    4. Instabiles Systemverhalten
    • haselchen
      haselchen Most Active @___manalishi last edited by haselchen
      @___manalishi
      Und warum hast Du den Admin auf Port 8000?
      Edit:
      das musste auch angehen
      Pending OS-Updates:     146
      Pending iob updates:    1
      • ___manalishi
        ___manalishi @Thomas Braun last edited by
        @thomas-braun ich bin mir nicht mehr sicher mit welchem update die Umstellung auf den dedizierten iobroker user kam. Vorher habe ich es unter "root" laufen lassen
          Thomas Braun Most Active @___manalishi last edited by
          @___manalishi sagte in Instabiles Systemverhalten:
          Das ist halt der Fehler. Schon immer gewesen.
          Langfassung von iob diag sagt?
          • ___manalishi
            ___manalishi last edited by ___manalishi
            @thomas-braun meinst du --unmask?```
            *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer-container
                     Chassis: container ☐
              Virtualization: lxc
            Operating System: Ubuntu 24.04.1 LTS
                      Kernel: Linux 6.8.12-8-pve
                Architecture: x86-64
            OS is similar to: debian
            model name      : Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz
            Docker          : false
            Virtualization  : lxc
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             16:01:21 up 3 days,  2:54,  5 users,  load average: 6.26, 6.22, 5.75
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Ubuntu LTS release codenamed 'noble'!
            *** TIME AND TIMEZONES ***
                           Local time: Fri 2025-03-28 16:01:21 CET
                       Universal time: Fri 2025-03-28 15:01:21 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            broker
            HOME=/home/broker
            GROUPS=broker adm dialout sudo audio video plugdev users iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:             17G        4.9G        5.9G        143K        6.4G         12G
            Swap:           8.6G         19M        8.6G
            Total:           25G        5.0G         14G
            Active iob-Instances:   53
                    16384 M total memory
                     4704 M used memory
                     4004 M active memory
                     5973 M inactive memory
                     5593 M free memory
                        0 M buffer memory
                     6086 M swap cache
                     8191 M total swap
                       18 M used swap
                     8173 M free swap
            top - 16:01:22 up 3 days,  2:54,  5 users,  load average: 6.26, 6.22, 5.75
            Tasks:  97 total,   1 running,  96 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 34.8 us, 17.4 sy,  0.0 ni, 47.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  16384.0 total,   5592.7 free,   4705.3 used,   6086.2 buff/cache
            MiB Swap:   8192.0 total,   8173.3 free,     18.7 used.  11678.7 avail Mem
            *** FAILED SERVICES ***
              UNIT              LOAD   ACTIVE SUB    DESCRIPTION
            * motd-news.service loaded failed failed Message of the Day
            Legend: LOAD   -> Reflects whether the unit definition was properly loaded.
                    ACTIVE -> The high-level unit activation state, i.e. generalization of SUB.
                    SUB    -> The low-level unit activation state, values depend on unit type.
            1 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            3 CRITICAL ERRORS DETECTED!
            Check 'sudo dmesg --level=emerg,alert,crit -T' for details
            *** FILESYSTEM ***
            Filesystem     Type   Size  Used Avail Use% Mounted on
            /dev/loop9     ext4   147G   67G   73G  48% /
            none           tmpfs  492K  4.0K  488K   1% /dev
            tmpfs          tmpfs   32G     0   32G   0% /dev/shm
            tmpfs          tmpfs   13G  192K   13G   1% /run
            tmpfs          tmpfs  5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs  6.3G  8.0K  6.3G   1% /run/user/0
            tmpfs          tmpfs  6.3G  8.0K  6.3G   1% /run/user/1001
            Show mounted filesystems:
            TARGET SOURCE     FSTYPE OPTIONS
            /      /dev/loop9 ext4   rw,relatime
            /var:
            1.2G    /var/
            580M    /var/log
            560M    /var/log/journal/a3fdee8ab0e1421cb7e7010b5ea0577a
            332M    /var/cache
            Archived and active journals take up 559.6M in the file system.
            /opt/iobroker/backups:
            2.8G    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            55G     /opt/iobroker/iobroker-data/
            54G     /opt/iobroker/iobroker-data/history
            601M    /opt/iobroker/iobroker-data/files
            237M    /opt/iobroker/iobroker-data/backup-objects
            161M    /opt/iobroker/iobroker-data/history/20250323
            find: Failed to change directory: /root: Permission denied
            find: Failed to restore initial working directory: /root: Permission denied
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.18.0
            /usr/bin/node           v20.18.0
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.29.3
            nodejs:
              Installed: 20.18.0-1nodesource1
              Candidate: 20.19.0-1nodesource1
              Version table:
                 20.19.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.18.3-1nodesource1 500
                 20.18.2-1nodesource1 500
                 20.18.1-1nodesource1 500
             *** 20.18.0-1nodesource1 500
                    100 /var/lib/dpkg/status
                 20.17.0-1nodesource1 500
                 20.16.0-1nodesource1 500
                 20.15.1-1nodesource1 500
                 20.15.0-1nodesource1 500
                 20.14.0-1nodesource1 500
                 20.13.1-1nodesource1 500
                 20.13.0-1nodesource1 500
                 20.12.2-1nodesource1 500
                 20.12.1-1nodesource1 500
                 20.12.0-1nodesource1 500
                 20.11.1-1nodesource1 500
                 20.11.0-1nodesource1 500
                 20.10.0-1nodesource1 500
                 20.9.0-1nodesource1 500
                 20.8.1-1nodesource1 500
                 20.8.0-1nodesource1 500
                 20.7.0-1nodesource1 500
                 20.6.1-1nodesource1 500
                 20.6.0-1nodesource1 500
                 20.5.1-1nodesource1 500
                 20.5.0-1nodesource1 500
                 20.4.0-1nodesource1 500
                 20.3.1-1nodesource1 500
                 20.3.0-1nodesource1 500
                 20.2.0-1nodesource1 500
                 20.1.0-1nodesource1 500
                 20.0.0-1nodesource1 500
                 18.19.1+dfsg-6ubuntu5 500
                    500 http://archive.ubuntu.com/ubuntu noble/universe amd64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 8061)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.6.3
            javascript:     8.9.1
            nodejs modules from github:     5
            +-- @iobroker/adapter-react-v5@7.2.4 (git+ssh://git@github.com/ioBroker/adapter-react-v5.git#4c258156cfb888fd713b85a7bb3de3a1eba13297)
            +-- iobroker.btc_kurs@0.3.3 (git+ssh://git@github.com/Apollon77/ioBroker.btc_kurs.git#7526be707ad113cec956c4194d0c8aeb6b064e70)
            +-- iobroker.heizoel@1.0.3 (git+ssh://git@github.com/TA2k/ioBroker.heizoel.git#f45d5281d9e783674351f95873b8233320620ff5)
            | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
            | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8000, bind: 0.0.0.0, run as: admin
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
              system.adapter.awattar.0                : awattar               : iobroker                                 - disabled
            + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
            + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
            + system.adapter.awtrix-light.2           : awtrix-light          : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
              system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
            + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
              system.adapter.btc_kurs.0               : btc_kurs              : iobroker                                 -  enabled
              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
              system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
            + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
              system.adapter.email.0                  : email                 : iobroker                                 - disabled
              system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.fhem.0                   : fhem                  : iobroker                                 - disabled, port: 7072
              system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
              system.adapter.harmony.0                : harmony               : iobroker                                 - disabled
              system.adapter.hass.0                   : hass                  : iobroker                                 - disabled, port: 8123
            + system.adapter.heizoel.0                : heizoel               : iobroker                                 -  enabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
            + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
              system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
              system.adapter.ical.3                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
              system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
              system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
              system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
              system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
              system.adapter.influxdb.1               : influxdb              : iobroker                                 - disabled, port: 8086
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
            + system.adapter.loxone.0                 : loxone                : iobroker                                 -  enabled, port: 80
              system.adapter.material.0               : material              : iobroker                                 - disabled
