    4. 2 iobroker installationen ...
      Homoran Global Moderator Administrators @pille0557 last edited by
      @pille0557 sagte in 2 iobroker installationen ...:
      fronius.0 (6416) Adapter requestType https:// was not matching, changed to http:// and trigger restart.
      pille0557 1 Reply Last reply Reply Quote 0
      • pille0557
        pille0557 @Homoran last edited by pille0557
        ? keine Ahnung ... http://ip oder https://ip geht auch nicht ... ?
        es steht da: IP sonst nix und auf dem raspi habe ich ja auch nichts anderes eingetragen
          das zeigst du uns ja nicht
          • pille0557
            raspi
            futro - debian
              @pille0557 was sagt iob diag in der Langfassung auf dem futro?
              • pille0557
                ich poste mal lieber nicht alles ...
                zum Schluss das log etwas anders:
                2025-03-23 15:04:24.745  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                2025-03-23 15:04:36.895  - error: fronius.0 (6554) IP is not a Fronius inverter
                2025-03-23 15:05:20.795  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                2025-03-23 15:05:20.798  - info: fronius.0 (6554) Got terminate signal TERMINATE_YOURSELF
                2025-03-23 15:05:20.848  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                2025-03-23 15:05:21.300  - info: fronius.0 (6554) terminating
                2025-03-23 15:05:21.301  - info: fronius.0 (6554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-03-23 15:05:21.842  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-03-23 15:05:22.509  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                2025-03-23 15:05:25.064  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6573
                2025-03-23 15:05:26.240  - info: fronius.0 (6573) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                2025-03-23 15:05:26.254  - error: fronius.0 (6573) Please configure the Fronius adapter
                2025-03-23 15:06:30.491  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                2025-03-23 15:06:37.755  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                2025-03-23 15:06:37.758  - info: fronius.0 (6573) Got terminate signal TERMINATE_YOURSELF
                2025-03-23 15:06:37.806  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                2025-03-23 15:06:38.260  - info: fronius.0 (6573) terminating
                2025-03-23 15:06:38.261  - info: fronius.0 (6573) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2025-03-23 15:06:38.804  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2025-03-23 15:06:39.722  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                2025-03-23 15:06:42.026  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6589
                2025-03-23 15:06:43.199  - info: fronius.0 (6589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                2025-03-23 15:06:43.213  - error: fronius.0 (6589) Please configure the Fronius adapter
                2025-03-23 15:07:08.589  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                2025-03-23 15:38:12.549  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                interessant die Zeile:
                aha ... nach dann ... ?
                  dann nutzt es nichts
                  • pille0557
                    Script v.2025-02-23
                    *** BASE SYSTEM ***
                     Static hostname: debianiob
                           Icon name: computer-desktop
                             Chassis: desktop 🖥️
                              Kernel: Linux 6.1.0-32-amd64
                        Architecture: x86-64
                     Hardware Vendor: FUJITSU
                      Hardware Model: FUTRO S740
                    Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
                    OS is similar to:
                    model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
                    Docker          : false
                    Virtualization  : none
                    Kernel          : x86_64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    *** TIME AND TIMEZONES ***
                                   Local time: Sun 2025-03-23 15:50:08 CET
                               Universal time: Sun 2025-03-23 14:50:08 UTC
                                     RTC time: Sun 2025-03-23 14:50:08
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    peter
                    HOME=/home/peter
                    GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev lpadmin scanner iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server: false
                    Desktop:
                    Terminal:       tty
                    System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                    *** MEMORY ***
                    Mem:             16G        1.6G         13G         33M        1.6G         14G
                    Swap:           1.0G          0B        1.0G
                    Total:           17G        1.6G         14G
                    Active iob-Instances:   8
                            15762 M total memory
                             1502 M used memory
                              907 M active memory
                             1540 M inactive memory
                            13029 M free memory
                              669 M buffer memory
                              889 M swap cache
                              976 M total swap
                                0 M used swap
                              976 M free swap
                    top - 15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
                    Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :  15762.3 total,  13028.9 free,   1503.6 used,   1559.3 buff/cache
                    MiB Swap:    977.0 total,    977.0 free,      0.0 used.  14258.7 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  7.7G     0  7.7G   0% /dev
                    tmpfs          tmpfs     1.6G  1.4M  1.6G   1% /run
                    /dev/sda2      ext4      233G  8.4G  213G   4% /
                    tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
                    tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
                    /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
                    tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run/user/107
                    tmpfs          tmpfs     1.6G   64K  1.6G   1% /run/user/1000
                    [Thu Mar 20 16:43:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                    [Thu Mar 20 16:43:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
                    Show mounted filesystems:
                    TARGET      SOURCE    FSTYPE OPTIONS
                    /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
                    `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
                    /var:
                    870M    /var/
                    376M    /var/cache
                    357M    /var/cache/apt
                    315M    /var/lib
                    279M    /var/cache/apt/archives
                    Archived and active journals take up 11.9M in the file system.
