    4. Test Adapter drops-weather 1.2.x
    • mcm1957
      mcm1957 @Winni last edited by
      @winni said in Test Adapter drops-weather 1.1.x:
      @mcm1957, ok
      drops-weather.0
      2025-03-20 08:50:23.836	error	Cannot read properties of null (reading 'pages')
      drops-weather.0
      2025-03-20 08:50:23.836	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
      drops-weather.0
      2025-03-20 08:50:23.834	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
      drops-weather.0
      2025-03-20 08:50:23.834	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      drops-weather.0
      2025-03-20 08:50:23.832	info	terminating
      drops-weather.0
      2025-03-20 08:50:23.830	info	Got terminate signal TERMINATE_YOURSELF
      drops-weather.0
      2025-03-20 08:50:23.803	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      drops-weather.0
      2025-03-20 08:50:23.801	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
      drops-weather.0
      2025-03-20 08:50:23.775	info	browserPath set to puppeteer default
      drops-weather.0
      2025-03-20 08:50:23.772	info	browserMode set to automatic
      drops-weather.0
      2025-03-20 08:50:23.760	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
      Hmm - das ist aber nicht DEBUG Level log 🙂
      Winni 1 Reply Last reply Reply Quote 0
        A Former User @arteck last edited by
        @arteck
        um's Choas kompletty zu machen, es gibt auch noch Fetch... 🙂
        https://www.zenrows.com/blog/axios-vs-got-vs-fetch#which-is-best
        Ihr seit schon hartnaeckig, das muss man sagen! geht nicht - gibts net.. 👍 👍 👍 👍
        • Winni
          Winni @mcm1957 last edited by
          @mcm1957 meinst du so?
          Zeit
          info
          Nachricht
          host.raspberrypi
          2025-03-20 15:03:02.764	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          host.raspberrypi
          2025-03-20 15:03:02.233	info	stopInstance system.adapter.drops-weather.0 send kill signal
          drops-weather.0
          2025-03-20 15:03:02.229	error	Cannot read properties of null (reading 'pages')
          drops-weather.0
          2025-03-20 15:03:02.228	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
          drops-weather.0
          2025-03-20 15:03:02.226	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
          drops-weather.0
          2025-03-20 15:03:02.222	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          host.raspberrypi
          2025-03-20 15:03:02.211	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
          host.raspberrypi
          2025-03-20 15:03:02.209	info	"system.adapter.drops-weather.0" disabled
          drops-weather.0
          2025-03-20 15:03:02.167	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
          host.raspberrypi
          2025-03-20 15:03:00.760	info	instance system.adapter.drops-weather.0 in version "1.1.0" (non-npm: iobroker-community-adapters/ioBroker.drops-weather) started with pid 125172
          host.raspberrypi
          2025-03-20 15:03:00.092	info	"system.adapter.drops-weather.0" enabled
          • mcm1957
            @winni
            Hmmm - eigentlich sollten da DEBUG Meldungen stehen. Hast du den LOG Level in der Instanz auf debug gestellt?
            Aber da @arteck sowieso plant auch scheduled umzustellen (damit hoffentlich dann die Zombieprozesse / Speicherfresser bereinigt werden) können wir diese Analyse auch mal nach hinten schieben.
            Den Fehler bei manuelle Auswahl (chromkum-browser) hab ich schon gefunden, war ein Typo in jsonConfig.json. Hab dafür aber keine neue Release erstell da zuerst die Änderung von arteck stabilisiert sein sollten. Danke für das Rückmelden
            • Winni
              @mcm1957 so hatte ich das eingestellt.