              system.adapter.mbus.1                   : mbus                  : iobroker                                 - disabled, port: 3493
            + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
            + system.adapter.modbus.4                 : modbus                : iobroker                                 -  enabled
              system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1883
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1884, bind: 192.168.90.3
            + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 192.168.90.3
            + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1887, bind: 192.168.90.3
            + system.adapter.mqtt.3                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.node-red.0               : node-red              : iobroker                                 - disabled, port: 1880, bind: 0.0.0.0
            + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
            + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
              system.adapter.parser.0                 : parser                : iobroker                                 - disabled
            + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            + system.adapter.ping.1                   : ping                  : iobroker                                 -  enabled
              system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              system.adapter.pvforecast.0             : pvforecast            : iobroker                                 - disabled
              system.adapter.radar.0                  : radar                 : iobroker                                 - disabled
              system.adapter.radar2.0                 : radar2                : iobroker                                 - disabled
              system.adapter.samsung.0                : samsung               : iobroker                                 - disabled
              system.adapter.sayit.0                  : sayit                 : iobroker                                 - disabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.90.3
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 192.168.90.3, run as: admin
              system.adapter.snips.0                  : snips                 : iobroker                                 - disabled, port: 1880
            + system.adapter.snmp.0                   : snmp                  : iobroker                                 -  enabled
              system.adapter.snmp.1                   : snmp                  : iobroker                                 - disabled
              system.adapter.solarwetter.0            : solarwetter           : iobroker                                 - disabled
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 192.168.90.3
            + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
            + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
            + system.adapter.spotify-premium.1        : spotify-premium       : iobroker                                 -  enabled
            + system.adapter.spotify-premium.2        : spotify-premium       : iobroker                                 -  enabled
            + system.adapter.spotify-premium.3        : spotify-premium       : iobroker                                 -  enabled
            + system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker                                 -  enabled, port: 9002
            + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
              system.adapter.synology.0               : synology              : iobroker                                 - disabled, port: 5000
              system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.2               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.3               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.4               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.5               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.6               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
              system.adapter.text2command.0           : text2command          : iobroker                                 - disabled
            + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.traccar.0                : traccar               : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
              system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
              system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
              system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
              system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
              system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
              system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 - disabled
              system.adapter.vis-material.0           : vis-material          : iobroker                                 - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
              system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
              system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
              system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.wiffi-wz.0               : wiffi-wz              : iobroker                                 - disabled
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
              system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : iobroker                                 - disabled
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name               │ url        │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'                                                  │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                           │ false        │
            │ 2       │ 'online'           │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json' │ false        │
            Active repo(s): Stable (default), Beta (latest)
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repositories: Stable (default), Beta (latest)
            Adapter    "admin"        : 7.6.3    , installed 7.6.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "awattar"      : 1.0.6    , installed 1.0.6
            Adapter    "awtrix-light" : 1.6.0    , installed 1.6.0
            Adapter    "backitup"     : 3.1.0    , installed 3.1.0
            Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
            Adapter    "bmw"          : 2.9.4    , installed 2.9.4
            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
            Adapter    "echarts"      : 2.0.6    , installed 2.0.6
            Adapter    "email"        : 2.0.3    , installed 2.0.2  [Updatable]
            Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "fhem"         : 3.0.0    , installed 3.0.0
            Adapter    "harmony"      : 1.5.0    , installed 1.5.0
            Adapter    "hass"         : 1.4.0    , installed 1.4.0
            Adapter    "heizoel"      : 1.0.3    , installed 1.0.3
            Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
            Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
            Adapter    "ical"         : 1.16.1   , installed 1.16.1
            Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
            Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
            Adapter    "javascript"   : 8.9.1    , installed 8.9.1
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "linux-control": 1.1.5    , installed 1.1.5
            Adapter    "loxone"       : 3.0.1    , installed 3.0.1
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "mbus"         : 2.7.0    , installed 2.7.0
            Adapter    "modbus"       : 6.4.0    , installed 6.4.0
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
            Adapter    "node-red"     : 6.0.7    , installed 6.0.7
            Adapter    "octoprint"    : 6.0.0    , installed 6.0.0
            Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
            Adapter    "parser"       : 2.3.1    , installed 2.3.1
            Adapter    "ping"         : 1.7.9    , installed 1.7.9
            Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
            Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
            Adapter    "radar2"       : 2.2.0    , installed 2.2.0
            Adapter    "samsung"      : 0.6.1    , installed 0.6.1
            Adapter    "sayit"        : 5.0.0    , installed 5.0.0
            Adapter    "scenes"       : 4.0.1    , installed 4.0.1
            Adapter    "shelly"       : 9.2.0    , installed 9.2.0
            Adapter    "simple-api"   : 3.0.6    , installed 3.0.6
            Adapter    "snips"        : 1.5.1    , installed 1.5.1
            Adapter    "snmp"         : 3.2.0    , installed 3.2.0
            Adapter    "socketio"     : 7.0.8    , installed 7.0.8
            Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
            Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
            Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
            Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
            Adapter    "squeezeboxrpc": 1.5.2    , installed 1.5.2
            Adapter    "statistics"   : 3.1.0    , installed 3.1.0
            Adapter    "synology"     : 3.1.0    , installed 3.1.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "traccar"      : 1.1.6    , installed 1.1.6
            Adapter    "trashschedule": 4.0.0    , installed 4.0.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
            Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
            Adapter    "vis-material" : 0.2.0    , installed 0.2.0
            Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
            Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
            Adapter    "weatherunderground": 3.7.0, installed 3.7.0
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
            Adapter    "wled"         : 0.7.3    , installed 0.7.3
            Adapter    "ws"           : 3.0.19   , installed 3.0.19
            Adapter    "yahoo-stock-market": 0.0.7, installed 0.0.7
            Objects and States
            Objects:        67149
            States:         54643
            Hit:1 http://archive.ubuntu.com/ubuntu noble InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu noble-updates InRelease
            Hit:3 http://archive.ubuntu.com/ubuntu noble-security InRelease
            Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
            Reading package lists...
