    3. Einsteigerfragen
    4. Installation
    5. Zigbee.0: You need save and run adapter before pairing!
    • Asgothian
      Asgothian Developer @nilli last edited by
      @nilli sagte in Zigbee.0: You need save and run adapter before pairing!:
      Was könnte ich noch zur Diagnose prüfen ?
      Bist du sicher das du da die Fehlermeldungen nicht heraus gefiltert hast ? Es muss Fehlermeldungen geben wenn der Adapter sich beendet.
      Widerhol bitte den Test oben, stell aber vor dem Start den Zigbee-Adapter auf debug, nicht auf Info.
      A.
      • N
        nilli @Asgothian last edited by
        @asgothian said in Zigbee.0: You need save and run adapter before pairing!:
        Protokoll auf debug gestellt 👍 . Es finden sich aber keine weiteren Einträge nach dem neustart.
        2025-03-18 22:39:47.464  - ^[[32minfo^[[39m: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
        2025-03-18 22:39:51.669  - ^[[32minfo^[[39m: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
        2025-03-18 22:39:58.499  - ^[[32minfo^[[39m: host.raspi5 "system.adapter.zigbee.0" disabled
        2025-03-18 22:39:58.500  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2025-03-18 22:39:58.503  - ^[[32minfo^[[39m: zigbee.0 (54685) Got terminate signal TERMINATE_YOURSELF
        2025-03-18 22:39:58.545  - ^[[32minfo^[[39m: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
        2025-03-18 22:39:58.504  - ^[[32minfo^[[39m: zigbee.0 (54685) cleaned everything up...
        2025-03-18 22:39:58.508  - ^[[32minfo^[[39m: zigbee.0 (54685) Zigbee: disabling joining new devices.
        2025-03-18 22:39:58.545  - ^[[33mwarn^[[39m: zigbee.0 (54685) Failed to stop zigbee during startup
        2025-03-18 22:39:58.546  - ^[[32minfo^[[39m: zigbee.0 (54685) terminating
        2025-03-18 22:39:58.546  - ^[[32minfo^[[39m: zigbee.0 (54685) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-03-18 22:39:58.554  - ^[[32minfo^[[39m: zigbee.0 (54685) debug devices set to []
        2025-03-18 22:39:58.626  - ^[[35msilly^[[39m: fritzdect.0 (22085) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Syst>
        2025-03-18 22:39:59.004  - ^[[32minfo^[[39m: zigbee.0 (54685) terminating
        2025-03-18 22:39:59.067  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-03-18 22:41:21.551  - ^[[32minfo^[[39m: host.raspi5 "system.adapter.zigbee.0" enabled
        2025-03-18 22:41:21.770  - ^[[35msilly^[[39m: fritzdect.0 (22085) Objects system redis pmessage system.config/cfg.o.system.config:{"_id":"system.config","type":"config","common":{"name":{"en":"System configuration","de":"Syst>
        2025-03-18 22:41:21.840  - ^[[32minfo^[[39m: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 56000
        2025-03-18 22:41:23.450  - ^[[32minfo^[[39m: zigbee.0 (56000) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
        2025-03-18 22:41:23.487  - ^[[32minfo^[[39m: zigbee.0 (56000) delete old Backup files. keep only last 10
        2025-03-18 22:41:23.489  - ^[[32minfo^[[39m: zigbee.0 (56000) Starting Zigbee  npm ...
        2025-03-18 22:41:23.624  - ^[[32minfo^[[39m: zigbee.0 (56000) Installed Version: iobroker.zigbee@1.10.14
        2025-03-18 22:43:55.876  - ^[[34mdebug^[[39m: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
        2025-03-18 22:43:55.876  - ^[[34mdebug^[[39m: fritzdect.0 (22085) __________________________
        • Asgothian
          Asgothian Developer last edited by
          @nilli Da ist etwas systematisch auf Deinem System nicht in Ordnung. Bist du sicher das du die 5 Minuten gewartet hast bevor Du das Log geladen hast ? Im Log selber ist davon wenig zu sehen.
