    4. 2 iobroker installationen ...
    • pille0557
      pille0557 @Homoran last edited by
      ich poste mal lieber nicht alles ...
      zum Schluss das log etwas anders:
      2025-03-23 15:04:24.745  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
      2025-03-23 15:04:36.895  - error: fronius.0 (6554) IP is not a Fronius inverter
      2025-03-23 15:05:20.795  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
      2025-03-23 15:05:20.798  - info: fronius.0 (6554) Got terminate signal TERMINATE_YOURSELF
      2025-03-23 15:05:20.848  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
      2025-03-23 15:05:21.300  - info: fronius.0 (6554) terminating
      2025-03-23 15:05:21.301  - info: fronius.0 (6554) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-03-23 15:05:21.842  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-03-23 15:05:22.509  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
      2025-03-23 15:05:25.064  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6573
      2025-03-23 15:05:26.240  - info: fronius.0 (6573) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
      2025-03-23 15:05:26.254  - error: fronius.0 (6573) Please configure the Fronius adapter
      2025-03-23 15:06:30.491  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
      2025-03-23 15:06:37.755  - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
      2025-03-23 15:06:37.758  - info: fronius.0 (6573) Got terminate signal TERMINATE_YOURSELF
      2025-03-23 15:06:37.806  - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
      2025-03-23 15:06:38.260  - info: fronius.0 (6573) terminating
      2025-03-23 15:06:38.261  - info: fronius.0 (6573) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-03-23 15:06:38.804  - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-03-23 15:06:39.722  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
      2025-03-23 15:06:42.026  - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 6589
      2025-03-23 15:06:43.199  - info: fronius.0 (6589) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
      2025-03-23 15:06:43.213  - error: fronius.0 (6589) Please configure the Fronius adapter
      2025-03-23 15:07:08.589  - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
      2025-03-23 15:38:12.549  - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
      interessant die Zeile:
      aha ... nach dann ... ?
        Homoran Global Moderator Administrators @pille0557 last edited by
        @pille0557 sagte in 2 iobroker installationen ...:
        dann nutzt es nichts
        pille0557 1 Reply Last reply Reply Quote 0
        • pille0557
          pille0557 @Homoran last edited by pille0557
          Script v.2025-02-23
          *** BASE SYSTEM ***
           Static hostname: debianiob
                 Icon name: computer-desktop
                   Chassis: desktop 🖥️
                    Kernel: Linux 6.1.0-32-amd64
              Architecture: x86-64
           Hardware Vendor: FUJITSU
            Hardware Model: FUTRO S740
          Firmware Version: V5.0.0.13 R1.5.0 for D3544-A1x
          OS is similar to:
          model name      : Intel(R) Celeron(R) J4105 CPU @ 1.50GHz
          Docker          : false
          Virtualization  : none
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** TIME AND TIMEZONES ***
                         Local time: Sun 2025-03-23 15:50:08 CET
                     Universal time: Sun 2025-03-23 14:50:08 UTC
                           RTC time: Sun 2025-03-23 14:50:08
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          peter
          HOME=/home/peter
          GROUPS=peter cdrom floppy sudo audio dip video plugdev users netdev lpadmin scanner iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:             16G        1.6G         13G         33M        1.6G         14G
          Swap:           1.0G          0B        1.0G
          Total:           17G        1.6G         14G
          Active iob-Instances:   8
                  15762 M total memory
                   1502 M used memory
                    907 M active memory
                   1540 M inactive memory
                  13029 M free memory
                    669 M buffer memory
                    889 M swap cache
                    976 M total swap
                      0 M used swap
                    976 M free swap
          top - 15:50:08 up 2 days, 23:06,  2 users,  load average: 0.39, 0.27, 0.20
          Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 40.0 sy,  0.0 ni, 60.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :  15762.3 total,  13028.9 free,   1503.6 used,   1559.3 buff/cache
          MiB Swap:    977.0 total,    977.0 free,      0.0 used.  14258.7 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  7.7G     0  7.7G   0% /dev
          tmpfs          tmpfs     1.6G  1.4M  1.6G   1% /run
          /dev/sda2      ext4      233G  8.4G  213G   4% /
          tmpfs          tmpfs     7.7G     0  7.7G   0% /dev/shm
          tmpfs          tmpfs     5.0M  8.0K  5.0M   1% /run/lock
          /dev/sda1      vfat      511M  5.9M  506M   2% /boot/efi
          tmpfs          tmpfs     1.6G  1.3M  1.6G   1% /run/user/107
          tmpfs          tmpfs     1.6G   64K  1.6G   1% /run/user/1000
          [Thu Mar 20 16:43:27 2025] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
          [Thu Mar 20 16:43:28 2025] EXT4-fs (sda2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET      SOURCE    FSTYPE OPTIONS
          /           /dev/sda2 ext4   rw,relatime,errors=remount-ro
          `-/boot/efi /dev/sda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
          /var:
          870M    /var/
          376M    /var/cache
          357M    /var/cache/apt
          315M    /var/lib
          279M    /var/cache/apt/archives
          Archived and active journals take up 11.9M in the file system.