            Pending Updates: 146
            *** Listening Ports ***
            tcp        0      0 192.168.90.3:8087       0.0.0.0:*               LISTEN      1000       239842059  568196/io.simple-ap
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      992        191013665  233/systemd-resolve
            tcp        0      0 192.168.90.3:1883       0.0.0.0:*               LISTEN      1000       239827495  567813/io.sonoff.0
            tcp        0      0 192.168.90.3:1882       0.0.0.0:*               LISTEN      1000       239814213  567745/io.shelly.0
            tcp        0      0 192.168.90.3:1887       0.0.0.0:*               LISTEN      1000       239821230  567604/io.mqtt.2
            tcp        0      0 192.168.90.3:1885       0.0.0.0:*               LISTEN      1000       239821211  567582/io.mqtt.1
            tcp        0      0 192.168.90.3:1884       0.0.0.0:*               LISTEN      1000       239813245  567551/io.mqtt.0
            tcp        0      0 192.168.90.3:2010       0.0.0.0:*               LISTEN      1000       239790057  566656/io.hm-rpc.1
            tcp        0      0 192.168.90.3:2001       0.0.0.0:*               LISTEN      1000       239807636  566596/io.hm-rpc.0
            tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          191016171  426/master
            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       239789162  565641/iobroker.js-
            tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       239789213  565641/iobroker.js-
            tcp        0      0 0.0.0.0:46705           0.0.0.0:*               LISTEN      108        191020743  862/rpc.statd
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          190996422  1/init
            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      992        191013667  233/systemd-resolve
            tcp6       0      0 :::33985                :::*                    LISTEN      108        191020748  862/rpc.statd
            tcp6       0      0 :::111                  :::*                    LISTEN      0          190996424  1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          191013676  1/init
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       239851918  568516/io.web.0
            tcp6       0      0 :::8000                 :::*                    LISTEN      1000       239789320  565670/io.admin.0
            udp        0      0 127.0.0.54:53           0.0.0.0:*                           992        191013666  233/systemd-resolve
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           992        191013664  233/systemd-resolve
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          190996423  1/init
            udp        0      0 127.0.0.1:614           0.0.0.0:*                           0          191027762  862/rpc.statd
            udp        0      0 0.0.0.0:35478           0.0.0.0:*                           1000       239829062  567785/io.snmp.0
            udp        0      0 0.0.0.0:35888           0.0.0.0:*                           108        191020740  862/rpc.statd
            udp        0      0 0.0.0.0:37145           0.0.0.0:*                           1000       239814360  567785/io.snmp.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       239854612  568538/io.wled.0
            udp        0      0 192.168.2.177:5353      0.0.0.0:*                           1000       239814649  567937/io.tr-064.0
            udp        0      0 192.168.90.3:5353       0.0.0.0:*                           1000       239814648  567937/io.tr-064.0
            udp        0      0 0.0.0.0:38548           0.0.0.0:*                           1000       239814357  567785/io.snmp.0
            udp6       0      0 :::59526                :::*                                108        191020746  862/rpc.statd
            udp6       0      0 :::111                  :::*                                0          190993364  1/init
            2025-03-28 16:02:00.611  - debug: awtrix-light.0 (568527) [onStateChange] Battery: State change "awtrix-light.0.apps.Time.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705422361382}
            2025-03-28 16:02:00.611  - debug: awtrix-light.0 (568527) [onStateChange] : State change "awtrix-light.0.apps.Time.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705422361382}
            2025-03-28 16:02:00.611  - debug: awtrix-light.0 (568527) [onStateChange] Time: State change "awtrix-light.0.apps.Temperature.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705263084577}
            2025-03-28 16:02:00.614  - debug: awtrix-light.0 (568527) [onStateChange] Date: State change "awtrix-light.0.apps.Temperature.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705263084577}
            2025-03-28 16:02:00.614  - debug: awtrix-light.0 (568527) [onStateChange] Temperature: State change "awtrix-light.0.apps.Temperature.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705263084577}
            2025-03-28 16:02:00.614  - debug: awtrix-light.0 (568527) [onStateChange] Humidity: State change "awtrix-light.0.apps.Temperature.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705263084577}
            2025-03-28 16:02:00.614  - debug: awtrix-light.0 (568527) [onStateChange] Battery: State change "awtrix-light.0.apps.Temperature.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705263084577}
            2025-03-28 16:02:00.614  - debug: awtrix-light.0 (568527) [onStateChange] : State change "awtrix-light.0.apps.Temperature.activate": {"val":false,"ack":true,"ts":1743174120249,"q":0,"c":"script.js.Haus.Administration.Matrix.Matrix_BUERO-OG","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1705263084577}
            2025-03-28 16:02:00.672  - warn: loxone.0 (567411) Timeout for ack loxone.0.1e33b969-0311-9b9d-ffff782a703fdd10.value
            2025-03-28 16:02:00.676  - debug: javascript.0 (565738) script.js.Haus.Pool.Umwaelzpumpe: Poolbetrieb: false
            Auto Einschaltzeit gesetz: false
            2025-03-28 16:02:00.678  - warn: loxone.0 (567411) Timeout for ack loxone.0.1e33b9c1-0115-bc23-ffff782a703fdd10.value
            2025-03-28 16:02:00.687  - warn: loxone.0 (567411) Timeout for ack loxone.0.1e33b9f0-01a8-e35d-ffff782a703fdd10.value
            2025-03-28 16:02:00.762  - debug: awtrix-light.0 (568527) received 200 response from "notify" with content: "OK"
            2025-03-28 16:02:00.793  - info: host.iobroker instance system.adapter.spotify-premium.3 scheduled normal terminated and will be restarted on schedule.
            2025-03-28 16:02:00.793  - info: host.iobroker Restart adapter system.adapter.spotify-premium.3 because enabled
            2025-03-28 16:02:00.903  - debug: awtrix-light.0 (568527) received 200 response from "notify" with content: "OK"
            2025-03-28 16:02:00.944  - debug: awtrix-light.0 (568527) received 200 response from "indicator2" with content: "OK"
            2025-03-28 16:02:00.975  - debug: awtrix-light.0 (568527) received 200 response from "indicator2" with content: "OK"
            2025-03-28 16:02:01.099  - info: javascript.0 (565738) script.js.Haus.DEFI.Test_Hyperliquid: -0.01014
            2025-03-28 16:02:01.113  - warn: loxone.0 (567411) Timeout for ack loxone.0.1cdcbd3f-000f-929c-ffff782a703fdd10.value
            2025-03-28 16:02:01.182  - info: host.iobroker instance system.adapter.spotify-premium.0 scheduled normal terminated and will be restarted on schedule.
