    3. Einsteigerfragen
    4. Installation
    5. Update auf node 20 erstellen von standart user
      Locke3600 @Thomas Braun last edited by
      brauchst du auch die ersten seiten?
       Static hostname: IoBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-30-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      Installation:           kvm
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CET, +0100)
      User-ID:                1001
      Display-Server:         false
      Boot Target:            graphical.target
      Pending OS-Updates:     38
      Pending iob updates:    8
      Nodejs-Installation:
      /usr/bin/nodejs         v18.20.6
      /usr/bin/node           v18.20.6
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      Recommended versions are nodejs 20.19.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            8.3G        1.7G        6.4G        565K        554M        6.7G
      Swap:           1.0G          0B        1.0G
      Total:          9.3G        1.7G        7.4G
      Active iob-Instances:   14
      Upgrade policy: none
      ioBroker Core:          js-controller           6.0.11
                              admin                   7.4.10
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.admin.1                  : admin                 : IoBroker                                 - disabled, port: 8088, bind: 127.0.0.1, run as: admin
        system.adapter.web.2                    : web                   : IoBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                4985
      States:                 3736
      Size of iob-Database:
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      5.2M    /opt/iobroker/iobroker-data/states.jsonl
        Thomas Braun Most Active @Locke3600 last edited by
        @locke3600 sagte in Update auf node 20 erstellen von standart user:
        Natürlich.
          @thomas-braun ```
          ========== Start marking the full check here ===========
          Script v.2025-02-23
          *** BASE SYSTEM ***
                   Chassis: vm 🖴
            Virtualization: kvm
          OS is similar to:
          model name      : QEMU Virtual CPU version 2.5+
          Docker          : false
          Virtualization  : kvm
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           18:32:15 up 20 min,  2 users,  load average: 0.11, 0.08, 0.07
          CPU threads: 2
          *** LIFE CYCLE STATUS ***
          Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
          *** TIME AND TIMEZONES ***
                         Local time: Mon 2025-03-24 18:32:15 CET
                     Universal time: Mon 2025-03-24 17:32:15 UTC
                           RTC time: Mon 2025-03-24 17:32:15
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          admin
          HOME=/home/admin
          GROUPS=admin adm dialout sudo audio video plugdev users iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout cdrom floppy audio dip video plugdev users netdev
          *** DISPLAY-SERVER SETUP ***
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            8.3G        1.6G        6.5G        561K        555M        6.8G
          Swap:           1.0G          0B        1.0G
          Total:          9.3G        1.6G        7.5G
                   7941 M total memory
                   1495 M used memory
                    320 M active memory
                   1263 M inactive memory
                   6161 M free memory
                     60 M buffer memory
                    468 M swap cache
                    974 M total swap
                      0 M used swap
                    974 M free swap
          top - 18:32:15 up 20 min,  2 users,  load average: 0.11, 0.08, 0.07
          Tasks: 104 total,   1 running, 103 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7941.2 total,   6161.4 free,   1495.7 used,    529.5 buff/cache
          MiB Swap:    975.0 total,    975.0 free,      0.0 used.   6445.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.9G     0  3.9G   0% /dev
          tmpfs          tmpfs     795M  552K  794M   1% /run
          /dev/sda1      ext4       97G  8.2G   84G   9% /
          tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
          tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
          tmpfs          tmpfs     744M     0  744M   0% /run/user/1001
          [Mon Mar 24 18:11:21 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
          [Mon Mar 24 18:11:22 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE    FSTYPE OPTIONS
          /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
          /var:
          622M    /var/
          281M    /var/cache
          274M    /var/cache/apt
          197M    /var/cache/apt/archives
          176M    /var/lib
          Archived and active journals take up 149.7M in the file system.