          Ansonsten bitte :
          • Zigbee-Adapter deinstallieren
          • sicherstellen das im NPM baum sowohl der zigbee-herdsman als auch die zigbee-herdsman-converters nicht mehr vorhanden sind
          • dann den Zigbee Adapter neu installieren
          • Dann den Zigbee-Adapter starten (so wie oben) und das Log posten.
          A.
          • N
            Danke für die Hilfe ! Wie überprüfe ich das ?
            • Asgothian
              Asgothian Developer @nilli last edited by Asgothian
              @nilli Im ioBroker Verzeichnis:
              npm list -a | grep -e zigbee darf keine Ausgabe liefern.
              Du kannst vor der de-installation verifizieren das der Befehl funktioniert - er müsste etwas ähnliches wie dieses liefern:
              iobroker.zigbee@2.0.4 /Users/ae/LocalDocuments/GitHub/ioBroker.zigbee
              ├─┬ zigbee-herdsman-converters@23.6.0
              │ └── zigbee-herdsman@3.3.2 deduped
              └─┬ zigbee-herdsman@3.3.2
              Wichtig - das ist von meinem Entwicklungssystem, Versionsnummern und Pfade werden bei Dir anders sein.
              A.
              • N
                @asgothian
                nils@raspi5:/opt/iobroker $ npm list -a | grep -e zigbee
                └─┬ iobroker.zigbee@1.10.14
                  ├─┬ zigbee-herdsman-converters@20.58.0
                  │ └── zigbee-herdsman@2.1.9 deduped
                  └─┬ zigbee-herdsman@2.1.9
                Adapter deinstalliert
                Inhalt von Ordner /opt/iobroker/iobroker-data/zigbee_0 gelöscht
                Adapter neu instaliert und konfiguruert mit :
                /dev/ttyUSB0
                Typ : TI Z-Stack/CCxxxx
                Baud : 115200
                Erweiterte PAN ID: abcdabcdabcdabcd
                Pan ID : 6754
                Kanal 11
                Transportschlüssel : 01030507090B0D0F00020406080A0C0D
                Leider immer noch das gleiche Verhalten 😧
                Merkwürdig : Ordner /opt/iobroker/iobroker-data/zigbee_0 weiterhin leer ... 🤔
                2025-03-19 10:23:59.374 - debug: fritzdect.0 (22085) With 087610147624got the following to parse{"devicestats":{"voltage":"","power":"","energy":""}}
                2025-03-19 10:27:53.294 - info: host.raspi5 iobroker del zigbee
                2025-03-19 10:27:54.886 - info: host.raspi5 iobroker Delete adapter "zigbee"
                2025-03-19 10:27:54.895 - info: host.raspi5 iobroker host.raspi5 Counted 1 instances of zigbee
                2025-03-19 10:27:54.911 - info: host.raspi5 iobroker host.raspi5 Counted 1 meta of zigbee
                2025-03-19 10:27:54.913 - info: host.raspi5 iobroker host.raspi5 Counted 1 adapter for zigbee
                2025-03-19 10:27:54.921 - info: host.raspi5 iobroker host.raspi5 Counted 2 channels of zigbee
                2025-03-19 10:27:54.925 - info: host.raspi5 iobroker host.raspi5 Counted 8 states of zigbee
                2025-03-19 10:27:54.929 - info: host.raspi5 iobroker host.raspi5 Counted 15 states of system.adapter.zigbee
                2025-03-19 10:27:54.932 - info: host.raspi5 iobroker host.raspi5 Counted 8 states (io.zigbee.*) from states
                2025-03-19 10:27:54.937 - info: host.raspi5 iobroker host.raspi5 Counted 16 states (system.adapter.zigbee.*) from states
                2025-03-19 10:27:55.225 - info: host.raspi5 iobroker host.raspi5 Counted 1 objects of zigbee
                2025-03-19 10:27:56.805 - info: host.raspi5 iobroker host.raspi5 file zigbee.admin deleted
                2025-03-19 10:27:56.808 - info: host.raspi5 iobroker host.raspi5 object zigbee deleted
                2025-03-19 10:27:56.812 - info: host.raspi5 iobroker host.raspi5 object zigbee.admin deletedhost.raspi5 Deleting 30 object(s).
