. für die Gruppenmeldungen generell ein Nachrichtenversand verhindert werden
              • DataPoint Filter für selektor hinzugefuegt. Der Filter laesst sich flexibel mit wildcards in einer Tabelle einstellen. Notwendig wurde dieser für den HM-AccessPoint, um Datenpunkte mit Alarmtypes auszuschliessen, die aber nur für Gruppen relevant waren und nicht für einzelne Geräte
              vG Looxer
              @Edis77
              Diese Version sollte dein Problem beheben.
              Eduard77 1 Reply Last reply Reply Quote 1
              • Eduard77
                Eduard77 @looxer01 last edited by
                @looxer01
                Danke für das Anpassung.
                Skript läuft und keine Fehler im LOG.
                  Version 3.30 ist online mit der Möglichkeit der Sprachausgabe.
                  Ich schreibe gerade für mich ein Alarmanlagenscript. Sprachausgabe ist eine von vielen Anforderungen.
                  Dabei nutze ich viele Elemente des Servicemeldungsscripts. Daher habe ich die Sprachausgabe dem Servicemeldungsscript jetzt hinzugefügt.
                  Die Sprachausgabe erfolgt über den "sayit" Adapter.
                  Eine Uhrzeit von bis kann konfiguriert werden, damit es Nachts nicht zu Störungen kommt.
                  Ich meine, dass die Sprachausgabe insbesondere bei Sabotage Sinn macht.
                  Anmerkung: im sayit Adapter kann je instanz ein anderes ausgabegerät festgelegt werden.
                  Im servicemeldungsscript können mehrere Instanzen konfiguriert werden - das passt also.
                  Die Konfig findet ihr in der Tabelle messenger scope und die Uhrzeiten für die Sprachausgaben darunter.
                  noch ein Hinweis:
                  im SayIt Adapter kann man "Browser" als Ausgabegerät konfigurieren. Damit können also eventuelle Tablets z.B. mit dem FullyKioskBrowser als Ausgabegeräte genutzt werden
                  vG Looxer
                  • rantanplan
                    rantanplan @looxer01 last edited by
                    @looxer01 Hallo
                    Ich habe hier eine Servicemeldung die Dein Script nicht mitbekommt.
                    Bei dem Gerät handelt es sich um ein HM-Classic "HM-CC-RT-DN".
                    Die Servicemeldung lautet: "Leere Batterie".
                    In Deinem Script habe ich mal folgendes hinzugefügt.
                        'HM-CC-RT-DN': {
                            7: 'Fehlstellung Ventil',
                    	8: 'Leere Batterie'       //von mir hinzugefügt !!!
                    Hat aber nichts gebracht. (Vielleicht weil die Meldung schon vorhanden ist?)
                      looxer01 @rantanplan last edited by looxer01
                      @rantanplan
                      kannst du mal die Objektliste für das Gerät checken ?
                      In den Objektdaten stehen ja die möglichen Status. (also mindestens die 0 - 7)
                      Ich muss halt wissen welcher Datenpunkt den Status für die leere Batterie mit welcher Ausprägung enthält.
                      (leider besitze ich kein classic mehr)
                      Kannst du das Protokoll laufen lassen mit debug level 2 und posten ?
                      muss der Zeitpunkt sein bei dem die CCU die Servicemeldung lowbat erzeugt.
                      vG Looxer
                      Edit: der relevante Datenpunkt müsste FAULT_REPORTING sein, wenn es der ist, den du im Blick hast.
                      Allerdings war ich der Meinung, dass es auch einen "lowbat"-Datenpunkt geben müsste.
