    4. Test Adapter drops-weather 1.2.x
    • Winni
      Winni @mcm1957 last edited by
      @mcm1957 guten Morgen, danke für deine Arbeit, funktioniert aber bei mir leider nicht. Raspberrypi Pi5. Hier der Log mit der Einstellung auf chromium-browser.
      drops-weather.0
      2025-03-20 04:35:32.433	info	terminating
      drops-weather.0
      2025-03-20 04:35:31.934	error	Cannot read properties of null (reading 'pages')
      drops-weather.0
      2025-03-20 04:35:31.933	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
      drops-weather.0
      2025-03-20 04:35:31.931	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
      drops-weather.0
      2025-03-20 04:35:31.931	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      drops-weather.0
      2025-03-20 04:35:31.930	info	terminating
      drops-weather.0
      2025-03-20 04:35:31.929	info	Got terminate signal TERMINATE_YOURSELF
      drops-weather.0
      2025-03-20 04:35:31.894	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      drops-weather.0
      2025-03-20 04:35:31.892	error	browser mode chromkum-browser not (yet) supported
      drops-weather.0
      2025-03-20 04:35:31.892	info	browserMode set to chromkum-browser
      drops-weather.0
      2025-03-20 04:35:31.877	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
        arteck Developer Most Active @simatec last edited by
        @simatec mal geschaut obs geht.. leoder nein wie bei axios 403
        • mcm1957
          mcm1957 @Winni last edited by
          @Winni
          Hast du den Browser manuell auf chromium gestellt? Da ist offensichtloich ein Tippfehler wo drinnen. Kannst du mal versuchen auf dem zweiten Ta explizit auf AUTOmatic zu stellen?
          Winni 1 Reply Last reply Reply Quote 0
          • Winni
            Winni @mcm1957 last edited by Winni
            @mcm1957 hatte ich auch probiert und jetzt nochmal, leider das gleiche Ergebnis.
            drops-weather.0
            2025-03-20 08:09:08.394	info	terminating
            drops-weather.0
            2025-03-20 08:09:07.898	error	Cannot read properties of null (reading 'pages')
            drops-weather.0
            2025-03-20 08:09:07.897	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
            drops-weather.0
            2025-03-20 08:09:07.895	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
            drops-weather.0
            2025-03-20 08:09:07.894	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            drops-weather.0
            2025-03-20 08:09:07.893	info	terminating
            drops-weather.0
            2025-03-20 08:09:07.892	info	Got terminate signal TERMINATE_YOURSELF
            drops-weather.0
            2025-03-20 08:09:07.864	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            drops-weather.0
            2025-03-20 08:09:07.862	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
            drops-weather.0
            2025-03-20 08:09:07.826	info	browserPath set to puppeteer default
            drops-weather.0
            2025-03-20 08:09:07.825	info	browserMode set to automatic
            drops-weather.0
            2025-03-20 08:09:07.813	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
            • mcm1957
              @winni
              Kannst du bitte mal mit debug Level starten und das log posten?
              Ist aber nicht prior - muss dann weg und kann erst nachher in Code schaun.
              • Winni
                @mcm1957, ok
                drops-weather.0
                2025-03-20 08:50:23.836	error	Cannot read properties of null (reading 'pages')
                drops-weather.0
                2025-03-20 08:50:23.836	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
                drops-weather.0
                2025-03-20 08:50:23.834	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                drops-weather.0
                2025-03-20 08:50:23.834	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                drops-weather.0
                2025-03-20 08:50:23.832	info	terminating
                drops-weather.0
                2025-03-20 08:50:23.830	info	Got terminate signal TERMINATE_YOURSELF
                drops-weather.0
                2025-03-20 08:50:23.803	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                drops-weather.0
                2025-03-20 08:50:23.801	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                drops-weather.0
                2025-03-20 08:50:23.775	info	browserPath set to puppeteer default
                drops-weather.0
                2025-03-20 08:50:23.772	info	browserMode set to automatic
                drops-weather.0
                2025-03-20 08:50:23.760	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                  so für alle..
                  das wird nix.. wir müssen den auf cron umstellen..
                  ich bitte um Geduld
                  mcm1957 ? 2 Replies Last reply Reply Quote 2
                  • mcm1957
                    mcm1957 @arteck last edited by
                    @arteck said in Test Adapter drops-weather 1.1.x:
                    so für alle..
                    ich bitte um Geduld
                    @arteck
                    Ich nehm an du meinst damit umstellen auf scheduled adapter.
                    Machst du das? Oder brauchts du Support? (wobei ich nicht bös bin wenn du das machst, bin eh ausgelastet).
                    • mcm1957
                      @winni said in Test Adapter drops-weather 1.1.x:
                      @mcm1957, ok
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      drops-weather.0
                      Hmm - das ist aber nicht DEBUG Level log 🙂
                        A Former User @arteck last edited by
                        @arteck
                        um's Choas kompletty zu machen, es gibt auch noch Fetch... 🙂
                        https://www.zenrows.com/blog/axios-vs-got-vs-fetch#which-is-best
                        Ihr seit schon hartnaeckig, das muss man sagen! geht nicht - gibts net.. 👍 👍 👍 👍
                        • Winni
                          @mcm1957 meinst du so?
