    4. 2 iobroker installationen ...
      Homoran Global Moderator Administrators @pille0557 last edited by
      @pille0557 was sagt iob diag in der Langfassung auf dem futro?
      pille0557 1 Reply Last reply Reply Quote 0
      • pille0557
        pille0557 @Homoran last edited by
        ich poste mal lieber nicht alles ...
        zum Schluss das log etwas anders:
        2025-03-23 15:04:24.745  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
        2025-03-23 15:04:36.895  - error: fronius.0 (6554) IP is not a Fronius inverter
        2025-03-23 15:05:20.795  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
        2025-03-23 15:05:20.798  - info: fronius.0 (6554) Got terminate signal TERMINATE_YOURSELF
        2025-03-23 15:05:20.848  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
        2025-03-23 15:05:21.300  - info: fronius.0 (6554) terminating
        2025-03-23 15:05:21.301  - info: fronius.0 (6554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-03-23 15:05:21.842  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-03-23 15:05:22.509  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
        2025-03-23 15:05:25.064  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6573
        2025-03-23 15:05:26.240  - info: fronius.0 (6573) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
        2025-03-23 15:05:26.254  - error: fronius.0 (6573) Please configure the Fronius adapter
        2025-03-23 15:06:30.491  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
        2025-03-23 15:06:37.755  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
        2025-03-23 15:06:37.758  - info: fronius.0 (6573) Got terminate signal TERMINATE_YOURSELF
        2025-03-23 15:06:37.806  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
        2025-03-23 15:06:38.260  - info: fronius.0 (6573) terminating
        2025-03-23 15:06:38.261  - info: fronius.0 (6573) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-03-23 15:06:38.804  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2025-03-23 15:06:39.722  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
        2025-03-23 15:06:42.026  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6589
        2025-03-23 15:06:43.199  - info: fronius.0 (6589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
        2025-03-23 15:06:43.213  - error: fronius.0 (6589) Please configure the Fronius adapter
        2025-03-23 15:07:08.589  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
        2025-03-23 15:38:12.549  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
        interessant die Zeile:
        aha ... nach dann ... ?
          @pille0557 sagte in 2 iobroker installationen ...:
          dann nutzt es nichts
          • pille0557
            pille0557 @Homoran last edited by pille0557
            Script v.2025-02-23
            *** BASE SYSTEM ***
             Static hostname: debianiob
                   Icon name: computer-desktop
                     Chassis: desktop 🖥️
                      Kernel: Linux 6.1.0-32-amd64
                Architecture: x86-64
             Hardware Vendor: FUJITSU
              Hardware Model: FUTRO S740
            Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
            OS is similar to:
            model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** TIME AND TIMEZONES ***
                           Local time: Sun 2025-03-23 15:50:08 CET
                       Universal time: Sun 2025-03-23 14:50:08 UTC
                             RTC time: Sun 2025-03-23 14:50:08
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            peter
            HOME=/home/peter
            GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev lpadmin scanner iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:             16G        1.6G         13G         33M        1.6G         14G
            Swap:           1.0G          0B        1.0G
            Total:           17G        1.6G         14G
            Active iob-Instances:   8
                    15762 M total memory
                     1502 M used memory
                      907 M active memory
                     1540 M inactive memory
                    13029 M free memory
                      669 M buffer memory
                      889 M swap cache
                      976 M total swap
                        0 M used swap
                      976 M free swap
            top - 15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
            Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  15762.3 total,  13028.9 free,   1503.6 used,   1559.3 buff/cache
            MiB Swap:    977.0 total,    977.0 free,      0.0 used.  14258.7 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  7.7G     0  7.7G   0% /dev
            tmpfs          tmpfs     1.6G  1.4M  1.6G   1% /run
            /dev/sda2      ext4      233G  8.4G  213G   4% /
            tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
            tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
            /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
            tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run/user/107
            tmpfs          tmpfs     1.6G   64K  1.6G   1% /run/user/1000
            [Thu Mar 20 16:43:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
            [Thu Mar 20 16:43:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET      SOURCE    FSTYPE OPTIONS
            /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
            `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
            /var:
            870M    /var/
            376M    /var/cache
            357M    /var/cache/apt
            315M    /var/lib
            279M    /var/cache/apt/archives
            Archived and active journals take up 11.9M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            240M    /opt/iobroker/iobroker-data/
            181M    /opt/iobroker/iobroker-data/files
            158M    /opt/iobroker/iobroker-data/files/admin.admin
            157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
            13M     /opt/iobroker/iobroker-data/objects.jsonl
            7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
            7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.19.0
            /usr/bin/node           v20.19.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.31.0
            nodejs:
              Installed: 20.19.0-1nodesource1
              Candidate: 20.19.0-1nodesource1
              Version table:
             *** 20.19.0-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                    100 /var/lib/dpkg/status
                 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
                 20.16.0-1nodesource1 1001
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 18.19.0+dfsg-6~deb12u2 500
                    500 http://deb.debian.org/debian bookworm/main amd64 Packages
                 18.19.0+dfsg-6~deb12u1 500
                    500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 255987)
            Core adapters versions
            admin:          7.4.10
            javascript:     "javascript" not found
            nodejs modules from github:     0
            Adapter State
            + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              system.adapter.backitup.0               : backitup              : debianiob                                - disabled
            + system.adapter.discovery.0              : discovery             : debianiob                                -  enabled
            + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
            + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
            + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
              system.adapter.fronius.1                : fronius               : debianiob                                - disabled
              system.adapter.fronius.2                : fronius               : debianiob                                - disabled
              system.adapter.fronius.3                : fronius               : debianiob                                - disabled
            + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
              system.adapter.shelly.0                 : shelly                : debianiob                                - disabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
            + instance is alive
            ioBroker-Repositories
            Active repo(s): stable
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.4.10   , installed 7.4.10
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "fronius"      : 2.1.1    , installed 2.1.1
            Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
            Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "shelly"       : 8.5.1    , installed 8.5.1
            Objects and States
            Objects:        5688
            States:         4438
            W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
            W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
            Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
            Hit:2 http://deb.debian.org/debian bookworm InRelease
            Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Hit:5 https://packages.grafana.com/oss/deb stable InRelease
            Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
            Reading package lists...