                2025-03-19 10:27:56.867 - info: host.raspi5 object deleted system.adapter.zigbee.0
                2025-03-19 10:27:56.867 - info: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2025-03-19 10:27:56.870 - info: zigbee.0 (82664) Got terminate signal TERMINATE_YOURSELF
                2025-03-19 10:27:56.869 - info: host.raspi5 iobroker host.raspi5 Deleting 24 state(s).
                2025-03-19 10:27:56.871 - info: zigbee.0 (82664) cleaned everything up...
                2025-03-19 10:27:56.872 - info: zigbee.0 (82664) Zigbee: disabling joining new devices.
                2025-03-19 10:27:56.873 - warn: zigbee.0 (82664) Failed to stop zigbee during startup
                2025-03-19 10:27:56.873 - info: zigbee.0 (82664) terminating
                2025-03-19 10:27:56.874 - info: zigbee.0 (82664) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-03-19 10:27:56.912 - info: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
                2025-03-19 10:27:57.371 - info: zigbee.0 (82664) terminating
                2025-03-19 10:27:57.405 - info: host.raspi5 instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                2025-03-19 10:27:57.405 - info: host.raspi5 Do not restart adapter system.adapter.zigbee.0 because desired by instance
                2025-03-19 10:28:01.292 - info: host.raspi5 iobroker
                2025-03-19 10:28:01.293 - info: host.raspi5 iobroker removed 22 packages in 4s200 packages are looking for funding run `npm fund` for details
                2025-03-19 10:28:02.320 - info: host.raspi5 iobroker exit 0
                2025-03-19 10:28:55.926 - debug: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
                2025-03-19 10:28:59.038 - debug: fritzdect.0 (22085) With 087610147624got the following to parse{"devicestats":{"voltage":"","power":"","energy":""}}
                2025-03-19 10:29:29.781 - info: host.raspi5 iobroker add zigbee --host raspi5
                2025-03-19 10:29:31.948 - info: host.raspi5 iobroker NPM version: 10.8.2
                2025-03-19 10:29:31.950 - info: host.raspi5 iobroker Installing iobroker.zigbee@1.10.14... (System call)
                2025-03-19 10:29:49.217 - info: host.raspi5 iobroker
                2025-03-19 10:29:49.217 - info: host.raspi5 iobroker added 22 packages in 17s202 packages are looking for funding run `npm fund` for details
                2025-03-19 10:29:49.278 - info: host.raspi5 iobroker host.raspi5 install adapter zigbee
                2025-03-19 10:29:49.444 - info: host.raspi5 iobroker upload [333] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                2025-03-19 10:29:51.617 - info: host.raspi5 iobroker upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                2025-03-19 10:29:52.013 - info: host.raspi5 iobroker upload [250] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/cc2538_router_v1.png img/cc2538_router_v1.png image/png
                2025-03-19 10:29:52.535 - info: host.raspi5 iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hue-smart-button.png img/hue-smart-button.png image/png
                2025-03-19 10:29:52.938 - info: host.raspi5 iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/lifecontrol_lamp.png img/lifecontrol_lamp.png image/png
                2025-03-19 10:29:53.361 - info: host.raspi5 iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_fuzo_outdoor_wall_light.png img/philips_fuzo_outdoor_wall_light.png image/png
                2025-03-19 10:29:53.424 - info: host.raspi5 iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_argenta_4.png img/philips_hue_argenta_4.png image/png
                2025-03-19 10:29:53.452 - info: host.raspi5 iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_gu10_ambiance.png img/philips_hue_gu10_ambiance.png image/png
                2025-03-19 10:29:53.487 - info: host.raspi5 iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/philips_hue_lwv001.png img/philips_hue_lwv001.png image/png
                2025-03-19 10:29:53.515 - info: host.raspi5 iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/previous_track.png img/previous_track.png image/png
                2025-03-19 10:29:53.542 - info: host.raspi5 iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/sensor_philipshue.png img/sensor_philipshue.png image/png
                2025-03-19 10:29:53.570 - info: host.raspi5 iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/smartthings_motion.png img/smartthings_motion.png image/png
                2025-03-19 10:29:53.602 - info: host.raspi5 iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ts0203.png img/ts0203.png image/png
                2025-03-19 10:29:53.811 - info: host.raspi5 iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_tyzs1l.png img/tuya_tyzs1l.png image/png
                2025-03-19 10:29:53.818 - info: host.raspi5 iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unavailable.png img/unavailable.png image/png
                2025-03-19 10:29:53.825 - info: host.raspi5 iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/unknown.png img/unknown.png image/png
                2025-03-19 10:29:53.832 - info: host.raspi5 iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/wemo.png img/wemo.png image/png
                2025-03-19 10:29:53.839 - info: host.raspi5 iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_plug_eu.png img/xiaomi_plug_eu.png image/png
                2025-03-19 10:29:53.846 - info: host.raspi5 iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/xiaomi_wireless_switch.png img/xiaomi_wireless_switch.png image/png
                2025-03-19 10:29:53.857 - info: host.raspi5 iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27.png img/zbt_e27.png image/png
                2025-03-19 10:29:53.863 - info: host.raspi5 iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_e27_rgbw.png img/zbt_e27_rgbw.png image/png
                2025-03-19 10:29:53.869 - info: host.raspi5 iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_led_panel.png img/zbt_led_panel.png image/png
                2025-03-19 10:29:53.875 - info: host.raspi5 iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zbt_smart_switch.png img/zbt_smart_switch.png image/png