                        emil70 @looxer01 last edited by emil70
                        @looxer01
                        Der LOWBAT Datenpunkt sieht so aus
                          "type": "state",
                          "common": {
                            "name": "Heizung Büro:0.LOWBAT",
                            "role": "indicator.lowbat",
                            "def": false,
                            "type": "boolean",
                            "read": true,
                            "write": false
                          "native": {
                            "DEFAULT": false,
                            "FLAGS": 9,
                            "ID": "LOWBAT",
                            "MAX": true,
                            "MIN": false,
                            "OPERATIONS": 5,
                            "TAB_ORDER": 3,
                            "TYPE": "BOOL",
                            "UNIT": ""
                          "from": "system.adapter.hm-rega.0",
                          "user": "system.user.admin",
                          "ts": 1733764617734,
                          "_id": "hm-rpc.0.NEQ0871182.0.LOWBAT",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                            "owner": "system.user.admin",
                        der LOWBAT_ALARM Datenpunkt so
                          "type": "state",
                          "common": {
                            "name": "Heizung Büro:0.LOWBAT_ALARM",
                            "type": "number",
                            "role": "indicator.alarm",
                            "read": true,
                            "write": true,
                            "def": 0,
                            "states": {
                              "0": "NO ALARM",
                              "1": "ALARM",
                              "2": "ACKNOWLEDGED"
                          "native": {
                            "Name": "Heizung Büro:0.LOWBAT_ALARM",
                            "TypeName": "ALARM",
                            "DP": "16869"
                          "ts": 1733806812677,
                          "_id": "hm-rpc.0.NEQ0871182.0.LOWBAT_ALARM",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        der BATTERY_STATE Datenpunkt so
                          "type": "state",
                          "common": {
                            "name": "Heizung Büro.BATTERY_STATE",
                            "role": "value.voltage",
                            "def": 0,
                            "type": "number",
                            "read": true,
                            "write": false,
                            "min": 1.5,
                            "max": 4.6,
                            "unit": "V"
                          "native": {
                            "CONTROL": "NONE",
                            "DEFAULT": 0,
                            "FLAGS": 1,
                            "ID": "BATTERY_STATE",
                            "MAX": 4.6,
                            "MIN": 1.5,
                            "OPERATIONS": 5,
                            "TAB_ORDER": 2,
                            "TYPE": "FLOAT",
                            "UNIT": "V"
                          "ts": 1733764617915,
                          "_id": "hm-rpc.0.NEQ0871182.4.BATTERY_STATE",
                          "acl": {
                            "object": 1636,
                            "state": 1636,
                        Hoffe das ist das was du brauchst
                          looxer01 @emil70 last edited by looxer01
                          @emil70
                          @rantanplan
                          vielen Dank, das ist es was ich brauchte
                          Allerdings stelle ich fest, dass es sich hier um einen Standardfall handelt.
                          LOWBAT_ALARM wird mit 1 gesetzt womit das Gerät selektiert werden sollte, wie andere classic Geräte auch.
                          Die erste Frage ist, ob das Script überhaupt ausgelöst wird. Das hängt mit der GeraeteIDTrigger einstellung zusammen
                          Entweder weil der Datenpunkt hm-rega.0.maintenance verändert wurde (bei GeraeteIDTrigger = false) oder
                          weil die 1 im Datenpunkt LOWBAT_ALARM gesetzt wurde (bei GeraeteIDTrigger = true).
                          Wenn es auslöst, dann hilft ein Protokoll. Das kann ja auch über längere Zeit aktiv gesetzt werden und als Datei abgespeichert werden.
                          So stört es dann nicht im Protokoll und du brauchst nicht danach im Protokoll zu suchen.
                          vG Looxer
                          rantanplan 1 Reply Last reply Reply Quote 0
                          • rantanplan
                            @looxer01
                            Ich habe mal im Script debugLevel auf 2 gesetzt.
                            GeraeteId steht bei mir auf false.
                            Dann habe ich neue Batterien eingesetzt.
                            Meldung auf der CCU3 weg.
                            Dann wieder die alten Batterien eingesetzt.
                            Systemmeldung auf der CCU3 "Leere Batterie"
                            Hier das LOG.
                            ServicemeldungenSystemLog.csv
                            Aktuell sind noch die leeren Batterien drin.