                Homoran Global Moderator Administrators @Winni last edited by
                @winni sagte in Test Adapter drops-weather 1.1.x:
                dann zeigt das log nur Errors
                bitte auf debug umstellen
                • Winni
                  Winni @Homoran last edited by
                  @homoran jetzt so:
                  host.raspberrypi
                  2025-03-20 15:49:41.016	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  host.raspberrypi
                  2025-03-20 15:49:40.497	info	stopInstance system.adapter.drops-weather.0 send kill signal
                  drops-weather.0
                  2025-03-20 15:49:40.494	error	Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-03-20 15:49:40.494	error	TypeError: Cannot read properties of null (reading 'pages') at DropsWeather.destroyBrowser (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:320:37) at DropsWeather.onUnload (/opt/iobroker/node_modules/iobroker.drops-weather/main.js:335:18) at DropsWeather.emit (node:events:524:28) at DropsWeather._stop (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:1171:16) at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7166:20) at Immediate.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/build/esm/lib/states/statesInRedisClient.js:291:37) at process.processImmediate (node:internal/timers:483:21)
                  drops-weather.0
                  2025-03-20 15:49:40.492	error	unhandled promise rejection: Cannot read properties of null (reading 'pages')
                  drops-weather.0
                  2025-03-20 15:49:40.492	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                  drops-weather.0
                  2025-03-20 15:49:40.491	info	terminating
                  drops-weather.0
                  2025-03-20 15:49:40.490	debug	destroy browser
                  drops-weather.0
                  2025-03-20 15:49:40.489	info	Got terminate signal TERMINATE_YOURSELF
                  host.raspberrypi
                  2025-03-20 15:49:40.486	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                  host.raspberrypi
                  2025-03-20 15:49:40.486	info	"system.adapter.drops-weather.0" disabled
                  drops-weather.0
                  2025-03-20 15:49:40.442	debug	de
                  drops-weather.0
                  2025-03-20 15:49:40.434	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  drops-weather.0
                  2025-03-20 15:49:40.433	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                  drops-weather.0
                  2025-03-20 15:49:40.413	debug	getting system language
                  drops-weather.0
                  2025-03-20 15:49:40.412	info	browserPath set to puppeteer default
                  drops-weather.0
                  2025-03-20 15:49:40.412	info	browserMode set to automatic
                  drops-weather.0
                  2025-03-20 15:49:40.401	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                    jetzt so:
                    wie geht das denn 😱 ??
                    debug und error?
                    Winni Negalein 2 Replies Last reply Reply Quote 0
                    • Winni
                      @homoran keine Ahnung, aber jetzt steht da nur noch debug, vielleicht war ich zu schnell..
                        @winni das log passt auf jeden Fall.
                        Da sollte jetzt alles für @mcm1957 drin sein
                        • Negalein
                          Negalein Global Moderator @Homoran last edited by
                          @homoran sagte in Test Adapter drops-weather 1.1.x:
                          wie geht das denn ??
                          Screenshot gleich nach speichern gemacht.
                          Sobald der Adapter gestartet ist, steht da nur eins von denen.
                            so hab da mal was
                            https://github.com/iobroker-community-adapters/ioBroker.drops-weather
                            der adapter muss aber zuvor gelöscht werden (die id aus den einstellungen merken)
                            dann installieren
                            dann instanz hinzufügen
                            dann starten
                            es kann aber sein dass es paar zombie prozesse gibt .. also am besten den iobroker neu starten oder die prozesse killen
                            dann erst den adapter starten
                            sollte dann so aussehen
                            kommt so eine meldung im LOG
                            drops-weather.0
                            2025-03-20 20:12:31.879	error	drops-weather.0 already running
                            drops-weather.0
                            2025-03-20 20:12:31.882	warn	Terminated (ADAPTER_ALREADY_RUNNING): Without reason
                            host.iobroker
                            2025-03-20 20:12:32.436	error	instance system.adapter.drops-weather.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
                            dann sind da noch prozesse am laufen die gekillt werden müssen.. oder iob neu starten
                            Winni 1 Reply Last reply Reply Quote 1
                            • Winni
                              Winni @arteck last edited by
                              @arteck Hallo, funktioniert bei mir leider nicht. Habe den Adapter erst deinstalliert, iob gestoppt und neu gestartet. Dann den Adapter neu installiert. Hier der Log:
                              host.raspberrypi