                2025-03-19 10:29:53.882 - info: host.raspi5 iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/zemismart_sw2.png img/zemismart_sw2.png image/png
                2025-03-19 10:29:53.888 - info: host.raspi5 iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index.html index.html text/html
                2025-03-19 10:29:53.900 - info: host.raspi5 iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/index_m.html index_m.html text/html
                2025-03-19 10:29:53.913 - info: host.raspi5 iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/moment.min.js moment.min.js application/javascript
                2025-03-19 10:29:53.924 - info: host.raspi5 iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/shuffle.min.js shuffle.min.js application/javascript
                2025-03-19 10:29:53.934 - info: host.raspi5 iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/tab_m.html tab_m.html text/html
                2025-03-19 10:29:53.946 - info: host.raspi5 iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.css vis-network.min.css text/css
                2025-03-19 10:29:53.960 - info: host.raspi5 iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/vis-network.min.js vis-network.min.js application/javascript
                2025-03-19 10:29:53.979 - info: host.raspi5 iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                2025-03-19 10:29:53.992 - info: host.raspi5 iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                2025-03-19 10:29:54.000 - info: host.raspi5 iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                2025-03-19 10:29:54.038 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee created/updated
                2025-03-19 10:29:54.039 - info: host.raspi5 iobroker Updating objects from io-package.json for adapter "zigbee" with version "1.10.14"
                2025-03-19 10:29:54.067 - info: host.raspi5 iobroker host.raspi5 create instance zigbee
                2025-03-19 10:29:54.071 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.alive created
                2025-03-19 10:29:54.074 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.connected created
                2025-03-19 10:29:54.077 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.compactMode created
                2025-03-19 10:29:54.080 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.cpu created
                2025-03-19 10:29:54.083 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.cputime created
                2025-03-19 10:29:54.087 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.memHeapUsed created
                2025-03-19 10:29:54.090 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.memHeapTotal created
                2025-03-19 10:29:54.093 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.memRss created
                2025-03-19 10:29:54.096 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.uptime created
                2025-03-19 10:29:54.099 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.inputCount created
                2025-03-19 10:29:54.102 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.outputCount created
                2025-03-19 10:29:54.105 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.eventLoopLag created
                2025-03-19 10:29:54.108 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.sigKill created
                2025-03-19 10:29:54.112 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0.logLevel created
                2025-03-19 10:29:54.115 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.exclude created
                2025-03-19 10:29:54.118 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.exclude.all created
                2025-03-19 10:29:54.120 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info created
                2025-03-19 10:29:54.123 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.connection created
                2025-03-19 10:29:54.126 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.pairingMode created
                2025-03-19 10:29:54.129 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.pairingCountdown created
                2025-03-19 10:29:54.133 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.pairingMessage created
                2025-03-19 10:29:54.136 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.groups created
                2025-03-19 10:29:54.139 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.undefinedDevices created
                2025-03-19 10:29:54.143 - info: host.raspi5 iobroker host.raspi5 object zigbee.0.info.debugmessages created
                2025-03-19 10:29:54.146 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.exclude.all: []
                2025-03-19 10:29:54.149 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.connection: false
                2025-03-19 10:29:54.152 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.pairingMode: false
                2025-03-19 10:29:54.154 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.pairingCountdown: 0
                2025-03-19 10:29:54.156 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.pairingMessage:
                2025-03-19 10:29:54.159 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.groups:
                2025-03-19 10:29:54.161 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.undefinedDevices:
                2025-03-19 10:29:54.163 - info: host.raspi5 iobroker host.raspi5 Set default value of zigbee.0.info.debugmessages:
                2025-03-19 10:29:54.170 - info: host.raspi5 iobroker host.raspi5 object system.adapter.zigbee.0 created
                2025-03-19 10:29:55.180 - info: host.raspi5 iobroker exit 0
                2025-03-19 10:29:56.875 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                2025-03-19 10:29:57.472 - info: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 83159
                2025-03-19 10:30:00.684 - info: zigbee.0 (83159) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                2025-03-19 10:30:00.706 - error: zigbee.0 (83159) Serial port not selected! Go to settings page.