          /opt/iobroker/backups:
          136M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.3G    /opt/iobroker/iobroker-data/
          1.2G    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
          19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6cc6339159d8ed118e09786162c613ac-if00-port0
          *** ZigBee Settings ***
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Installed: 18.20.6-1nodesource1
            Candidate: 18.20.6-1nodesource1
            Version table:
           *** 18.20.6-1nodesource1 1001
                  500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               18.20.5-1nodesource1 1001
               18.20.4-1nodesource1 1001
               18.20.3-1nodesource1 1001
               18.20.2-1nodesource1 1001
               18.20.1-1nodesource1 1001
               18.20.0-1nodesource1 1001
               18.19.1-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
               18.19.0-1nodesource1 1001
               18.18.2-1nodesource1 1001
               18.18.1-1nodesource1 1001
               18.18.0-1nodesource1 1001
               18.17.1-1nodesource1 1001
               18.17.0-1nodesource1 1001
               18.16.1-1nodesource1 1001
               18.16.0-1nodesource1 1001
               18.15.0-1nodesource1 1001
               18.14.2-1nodesource1 1001
               18.14.1-1nodesource1 1001
               18.14.0-1nodesource1 1001
               18.13.0-1nodesource1 1001
               18.12.0-1nodesource1 1001
               18.11.0-1nodesource1 1001
               18.10.0-1nodesource1 1001
               18.9.1-1nodesource1 1001
               18.9.0-1nodesource1 1001
               18.8.0-1nodesource1 1001
               18.7.0-1nodesource1 1001
               18.6.0-1nodesource1 1001
               18.5.0-1nodesource1 1001
               18.4.0-1nodesource1 1001
               18.3.0-1nodesource1 1001
               18.2.0-1nodesource1 1001
               18.1.0-1nodesource1 1001
               18.0.0-1nodesource1 1001
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          IoBroker            IoBroker (version: 6.0.11, hostname: IoBroker      , alive, uptime: 1111)
          Core adapters versions
          js-controller:  6.0.11
          admin:          7.4.10
          javascript:     8.8.3
          nodejs modules from github:     2
          +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
          +-- iobroker.tapo@0.2.9 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#bded02134bbcc37543a2af51224c4d50c718088f)
          Adapter State
          + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
          + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : IoBroker                                 -  enabled
          + system.adapter.denon.0                  : denon                 : IoBroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
            system.adapter.history.0                : history               : IoBroker                                 - disabled
          + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 8081
            system.adapter.hs100.0                  : hs100                 : IoBroker                                 - disabled
            system.adapter.ical.0                   : ical                  : IoBroker                                 - disabled
          + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
            system.adapter.iqontrol.0               : iqontrol              : IoBroker                                 - disabled
          + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
            system.adapter.lgtv.0                   : lgtv                  : IoBroker                                 - disabled
            system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 - disabled, port: 54321
            system.adapter.ping.0                   : ping                  : IoBroker                                 - disabled
          + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
            system.adapter.scenes.0                 : scenes                : IoBroker                                 - disabled
            system.adapter.tapo.0                   : tapo                  : IoBroker                                 - disabled
            system.adapter.text2command.0           : text2command          : IoBroker                                 - disabled
          + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
            system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 - disabled
          + system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 -  enabled
          + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6cc6339159d8ed118e09786162c613ac-if00-port0
          + instance is alive
          ioBroker-Repositories
          │ (index) │   name   │                           url                           │ auto upgrade │
          │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
          │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
          Active repo(s): stable
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.6.3    , installed 7.4.10 [Updatable]
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "denon"        : 1.15.12  , installed 1.15.12
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "hs100"        : 2.2.2    , installed 2.2.2
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "iqontrol"     : 3.0.0    , installed 2.3.0  [Updatable]
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
          Adapter    "lgtv"         : 2.4.0    , installed 2.2.0  [Updatable]
          Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
          Adapter    "proxmox"      : 2.4.0    , installed 2.3.0  [Updatable]
          Adapter    "scenes"       : 3.2.3    , installed 3.2.1  [Updatable]
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.32 [Updatable]
          Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
          Objects and States
          Objects:        4985
          States:         3731
          Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
          Reading package lists...
          Pending Updates: 38
          *** Listening Ports ***
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17926      829/iobroker.js-con
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       17343      829/iobroker.js-con
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13432      1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15919      511/sshd: /usr/sbin
          tcp        0      0 192.168.178.201:8082    0.0.0.0:*               LISTEN      1000       18838      1004/io.hm-rpc.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          13434      1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15921      511/sshd: /usr/sbin
          tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18457      847/io.admin.0
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14125      371/dhclient
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13433      1/init
          udp6       0      0 :::111                  :::*                                0          13435      1/init
          2025-03-24 18:14:23.018  - info: denon.0 (1034) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.32:23
          2025-03-24 18:14:25.421  - error: cloud.0 (923) Instance web.2 not enabled. Please enable this instance for cloud
          2025-03-24 18:14:25.431  - error: cloud.0 (923) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
          2025-03-24 18:14:25.432  - info: cloud.0 (923) Trying to connect as system.user.admin to cloud
          2025-03-24 18:14:25.588  - info: cloud.0 (923) Connection changed: connect
          2025-03-24 18:14:26.329  - info: host.IoBroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1049
          2025-03-24 18:14:27.263  - info: iot.0 (1049) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v18.20.6, js-controller: 6.0.11
          2025-03-24 18:14:27.290  - info: iot.0 (1049) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
          2025-03-24 18:14:27.772  - info: iot.0 (1049) Connection changed: connect "andre23___web_de"
          2025-03-24 18:14:30.297  - info: host.IoBroker instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1064
          2025-03-24 18:14:31.111  - info: vis-2.0 (1064) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v18.20.6, js-controller: 6.0.11
          2025-03-24 18:14:31.312  - info: vis-2.0 (1064) vis-2 license is OK.
