    3. Einsteigerfragen
    4. Installation
    5. Zigbee.0: You need save and run adapter before pairing!
      Homoran Global Moderator Administrators @pmayer last edited by
      @pmayer sagte in Zigbee.0: You need save and run adapter before pairing!:
      Oder hab ich dich falsch verstanden
      leider ja 😢
      es ging um den
      @nilli sagte in Zigbee.0: You need save and run adapter before pairing!:
      SLZB-07p7
      • N
        nilli @Thomas Braun last edited by nilli
        leider nichts auffälliges ...
        USB-Devices by-id:
        /dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0
        *** ZigBee Settings ***
        Your zigbee.0 COM-Port is matching 'by-id'. Very good!
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.0
        Extended Pan ID:
        grep: /opt/iobroker/iobroker-data/zigbee_0/nvbackup.json: No such file or directory
        Pan ID:
        /home/iobroker/.diag.sh: line 699: printf: 0x: invalid hex number
        0
        Channel:
        Network Key:
        Adapter State
        + system.adapter.zigbee.0                 : zigbee                : raspi5                                   -  enabled, port: /dev/serial/by-id/usb-SMLIGHT_SMLIGHT_SLZB-07p7_9c66d41ef372ed1189a81df3fdf7b791-if00-port0
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
         Static hostname: raspi5
               Icon name: computer
                  Kernel: Linux 6.6.74+rpt-rpi-2712
            Architecture: arm64
        OS is similar to:
        Model		: Raspberry Pi 5 Model B Rev 1.0
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         19:16:26 up 1 day, 11:01,  2 users,  load average: 113.00, 112.51, 111.72
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Operating System is the current Debian stable version codenamed 'bookworm'!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Wed 2025-03-19 19:16:27 CET
                   Universal time: Wed 2025-03-19 18:16:27 UTC
                         RTC time: Wed 2025-03-19 18:16:27
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        nils
        HOME=/home/nils
        GROUPS=nils adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal: 	tty
        *** MEMORY ***
        Mem:            2.1G        1.5G        163M        425K        557M        651M
        Swap:           536M        536M        573K
        Total:          2.6G        2.0G        163M
        Active iob-Instances: 	22
                 2009 M total memory
                 1387 M used memory
                  754 M active memory
                  838 M inactive memory
                  155 M free memory
                   87 M buffer memory
                  443 M swap cache
                  511 M total swap
                  511 M used swap
                    0 M free swap
        top - 19:16:27 up 1 day, 11:01,  2 users,  load average: 113.00, 112.51, 111.72
        Tasks: 293 total,   1 running, 292 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni, 66.7 id, 33.3 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2009.0 total,    155.0 free,   1387.7 used,    531.4 buff/cache
        MiB Swap:    512.0 total,      0.5 free,    511.4 used.    621.3 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        15 CRITICAL ERRORS DETECTED!
        Check 'sudo dmesg --level=emerg,alert,crit -T' for details
        *** FILESYSTEM ***
        udev           devtmpfs  967M     0  967M   0% /dev
        tmpfs          tmpfs     201M  5.2M  196M   3% /run
        /dev/mmcblk0p2 ext4       59G  9.7G   46G  18% /
        tmpfs          tmpfs    1005M     0 1005M   0% /dev/shm
        tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
        /dev/mmcblk0p1 vfat      510M   55M  456M  11% /boot/firmware
        tmpfs          tmpfs     201M     0  201M   0% /run/user/1000
        [Tue Mar 18 08:14:35 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  smsc95xx.macaddr=2C:CF:67:7A:6F:0D vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=a7b4f037-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
        [Tue Mar 18 08:14:38 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
        [Tue Mar 18 08:14:39 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
        Show mounted filesystems:
        TARGET           SOURCE         FSTYPE OPTIONS
        /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
        `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.1G	/var/
        206M	/var/cache
        200M	/var/cache/apt
        174M	/var/lib
        135M	/var/lib/apt/lists
        Archived and active journals take up 133.0M in the file system.