                2025-03-19 10:30:00.709 - info: zigbee.0 (83159) Starting Zigbee npm ...
                2025-03-19 10:30:01.111 - info: zigbee.0 (83159) Installed Version: iobroker.zigbee@1.10.14
                2025-03-19 10:31:32.746 - info: host.raspi5 stopInstance system.adapter.zigbee.0 (force=false, process=true)
                2025-03-19 10:31:32.750 - info: zigbee.0 (83159) Got terminate signal TERMINATE_YOURSELF
                2025-03-19 10:31:32.751 - info: zigbee.0 (83159) cleaned everything up...
                2025-03-19 10:31:32.753 - info: zigbee.0 (83159) Zigbee: disabling joining new devices.
                2025-03-19 10:31:32.754 - warn: zigbee.0 (83159) Failed to stop zigbee during startup
                2025-03-19 10:31:32.754 - info: zigbee.0 (83159) terminating
                2025-03-19 10:31:32.755 - info: zigbee.0 (83159) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-03-19 10:31:32.793 - info: host.raspi5 stopInstance system.adapter.zigbee.0 send kill signal
                2025-03-19 10:31:33.252 - info: zigbee.0 (83159) terminating
                2025-03-19 10:31:33.285 - info: host.raspi5 instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-03-19 10:31:36.506 - info: host.raspi5 instance system.adapter.zigbee.0 in version "1.10.14" started with pid 83248
                2025-03-19 10:31:36.575 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                2025-03-19 10:31:38.535 - info: zigbee.0 (83248) starting. Version 1.10.14 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                2025-03-19 10:31:38.549 - info: zigbee.0 (83248) Starting Zigbee npm ...
                2025-03-19 10:31:38.803 - info: zigbee.0 (83248) Installed Version: iobroker.zigbee@1.10.14
                2025-03-19 10:33:55.927 - debug: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
                2025-03-19 10:33:55.927 - debug: fritzdect.0 (22085) __________________________
                2025-03-19 10:33:55.927 - debug: fritzdect.0 (22085) updating Devices / Groups
                2025-03-19 10:33:56.951 - debug: fritzdect.0 (22085) devices
                2025-03-19 10:33:56.951 - debug: fritzdect.0 (22085) update Devices 1
                2025-03-19 10:38:56.993 - debug: fritzdect.0 (22085) _____________________________________________
                2025-03-19 10:38:56.993 - debug: fritzdect.0 (22085) updating Device FRITZ!DECT 200 #1
                • N
                  Wie kann ich die obigen (doppelten) posts löschen ?
                  Was mir noch merkwürdig erscheint, ist dass im Instanzeneinstellungsmenue des Zigbee-Adapters ein klick auf den Pfeil hinter dem COM-Anschlussnamen keine Auswahl ergibt. Sollten dort nicht alle verfügbaren Adapter angezeigt werden ?
                  Irgendwie habe ich das Gefühl das der Anschluss nicht richtig für den Adapter konfiguriert ist.
