    4. Test Adapter drops-weather 1.2.x
    • mcm1957
      mcm1957 @arteck last edited by
      @arteck said in Test Adapter drops-weather 1.1.x:
      so für alle..
      das wird nix.. wir müssen den auf cron umstellen..
      ich bitte um Geduld
      @arteck
      Ich nehm an du meinst damit umstellen auf scheduled adapter.
      Machst du das? Oder brauchts du Support? (wobei ich nicht bös bin wenn du das machst, bin eh ausgelastet).
      • mcm1957
        mcm1957 @Winni last edited by
        @winni said in Test Adapter drops-weather 1.1.x:
        @mcm1957, ok
        drops-weather.0
        2025-03-20 08:50:23.836	error	Cannot read properties of null (reading 'pages')
        drops-weather.0
        2025-03-20 08:50:23.836	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
        drops-weather.0
        2025-03-20 08:50:23.834	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
        drops-weather.0
        2025-03-20 08:50:23.834	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        drops-weather.0
        2025-03-20 08:50:23.832	info	terminating
        drops-weather.0
        2025-03-20 08:50:23.830	info	Got terminate signal TERMINATE_YOURSELF
        drops-weather.0
        2025-03-20 08:50:23.803	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        drops-weather.0
        2025-03-20 08:50:23.801	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
        drops-weather.0
        2025-03-20 08:50:23.775	info	browserPath set to puppeteer default
        drops-weather.0
        2025-03-20 08:50:23.772	info	browserMode set to automatic
        drops-weather.0
        2025-03-20 08:50:23.760	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
        Hmm - das ist aber nicht DEBUG Level log 🙂
        Winni 1 Reply Last reply Reply Quote 0
          A Former User @arteck last edited by
          @arteck
          um's Choas kompletty zu machen, es gibt auch noch Fetch... 🙂
          https://www.zenrows.com/blog/axios-vs-got-vs-fetch#which-is-best
          Ihr seit schon hartnaeckig, das muss man sagen! geht nicht - gibts net.. 👍 👍 👍 👍
          • Winni
            Winni @mcm1957 last edited by
            @mcm1957 meinst du so?
            Zeit
            info
            Nachricht
            host.raspberrypi
            2025-03-20 15:03:02.764	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            host.raspberrypi
            2025-03-20 15:03:02.233	info	stopInstance system.adapter.drops-weather.0 send kill signal
            drops-weather.0
            2025-03-20 15:03:02.229	error	Cannot read properties of null (reading 'pages')
            drops-weather.0
            2025-03-20 15:03:02.228	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
            drops-weather.0
            2025-03-20 15:03:02.226	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
            drops-weather.0
            2025-03-20 15:03:02.222	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            host.raspberrypi
            2025-03-20 15:03:02.211	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
            host.raspberrypi
            2025-03-20 15:03:02.209	info	"system.adapter.drops-weather.0" disabled
            drops-weather.0
            2025-03-20 15:03:02.167	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
            host.raspberrypi
            2025-03-20 15:03:00.760	info	instance system.adapter.drops-weather.0 in version "1.1.0" (non-npm: iobroker-community-adapters/ioBroker.drops-weather) started with pid 125172
            host.raspberrypi
            2025-03-20 15:03:00.092	info	"system.adapter.drops-weather.0" enabled
            • mcm1957
              @winni
              Hmmm - eigentlich sollten da DEBUG Meldungen stehen. Hast du den LOG Level in der Instanz auf debug gestellt?
              Aber da @arteck sowieso plant auch scheduled umzustellen (damit hoffentlich dann die Zombieprozesse / Speicherfresser bereinigt werden) können wir diese Analyse auch mal nach hinten schieben.
              Den Fehler bei manuelle Auswahl (chromkum-browser) hab ich schon gefunden, war ein Typo in jsonConfig.json. Hab dafür aber keine neue Release erstell da zuerst die Änderung von arteck stabilisiert sein sollten. Danke für das Rückmelden
              • Winni
                @mcm1957 so hatte ich das eingestellt.