        /opt/iobroker/backups:
        19M	/opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.4G	/opt/iobroker/iobroker-data/
        1.3G	/opt/iobroker/iobroker-data/files
        617M	/opt/iobroker/iobroker-data/files/javascript.admin
        560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
        558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
        38M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        26M	/opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
        26M	/opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
        24M	/opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
        24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
        USB-Devices by-id:
        zigbee.0
        Extended Pan ID:
        Pan ID:
        0
        Channel:
        Network Key:
        *** NodeJS-Installation ***
        /usr/bin/nodejs 	v20.19.0
        /usr/bin/node 		v20.19.0
        /usr/bin/npm 		10.8.2
        /usr/bin/npx 		10.8.2
        /usr/bin/corepack 	0.31.0
        nodejs:
          Installed: 20.19.0-1nodesource1
          Candidate: 20.19.0-1nodesource1
          Version table:
         *** 20.19.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.19.0+dfsg-6~deb12u2 500
             18.19.0+dfsg-6~deb12u1 500
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspi5              raspi5 (version: 7.0.6, hostname: raspi5        , alive, uptime: 114649)
        Core adapters versions
        js-controller: 	7.0.6
        admin: 		7.4.10
        javascript: 	8.8.3
        nodejs modules from github: 	0
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspi5                                   -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : raspi5                                   -  enabled
          system.adapter.cloud.0                  : cloud                 : raspi5                                   - disabled
        + system.adapter.discovery.0              : discovery             : raspi5                                   -  enabled
        + system.adapter.echarts.0                : echarts               : raspi5                                   -  enabled
        + system.adapter.email.0                  : email                 : raspi5                                   -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspi5                                   -  enabled
        + system.adapter.history.0                : history               : raspi5                                   -  enabled
          system.adapter.iot.0                    : iot                   : raspi5                                   - disabled
        + system.adapter.iqontrol.0               : iqontrol              : raspi5                                   -  enabled
        + system.adapter.jarvis.0                 : jarvis                : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + system.adapter.javascript.0             : javascript            : raspi5                                   -  enabled
        + system.adapter.maxcube.0                : maxcube               : raspi5                                   -  enabled, port: 62910, bind: 0.0.0.0
        + system.adapter.node-red.0               : node-red              : raspi5                                   -  enabled, port: 1880, bind: 0.0.0.0
        + system.adapter.notification-manager.0   : notification-manager  : raspi5                                   -  enabled
          system.adapter.ping.0                   : ping                  : raspi5                                   - disabled
        + system.adapter.rpi2.0                   : rpi2                  : raspi5                                   -  enabled
        + system.adapter.scenes.0                 : scenes                : raspi5                                   -  enabled
        + system.adapter.signal-cmb.0             : signal-cmb            : raspi5                                   -  enabled
        + system.adapter.sql.0                    : sql                   : raspi5                                   -  enabled
        + system.adapter.tr-064.0                 : tr-064                : raspi5                                   -  enabled
        + system.adapter.vis-2.0                  : vis-2                 : raspi5                                   -  enabled
          system.adapter.weatherunderground.0     : weatherunderground    : raspi5                                   - disabled
        + system.adapter.web.0                    : web                   : raspi5                                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.4.10   , installed 7.4.10
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "echarts"      : 1.9.2    , installed 1.9.2
        Adapter    "email"        : 1.3.1    , installed 1.3.1
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "maxcube"      : 1.0.4    , installed 1.0.4
        Adapter    "node-red"     : 5.2.1    , installed 5.2.1
        Adapter    "notification-manager": 1.2.1, installed 1.2.1
        Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
        Adapter    "scenes"       : 3.2.3    , installed 3.2.3
        Adapter    "signal-cmb"   : 0.3.0    , installed 0.3.0
        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sql"          : 3.0.1    , installed 3.0.1
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
        Adapter    "weatherunderground": 3.7.0, installed 3.7.0
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
        Objects and States
        Objects: 	1841
        States: 	937
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:6 https://packages.adoptium.net/artifactory/deb bookworm InRelease
        Reading package lists...
