    4. [gelöst] Deye GEN-Eingang mit JS schalten funktioniert nicht
    • fuzzy1955
      fuzzy1955 @wendy2702 last edited by fuzzy1955
      @wendy2702 sagte in Deye GEN-Eingang mit IOB-JS schalten funktioniert nicht:
      was kommt denn im Modbus log wenn das auf Debug steht?
      javascript.0	13:07:07.430	info	script.js.common._Tests.Deye_GEN_schalten: setForeignState(id=modbus.0.holdingRegisters.1.125_GEN_Ladestrom_SOLL, state={"val":90,"ack":true,"ts":1742386027430,"q":0,"from":"system.adapter.javascript.0","lc":1742386027430,"c":"script.js.common._Tests.Deye_GEN_schalten"})
      javascript.0	13:07:07.431	info	script.js.common._Tests.Deye_GEN_schalten: setForeignState(id=modbus.0.holdingRegisters.1.132_GEN_Ladeenergie_ein, state={"val":-1,"ack":true,"ts":1742386027430,"q":0,"from":"system.adapter.javascript.0","lc":1742386027430,"c":"script.js.common._Tests.Deye_GEN_schalten"})
      javascript.0	13:07:07.431	info	script.js.common._Tests.Deye_GEN_schalten: setForeignState(id=modbus.0.holdingRegisters.1.195_GEN_Relaisstatus, state={"val":-1,"ack":true,"ts":1742386027431,"q":0,"from":"system.adapter.javascript.0","lc":1742386027431,"c":"script.js.common._Tests.Deye_GEN_schalten"})
      javascript.0	13:07:07.431	warn	at GenSchalten (script.js.common._Tests.Deye_GEN_schalten:11:5)
      javascript.0	13:07:07.431	warn	at Object.<anonymous> (script.js.common._Tests.Deye_GEN_schalten:2:25)
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.141_EnergyManagementMode, timerId=undefined) => {"val":1,"ack":true,"ts":1742331164419,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742315811907}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.125_GEN_Ladestrom_SOLL, timerId=undefined) => {"val":95,"ack":true,"ts":1742331164377,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742328807702}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.230_GEN_Ladestrom_IST, timerId=undefined) => {"val":-1,"ack":true,"ts":1742331164476,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742240374465}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.132_GEN_Ladeenergie_ein, timerId=undefined) => {"val":0,"ack":true,"ts":1742331164377,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742328807702}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.139_GEN_MinPvStart, timerId=undefined) => {"val":500,"ack":true,"ts":1742331164418,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742236165043}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.140_GEN_Netzsignal_ein, timerId=undefined) => {"val":3,"ack":true,"ts":1742331164419,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742236165043}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.133_GEN_Modus, timerId=undefined) => {"val":0,"ack":true,"ts":1742331164377,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742331163957}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.195_GEN_Relaisstatus, timerId=undefined) => {"val":0,"ack":true,"ts":1742331164466,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742328807792}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.661_GEN_Spannung_L1, timerId=undefined) => {"val":0.9,"ack":true,"ts":1742385741568,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742385741568}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.662_GEN_Spannung_L2, timerId=undefined) => {"val":0.8,"ack":true,"ts":1742386022890,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742386022890}
      javascript.0	13:07:07.432	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.663_GEN_Spannung_L3, timerId=undefined) => {"val":0.2,"ack":true,"ts":1742384866346,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742384866346}
      javascript.0	13:07:07.433	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=modbus.0.holdingRegisters.1.667_GEN_Gesamtleistung, timerId=undefined) => {"val":0,"ack":true,"ts":1742331164919,"q":0,"from":"system.adapter.modbus.0","user":"system.user.admin","lc":1742238930639}
      javascript.0	13:07:07.433	info	script.js.common._Tests.Deye_GEN_schalten: getState(id=alias.0.PV-Anlage.Wechselrichter.PV_Ueberschuss, timerId=undefined) => {"val":0.01,"ack":true,"ts":1742386020742,"q":0,"c":"script.js.common.Photovoltaik.Datenpunkte_Refresh","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1742386010741}
      javascript.0	13:07:08.471	info	Stopping script script.js.common._Tests.Deye_GEN_schalten
      timerId=undefined muss ich noch eruieren.
        warp735 @fuzzy1955 last edited by
        @fuzzy1955
        Das Relais lässt sich selbstredend nicht direkt schalten. Woher hast denn das?!
        Das was du da rumfummelst ist das Signal für den E-Starter, um einen Generator zu starten.
        Du kannst die Konfiguration dahingehend mit Modbus ändern das es schaltet.
        fuzzy1955 1 Reply Last reply Reply Quote 0
          Homoran Global Moderator Administrators @fuzzy1955 last edited by
          @fuzzy1955 sagte in Deye GEN-Eingang mit IOB-JS schalten funktioniert nicht:
          @homoran sagte in Deye GEN-Eingang mit IOB-JS schalten funktioniert nicht:
          was steht denn in der Bedienungsanleitung des WR dazu?