                            Sieht so aus:
                            Object Daten WZ-VD-Regal:4.FAULT_REPORTING
                             "type": "state",
                             "common": {
                               "def": 0,
                               "type": "number",
                               "read": true,
                               "write": false,
                               "min": 0,
                               "max": 7,
                               "states": {
                                 "0": "NO_FAULT",
                                 "1": "VALVE_TIGHT",
                                 "2": "ADJUSTING_RANGE_TOO_LARGE",
                                 "3": "ADJUSTING_RANGE_TOO_SMALL",
                                 "4": "COMMUNICATION_ERROR",
                                 "5": "",
                                 "6": "LOWBAT",
                                 "7": "VALVE_ERROR_POSITION"
                               "role": "indicator",
                               "name": "WZ-VD-Regal:4.FAULT_REPORTING"
                             "native": {
                               "CONTROL": "NONE",
                               "DEFAULT": 0,
                               "FLAGS": 9,
                               "ID": "FAULT_REPORTING",
                               "MAX": 7,
                               "MIN": 0,
                               "OPERATIONS": 5,
                               "TAB_ORDER": 1,
                               "TYPE": "ENUM",
                               "UNIT": "",
                               "VALUE_LIST": [
                                 "NO_FAULT",
                                 "VALVE_TIGHT",
                                 "LOWBAT",
                             "ts": 1740918410792,
                             "_id": "hm-rpc.0.OEQ2637929.4.FAULT_REPORTING",
                             "acl": {
                               "object": 1636,
                               "state": 1636,
                            Object Daten WZ-VD-Regal:4.FAULT_REPORTING-6_ALARM
                             "type": "state",
                             "common": {
                               "name": "WZ-VD-Regal:4.FAULT_REPORTING-6_ALARM",
                               "type": "number",
                               "read": true,
                               "write": true,
                               "def": 0,
                               "states": {
                                 "0": "NO ALARM",
                                 "1": "ALARM",
                                 "2": "ACKNOWLEDGED"
                             "native": {
                               "Name": "WZ-VD-Regal:4.FAULT_REPORTING-6_ALARM",
                               "DP": "16978"
                             "ts": 1548955628248,
                             "_id": "hm-rpc.0.OEQ2637929.4.FAULT_REPORTING-6_ALARM",
                             "acl": {
                               "object": 1636,
                               "state": 1636,
                            Was kann ich noch tun?
                            L 3 Replies Last reply Reply Quote 0
                              @rantanplan
                              @rantanplan sagte in [Vorlage] Servicemeldungen Volume2:
                              im moment nichts. Ich erstelle einen Fix und poste ihn hier.
                              Ursache ist, so glaube ich, klar.
                              vG Looxer
                                @rantanplan
                                kannst du diese Tabelle austauschen und dann nochmal mit debug laufen lassen ?
                                    { key: 'FAULT_REPORTING',                   suffixes: ['FAULT_REPORTING','FAULT_REPORTING-1_ALARM','FAULT_REPORTING-2_ALARM','FAULT_REPORTING-3_ALARM','FAULT_REPORTING-4_ALARM','FAULT_REPORTING-5_ALARM','FAULT_REPORTING-6_ALARM'] },
                                Die Änderung befindet sich in Zeile 9.
                                  @rantanplan
                                  ignoriere die voherige message.
                                  Nutze stattdessen die angehängte Version. Ich musste noch ein paar Codezeilen hinzufügen.
                                  Es konnte gar nicht funktionieren
                                  Servicemeldungen_Vol2_3-30_Rantanplan.txt
                                  rantanplan 2 Replies Last reply Reply Quote 0
                                  • rantanplan
                                    @looxer01 sagte in [Vorlage] Servicemeldungen Volume2:
                                    @rantanplan
                                    Zu spät😊
                                    Mit leeren Batterien kam die Meldung ".....Ventil blockiert"
                                    Damit meine "Arbeit" nicht umsonst war, hier das Log.😬
                                    Probiere jetzt Dein geändertes Script.
