    4. Tester für Zigbee Adapter 2.0.x gesucht
      MeisterQ 0 last edited by MeisterQ 0
      @Asgothian
      Wo muss ich externe Converter ablegen bei 2.0.5? Ich bekomme nur fehler.
      Ich habs schon hier /opt/iobroker/node_modules/zigbee-herdsman-converters/dist/devices und hier /opt/iobroker/iobroker-data/zigbee_0 ausprobiert.
      Bekomme leider immer Fehlermeldungen.
      zigbee.0
      	2025-03-29 18:00:58.391	error	Unable to apply converter from module: /opt/iobroker/node_modules/zigbee-herdsman-converters/dist/devices/shelly_mini1pmG4.js - the code does not run: ReferenceError: fz is not defined
      zigbee.0
      	2025-03-29 18:00:58.388	warn	Trying to run sandbox for /opt/iobroker/node_modules/zigbee-herdsman-converters/dist/devices/shelly_mini1pmG4.js
      zigbee.0
      	2025-03-29 18:00:58.388	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/toZigbee' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      zigbee.0
      	2025-03-29 18:00:58.388	warn	trying to add "tz = require(../zigbee-herdsman-converters/converters/toZigbee)" to sandbox
      zigbee.0
      	2025-03-29 18:00:58.387	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/converters/fromZigbee' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
      zigbee.0
      	2025-03-29 18:00:58.387	warn	trying to add "fz = require(../zigbee-herdsman-converters/converters/fromZigbee)" to sandbox
      Mein Converter sieht so aus:
      // shelly_mini1pm_legacy.js
      // Module laden
      const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
      const tz = require('zigbee-herdsman-converters/converters/toZigbee');
      module.exports = {
          // Fingerprint, um das Gerät zu identifizieren
          fingerprint: [
                  modelID: 'Mini1PM',
                  manufacturerName: 'Shelly',
          // Interne Beschreibung
          model: 'Mini1PM',
          vendor: 'Shelly',
          description: 'Shelly Mini1PM - Zigbee In-Wall Switch with Power Measurement',
          // Unterstützte Features (nur zu Informationszwecken)
          supports: 'on/off, power measurement',
          // Eingehende Daten
          fromZigbee: [
              fz.on_off,                 // Schaltzustände (genOnOff)
              fz.electrical_measurement, // Leistung, Spannung, Strom (haElectricalMeasurement)
              fz.metering,               // Energieverbrauch (seMetering)
          // Ausgehende Befehle
          toZigbee: [
              tz.on_off, // Schalten
      Und Eingebunden über Admin so
      • Asgothian
        Asgothian Developer @MeisterQ 0 last edited by
        @meisterq-0 der externe Konverter muss in das Verzeichnis /opt/iobroker/iobroker-data/zigbee_0
        Und ich gehe davon aus das in deinem Pfad ein 'dist' fehlt - schau mal bitte nach ob die Datei
        /opt/iobroker/iobroker-data/node_modules/zigbee-herdsman-converters/converters/toZigbee.js existiert. Wenn nein, bitte den Pfad (unterhalb zigbee-herdsman-converters) anpassen
        A.
          MeisterQ 0 @Asgothian last edited by
          @asgothian said in Tester für Zigbee Adapter 2.0.x gesucht:
          A.
          Danke. Ja das dist hat Tatsächlich gefehlt... Danke.
          Switch on und off geht. (state) aber die Energiedaten Strom, Spannung, Leistung fehlt
          // 1) Benötigte Module laden:
          const fz = require('zigbee-herdsman-converters/dist/converters/fromZigbee');
          const tz = require('zigbee-herdsman-converters/dist/converters/toZigbee');
          const exposes = require('zigbee-herdsman-converters/dist/lib/exposes');
          const e = exposes.presets;
          const ea = exposes.access;
          // 2) Definiere den Converter
          module.exports = {
              // Fingerprint: ordnet den Converter einem Gerät zu
              fingerprint: [
                      modelID: 'Mini1PM',
              model: 'Mini1PM',
              vendor: 'Shelly',
              // fromZigbee: Ankommende Daten verarbeiten
              fromZigbee: [
                  fz.metering,               // Verbrauch (seMetering)
              // toZigbee: Befehle an das Gerät senden
              toZigbee: [
                  tz.on_off, // Ein-/Ausschalten
              // exposes: Welche Datenpunkte im ioBroker/Zigbee-Adapter sichtbar sind
              exposes: [
                  e.switch(),   // An/Aus-Schalter
                  e.power(),    // Leistung (W)
                  e.current(),  // Strom (A)
                  e.voltage(),  // Spannung (V)
                  e.energy(),   // Verbrauch (kWh)
          Hast du einen Tipp für mich? (Ich weiß, der Thread ist nicht dafür da eigentlich)
          • Asgothian
            @meisterq-0 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
            Tip 1: Abwarten
            Tip 2: Device Query aktivieren
            Tip3: Poste mal das Info-Panel vom Device
              @asgothian
              Tip 1: Läuft ja nebenher.
