    4. Test Adapter Daikin-Cloud 0.4.0
    • Armilar
      Armilar Most Active Forum Testing @Lemmi last edited by Armilar
      @lemmi
      habe mal ein wenig Zeit gefunden, um das Skript auf alle Device-Typen und Adapterinstanzen anzupassen.
      TypeScript anlegen. Inhalt reinwerfen. Sollte nichts angepasst werden müssen. Skript starten...
      Die Daten für jedes Daikin-Device in der Onnecta-App (Klima, Wärmepumpe, heating, cooling, Total, etc.) werden unter 0_userdata.0.daikin-cloud.... angelegt.
      @apollon77 - evtl. kann man das in den Adapter schreddern...
      /* TypeScript (TS) @Armilar
       * This Script will read the consumption Data from Daikin-Cloud adapter and transform the raw data into individual data points similar to how it's shown in the Daikin Onecta App.
       * It will also sum up the historic consumption from the current and previous year and update the total consumption meter going forward.
       * The data is created in the following path analogous to the daikin cloud data
       * 0_userdata.0.daikin-cloud.0...
       * Createtd: 14.11.2024
      // Log-Mode
      const logMode: any = 'info'; // 'info' or 'debug'
      // Path in 0_userdata
      const mainPath: string = '0_userdata.0.';
      // Onnecta hours (if d-raw)
      const hourly: Array<string>  = ["00:00 - 02:00", "02:00 - 04:00", "04:00 - 06:00", "06:00 - 08:00", "08:00 - 10:00", "10:00 - 12:00", "12:00 - 14:00", "14:00 - 16:00", "16:00 - 18:00", "18:00 - 20:00", "20:00 - 22:00", "22:00 - 24:00"];
      // Onnecta weekdays (if w-raw)
      const daily: Array<string>   = ["01_Monday", "02_Tuesday", "03_Wednesday", "04_Thursday", "05_Friday", "06_Saturday", "07_Sunday"];
      // Onnecta months  (if m-raw)
      const monthly: Array<string> = ["01_Januray", "02_February", "03_March", "04_April", "05_May", "06_June", "07_July", "08_August", "09_September", "10_October", "11_November", "12_December"];
      let devices: string[] = getDeviceNames("daikin-cloud.");
      function setOrCreateState(id: string, value: any, forceCreation: boolean = true, common: Partial<iobJS.StateCommon> = {}, callback?: iobJS.SetStateCallback): void {
          if (!existsState(id)) {
              createState(id, value, forceCreation, common, callback);
          } else {
              setState(id, value, true);
      // Get Daikin Device Names
      function getDeviceNames(vAdapterInstance: string): string[] {
          let devices = [];
          $(vAdapterInstance + '*raw').each(function (id) {
              if (devices.indexOf(id) == -1) {
                  devices.push(id);
          return devices;
      async function writeConsumtionData(path: string, rawType: string, rawData: number[]): Promise<void> {
          log(rawType + ' - ' + rawData, logMode);
          let total: number = 0;
          switch (rawType) {
      	case "d-raw":
                  for (let j = 0; j < 12; j++) {
                      let dpName = "Yesterday." + hourly[j];
                      setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: hourly[j], role: 'value.power', unit: 'kWh'});
                      log(mainPath + path + dpName + ': ' + rawData[j], logMode);
                      total = total + rawData[j];
                  setOrCreateState(mainPath + path + 'Total.Yesterday', total, true, {type: 'number', name: 'Yesterday', role: 'value.power',unit: 'kWh'});
                  total = 0;
                  for (let j = 12; j < 24; j++) {
                      let dpName = "Today." + hourly[j-12];
                      setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: hourly[j-12], role: 'value.power', unit: 'kWh'});
                  setOrCreateState(mainPath + path + 'Total.Today', total, true, {type: 'number', name: 'Today', role: 'value.power',unit: 'kWh'});
                  break;
      	case "w-raw":
                  for (let j = 0; j < 7; j++) {
                      let dpName = "LastWeek." + daily[j];
                      setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: daily[j], role: 'value.power', unit: 'kWh'});
                  setOrCreateState(mainPath + path + 'Total.LastWeek', total, true, {type: 'number', name: 'LastWeek', role: 'value.power',unit: 'kWh'});
                  total = 0;
                  for (let j = 7; j < 14; j++) {
                      let dpName = "ThisWeek." + daily[j-7];
