    3. Einsteigerfragen
    4. Installation
    5. Update auf node 20 erstellen von standart user
      Locke3600 @Thomas Braun last edited by
      @thomas-braun ```
      ========== Start marking the full check here ===========
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: IoBroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-30-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.2-0-gea1b7a073390-prebuilt.qemu.org
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:32:15 up 20 min,  2 users,  load average: 0.11, 0.08, 0.07
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Unknown release codenamed 'bookworm'. Please check yourself if the Operating System is actively maintained.
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-03-24 18:32:15 CET
                 Universal time: Mon 2025-03-24 17:32:15 UTC
                       RTC time: Mon 2025-03-24 17:32:15
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      admin
      HOME=/home/admin
      GROUPS=admin adm dialout sudo audio video plugdev users iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout cdrom floppy audio dip video plugdev users netdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:            8.3G        1.6G        6.5G        561K        555M        6.8G
      Swap:           1.0G          0B        1.0G
      Total:          9.3G        1.6G        7.5G
      Active iob-Instances:   14
               7941 M total memory
               1495 M used memory
                320 M active memory
               1263 M inactive memory
               6161 M free memory
                 60 M buffer memory
                468 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 18:32:15 up 20 min,  2 users,  load average: 0.11, 0.08, 0.07
      Tasks: 104 total,   1 running, 103 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7941.2 total,   6161.4 free,   1495.7 used,    529.5 buff/cache
      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   6445.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  552K  794M   1% /run
      /dev/sda1      ext4       97G  8.2G   84G   9% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     744M     0  744M   0% /run/user/1001
      [Mon Mar 24 18:11:21 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Mar 24 18:11:22 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      622M    /var/
      281M    /var/cache
      274M    /var/cache/apt
      197M    /var/cache/apt/archives
      176M    /var/lib
      Archived and active journals take up 149.7M in the file system.
      /opt/iobroker/backups:
      136M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G    /opt/iobroker/iobroker-data/
      1.2G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.1e6546bb.js.map
      19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.e7bb655f.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6cc6339159d8ed118e09786162c613ac-if00-port0
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v18.20.6
      /usr/bin/node           v18.20.6
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 18.20.6-1nodesource1
        Candidate: 18.20.6-1nodesource1
        Version table:
       *** 18.20.6-1nodesource1 1001
              500 https://deb.nodesource.com/node_18.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           18.20.5-1nodesource1 1001
           18.20.4-1nodesource1 1001
           18.20.3-1nodesource1 1001
           18.20.2-1nodesource1 1001
           18.20.1-1nodesource1 1001
           18.20.0-1nodesource1 1001
           18.19.1-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
           18.19.0-1nodesource1 1001
           18.18.2-1nodesource1 1001
           18.18.1-1nodesource1 1001
           18.18.0-1nodesource1 1001
           18.17.1-1nodesource1 1001
           18.17.0-1nodesource1 1001
           18.16.1-1nodesource1 1001
           18.16.0-1nodesource1 1001
           18.15.0-1nodesource1 1001
           18.14.2-1nodesource1 1001
           18.14.1-1nodesource1 1001
           18.14.0-1nodesource1 1001
           18.13.0-1nodesource1 1001
           18.12.0-1nodesource1 1001
           18.11.0-1nodesource1 1001
           18.10.0-1nodesource1 1001
           18.9.1-1nodesource1 1001
           18.9.0-1nodesource1 1001
           18.8.0-1nodesource1 1001
           18.7.0-1nodesource1 1001
           18.6.0-1nodesource1 1001
           18.5.0-1nodesource1 1001
           18.4.0-1nodesource1 1001
           18.3.0-1nodesource1 1001
           18.2.0-1nodesource1 1001
           18.1.0-1nodesource1 1001
           18.0.0-1nodesource1 1001
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      IoBroker            IoBroker (version: 6.0.11, hostname: IoBroker      , alive, uptime: 1111)