        Pending Updates: 12
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4944       675/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       88612      21571/iobroker.js-c
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       88607      21571/iobroker.js-c
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       90865      22057/io.jarvis.0
        tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       90518      21746/node-red
        tcp6       0      0 :::22                   :::*                    LISTEN      0          4946       675/sshd: /usr/sbin
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       87450      21591/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       89048      21978/io.web.0
        udp        0      0 192.168.2.87:5353       0.0.0.0:*                           1001       87961      22014/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4799       541/avahi-daemon: r
        udp        0      0 0.0.0.0:39307           0.0.0.0:*                           104        4801       541/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        4800       541/avahi-daemon: r
        udp6       0      0 fe80::cfaa:2ac1:4ed:546 :::*                                0          372348     618/NetworkManager
        udp6       0      0 :::41901                :::*                                104        4802       541/avahi-daemon: r
        2025-03-19 19:15:51.328  - debug: fritzdect.0 (22085) polling! fritzdect is alive with 300 s
        2025-03-19 19:15:51.329  - debug: fritzdect.0 (22085) __________________________
        2025-03-19 19:15:51.329  - debug: fritzdect.0 (22085) updating Devices / Groups
        2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) devices
        2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) [{"identifier":"08761 0147624","id":"16","functionbitmask":"35456","fwversion":"04.27","manufacturer":"AVM","productname":"FRITZ!Smart Energy 200","present":"0","txbusy":"0","name":"FRITZ!DECT 200 #1","switch":{"state":"","mode":"","lock":"","devicelock":""},"simpleonoff":{"state":""},"powermeter":{"voltage":"","power":"","energy":""}}]
        2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) update Devices 1
        2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) _____________________________________________
        2025-03-19 19:15:53.097  - debug: fritzdect.0 (22085) updating Device FRITZ!DECT 200 #1
        2025-03-19 19:15:53.101  - silly: fritzdect.0 (22085) States user redis pmessage fritzdect.0.*/fritzdect.0.DECT_087610147624.present:{"val":false,"ack":true,"ts":1742408153100,"q":0,"from":"system.adapter.fritzdect.0","user":"system.user.admin","lc":1739294859072}
        2025-03-19 19:15:53.101  - debug: fritzdect.0 (22085) onStateChange => state fritzdect.0.DECT_087610147624.present changed: false (ack = true)
        2025-03-19 19:15:53.101  - debug: fritzdect.0 (22085) DECT_087610147624 is not present, check the device connection, no values are written
        2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) groups
        2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) []
        2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) __________________________
        2025-03-19 19:15:53.102  - debug: fritzdect.0 (22085) updating Routines
        2025-03-19 19:15:55.346  - debug: fritzdect.0 (22085) __________________________
        2025-03-19 19:15:55.346  - debug: fritzdect.0 (22085) routines
        2025-03-19 19:15:55.346  - debug: fritzdect.0 (22085) []
        2025-03-19 19:15:55.348  - debug: fritzdect.0 (22085) glob state ["087610147624"]
        2025-03-19 19:15:55.348  - debug: fritzdect.0 (22085) updating Stats of device 087610147624
        2025-03-19 19:15:55.348  - debug: fritzdect.0 (22085) update Stats objects 087610147624
        2025-03-19 19:15:56.368  - debug: fritzdect.0 (22085) With 087610147624got the following to parse{"devicestats":{"voltage":"","power":"","energy":""}}
        • N
          nilli @Asgothian last edited by
          @asgothian said in Zigbee.0: You need save and run adapter before pairing!:
          Deswegen ist ein Update auf eine 2.0.x version zu empfehlen - da habe ich den exakten Quelltext hier.
          Würde ich gerne versuchen, leider bin ich noch etwas unerfahren.
          Wie gehe ich zur Installation vor ? Gibt es irgendwo eine Anleitung ?
          Danke !!
            Thomas Braun Most Active @nilli last edited by
            Was sind denn das für Errors?