                      setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: daily[j-7], role: 'value.power', unit: 'kWh'});
                  setOrCreateState(mainPath + path + 'Total.ThisWeek', total, true, {type: 'number', name: 'ThisWeek', role: 'value.power',unit: 'kWh'});
                  break;
      	case "m-raw":
                      let dpName = "LastYear." + monthly[j];
                      setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: monthly[j], role: 'value.power', unit: 'kWh'});
                  setOrCreateState(mainPath + path + 'Total.LastYear', total, true, {type: 'number', name: 'LastYear', role: 'value.power',unit: 'kWh'});
                  total = 0;
                      let dpName = "ThisYear." + monthly[j-12];
                      setOrCreateState(mainPath + path + dpName, rawData[j], true, {type: 'number', name: monthly[j-12], role: 'value.power', unit: 'kWh'});
                  setOrCreateState(mainPath + path + 'Total.ThisYear', total, true, {type: 'number', name: 'ThisYear', role: 'value.power',unit: 'kWh'});
                  break;
      async function readConsumtionData(): Promise<void> {
          for (let i = 0; i < devices.length; i++) {
              //get d-raw; w-raw; m-raw
              let dev: any = devices[i].split('.');
              let state = getState(devices[i]).val;
              state = state.slice(1,-1);
              state = state.replaceAll('null', '0');
              await writeConsumtionData(devices[i].slice(0,-5), dev[dev.length -1], Array.from(state.split(','), Number));
      readConsumtionData();
      on({ id: [].concat(Array.prototype.slice.apply($('daikin-cloud.*.lastUpdateReceived'))), change: 'any' }, async (obj) => {
          await readConsumtionData();
      K L T 3 Replies Last reply Reply Quote 2
        Kredar @Armilar last edited by Kredar
        @armilar sagte in Test Adapter Daikin-Cloud 0.4.0:
        • This Script will read the consumption Data from Daikin-Cloud adapter and transform the raw data into individual data points similar to how it's shown in the Daikin Onecta App.
        • It will also sum up the historic consumption from the current and previous year and update the total consumption meter going forward.
        • The data is created in the following path analogous to the daikin cloud data
        • 0_userdata.0.daikin-cloud.0...
        • Createtd: 14.11.2024
        // Log-Mode
        } else {
        let devices = [];
        devices.push(id);
        return devices;
        switch (rawType) {
        case "d-raw":
        total = 0;
        break;
        case "w-raw":
        total = 0;
        break;
        case "m-raw":
        total = 0;
        break;
        Super da ist ja auch meine Klimaanlage von Daikin drinnen 🙂 Läuft 1a. Danke für das überarbeite Script. Merci
          Lemmi @Armilar last edited by
          @armilar Welchen Teil des Skriptes muss ich denn kopieren und einfügen? Irgendwie haut das bei mir nicht hin. Das Blockly funzt.
          Vielen Dank1
            Lemmi @Kredar last edited by Lemmi
            @kredar
            Problem gelöst!!! Ich bin auch ein kleines dummerchen. Habe die ganze Zeit versucht unter Javaskript das Ding ans laufen zu bringen. Kann ja auch nicht klappen denn es steht doch deutlich geschrieben "TypeScript (TS)" anlegen. Das richtige Skript angelegt und alles reingeschmissen. Siehe da, es funzt.
            Vielen Dank an @kredar
              Kredar @Lemmi last edited by
              @lemmi
              steht ja auch da, TS Script 🙂
              Super wenn es nun geht 😉
                Hofmann IOBRF @apollon77 last edited by Hofmann IOBRF
                @apollon77 Die Verbindung zur Cloud hat nun einige Zeit gut funktioniert.
                Heute Morgen hatte ich einen "Error on update (1): expected 200 OK, got: 500 Internal Server Error" Fehler.
                Danach ging gar nichts mehr.
                Die Daikin Status Seite meldet keinen Fehler.
                Also habe ich die App gelöscht und neu angelegt.
                Ohne Erfolg.
                Nach dem Zugriff bestätigen bekomme ich die Fehlermeldung "Error on OAuth process: OPError: invalid_grant (invalid authorization code)"
                Hat noch wer aktuell Probleme damit?
                Jetzt meldet auch die Daikin Status Seite meldet Fehler!
                Geht jetzt wieder!
