    4. go2rtc installieren und einrichten
      liv-in-sky @Peter Haller last edited by
      @peter-haller
      weiß nicht ob's hilft
      ich mußte bei meiner cam im iframe widget - kein sandkasten anklicken 😞 🙂
      Peter Haller 1 Reply Last reply Reply Quote 0
      • Peter Haller
        Peter Haller @wendy2702 last edited by wendy2702
        @wendy2702 said in go2rtc installieren und einrichten:
        log: level: debug api: trace exec: debug ngrok: info rtsp: warn streams: error webrtc: fatal
        Streams Add Config Log Net ☀️
        Time 	Level 	Message
        17:52:24,200	info	go2rtc version=1.9.9 platform=linux/arm revision=fa580c5
        17:52:24,201	debug	build version=go1.24.1 vcs.time=2025-03-10T02:51:40Z
        17:52:24,202	info	config path=/usr/local/bin/go2rtc/go2rtc.yaml
        17:52:24,202	trace	[api] register path path=/
        17:52:24,202	trace	[api] register path path=/api
        17:52:24,202	trace	[api] register path path=/api/config
        17:52:24,202	trace	[api] register path path=/api/exit
        17:52:24,202	trace	[api] register path path=/api/restart
        17:52:24,202	trace	[api] register path path=/api/log
        17:52:24,202	trace	[api] register path path=/api/ws
        17:52:24,203	trace	[api] register path path=/api/streams
        17:52:24,203	trace	[api] register path path=/api/streams.dot
        17:52:24,203	info	[api] listen addr=:1984
        17:52:24,205	trace	[api] register path path=/api/webrtc
        17:52:24,205	trace	[api] register path path=/api/frame.mp4
        17:52:24,205	trace	[api] register path path=/api/stream.mp4
        17:52:24,205	trace	[api] register path path=/api/stream.m3u8
        17:52:24,207	trace	[api] register path path=/api/hls/playlist.m3u8
        17:52:24,207	trace	[api] register path path=/api/hls/segment.ts
        17:52:24,207	trace	[api] register path path=/api/hls/init.mp4
        17:52:24,207	trace	[api] register path path=/api/hls/segment.m4s
        17:52:24,208	trace	[api] register path path=/api/frame.jpeg
        17:52:24,208	trace	[api] register path path=/api/stream.mjpeg
        17:52:24,208	trace	[api] register path path=/api/stream.ascii
        17:52:24,208	trace	[api] register path path=/api/stream.y4m
        17:52:24,209	trace	[api] register path path=/static
        17:52:24,209	trace	[api] register path path=/streams
        17:52:24,209	trace	[api] register path path=/stream/
        17:52:24,209	trace	[api] register path path=/api/hass
        17:52:24,209	trace	[api] register path path=/onvif/
        17:52:24,210	trace	[api] register path path=/api/onvif
        17:52:24,210	trace	[api] register path path=/api/webtorrent
        17:52:24,210	trace	[api] register path path=/api/stream.flv
        17:52:24,211	trace	[api] register path path=/api/ffmpeg
        17:52:24,211	trace	[api] register path path=/api/ffmpeg/devices
        17:52:24,211	trace	[api] register path path=/api/ffmpeg/hardware
        17:52:24,211	trace	[api] register path path=/api/stream
        17:52:24,212	trace	[api] register path path=/api/dvrip
        17:52:24,212	trace	[api] register path path=/api/stream.ts
        17:52:24,212	trace	[api] register path path=/api/stream.aac
        17:52:24,212	trace	[api] register path path=/api/roborock
        17:52:24,213	trace	[api] register path path=/api/homekit
        17:52:24,213	trace	[api] register path path=/api/ring
        17:52:24,213	trace	[api] register path path=/api/nest
        17:52:24,213	trace	[api] register path path=/api/gopro
        17:52:24,213	trace	[api] register path path=/api/v4l2
        17:52:24,213	trace	[api] register path path=/api/stack
        17:52:25,546	trace	[api] GET / 192.168.10.77:57236
        17:52:25,598	trace	[api] GET /main.js 192.168.10.77:57236
        17:52:25,631	trace	[api] GET /api 192.168.10.77:57236
        17:52:25,646	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:26,639	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:27,640	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:28,628	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:29,637	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:30,633	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:31,194	trace	[api] GET /stream.html?src=Kamera1 192.168.10.77:57237
        17:52:31,252	trace	[api] GET /video-stream.js 192.168.10.77:57237
        17:52:31,278	trace	[api] GET /video-rtc.js 192.168.10.77:57237
        17:52:31,299	trace	[api] GET /api/ws?src=Kamera1 192.168.10.77:57240
        17:52:31,423	trace	[api] ws msg type=webrtc/offer
