    4. RFlink (LOS GEHT ES ) Bestellung d.Hardware (20€) + 5€ Spende an Forum f.d. Adapter (crowdfunding like :-)
    • I
      intrahorst last edited by
      Hallo liebe ioBrokers 🙂
      ich habe IOBroker ganz gut laufen und bin soweit glücklich 🙂
      Jetzt habe ich auf anraten hier im Forum RFLink Module gebaut (433 + 868Mhz).
      Leider werden beide Adapter nach kurzer Zeit immer Gelb:
      ~~![](</s><URL url=)http://fs1.directupload.net/images/180106/xudadl2g.png" />
      Die Logs spiegeln es auch wieder:
      rflink.0	2018-01-06 21:24:15.373	info	List of port: [{"comName":"/dev/ttyACM0","manufacturer":"Arduino__www.arduino.cc_","serialNumber":"Arduino__www.arduino.cc__Arduino_Mega_2560_7543931323735131C1A2","pnpId":"usb-Arduino__www.arduino.c
      rflink.0	2018-01-06 21:24:10.993	info	List of port: [{"comName":"/dev/ttyACM0","manufacturer":"Arduino__www.arduino.cc_","serialNumber":"Arduino__www.arduino.cc__Arduino_Mega_2560_7543931323735131C1A2","pnpId":"usb-Arduino__www.arduino.c
      rflink.1	2018-01-06 21:24:05.832	info	List of port: [{"comName":"/dev/ttyACM0","manufacturer":"Arduino__www.arduino.cc_","serialNumber":"Arduino__www.arduino.cc__Arduino_Mega_2560_7543931323735131C1A2","pnpId":"usb-Arduino__www.arduino.c
      rflink.1	2018-01-06 19:35:17.930	info	disconnected
      rflink.1	2018-01-06 19:25:18.358	info	done rflink.1.channels.RTS_1
      rflink.1	2018-01-06 19:25:18.329	info	Add rflink.1.channels.RTS_1.BLIND_01
      rflink.1	2018-01-06 19:25:18.238	info	Add rflink.1.channels.RTS_1.BLIND_STOP_01
      rflink.1	2018-01-06 19:25:18.148	info	Add rflink.1.channels.RTS_1
      rflink.1	2018-01-06 19:25:17.928	info	Connected
      rflink.1	2018-01-06 18:16:03.715	info	disconnected
      rflink.0	2018-01-06 18:15:58.226	info	disconnected
      rflink.1	2018-01-06 18:06:03.714	info	Connected
      rflink.1	2018-01-06 18:06:02.777	info	Serial port opened
      rflink.1	2018-01-06 18:06:02.486	info	starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.rflink, node: v6.12.0
      host.ioBroker-Pi	2018-01-06 18:05:59.613	info	instance system.adapter.rflink.1 started with pid 17386
      rflink.0	2018-01-06 18:05:58.225	info	Connected
      rflink.0	2018-01-06 18:05:57.296	info	Serial port opened
      host.ioBroker-Pi	2018-01-06 18:05:57.174	info	instance system.adapter.rflink.1 terminated with code 0 (OK)
      rflink.1	2018-01-06 18:05:57.153	info	terminating
      rflink.0	2018-01-06 18:05:57.041	info	starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.rflink, node: v6.12.0
      host.ioBroker-Pi	2018-01-06 18:05:57.092	info	stopInstance system.adapter.rflink.1 killing pid 17335
      host.ioBroker-Pi	2018-01-06 18:05:57.090	info	object change system.adapter.rflink.1
      rflink.1	2018-01-06 18:05:54.472	info	List of port: [{"comName":"/dev/ttyACM0","manufacturer":"Arduino__www.arduino.cc_","serialNumber":"Arduino__www.arduino.cc__Arduino_Mega_2560_7543931323735131C1A2","pnpId":"usb-Arduino__www.arduino.c
      host.ioBroker-Pi	2018-01-06 18:05:54.095	info	instance system.adapter.rflink.0 started with pid 17367
      host.ioBroker-Pi	2018-01-06 18:05:51.646	info	instance system.adapter.rflink.0 terminated with code 0 (OK)
      rflink.0	2018-01-06 18:05:51.620	info	terminating
      host.ioBroker-Pi	2018-01-06 18:05:51.575	info	stopInstance system.adapter.rflink.0 killing pid 17316
      host.ioBroker-Pi	2018-01-06 18:05:51.573	info	object change system.adapter.rflink.0
      rflink.0	2018-01-06 18:05:46.432	info	List of port: [{"comName":"/dev/ttyACM0","manufacturer":"Arduino__www.arduino.cc_","serialNumber":"Arduino__www.arduino.cc__Arduino_Mega_2560_7543931323735131C1A2","pnpId":"usb-Arduino__www.arduino.c