            2025-03-28 16:02:01.209  - debug: javascript.0 (565738) script.js.Haus.Heizung.Heizung-Pumpensteuerung: TVL berechnet: 49.261318407960204
            iob diag --unmask.txt
            • ___manalishi
              @thomas-braun Ich habe einen neuen container aufgesetzt und iob fix mit einem anderen user ausgeführt. Berechtigung scheinen jetzt zu passen. versuche ein backup einzuspielen
              Script v.2025-02-23
              *** BASE SYSTEM ***
               Static hostname: iobroker-1
                Virtualization: lxc
                        Kernel: Linux 6.8.12-5-pve
              OS is similar to:
              model name      : AMD Ryzen Threadripper 3960X 24-Core Processor
              Docker          : false
              Kernel          : x86_64
              Userland        : 64 bit
               16:30:43 up 10 min,  2 users,  load average: 2.61, 3.02, 3.19
              CPU threads: 4
              Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                             Local time: Fri 2025-03-28 16:30:43 CET
                         Universal time: Fri 2025-03-28 15:30:43 UTC
                               RTC time: n/a
              System clock synchronized: no
                        RTC in local TZ: no
              broker
              HOME=/home/broker
              iobroker
              HOME=/home/iobroker
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:             17G        532M         14G        139K        2.0G         16G
              Swap:           536M          0B        536M
              Total:           17G        532M         15G
              Active iob-Instances:   4
                        507 M used memory
                        396 M active memory
                       1848 M inactive memory
                      13962 M free memory
                          0 M buffer memory
                       1914 M swap cache
                        512 M total swap
                          0 M used swap
                        512 M free swap
              top - 16:30:43 up 10 min,  2 users,  load average: 2.61, 3.02, 3.19
              Tasks:  32 total,   1 running,  31 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :  16384.0 total,  13960.3 free,    509.3 used,   1914.5 buff/cache
              MiB Swap:    512.0 total,    512.0 free,      0.0 used.  15874.7 avail Mem
              * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
              LOAD   = Reflects whether the unit definition was properly loaded.
              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
              SUB    = The low-level unit activation state, values depend on unit type.
              dmesg: read kernel buffer failed: Operation not permitted
              No critical errors detected
              *** FILESYSTEM ***
              /dev/mapper/NVME.2--2TB-vm--120--disk--0 ext4      147G  2.2G  137G   2% /
              udev                                     devtmpfs  126G     0  126G   0% /dev/tty
              tmpfs                                    tmpfs     126G     0  126G   0% /dev/shm
              tmpfs                                    tmpfs      51G  132K   51G   1% /run
              tmpfs                                    tmpfs      26G     0   26G   0% /run/user/1001
              /      /dev/mapper/NVME.2--2TB-vm--120--disk--0 ext4   rw,relatime,stripe=16
              /var:
              459M    /var/
              287M    /var/cache
              283M    /var/cache/apt
              208M    /var/cache/apt/archives
              147M    /var/lib
              Archived and active journals take up 24.0M in the file system.
              4.0K    /opt/iobroker/backups/
              62M     /opt/iobroker/iobroker-data/
              56M     /opt/iobroker/iobroker-data/files
              38M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
              6.8M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
              5.1M    /opt/iobroker/iobroker-data/objects.jsonl
              3.9M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.92169c09.chunk.js
              3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-ZPb95xPG.js
              3.7M    /opt/iobroker/iobroker-data/files/admin.admin/custom/assets/index-Drg0QIRU.js
              USB-Devices by-id:
              /usr/bin/nodejs         v20.19.0
              /usr/bin/node           v20.19.0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.31.0
              nodejs:
                Installed: 20.19.0-1nodesource1
                Version table:
               *** 20.19.0-1nodesource1 500
                   18.19.0+dfsg-6~deb12u2 500
                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                   18.19.0+dfsg-6~deb12u1 500
                      500 http://security.debian.org bookworm-security/main amd64 Packages
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              iobroker-1          iobroker-1 (version: 7.0.6, hostname: iobroker-1    , alive, uptime: 166)
              admin:          7.6.3
              javascript:     "javascript" not found
              nodejs modules from github:     0
              Adapter State
              + system.adapter.admin.0                  : admin                 : iobroker-1                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.backitup.0               : backitup              : iobroker-1                               -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker-1                               -  enabled
              + instance is alive
              Active repo(s): stable
              Used repository: stable
              Adapter    "backitup"     : 3.0.31   , installed 3.0.31
              Objects and States
              Objects:        148
              States:         104
              Hit:1 http://security.debian.org bookworm-security InRelease
              Hit:2 http://deb.debian.org/debian bookworm InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Pending Updates: 0
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          132099012  362/master
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       132220826  16188/iobroker.js-c
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       132220831  16188/iobroker.js-c
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          132200526  1/systemd
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          132200960  15058/sshd: /usr/sb
              tcp6       0      0 :::111                  :::*                    LISTEN      0          132200528  1/systemd
              tcp6       0      0 :::22                   :::*                    LISTEN      0          132200962  15058/sshd: /usr/sb
              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       132214486  16206/io.admin.0
              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          132135329  115/dhclient
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          132200527  1/systemd
              udp6       0      0 :::111                  :::*                                0          132200529  1/systemd
              2025-03-28 16:28:00.500  - info: host.iobroker-1 ip addresses: 192.168.90.116
              2025-03-28 16:28:00.772  - info: host.iobroker-1 connected to Objects and States
              2025-03-28 16:28:00.777  - info: host.iobroker-1 added notifications configuration of host
              2025-03-28 16:28:00.880  - info: host.iobroker-1 3 instances found
              2025-03-28 16:28:00.881  - info: host.iobroker-1 starting 3 instances
              2025-03-28 16:28:00.979  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeCurrent"
              2025-03-28 16:28:00.998  - info: host.iobroker-1 instance system.adapter.admin.0 in version "7.6.3" started with pid 16206
              2025-03-28 16:28:01.033  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeNewest"
              2025-03-28 16:28:01.035  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.nodeNewestNext"
              2025-03-28 16:28:01.035  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmCurrent"
              2025-03-28 16:28:01.036  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmNewest"
              2025-03-28 16:28:01.037  - info: host.iobroker-1 Delete state "system.host.iobroker-1.versions.npmNewestNext"
              2025-03-28 16:28:01.042  - info: host.iobroker-1 Some obsolete host states deleted.