        17:52:31,427	trace	[api] ws msg type=mse
        17:52:31,448	trace	[api] ws msg type=webrtc/candidate
        17:52:31,504	trace	[api] ws msg type=webrtc/candidate
        17:52:37,320	trace	[api] GET /stream.html?src=Kamera1 192.168.10.77:57241
        17:52:52,791	trace	[api] GET / 192.168.10.77:57237
        17:52:52,897	trace	[api] GET /main.js 192.168.10.77:57237
        17:52:52,950	trace	[api] GET /api 192.168.10.77:57237
        17:52:52,986	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:53,970	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:54,948	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:55,948	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:56,952	trace	[api] GET /api/streams 192.168.10.77:57237
        17:52:57,087	trace	[api] GET /log.html 192.168.10.77:57237
        17:52:57,137	trace	[api] GET /main.js 192.168.10.77:57237
        17:52:57,171	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:02,172	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:02,963	trace	[api] GET /log.html 192.168.10.77:57244
        17:53:07,230	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:12,175	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:17,176	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:22,168	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:27,180	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:32,174	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:37,169	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:42,181	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:47,171	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:52,169	trace	[api] GET /api/log 192.168.10.77:57237
        17:53:57,178	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:02,177	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:07,173	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:12,170	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:17,194	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:22,169	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:27,180	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:32,177	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:38,282	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:43,021	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:48,204	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:53,033	trace	[api] GET /api/log 192.168.10.77:57237
        17:54:58,057	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:03,023	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:08,032	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:13,028	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:18,033	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:23,028	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:28,024	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:33,031	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:38,022	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:42,378	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:47,185	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:53,032	trace	[api] GET /api/log 192.168.10.77:57237
        17:55:58,034	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:03,033	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:08,031	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:13,035	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:18,325	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:23,029	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:28,031	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:33,026	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:38,028	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:43,031	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:48,022	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:53,031	trace	[api] GET /api/log 192.168.10.77:57237
        17:56:58,028	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:03,023	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:08,034	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:13,023	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:18,026	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:23,022	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:28,028	trace	[api] GET /api/log 192.168.10.77:57237
        17:57:33,029	trace	[api] GET /api/log 192.168.10.77:57237
        17:58:16,049	trace	[api] GET /api/log 192.168.10.77:57237
        17:59:16,037	trace	[api] GET /api/log 192.168.10.77:57237
        17:59:16,639	trace	[api] GET / 192.168.10.77:57285