      Core adapters versions
      js-controller:  6.0.11
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     2
      +-- homebridge-tapo@1.4.17 (git+ssh://git@github.com/apatsufas/homebridge-tapo-p100.git#8d25f8ab9ffc1d7cca1118cd0081d1ba28fd3cd1)
      +-- iobroker.tapo@0.2.9 (git+ssh://git@github.com/TA2k/ioBroker.tapo.git#bded02134bbcc37543a2af51224c4d50c718088f)
      Adapter State
      + system.adapter.admin.0                  : admin                 : IoBroker                                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
        system.adapter.admin.1                  : admin                 : IoBroker                                 - disabled, port: 8088, bind: 127.0.0.1, run as: admin
      + system.adapter.alexa2.0                 : alexa2                : IoBroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : IoBroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : IoBroker                                 -  enabled
      + system.adapter.denon.0                  : denon                 : IoBroker                                 -  enabled
        system.adapter.discovery.0              : discovery             : IoBroker                                 - disabled
        system.adapter.history.0                : history               : IoBroker                                 - disabled
      + system.adapter.hm-rega.0                : hm-rega               : IoBroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : IoBroker                                 -  enabled, port: 8081
        system.adapter.hs100.0                  : hs100                 : IoBroker                                 - disabled
        system.adapter.ical.0                   : ical                  : IoBroker                                 - disabled
      + system.adapter.iot.0                    : iot                   : IoBroker                                 -  enabled
        system.adapter.iqontrol.0               : iqontrol              : IoBroker                                 - disabled
      + system.adapter.javascript.0             : javascript            : IoBroker                                 -  enabled
        system.adapter.lgtv.0                   : lgtv                  : IoBroker                                 - disabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : IoBroker                                 - disabled, port: 54321
        system.adapter.ping.0                   : ping                  : IoBroker                                 - disabled
      + system.adapter.proxmox.0                : proxmox               : IoBroker                                 -  enabled, port: 8006
        system.adapter.scenes.0                 : scenes                : IoBroker                                 - disabled
        system.adapter.tapo.0                   : tapo                  : IoBroker                                 - disabled
        system.adapter.text2command.0           : text2command          : IoBroker                                 - disabled
      + system.adapter.tr-064.0                 : tr-064                : IoBroker                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : IoBroker                                 - disabled
      + system.adapter.vis-2.0                  : vis-2                 : IoBroker                                 -  enabled
        system.adapter.web.2                    : web                   : IoBroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.zigbee.0                 : zigbee                : IoBroker                                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_6cc6339159d8ed118e09786162c613ac-if00-port0
      + instance is alive
      ioBroker-Repositories
      │ (index) │   name   │                           url                           │ auto upgrade │
      │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
      │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.4.10 [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "hs100"        : 2.2.2    , installed 2.2.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 3.0.0    , installed 2.3.0  [Updatable]
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 6.0.11 [Updatable]
      Adapter    "lgtv"         : 2.4.0    , installed 2.2.0  [Updatable]
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "proxmox"      : 2.4.0    , installed 2.3.0  [Updatable]
      Adapter    "scenes"       : 3.2.3    , installed 3.2.1  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.32 [Updatable]
      Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        4985
      States:         3731
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_18.x nodistro InRelease
      Reading package lists...