                    /opt/iobroker/backups:
                    4.0K    /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    240M    /opt/iobroker/iobroker-data/
                    181M    /opt/iobroker/iobroker-data/files
                    158M    /opt/iobroker/iobroker-data/files/admin.admin
                    157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                    13M     /opt/iobroker/iobroker-data/objects.jsonl
                    7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                    7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                    USB-Devices by-id:
                    No Devices found 'by-id'
                    Zigbee Network Settings on your coordinator/in nvbackup are:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    To unmask the settings run 'iob diag --unmask'
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.19.0
                    /usr/bin/node           v20.19.0
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.31.0
                    nodejs:
                      Installed: 20.19.0-1nodesource1
                      Candidate: 20.19.0-1nodesource1
                      Version table:
                     *** 20.19.0-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                            100 /var/lib/dpkg/status
                         20.18.3-1nodesource1 1001
                         20.18.2-1nodesource1 1001
                         20.18.1-1nodesource1 1001
                         20.18.0-1nodesource1 1001
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2 500
                            500 http://deb.debian.org/debian bookworm/main amd64 Packages
                         18.19.0+dfsg-6~deb12u1 500
                            500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 255987)
                    Core adapters versions
                    admin:          7.4.10
                    javascript:     "javascript" not found
                    nodejs modules from github:     0
                    Adapter State
                    + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      system.adapter.backitup.0               : backitup              : debianiob                                - disabled
                    + system.adapter.discovery.0              : discovery             : debianiob                                -  enabled
                    + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
                    + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
                    + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
                      system.adapter.fronius.1                : fronius               : debianiob                                - disabled
                      system.adapter.fronius.2                : fronius               : debianiob                                - disabled
                      system.adapter.fronius.3                : fronius               : debianiob                                - disabled
                    + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
                      system.adapter.shelly.0                 : shelly                : debianiob                                - disabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Upgrade policy: none
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.4.10   , installed 7.4.10
                    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                    Adapter    "fronius"      : 2.1.1    , installed 2.1.1
                    Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
                    Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
                    Controller "js-controller": 7.0.6    , installed 7.0.6
                    Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                    Objects and States
                    Objects:        5688
                    States:         4438
                    W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                    Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
                    Hit:2 http://deb.debian.org/debian bookworm InRelease
                    Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                    Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                    Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
                    Reading package lists...
                    Pending Updates: 1
                    *** Listening Ports ***
                    tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          20864      581/brltty
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        18219      652/influxd
                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14588      1/init
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22684      677/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23135      653/iobroker.js-con
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18293      653/iobroker.js-con
                    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1161295    5328/cupsd
                    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1161294    5328/cupsd
                    tcp6       0      0 :::8086                 :::*                    LISTEN      112        18242      652/influxd
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24645      835/io.admin.0
                    tcp6       0      0 :::111                  :::*                    LISTEN      0          14589      1/init
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          22686      677/sshd: /usr/sbin
                    tcp6       0      0 ::1:4101                :::*                    LISTEN      0          22589      581/brltty
                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1607       1/init
                    udp        0      0 0.0.0.0:54464           0.0.0.0:*                           103        20852      591/avahi-daemon: r
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        20850      591/avahi-daemon: r
                    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24918      1062/io.shelly.1
                    udp6       0      0 :::111                  :::*                                0          1608       1/init
                    udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          1454426    606/NetworkManager
                    udp6       0      0 :::59684                :::*                                103        20853      591/avahi-daemon: r
                    udp6       0      0 :::5353                 :::*                                103        20851      591/avahi-daemon: r
                                            v.2025-02-23
                             Chassis: desktop 🖥️
                    Installation:           native
                    Kernel:                 x86_64
                    Userland:               64 bit
                    Timezone:               Europe/Berlin (CET, +0100)
                    User-ID:                1000
                    Boot Target:            graphical.target
                    Pending OS-Updates:     1
                    Pending iob updates:    0
                    Nodejs-Installation:
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    Recommended versions are nodejs 20.19.0 and npm 10.8.2
                    nodeJS installation is correct
                    MEMORY:
                    Swap:           1.0G          0B        1.0G
                    Total:           17G        1.6G         14G
                    ioBroker Core:          js-controller           7.0.6
                                            admin                   7.4.10
                    Objects type: jsonl
                    States  type: jsonl
                    Objects:                5688
                    States:                 4438
                    Size of iob-Database:
                    4.5M    /opt/iobroker/iobroker-data/states.jsonl
                      ticaki Developer @pille0557 last edited by
                      @pille0557
                      Hast du auf den Test Connection button gedrückt?