        17:59:16,776	trace	[api] GET /main.js 192.168.10.77:57285
        17:59:16,877	trace	[api] GET /api 192.168.10.77:57285
        17:59:17,128	trace	[api] GET /api/streams 192.168.10.77:57285
        17:59:17,851	trace	[api] GET /api/streams 192.168.10.77:57285
        17:59:18,860	trace	[api] GET /api/streams 192.168.10.77:57285
        17:59:19,344	trace	[api] GET /stream.html?src=Kamera1&mode=webrtc,mse,hls,mjpeg 192.168.10.77:57285
        17:59:19,430	trace	[api] GET /video-stream.js 192.168.10.77:57285
        17:59:19,505	trace	[api] GET /video-rtc.js 192.168.10.77:57285
        17:59:19,615	trace	[api] GET /api/ws?src=Kamera1 192.168.10.77:57288
        17:59:19,703	trace	[api] ws msg type=mse
        17:59:19,715	trace	[api] ws msg type=webrtc/offer
        17:59:19,744	trace	[api] ws msg type=webrtc/candidate
        17:59:19,745	trace	[api] ws msg type=webrtc/candidate
        17:59:19,746	trace	[api] ws msg type=webrtc/candidate
        17:59:19,748	trace	[api] ws msg type=webrtc/candidate
        17:59:22,467	trace	[api] GET /stream.html?src=Kamera1&mode=webrtc,mse,hls,mjpeg 192.168.10.77:57285
        17:59:22,535	trace	[api] GET /video-stream.js 192.168.10.77:57285
        17:59:22,555	trace	[api] GET /video-rtc.js 192.168.10.77:57285
        17:59:22,615	trace	[api] GET /api/ws?src=Kamera1 192.168.10.77:57289
        17:59:22,665	trace	[api] ws msg type=mse
        17:59:22,677	trace	[api] ws msg type=webrtc/offer
        17:59:22,711	trace	[api] ws msg type=webrtc/candidate
        17:59:22,712	trace	[api] ws msg type=webrtc/candidate
        17:59:22,765	trace	[api] ws msg type=webrtc/candidate
        17:59:23,741	trace	[api] GET / 192.168.10.77:57290
        17:59:28,346	trace	[api] GET /stream.html?src=Kamera1&mode=webrtc,mse,hls,mjpeg 192.168.10.77:57293
        18:00:14,682	trace	[api] GET /favicon.ico 192.168.10.77:57285
        18:00:15,119	trace	[api] GET /api/streams 192.168.10.77:57299
        18:00:16,044	trace	[api] GET /api/log 192.168.10.77:57237
        18:00:16,206	trace	[api] GET /api/streams 192.168.10.77:57299
        18:00:16,288	trace	[api] GET /log.html 192.168.10.77:57299
        18:00:16,378	trace	[api] GET /main.js 192.168.10.77:57299
        18:00:16,423	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:21,521	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:21,754	trace	[api] GET /log.html 192.168.10.77:57300
        18:00:26,551	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:31,743	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:36,890	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:41,930	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:46,948	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:51,978	trace	[api] GET /api/log 192.168.10.77:57299
        18:00:56,976	trace	[api] GET /api/log 192.168.10.77:57299
        18:01:02,066	trace	[api] GET /api/log 192.168.10.77:57299
        18:01:07,084	trace	[api] GET /api/log 192.168.10.77:57299
        Die EInstellung im Browser hat auch nicht geändert. Ton ist da vom Stream Videobild ist schwarz.
        MOD EdIT: LOG in Code Tags gesetzt
        • Peter Haller
          Peter Haller @liv-in-sky last edited by
          @liv-in-sky Danke für deinen Vorschlag. Auch dieser hat leider nicht geholfen. Das einzige was passiert ist das er den RealPlayer öffnen will und dieser sich dann gnadenlos aufhägt. Nur noch über den Taskmanager u killen.
          Gruß Peter
            @peter-haller hört sich seltsam an - warum geht der realplayer auf ? kannst du den ton an der cam deaktivieren ?
            • Peter Haller
              @liv-in-sky Hallo tja wenn ich das wüsste warum der realplayer aufgeht 😉 Der geht nur auf wenn ich das ganze in die VIS einbinden will. Wenn ich den Stream im Browser direkt aufrufe dann nicht. Dann hab ich das offenen Streamfenster mit ton und schwarzem Bild. Hier kann ich aber den Ton über das Lautsprechersymbol ein und ausschalten.
              Gruß Peter
              • werner2000x
                werner2000x @wendy2702 last edited by
                @wendy2702 Ich habe es selbst geschafft.
                Nachdem ich go2rtc auf meinem raspi installiert habe, kann ich die webseite mit http://raspi:1984 aufrufen und dort die aqara camera eintragen mit z.B. rtsp://user:pass@IP:8554/1080p
                Dann bekomme ich eine url zum einbinden z.B. in VIS.
                Ich brauch jedoch auch einen Snapshot der Camera um z.B. ein Klingelbild zu generieren. Da habe ich in den Konfig von go2rtc noch nicht gefunden.