      Pending Updates: 38
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       17926      829/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       17343      829/iobroker.js-con
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13432      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15919      511/sshd: /usr/sbin
      tcp        0      0 192.168.178.201:8082    0.0.0.0:*               LISTEN      1000       18838      1004/io.hm-rpc.0
      tcp6       0      0 :::111                  :::*                    LISTEN      0          13434      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15921      511/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1000       18457      847/io.admin.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14125      371/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13433      1/init
      udp6       0      0 :::111                  :::*                                0          13435      1/init
      2025-03-24 18:14:23.018  - info: denon.0 (1034) [CONNECT] Adapter connected to DENON-AVR: 192.168.178.32:23
      2025-03-24 18:14:25.421  - error: cloud.0 (923) Instance web.2 not enabled. Please enable this instance for cloud
      2025-03-24 18:14:25.431  - error: cloud.0 (923) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
      2025-03-24 18:14:25.432  - info: cloud.0 (923) Trying to connect as system.user.admin to cloud
      2025-03-24 18:14:25.588  - info: cloud.0 (923) Connection changed: connect
      2025-03-24 18:14:26.329  - info: host.IoBroker instance system.adapter.iot.0 in version "3.3.0" started with pid 1049
      2025-03-24 18:14:27.263  - info: iot.0 (1049) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.iot, node: v18.20.6, js-controller: 6.0.11
      2025-03-24 18:14:27.290  - info: iot.0 (1049) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
      2025-03-24 18:14:27.772  - info: iot.0 (1049) Connection changed: connect "andre23___web_de"
      2025-03-24 18:14:30.297  - info: host.IoBroker instance system.adapter.vis-2.0 in version "2.9.32" started with pid 1064
      2025-03-24 18:14:31.111  - info: vis-2.0 (1064) starting. Version 2.9.32 in /opt/iobroker/node_modules/iobroker.vis-2, node: v18.20.6, js-controller: 6.0.11
      2025-03-24 18:14:31.312  - info: vis-2.0 (1064) vis-2 license is OK.
      2025-03-24 18:14:34.940  - warn: zigbee.0 (943) DeviceAvailability:Failed to ping 0x00178801024795b4 LCT010
      2025-03-24 18:14:43.649  - info: alexa2.0 (989) Unknown Device, but enabling commands, Try it and report back if commands work.
      2025-03-24 18:14:43.649  - info: alexa2.0 (989) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-03-24 18:14:43.649  - info: alexa2.0 (989)     Device-type:A2V9UEGZ82H4KZ - Taplet Smart Home (VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,DIALOG_INTERFACE_VERSION,NO_TIME_ZONE_SETTING,SET_TIME_ZONE,TIMERS_AND_ALARMS,SOUND_SETTINGS,REMINDERS,ASX_TIME_ZONE,TIMERS_ALARMS_NOTIFICATIONS_VOLUME,CUSTOM_ALARM_TONE,SUPPORTS_LOCALE,PERSISTENT_CONNECTION)
      2025-03-24 18:14:48.484  - info: alexa2.0 (989) Unknown Device, but enabling commands, Try it and report back if commands work.
      2025-03-24 18:14:48.484  - info: alexa2.0 (989) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
      2025-03-24 18:14:48.484  - info: alexa2.0 (989)     Device-type:A1Q6UGEXJZWJQ0 - Mama Fire TV (VOLUME_SETTING,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,DIALOG_INTERFACE_VERSION,EARCONS,SHARKNADO,SUPPORTS_LOCALE_SWITCH,MULTI_WAKEWORDS_SUPPORTED,FLASH_BRIEFING,ARTHUR_TARGET,TIMERS_AND_ALARMS,SOUND_SETTINGS,CHANGE_NAME,SPEECH_RECOGNIZER_USS,REMINDERS,ACTIVE_AFTER_FRO,SUPPORTS_CONNECTED_HOME_CLOUD_ONLY,CUSTOM_ALARM_TONE,SUPPORTS_LOCALE,PERSISTENT_CONNECTION)
      2025-03-24 18:15:04.826  - info: alexa2.0 (989) Using cached smart home devices list from Mon Mar 24 2025 18:05:23 GMT+0100 (Mitteleuropäische Normalzeit)
      2025-03-24 18:15:05.828  - info: alexa2.0 (989) No smart home devices to query
      2025-03-24 18:15:07.777  - info: alexa2.0 (989) Subscribing to states...