              Tip 2: hat nichts gebracht.
              Tip 3:
              • Asgothian
                @meisterq-0 Wo hast du den externen Konverter her ? Ist in der Implementation in den Konvertern 21.13.0 noch weiterer Code ? Es scheint als ob da noch eine Konfiguration notwendig sein kann, die fehlt.
                A.
                  A.
                  Die hab ich mit hilfe von ChatGPT Plus (Modell o3-mini-high) erstellt. Ich spiele damit gerade rum. Hab den mit dem Infopanel gefüttert und mir was draus machen lassen.
                  • Asgothian
                    A.
                    schau dir auf GitHub das Projekt koenkk/zigbee-herdsman-converters an. Da gibt es eine .ts Datei die die Implementierung des Devices beschreibt. Ist besser als Chat-GPT - der Halluziniert zu viel.
                    A.
                      MeisterQ 0 @Asgothian last edited by MeisterQ 0
                      @asgothian In dem Projekt habe ich schon geschaut. Ich werde noch mal schauen was die Kiste vergessen hat hinzuzufügen. Danke
                      Hast du einen Link zur Datei, bzw einen Beispielhaften converter mit energiemessung?
                        @Asgothian So ganz blicke ich nicht wie ich dem ZHC helfen kann, neue Geräte zu unterstützen. Es gibt ja eine Anleitung bei Z2M wie man das macht, aber kann man das auf den Zigbee Adapter übertragen? Kann man die Files dafür hiermit auch generieren? Habt ihr dafür irgendwie eine Anleitung oder so?
                        • Asgothian
                          @meisterq-0 Eine klare Anleitung dazu gibt es nicht.
                          In Deinem Fall ist das aber auch nicht nötig - wenn ich das korrekt gesehen hab wird der Shelly 1 Mini in ZJC 21.13.0 unterstützt, sprich es gibt eine Datei shelly.ts auf GitHub mit dem was im externen Konverter benötigt wird.
                          Das übernehmen von externen Konvertern von Z2M hingegen ist trivial:
                          • Datei im Zigbee Datenverzeichnis ablegen (JS, nicht TS)
                          • Sicherstellen das die Pfade passen
                          • Sicherstellen das am Ende ein passendes Export Statement steht
                          • Dateinamen eintragen.
                          Der Zigbee Adapter übernimmt einen Grossteil der notwendigen Syntax-Anpassungen selber.
                          A.
                            @asgothian
                            Hab gerade geschaut. Ja der Shelly 1 Mini wird dann unterstützt. Aber es gibt auch noch den Shelly 1 Mini PM, den Shelly 1 Gen4, das Shelly BLU TRV usw die alle neu Zigbee bekommen. 3 der Geräte habe ich hier, und ich würde Koenkk da gerne unterstützen und Daten liefern, weil er ja scheinbar nicht auf Issues reagiert wenn man nicht die Infos aus der External definition postet.
                            https://github.com/Koenkk/zigbee-herdsman-converters/issues/9057
                            Das wäre der Post, aber da geht es halt wirklich nur um einen von mindestens 4 oder 5 neuen Zigbee Geräten.
                            Wie bekomme ich es dann raus?
                            slk34 created this issue in Koenkk/zigbee-herdsman-converters
                            closed [New Device Support] Shelly 1 Mini Gen4 #9057
                            • Asgothian
                              Vorschlag - wir treffen uns auf Discord, und gehen das durch. Das hier zu schreiben führt zu einem 3-Seitigen Monolog.