            • N
              Ich habe gestern versucht nach https://stmxcsr.com/micro/raspberry-signal-client.html signal-cli zu compelieren, bin aber leider krachend gescheitert 😧
              nils@raspi5:~ $ sudo dmesg --level=emerg,alert,crit -T
              [Tue Mar 18 08:14:41 2025] Unable to handle kernel paging request at virtual address ffffc00080aa3f04
              [Tue Mar 18 08:14:41 2025] Mem abort info:
              [Tue Mar 18 08:14:41 2025]   ESR = 0x0000000096000047
              [Tue Mar 18 08:14:41 2025]   EC = 0x25: DABT (current EL), IL = 32 bits
              [Tue Mar 18 08:14:41 2025]   SET = 0, FnV = 0
              [Tue Mar 18 08:14:41 2025]   EA = 0, S1PTW = 0
              [Tue Mar 18 08:14:41 2025]   FSC = 0x07: level 3 translation fault
              [Tue Mar 18 08:14:41 2025] Data abort info:
              [Tue Mar 18 08:14:41 2025]   ISV = 0, ISS = 0x00000047, ISS2 = 0x00000000
              [Tue Mar 18 08:14:41 2025]   CM = 0, WnR = 1, TnD = 0, TagAccess = 0
              [Tue Mar 18 08:14:41 2025]   GCS = 0, Overlay = 0, DirtyBit = 0, Xs = 0
              [Tue Mar 18 08:14:41 2025] swapper pgtable: 16k pages, 47-bit VAs, pgdp=0000000001398000
              [Tue Mar 18 08:14:41 2025] [ffffc00080aa3f04] pgd=100000000619c003, p4d=100000000619c003, pud=100000000619c003, pmd=10000000061a0003, pte=0000000000000000
              [Tue Mar 18 08:14:41 2025] Internal error: Oops: 0000000096000047 [#1] PREEMPT SMP
              [Tue Mar 18 08:14:41 2025] Code: d503201f b50000e2 14000020 38401423 (39000003)
              • N
                Kann mir jemand einen Tip geben wie ich
                https://github.com/asgothian/ioBroker.zigbee/tarball/2.1.0
                installiere ? Danke !
                • Asgothian
                  Asgothian Developer @nilli last edited by Asgothian
                  @nilli
                  • Adapter anhalten (Wichtig!!!)
                  • Adapter Seite aufrufen
                  • Experten modus aktivieren (1)
                  • Installation mit der 'Katze' (2)
                  • Benutzerdefiniert auswählen
                  • Link hinein kopieren
                  • Installieren
                  A.
                  Nachtrag: Ich hatte einen Link auf den Post zum Testen der 2.0.x Version gegeben - da stand auch drin von wo die 'standard' 2.0.x zu installieren sind - diese sind im Latest verfügbar.
                  Ich hoffe Du hast diesen Post gelesen.
                    https://github.com/ioBroker/ioBroker.zigbee/wiki/GIT-install
                    • N
                      nilli @arteck last edited by
                      @arteck
                      Super ! Danke 🙂 Wenn man weiss wie es geht ganz einfach.
                      Adapter 2.0.4 installiert und konfiguriert.
                      Leider immer noch kein Erfolg ...
                      2025-03-19 21:43:52.019 - info: host.raspi5 iobroker exit 0
                      2025-03-19 21:43:53.877 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                      2025-03-19 21:43:54.259 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 112722
                      2025-03-19 21:43:55.356 - info: zigbee.1 (112722) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                      2025-03-19 21:43:55.365 - info: zigbee.1 (112722) init localConfig
                      2025-03-19 21:43:55.368 - error: zigbee.1 (112722) Serial port not selected! Go to settings page.
                      2025-03-19 21:43:55.369 - info: zigbee.1 (112722) --> transmitPower : normal
                      2025-03-19 21:43:55.371 - info: zigbee.1 (112722) --- creating device debug ---
                      2025-03-19 21:47:34.730 - info: host.raspi5 stopInstance system.adapter.zigbee.1 (force=false, process=true)
                      2025-03-19 21:47:34.733 - info: zigbee.1 (112722) Got terminate signal TERMINATE_YOURSELF
                      2025-03-19 21:47:34.734 - info: zigbee.1 (112722) cleaned everything up...