                                    • rantanplan
                                      @looxer01
                                      Nach dem Script-Start wird "Einstellbereich Ventil zu gross" gemeldet
                                      Auf der CCU3 keine Servicemeldung.
                                      Hier das Log.
                                      Habe auch mal das andere Log aktiviert.
                                      ServicemeldungenVol2.csv
                                      Sehe gerade, dass "FAULT_REPORTING-6_ALARM" in ioBroker tatsächlich auf '2' steht. Warum auch immer.
                                      CCU3 sagt "alles ok".
                                      Tausche jetzt nochmal die Batterien.
                                        @rantanplan
                                        • es wäre gut zu wissen wie Object Daten WZ-VD-Regal:4.FAULT_REPORTING ausgeprägt ist. Denn dort gibt es die status 1 - 7. bei den anderen nicht. (das hatte ich leider falsch gesehen)
                                          In der Regel werden die ALARM-Datenpunkte augelöst.
                                        • Ein quick Fix wäre 'FAULT_REPORTING-6_ALARM' unter den AlarmType LowBat zu listen. Dann fehlen aber immer noch die anderen Alarme.
                                        ich muss nochmal nachdenken.
                                        EDIT
                                        ok, nachgedacht.
                                        Der Ansatz wäre
                                        • 'FAULT_REPORTING-6_ALARM' unter lowbat zu führen. Dann bekommst du das auch klassifiziert als lowbat und nicht als 'FaultMessage"
                                        • Die anderen werde ich dann vom status her als FaultMessages führen und die status 1-7 (ohne 6) entsprechend als status messages entsprechend der Tabelle: faultMessages aus dem Script darstellen
                                        brauche ich jetzt aber ein wenig Zeit für
                                          @rantanplan
                                          ich habe eine neue Version gebaut und hoffe, dass es jetzt ok ist.
                                          Du solltest jetzt eine lowbat message erhalten für dieses gerät.
                                          für alle anderen messages (Ventilstellung etc) erhälts du "Fault Messages"
                                          Servicemeldungen_Vol2_3-30_Rantanplan2.txt
                                          Falls ok, werde ich das in die nächste Version übernehmen.
                                          vG Looxer
                                          • rantanplan
                                            @rantanplan
                                            Irgendetwas hakt noch. (Sorry)
                                            Leztes Script gestartet.
                                            Leere Batterien noch im Gerät.
                                            CCU3 zeigt "Leere Batterie"
                                            Script JSONAktuelleSM "Keine passende Meldung......."
                                               "datum_seit": "20.03.25 13:12:21 Uhr",
                                               "meldungsart": "FAULT_REPORTING-6_ALARM",
                                               "common_name": "Wohnzimmer-VD-Regal",
                                               "GeraeteId": "OEQ2637929",
                                               "status": 1,
                                               "status_message_Lang": "20.03.25 13:12:21 Uhr - FAULT_REPORTING-6_ALARM - Wohnzimmer-VD-Regal - (OEQ2637929) - 1 - Keine passende Meldung fuer MessageType: \"FAULT_REPORTING-6_ALARM\", Adapter: \"hm-rpc\", Status: \"1\". - Batteriebezeichnung: 2x LR6/AA",
                                               "status_message_Pure": "Keine passende Meldung fuer MessageType: \"FAULT_REPORTING-6_ALARM\", Adapter: \"hm-rpc\", Status: \"1\". - Batteriebezeichnung: 2x LR6/AA",
                                               "batterie_bezeichnung": "2x LR6/AA",
                                               "SM_aufgehoben_seit": "aktiv",
                                               "DataPoint": "hm-rpc.0.OEQ2637929.4.FAULT_REPORTING-6_ALARM"
                                            Über Telegram kam keine Meldung!!!
                                            Hier das LOG.
                                            1.2k
                                            224
                                            41978