                              A.
                                @asgothian In welchem Channel? Nutze Discord nicht oft. Hab aber jetzt nicht so viel zusammenhängende Zeit
                                • Asgothian
                                  Asgothian Developer last edited by
                                  @meisterq-0 bin gerade in 'lounge'. Wir können uns auch verabreden
                                  A.
                                    @asgothian Danke für das nette Gespräch gestern 🙂
                                    Du meintest gestern, dass in der neuen Version des Adapters auch die Converter vom Herdsman direkt genutzt werden können weil der Adapter sich Fehlende Teile dazudenkt.
                                    Ich hab gerade im Repo vom Herdsman mal nach der shelly.ts geschaut die so aussieht:
                                    import * as m from "../lib/modernExtend";
                                    import type {DefinitionWithExtend} from "../lib/types";
                                    export const definitions: DefinitionWithExtend[] = [
                                            zigbeeModel: ["Mini1"],
                                            model: "S4SW-001X8EU",
                                            vendor: "Shelly",
                                            description: "Mini gen 4",
                                            extend: [m.onOff({powerOnBehavior: false})],
                                    Kann ich die jetzt so copy&paste in /opt/iobroker/iobroker-data/zigbee_0 einfügen und als externen converter einfügen, oder muss ich da noch was anpassen? Weil so gibt es die Meldung:
                                    zigbee.0
                                    2025-03-31 09:58:41.767	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/types' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                    zigbee.0
                                    2025-03-31 09:58:41.767	warn	trying to add "type {DefinitionWithExtend} = require(../zigbee-herdsman-converters/lib/types)" to sandbox
                                    zigbee.0
                                    2025-03-31 09:58:41.767	error	Sandbox error: Cannot find module '../zigbee-herdsman-converters/lib/modernExtend' Require stack: - /opt/iobroker/node_modules/iobroker.zigbee/main.js
                                    zigbee.0
                                    2025-03-31 09:58:41.766	warn	trying to add "m = require(../zigbee-herdsman-converters/lib/modernExtend)" to sandbox
                                    Nachtrag noch: Ich hab den Adapter gestern mal neugestartet und die divisoren haben auch nach dem Neustart noch gepasst.
                                    • Asgothian
                                      Asgothian Developer @MeisterQ 0 last edited by Asgothian
                                      Die 'Neue' Version ist die die ich aktuell bei mir in der Mache hab - die hast du noch nicht auf Deinem System.
                                              vendor: "Shelly",
                                      Die Meldung ist klar - über die Lösung hatten wir auch gesprochen - bei einigen Installationen (nicht sicher ob bei allen) ist ein 'unterverzeichnis' mit eingezogen, sprich die eigentlichen Bibliotheken liegen nicht unter zigbee-herdsman-converters/lib/... sondern unter zigbee-herdsman-converters/dist/lib/.... Sprich - ein Einfügen eines dist/ in die Pfade in den Import statements ist (noch) notwendig.
                                      Zusätzlich wirst Du wahrscheinlich am Ende der Datei den Ausdruck
                                      module.exports = definitions; benötigen
                                      Fein - das bedeutet wir können Deinen Konverter direkt als Issue am zigbee-herdsman-converters Projekt eintragen. Als Issue, nicht als PR, da wir nicht das neue Muster mit 'extend' sondern das alte muster mit expose, fromZigbee und toZigbee nutzen.
                                      A.
                                        @asgothian
                                        Ich habe diesen Thread gefunden:
                                        https://github.com/Koenkk/zigbee2mqtt/issues/26852#issuecomment-2766198573 Scheinbar wird sich hier schon um das Gerät gekümmert.
                                        Ich würde trotzdem ein Issue aufmachen?
                                        marce14-git created this issue in Koenkk/zigbee2mqtt
                                        open [New device support]: Shelly 1PM Mini Gen4 #26852
                                        • Asgothian
                                          @meisterq-0 Ich würde keinen neuen issue aufmachen - aber du kannst deinen Konverter in dem Thread posten und deine Erfahrungen damit beschreiben.
                                          A.
                                            @asgothian Nochmals Danke für die Hilfe 🙂
                                            zigbee 2.0.1
                                            50
                                            525
                                            70075