              2025-03-28 16:28:01.632  - info: admin.0 (16206) starting. Version 7.6.3 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.0, js-controller: 7.0.6
              2025-03-28 16:28:01.643  - info: admin.0 (16206) requesting all objects
              2025-03-28 16:28:01.784  - info: admin.0 (16206) received all objects
              2025-03-28 16:28:01.875  - info: admin.0 (16206) socket.io server listening on port 8081
              2025-03-28 16:28:01.875  - info: admin.0 (16206) http server listening on port 8081
              2025-03-28 16:28:01.876  - info: admin.0 (16206) Use link "http://127.0.0.1:8081" to configure.
              2025-03-28 16:28:04.980  - info: host.iobroker-1 instance system.adapter.backitup.0 in version "3.0.31" started with pid 16251
              2025-03-28 16:28:05.390  - info: backitup.0 (16251) starting. Version 3.0.31 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.0, js-controller: 7.0.6
              2025-03-28 16:28:05.404  - info: backitup.0 (16251) [iobroker] backup will be activated at 02:48 every 1 day(s)
              2025-03-28 16:28:08.984  - info: host.iobroker-1 instance system.adapter.discovery.0 in version "5.0.0" started with pid 16274
              2025-03-28 16:28:09.378  - info: discovery.0 (16274) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.19.0, js-controller: 7.0.6
              2025-03-28 16:28:27.927  - info: admin.0 (16206) ==> Connected system.user.admin from ::ffff:192.168.2.74
                @___manalishi
                Über den neuen Container kannste gleich mal den
                iob fix
                jagen.
                ___manalishi 1 Reply Last reply Reply Quote 0
                • ___manalishi
                  @thomas-braun habe ich bereits getan. das ergebnis habe ich im vorherigen post. scheint jetzt mit den Berechtigungen in Ordnung zu sein
                    @___manalishi
                    Kann eigentlich nicht sein, nach der Installation ist direkt danach ein fix erforderlich. Dann sieht die Ausgabe nämlich noch etwas anders aus.
                    • ___manalishi
                      ___manalishi @Thomas Braun last edited by ___manalishi
                      ich habe das iob fix nach der installation vor dem restore des backups ausgeführt. Das sind die 4 Instanzen, die mit der Installation mitkommen. Aktuell läuft nach dem Restore Charts, Skripte und Vis stabil.
                      • ___manalishi
                        Vielen Dank für eure Unterstützung.
                        Bisher läuft in dem neuen Container der IOBroker ohne root wieder alles stabil. Es ist schwer im Nachgang die wirkliche Fehlerursache herauszufinden. Werde mir aber nochmal die Fehler im iob diag des alten LXC Containers genau ansehen.
                        • ___manalishi
                          ___manalishi @___manalishi last edited by ___manalishi
                          @Thomas-Braun ich habe wahrscheinlich die Ursache gefunden.
                          Ich verwende einen Slave iobroker wegen einem MBus Adapter. Dieser Slave hatte die Verbindung zum Master (LXC) verloren und ich habe daher den Slave vor einigen Wochen deaktiviert.
                          Nachdem ich eben den Slave neu installiert und verbunden habe sind wieder die gleichen Symptome aufgetreten (langsames WEBUI)
                          Der Master/Slave Betrieb lief bis vor ein paar Wochen über mehrere Monate stabil.
                          Hast Du eine Idee was hier schiefläuft?
                          hier das aktuelle iob diag
                          Script v.2025-02-23
                          *** BASE SYSTEM ***
                            Virtualization: lxc
                          OS is similar to:
                          Docker          : false
                          Kernel          : x86_64
                          Userland        : 64 bit
                           22:35:27 up  5:07,  4 users,  load average: 4.56, 4.23, 3.80
                          CPU threads: 4
                                         Local time: Fri 2025-03-28 22:35:27 CET
                                     Universal time: Fri 2025-03-28 21:35:27 UTC
                                           RTC time: n/a
                                    RTC in local TZ: no
                          broker
                          HOME=/home/broker
                          iobroker
                          HOME=/home/iobroker
                          Desktop:
                          Terminal:
                          *** MEMORY ***
                          Mem:             17G        4.1G        2.2G        151K         10G         13G
                          Swap:           536M          0B        536M
                          Total:           17G        4.1G        2.7G
                          Active iob-Instances:   48
                                   3901 M used memory
                                   3469 M active memory
                                  10067 M inactive memory
                                   2089 M free memory
                                      0 M buffer memory
                                  10393 M swap cache
                                    512 M total swap
                                      0 M used swap
                                    512 M free swap
                          top - 22:35:27 up  5:08,  4 users,  load average: 4.56, 4.23, 3.80
                          Tasks:  88 total,   2 running,  86 sleeping,   0 stopped,   0 zombie
                          %Cpu(s): 50.0 us, 33.3 sy,  0.0 ni, 16.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                          MiB Mem :  16384.0 total,   2085.3 free,   3905.5 used,  10393.5 buff/cache
                          MiB Swap:    512.0 total,    512.0 free,      0.0 used.  12478.5 avail Mem
                          *** FILESYSTEM ***
                          /dev/loop0     ext4      147G   61G   79G  44% /
                          tmpfs          tmpfs      51G  144K   51G   1% /run
                          /      /dev/loop0 ext4   rw,relatime
                          /var:
                          447M    /var/
                          287M    /var/cache
                          283M    /var/cache/apt
                          147M    /var/lib
                          Archived and active journals take up 12.6M in the file system.