                Die Cloud ist halt einfach nicht sehr stabil!
                nik82 1 Reply Last reply Reply Quote 0
                • nik82
                  nik82 Most Active @Hofmann IOBRF last edited by
                  @hofmann-iobrf
                  Kam bei mir auch, ich musste nur wieder authentifizieren:
                  Und jetzt gehts wieder...
                    Gismoh @nik82 last edited by
                    @nik82
                    War bei mir ebenso, auch der App Zugriff war gestört.
                    War bei Daikin auch bekannt, und hatten dran gearbeitet.
                    Mit der neuen Authentifizierung über den Adapter funktioniert nun es auch wieder im IOBroker.
                      Es gibt in der App ein Update für die Benutzerschnittstelle. Hat das schon jemand gemacht? Kommt der Adapter danach damit klar?
                      Aktuell läuft es sehr gut mit dem Adapter, deswegen frage ich mal.
                        Hofmann IOBRF @Hofmann IOBRF last edited by
                        @hofmann-iobrf ist hier noch jemand?
                        • Armilar
                          Armilar Most Active Forum Testing @Hofmann IOBRF last edited by
                          @hofmann-iobrf
                          ja, der Adapter reicht nur die Daten durch... Du kannst das Update machen
                            Hofmann IOBRF @Armilar last edited by
                            @armilar Ja, hat geklappt. Funktioniert alles. Nur die Energiedaten kommen jetzt noch unregelmäßiger. Tlw. 2h später.
                              apollon77 @Hofmann IOBRF last edited by
                              @hofmann-iobrf Das wäre eine Frage an Daikin, da kann der Adapter leider nichts tun.
                                mhuber last edited by
                                ich habe ein neues Innengerät bekommen, hab bis jetzt immer den anderen Adapter (lokale Kommunikation) verwendet, das geht beim neuen Innengerät nicht mehr. Habe nun den Cloud Adapter Version 0.4.11 installiert.
                                Connect usw. funktioniert, Devices werden offline angezeigt aber das dürfte normal sein wie ich hier gelesen habe.
                                Ich kann aber kein Gerät ein oder ausschalten, woran kann das liegen? Das wäre ja "onOffMode" oder? Habe auch ein paar Minuten gewartet, es tut sich nichts.
                                Kann mir jemand helfen! Danke!
                                  FritzTheCat @mhuber last edited by
                                  @mhuber Hallo, ja "onOffMode" ist der richtige Schalter, aber da muss man normalerweise nicht warten. Bei mir ist die Verzögerung ganz gleich wie bei der normalen Fernbedienung direkt oder ca. 1 Sekunde.
                                  Das Gerät wird allerdings auch nicht offline angezeigt:
                                  Vielleicht findest Du eine Fehlermelung im Log?
                                    mhuber @FritzTheCat last edited by
                                    @fritzthecat ist bei mir so nicht gegangen, Adapter deinstalliert, nochmal installiert und es geht, komisch....
                                    Wie bekommen Du das "online" in grün hin? Bei mir zeigt es offline, aber es scheint alles zu gehen
                                      apollon77 @mhuber last edited by
                                      @mhuber Es gibt wohl einige Geräte die den Online Status nicht korrekt zurückmelden ... andere gehen. Schau mal GitHub issues. Haben bisher noch keine Lösung
                                        topsurfer @Armilar last edited by topsurfer
                                        @armilar Auch von mir ein Danke für das Script, lief auf Anhieb!
                                        Frage (hoffe es ist nicht zu OT),
                                        Jetzt sieht man ja die DP auch mit historischen Daten (z.B. letzte 12 Monate je ein Monatsverbrauch), gibt es einen Trick, diese Daten mit entsprechendem Timestamp in eine InfluxDB zu bekommen, oder ist händige Arbeit angesagt (mittels insert ...)
                                        Die jetzt neuen Monatswerte würde ich per Cron am Monatsende dann in die DB schreiben lassen (oder?)
                                        Armilar 1 Reply Last reply Reply Quote 1
                                          @Armilar Soll ich den Post mit dem Skript mal in der Adapter Readme verlinken?
                                          • Armilar
                                            Armilar Most Active Forum Testing @apollon77 last edited by
                                            @apollon77
                                            ja gerne... 😊
                                            hier verschwindet es ja irgendwann im "ich habe ja nicht alle Posts gelesen" 😉
                                            31.7k
                                            79.8k
                                            232
                                            26315