                              2025-03-20 20:42:18.103	info	instance system.adapter.drops-weather.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              host.raspberrypi
                              2025-03-20 20:42:17.538	info	stopInstance canceled schedule system.adapter.drops-weather.0
                              host.raspberrypi
                              2025-03-20 20:42:17.538	info	stopInstance system.adapter.drops-weather.0 (force=false, process=true)
                              host.raspberrypi
                              2025-03-20 20:42:17.537	info	"system.adapter.drops-weather.0" disabled
                              drops-weather.0
                              2025-03-20 20:42:17.494	debug	de
                              drops-weather.0
                              2025-03-20 20:42:17.486	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              drops-weather.0
                              2025-03-20 20:42:17.485	error	error launching browser undefined - Error: Failed to launch the browser process! undefined TROUBLESHOOTING: https://pptr.dev/troubleshooting
                              drops-weather.0
                              2025-03-20 20:42:17.466	debug	getting system language
                              drops-weather.0
                              2025-03-20 20:42:17.466	info	browserPath set to puppeteer default
                              drops-weather.0
                              2025-03-20 20:42:17.465	info	browserMode set to automatic
                              drops-weather.0
                              2025-03-20 20:42:17.453	info	starting. Version 1.1.0 (non-npm: iobroker-community-adapters/ioBroker.drops-weather#df8b0a7231e71f2a89672d780c44b03675ed4dfe) in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                              • mcm1957
                                mcm1957 @Winni last edited by mcm1957
                                @arteck hat den Adapter dankenswerter Weise nochmals überarbeitet und auf schedule Betrieb umgestellt. Er startet jetzt alle 5 Minuten als neuer Prozess. Das Problem der Zobieprozesse sollte dadurch gelöst sein.
                                Der Adapter steht in dieser Version nun als 1.2.0 nun zurVerfügung (ab morgen im LATEST).
                                Bei Tests auf meine Pi4 in den letzen Tagen hat dieser "halbwegs" funktioniert. Das halbwegs bezieht sich darauf, dass der Adapter in nicht vorhersehbarere Weise updates durch ein Timeout verweigert - mal gehen die Update stundenlang gut, dann kommen wieder timeouts ohne unterbrechung... Die Ursache dafür ist zumindest mir derzeit nicht klar. Eine Vergrößerung des Timeouts von 10 auf 15s hat keine Verbesserung gebracht.
                                Ich stellen den Adapter trotzdem mal zum Testen bereit - viulleicht zeigt sich ja da dann ein klareres Bild. Oder @arteck hat noch eine Idee wie / wo "man" suchen könnte.
                                mcm1957
                                EDIT:
                                mcm1957 about a minute ago
                                ACHTUNG:
                                Bitte vor der Installation der 1.2.0 den Adapter DEINSTALLIEREN. Vorher bitte die locationID notieren.
                                Siehe: https://forum.iobroker.net/topic/80335/test-adapter-drops-weather-1-1-x/77
                                Chris76e S 3 Replies Last reply Reply Quote 0
                                • Chris76e
                                  Chris76e @mcm1957 last edited by
                                  @mcm1957
                                  Auf meinem System Startet der immer wieder neu....
                                  01
                                  Log-Größe: 19.1 KB
                                  Zeit
                                  drops-weather.0
                                  	2025-03-24 18:58:47.388	info	terminating
                                  drops-weather.0
                                  	2025-03-24 18:58:47.075	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                                  drops-weather.0
                                  	2025-03-24 18:58:47.015	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                                  drops-weather.0
                                  	2025-03-24 18:58:46.902	info	Terminated (NO_ERROR): Without reason
                                  drops-weather.0
                                  	2025-03-24 18:58:46.900	info	terminating
                                  drops-weather.0
                                  	2025-03-24 18:58:46.883	debug	destroy browser
                                  drops-weather.0
                                  	2025-03-24 18:58:46.882	debug	creating 1 hour states
                                  drops-weather.0
                                  	2025-03-24 18:58:46.881	debug	creating 5 min states
                                  drops-weather.0
                                  	2025-03-24 18:58:46.881	debug	weatherData found
                                  drops-weather.0
                                  	2025-03-24 18:58:46.877	debug	got labeltext "It will stay dry for now"
                                  drops-weather.0
                                  	2025-03-24 18:58:46.873	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                                  drops-weather.0
                                  	2025-03-24 18:58:46.865	debug	domcontent loaded, evaluate page
                                  drops-weather.0
                                  	2025-03-24 18:58:44.910	debug	creating new page ...