                  Homoran Global Moderator Administrators @Winni last edited by
                  @winni sagte in Test Adapter drops-weather 1.1.x:
                  dann zeigt das log nur Errors
                  bitte auf debug umstellen
                  • Winni
                    Winni @Homoran last edited by
                    @homoran jetzt so:
                    host.raspberrypi
                    2025-03-20 15:49:41.016	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    host.raspberrypi
                    2025-03-20 15:49:40.497	info	stopInstance system.adapter.drops-weather.0 send kill signal
                    drops-weather.0
                    2025-03-20 15:49:40.494	error	Cannot read properties of null (reading 'pages')
                    drops-weather.0
                    2025-03-20 15:49:40.494	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
                    drops-weather.0
                    2025-03-20 15:49:40.492	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                    drops-weather.0
                    2025-03-20 15:49:40.492	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    drops-weather.0
                    2025-03-20 15:49:40.491	info	terminating
                    drops-weather.0
                    2025-03-20 15:49:40.490	debug	destroy browser
                    drops-weather.0
                    2025-03-20 15:49:40.489	info	Got terminate signal TERMINATE_YOURSELF
                    host.raspberrypi
                    2025-03-20 15:49:40.486	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                    host.raspberrypi
                    2025-03-20 15:49:40.486	info	"system.adapter.drops-weather.0" disabled
                    drops-weather.0
                    2025-03-20 15:49:40.442	debug	de
                    drops-weather.0
                    2025-03-20 15:49:40.434	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    drops-weather.0
                    2025-03-20 15:49:40.433	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                    drops-weather.0
                    2025-03-20 15:49:40.413	debug	getting system language
                    drops-weather.0
                    2025-03-20 15:49:40.412	info	browserPath set to puppeteer default
                    drops-weather.0
                    2025-03-20 15:49:40.412	info	browserMode set to automatic
                    drops-weather.0
                    2025-03-20 15:49:40.401	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                      jetzt so:
                      wie geht das denn 😱 ??
                      debug und error?
                      Winni Negalein 2 Replies Last reply Reply Quote 0
                      • Winni
                        @homoran keine Ahnung, aber jetzt steht da nur noch debug, vielleicht war ich zu schnell..
                          @winni das log passt auf jeden Fall.
                          Da sollte jetzt alles für @mcm1957 drin sein
                          • Negalein
                            Negalein Global Moderator @Homoran last edited by
                            @homoran sagte in Test Adapter drops-weather 1.1.x:
                            wie geht das denn ??
                            Screenshot gleich nach speichern gemacht.
                            Sobald der Adapter gestartet ist, steht da nur eins von denen.
                              so hab da mal was
                              https://github.com/iobroker-community-adapters/ioBroker.drops-weather
                              der adapter muss aber zuvor gelöscht werden (die id aus den einstellungen merken)
                              dann installieren
                              dann instanz hinzufügen
                              dann starten
                              es kann aber sein dass es paar zombie prozesse gibt .. also am besten den iobroker neu starten oder die prozesse killen
                              dann erst den adapter starten
                              sollte dann so aussehen
                              kommt so eine meldung im LOG
                              drops-weather.0
                              2025-03-20 20:12:31.879	error	drops-weather.0 already running
                              drops-weather.0
                              2025-03-20 20:12:31.882	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                              host.iobroker
                              2025-03-20 20:12:32.436	error	instance system.adapter.drops-weather.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                              dann sind da noch prozesse am laufen die gekillt werden müssen.. oder iob neu starten
                              Winni 1 Reply Last reply Reply Quote 1
                              • Winni
                                Winni @arteck last edited by
                                @arteck Hallo, funktioniert bei mir leider nicht. Habe den Adapter erst deinstalliert, iob gestoppt und neu gestartet. Dann den Adapter neu installiert. Hier der Log:
                                host.raspberrypi
                                2025-03-20 20:42:18.103	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.raspberrypi
                                2025-03-20 20:42:17.538	info	stopInstance canceled schedule system.adapter.drops-weather.0
                                host.raspberrypi
                                2025-03-20 20:42:17.538	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                                host.raspberrypi
                                2025-03-20 20:42:17.537	info	"system.adapter.drops-weather.0" disabled
                                drops-weather.0
                                2025-03-20 20:42:17.494	debug	de
                                drops-weather.0
                                2025-03-20 20:42:17.486	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                drops-weather.0
                                2025-03-20 20:42:17.485	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                                drops-weather.0
                                2025-03-20 20:42:17.466	debug	getting system language
                                drops-weather.0
                                2025-03-20 20:42:17.466	info	browserPath set to puppeteer default
                                drops-weather.0
                                2025-03-20 20:42:17.465	info	browserMode set to automatic
                                drops-weather.0
                                2025-03-20 20:42:17.453	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather#df8b0a7231e71f2a89672d780c44b03675ed4dfe) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                • mcm1957
                                  mcm1957 @Winni last edited by mcm1957
                                  @arteck hat den Adapter dankenswerter Weise nochmals überarbeitet und auf schedule Betrieb umgestellt. Er startet jetzt alle 5 Minuten als neuer Prozess. Das Problem der Zobieprozesse sollte dadurch gelöst sein.