      2025-03-24 18:15:07.779  - info: alexa2.0 (989) Deleting the following states: ["Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476","Smart-Home-Devices.0f312b76-25b6-4d4e-8a1e-a087cfbd7adc","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#enabled","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#delete","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.powerState","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#query","Smart-Home-Devices.03c64f0c-89dc-48d5-bf8e-ad01effa5476.#includeInAllQuery","Smart-Home-Devices.0f312b76-25b6-4d4e-8a1e-a087cfbd7adc.#enabled","Smart-Home-Devices.0f312b76-25b6-4d4e-8a1e-a087cfbd7adc.#delete","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65.#enabled","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65.#delete","Smart-Home-Devices.ff8af7b7-170e-4af6-9f34-f16f111dcd65.active","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a.#enabled","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a.#delete","Smart-Home-Devices.0cfcdabe-abf5-4726-be68-1ac7df85035a.active","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3.#enabled","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3.#delete","Smart-Home-Devices.ba1c49a7-8422-443a-b5dd-cfa4e5830eb3.active","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831.#enabled","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831.#delete","Smart-Home-Devices.15bcebab-6788-4a0a-87a1-569f0c766831.active","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150.#enabled","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150.#delete","Smart-Home-Devices.9f803c48-0949-40ed-8bf2-df757de7d150.active","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635.#enabled","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635.#delete","Smart-Home-Devices.67826c80-4fa7-438c-92a5-bc3f5dd6c635.active","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a.#enabled","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a.#delete","Smart-Home-Devices.daec1235-8b26-4e42-9d46-72e9ce66133a.active","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122.#enabled","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122.#delete","Smart-Home-Devices.357a4ca8-997d-424c-824d-5a66c4228122.active","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa.#enabled","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa.#delete","Smart-Home-Devices.987fac99-c50e-42dc-b402-75a1ba181daa.active","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3.#enabled","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3.#delete","Smart-Home-Devices.14378c60-50cc-4020-8a83-1436abbba3d3.active","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b.#enabled","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b.#delete","Smart-Home-Devices.fb339671-d78b-43c9-9a32-f0db6d49230b.active","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef.#enabled","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef.#delete","Smart-Home-Devices.fcb31177-cf3d-45bb-9a1a-465e780d71ef.active","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e.#enabled","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e.#delete","Smart-Home-Devices.c3cef993-5bab-4ec3-adb9-64eb595c2c1e.active","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049.#enabled","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049.#delete","Smart-Home-Devices.e96aa18b-fd21-458c-b630-5cee5e66a049.active","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0.#enabled","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0.#delete","Smart-Home-Devices.4e9dca5b-2797-4225-a348-38ffe8b717a0.active","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f.#enabled","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f.#delete","Smart-Home-Devices.ed039111-9733-43e9-8eff-a719e1c86e2f.active","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14.#enabled","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14.#delete","Smart-Home-Devices.f5f8a201-aa50-4f3d-9874-8a685e13be14.active","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f.#enabled","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f.#delete","Smart-Home-Devices.99a273c5-1182-475d-b0a7-7b31fa85c59f.active","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad.#enabled","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad.#delete","Smart-Home-Devices.1f5a6197-0fe4-4597-a6e1-10a61fc44aad.active","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c.#enabled","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c.#delete","Smart-Home-Devices.56090f9e-096c-4838-b090-5965ea4a6f3c.active","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d.#enabled","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d.#delete","Smart-Home-Devices.9c451cec-af42-4a53-af6f-38c0c130014d.active","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92.#enabled","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92.#delete","Smart-Home-Devices.4071e605-69da-41b0-b2f8-eeba325f6a92.active","Smart-Home-Devices.ea1d8e4c-5d48-454b-b61f-801664d05cd2.detectionState","Smart-Home-Devices.ea1d8e4c-5d48-454b-b61f-801664d05cd2.#query","Smart-Home-Devices.ea1d8e4c-5d48-454b-b61f-801664d05cd2.#includeInAllQuery","Smart-Home-Devices.0b992735-56a7-4d5b-a799-3ba9b5499d02.detectionState"]
      2025-03-24 18:15:09.690  - info: alexa2.0 (989) Alexa-Push-Connection (macDms = true) established. Disable Polling
      2025-03-24 18:15:23.622  - info: alexa2.0 (989) Initialization Done ...
      iob diag has finished.