            Pending Updates: 1
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          20864      581/brltty
            tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        18219      652/influxd
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14588      1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22684      677/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23135      653/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18293      653/iobroker.js-con
            tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1161295    5328/cupsd
            tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1161294    5328/cupsd
            tcp6       0      0 :::8086                 :::*                    LISTEN      112        18242      652/influxd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24645      835/io.admin.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          14589      1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          22686      677/sshd: /usr/sbin
            tcp6       0      0 ::1:4101                :::*                    LISTEN      0          22589      581/brltty
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1607       1/init
            udp        0      0 0.0.0.0:54464           0.0.0.0:*                           103        20852      591/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        20850      591/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24918      1062/io.shelly.1
            udp6       0      0 :::111                  :::*                                0          1608       1/init
            udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          1454426    606/NetworkManager
            udp6       0      0 :::59684                :::*                                103        20853      591/avahi-daemon: r
            udp6       0      0 :::5353                 :::*                                103        20851      591/avahi-daemon: r
                                    v.2025-02-23
                     Chassis: desktop 🖥️
            Installation:           native
            Kernel:                 x86_64
            Userland:               64 bit
            Timezone:               Europe/Berlin (CET, +0100)
            User-ID:                1000
            Boot Target:            graphical.target
            Pending OS-Updates:     1
            Pending iob updates:    0
            Nodejs-Installation:
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            Recommended versions are nodejs 20.19.0 and npm 10.8.2
            nodeJS installation is correct
            MEMORY:
            Swap:           1.0G          0B        1.0G
            Total:           17G        1.6G         14G
            ioBroker Core:          js-controller           7.0.6
                                    admin                   7.4.10
            Objects type: jsonl
            States  type: jsonl
            Objects:                5688
            States:                 4438
            Size of iob-Database:
            4.5M    /opt/iobroker/iobroker-data/states.jsonl
              ticaki Developer @pille0557 last edited by
              @pille0557
              Hast du auf den Test Connection button gedrückt?
              • pille0557
                pille0557 @ticaki last edited by
                @ticaki said in 2 iobroker installationen ...:
                @pille0557
                ja habe ich auch schon, keine Info als Ergebnis
                Homoran T 2 Replies Last reply Reply Quote 0
                  @pille0557 ist da vielleicht noch ein Leerzeichen o.ä. in der Adresse?
                    @pille0557
                    Dann schalte den Adapter mal in den Debugmodus - da sollte mehr an infos kommen.
                    • pille0557
                      @ticaki
                      2025-03-23 17:04:23.191 - error: fronius.0 (11921) Please configure the Fronius adapter
                      2025-03-23 17:04:27.896 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                      2025-03-23 17:33:21.021 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                      2025-03-23 17:33:32.189 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                      2025-03-23 17:33:32.193 - info: fronius.0 (11921) Got terminate signal TERMINATE_YOURSELF
                      2025-03-23 17:33:32.257 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                      2025-03-23 17:33:32.695 - info: fronius.0 (11921) terminating
                      2025-03-23 17:33:32.696 - info: fronius.0 (11921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-03-23 17:33:33.267 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-03-23 17:33:36.493 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 14290
                      2025-03-23 17:33:37.435 - debug: fronius.0 (14290) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2025-03-23 17:33:37.472 - debug: fronius.0 (14290) Objects client ready ... initialize now
                      2025-03-23 17:33:37.473 - debug: fronius.0 (14290) Objects create System PubSub Client
                      2025-03-23 17:33:37.474 - debug: fronius.0 (14290) Objects create User PubSub Client
                      2025-03-23 17:33:37.505 - debug: fronius.0 (14290) Objects client initialize lua scripts
                      2025-03-23 17:33:37.510 - debug: fronius.0 (14290) Objects connected to redis: 127.0.0.1:9001
                      2025-03-23 17:33:37.531 - debug: fronius.0 (14290) Redis States: Use Redis connection: 127.0.0.1:9000
                      2025-03-23 17:33:37.540 - debug: fronius.0 (14290) States create System PubSub Client
                      2025-03-23 17:33:37.541 - debug: fronius.0 (14290) States create User PubSub Client
                      2025-03-23 17:33:37.597 - debug: fronius.0 (14290) States connected to redis: 127.0.0.1:9000
                      2025-03-23 17:33:37.666 - info: fronius.0 (14290) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                      2025-03-23 17:33:37.678 - error: fronius.0 (14290) Please configure the Fronius adapter
                      2025-03-23 17:33:38.184 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                      • pille0557
                        pille0557 @pille0557 last edited by
                        @pille0557
                        danke für die Hilfe, ich werde die Kiste mal neu aufsetzen ...
                        damit ich grafana mit meinem älteren iPad in der Küche als Statusanzeigen benutzen kann, muss ich sowieso eine ältere Grafana Version installieren, ein downgrade wird wohl auch nicht einfach
                        • Meister Mopper
                          Meister Mopper @pille0557 last edited by
                          @pille0557
                          Da muss nur die ältere Version gepinnt werden.
                          Ein wenig aufwändiger wird es lediglich, wenn du major upgrades verhindern möchtest. Das ist aber auch kein Hexenwerk.
                          1054