                                  drops-weather.0
                                  	2025-03-24 18:58:44.909	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                                  drops-weather.0
                                  	2025-03-24 18:58:44.569	debug	de
                                  drops-weather.0
                                  	2025-03-24 18:58:44.532	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                                  drops-weather.0
                                  	2025-03-24 18:58:44.531	debug	getting system language
                                  drops-weather.0
                                  	2025-03-24 18:58:44.530	debug	browserPath set to puppeteer default
                                  drops-weather.0
                                  	2025-03-24 18:58:44.530	debug	browserMode set to automatic, running on linux / x64
                                  drops-weather.0
                                  	2025-03-24 18:58:44.511	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                  drops-weather.0
                                  	2025-03-24 18:58:05.945	info	terminating
                                  drops-weather.0
                                  	2025-03-24 18:58:05.565	debug	Rain (data_1h): [{"label":"Mo 21:00","value":"0"},{"label":"Mo 22:00","value":"0"},{"label":"Mo 23:00","value":"0"},{"label":"Di 00:00","value":"0"},{"label":"Di 01:00","value":"0"},{"label":"Di 02:00","value":"0"},{"label":"Di 03:00","value":"0"},{"label":"Di 04:00","value":"0"},{"label":"Di 05:00","value":"0"},{"label":"Di 06:00","value":"0"},{"label":"Di 07:00","value":"0"},{"label":"Di 08:00","value":"0"},{"label":"Di 09:00","value":"0"},{"label":"Di 10:00","value":"0"},{"label":"Di 11:00","value":"0"},{"label":"Di 12:00","value":"0"},{"label":"Di 13:00","value":"0"},{"label":"Di 14:00","value":"0"},{"label":"Di 15:00","value":"0"},{"label":"Di 16:00","value":"0"},{"label":"Di 17:00","value":"0"},{"label":"Di 18:00","value":"0"},{"label":"Di 19:00","value":"0"},{"label":"Di 20:00","value":"0.1"}]
                                  drops-weather.0
                                  	2025-03-24 18:58:05.555	debug	Rain (data_5min): [{"label":"18:55","value":"0"},{"label":"19:00","value":"0"},{"label":"19:05","value":"0"},{"label":"19:10","value":"0"},{"label":"19:15","value":"0"},{"label":"19:20","value":"0"},{"label":"19:25","value":"0"},{"label":"19:30","value":"0"},{"label":"19:35","value":"0"},{"label":"19:40","value":"0"},{"label":"19:45","value":"0"},{"label":"19:50","value":"0"},{"label":"19:55","value":"0"},{"label":"20:00","value":"0"},{"label":"20:05","value":"0"},{"label":"20:10","value":"0"},{"label":"20:15","value":"0"},{"label":"20:20","value":"0"},{"label":"20:25","value":"0"},{"label":"20:30","value":"0"},{"label":"20:35","value":"0"},{"label":"20:40","value":"0"},{"label":"20:45","value":"0"},{"label":"20:50","value":"0"},{"label":"20:55","value":"0"},{"label":"21:00","value":"0"},{"label":"21:05","value":"0"},{"label":"21:10","value":"0"},{"label":"21:15","value":"0"},{"label":"21:20","value":"0"},{"label":"21:25","value":"0"},{"label":"21:30","value":"0"},{"label":"21:35","value":"0"},{"label":"21:40","value":"0"},{"label":"21:45","value":"0"},{"label":"21:50","value":"0"},{"label":"21:55","value":"0"},{"label":"22:00","value":"0"}]
                                  drops-weather.0
                                  	2025-03-24 18:58:05.491	info	Terminated (NO_ERROR): Without reason
                                  drops-weather.0
                                  	2025-03-24 18:58:05.489	info	terminating
                                  drops-weather.0
                                  	2025-03-24 18:58:05.439	debug	destroy browser
                                  drops-weather.0
                                  	2025-03-24 18:58:05.438	debug	creating 1 hour states
                                  drops-weather.0
                                  	2025-03-24 18:58:05.435	debug	creating 5 min states
                                  drops-weather.0
                                  	2025-03-24 18:58:05.435	debug	weatherData found
                                  drops-weather.0
                                  	2025-03-24 18:58:05.431	debug	got labeltext "It will stay dry for now"
                                  drops-weather.0