                  @peter-haller sagte in go2rtc installieren und einrichten:
                  Gruß Peter
                  leider bin ich keine hilfe - habe selber auch noch eine cam, die mir ärger macht - ich habe mal mit ffmpeg rumgespielt, da ging dann etwas mehr - leider habe ich zu wenig zeit, um viel zu testen
                  mein yaml eintrag hat dann z.b. so ausgesehen
                  ffmpeg:rtsp://admin:xxxxxx@192.168.178.193:554/12
                  vielleicht kannst du damit was erreichen
                  • Peter Haller
                    Peter Haller @liv-in-sky last edited by Peter Haller
                    @liv-in-sky said in go2rtc installieren und einrichten:
                    ffmpeg:rtsp:
                    Ok danke das war der HInweis. Nun hab ich den strem mit dem Bild und Ton: Doch wenn ich jetzt den Link in die VIS einbinde in einem IFrame dann bleibt der Frame noch grau. Der Stream wird nicht geladen. 8e3f2305-d47d-4637-93fe-e183babfd07e-image.png Der Link dazu ist der http://192.168.10.7:1984/stream.html?src=Kamera1
                    So sieht es in der Vis aus:
                    Danke und Gruß Peter
                    wendy2702 liv-in-sky 4 Replies Last reply Reply Quote 0
                    • wendy2702
                      wendy2702 @Peter Haller last edited by
                      @peter-haller so sieht der im Editor aus. Nicht in der VIS=Runtime, da mal geschaut?
                      • bahnuhr
                        bahnuhr Forum Testing Most Active @wendy2702 last edited by
                        @wendy2702 sagte in go2rtc installieren und einrichten:
                        Im edit und auch in run sieht man das Bild.
                        • wendy2702
                          wendy2702 @bahnuhr last edited by
                          @bahnuhr kann ich nicht bestätigen.
                          Hatte gerade mit VIS 1 oft das Problem das es im Editor nur grau blieb.
                          Ich vermisse aber immer noch die Ausgabe der Browser Konsole beim Aufruf des Videos im Widget.
                          • bahnuhr
                            Ist bei mir meistens auch so.
                            Nur halt nicht bei den go2rtc streams.
                            Diese werden im edit als auch im run angezeigt.
                            Bin auch auf vis1 (und da bleibe ich auch).
                            • haselchen
                              haselchen Most Active @bahnuhr last edited by
                              @wendy2702
                              Kann @bahnuhr‘s Aussage bestätigen.
                              Go2RTC Streams werden sowohl als auch angezeigt .
                              Eventuell kriegt der TE noch ne andere Stream URL raus (ONVIF Manager) , die besser mit der VIS kooperiert.
                                liv-in-sky @Peter Haller last edited by liv-in-sky
                                ffmpeg:rtsp:
                                wie erwähnt - ich habe auch diverse probleme
                                meine streams werden weder im vis-editor noch in der runtime in chrome angezeigt - aber ich nutze die vis auf echo 15 mit fully-browser - da werden sie dann in der vis-runtime angezeigt - warum - keine ahnung
                                im edge browser wird es im editor und der runtime angezeigt
                                im firefox nur in der runtime - nicht im editor
                                • wendy2702
                                  @peter-haller Steht deine Kamera hier mit in der Liste: https://www.ispyconnect.com/de/camera/hiseeu
                                  Bitte zeige doch mal die Ausgabe der Browser Konsole wenn du den Stream direkt auf dr go2RTC Seite öffnest.
                                  • Peter Haller
                                    @wendy2702 Die Liste von Ispy muss ich noch durschauen:
                                    Firefox:
                                    Edge:
                                    Chrome:
                                    • wendy2702
                                      @peter-haller Also bekommst du jetzt ein Bild aus go2RTC wie es aussieht.
                                      werner2000x Peter Haller 2 Replies Last reply Reply Quote 0
                                      • werner2000x
                                        werner2000x @wendy2702 last edited by werner2000x
                                        @wendy2702 Ich habe auch go2rtc installiert und bekomme im Browser ein Bild angezeigt mit http://IP_Raspi:1984/api/frame.jpeg?src=Haustuer1080
                                        Doch wie komme ich an die Datei heran um sie mit pushover zu versenden?
                                        wendy2702 Jey Cee 2 Replies Last reply Reply Quote 0
                                        • wendy2702
                                          wendy2702 @werner2000x last edited by
                                          @werner2000x Ich hole mir die Snapshots direkt von der Kamera. Die meisten Kameras stellen Bilder direkt zur Verfügung.
                                          • Jey Cee
                                            Jey Cee Developer @werner2000x last edited by
                                            @werner2000x sagte in go2rtc installieren und einrichten:
                                            Such mal im Forum nach Bild per Telegram verschicken, da gibt es einige Themen, die meisten beinhalten auch eine Anleitung/Script/Blockly um ein Bild von einer URL zu holen.
                                            160
                                            35591