        Thomas Braun Most Active @Locke3600 last edited by
        @locke3600
        Dann jag jetzt den
        iob fix
        drüber.
          Locke3600 @Thomas Braun last edited by Locke3600
          @Thomas-Braun
          iob fix :
          Brauch ich das?
          Your system is booting into 'graphical.target', which means that a user interface or desktop is available. Usually a server is running without a desktop to have more RAM available. Do you want to switch to 'multi-user.target'? (y/N)
            @locke3600
            Ja, du möchtest multi-user fahren.
              alles klar iob fix ist durch
                @locke3600
                Dann sollte jetzt auch ein
                iob diag
                an mindestens 2 Stellen anders aussehen.
                  ```bash
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                           Chassis: vm 🖴
                    Virtualization: kvm
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   18:43:47 up 32 min,  2 users,  load average: 0.27, 0.16, 0.11
                  CPU threads: 2
                  Operating System is the current Debian stable version codenamed 'bookworm'!
                                 Local time: Mon 2025-03-24 18:43:47 CET
                             Universal time: Mon 2025-03-24 17:43:47 UTC
                                   RTC time: Mon 2025-03-24 17:43:47
                                NTP service: active
                            RTC in local TZ: no
                  admin
                  HOME=/home/admin
                  js-controller is not running
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            8.3G        422M        7.5G        552K        671M        7.9G
                  Swap:           1.0G          0B        1.0G
                  Total:          9.3G        422M        8.5G
                           7941 M total memory
                            402 M used memory
                            416 M active memory
                            132 M inactive memory
                           7174 M free memory
                             86 M buffer memory
                            553 M swap cache
                            974 M total swap
                              0 M used swap
                            974 M free swap
                  top - 18:43:47 up 32 min,  2 users,  load average: 0.27, 0.16, 0.11
                  Tasks:  91 total,   1 running,  90 sleeping,   0 stopped,   0 zombie
                  %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   7941.2 total,   7174.6 free,    402.6 used,    640.1 buff/cache
                  MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7538.6 avail Mem
                    UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                  * iobroker.service loaded failed failed ioBroker Server
                  LOAD   = Reflects whether the unit definition was properly loaded.
                  ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                  SUB    = The low-level unit activation state, values depend on unit type.
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  tmpfs          tmpfs     795M  548K  794M   1% /run
                  /var:
                  622M    /var/
                  281M    /var/cache
                  274M    /var/cache/apt
                  198M    /var/cache/apt/archives
                  176M    /var/lib
                  19M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.368dc292.js.map
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Version table:
                  ioBroker Status
                  iobroker is not running on this host.
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  IoBroker            IoBroker (version: 6.0.11, hostname: IoBroker      , alive, uptime: 1471)
                  admin:          7.4.10
                  javascript:     8.8.3
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        4985
                  States:         3614
                  Pending Updates: 38
                  2025-03-24 18:38:18.790  - info: zigbee.0 (943) terminating
                  2025-03-24 18:38:18.791  - info: zigbee.0 (943) Terminated (NO_ERROR): Without reason
                  2025-03-24 18:38:18.794  - info: tr-064.0 (959) terminating
                  2025-03-24 18:38:18.795  - info: javascript.0 (890) terminating
                  2025-03-24 18:38:18.798  - info: hm-rega.0 (1019) terminating
                  2025-03-24 18:38:18.802  - info: denon.0 (1034) terminating
                  2025-03-24 18:38:18.803  - info: vis-2.0 (1064) terminating
                  2025-03-24 18:38:18.805  - info: cloud.0 (923) terminating
                  2025-03-24 18:38:18.805  - info: admin.0 (847) terminating
                  2025-03-24 18:38:18.806  - info: alexa2.0 (989) terminating
                  2025-03-24 18:38:18.937  - info: host.IoBroker instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:18.938  - info: host.IoBroker instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:18.938  - info: host.IoBroker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.030  - info: host.IoBroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.031  - info: host.IoBroker instance system.adapter.denon.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.031  - info: host.IoBroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.080  - info: host.IoBroker instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.081  - info: host.IoBroker instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.081  - info: host.IoBroker instance system.adapter.cloud.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.081  - info: host.IoBroker instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.105  - info: host.IoBroker instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.105  - info: host.IoBroker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.324  - info: host.IoBroker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                  2025-03-24 18:38:19.324  - info: host.IoBroker All instances are stopped.
