    4. js-controller updaten
      Thomas Braun Most Active @Erich 1 last edited by
      @erich-1 sagte in js-controller updaten:
      Wie bekomme ich die Langversion?
      Die läuft automatisch zuerst durch.
        Erich 1 @Thomas Braun last edited by
        @thomas-braun Das ist alles, was bei ssh kommt::
        erich@debian-iobroker:~$ ssh
        usage: ssh [-46AaCfGgKkMNnqsTtVvXxYy] [-B bind_interface]
                   [-b bind_address] [-c cipher_spec] [-D [bind_address:]port]
                   [-E log_file] [-e escape_char] [-F configfile] [-I pkcs11]
                   [-i identity_file] [-J [user@]host[:port]] [-L address]
                   [-l login_name] [-m mac_spec] [-O ctl_cmd] [-o option] [-p port]
                   [-Q query_option] [-R address] [-S ctl_path] [-W host:port]
                   [-w local_tun[:remote_tun]] destination [command]
          @erich-1
          Dann bist du doch schon auf dem Host angemeldet...
            @thomas-braun Und wie jetzt weiter?
              @erich-1
              iob diag
              aufrufen, Ausgabe hier rein kopieren.
                @thomas-braun Ist es das?
                Copy text starting here:
                ```bash
                                        v.2025-02-23
                   Static hostname: debian-iobroker
                         Icon name: computer-vm
                           Chassis: vm
                    Virtualization: kvm
                  Operating System: Debian GNU/Linux 11 (bullseye)
                            Kernel: Linux 5.10.0-23-amd64
                      Architecture: x86-64
                Installation:           kvm
                Kernel:                 x86_64
                Userland:               64 bit
                Timezone:               Europe/Berlin (CET, +0100)
                User-ID:                1000
                Display-Server:         false
                Boot Target:            graphical.target
                Pending OS-Updates:     144
                Pending iob updates:    13
                Nodejs-Installation:
                /usr/bin/nodejs         v18.16.0
                /usr/bin/node           v18.16.0
                /usr/bin/npm            9.5.1
                /usr/bin/npx            9.5.1
                /usr/bin/corepack       0.17.0
                Recommended versions are nodejs 20.19.0 and npm 10.8.2
                nodeJS installation is correct
                MEMORY:
                Mem:            3.9G        1.4G        1.9G        0.0K        585M        2.2G
                Swap:           974M          0B        974M
                Total:          4.9G        1.4G        2.9G
                Active iob-Instances:   15
                Active repo(s): stable
                ioBroker Core:          js-controller           4.0.24
                                        admin                   7.4.10
                Objects type: jsonl
                States  type: jsonl
                + system.adapter.admin.0                  : admin                 : debian-iobroker                          -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.web.0                    : web                   : debian-iobroker                          - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                Objects:                3678
                States:                 3092
                Size of iob-Database:
                28M     /opt/iobroker/iobroker-data/objects.jsonl
                4.8M    /opt/iobroker/iobroker-data/states.jsonl
                Unknown release codenamed 'bullseye'. Please check yourself if the Operating System is actively maintained.
                === Mark text until here for copying ===
                  @erich-1
                  Nein, das ist nur die Zusammenfassung.
                    nodejs v18.16.0
                    Alles total veraltet...
                      @thomas-braun Ja, deswegen wollte ich ja alles updaten ...
                        @erich-1
                        Dann fang im Keller an.
                        Zuerst das OS, dann nodejs, dann den ioBroker.
                          @thomas-braun Leichter gesagt als getan, Ich bin diesbezüglich ein absoluter Laie ...
                            @erich-1
                            Keller aufräumen:
                            https://forum.iobroker.net/topic/65655/upgrade-von-debian-11-bullseye-auf-12-bookworm
                              @thomas-braun Ich bin im Moment schon überfordert, um überhaupt auf die Debian-Installation zu kommen.
                              Das wird ein langwieriges Unterfangen, bis das alles wieder läuft.
                                Homoran Global Moderator Administrators @Erich 1 last edited by
                                da bist du doch schon drauf!