                                  Der Adapter steht in dieser Version nun als 1.2.0 nun zurVerfügung (ab morgen im LATEST).
                                  Bei Tests auf meine Pi4 in den letzen Tagen hat dieser "halbwegs" funktioniert. Das halbwegs bezieht sich darauf, dass der Adapter in nicht vorhersehbarere Weise updates durch ein Timeout verweigert - mal gehen die Update stundenlang gut, dann kommen wieder timeouts ohne unterbrechung... Die Ursache dafür ist zumindest mir derzeit nicht klar. Eine Vergrößerung des Timeouts von 10 auf 15s hat keine Verbesserung gebracht.
                                  Ich stellen den Adapter trotzdem mal zum Testen bereit - viulleicht zeigt sich ja da dann ein klareres Bild. Oder @arteck hat noch eine Idee wie / wo "man" suchen könnte.
                                  mcm1957
                                  EDIT:
                                  mcm1957 about a minute ago
                                  ACHTUNG:
                                  Bitte vor der Installation der 1.2.0 den Adapter DEINSTALLIEREN. Vorher bitte die locationID notieren.
                                  Siehe: https://forum.iobroker.net/topic/80335/test-adapter-drops-weather-1-1-x/77
                                  Chris76e S 3 Replies Last reply Reply Quote 0
                                  • Chris76e
                                    Chris76e @mcm1957 last edited by
                                    @mcm1957
                                    Auf meinem System Startet der immer wieder neu....
                                    01
                                    Log-Größe: 19.1 KB
                                    Zeit
                                    drops-weather.0
                                    	2025-03-24 18:58:47.388	info	terminating
                                    drops-weather.0
                                    	2025-03-24 18:58:47.075	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                                    drops-weather.0
                                    	2025-03-24 18:58:47.015	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                                    drops-weather.0
                                    	2025-03-24 18:58:46.902	info	Terminated (NO_ERROR): Without reason
                                    drops-weather.0
                                    	2025-03-24 18:58:46.900	info	terminating
                                    drops-weather.0
                                    	2025-03-24 18:58:46.883	debug	destroy browser
                                    drops-weather.0
                                    	2025-03-24 18:58:46.882	debug	creating 1 hour states
                                    drops-weather.0
                                    	2025-03-24 18:58:46.881	debug	creating 5 min states
                                    drops-weather.0
                                    	2025-03-24 18:58:46.881	debug	weatherData found
                                    drops-weather.0
                                    	2025-03-24 18:58:46.877	debug	got labeltext "It will stay dry for now"
                                    drops-weather.0
                                    	2025-03-24 18:58:46.873	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                                    drops-weather.0
                                    	2025-03-24 18:58:46.865	debug	domcontent loaded, evaluate page
                                    drops-weather.0
                                    	2025-03-24 18:58:44.910	debug	creating new page ...
