    5. PV Überschuss nutzen um 1,5KW und 3,0KW Heizstab zu schalten
      Spidermike @paul53 last edited by
      so
          <block type="logic_compare" id="UQv[Rz^5f:#)fAqUWMk-">
            <field name="OP">NEQ</field>
              <block type="variables_get" id="K^Cr`lcToTn%,N+kEZ[s">
                <field name="VAR" id="9y5$f~sG5n39o=TlsnI_">heizstab2</field>
              <block type="get_value" id="3Yr2{GacZb_mhZ4^?jF*">
                <field name="OID">shelly.1.shelly1g3#3000W#1.Relay0.Switch</field>
          <block type="control" id="D/q[T[3mSbu1ysV{VPjV">
              <block type="variables_get" id=",[uX/yd,c(y.Gx~g[U#y">
          <block type="debug" id="KS{*7I7)yzeN1jB=6;V/">
            <field name="Severity">info</field>
            <value name="TEXT">
              <shadow type="text" id="KS:4~UZ{vccU~iTf-V_u">
              <block type="text_join" id="5Y{~PghQ={@pOvAT^46;" inline="false">
                <mutation items="8"></mutation>
                <value name="ADD0">
                  <block type="text" id="`0;1s$3.TKPa^lIjw~W4">
                    <field name="TEXT">Einspeisung:</field>
                <value name="ADD1">
                  <block type="get_value" id="8z^$PnY|MP{gr{A#bPi.">
                    <field name="OID">plenticore.0.devices.local.ToGrid_P</field>
                <value name="ADD2">
                  <block type="text" id="nlvwHcKhv@po6U57sDxA">
                    <field name="TEXT"> Netz-Bezug:</field>
                <value name="ADD3">
                  <block type="get_value" id="EL:l7T_?7p#z;7DZZs6`">
                    <field name="OID">plenticore.0.devices.local.HomeGrid_P</field>
                <value name="ADD4">
                  <block type="text" id="8R5CWhYs_y*4;ljCHQcR">
                    <field name="TEXT"> Heiz-Stufe:</field>
                <value name="ADD5">
                  <block type="variables_get" id="(Oc3%bWXeM6!16qd]K7}">
                    <field name="VAR" id="(au?)v#|.A3h~W0?i*.n">heizstufe</field>
                <value name="ADD6">
                  <block type="text" id="Y_gY|k^^bh44qU{VA%^z">
                    <field name="TEXT"> Boilertemp:</field>
                <value name="ADD7">
                  <block type="get_value" id="s783,ESop@{W@u@|4o?r">
                    <field name="OID">mqtt.0.ESP_Easy.Sensor_1.temperature_oben</field>
        paul53 @Spidermike last edited by
        @spidermike sagte: so
        Lässt sich nicht importieren!
        Zeige den unteren Blockly-Ausschnitt als Bild.
          S paul53 2 Replies Last reply Reply Quote 0
            Spidermike @Spidermike last edited by
              paul53 @Spidermike last edited by paul53
              @spidermike
              Den Debug-Block unter das Schalten von Heizstab1 schieben, denn der schaltet bei jeder Stufenänderung.
              Der gesteuerte Shelly für Heizstab1 ist offenbar falsch.
                Spidermike @paul53 last edited by Spidermike
                ja hatte ich schon gesehen und gegen den anderen Shelly geändert.
                ich sehe bei mir im script keine Geräte sondern nur den Datenpunkt
                komisch nur das er in deinen Bildern mir das Gerät sprich den Shelly anzeigt sonst wäre es mir nicht aufgefallen
                  @spidermike
                  hier noch ein versuch
                  <block xmlns="https://developers.google.com/blockly/xml" type="debug" id="KS{*7I7)yzeN1jB=6;V/" x="-341.83333587646484" y="878">
                    <value name="TEXT">
                        <value name="ADD0">
                        <value name="ADD1">
                        <value name="ADD2">
                        <value name="ADD3">
                        <value name="ADD4">
                        <value name="ADD5">
                        <value name="ADD6">
                        <value name="ADD7">
                    @spidermike sagte: hier noch ein versuch
                    Das ist nur der Debug-Block.
                    @spidermike sagte in PV Überschuss nutzen um 1,5KW und 3,0KW Heizstab zu schalten:
                    Wenn der Datenpunkt existiert, wird in Blockly der Name dargestellt, andernfalls die ID.
                      @paul53 ist das jetzt soweit ok?
                        @spidermike sagte: ist das jetzt soweit ok?
                        Kann ich nicht beurteilen, denn der Export enthält nur den Debug-Block:
                        S 3 Replies Last reply Reply Quote 0
                          @paul53 ok ich werde es morgen sehen was passiert und melde mich dann nochmal wenn ich es ok ist oder probleme gibt
                            @paul53 ich wollte mich mal wieder melden und nach einer gewissen testphase ein kleines Feedback geben.
                            das Script funktioniert jetzt wieder super und schaltet meine Heizstäbe wunderbar,
                            Danke für Deine Hilfe
                              @paul53 hallo,
                              nach dem Shelly adapter upate schaltet das script die zwei shellys nicht mehr obwohl die datenpunkte vorhanden sind.
                              was kann das jetzt wieder sein?
                              gruß Maik
                              497