          /opt/iobroker/backups:
          4.0K    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          240M    /opt/iobroker/iobroker-data/
          181M    /opt/iobroker/iobroker-data/files
          158M    /opt/iobroker/iobroker-data/files/admin.admin
          157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
          13M     /opt/iobroker/iobroker-data/objects.jsonl
          7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.19.0
          /usr/bin/node           v20.19.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.31.0
          nodejs:
            Installed: 20.19.0-1nodesource1
            Candidate: 20.19.0-1nodesource1
            Version table:
           *** 20.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.18.3-1nodesource1 1001
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          debianiob           debianiob (version: 7.0.6, hostname: debianiob     , alive, uptime: 255987)
          Core adapters versions
          admin:          7.4.10
          javascript:     "javascript" not found
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : debianiob                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : debianiob                                - disabled
          + system.adapter.discovery.0              : discovery             : debianiob                                -  enabled
          + system.adapter.fronius-solarweb.0       : fronius-solarweb      : debianiob                                -  enabled
          + system.adapter.fronius-wattpilot.0      : fronius-wattpilot     : debianiob                                -  enabled
          + system.adapter.fronius.0                : fronius               : debianiob                                -  enabled
            system.adapter.fronius.1                : fronius               : debianiob                                - disabled
            system.adapter.fronius.2                : fronius               : debianiob                                - disabled
            system.adapter.fronius.3                : fronius               : debianiob                                - disabled
          + system.adapter.influxdb.0               : influxdb              : debianiob                                -  enabled, port: 8086
            system.adapter.shelly.0                 : shelly                : debianiob                                - disabled, port: 1882, bind: 0.0.0.0
          + system.adapter.shelly.1                 : shelly                : debianiob                                -  enabled, port: 1882, bind: 0.0.0.0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "fronius"      : 2.1.1    , installed 2.1.1
          Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
          Adapter    "fronius-wattpilot": 4.6.3, installed 4.6.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Objects and States
          Objects:        5688
          States:         4438
          W: https://packages.grafana.com/oss/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          W: https://packages.grafana.com/enterprise/deb/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:5 https://packages.grafana.com/oss/deb stable InRelease
          Hit:6 https://packages.grafana.com/enterprise/deb stable InRelease
          Reading package lists...
          Pending Updates: 1
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:4101          0.0.0.0:*               LISTEN      0          20864      581/brltty
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      112        18219      652/influxd
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14588      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          22684      677/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       23135      653/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       18293      653/iobroker.js-con
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          1161295    5328/cupsd
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          1161294    5328/cupsd
          tcp6       0      0 :::8086                 :::*                    LISTEN      112        18242      652/influxd
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       24645      835/io.admin.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          14589      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          22686      677/sshd: /usr/sbin
          tcp6       0      0 ::1:4101                :::*                    LISTEN      0          22589      581/brltty
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1607       1/init
          udp        0      0 0.0.0.0:54464           0.0.0.0:*                           103        20852      591/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           103        20850      591/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       24918      1062/io.shelly.1
          udp6       0      0 :::111                  :::*                                0          1608       1/init
          udp6       0      0 fe80::4e52:62ff:fe1:546 :::*                                0          1454426    606/NetworkManager
          udp6       0      0 :::59684                :::*                                103        20853      591/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                103        20851      591/avahi-daemon: r
                                  v.2025-02-23
                   Chassis: desktop 🖥️
          Installation:           native
          Kernel:                 x86_64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Boot Target:            graphical.target
          Pending OS-Updates:     1
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          Recommended versions are nodejs 20.19.0 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Swap:           1.0G          0B        1.0G
          Total:           17G        1.6G         14G
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.4.10
          Objects type: jsonl
          States  type: jsonl
          Objects:                5688
          States:                 4438
          Size of iob-Database:
          4.5M    /opt/iobroker/iobroker-data/states.jsonl
            ticaki Developer @pille0557 last edited by
            @pille0557
            Hast du auf den Test Connection button gedrückt?