                  Kann man sich die Adapterkonfiguration direkt im terminal anschauen ?
                  Asgothian Homoran 2 Replies Last reply Reply Quote 0
                  • Asgothian
                    @nilli Nein. Um da näher dran zu kommen müsstest Du die 2.1.0 RC3 von meinem Github installieren. Anbei ein Link und ein Hinweis in wie weit diese Version besonders ist.
                    Interessant für Deine Situation ist das du direkt versuchen kannst den Herdsman zu starten und zu stoppen, ohne immer die Ansicht zu wechseln. Relevante Log-Meldunge bekommst du auch direkt in der Oberfläche angezeigt
                    Wichtig - alle Breaking changes aus dem Wechsel von 1.10 zu 2.0.1 gelten auch (siehe hier)
                    Link: https://github.com/asgothian/ioBroker.zigbee/tarball/2.1.0
                    Was hier neu ist:
                    • der Adatper startet nicht mehr ‘durch’, sprich der Adapter startet das Zigbee-Subsystem nur dann wenn der entsprechende Haken gesetzt ist. Per default ist der nicht gesetzt. (Im Bild rot umrandet)
                    • der Adapter bietet die Option den Herdsman testweise zu starten, und direkt im Admin die Meldungen des Starts zu sehen. So kann ohne Jongliererei geprüft werden ob die Parameter passen. Im Bild lila umrandet
                    • Der Knopf zum Reset ist aktuell noch nicht getestet - da bin ich noch dran. Das sollte aber im Laufe der Woche passieren
                    • Mit Start/Stop kann der Herdsman gestartet / angehalten werden
                    Das icon mit dem Trauerrand taucht immer dann auf wenn der Herdsman nicht läuft.
                    Zum testen sollte das ganze ausreichen.
                      Homoran Global Moderator Administrators @nilli last edited by
                      wenn du damit Converter meinst, bin ich schon länger dieser Meinung
                      • N
                        nilli @Homoran last edited by
                        @homoran : Ja. Converter ist wohl richtig. Sorry !
                          @nilli was sagt denn lsusb und ls /dev/serial/by-id?
                          • N
                            nilli @Homoran last edited by nilli
                            leider genau was es sollte , oder ?
                            nils@raspi5:/ $ lsusb
                            Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                            Bus 003 Device 009: ID 10c4:ea60 Silicon Labs CP210x UART Bridge
                            Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                            Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
                            Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                            nils@raspi5:/ $ ls -l /dev/serial/by-id
                            total 0
                            lrwxrwxrwx 1 root root 13 Mar 19 10:00 usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0 -> ../../ttyUSB0
                              oder
                              was steht denn hier
                              ist leider abgeschnitten
                              • N
                                /dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0
                                • N
                                  /dev/ttyUSB0 müsste doch eigentlich auch möglich sein, oder ?
                                    kannst du mal versuchen, nur diese Angabe kann sich nach einem Neustart ändern.
                                      Homoran Global Moderator Administrators @nilli last edited by Homoran
                                      @homoran said in Zigbee.0: You need save and run adapter before pairing!:
                                      was für ein chip ist im Koordinator verbaut?
                                      SLZB-07p7 basierend auf CC2652P7 und CP2102N.
                                      @Asgothian
                                      wird der Chip unterstützt?
                                      Hintergrund:
                                      @pmayer sagte in IEEE bei cod.m Zigbee Koordinator ändern:
                                      unser Entwickler hat sich mal durch die Sourcen der Z-Stack Firmware und cc2538-bsl gegraben.
                                      Wie es aussieht wird beim Update die IEEE im CC2652P7 an die falsche stelle geschrieben, weil das Speicherlayout anders ist als beim CC1352P7.
                                      N pmayer 2 Replies Last reply Reply Quote 0
                                      • N
                                        /dev/ttyUSB0 -> gleiches Verhalten 😖
                                        wird der Chip unterstützt? -> Ja, letzte Woche funktionierte er.
                                          Aah!
                                          mit welchen Einstellungen?
                                          Was hast du dann geändert?
                                          • N
                                            Keine Änderung. Ein Neustart war der Auslöser ...
                                            1.3k
                                            4784
