    4. Zeitstemlel von SQL- Historyeintrag manipulieren
    • David G.
      David G. @BananaJoe last edited by
      @bananajoe
      Hab das Skript jetzt mal getestet und in ein Blockly gepackt.
      Klappt bestens.
        <variables>
          <variable id="Civ)@a`PPOAP;Au`yrk7">id</variable>
          <variable id="He?L*;%S5ZxhQdVQ|nwK">value</variable>
          <variable id="}H`Md*ym;;=9MQYQ+d#g">ts</variable>
          <variable id="}FYTizs{~u7qb%G~dwNB">ack</variable>
          <variable id="mbSwYNv,Ng@m[=[1wvlp">from</variable>
          <variable id="n]Oh`3dmP!HF^Id)E2cC">q</variable>
        </variables>
        <block type="procedures_defcustomnoreturn" id="byaN9|n~rP|LoWSf8_V~" x="-187" y="-838">
          <mutation statements="false">
            <arg name="id" varid="Civ)@a`PPOAP;Au`yrk7"></arg>
            <arg name="value" varid="He?L*;%S5ZxhQdVQ|nwK"></arg>
            <arg name="ts" varid="}H`Md*ym;;=9MQYQ+d#g"></arg>
            <arg name="ack" varid="}FYTizs{~u7qb%G~dwNB"></arg>
            <arg name="from" varid="mbSwYNv,Ng@m[=[1wvlp"></arg>
            <arg name="q" varid="n]Oh`3dmP!HF^Id)E2cC"></arg>
          </mutation>
          <field name="NAME">Sql</field>
          <field name="SCRIPT">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</field>
        <block type="procedures_callcustomnoreturn" id="KIg}!gS-U_Q,4VS(Y;ag" x="-187" y="-787">
          <mutation name="Sql">
            <arg name="id"></arg>
            <arg name="value"></arg>
            <arg name="ts"></arg>
            <arg name="ack"></arg>
            <arg name="from"></arg>
            <arg name="q"></arg>
          </mutation>
          <value name="ARG0">
            <block type="text" id="DxgSLx$~EyIX~8JHOLN!">
              <field name="TEXT">0_userdata.0.sqlnummer</field>
          <value name="ARG1">
            <block type="math_number" id="VwIr0SM1gpzH}fLap/,5">
              <field name="NUM">9</field>
          <value name="ARG2">
            <block type="time_get" id="v8^^Zqii`2`lnLSSwwpz">
              <field name="OPTION">object</field>
          <value name="ARG3">
            <block type="math_number" id="9$_Ioh[7,!JS0{?tgRI+">
              <field name="NUM">1</field>
          <value name="ARG4">
            <block type="math_number" id="24j,lq_?zyj-~=}ej%@,">
          <value name="ARG5">
            <block type="math_number" id="J{v_.^f0|TOmC)1c3!QP">
              <field name="NUM">0</field>
        Friedel @David G. last edited by
        @david-g Hallo,
        ich möchte dieses Thema gerne wieder aufgreifen.
        Ich würde gerne bei dem letzten Eintrag in der SQL Datenbank den Zeitstempel nachträglich ändern.
        Habe es mit dem Hinweis von @liv-in-sky versucht, bekomme es aber nicht hin.
        Bin auch eher die Fraktion Blockly und habe es in einer Javascript-Funktion eingetragen um diese dann bei Bedarf aufzurufen.
        Bei dem Aufruf würde ich gerne den Datenpunkt und den neuen Zeitstempel übergeben.
        Kann mir hier einer weiterhelfen?
        • BananaJoe
          BananaJoe Most Active @Friedel last edited by
          @friedel sagte in Zeitstemlel von SQL- Historyeintrag manipulieren:
          du kannst den löschen und neu mit dem richtigen Wert anlegen (Reihenfolge beliebig).
          Im Idealfall schreibst du den falschen Eintrag gar nicht erst
            Friedel @BananaJoe last edited by
            @bananajoe
            Der Eintrag wird automatisch geschrieben. das möchte ich auch gerne so lassen.
            Bei einer bestimmten Bedingung (Trigger) soll der Zeitstempel geändert werden.
            Das braucht auch nur für den letzten Datensatz gemacht werden.
            BananaJoe OliverIO 2 Replies Last reply Reply Quote 0
            • BananaJoe
              @friedel dann mit dem richtige Zeitstempel noch mal neu schreiben und den falschen löschen.
              Liegt der "richtige" davor oder dahinter?
              • OliverIO
                OliverIO @Friedel last edited by
                @friedel
                Es dürfte zwar egal sein, aber wenn dann würde ich mit einem Update sql Befehl den Datensatz aktualisieren.