                                hast ja das iob diag da gestartet
                                  Joh, je länger man das schleifen lässt desto aufwändiger wird die Renovierung. Ist keine neue Erkenntnis.
                                    Erich 1 @Homoran last edited by
                                    @homoran said in js-controller updaten:
                                    OK, was muss ich da dann eingeben?
                                      Da musst du dich schon einlesen.
                                      Link zur Anleitung hatte ich dir ja schon gegeben.
                                        @thomas-braun Hab jetzt mal einiges versucht:
                                        ========== Start marking the full check here ===========
                                        ```bash
                                        Script v.2025-02-23
                                        *** BASE SYSTEM ***
                                                   Chassis: vm
                                            Virtualization: kvm
                                        OS is similar to:
                                        model name      : Common KVM processor
                                        Docker          : false
                                        Virtualization  : kvm
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         21:05:41 up 33 min,  2 users,  load average: 0.93, 0.82, 0.97
                                        CPU threads: 2
                                        *** LIFE CYCLE STATUS ***
                                        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
                                        This system needs to be REBOOTED!
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Mon 2025-03-24 21:05:41 CET
                                                   Universal time: Mon 2025-03-24 20:05:41 UTC
                                                         RTC time: Mon 2025-03-24 20:05:42
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        erich
                                        HOME=/home/erich
                                        GROUPS=erich cdrom floppy sudo audio dip video plugdev netdev iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout audio video plugdev
                                        *** DISPLAY-SERVER SETUP ***
                                        Desktop:
                                        Terminal:       tty
                                        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                                        *** MEMORY ***
                                        Mem:            3.9G        1.5G        555M        0.0K        1.9G        2.2G
                                        Swap:           974M        2.0M        972M
                                        Total:          4.9G        1.5G        1.5G
                                                 3919 M total memory
                                                 1468 M used memory
                                                  466 M active memory
                                                 2626 M inactive memory
                                                  555 M free memory
                                                   73 M buffer memory
                                                 1822 M swap cache
                                                  974 M total swap
                                                    2 M used swap
                                                  972 M free swap
                                        top - 21:05:41 up 33 min,  2 users,  load average: 0.93, 0.82, 0.97
                                        Tasks: 104 total,   2 running, 102 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :   3919.7 total,    555.2 free,   1468.4 used,   1896.2 buff/cache
                                        MiB Swap:    975.0 total,    972.5 free,      2.5 used.   2179.4 avail Mem
                                        *** FAILED SERVICES ***
                                        0 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        udev           devtmpfs  1.9G     0  1.9G   0% /dev
                                        tmpfs          tmpfs     392M  516K  392M   1% /run
                                        /dev/sda1      ext4       39G  9.4G   27G  26% /
                                        tmpfs          tmpfs     2.0G     0  2.0G   0% /dev/shm
                                        tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
                                        tmpfs          tmpfs     392M     0  392M   0% /run/user/1000
                                        [Mon Mar 24 20:32:25 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
                                        [Mon Mar 24 20:32:25 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
                                        Show mounted filesystems:
                                        TARGET SOURCE    FSTYPE OPTIONS
                                        /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
                                        /var:
                                        834M    /var/
                                        449M    /var/log
                                        433M    /var/log/journal/4782ab7b08f9440cb38008c40dbc892b
                                        223M    /var/cache
                                        Archived and active journals take up 40.0M in the file system.