                                  	2025-03-24 18:58:05.429	debug	got scriptContents "[""," document.addEventListener(\"DOMContentLoaded\", () =>"," RainGraph.create({"," id: 0,"," series: {\"2h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T17:55:00Z\",\"timestamp\":1742838900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:05:00Z\",\"timestamp\":1742839500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:10:00Z\",\"timestamp\":1742839800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:15:00Z\",\"timestamp\":1742840100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:20:00Z\",\"timestamp\":1742840400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:25:00Z\",\"timestamp\":1742840700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:30:00Z\",\"timestamp\":1742841000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:35:00Z\",\"timestamp\":1742841300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:40:00Z\",\"timestamp\":1742841600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:45:00Z\",\"timestamp\":1742841900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:50:00Z\",\"timestamp\":1742842200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T18:55:00Z\",\"timestamp\":1742842500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:05:00Z\",\"timestamp\":1742843100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:10:00Z\",\"timestamp\":1742843400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:15:00Z\",\"timestamp\":1742843700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:20:00Z\",\"timestamp\":1742844000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:25:00Z\",\"timestamp\":1742844300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:30:00Z\",\"timestamp\":1742844600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:35:00Z\",\"timestamp\":1742844900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:40:00Z\",\"timestamp\":1742845200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:45:00Z\",\"timestamp\":1742845500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:50:00Z\",\"timestamp\":1742845800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T19:55:00Z\",\"timestamp\":1742846100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:05:00Z\",\"timestamp\":1742846700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:10:00Z\",\"timestamp\":1742847000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:15:00Z\",\"timestamp\":1742847300},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:20:00Z\",\"timestamp\":1742847600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:25:00Z\",\"timestamp\":1742847900},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:30:00Z\",\"timestamp\":1742848200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:35:00Z\",\"timestamp\":1742848500},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:40:00Z\",\"timestamp\":1742848800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:45:00Z\",\"timestamp\":1742849100},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:50:00Z\",\"timestamp\":1742849400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:55:00Z\",\"timestamp\":1742849700},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000}],\"daypart\":[{\"precipitationrate\":0.0,\"time\":\"2025-03-24T17:00:00Z\",\"timestamp\":1742835600,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T18:00:00Z\",\"timestamp\":1742839200,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T19:00:00Z\",\"timestamp\":1742842800,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]},{\"precipitationrate\":0.0,\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000,\"weathericon\":[0,0,-1,-1,-1,-1,-1,-1,-1]}],\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"el\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"es\":{\"valuekind\":3},\"fr\":{\"valuekind\":3},\"hr\":{\"valuekind\":3},\"hu\":{\"valuekind\":3},\"ispush\":{\"valuekind\":4},\"it\":{\"valuekind\":3},\"nl\":{\"valuekind\":3},\"pl\":{\"valuekind\":3},\"pt\":{\"valuekind\":3},\"sv\":{\"valuekind\":3},\"tags\":{\"valuekind\":2},\"tr\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.12,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADBBB\",\"source\":\"radar-nl\",\"timestamp\":1742838300}},\"24h\":{\"data\":[{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T20:00:00Z\",\"timestamp\":1742846400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T21:00:00Z\",\"timestamp\":1742850000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T22:00:00Z\",\"timestamp\":1742853600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-24T23:00:00Z\",\"timestamp\":1742857200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T00:00:00Z\",\"timestamp\":1742860800