                          2.2G    /opt/iobroker/backups/
                          577M    /opt/iobroker/iobroker-data/files
                          157M    /opt/iobroker/iobroker-data/history/20250324
                          58M     /opt/iobroker/iobroker-data/objects.jsonl
                          41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                          36M     /opt/iobroker/iobroker-data/states.jsonl
                          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                          19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
                          USB-Devices by-id:
                          /usr/bin/npm            10.8.2
                          /usr/bin/npx            10.8.2
                          nodejs:
                            Version table:
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          Hosts:
                          iobroker-1          iobroker-1 (version: 7.0.6, hostname: iobroker-1    , alive, uptime: 227)
                          admin:          7.6.3
                          javascript:     8.9.1
                          +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
                          Adapter State
                          + system.adapter.admin.0                  : admin                 : iobroker-1                               -  enabled, port: 8000, bind: 0.0.0.0, run as: admin
                            system.adapter.alias-manager.0          : alias-manager         : iobroker-1                               - disabled
                            system.adapter.awattar.0                : awattar               : iobroker-1                               - disabled
                          + system.adapter.awtrix-light.0           : awtrix-light          : iobroker-1                               -  enabled
                          + system.adapter.awtrix-light.1           : awtrix-light          : iobroker-1                               -  enabled
                          + system.adapter.awtrix-light.2           : awtrix-light          : iobroker-1                               -  enabled
                            system.adapter.birthdays.0              : birthdays             : iobroker-1                               -  enabled
                          + system.adapter.bmw.0                    : bmw                   : iobroker-1                               -  enabled
                            system.adapter.btc_kurs.0               : btc_kurs              : iobroker-1                               -  enabled
                            system.adapter.daswetter.0              : daswetter             : iobroker-1                               -  enabled
                            system.adapter.discovery.0              : discovery             : iobroker-1                               - disabled
                            system.adapter.dwd.0                    : dwd                   : iobroker-1                               -  enabled
                          + system.adapter.echarts.0                : echarts               : iobroker-1                               -  enabled
                            system.adapter.email.0                  : email                 : iobroker-1                               - disabled
                          + system.adapter.energiefluss.0           : energiefluss          : iobroker-1                               -  enabled
                            system.adapter.feiertage.0              : feiertage             : iobroker-1                               -  enabled
                            system.adapter.fhem.0                   : fhem                  : iobroker-1                               - disabled, port: 7072
                            system.adapter.flot.0                   : flot                  : iobroker-1                               - disabled
                            system.adapter.harmony.0                : harmony               : iobroker-1                               - disabled
                            system.adapter.hass.0                   : hass                  : iobroker-1                               - disabled, port: 8123
                          + system.adapter.heizoel.0                : heizoel               : iobroker-1                               -  enabled
                          + system.adapter.history.0                : history               : iobroker-1                               -  enabled
                          + system.adapter.hm-rega.0                : hm-rega               : iobroker-1                               -  enabled
                          + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-1                               -  enabled, port: 0
                          + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-1                               -  enabled, port: 0
                            system.adapter.ical.1                   : ical                  : iobroker-1                               -  enabled
                            system.adapter.ical.2                   : ical                  : iobroker-1                               -  enabled
                            system.adapter.ical.3                   : ical                  : iobroker-1                               -  enabled
                            system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-1                               - disabled
                            system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker-1                               - disabled
                            system.adapter.icons-material-png.0     : icons-material-png    : iobroker-1                               - disabled
                            system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-1                               - disabled
                            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-1                               - disabled
                            system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-1                               - disabled
                            system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-1                               - disabled
                          + system.adapter.influxdb.0               : influxdb              : iobroker-1                               -  enabled, port: 8086
                            system.adapter.influxdb.1               : influxdb              : iobroker-1                               - disabled, port: 8086
                          + system.adapter.javascript.0             : javascript            : iobroker-1                               -  enabled
                            system.adapter.linux-control.0          : linux-control         : iobroker-1                               - disabled
                          + system.adapter.loxone.0                 : loxone                : iobroker-1                               -  enabled, port: 80
                            system.adapter.material.0               : material              : iobroker-1                               - disabled
                            system.adapter.mbus.1                   : mbus                  : 3D-Printserver                           - disabled, port: 3493
                          + system.adapter.modbus.0                 : modbus                : iobroker-1                               -  enabled
                          + system.adapter.modbus.1                 : modbus                : iobroker-1                               -  enabled
                          + system.adapter.modbus.2                 : modbus                : iobroker-1                               -  enabled
                          + system.adapter.modbus.4                 : modbus                : iobroker-1                               -  enabled
                            system.adapter.mqtt-client.0            : mqtt-client           : iobroker-1                               - disabled, port: 1883
                          + system.adapter.mqtt.0                   : mqtt                  : iobroker-1                               -  enabled, port: 1884, bind: 192.168.90.3
                          + system.adapter.mqtt.1                   : mqtt                  : iobroker-1                               -  enabled, port: 1885, bind: 192.168.90.3
                          + system.adapter.mqtt.2                   : mqtt                  : iobroker-1                               -  enabled, port: 1887, bind: 192.168.90.3
                          + system.adapter.mqtt.3                   : mqtt                  : iobroker-1                               -  enabled, port: 1883, bind: 0.0.0.0
                            system.adapter.node-red.0               : node-red              : iobroker-1                               - disabled, port: 1880, bind: 0.0.0.0
                          + system.adapter.octoprint.0              : octoprint             : iobroker-1                               -  enabled
                          + system.adapter.opendtu.0                : opendtu               : iobroker-1                               -  enabled
                          + system.adapter.parser.0                 : parser                : iobroker-1                               -  enabled
                          + system.adapter.ping.0                   : ping                  : iobroker-1                               -  enabled
                          + system.adapter.ping.1                   : ping                  : iobroker-1                               -  enabled
                            system.adapter.proxmox.0                : proxmox               : iobroker-1                               - disabled, port: 8006
                            system.adapter.pvforecast.0             : pvforecast            : iobroker-1                               - disabled
                            system.adapter.radar.0                  : radar                 : iobroker-1                               - disabled