          2025-03-24 18:14:34.940  - warn: zigbee.0 (943) DeviceAvailability:Failed to ping 0x00178801024795b4 LCT010
          2025-03-24 18:14:43.649  - info: alexa2.0 (989) Unknown Device, but enabling commands, Try it and report back if commands work.
          2025-03-24 18:14:43.649  - info: alexa2.0 (989) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
          2025-03-24 18:14:43.649  - info: alexa2.0 (989)     Device-type:A2V9UEGZ82H4KZ - Taplet Smart Home (VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,DIALOG_INTERFACE_VERSION,NO_TIME_ZONE_SETTING,SET_TIME_ZONE,TIMERS_AND_ALARMS,SOUND_SETTINGS,REMINDERS,ASX_TIME_ZONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,CUSTOM_ALARM_TONE,SUPPORTS_LOCALE,PERSISTENT_CONNECTION)
          2025-03-24 18:14:48.484  - info: alexa2.0 (989) Unknown Device, but enabling commands, Try it and report back if commands work.
          2025-03-24 18:14:48.484  - info: alexa2.0 (989) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
          2025-03-24 18:14:48.484  - info: alexa2.0 (989)     Device-type:A1Q6UGEXJZWJQ0 - Mama Fire TV (VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,DIALOG_INTERFACE_VERSION,EARCONS,SHARKNADO,SUPPORTS_LOCALE_SWITCH,MULTI_WAKEWORDS_SUPPORTED,FLASH_BRIEFING,ARTHUR_TARGET,TIMERS_AND_ALARMS,SOUND_SETTINGS,CHANGE_NAME,SPEECH_RECOGNIZER_USS,REMINDERS,ACTIVE_AFTER_FRO,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CUSTOM_ALARM_TONE,SUPPORTS_LOCALE,PERSISTENT_CONNECTION)
          2025-03-24 18:15:04.826  - info: alexa2.0 (989) Using cached smart home devices list from Mon Mar 24 2025 18:05:23 GMT+0100 (Mitteleuropäische Normalzeit)
          2025-03-24 18:15:05.828  - info: alexa2.0 (989) No smart home devices to query
          2025-03-24 18:15:07.777  - info: alexa2.0 (989) Subscribing to states...
          2025-03-24 18:15:07.779  - info: alexa2.0 (989) Deleting the following states: ["Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476","Smart-Home-Devices.0f312b76-25b6-4d4e-8a1e-a087cfbd7adc","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#enabled","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#delete","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.powerState","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#query","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#includeInAllQuery","Smart-Home-Devices.0f312b76-25b6-4d4e-8a1e-a087cfbd7adc.#enabled","Smart-Home-Devices.0f312b76-25b6-4d4e-8a1e-a087cfbd7adc.#delete","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65.#enabled","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65.#delete","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65.active","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a.#enabled","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a.#delete","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a.active","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3.#enabled","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3.#delete","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3.active","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831.#enabled","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831.#delete","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831.active","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150.#enabled","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150.#delete","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150.active","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635.#enabled","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635.#delete","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635.active","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a.#enabled","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a.#delete","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a.active","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122.#enabled","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122.#delete","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122.active","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa.#enabled","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa.#delete","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa.active","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3.#enabled","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3.#delete","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3.active","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b.#enabled","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b.#delete","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b.active","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef.#enabled","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef.#delete","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef.active","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e.#enabled","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e.#delete","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e.active","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049.#enabled","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049.#delete","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049.active","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0.#enabled","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0.#delete","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0.active","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f.#enabled","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f.#delete","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f.active","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14.#enabled","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14.#delete","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14.active","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f.#enabled","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f.#delete","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f.active","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad.#enabled","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad.#delete","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad.active","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c.#enabled","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c.#delete","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c.active","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d.#enabled","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d.#delete","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d.active","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92.#enabled","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92.#delete","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92.active","Smart-Home-Devices.ea1d8e4c-5d48-454b-b61f-801664d05cd2.detectionState","Smart-Home-Devices.ea1d8e4c-5d48-454b-b61f-801664d05cd2.#query","Smart-Home-Devices.ea1d8e4c-5d48-454b-b61f-801664d05cd2.#includeInAllQuery","Smart-Home-Devices.0b992735-56a7-4d5b-a799-3ba9b5499d02.detectionState"]
          2025-03-24 18:15:09.690  - info: alexa2.0 (989) Alexa-Push-Connection (macDms = true) established. Disable Polling
          2025-03-24 18:15:23.622  - info: alexa2.0 (989) Initialization Done ...
          iob diag has finished.