                                        /opt/iobroker/backups:
                                        2.6G    /opt/iobroker/backups/
                                        /opt/iobroker/iobroker-data:
                                        1.7G    /opt/iobroker/iobroker-data/
                                        855M    /opt/iobroker/iobroker-data/backupDir
                                        764M    /opt/iobroker/iobroker-data/files
                                        617M    /opt/iobroker/iobroker-data/files/javascript.admin
                                        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                                        35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                                        24M     /opt/iobroker/iobroker-data/objects.jsonl
                                        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                                        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                                        8.6M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        Zigbee Network Settings on your coordinator/in nvbackup are:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        To unmask the settings run 'iob diag --unmask'
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v18.17.1
                                        /usr/bin/node           v18.17.1
                                        /usr/bin/npm            9.6.7
                                        /usr/bin/npx            9.6.7
                                        /usr/bin/corepack       0.18.0
                                        nodejs:
                                          Installed: 18.17.1-deb-1nodesource1
                                          Candidate: 18.17.1-deb-1nodesource1
                                          Version table:
                                         *** 18.17.1-deb-1nodesource1 500
                                                500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
                                                100 /var/lib/dpkg/status
                                             12.22.12~dfsg-1~deb11u6 500
                                                500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
                                             12.22.12~dfsg-1~deb11u4 500
                                                500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        debian-iobroker     debian-iobroker (version: 7.0.6, hostname: debian-iobroker, alive, uptime: 692)
                                        Core adapters versions
                                        js-controller:  7.0.6
                                        admin:          7.6.3
                                        javascript:     8.8.3
                                        nodejs modules from github:     0
                                        Adapter State
                                        + system.adapter.backitup.0               : backitup              : debian-iobroker                          -  enabled
                                          system.adapter.birthdays.0              : birthdays             : debian-iobroker                          -  enabled
                                        + system.adapter.cloud.0                  : cloud                 : debian-iobroker                          -  enabled
                                          system.adapter.devices.0                : devices               : debian-iobroker                          - disabled
                                        + system.adapter.discovery.0              : discovery             : debian-iobroker                          -  enabled
                                        + system.adapter.email.0                  : email                 : debian-iobroker                          -  enabled
                                          system.adapter.flot.0                   : flot                  : debian-iobroker                          - disabled
                                        + system.adapter.fritzdect.0              : fritzdect             : debian-iobroker                          -  enabled
                                        + system.adapter.fullybrowser.0           : fullybrowser          : debian-iobroker                          -  enabled
                                          system.adapter.habpanel.0               : habpanel              : debian-iobroker                          - disabled
                                          system.adapter.heatingcontrol.0         : heatingcontrol        : debian-iobroker                          - disabled
                                        + system.adapter.history.0                : history               : debian-iobroker                          -  enabled
                                        + system.adapter.javascript.0             : javascript            : debian-iobroker                          -  enabled
                                        + system.adapter.javascript.1             : javascript            : debian-iobroker                          -  enabled
                                        + system.adapter.mqtt.0                   : mqtt                  : debian-iobroker                          -  enabled, port: 1883, bind: 0.0.0.0
                                          system.adapter.netatmo-crawler.0        : netatmo-crawler       : debian-iobroker                          -  enabled
                                          system.adapter.openweathermap.0         : openweathermap        : debian-iobroker                          -  enabled
                                        + system.adapter.shelly.0                 : shelly                : debian-iobroker                          -  enabled, port: 1882, bind: 0.0.0.0
                                        + system.adapter.sonoff.0                 : sonoff                : debian-iobroker                          -  enabled, port: 1886, bind: 0.0.0.0
                                        + system.adapter.tuya.0                   : tuya                  : debian-iobroker                          -  enabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : debian-iobroker                          - disabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : debian-iobroker                          - disabled
                                          system.adapter.vis-rgraph.0             : vis-rgraph            : debian-iobroker                          -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : debian-iobroker                          - disabled
                                          system.adapter.vis.0                    : vis                   : debian-iobroker                          -  enabled
                                        + instance is alive
                                        ioBroker-Repositories
                                        │ (index) │   name   │                           url                           │ auto upgrade │
                                        │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
                                        │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
                                        Upgrade policy: none
                                        Installed ioBroker-Adapters
                                        Used repository: stable
                                        Adapter    "admin"        : 7.6.3    , installed 7.6.3
                                        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                        Adapter    "birthdays"    : 3.1.0    , installed 3.1.0
                                        Adapter    "email"        : 1.3.1    , installed 1.3.1
                                        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                                        Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
                                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                                        Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
                                        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                        Controller "js-controller": 7.0.6    , installed 7.0.6
                                        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                        Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                        Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                        Adapter    "shelly"       : 8.5.1    , installed 8.5.1
                                        Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                        Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                        Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                                        Adapter    "web"          : 7.0.8    , installed 7.0.8
                                        Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                        Objects and States
                                        Objects:        3719
                                        States:         3066
                                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                                        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          10984      1/systemd
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          37313      10130/sshd: /usr/sb
                                        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       66915      21512/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       67113      21557/io.sonoff.0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       65840      21326/iobroker.js-c
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       65833      21326/iobroker.js-c
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          10992      1/systemd
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       65966      21344/io.admin.0
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          37324      10130/sshd: /usr/sb
                                        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       67053      21542/io.shelly.0
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12495      342/dhclient
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10987      1/systemd
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       67232      21572/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       67233      21572/io.tuya.0
                                        udp6       0      0 :::111                  :::*                                0          10997      1/systemd
                                        2025-03-24 20:55:46.062  - error: tuya.0 (21572) Cloud login failed: Incorrect account ID or password
                                        2025-03-24 20:55:46.062  - error: tuya.0 (21572) Please check your cloud credentials in the adapter configuration!