                          Zeit
                          info
                          Nachricht
                          host.raspberrypi
                          2025-03-20 15:03:02.764	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.raspberrypi
                          2025-03-20 15:03:02.233	info	stopInstance system.adapter.drops-weather.0 send kill signal
                          drops-weather.0
                          2025-03-20 15:03:02.229	error	Cannot read properties of null (reading 'pages')
                          drops-weather.0
                          2025-03-20 15:03:02.228	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
                          drops-weather.0
                          2025-03-20 15:03:02.226	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                          drops-weather.0
                          2025-03-20 15:03:02.222	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          host.raspberrypi
                          2025-03-20 15:03:02.211	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                          host.raspberrypi
                          2025-03-20 15:03:02.209	info	"system.adapter.drops-weather.0" disabled
                          drops-weather.0
                          2025-03-20 15:03:02.167	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                          host.raspberrypi
                          2025-03-20 15:03:00.760	info	instance system.adapter.drops-weather.0 in version "1.1.0" (non-npm: iobroker-community-adapters/ioBroker.drops-weather) started with pid 125172
                          host.raspberrypi
                          2025-03-20 15:03:00.092	info	"system.adapter.drops-weather.0" enabled
                          • mcm1957
                            @winni
                            Hmmm - eigentlich sollten da DEBUG Meldungen stehen. Hast du den LOG Level in der Instanz auf debug gestellt?
                            Aber da @arteck sowieso plant auch scheduled umzustellen (damit hoffentlich dann die Zombieprozesse / Speicherfresser bereinigt werden) können wir diese Analyse auch mal nach hinten schieben.
                            Den Fehler bei manuelle Auswahl (chromkum-browser) hab ich schon gefunden, war ein Typo in jsonConfig.json. Hab dafür aber keine neue Release erstell da zuerst die Änderung von arteck stabilisiert sein sollten. Danke für das Rückmelden
                            • Winni
                              @mcm1957 so hatte ich das eingestellt.
                                Homoran Global Moderator Administrators @Winni last edited by
                                @winni sagte in Test Adapter drops-weather 1.1.x:
                                dann zeigt das log nur Errors
                                bitte auf debug umstellen
                                • Winni
                                  Winni @Homoran last edited by
                                  @homoran jetzt so:
                                  host.raspberrypi
                                  2025-03-20 15:49:41.016	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  host.raspberrypi
                                  2025-03-20 15:49:40.497	info	stopInstance system.adapter.drops-weather.0 send kill signal
                                  drops-weather.0
                                  2025-03-20 15:49:40.494	error	Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-03-20 15:49:40.494	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
                                  drops-weather.0
                                  2025-03-20 15:49:40.492	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                                  drops-weather.0
                                  2025-03-20 15:49:40.492	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  drops-weather.0
                                  2025-03-20 15:49:40.491	info	terminating
                                  drops-weather.0
                                  2025-03-20 15:49:40.490	debug	destroy browser
                                  drops-weather.0
                                  2025-03-20 15:49:40.489	info	Got terminate signal TERMINATE_YOURSELF
                                  host.raspberrypi
                                  2025-03-20 15:49:40.486	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                                  host.raspberrypi
                                  2025-03-20 15:49:40.486	info	"system.adapter.drops-weather.0" disabled
                                  drops-weather.0
                                  2025-03-20 15:49:40.442	debug	de
                                  drops-weather.0
                                  2025-03-20 15:49:40.434	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  drops-weather.0
                                  2025-03-20 15:49:40.433	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                  drops-weather.0
                                  2025-03-20 15:49:40.413	debug	getting system language
                                  drops-weather.0
                                  2025-03-20 15:49:40.412	info	browserPath set to puppeteer default
                                  drops-weather.0
                                  2025-03-20 15:49:40.412	info	browserMode set to automatic
                                  drops-weather.0
                                  2025-03-20 15:49:40.401	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                    jetzt so:
                                    wie geht das denn 😱 ??
                                    debug und error?
                                    Winni Negalein 2 Replies Last reply Reply Quote 0
                                    • Winni
                                      @homoran keine Ahnung, aber jetzt steht da nur noch debug, vielleicht war ich zu schnell..
                                        @winni das log passt auf jeden Fall.
                                        Da sollte jetzt alles für @mcm1957 drin sein
                                        • Negalein
                                          Negalein Global Moderator @Homoran last edited by
                                          @homoran sagte in Test Adapter drops-weather 1.1.x:
                                          wie geht das denn ??
                                          Screenshot gleich nach speichern gemacht.
                                          Sobald der Adapter gestartet ist, steht da nur eins von denen.
                                            so hab da mal was
                                            https://github.com/iobroker-community-adapters/ioBroker.drops-weather
                                            der adapter muss aber zuvor gelöscht werden (die id aus den einstellungen merken)
                                            dann installieren
                                            dann instanz hinzufügen
                                            dann starten
                                            es kann aber sein dass es paar zombie prozesse gibt .. also am besten den iobroker neu starten oder die prozesse killen
                                            dann erst den adapter starten
                                            sollte dann so aussehen
                                            kommt so eine meldung im LOG
                                            drops-weather.0
                                            2025-03-20 20:12:31.879	error	drops-weather.0 already running
                                            drops-weather.0
                                            2025-03-20 20:12:31.882	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                                            host.iobroker
                                            2025-03-20 20:12:32.436	error	instance system.adapter.drops-weather.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                                            dann sind da noch prozesse am laufen die gekillt werden müssen.. oder iob neu starten
                                            Winni 1 Reply Last reply Reply Quote 1
                                            drops-weather mcm1957
                                            21
                                            196
                                            25340