                Wenn du nur den letzten aktualisieren willst, könntest du aber auch einen neuen zusätzlichen Datensatz schreiben.
                Bei Datenbanken gibt es nicht wirklich ein davor und danach, da die Methode wie eine Datenbank dann wirklich physisch speichert für einen Nutzer ziemlich uninteressant ist.
                Die Reihenfolge kommt über eine Sortierung, meist dann nach dem primary key, welcher meist die id ist.
                  @bananajoe
                  Dein Vorschlag mit neu schreiben funktioniert ja.
                  Hat aber den Nachteil das ich den Wert nicht abfragen kann sondern nur für z.B. eChart nutzen kann.
                  Ich möchte nur den Zeitstempel des zuletzt eingetragenen Wertes ändern.
                  • OliverIO
                    @friedel
                    Kein Problem. Dann einfach ein updatestatement mit einer where clause auf den datenpunkt id und dann einfach die max funktion auf die id oder den timestamp mit Limit 1 ausführen. Schon hast du den letzten Datensatz zu deinem datenpunkt.
                      Friedel @OliverIO last edited by
                      @oliverio
                      Mit Update habe ich es probiert, aber ich bin ganz ehrlich ich tue mich mit Javascript etwas schwer.
                      Würde es gerne in ein Blockly Javascriptfunktion mit Parameter packen und dann über Blockly ausführen.
                      • OliverIO
                        OliverIO @Friedel last edited by OliverIO
                        @friedel
                        Wieso JavaScript? Ich würde das direkt mit sql machen. ok, ein wenig javascript ist auch dabei. mit blockly kenne ich mich leider nicht so gut aus
                        ergänzung:
                        hier das sql für den abruf des letzten eintrags anhand des datenpunktnamens.
                        SELECT tn.* FROM ts_number tn JOIN datapoints dp ON dp.id = tn.id WHERE dp.name = 'datenpunkt id' ORDER BY tn.ts DESC LIMIT 1
                        und hier der befehl zum aktualisieren
                        UPDATE ts_number
                        SET ts= 1742833899865
                        WHERE id = (
                            SELECT dp.id
                            FROM datapoints dp
                        AND ts = (
                            SELECT MAX(tn.ts)
                            FROM ts_number tn
                        ggfs muss bei den FROM noch jeweils der Datenbankname davor geschrieben werden.
                        Also anhand eines Beispiels:
                        FROM ts_number
                        nach
                        FROM iobroker.ts_number
                        falls die Datenbank iobroker heißt
                          @oliverio
                          Dieses ist mein Versuch. Aber er meldet direkt Fehler.
                          UPDATE daten_iobroker.ts_number SET ts = '1742832000000' WHERE id = 0_userdata.0.Test_SQL.PV_Ertrag_Stunde ORDER BY ts DESC LIMIT 1;
                          • OliverIO
                            @friedel
                            das problem ist, das der datenpunktname nicht direkt in der tabelle drin steht, sondern auf 2 tabellen aufgeteilt ist. eine tabelle mit den datenpunktnamen und einer id und dann je nach datentyp eine tabelle mit den werten, die aber nur auf die id der datenpunkt tabelle referenziert.
                            daher muss man immer noch einen join machen.
                            ich kann zwar sql, hab mir aber jetzt nur schnell die mal mit chat gpt erstellen lassen. man muss chatgpt halt die informationen mitliefern wie bspw:
                            ich habe eine tabelle mit datapoints und einer spalte id und name, sowie eine tabelle
                            ts_number mit den spalten id, welche der id in tabelle datapoints entspricht und einer spalte ts
                            für einen timestamp, sowie eine spalte value. ich benötige nun ein sql zur abfrage zeitlich
                            letzten wertes anhand eines datenpunkt namens und ein sql zur aktualisierung des werts
                            als ergebnis hat mit chatgpt sogar eine erklärung geliefert.
                            das kannst du auch zur fehlersuche verwenden.
                            schau dir auch mal den inhalt der datenbank an, die iobroker verwendet.
                            am besten für mysql/mariadb verwendest du myphpadmin. ist mit docker auch relativ schnell installiert
                            ich habe oben das update sql noch angepasst, da ich gemerkt habe das du ja nicht value, sonder ts anpassen willst
                            • OliverIO
                              für bessere hilfe ist es immer gut, die fehler auch gleich mit zu benennen.
                              "er meldet fehler" ist sehr generisch
                              gut hier wusste ich es, aber für die weitere verfolgung bitte so
                                @oliverio
                                Danke für die Unterstützung.