                                        2025-03-24 20:55:46.062  - warn: tuya.0 (21572) App cloud connection failed. No sync possible
                                        2025-03-24 20:57:32.476  - info: admin.0 (21344) ==> Connected system.user.admin from ::ffff:192.168.178.91
                                        2025-03-24 20:57:56.747  - info: admin.0 (21344) <== Disconnect system.user.admin from ::ffff:192.168.178.91 javascript
                                        2025-03-24 20:59:08.140  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connection closed: timeout
                                        2025-03-24 20:59:08.308  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connected with secret 1742846348307_1509
                                        2025-03-24 20:59:08.333  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#" with regex /^ESP_Easy-03_Wetterstation\..*/
                                        2025-03-24 20:59:08.336  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#"  with regex /^mqtt\.0\.ESP_Easy-03_Wetterstation\..*/
                                        2025-03-24 20:59:08.536  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] publishOnSubscribe send all known states
                                        2025-03-24 21:00:17.029  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 21695
                                        2025-03-24 21:00:18.865  - info: netatmo-crawler.0 (21695) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 7.0.6
                                        2025-03-24 21:00:18.911  - info: netatmo-crawler.0 (21695) Getting data for stationid:70:ee:50:1b:2f:26
                                        2025-03-24 21:00:22.311  - info: netatmo-crawler.0 (21695) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                        2025-03-24 21:00:22.857  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 having pid 21695 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-03-24 21:05:17.015  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 in version "0.8.1" started with pid 21786
                                        2025-03-24 21:05:20.937  - info: netatmo-crawler.0 (21786) starting. Version 0.8.1 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v18.17.1, js-controller: 7.0.6
                                        2025-03-24 21:05:21.131  - info: netatmo-crawler.0 (21786) Getting data for stationid:70:ee:50:1b:2f:26
                                        2025-03-24 21:05:21.739  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connection closed: timeout
                                        2025-03-24 21:05:22.025  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] connected with secret 1742846722025_2942
                                        2025-03-24 21:05:22.041  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#" with regex /^ESP_Easy-03_Wetterstation\..*/
                                        2025-03-24 21:05:22.041  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] subscribes on "ESP_Easy-03 Wetterstation/#"  with regex /^mqtt\.0\.ESP_Easy-03_Wetterstation\..*/
                                        2025-03-24 21:05:22.242  - info: mqtt.0 (21512) Client [ESP_Easy-03_Wetterstation_0] publishOnSubscribe send all known states
                                        2025-03-24 21:05:23.286  - info: netatmo-crawler.0 (21786) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                                        2025-03-24 21:05:23.851  - info: host.debian-iobroker instance system.adapter.netatmo-crawler.0 having pid 21786 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                            @thomas-braun Hab das mal gemacht, der ioBroker läuft wieder, aber die VIS ist nicht erreichbar. Weder über die Instanz im ioBroker und auch nicht über den Fully-Browser ...
                                            2631