                                    drops-weather.0
                                    	2025-03-24 18:58:44.909	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                                    drops-weather.0
                                    	2025-03-24 18:58:44.569	debug	de
                                    drops-weather.0
                                    	2025-03-24 18:58:44.532	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                                    drops-weather.0
                                    	2025-03-24 18:58:44.531	debug	getting system language
                                    drops-weather.0
                                    	2025-03-24 18:58:44.530	debug	browserPath set to puppeteer default
                                    drops-weather.0
                                    	2025-03-24 18:58:44.530	debug	browserMode set to automatic, running on linux / x64
                                    drops-weather.0
                                    	2025-03-24 18:58:44.511	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                    drops-weather.0
                                    	2025-03-24 18:58:05.945	info	terminating
                                    drops-weather.0
                                    	2025-03-24 18:58:05.565	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                                    drops-weather.0
                                    	2025-03-24 18:58:05.555	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                                    drops-weather.0
                                    	2025-03-24 18:58:05.491	info	Terminated (NO_ERROR): Without reason
                                    drops-weather.0
                                    	2025-03-24 18:58:05.489	info	terminating
                                    drops-weather.0
                                    	2025-03-24 18:58:05.439	debug	destroy browser
                                    drops-weather.0
                                    	2025-03-24 18:58:05.438	debug	creating 1 hour states
                                    drops-weather.0
                                    	2025-03-24 18:58:05.435	debug	creating 5 min states
                                    drops-weather.0
                                    	2025-03-24 18:58:05.435	debug	weatherData found
                                    drops-weather.0
                                    	2025-03-24 18:58:05.431	debug	got labeltext "It will stay dry for now"
                                    drops-weather.0
                                    	2025-03-24 18:58:05.429	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                                    drops-weather.0
                                    	2025-03-24 18:58:05.427	debug	domcontent loaded, evaluate page
                                    drops-weather.0
                                    	2025-03-24 18:58:02.955	debug	creating new page ...
                                    drops-weather.0
                                    	2025-03-24 18:58:02.955	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                                    drops-weather.0
                                    	2025-03-24 18:58:02.621	debug	de
                                    drops-weather.0
                                    	2025-03-24 18:58:02.561	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                                    drops-weather.0
                                    	2025-03-24 18:58:02.561	debug	getting system language
                                    drops-weather.0
                                    	2025-03-24 18:58:02.560	debug	browserPath set to puppeteer default
                                    drops-weather.0
                                    	2025-03-24 18:58:02.560	debug	browserMode set to automatic, running on linux / x64
                                    drops-weather.0
                                    	2025-03-24 18:58:02.525	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                    drops-weather.0
                                    	2025-03-24 18:57:48.137	info	terminating
                                    drops-weather.0
                                    	2025-03-24 18:57:47.641	info	Terminated (NO_ERROR): Without reason
                                      Sleepwalker @mcm1957 last edited by
                                      @mcm1957
                                      Moin!
                                      [OT]
                                      Da demnächst die Gartensaison wieder startet und ich unseren Rasimir entstauben will, fiel mein Blick die Tage Richtung Drops-Adapter, den ich seit vielen Monden wegen eines Axios-Fehlers deaktiviert hatte.
                                      Nun sehe ich, dass sich dem Adapter schon angenommen wurde und wollte ein herzliches "Danke" hierlassen! Ich freue mich drauf, den Adapter ab morgen "offiziell" im Latest-Repo begrüßen zu dürfen.
                                      Bei mir läuft ioBroker auch noch im Container auf einem Pi4 mit Bullseye. Habe mich noch nicht getraut auf Bookworm zu aktualisieren 😄
                                      Ich stelle mich gerne als Tester zur Verfügung, für mehr reicht meine (Frei-)Zeit aktuell leider nicht, auch wenn ich selbst Software entwickele. Echt stark, dass sich jemand dem Adapter annimmt. Er hat sich zu meinem Liebling unter den Regenwarnern gemausert.
                                      Vielen Dank nochmal an euch!
                                      [/OT]
                                      • mcm1957
                                        mcm1957 @Chris76e last edited by
                                        @chris76e
                                        Das ist das normale Verhalten für einen SCHEDULED Adapter. Dieser startet gemäß cron einstellungen, erledigt seine Aufgabe und beendet sich dann wieder.
                                        • Chris76e
                                          @mcm1957 sagte in Test Adapter drops-weather 1.1.x:
                                          Habe das so verstanden das er das alle 5 Minuten macht und nicht ständig.
                                          • mcm1957
                                            @chris76e
                                            Ok, ja sollte er nur alle 5 Minuten machen, genauer (derzeit) immer wenn die Minutenanzahl durch 5 teilbar ist (5, 10, 15, ...)
                                            ABER auch direkt nach der Installation oder nach dem Ändern von Parametern zusätzlich einmal.
                                            Chris76e mcm1957 2 Replies Last reply Reply Quote 0
                                            drops-weather mcm1957
                                            21
                                            196
                                            25472