                      2025-03-19 21:47:34.735 - info: zigbee.1 (112722) local config saved
                      2025-03-19 21:47:34.737 - info: zigbee.1 (112722) Saved local configuration data
                      2025-03-19 21:47:34.738 - info: zigbee.1 (112722) terminating
                      2025-03-19 21:47:34.739 - info: zigbee.1 (112722) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-03-19 21:47:34.743 - error: zigbee.1 (112722) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
                      at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:263:35)
                      at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:690:33)
                      at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:664:24)
                      at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                      at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1070:17)
                      2025-03-19 21:47:34.744 - warn: zigbee.1 (112722) Failed to stop zigbee during startup
                      2025-03-19 21:47:34.744 - info: zigbee.1 (112722) terminating
                      2025-03-19 21:47:35.241 - info: zigbee.1 (112722) terminating
                      2025-03-19 21:47:35.269 - info: host.raspi5 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-03-19 21:47:38.427 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 112848
                      2025-03-19 21:47:39.389 - info: zigbee.1 (112848) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                      2025-03-19 21:47:39.398 - info: zigbee.1 (112848) init localConfig
                      2025-03-19 21:47:39.401 - info: zigbee.1 (112848) --> transmitPower : normal
                      2025-03-19 21:47:39.403 - info: zigbee.1 (112848) --- creating device debug ---
                      asgothian created this issue in asgothian/ioBroker.zigbee
                      closed 1.3.9dev #2
                      • Asgothian
                        @nilli hast du versucht das zigbee-subsystem direkt aus dem Admin-Interface zu starten, wie das im Post beschrieben ist, oder hast du einfach nur den Haken bei ‘automatisch starten’ gesetzt ?
                        A.
                        • N
                          nilli @Asgothian last edited by nilli
                          @asgothian
                          'start the Network automaticly' ist in den Instanzeneinstellungen nicht gesetzt.
                          Ich habe den Adapter im 'instanzen' Menue gestartet.
                          2025-03-19 22:08:47.638 - info: admin.0 (21591) ==> Connected system.user.admin from ::ffff:192.168.2.66
                          2025-03-19 22:08:50.036 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                          2025-03-19 22:08:52.842 - info: host.raspi5 "system.adapter.zigbee.1" enabled
                          2025-03-19 22:08:53.076 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 113695
                          2025-03-19 22:08:54.050 - info: zigbee.1 (113695) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                          2025-03-19 22:08:54.060 - info: zigbee.1 (113695) init localConfig
                          2025-03-19 22:08:54.063 - info: zigbee.1 (113695) --> transmitPower : normal
                          2025-03-19 22:08:54.066 - info: zigbee.1 (113695) --- creating device debug ---
                          closed 1.3.9dev #2
                          • Asgothian
                            @nilli dann lies nochmal was ich oben geschrieben habe.
                            Eine wichtige Eigenschaft dieser Version ist das das zigbee subsystem nicht automatisch gestartet wird. Du kannst (und sollst) versuchen das subsystem aus dem Admin zu starten um a die Meldungen vom Start zu kommen. Wenn du das nicht machst bleibt der Adapter “gelb”
                            • N
                              @asgothian
                              Danke für Deine Hilfe.
                              Ich habe den Start/Stop button in der Instanzeinstellung benutzt.
                              Ich hoffe das war, was Du meintest.
                              • Asgothian
                                @nilli Das sieht besser aus, aber nicht gut - das USB Device wird vom Zigbee-Herdsman nicht sauber akzeptiert.
                                halte das Zigbee-Subsystem bitte wieder an (start/stop nochmal drücken) und setz dann den haken beim flow control. Danach noch einmal starten.
                                A.
                                • N
                                  @asgothian
                                  Einmal gedrückt, wird der Start/Stop Button ausgegraut und hat keine Funktion mehr.