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T01:00:00Z\",\"timestamp\":1742864400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T02:00:00Z\",\"timestamp\":1742868000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T03:00:00Z\",\"timestamp\":1742871600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T04:00:00Z\",\"timestamp\":1742875200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T05:00:00Z\",\"timestamp\":1742878800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T06:00:00Z\",\"timestamp\":1742882400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T07:00:00Z\",\"timestamp\":1742886000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T08:00:00Z\",\"timestamp\":1742889600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T09:00:00Z\",\"timestamp\":1742893200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T10:00:00Z\",\"timestamp\":1742896800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T11:00:00Z\",\"timestamp\":1742900400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T12:00:00Z\",\"timestamp\":1742904000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T13:00:00Z\",\"timestamp\":1742907600},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T14:00:00Z\",\"timestamp\":1742911200},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T15:00:00Z\",\"timestamp\":1742914800},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T16:00:00Z\",\"timestamp\":1742918400},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T17:00:00Z\",\"timestamp\":1742922000},{\"lightningclass\":-1,\"precipitationrate\":0.0,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T18:00:00Z\",\"timestamp\":1742925600},{\"lightningclass\":-1,\"precipitationrate\":0.1,\"precipitationtype\":\"rain\",\"time\":\"2025-03-25T19:00:00Z\",\"timestamp\":1742929200}],\"daypart\":null,\"nowcastmessage\":{\"de\":{\"valuekind\":3},\"en\":{\"valuekind\":3},\"nl\":{\"valuekind\":3}},\"summary\":{\"available\":true,\"latitude\":51.115,\"longitude\":6.15,\"quadindex\":\"BCACADACCBADB\",\"source\":\"weathercomputer\",\"timestamp\":1742838984}}},"," timezoneOffset: 60,"," locals: {\"labels\":[[0,\"dry\"],[0.1,\"drizzle\"],[1,\"light rain\"],[2,\"heavy rain\"]],\"language\":\"en\",\"strings\":{\"unavailable\":\"Something went wrong\",\"mmph\":\"mm per hour\",\"now\":\"now\"}} ?? [],"," timezone: \"Europe/Berlin\","," show2h: true,"," show24h: true,"," sendEvents: \"False\","," is3HourRadar: \"True\","," useUserLocation: \"False\","," show24Default: \"False\","," })"," );",""]"
                                  drops-weather.0
                                  	2025-03-24 18:58:05.427	debug	domcontent loaded, evaluate page
                                  drops-weather.0
                                  	2025-03-24 18:58:02.955	debug	creating new page ...
                                  drops-weather.0
                                  	2025-03-24 18:58:02.955	debug	Reading data from : https://www.meteox.com/en-gb/city/2937543
                                  drops-weather.0
                                  	2025-03-24 18:58:02.621	debug	de
                                  drops-weather.0
                                  	2025-03-24 18:58:02.561	debug	puppeteer.lauch invoked with {"headless":true,"defaultViewport":null,"args":["--periodic-task","--no-sandbox","--disable-setuid-sandbox","--disable-dev-shm-usage","--disable-accelerated-2d-canvas","--no-first-run","--no-zygote","--single-process","--disable-gpu","--ignore-certificate-errors"]}
                                  drops-weather.0
                                  	2025-03-24 18:58:02.561	debug	getting system language
                                  drops-weather.0
                                  	2025-03-24 18:58:02.560	debug	browserPath set to puppeteer default
                                  drops-weather.0
                                  	2025-03-24 18:58:02.560	debug	browserMode set to automatic, running on linux / x64
                                  drops-weather.0
                                  	2025-03-24 18:58:02.525	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                  drops-weather.0
                                  	2025-03-24 18:57:48.137	info	terminating
                                  drops-weather.0
                                  	2025-03-24 18:57:47.641	info	Terminated (NO_ERROR): Without reason
                                    Sleepwalker @mcm1957 last edited by
                                    @mcm1957
                                    Moin!