            @locke3600
            Dann jag jetzt den
            iob fix
            drüber.
              Locke3600 @Thomas Braun last edited by Locke3600
              @Thomas-Braun
              iob fix :
              Brauch ich das?
              Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
                @locke3600
                Ja, du möchtest multi-user fahren.
                  alles klar iob fix ist durch
                    @locke3600
                    Dann sollte jetzt auch ein
                    iob diag
                    an mindestens 2 Stellen anders aussehen.
                      ```bash
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                        Virtualization: kvm
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       18:43:47 up 32 min,  2 users,  load average: 0.27, 0.16, 0.11
                      CPU threads: 2
                      Operating System is the current Debian stable version codenamed 'bookworm'!
                                     Local time: Mon 2025-03-24 18:43:47 CET
                                 Universal time: Mon 2025-03-24 17:43:47 UTC
                                       RTC time: Mon 2025-03-24 17:43:47
                                    NTP service: active
                                RTC in local TZ: no
                      admin
                      HOME=/home/admin
                      js-controller is not running
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.3G        422M        7.5G        552K        671M        7.9G
                      Swap:           1.0G          0B        1.0G
                      Total:          9.3G        422M        8.5G
                               7941 M total memory
                                402 M used memory
                                416 M active memory
                                132 M inactive memory
                               7174 M free memory
                                 86 M buffer memory
                                553 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      top - 18:43:47 up 32 min,  2 users,  load average: 0.27, 0.16, 0.11
                      Tasks:  91 total,   1 running,  90 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   7941.2 total,   7174.6 free,    402.6 used,    640.1 buff/cache
                      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7538.6 avail Mem
                        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                      * iobroker.service loaded failed failed ioBroker Server
                      LOAD   = Reflects whether the unit definition was properly loaded.
                      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                      SUB    = The low-level unit activation state, values depend on unit type.
                      1 loaded units listed.
                      *** FILESYSTEM ***
                      tmpfs          tmpfs     795M  548K  794M   1% /run
                      /var:
                      622M    /var/
                      281M    /var/cache
                      274M    /var/cache/apt
                      198M    /var/cache/apt/archives
                      176M    /var/lib
                      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      iobroker is not running on this host.
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      IoBroker            IoBroker (version: 6.0.11, hostname: IoBroker      , alive, uptime: 1471)
                      admin:          7.4.10
                      javascript:     8.8.3
                      Adapter State
                      + instance is alive
                      Objects and States
                      Objects:        4985
                      States:         3614
                      Pending Updates: 38
                      2025-03-24 18:38:18.790  - info: zigbee.0 (943) terminating
                      2025-03-24 18:38:18.791  - info: zigbee.0 (943) Terminated (NO_ERROR): Without reason
                      2025-03-24 18:38:18.794  - info: tr-064.0 (959) terminating
                      2025-03-24 18:38:18.795  - info: javascript.0 (890) terminating
                      2025-03-24 18:38:18.798  - info: hm-rega.0 (1019) terminating
                      2025-03-24 18:38:18.802  - info: denon.0 (1034) terminating
                      2025-03-24 18:38:18.803  - info: vis-2.0 (1064) terminating
                      2025-03-24 18:38:18.805  - info: cloud.0 (923) terminating
                      2025-03-24 18:38:18.805  - info: admin.0 (847) terminating
                      2025-03-24 18:38:18.806  - info: alexa2.0 (989) terminating
                      2025-03-24 18:38:18.937  - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:18.938  - info: host.IoBroker instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:18.938  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.030  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.031  - info: host.IoBroker instance system.adapter.denon.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.031  - info: host.IoBroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.080  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.081  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.081  - info: host.IoBroker instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.081  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.105  - info: host.IoBroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.105  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.324  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                      2025-03-24 18:38:19.324  - info: host.IoBroker All instances are stopped.
                      2025-03-24 18:38:19.516  - info: host.IoBroker terminated
                        @locke3600
                        Dann bring das ganze Spiel noch auf
                        iob nodejs-update
                        und hau die anderen Updates (OS und ioBroker) noch drauf.
                          jetzt ist alles auf stand.
                          wen man weis wie ganz einfach😖
                          vielen dank schonmal.