          Da steht nur von der externen Ansteuerung etwas.
          Ich möchte aber die Registerfunktionen verwenden:
          _address	deviceId	name	description	unit
          122	1	GEN_Laufzeit	Gen-Cool-Time	h
          125	1	GEN_Ladestrom_SOLL	Gen-Charge-Current	A
          132	1	GEN_Ladeenergie_ein	Force on generator as load function
          133	1	GEN_Modus	0 = Generator input, 1 = SmartLoad Output, 2 = Micinv Input
          139	1	GEN_MinPvStart	minimum solar power required to start a generator	W
          140	1	GEN_Netzsignal_ein
          195	1	GEN_Relaisstatus	Bit0-3 : 0=not attached 1=actuation; Bit4-7: 0=power off 1=power on; Bit8-11 ??
          230	1	GEN_Ladestrom_IST	Netz-zu-Batterie-Ladestrom	A
          661	1	GEN_Spannung L1	Phasenspannung von Gen-Port L1	V
          662	1	GEN_Spannung L2	Phasenspannung von Gen-Port L2	V
          663	1	GEN_Spannung L3	Phasenspannung von Gen-Port L3	V
          667	1	GEN_Gesamtleistung	Gesamtleistung des Gen-Ports	W
          geht ggf nicht immer.
          welche hattest du versucht?
          mit welchen Einstellungen
          lass dir doch nicht alles aus der Nase ziehen.
          W fuzzy1955 2 Replies Last reply Reply Quote 0
            warp735 @Homoran last edited by
            Nicht überall mitschreiben, wo man keine Ahnung von hat 😉
            Der Herr versucht ein nicht beschreibbares Register zu beschreiben. So einfach wie er sich das vorstellt, funktionierts nicht.
            Homoran 1 Reply Last reply Reply Quote -1
              Homoran Global Moderator Administrators @warp735 last edited by Homoran
              @warp735 Bitte unterlasse diese unqualifizierte Stimmungsmache!
              @warp735 sagte in Deye GEN-Eingang mit IOB-JS schalten funktioniert nicht:
              genau das vermute ich
                Dann schreibs doch einfach nd zieh nicht immer alles mit zig Nachfragen in die Länge...
                Und danke fürs Downvote 😉
                @fuzzy1955
                Du musst die Time of Use Tabelle umschreiben und dort GEN Laden aktivieren. An der restlichen Konfiguration am WR brauchst nix ändern.
                Samson71 fuzzy1955 2 Replies Last reply Reply Quote 0
                • Samson71
                  Samson71 Global Moderator @warp735 last edited by Samson71
                  für den Spruch
                  mehr als verdient.
                  Im Übrigen ist "Revanche-Downvote" keinen Deut besser. Hat eher was von Kindergarten...
                  • fuzzy1955
                    fuzzy1955 @warp735 last edited by fuzzy1955
                    Hab ich schon alles probiert:
                    Mir geht es um das Register: 140 GEN_Netzsignal_ein. Ob das beschreibbar ist, kann ich nirgends finden.
                    Danke für deine ausdauernde Unterstützung!
                      @fuzzy1955
                      Und jetzt zeig mal noch die GEN Port Einstellungen
                      • fuzzy1955
                        Ich hab' da nix probiert. Es war auch nicht meine Idee und stammt nur vom Handbuch.
                        • fuzzy1955
                          fuzzy1955 @Homoran last edited by fuzzy1955
                          Mir geht es nur um das Register: 140 GEN_Netzsignal_ein. Ob das beschreibbar ist, kann ich nirgends finden. Auslesen kann ich alle Register.
                            @fuzzy1955 seltsamerweise steht bei 140 auch in der Registertabelle gar nichts außer der ID
                              oh neue Zusatzinfo 😉
                              Dann passen ja die Einstellungen
                              • fuzzy1955
                                • fuzzy1955
                                  Es kommen Werte raus:
                                  • fuzzy1955
                                    oh neue Zusatzinfo
                                    Wie eingangs beschrieben geht es mir nur um eines: Automatisches Schalten des GEN-Eingangs
                                      @fuzzy1955 klar, aber wenn du lesen, aber nicht schreiben kannst und nichts in irgendeinem log steht, wird dieser DP nur zum lesen sein.
                                        @fuzzy1955
                                        Probier das mal. Und in Time of Use muss der Prozentwert höher sein, als der aktuelle SOC
                                        • fuzzy1955
                                          Habe ich probiert. Jetzt schaltet der GEN ein, aber er lässt sich nicht mehr ausschalten.
                                          • fuzzy1955
                                            @warp735
                                            Ich habe zwischendurch einen 10 m-Baum mit der Motorsäge umgelegt - darum die Pause 😊
                                            2715