                            system.adapter.radar2.0                 : radar2                : iobroker-1                               - disabled
                            system.adapter.samsung.0                : samsung               : iobroker-1                               - disabled
                            system.adapter.sayit.0                  : sayit                 : iobroker-1                               - disabled
                          + system.adapter.scenes.0                 : scenes                : iobroker-1                               -  enabled
                          + system.adapter.shelly.0                 : shelly                : iobroker-1                               -  enabled, port: 1882, bind: 192.168.90.3
                          + system.adapter.simple-api.0             : simple-api            : iobroker-1                               -  enabled, port: 8087, bind: 192.168.90.3, run as: admin
                            system.adapter.snips.0                  : snips                 : iobroker-1                               - disabled, port: 1880
                            system.adapter.snmp.0                   : snmp                  : iobroker-1                               - disabled
                            system.adapter.snmp.1                   : snmp                  : iobroker-1                               - disabled
                            system.adapter.solarwetter.0            : solarwetter           : iobroker-1                               - disabled
                          + system.adapter.sonoff.0                 : sonoff                : iobroker-1                               -  enabled, port: 1883, bind: 192.168.90.3
                          + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-1                               -  enabled
                          + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker-1                               -  enabled
                          + system.adapter.spotify-premium.0        : spotify-premium       : iobroker-1                               -  enabled
                          + system.adapter.spotify-premium.1        : spotify-premium       : iobroker-1                               -  enabled
                          + system.adapter.spotify-premium.2        : spotify-premium       : iobroker-1                               -  enabled
                          + system.adapter.spotify-premium.3        : spotify-premium       : iobroker-1                               -  enabled
                            system.adapter.squeezeboxrpc.0          : squeezeboxrpc         : iobroker-1                               -  enabled, port: 9002
                            system.adapter.statistics.0             : statistics            : iobroker-1                               -  enabled
                            system.adapter.synology.0               : synology              : iobroker-1                               - disabled, port: 5000
                            system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-1                               -  enabled
                          + system.adapter.telegram.0               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.1               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.2               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.3               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.4               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.5               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                          + system.adapter.telegram.6               : telegram              : iobroker-1                               -  enabled, port: 8443, bind: 0.0.0.0
                            system.adapter.text2command.0           : text2command          : iobroker-1                               -  enabled
                            system.adapter.time-switch.0            : time-switch           : iobroker-1                               -  enabled
                          + system.adapter.tr-064.0                 : tr-064                : iobroker-1                               -  enabled
                            system.adapter.traccar.0                : traccar               : iobroker-1                               -  enabled
                            system.adapter.trashschedule.0          : trashschedule         : iobroker-1                               -  enabled
                            system.adapter.unifi.0                  : unifi                 : iobroker-1                               - disabled
                            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker-1                               - disabled
                            system.adapter.vis-bars.0               : vis-bars              : iobroker-1                               - disabled
                            system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-1                               - disabled
                            system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-1                               - disabled
                            system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-1                               -  enabled
                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-1                               - disabled
                            system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-1                               - disabled
                            system.adapter.vis-justgage.0           : vis-justgage          : iobroker-1                               - disabled
                            system.adapter.vis-map.0                : vis-map               : iobroker-1                               - disabled
                            system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-1                               - disabled
                            system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker-1                               - disabled
                            system.adapter.vis-material.0           : vis-material          : iobroker-1                               - disabled
                            system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-1                               - disabled
                            system.adapter.vis-metro.0              : vis-metro             : iobroker-1                               - disabled
                            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-1                               - disabled
                            system.adapter.vis-weather.0            : vis-weather           : iobroker-1                               - disabled
                            system.adapter.vis.0                    : vis                   : iobroker-1                               -  enabled
                            system.adapter.weatherunderground.0     : weatherunderground    : iobroker-1                               -  enabled
                            system.adapter.web.0                    : web                   : iobroker-1                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            system.adapter.wiffi-wz.0               : wiffi-wz              : iobroker-1                               - disabled
                            system.adapter.wled.0                   : wled                  : iobroker-1                               -  enabled
                            system.adapter.yahoo-stock-market.0     : yahoo-stock-market    : iobroker-1                               - disabled
                          + instance is alive
                          Objects and States
                          Objects:        68366
                          States:         55316
                          Hit:2 http://security.debian.org bookworm-security InRelease
                          Pending Updates: 0
                          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          132466348  294/master
                          tcp        0      0 192.168.90.3:2010       0.0.0.0:*               LISTEN      1000       133880117  46720/io.hm-rpc.1
                          tcp        0      0 192.168.90.3:2001       0.0.0.0:*               LISTEN      1000       133873206  46702/io.hm-rpc.0
                          tcp        0      0 192.168.90.3:1882       0.0.0.0:*               LISTEN      1000       133881627  47038/io.shelly.0
                          tcp        0      0 192.168.90.3:1883       0.0.0.0:*               LISTEN      1000       133881662  47056/io.sonoff.0
                          tcp        0      0 192.168.90.3:1884       0.0.0.0:*               LISTEN      1000       133880264  46873/io.mqtt.0
                          tcp        0      0 192.168.90.3:1885       0.0.0.0:*               LISTEN      1000       133880280  46888/io.mqtt.1
                          tcp        0      0 192.168.90.3:1887       0.0.0.0:*               LISTEN      1000       133873449  46903/io.mqtt.2
                          tcp        0      0 192.168.90.3:8087       0.0.0.0:*               LISTEN      1000       133893526  47445/io.simple-api
                          tcp        0      0 0.0.0.0:35531           0.0.0.0:*               LISTEN      104        132481025  419/rpc.statd
                          tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       133875177  46031/iobroker.js-c
                          tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       133875172  46031/iobroker.js-c
                          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          132477506  1/init
                          tcp6       0      0 :::60461                :::*                    LISTEN      104        132481030  419/rpc.statd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          132462193  1/init
                          tcp6       0      0 :::111                  :::*                    LISTEN      0          132477508  1/init
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1000       133898926  48257/io.web.0