      rflink.0	2018-01-06 18:05:34.268	info	List of port: [{"comName":"/dev/ttyACM0","manufacturer":"Arduino__www.arduino.cc_","serialNumber":"Arduino__www.arduino.cc__Arduino_Mega_2560_7543931323735131C1A2","pnpId":"usb-Arduino__www.arduino.c
      rflink.0	2018-01-06 18:02:49.101	info	disconnected
      rflink.0	2018-01-06 17:52:49.506	info	done rflink.0.channels.TRC02RGB_1
      rflink.0	2018-01-06 17:52:49.478	info	Add rflink.0.channels.TRC02RGB_1.RGBW_ff
      rflink.0	2018-01-06 17:52:49.368	info	Add rflink.0.channels.TRC02RGB_1.SWITCH_ff
      rflink.0	2018-01-06 17:52:49.260	info	Add rflink.0.channels.TRC02RGB_1
      rflink.1	2018-01-06 17:50:25.435	info	disconnected
      rflink.0	2018-01-06 17:48:14.760	info	done rflink.0.channels.BofuMotor_1
      rflink.0	2018-01-06 17:48:14.727	info	Add rflink.0.channels.BofuMotor_1.SWITCH_0f
      rflink.0	2018-01-06 17:48:14.629	info	Add rflink.0.channels.BofuMotor_1
      rflink.1	2018-01-06 17:40:25.434	info	Connected
      rflink.1	2018-01-06 17:40:24.497	info	Serial port opened
      rflink.1	2018-01-06 17:40:24.282	info	starting. Version 1.1.6 in /opt/iobroker/node_modules/iobroker.rflink, node: v6.12.0
      host.ioBroker-Pi	2018-01-06 17:40:21.432	info	instance system.adapter.rflink.1 started with pid 17335
      hat einer irgend einen Tipp für mich?~~
      • Matzebhv
        Matzebhv last edited by
        Moin,
        der RF-link geht offline wenn er längere Zeit nix empfängt. Du kannst im Adapter den Verbindungs-Timeout erhöhen.
        Normalerweise wird's bei Datenempfang aber von selbst wieder grün.
        Matze
          knopers1 last edited by
          richtig, und genau so verhält sich der Adapter bei mir. Wenn Du etwas sendest, wird es auch automatisch grün.
          Von daher alles i.O. Funktion ist die ganze Zeit gegeben, grün oder gelb-spielt keine Rolle…
            passuff last edited by
            @hg6806:
            Weiß jemand ob man damit auch Rollladenmotoren von Jarolift (433MHz) ansteuern kann?
            Dann hätte ich def. auch Interesse `
            Fände ich auch super.
            Hier hat jemand die Jarolift Kommunikation für fhem analysiert:
            http://www.bastelbudenbuben.de/2017/04/ … f-motoren/
            Eventuell ist ja jemand mit Interesse in der Lage das für iobroker umzusetzen...
              DKM last edited by
              @MArkl.:
              Hallo Matox,
              ich bin derzeit noch absoluter ioBroker Neuling.
              Gibts eigentlich noch die mögliochkeit bei dir den RFLink zu bestellen?
              Ich musste leider feststellen das ich mit meinem nanoCUL433mhz leider nicht weit komme meine bisher vorhandenen Wetterstationen auszulesen.
              Viele Grüße
              MarkL. `
              Hallo Maxtox,
              ich hätte auch Interesse. Vorher habe ich aber noch ein paar Fragen zur Hardware:
              1. Kann man den Sender/Empfänger austauschen, oder ist dieser verlötet (oder sprechen andere Dinge dagegen)
              Problem ist, dass ich einen sehr leistungsstarken Sender und Empfänger benötige
              2. Kann die von dir erstellte Hardware auch nur im Sendungsmodus arbeiten?
              3. Ist die Prozedur für die Bestellung noch gleich? (25 € per Paypal und Adresse per PN)
              Liebe Grüße
                DKM last edited by
                Da der Preis mittlerweile auf 32 € angestiegen ist (gem. PN von Maxtox) und meine Fragen zwecks Abänderung auch nicht beantwortet wurden, suche ich Alternativen. Da sich in diesem Thread viele mit Funk beschäftigten, schreibe ich einfach hier weiter. Sollte dies nicht ok sein, bitte ich um eine kurze Nachricht eines Mods, ich werde dann natürlich einen neuen Thread eröffnen.
