    3. Off Topic
    4. Proxmox
    5. Problem mit Proxmox Speicher
      ticaki @guitardoc last edited by
      @guitardoc
      Das ist die aus einem Container 🙂 ich meinte im pve
        guitardoc @ticaki last edited by
        @ticaki
        Linux proxmox 6.8.12-9-pve #1 SMP PREEMPT_DYNAMIC PMX 6.8.12-9 (2025-03-16T19:18Z) x86_64
        The programs included with the Debian GNU/Linux system are free software;
        the exact distribution terms for each program are described in the
        individual files in /usr/share/doc/*/copyright.
        Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
        permitted by applicable law.
        Last login: Mon Mar 31 23:25:49 CEST 2025 on pts/0
        root@proxmox:~# mount
        sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
        proc on /proc type proc (rw,relatime)
        udev on /dev type devtmpfs (rw,nosuid,relatime,size=32816220k,nr_inodes=8204055,mode=755,inode64)
        devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
        tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=6570032k,mode=755,inode64)
        /dev/mapper/pve-root on / type ext4 (rw,relatime,errors=remount-ro)
        securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
        tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
        tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k,inode64)
        cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime)
        pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
        efivarfs on /sys/firmware/efi/efivars type efivarfs (rw,nosuid,nodev,noexec,relatime)
        bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
        systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=10286)
        mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
        hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
        debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
        tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
        fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
        configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
        ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        /dev/nvme0n1p2 on /boot/efi type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
        /dev/sda on /mnt/sda type ext4 (rw,relatime)
        ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
        binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
        lxcfs on /var/lib/lxcfs type fuse.lxcfs (rw,nosuid,nodev,relatime,user_id=0,group_id=0,allow_other)
        sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
        /dev/fuse on /etc/pve type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other)
        tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=6570032k,nr_inodes=1642508,mode=700,inode64)
        root@proxmox:~#
          ticaki @guitardoc last edited by ticaki
          @guitardoc sagte in Problem mit Proxmox Speicher:
          Ich weiß jetzt leider nicht so ganz wie ich dir helfen soll. Das Problem ist das /mnt/sda deinen Speicher gefüllt hat... ABER da ist die externe Platte gemoutet. Wenn du da was löschst hilft das nicht.
          • externe Platte aus Proxmox entfernen, dann
          • umount /mnt/sda
          • den Inhalt von /mnt/sda löschen,
          • mount /mnt/sda
          • die externe Platte wieder in proxmox hinzufügen.
          Das geht aber so nur im besten Fall.
            @ticaki
            Hmm, da bräuchte ich für jeden Schritt eine genaue Anleitung was ich wo machen muss… Geht das irgendwie?
            T G 2 Replies Last reply Reply Quote 0
              @guitardoc
              Ich fühle mich in der Materie nicht wirklich sicher genug um Anleitungen zu schreiben. Versuchen kann ich es aber:
              Geh mal ins Datacenter und Storage und entferne dort die externe ssd
              Dann gibts du in der PVE shell umount /mnt/sda ein und zeigst die ausgabe.
                guitardoc @guitardoc last edited by
                Ich habe hier noch was entdeckt - das kann doch nicht richtig sein, oder?
                  @guitardoc
                  Das ist eine Möglichkeit, da kann man nicht sagen das es falsch ist. Geh halt auf edit und wähle es ab. Ändert aber nichts an dem was ich vorher gesagt habe.
                    @ticaki Bevor ich die externe SSD rausschmeiße - wie kann ich die dann wieder einfügen? In der Liste unter add finde ich da nichts:
                      @guitardoc
                      Directory - steht doch auch jetzt im type
                        @ticaki said in Problem mit Proxmox Speicher:
                        So, hab ich gemacht. eine Ausgabe kam nicht.
                          @guitardoc
                          Was sagt 'du' mit /mnt siehe oben
                            @ticaki
                            root@proxmox:~# du /mnt
                            4       /mnt/vzsnap0
                            82217832        /mnt/sda/dump
                            4       /mnt/sda/private
                            4       /mnt/sda/snippets
                            4       /mnt/sda/template/iso
                            4       /mnt/sda/template/cache
                            12      /mnt/sda/template
                            4       /mnt/sda/images
                            82217860        /mnt/sda
                            82217868        /mnt
                            root@proxmox:~#
                              @guitardoc
                              jetzt bitte vorsichtig und doppelt prüfen:
                              rm -rf /mnt/sda/*
                              in der pve shell eingeben.
                              muss jetzt für 15 minuten afk gehen, bin gleich wieder da.
                                guitardoc @ticaki last edited by guitardoc
                                @ticaki Hab’s eingegeben. Eine Ausgabe kam nicht.
                                EDIT:
                                4       /mnt/vzsnap0
                                4       /mnt/sda
                                12      /mnt
                                root@proxmox:~#
                                EDIT nochmal: Ich vermute jetzt mount /mnt/sda in der PVE Shell?
                                  @guitardoc
                                  jetzt mount /mnt/sda und dann als storage hinzufügen
                                  anschließend alle backup automatiionen editieren und den pfad richtig setzen.
                                    @ticaki
                                    root@proxmox:~# mount /mnt/sda
                                    4       /mnt/vzsnap0
                                    4       /mnt/sda/snippets
                                    4       /mnt/sda/private
                                    92966180        /mnt/sda/dump
                                    4       /mnt/sda/images
                                    16      /mnt/sda/lost+found
                                    92966224        /mnt/sda
                                    92966232        /mnt
                                    root@proxmox:~#
                                    Hmm, jetzt ist doch wieder so viel da drauf? Oder ist das jetzt richtig?
                                      @guitardoc
                                      gib df ein. Ist jetzt aber richtig.
                                        @ticaki
                                        root@proxmox:~# df
                                        Filesystem           1K-blocks     Used Available Use% Mounted on
                                        udev                  32816220        0  32816220   0% /dev
                                        tmpfs                  6570032     1900   6568132   1% /run
                                        /dev/mapper/pve-root  98497780 11336784  82111448  13% /
                                        tmpfs                 32850160    34320  32815840   1% /dev/shm
                                        tmpfs                     5120        0      5120   0% /run/lock
                                        efivarfs                   256       40       212  16% /sys/firmware/efi/efivars
                                        /dev/nvme0n1p2         1046512      344   1046168   1% /boot/efi
                                        /dev/fuse               131072       24    131048   1% /etc/pve
                                        tmpfs                  6570032        0   6570032   0% /run/user/0
                                        /dev/sda             245024372 92966232 139538804  40% /mnt/sda
                                        root@proxmox:~#
                                          @guitardoc
                                          13% auflastung auf root
                                          passt.
                                          du zeigt dir auf dateiebene an, was was verbraucht unabhängig von dem wo
                                          df zeigt dir das wo an
                                          EDIT: mit wo meine ich Festplatten usw.
                                            @ticaki Super!!!
                                            Nun die Platte wieder dazu. Was muss ich da hier eingeben?
                                            5842