                          tcp6       0      0 :::8000                 :::*                    LISTEN      1000       133875755  46060/io.admin.0
                          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          132477507  1/init
                          udp        0      0 127.0.0.1:1019          0.0.0.0:*                           0          132462485  419/rpc.statd
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       133898834  48301/io.wled.0
                          udp        0      0 192.168.2.203:5353      0.0.0.0:*                           1000       133888361  47149/io.tr-064.0
                          udp        0      0 192.168.90.3:5353       0.0.0.0:*                           1000       133888360  47149/io.tr-064.0
                          udp        0      0 0.0.0.0:46833           0.0.0.0:*                           104        132462489  419/rpc.statd
                          udp6       0      0 :::51829                :::*                                104        132481028  419/rpc.statd
                          udp6       0      0 :::111                  :::*                                0          132477509  1/init
                          2025-03-28 22:36:05.897  - info: wled.0 (48301) Try to contact 1 known devices
                          2025-03-28 22:36:05.897  - info: wled.0 (48301) Try to contact : "WLED" on IP : 192.168.90.38
                          2025-03-28 22:36:06.000  - info: javascript.0 (46157) script.js.Haus.Heizung.Heizraum-Heisswasser-Umwälzpumpe: request: http://192.168.90.32/cm?cmnd=status%2010
                          2025-03-28 22:36:06.065  - debug: awtrix-light.0 (47204) [onMessage] received command "notification" with message: {"text":"M2: 0","color":"#FFFFFF","sound":null,"icon":11861,"repeat":1,"duration":5,"rainbow":false,"stack":true,"wakeup":true,"hold":false}
                          2025-03-28 22:36:06.066  - debug: awtrix-light.0 (47204) sending "POST" request to "notify" with data: {"text":"M2: 0","color":"#FFFFFF","icon":11861,"repeat":1,"duration":5,"rainbow":false,"stack":true,"wakeup":true,"hold":false}
                          2025-03-28 22:36:06.082  - info: wled.0 (48301) Initialising : " WLED" on IP :  192.168.90.38
                          2025-03-28 22:36:06.291  - debug: awtrix-light.0 (47204) received 200 response from "notify" with content: "OK"
                          2025-03-28 22:36:06.359  - info: wled.0 (48301) Bonjour service started, new  devices  will  be detected automatically
                          2025-03-28 22:36:06.494  - info: wled.0 (48301) WLED connected
                          2025-03-28 22:36:07.136  - info: shelly.0 (47038) [authEnabled] 192.168.90.69 (shelly1 / shelly1-E8DB84D70888 / SHSW-1#E8DB84D70888#1): This device is not protected via restricted login (see adapter documentation for details)
                          2025-03-28 22:36:07.162  - info: shelly.0 (47038) [authEnabled] 192.168.90.51 (shelly1 / shelly1-E8DB84A21281 / SHSW-1#E8DB84A21281#1): This device is not protected via restricted login (see adapter documentation for details)
                          2025-03-28 22:36:07.232  - warn: parser.0 (47430) Cannot read link "C:/ioBroker/dataimport/snips/SlotValuesMusik.txt": File does not exist
                          2025-03-28 22:36:08.001  - info: javascript.0 (46157) script.js.Haus.Heizung.Heizraum-Heisswasser-Umwälzpumpe: request: http://192.168.90.32/cm?cmnd=status%2010
                          2025-03-28 22:36:08.061  - debug: awtrix-light.0 (47204) [onMessage] received command "notification" with message: {"text":"84100","color":"#FFFFFF","sound":null,"icon":60237,"repeat":1,"duration":5,"rainbow":false,"stack":true,"wakeup":true,"hold":false}
                          2025-03-28 22:36:08.061  - debug: awtrix-light.0 (47204) sending "POST" request to "notify" with data: {"text":"84100","color":"#FFFFFF","icon":60237,"repeat":1,"duration":5,"rainbow":false,"stack":true,"wakeup":true,"hold":false}
                          2025-03-28 22:36:08.062  - debug: awtrix-light.0 (47204) [onMessage] received command "notification" with message: {"text":"2.2","color":"#FFFF00","sound":null,"icon":21311,"repeat":1,"duration":5,"rainbow":false,"stack":true,"wakeup":true,"hold":false}
                          2025-03-28 22:36:08.062  - debug: awtrix-light.0 (47204) sending "POST" request to "notify" with data: {"text":"2.2","color":"#FFFF00","icon":21311,"repeat":1,"duration":5,"rainbow":false,"stack":true,"wakeup":true,"hold":false}
                          2025-03-28 22:36:08.262  - debug: awtrix-light.0 (47204) received 200 response from "notify" with content: "OK"
                          2025-03-28 22:36:08.389  - debug: awtrix-light.0 (47204) received 200 response from "notify" with content: "OK"
                          2025-03-28 22:36:09.412  - debug: traccar.0 (48126) Incomming message: {"devices":[{"id":10,"attributes":{},"groupId":0,"calendarId":0,"name":"Frank","uniqueId":"845610","status":"online","lastUpdate":"2025-03-28T21:36:11.039+00:00","positionId":16508097,"phone":null,"model":null,"contact":null,"category":"person","disabled":false,"expirationTime":null}]}
                          2025-03-28 22:36:09.429  - debug: traccar.0 (48126) Incomming message: {"positions":[{"id":16508716,"attributes":{"batteryLevel":75.0,"distance":0.07096980166703733,"totalDistance":2.685060766715325E7,"motion":false},"deviceId":10,"protocol":"osmand","serverTime":"2025-03-28T21:36:11.037+00:00","deviceTime":"2025-03-28T21:36:11.000+00:00","fixTime":"2025-03-28T21:36:11.000+00:00","outdated":false,"valid":true,"latitude":50.391925,"longitude":8.887082,"altitude":131.3889424148947,"speed":0.0,"course":0.0,"address":null,"accuracy":2.0,"network":null,"geofenceIds":null}]}
                          2025-03-28 22:36:09.430  - debug: traccar.0 (48126) objID: devices.device.battery_level, val: 75
                          2025-03-28 22:36:09.430  - debug: traccar.0 (48126) objID: devices.device.distance, val: 0.07096980166703733
                          2025-03-28 22:36:09.430  - debug: traccar.0 (48126) objID: devices.device.total_distance, val: 26850607.66715325
                          2025-03-28 22:36:09.430  - debug: traccar.0 (48126) objID: devices.device.motion, val: false
                          T Thomas Braun 2 Replies Last reply Reply Quote 0
                            ticaki Developer @___manalishi last edited by
                            @___manalishi
                            geht master/slave mit jsonl? Ich dacht da ist redis ein muss.
                            ___manalishi arteck 2 Replies Last reply Reply Quote 0
                              Thomas Braun Most Active @___manalishi last edited by Thomas Braun
                              Lass den Fixer laufen und stell das auf 'multi-user.target' um.
                              Stell das auf EIN Repo um. Wenn beide aktiv sind kann es Chaos geben.
                              Und schau mal, ob du ein paar der Instanzen (mqtt, modbus) einsparen kannst.
                              • ___manalishi
                                ___manalishi @ticaki last edited by
                                @ticaki Ich bin nach diesen Infos vorgegangen und das lief einige Monate einwandfrei.
                                https://haus-automatisierung.com/software/iobroker/2020/07/23/iobroker-multihost-master-slave.html
                                  @___manalishi
                                  Matthias wird es wohl richtig haben 🙂 War mir unbekannt. Irgendwo/wann hab ich das mit redis ausgeschnappt, scheint wohl falsch zu sein.
                                    arteck Developer Most Active @ticaki last edited by
                                    @ticaki sagte in Instabiles Systemverhalten:
                                    @___manalishi
                                    das geht..
                                    • ___manalishi
                                      @thomas-braun die Umstellung auf nur "Beta-Repo" und Multi-user.target" hat keine Veränderung gebracht.
                                      Ich habe soeben nach identischer Vorgehensweise gerade wieder einen neuen LXC erstellt und ein Backup wiederhergestellt. Der neue Container läuft wieder performant wie der vorherige ohne Master-Slave Konfiguration.
                                      der
                                      iobroker multihost
                                      command hat keine "disconnect" option. Ich habe daher den Folder des Slaves unter Objects gelöscht und den Slave gestoppt.
                                      iob stop
                                      iob fix
                                      iob start
                                      ausgeführt, da der Remove Button unter Hosts beim Entfernen des Slaves eine Fehlermeldung erzeugt.
                                      Bleibt ggf. durch diese Methode eine Konfiguration erhalten, die zu den Performance Problemen führt?
                                      • ___manalishi
                                        ___manalishi @arteck last edited by ___manalishi
                                        @arteck Hast Du Erfahrung min Master-Slave Betrieb und weisst ggf. wie ,am eine Konfiguration "sauber" entfernt?
                                        T arteck 2 Replies Last reply Reply Quote 0
                                          @___manalishi
                                          iob host remove nameVomHost
                                          Vorher Iobroker und alle Slave anhalten hatte das problem letzte Woche
                                            arteck Developer Most Active @___manalishi last edited by
                                            Die gibt's nicht...
                                            Das wasdu gemacht hast ist schon ok..ausserdem ein offline host verursacht keine performance probleme am andern host
                                            T ___manalishi 2 Replies Last reply Reply Quote 0
                                            1208