                          Script v.2025-02-23
                          *** BASE SYSTEM ***
                                   Chassis: vm 🖴
                            Virtualization: kvm
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           19:07:32 up 56 min,  2 users,  load average: 0.50, 0.26, 0.14
                          CPU threads: 2
                                         Local time: Mon 2025-03-24 19:07:33 CET
                                     Universal time: Mon 2025-03-24 18:07:33 UTC
                                           RTC time: Mon 2025-03-24 18:07:33
                                        NTP service: active
                                    RTC in local TZ: no
                          admin
                          HOME=/home/admin
                          Desktop:
                          Terminal:       tty
                          *** MEMORY ***
                          Mem:            8.3G        447M        6.0G        561K        2.2G        7.9G
                          Swap:           1.0G          0B        1.0G
                          Total:          9.3G        447M        7.0G
                                   7941 M total memory
                                    426 M used memory
                                    514 M active memory
                                   1398 M inactive memory
                                   5725 M free memory
                                    159 M buffer memory
                                   1927 M swap cache
                                    974 M total swap
                                      0 M used swap
                                    974 M free swap
                          top - 19:07:33 up 56 min,  2 users,  load average: 0.50, 0.26, 0.14
                          MiB Mem :   7941.2 total,   5725.4 free,    427.3 used,   2087.0 buff/cache
                          MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7513.8 avail Mem
                          *** FILESYSTEM ***
                          /dev/sda1      ext4       97G  8.1G   84G   9% /
                          /var:
                          697M    /var/
                          355M    /var/cache
                          348M    /var/cache/apt
                          272M    /var/cache/apt/archives
                          176M    /var/lib
                          1.1G    /opt/iobroker/iobroker-data/
                          998M    /opt/iobroker/iobroker-data/files
                          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                          24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
                          24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                          USB-Devices by-id:
                          zigbee.X
                          Extended Pan ID:
                          *** MASKED ***
                          Pan ID:
                          *** MASKED ***
                          Channel:
                          *** MASKED ***
                          Network Key:
                          *** MASKED ***
                          /usr/bin/nodejs         v20.19.0
                          /usr/bin/node           v20.19.0
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          /usr/bin/corepack       0.31.0
                          nodejs:
                            Installed: 20.19.0-1nodesource1
                            Candidate: 20.19.0-1nodesource1
                            Version table:
                           *** 20.19.0-1nodesource1 1001
                                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                               20.18.3-1nodesource1 1001
                               20.18.2-1nodesource1 1001
                               20.18.1-1nodesource1 1001
                               20.18.0-1nodesource1 1001
                               20.17.0-1nodesource1 1001
                               20.16.0-1nodesource1 1001
                               20.15.1-1nodesource1 1001
                               20.15.0-1nodesource1 1001
                               20.14.0-1nodesource1 1001
                               20.13.1-1nodesource1 1001
                               20.13.0-1nodesource1 1001
                               20.12.2-1nodesource1 1001
                               20.12.1-1nodesource1 1001
                               20.12.0-1nodesource1 1001
                               20.11.1-1nodesource1 1001
                               20.11.0-1nodesource1 1001
                               20.10.0-1nodesource1 1001
                               20.9.0-1nodesource1 1001
                               20.8.1-1nodesource1 1001
                               20.8.0-1nodesource1 1001
                               20.7.0-1nodesource1 1001
                               20.6.1-1nodesource1 1001
                               20.6.0-1nodesource1 1001
                               20.5.1-1nodesource1 1001
                               20.5.0-1nodesource1 1001
                               20.4.0-1nodesource1 1001
                               20.3.1-1nodesource1 1001
                               20.3.0-1nodesource1 1001
                               20.2.0-1nodesource1 1001
                               20.1.0-1nodesource1 1001
                               20.0.0-1nodesource1 1001
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          js-controller:  7.0.6
                          admin:          7.6.3
                          javascript:     8.8.3
                          Adapter State
                          + instance is alive
                          Adapter    "admin"        : 7.6.3    , installed 7.6.3
                          Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                          Controller "js-controller": 7.0.6    , installed 7.0.6
                          Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                          Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                          Adapter    "web"          : 7.0.8    , installed 7.0.8
                          Objects and States
                          Objects:        4985
                          States:         3614
                          Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                          Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                          Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                          Pending Updates: 0
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13432      1/systemd
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          52530      10457/sshd: /usr/sb
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          13434      1/systemd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          52532      10457/sshd: /usr/sb
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13433      1/systemd
                          udp6       0      0 :::111                  :::*                                0          13435      1/systemd
                            Thema Basics...
                            81.1k
                            5245