                Ich benötige nur einen starken Empfänger, da alle Geräte nur Senden (Türalarm, Bewegungsmelder, etc.) Alle Geräte laufen auf 433MHz. Ich suche eine einfache aber gute Lösung.
                Danke 🙂
                  Hast Du wenigstens etwas im Thema durchgelesen?
                  Ich habe auf Seite 5 meine Hardware sogar mit Bild verlinkt.
                  RXB6 433 Mhz Superheterodyne Funkempfänger brauchst Du. Damit bekomme ich selbst die Wetterstationen der Nachbarn in den IOBroker herein.
                    DKM last edited by
                    @knopers1:
                    RXB6 433 Mhz Superheterodyne Funkempfänger brauchst Du. Damit bekomme ich selbst die Wetterstationen der Nachbarn in den IOBroker herein. ` Habe ich, habe auch einen bestellt. Aber kann ja auch sein, dass andere auch gute Lösungen haben.
                    Gesendet von meinem SM-G930F mit Tapatalk
                      dann verstehe ich dein Problem nicht…. Bau das Teil erst ein was Du bestellt hast! Der RXB6 gehört zu den besten Empfängern, damit sollte an sich nichts schief laufen....
                        DKM last edited by
                        @knopers1:
                        dann verstehe ich dein Problem nicht…. Bau das Teil erst ein was Du bestellt hast! Der RXB6 gehört zu den besten Empfängern, damit sollte an sich nichts schief laufen.... `
                        Der läuft wunderbar - und die Lösung ist echt kostengünstig. Kannst du mir evtl. auch einen Türsensor empfehlen, der beim schließen auch ein Signal sendet? Meine senden nur ein Signal, wenn der Kontakt gelöst wird, sprich wenn die Tür geöffnet wird.
                        • N
                          NemoN last edited by
                          @DKM:
                          Der läuft wunderbar - und die Lösung ist echt kostengünstig. Kannst du mir evtl. auch einen Türsensor empfehlen, der beim schließen auch ein Signal sendet? Meine senden nur ein Signal, wenn der Kontakt gelöst wird, sprich wenn die Tür geöffnet wird. `
                          https://www.gearbest.com/access-control/pp_593451.html
                          läuft bei mir 1a
                            DKM last edited by
                            @NemoN:
                            @DKM:
                            läuft bei mir 1a `
                            Danke für den Hinweis, habe mir welche bestellt. Ich hoffe das der Rest von Gearbest auch bald ankommt.
                            Ich habe den Türöffner von SONOFF (DW1) probiert. Der funktioniert auch super. Weiterhin habe ich von DIGOO einen Bewegungsmelder und 3 Türsensoren. Die Reichweite bei allen Geräten (ohne zusätzliche Antenne am Empfänger) ist bombastisch. Der Empfänger hängt im 1. OG, die Sensoren im EG und im Keller. Dazwischen sind Rigipswänder, Steinwände, ein Kamin und ein Kachelofen.
                              amnesia106 last edited by
                              @DKM:
                              Weiterhin habe ich von DIGOO einen Bewegungsmelder und 3 Türsensoren. Die Reichweite bei allen Geräten (ohne zusätzliche Antenne am Empfänger) ist bombastisch. Der Empfänger hängt im 1. OG, die Sensoren im EG und im Keller. Dazwischen sind Rigipswänder, Steinwände, ein Kamin und ein Kachelofen. `
                              Welche Türkontakte nutzt du von Digoo? Die von der Alarmanlage DG-HOSA?
                                DKM last edited by
                                Diese hier
                                <url url="https://m.banggood.com/Digoo-DG-HOSA-433MHz-Window-Door-Sensor-PIR-Detector-Wireless-Remote-Controller-External-Siren-p-1163239.html?rmmds=search[img]https://uploads.tapatalk-cdn.com/20180127/d2d46246d5f66648f6f8b558b3bbc9ec.jpg"><link_text text="https://m.banggood.com/Digoo-DG-HOSA-43 … bbc9ec.jpg">https://m.banggood.com/Digoo-DG-HOSA-433MHz-Window-Door-Sensor-PIR-Detector-Wireless-Remote-Controller-External-Siren-p-1163239.html?rmmds=search
                                Gesendet von meinem SM-G930F mit Tapatalk</link_text></url>
                                  welche Werte bringen die Sensoren? Ausgelesen mit dem RXB6? Ist die Übertragung veschlüsselt oder irgendwie codiert, oder wie bekomme ich den ins iobroker?