                      • pille0557
                        pille0557 @ticaki last edited by
                        @ticaki said in 2 iobroker installationen ...:
                        @pille0557
                        ja habe ich auch schon, keine Info als Ergebnis
                        Homoran T 2 Replies Last reply Reply Quote 0
                          @pille0557 ist da vielleicht noch ein Leerzeichen o.ä. in der Adresse?
                            @pille0557
                            Dann schalte den Adapter mal in den Debugmodus - da sollte mehr an infos kommen.
                            • pille0557
                              @ticaki
                              2025-03-23 17:04:23.191 - error: fronius.0 (11921) Please configure the Fronius adapter
                              2025-03-23 17:04:27.896 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                              2025-03-23 17:33:21.021 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                              2025-03-23 17:33:32.189 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                              2025-03-23 17:33:32.193 - info: fronius.0 (11921) Got terminate signal TERMINATE_YOURSELF
                              2025-03-23 17:33:32.257 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                              2025-03-23 17:33:32.695 - info: fronius.0 (11921) terminating
                              2025-03-23 17:33:32.696 - info: fronius.0 (11921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2025-03-23 17:33:33.267 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2025-03-23 17:33:36.493 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 14290
                              2025-03-23 17:33:37.435 - debug: fronius.0 (14290) Redis Objects: Use Redis connection: 127.0.0.1:9001
                              2025-03-23 17:33:37.472 - debug: fronius.0 (14290) Objects client ready ... initialize now
                              2025-03-23 17:33:37.473 - debug: fronius.0 (14290) Objects create System PubSub Client
                              2025-03-23 17:33:37.474 - debug: fronius.0 (14290) Objects create User PubSub Client
                              2025-03-23 17:33:37.505 - debug: fronius.0 (14290) Objects client initialize lua scripts
                              2025-03-23 17:33:37.510 - debug: fronius.0 (14290) Objects connected to redis: 127.0.0.1:9001
                              2025-03-23 17:33:37.531 - debug: fronius.0 (14290) Redis States: Use Redis connection: 127.0.0.1:9000
                              2025-03-23 17:33:37.540 - debug: fronius.0 (14290) States create System PubSub Client
                              2025-03-23 17:33:37.541 - debug: fronius.0 (14290) States create User PubSub Client
                              2025-03-23 17:33:37.597 - debug: fronius.0 (14290) States connected to redis: 127.0.0.1:9000
                              2025-03-23 17:33:37.666 - info: fronius.0 (14290) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                              2025-03-23 17:33:37.678 - error: fronius.0 (14290) Please configure the Fronius adapter
                              2025-03-23 17:33:38.184 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                              • pille0557
                                pille0557 @pille0557 last edited by
                                @pille0557
                                danke für die Hilfe, ich werde die Kiste mal neu aufsetzen ...
                                damit ich grafana mit meinem älteren iPad in der Küche als Statusanzeigen benutzen kann, muss ich sowieso eine ältere Grafana Version installieren, ein downgrade wird wohl auch nicht einfach
                                • Meister Mopper
                                  Meister Mopper @pille0557 last edited by
                                  @pille0557
                                  Da muss nur die ältere Version gepinnt werden.
                                  Ein wenig aufwändiger wird es lediglich, wenn du major upgrades verhindern möchtest. Das ist aber auch kein Hexenwerk.
                                  1355