                                    [OT]
                                    Da demnächst die Gartensaison wieder startet und ich unseren Rasimir entstauben will, fiel mein Blick die Tage Richtung Drops-Adapter, den ich seit vielen Monden wegen eines Axios-Fehlers deaktiviert hatte.
                                    Nun sehe ich, dass sich dem Adapter schon angenommen wurde und wollte ein herzliches "Danke" hierlassen! Ich freue mich drauf, den Adapter ab morgen "offiziell" im Latest-Repo begrüßen zu dürfen.
                                    Bei mir läuft ioBroker auch noch im Container auf einem Pi4 mit Bullseye. Habe mich noch nicht getraut auf Bookworm zu aktualisieren 😄
                                    Ich stelle mich gerne als Tester zur Verfügung, für mehr reicht meine (Frei-)Zeit aktuell leider nicht, auch wenn ich selbst Software entwickele. Echt stark, dass sich jemand dem Adapter annimmt. Er hat sich zu meinem Liebling unter den Regenwarnern gemausert.
                                    Vielen Dank nochmal an euch!
                                    [/OT]
                                    • mcm1957
                                      mcm1957 @Chris76e last edited by
                                      @chris76e
                                      Das ist das normale Verhalten für einen SCHEDULED Adapter. Dieser startet gemäß cron einstellungen, erledigt seine Aufgabe und beendet sich dann wieder.
                                      • Chris76e
                                        @mcm1957 sagte in Test Adapter drops-weather 1.1.x:
                                        Habe das so verstanden das er das alle 5 Minuten macht und nicht ständig.
                                        • mcm1957
                                          @chris76e
                                          Ok, ja sollte er nur alle 5 Minuten machen, genauer (derzeit) immer wenn die Minutenanzahl durch 5 teilbar ist (5, 10, 15, ...)
                                          ABER auch direkt nach der Installation oder nach dem Ändern von Parametern zusätzlich einmal.
                                          Chris76e mcm1957 2 Replies Last reply Reply Quote 0
                                          • Chris76e
                                            @mcm1957
                                            so sieht es bei mir aus:
                                            drops-weather.0
                                            	2025-03-24 19:16:44.345	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:43.849	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:16:43.848	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:41.245	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:16:33.864	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:33.389	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:16:33.387	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:30.720	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:16:23.445	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:22.952	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:16:22.951	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:20.205	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:16:12.670	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:12.171	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:16:12.170	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:09.570	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:16:02.063	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:16:01.564	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:16:01.563	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:58.740	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:15:47.979	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:15:47.979	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:45.209	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:15:37.552	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:37.061	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:15:37.060	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:28.333	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:15:20.443	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:19.947	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:15:19.947	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:17.148	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:15:08.618	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:15:08.618	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:15:05.650	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:14:54.896	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:54.401	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:14:54.400	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:51.649	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:14:44.832	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:44.338	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:14:44.338	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:41.840	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:14:34.264	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:33.838	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:14:33.837	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:30.789	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:14:23.180	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:14:23.180	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:20.282	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:14:13.210	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:12.719	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:14:12.718	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:10.193	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:14:03.230	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:14:02.740	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:14:02.739	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:13:59.884	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:13:51.804	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:13:51.311	info	Terminated (NO_ERROR): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:13:51.310	info	terminating
                                            drops-weather.0
                                            	2025-03-24 19:13:48.751	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.drops-weather, node: v20.19.0, js-controller: 7.0.6
                                            drops-weather.0
                                            	2025-03-24 19:13:39.050	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                            drops-weather.0
                                            	2025-03-24 19:13:39.050	info	terminating
                                            drops-weather mcm1957
                                            21
                                            196
                                            25340
