    4. Material Design Widgets: Calendar Widget
    • jojo regneup
      jojo regneup @sigi234 last edited by jojo regneup
      @sigi234
      Mein Skript sieht wie folgt aus:
      // momentjs is required as dependecies in javascript adapter
      const moment = require("moment");
      var instances = $(`[id=ical.*.data.table]`);
      instances.on(ical2CalendarWidget);
      // remove this, if you know to use your own datapoint
      let datapointId = 'materialdesignwidgets.calendar.ical2calendar'
      createState(datapointId, "[]", {
        read: true,
        write: false,
        desc: "JSON String for Calendar Widget",
        type: "string",
        def: "[]"
      function ical2CalendarWidget() {
          try {
              let calList = [];
              for (var inst = 0; inst <= instances.length - 1; inst++) {
                  let icalObj = getState(instances[inst]).val;
                  if (icalObj) {
                      for (var i = 0; i <= icalObj.length - 1; i++) {
                          let item = icalObj[i];
                          // extract calendar color
                          let calendarName = item._class.split(' ')[0].replace('ical_', '');
                          let startTime = moment(item._date);
                          let endTime = moment(item._end);
                          let start = startTime.format("YYYY-MM-DD HH:mm");
                          let end = endTime.format("YYYY-MM-DD HH:mm");
                          if (startTime.format('HH:mm') === '00:00' && endTime.format('HH:mm') === '00:00') {
                              // is full-day event
                              if (endTime.diff(startTime, 'hours') === 24) {
                                  // full-day event, one day
                                  start = startTime.format("YYYY-MM-DD");
                                  end = startTime.format("YYYY-MM-DD");
                              } else {
                                  // full-day event, multiple days
                                  end = endTime.format("YYYY-MM-DD");
                          // create object for calendar widget
                          calList.push({
                              color: getMyCalendarColor(calendarName),
                              colorText: getMyCalendarTextColor(calendarName),
                              start: start,
                              end: end
                      function getMyCalendarColor(calendarName) {
                          // assign colors via the calendar names, use calendar name as set in ical
                          if (calendarName === 'calendar1') {
                              return '#FF0000';
                          } else if (calendarName === 'calendar2') {
                              return '#44739e'
                          } else if (calendarName === 'calendar3') {
                              return '#32a852'
                      function getMyCalendarTextColor(calendarName) {
                              return '#FFFFFF';
                              return '#FFFFFF'
                              return '#FFFFFF'
                  // Enter the destination data point that is to be used as object ID in the widget
                  setState('0_userdata.0.ical2Calendar', JSON.stringify(calList), true);
          } catch (e) {
              console.error(`ical2MaterialDesignCalendarWidget: message: ${e.message}, stack: ${e.stack}`);
      ical2CalendarWidget();
      Ich habe mir dieses einfach aus den Docs von Github entnommen. Weiß aber nicht genau, ob ich da jetzt noch was ändern muss.
        sigi234 Forum Testing Most Active @jojo regneup last edited by sigi234
        @jojo-regneup
        Das ist meines was funktioniert:
        let datapointId = 'materialdesignwidgets.calendar.ical0calendar'
          read: true,
          write: false,
          type: "string",
          def: "[]"
            try {
                let calList = [];
                    if (icalObj) {
                                } else {
                            calList.push({
                                start: start,
                                end: end
                            if (calendarName === 'Sigi') {
                                return '#0094ff';
                            } else if (calendarName === 'Geburtstage') {
                                return '#ff9214'
                            } else if (calendarName === 'Abfall Neuhofen') {
                                return '#0094ff'
                                return '#FFFFFF';
                                return '#FFFFFF'
                                return '#FFFFFF'
                    setState(datapointId, JSON.stringify(calList), true);
            } catch (e) {
        calendarName musst du natürlich an deine anpassen
        jojo regneup 1 Reply Last reply Reply Quote 0
        • jojo regneup
          @sigi234
          Danke für den Hinweis. Jedoch sollte das ja schon so passen, weil mein Kalender genauso wie im Skript calendar1 heißt:
          Jedoch bekomme ich immernoch genau den gleichen Fehler im Protokoll wie vorher.
          Gibt es irgendeine Sache die ich übersehen habe?
            @jojo-regneup
            Zeile 84
            • jojo regneup
              @sigi234
              In Zeile 84 wird der Datenpunkt erstellt.
              Muss ich diesen Vorher manuell erstellen, damit dann der Inhalt vom Skript überschrieben werden kann oder wird der Datenpunkt automatisch erstellt?
                @jojo-regneup
                Wenn unter userdata, hast du den DP auch angelegt?
                jojo regneup 1 Reply Last reply Reply Quote 1
                • jojo regneup
                  @sigi234
                  Ahh super, jetzt hats geklappt. Dachte der Datenpunkt wird von dem Skript automatisch erstellt
                  Danke für die Hilfe
                  Ro75 1 Reply Last reply Reply Quote 0
                  • Ro75
                    Ro75 @jojo regneup last edited by
                    @jojo-regneup sagte in Material Design Widgets: Calendar Widget:
                    Wird er auch, aber dann muss Zeile 8 auch korrekt sein.
                    Ro75.
                      demaxo last edited by
                      ich erarbeite gerade mühsam meine VIS. Und ich bin froh, dass es soviele Fachleute gibt, die dabei weiterhelfen.
                      Derzeit bin ich gerade mit dem Kalender beschäftigt. Das ganze funktioniert auch schon mal grundsätzlich. Aber: Alle Termine werden mir im Kalender-Widget in der VIS eine Stunde früher angezeigt.
                      Jemand eine Idee, was da schiefläuft?
                      Am iCal-Adapter dürfte es nicht liegen, dieser holt die Termine korrekt ab. Es scheint also etwas bei Ausführung des Scriptes schief zu laufen. Das Script habe ich mir von GitHub geladen und es unverändert übernommen.
                      Viele Grüße
                      Jens
                        demaxo last edited by demaxo
                        This post is deleted!
                        vis
                        45
                        200
                        31494