            • pille0557
              pille0557 @ticaki last edited by
              @ticaki said in 2 iobroker installationen ...:
              @pille0557
              ja habe ich auch schon, keine Info als Ergebnis
              Homoran T 2 Replies Last reply Reply Quote 0
                @pille0557 ist da vielleicht noch ein Leerzeichen o.ä. in der Adresse?
                  @pille0557
                  Dann schalte den Adapter mal in den Debugmodus - da sollte mehr an infos kommen.
                  • pille0557
                    @ticaki
                    2025-03-23 17:04:23.191 - error: fronius.0 (11921) Please configure the Fronius adapter
                    2025-03-23 17:04:27.896 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                    2025-03-23 17:33:21.021 - info: admin.0 (835) ==> Connected system.user.admin from ::ffff:192.168.0.76
                    2025-03-23 17:33:32.189 - info: host.debianiob stopInstance system.adapter.fronius.0 (force=false, process=true)
                    2025-03-23 17:33:32.193 - info: fronius.0 (11921) Got terminate signal TERMINATE_YOURSELF
                    2025-03-23 17:33:32.257 - info: host.debianiob stopInstance system.adapter.fronius.0 send kill signal
                    2025-03-23 17:33:32.695 - info: fronius.0 (11921) terminating
                    2025-03-23 17:33:32.696 - info: fronius.0 (11921) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    2025-03-23 17:33:33.267 - info: host.debianiob instance system.adapter.fronius.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                    2025-03-23 17:33:36.493 - info: host.debianiob instance system.adapter.fronius.0 in version "2.1.1" started with pid 14290
                    2025-03-23 17:33:37.435 - debug: fronius.0 (14290) Redis Objects: Use Redis connection: 127.0.0.1:9001
                    2025-03-23 17:33:37.472 - debug: fronius.0 (14290) Objects client ready ... initialize now
                    2025-03-23 17:33:37.473 - debug: fronius.0 (14290) Objects create System PubSub Client
                    2025-03-23 17:33:37.474 - debug: fronius.0 (14290) Objects create User PubSub Client
                    2025-03-23 17:33:37.505 - debug: fronius.0 (14290) Objects client initialize lua scripts
                    2025-03-23 17:33:37.510 - debug: fronius.0 (14290) Objects connected to redis: 127.0.0.1:9001
                    2025-03-23 17:33:37.531 - debug: fronius.0 (14290) Redis States: Use Redis connection: 127.0.0.1:9000
                    2025-03-23 17:33:37.540 - debug: fronius.0 (14290) States create System PubSub Client
                    2025-03-23 17:33:37.541 - debug: fronius.0 (14290) States create User PubSub Client
                    2025-03-23 17:33:37.597 - debug: fronius.0 (14290) States connected to redis: 127.0.0.1:9000
                    2025-03-23 17:33:37.666 - info: fronius.0 (14290) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fronius, node: v20.19.0, js-controller: 7.0.6
                    2025-03-23 17:33:37.678 - error: fronius.0 (14290) Please configure the Fronius adapter
                    2025-03-23 17:33:38.184 - info: admin.0 (835) <== Disconnect system.user.admin from ::ffff:192.168.0.76
                    • pille0557
                      pille0557 @pille0557 last edited by
                      @pille0557
                      danke für die Hilfe, ich werde die Kiste mal neu aufsetzen ...
                      damit ich grafana mit meinem älteren iPad in der Küche als Statusanzeigen benutzen kann, muss ich sowieso eine ältere Grafana Version installieren, ein downgrade wird wohl auch nicht einfach
                      • Meister Mopper
                        Meister Mopper @pille0557 last edited by
                        @pille0557
                        Da muss nur die ältere Version gepinnt werden.
                        Ein wenig aufwändiger wird es lediglich, wenn du major upgrades verhindern möchtest. Das ist aber auch kein Hexenwerk.
                        1054