                                    DKM last edited by
                                    Falls du noch gar nichts im Bereich 433MHz eingerichtet hat, schau in den Spoiler
                                    ! Ich habe folgende Komponenten im Einsatz:
                                    ! Raspberry Pi 2b mit ioBroker
                                    ! Elegoo Kompatibler Mikrocontroller Mega2560R3 Board mit ATmega2560
                                    ! WINGONEER RXB6 433Mhz Superheterodyne Wireless Receiver Modul
                                    ! Die Komponenten werden wie folgt verkabelt:
                                    ! GND GND
                                    ! DATA Pin 19 RX1
                                    ! DER -
                                    ! +5V Pin 16 TX2
                                    ! +5V -
                                    ! GND -
                                    ! GND -
                                    ! ANT 17 cm Kupferdraht (ich habe "nur" ein 15 cm Male-Female Kabel vom Raspberry angeschlossen
                                    ! Dann nach Anleitung die Firmware flashen und das ganze an den Raspberry anschließen.
                                    ! In ioBroker dann den RFLink Adapter installieren und den passenden Port auswählen
                                    Im Adapter muss der Lernmodus aktiviert sein, dann nimmst du den Sensor und hältst die Kontakte zusammen. Da der DG-HOSA nur ein Signal sendet, wenn der Kontakt unterbrochen wird, verfährst du auch so beim anlernen - du ziehst die beiden Teile auseinander, bis die rote LED leuchtet.
                                    Der Adapter sollte nun das Signal empfangen haben und du kannst es dann weiter verwenden.
                                    Ich hoffe ich konnte dir helfen.
                                    • 2
                                      2hot4you last edited by
                                      Als Neuling habe ich zum RF Link eine Frage zur Reichweite.
                                      Habe heute die Hardware bekommen und zusammengebaut. Nach ein paar Anlaufschwierigkeiten läuft alles.
                                      Nur mit der Reichweite bin ich überhaupt nicht zufrieden, quasi ein Raum weiter kein Empfang. Jemand ne Idee ?
                                      Folgendes habe ich gekauft : RFLink 433.92 / Arduino / Antenna/ USB cable
                                        hmm, mit der Hardware kann man schon fast nichts beim Zusammenbau falsch machen….
                                        Ich habe ein RXB6 Empfänger (sehe vorherige Post) in Verbindung mit FST FS1000A Sender.
                                        Das Teil liegt in einem Serverrack 1OG, verschlossen hinter der Tür und Sendet fleißig nach EG oder 2OG ohne Probleme. Als Antenne habe ich einfach ein Breadboard Kabel für Arduino auf die passende länge zugeschnitten. Es geht über unzählige Wände und Türe durch.
                                        Ich kann mir nicht vorstellen, dass es mit deiner Hardware schlechter funktionieren sollte.
                                        Hast Du sauber gelötet? (kalte Lötstellen?) Evtl. hast Du es vorher falsch zusammengesteckt? (Hardwareschaden?)
                                        • 2
                                          Ich habe noch mal alles gecheckt, von der Hardware ist alles OK. Trotzdem verstehe ich das ganze mit
                                          dem RF Link noch nicht so ganz. Wenn ich neben dem Geräte eine Fernbedienung anlerne, kann ich
                                          z.B. über das VIS eine 433 MHZ Steckdose die in einem anderen Raum steht schalten.
                                          Ich möchte aber z.B. eine Sonoff S20 über eine 433 MHZ Fernbedienung steuern. Das klappt nur, wenn ich
                                          neben dem RF Link stehe. Das heisst doch, dass die Antenne auf dem RF Link nur zum senden ist. ??
                                          Muss ich da noch was erweitern ?
                                            Normalerweise besitzt die RF-Link-Hardware zwei module:
                                            1x Sender
                                            1x Empfänger.
                                            und an jedem ist eine Antenne.
                                            Was bei dir jetzt genau verbaut ist kann ich auf dem kleinen Bild nicht erkennen.
                                            Rainer
                                            698
                                            200397