                                  Extern angehalten, flow control aktiviert und neu gestartet :
                                  2025-03-20 21:03:28.458 - info: zigbee.1 (164560) --- creating device debug ---
                                  2025-03-20 21:03:30.876 - info: admin.0 (21591) <== Disconnect system.user.admin from ::ffff:192.168.2.66
                                  2025-03-20 21:03:33.961 - info: host.raspi5 stopInstance system.adapter.zigbee.1 (force=false, process=true)
                                  2025-03-20 21:03:33.963 - info: zigbee.1 (164560) Got terminate signal TERMINATE_YOURSELF
                                  2025-03-20 21:03:33.964 - info: zigbee.1 (164560) cleaned everything up...
                                  2025-03-20 21:03:33.965 - info: zigbee.1 (164560) local config saved
                                  2025-03-20 21:03:33.965 - info: zigbee.1 (164560) Saved local configuration data
                                  2025-03-20 21:03:33.966 - info: zigbee.1 (164560) terminating
                                  2025-03-20 21:03:33.967 - info: zigbee.1 (164560) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2025-03-20 21:03:33.970 - error: zigbee.1 (164560) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
                                  2025-03-20 21:03:33.971 - warn: zigbee.1 (164560) Failed to stop zigbee during startup
                                  2025-03-20 21:03:33.972 - info: zigbee.1 (164560) terminating
                                  2025-03-20 21:03:34.005 - info: host.raspi5 stopInstance system.adapter.zigbee.1 send kill signal
                                  2025-03-20 21:03:34.467 - info: zigbee.1 (164560) terminating
                                  2025-03-20 21:03:34.496 - info: host.raspi5 instance system.adapter.zigbee.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2025-03-20 21:03:37.710 - info: host.raspi5 instance system.adapter.zigbee.1 in version "2.0.4" (non-npm: asgothian/ioBroker.zigbee#2.1.0) started with pid 164576
                                  2025-03-20 21:03:38.740 - info: zigbee.1 (164576) starting. Version 2.0.4 (non-npm: asgothian/ioBroker.zigbee#2.1.0) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                                  2025-03-20 21:03:38.750 - info: zigbee.1 (164576) init localConfig
                                  2025-03-20 21:03:38.753 - info: zigbee.1 (164576) --> transmitPower : normal
                                  2025-03-20 21:03:38.755 - info: zigbee.1 (164576) --- creating device debug ---
                                  closed 1.3.9dev #2
                                  • Asgothian
                                    @nilli da bin am Ende - ich gehe relativ fest davon aus das der Stick nicht in Ordnung ist.
                                    Der Aufruf in den zigbee-Herdsman läuft so wie er soll, dieser sollte nach entsprechender Wartezeit zurück kommen. Das schreint er nicht zu tun. Der Adapter macht da nichts weiter. Die übergebenen Werte sehen OK aus. Warum der Herdsman ohne weitere Meldungen nicht startet kann ich kaum sagen.
                                    Als letzten Versuch kannst du:
                                    • den Adapter anhalten
                                    • den Adapter auf 'debug' umstellen (wichtig)
                                    • in der Adapter-Konfiguration den Haken bei 'zigbee-herdsman debug info' setzen
                                    • auf der Hardware-Seite versuchen den Herdsman zu starten.
                                    • 10 Minuten warten - schauen ob da überhaupt etwas kommt. Wenn nicht im Log schauen ob da debug-Meldungen aufgetaucht sind.
                                    A.
                                      darkblu last edited by darkblu
                                      Selbigen Fehler wie der Threadersteller hatte ich gestern auch.
                                      Und zwar nachdem es 9 updates für den Raspi gab.
                                      Danach wurde der Adapter einfach nicht grün.
                                      Neustart und stromlos machen hatte alles nix geholfen.
                                      Dann habe ich „iob fix, iob update, iob upgrade self (?)“
                                      (oder so ähnlich) und sudo reboot gemacht und erst danach wurde der Zigbee Adapter wieder grün.
                                      War wieder ein sehr aufregender Abend 😰
                                      1.3k
                                      4784