                  2025-03-24 18:38:19.516  - info: host.IoBroker terminated
                    @locke3600
                    Dann bring das ganze Spiel noch auf
                    iob nodejs-update
                    und hau die anderen Updates (OS und ioBroker) noch drauf.
                      jetzt ist alles auf stand.
                      wen man weis wie ganz einfach😖
                      vielen dank schonmal.
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                               Chassis: vm 🖴
                        Virtualization: kvm
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       19:07:32 up 56 min,  2 users,  load average: 0.50, 0.26, 0.14
                      CPU threads: 2
                                     Local time: Mon 2025-03-24 19:07:33 CET
                                 Universal time: Mon 2025-03-24 18:07:33 UTC
                                       RTC time: Mon 2025-03-24 18:07:33
                                    NTP service: active
                                RTC in local TZ: no
                      admin
                      HOME=/home/admin
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.3G        447M        6.0G        561K        2.2G        7.9G
                      Swap:           1.0G          0B        1.0G
                      Total:          9.3G        447M        7.0G
                               7941 M total memory
                                426 M used memory
                                514 M active memory
                               1398 M inactive memory
                               5725 M free memory
                                159 M buffer memory
                               1927 M swap cache
                                974 M total swap
                                  0 M used swap
                                974 M free swap
                      top - 19:07:33 up 56 min,  2 users,  load average: 0.50, 0.26, 0.14
                      MiB Mem :   7941.2 total,   5725.4 free,    427.3 used,   2087.0 buff/cache
                      MiB Swap:    975.0 total,    975.0 free,      0.0 used.   7513.8 avail Mem
                      *** FILESYSTEM ***
                      /dev/sda1      ext4       97G  8.1G   84G   9% /
                      /var:
                      697M    /var/
                      355M    /var/cache
                      348M    /var/cache/apt
                      272M    /var/cache/apt/archives
                      176M    /var/lib
                      1.1G    /opt/iobroker/iobroker-data/
                      998M    /opt/iobroker/iobroker-data/files
                      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
                      24M     /opt/iobroker/iobroker-data/files/vis-2/customWidgets.js.map
                      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                      USB-Devices by-id:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/nodejs         v20.19.0
                      /usr/bin/node           v20.19.0
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      /usr/bin/corepack       0.31.0
                      nodejs:
                        Installed: 20.19.0-1nodesource1
                        Candidate: 20.19.0-1nodesource1
                        Version table:
                       *** 20.19.0-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.18.3-1nodesource1 1001
                           20.18.2-1nodesource1 1001
                           20.18.1-1nodesource1 1001
                           20.18.0-1nodesource1 1001
                           20.17.0-1nodesource1 1001
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      js-controller:  7.0.6
                      admin:          7.6.3
                      javascript:     8.8.3
                      Adapter State
                      + instance is alive
                      Adapter    "admin"        : 7.6.3    , installed 7.6.3
                      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                      Controller "js-controller": 7.0.6    , installed 7.0.6
                      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                      Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Objects and States
                      Objects:        4985
                      States:         3614
                      Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          13432      1/systemd
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          52530      10457/sshd: /usr/sb
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          13434      1/systemd
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          52532      10457/sshd: /usr/sb
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          13433      1/systemd
                      udp6       0      0 :::111                  :::*                                0          13435      1/systemd
                        @locke3600 sagte in Update auf node 20 erstellen von standart user:
                        Thema Basics...
                        81.1k
                        5245
