    3. Off Topic
    4. Proxmox
    5. Problem mit Proxmox Speicher
      guitardoc @ticaki last edited by
      @ticaki Meinst du das?
        ticaki @guitardoc last edited by
        @guitardoc
        Verwirrend - kannst du mal die ausgabe von mount zeigen?
          @ticaki Wie muss ich das machen?
            ticaki last edited by ticaki
            natürlich aus der proxmox shell und nicht einem container 🙂
              guitardoc @ticaki last edited by guitardoc
              @ticaki
              mn@iobroker:~$ mount
              /dev/mapper/pve-vm--101--disk--1 on / type ext4 (rw,relatime,stripe=16)
              none on /dev type tmpfs (rw,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64)
              proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
              proc on /proc/sys/net type proc (rw,nosuid,nodev,noexec,relatime)
              proc on /proc/sys type proc (ro,relatime)
              proc on /proc/sysrq-trigger type proc (ro,relatime)
              sysfs on /sys type sysfs (ro,nosuid,nodev,noexec,relatime)
              sysfs on /sys/devices/virtual/net type sysfs (rw,nosuid,nodev,noexec,relatime)
              fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
              /dev/mapper/pve-root on /dev/ttyACM0 type ext4 (rw,relatime,errors=remount-ro)
              proc on /dev/.lxc/proc type proc (rw,relatime)
              sys on /dev/.lxc/sys type sysfs (rw,relatime)
              none on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
              lxcfs on /proc/cpuinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/diskstats type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/loadavg type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/meminfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/slabinfo type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/stat type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/swaps type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /proc/uptime type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              lxcfs on /sys/devices/system/cpu type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
              udev on /dev/full type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
              udev on /dev/null type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
              udev on /dev/random type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
              udev on /dev/tty type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
              udev on /dev/urandom type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
              udev on /dev/zero type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
              devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026)
              devpts on /dev/ptmx type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026)
              devpts on /dev/console type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026)
              devpts on /dev/tty1 type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026)
              devpts on /dev/tty2 type devpts (rw,nosuid,noexec,relatime,gid=100005,mode=620,ptmxmode=666,max=1026)
              none on /proc/sys/kernel/random/boot_id type tmpfs (ro,nosuid,nodev,noexec,relatime,size=492k,mode=755,uid=100000,gid=100000,inode64)
              tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,uid=100000,gid=100000,inode64)
              tmpfs on /run type tmpfs (rw,nosuid,nodev,size=13140064k,nr_inodes=819200,mode=755,uid=100000,gid=100000,inode64)
              tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,uid=100000,gid=100000,inode64)
              mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
              ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
              ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
              ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
              ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
              tmpfs on /run/user/1001 type tmpfs (rw,nosuid,nodev,relatime,size=6570032k,nr_inodes=1642508,mode=700,uid=101001,gid=101001,inode64)
              mn@iobroker:~$
              Oder meintest du mount in der Proxmox-Shell?
                @guitardoc
                Das ist die aus einem Container 🙂 ich meinte im pve
                  @ticaki
                  Linux proxmox 6.8.12-9-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-9 (2025-03-16T19:18Z) x86_64
                  The programs included with the Debian GNU/Linux system are free software;
                  the exact distribution terms for each program are described in the
                  individual files in /usr/share/doc/*/copyright.
                  Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                  permitted by applicable law.
                  Last login: Mon Mar 31 23:25:49 CEST 2025 on pts/0
                  root@proxmox:~# mount
                  sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
                  proc on /proc type proc (rw,relatime)
                  udev on /dev type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
                  devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
                  tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=6570032k,mode=755,inode64)
                  /dev/mapper/pve-root on / type ext4 (rw,relatime,errors=remount-ro)
                  securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
                  tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
                  tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
                  cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
                  pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
                  efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
                  bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
                  systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=10286)
                  hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
                  debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
                  tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
                  configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
                  /dev/nvme0n1p2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
                  /dev/sda on /mnt/sda type ext4 (rw,relatime)
                  binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
                  lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
                  sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
                  /dev/fuse on /etc/pve type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other)
                  tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=6570032k,nr_inodes=1642508,mode=700,inode64)
                  root@proxmox:~#
                    ticaki @guitardoc last edited by ticaki
                    @guitardoc sagte in Problem mit Proxmox Speicher:
                    Ich weiß jetzt leider nicht so ganz wie ich dir helfen soll. Das Problem ist das /mnt/sda deinen Speicher gefüllt hat... ABER da ist die externe Platte gemoutet. Wenn du da was löschst hilft das nicht.
                    • externe Platte aus Proxmox entfernen, dann
                    • umount /mnt/sda
                    • den Inhalt von /mnt/sda löschen,
                    • mount /mnt/sda
                    • die externe Platte wieder in proxmox hinzufügen.
                    Das geht aber so nur im besten Fall.
                      @ticaki
                      Hmm, da bräuchte ich für jeden Schritt eine genaue Anleitung was ich wo machen muss… Geht das irgendwie?
                      T G 2 Replies Last reply Reply Quote 0
                        @guitardoc
                        Ich fühle mich in der Materie nicht wirklich sicher genug um Anleitungen zu schreiben. Versuchen kann ich es aber:
                        Geh mal ins Datacenter und Storage und entferne dort die externe ssd
                        Dann gibts du in der PVE shell umount /mnt/sda ein und zeigst die ausgabe.
                          guitardoc @guitardoc last edited by
                          Ich habe hier noch was entdeckt - das kann doch nicht richtig sein, oder?
                            @guitardoc
                            Das ist eine Möglichkeit, da kann man nicht sagen das es falsch ist. Geh halt auf edit und wähle es ab. Ändert aber nichts an dem was ich vorher gesagt habe.
                              @ticaki Bevor ich die externe SSD rausschmeiße - wie kann ich die dann wieder einfügen? In der Liste unter add finde ich da nichts:
                                @guitardoc
                                Directory - steht doch auch jetzt im type
                                  @ticaki said in Problem mit Proxmox Speicher:
                                  So, hab ich gemacht. eine Ausgabe kam nicht.
                                    @guitardoc
                                    Was sagt 'du' mit /mnt siehe oben
                                      @ticaki
                                      root@proxmox:~# du /mnt
                                      4       /mnt/vzsnap0
                                      82217832        /mnt/sda/dump
                                      4       /mnt/sda/private
                                      4       /mnt/sda/snippets
                                      4       /mnt/sda/template/iso
                                      4       /mnt/sda/template/cache
                                      12      /mnt/sda/template
                                      4       /mnt/sda/images
                                      82217860        /mnt/sda
                                      82217868        /mnt
                                      root@proxmox:~#
                                        @guitardoc
                                        jetzt bitte vorsichtig und doppelt prüfen:
                                        rm -rf /mnt/sda/*
                                        in der pve shell eingeben.
                                        muss jetzt für 15 minuten afk gehen, bin gleich wieder da.
                                          @ticaki Hab’s eingegeben. Eine Ausgabe kam nicht.
                                          EDIT:
                                          4       /mnt/vzsnap0
                                          4       /mnt/sda
                                          12      /mnt
                                          root@proxmox:~#
                                          EDIT nochmal: Ich vermute jetzt mount /mnt/sda in der PVE Shell?
                                            @guitardoc
                                            jetzt mount /mnt/sda und dann als storage hinzufügen
                                            anschließend alle backup automatiionen editieren und den pfad richtig setzen.
                                            1.0k
                                            5846