                                Ich werde es gleich mal ausprobieren.
                                Mit chat gpt habe ich noch nicht gearbeitet, schau ich mir auch gleich mal an.
                                • OliverIO
                                  @friedel
                                  gerade für anfänger ist das ideal.
                                  auch zum erklären, einfach reinkopieren zeile leer lassen und nach erklärung fragen.
                                  alles was mit strikter syntax versehen ist können LLMs sehr gut.
                                  Man muss aber alles nochmal checken, aber du kannst mit chatgpt sprechen wie mit einem hilfsprogrammierer. wenn du dann sagst das du anfänger bist, erklärt chatgpt auch mehr,detaillierter und einfacher, so das es anfänger auch verstehen. ansonsten immer nachfragen
                                    Friedel last edited by Friedel
                                    @oliverio
                                    Ich komme hier einfach nicht weiter.
                                    Den letzten Eintrag anzeigen zu lassen klappt schon nicht.
                                    Wahrscheinlich ist es nur eine Kleinigkeit, aber ich habe mich hier festgefahren.
                                    Vieleicht kann mir noch einer auf die Sprünge helfen.
                                    javascript.0	20:18:57.377	info	script.js.common.SQL_Datenbank.Zeitstempel_1: sendTo(instance=sql.0, cmd=query, msg="SELECT * FROM daten_iobroker.ts_number WHERE id = '0_userdata.0.Test_SQL.PV_Ertrag_Stunde' ORDER BY ts DESC LIMIT 1;", hasCallback=true)
                                    javascript.0	20:18:57.377	info	script.js.common.SQL_Datenbank.Zeitstempel_1: sendTo[custom] sql.0: SELECT * FROM daten_iobroker.ts_number WHERE id = '0_userdata.0.Test_SQL.PV_Ertrag_Stunde' ORDER BY ts DESC LIMIT 1;
                                    javascript.0	20:18:57.378	info	script.js.common.SQL_Datenbank.Zeitstempel_1: registered 0 subscriptions, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                                    javascript.0	20:18:57.386	info	script.js.common.SQL_Datenbank.Zeitstempel_1: { error: null, result: [] }
                                    • OliverIO
                                      hatte ich ja oben schon geschrieben
                                      @oliverio sagte in Zeitstemlel von SQL- Historyeintrag manipulieren:
                                      in der tabelle ts_numer ist die spalte id eine nummer. das mapping von id zu datenpunktname erfolgt in der tabelle datapoints. daher muss man ein join machen.
                                      du hast 2 möglichkeiten
                                      a) auswahl über den datenpunktnamen wie folgt:
                                      SELECT tn.*
                                      FROM ts_number tn
                                      JOIN datapoints dp
                                      ON dp.id = tn.id
                                      ORDER BY tn.ts DESC
                                      LIMIT 1
                                      oder b)
                                      du suchst in tabelle datapoint die id passend zu deinem datenpunkt heraus (wie gesagt das ist eine nummer)
                                      dann kannst du auch so machen. 123 dann gegen die eigentliche id austauschen
                                      SELECT *
                                      WHERE id = 123
                                      ORDER BY ts DESC
                                      LIMIT 1
                                        @oliverio
                                        Hallo, habe es jetzt hinbekommen so wie Du es geasgt hattest.
                                        Hier einmal die Abfrage nach dem letzten Eintrag.
                                        sendTo('sql.0', 'query', 'SELECT * FROM daten_iobroker.ts_number WHERE id = 33 ORDER BY ts DESC LIMIT 1', async (result) => {
                                            console.info(result);
                                        Und hier einmal wo der Zeitstempel vom letzten Eintrag geändert wird.
                                        sendTo('sql.0', 'query', 'UPDATE daten_iobroker.ts_number SET ts = \'1743082140098\' WHERE id = 33 ORDER BY ts DESC LIMIT 1');
                                        Nun würde ich aber gerne die ID und den Zeitstempel als Variable übergeben. Dieses bekomme ich aber nicht hin.
                                        Kann mir hier noch einer weiterhelfen?
                                          Friedel @Friedel last edited by
                                          @oliverio
                                            @friedel
                                            Die Frage ist wie ich die Variabel übergeben muss?
                                            var Datenpunkt = _id;
                                            var Timestamp = _ts;
                                            sendTo('sql.0', 'query', 'SELECT * FROM daten_iobroker.ts_number WHERE id == Datenpunkt ORDER BY ts DESC LIMIT 1', async (result) => {
                                            console.log(Datenpunkt);
                                            console.log(Timestamp);
                                            1332
