    • Armilar
      Armilar Most Active Forum Testing @Armilar last edited by Armilar
      @armilar
      Update v4.6.0.1
      Das Lights Update...
      https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/NsPanelTs.ts
      Hierfür bitte den unteren Teil austauschen:
      Konfigurationsbeispiele aus den Abbildungen
      let Test_Color_Lights_1: PageType =
          type: 'cardEntities',
          useColor: true,
          heading: 'Test Color Lights 1',
          'items': [
                  name: 'HUE (CT=Kelvin)', // HUE Channel - Philips WiZ GU10 über matter.0 - Color-Temperature in Kelvin
                  icon: 'lightbulb-on',
                  icon2: 'lightbulb-outline',
                  offColor: Off,
                  minValueColorTemp: 2203, // Kelvin = Warmweiß
                  maxValueColorTemp: 6536, // Kelvin = Kaltweiß
                  interpolateColor: true,
                  modeList: ["Color", "Ocean", "Romantik", "Sonnenuntergang", "Party", "Kamin", "Gemütlich", "Wald", "Pastellfarben", "Aufwachen", "Schlafenszeit", "Warmweiß", "Tageslicht",
                             "Kaltweiß", "Nachtlicht", "Fokus", "Entspannen", "Echte Farben", "Fernsehzeit", "Pflanzenwachstum", "Frühling", "Sommer", "Herbst", "Tieftauchgang", "Dschungel",
                             "Mojito", "Club", "Weihnachten", "Halloween", "Kerzenlicht", "Goldenes Weiß", "Impuls", "Steampunk"],
                  inSel_ChoiceState: true
                  name: 'RGB Hex (CT=Mired)', // RGBsingle Channel - IKEA Tradfri GU10 über zigbee.0 - Color-Temperature in Mired
                  offColor: Off,
                  minValueColorTemp: 500, // Mired = Warmweiß = 1.000.000 / 2000 K = 500 Mired
                  maxValueColorTemp: 153, // Mired = Kaltweiß = 1.000.000 / 6536 K = 153 Mired
                  modeList: ["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"],
                  name: 'RGB (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired
                  offColor: Off,
              { //Übersetzungsdatenpunkt für XY in 0_useedata schreibt in X, Y von zigbee.0
                  name: 'CIE (CT=Mired)', // RGB Channel - E14 Livarno Home Color über zigbee.0 - Color-Temperature in Mired
                  offColor: Off,
      let Test_CT_Lights_1: PageType =
          useColor: true,
          heading: 'Test CT Lights 1',
          'items': [
                  name: 'Socket', // Socket Channel - Smart-Plug über sonoff.0
                  onColor: MSGreen,
                  offColor: HMIOff,
                  icon: 'power-plug',
                  icon2: 'power-plug-outline'
                  name: 'Light', // Light Channel - Shelly 1L über shelly.0
                  onColor: On,
                  offColor: Off,
                  name: 'Dimmer', // Dimmer Channel - IKEA Tradfri GU10 über zigbee.0
                  name: 'CT (CT=Mired)', // CT Channel - Livarno Home GU10 über zigbee.0
                  offColor: Off,
      NSPanelTS.ts
      • Der Alias-Channel CIE (XY) kann ebenfalls verwendet werden
      • Die Icons interpolieren jetzt Color mit Brightness und Color-Temperature mit Brightness
      • Alle Lampen verfügen jetzt über 2 Icons (icon, icon2)
      • Warmweiß ist default minValueColorTemp bei Kelvin (Achtung: bei Mired (insbesondere im Zigbee.0 vertreten), ist Warmweiß 500 und Kaltweiß 153)
      • diverse kleinere Bugs eliminiert
      • popupLightNew (Alternative Slider sind im Script entfernt)
      TFT
      • Es gab bei den TFT-Pictures Zuordnungsfehler die dazu geführt haben, dass Teile des popupLightNew zu sehen waren, wenn die Hintergrundfarbe Black anstelle von HMIDark gewählt wurde. Black sollte jetzt wieder normal funktionieren.
        FlashNextion http://nspanel.de/nspanel-v4.6.0.tft
      cardQR
      • Im unteren Teil der cardQR lässt sich mit einem neuen Parameter im pageItem die Entity2 (Passwort oder der Schalter) ausblenden.
             let WLAN: PageType =
                 type: 'cardQR',
                 heading: 'Gäste WLAN',
                 subPage: true,
                 parent: Subpages_1,
                 items: [
                     { id: 'alias.0.NSPanel.GuestWifi',
                       hidePassword: true, // true = Switch; false = Password
                       hideEntity2: true   // true = Switch or Password is hide
      Und jetzt viel Spaß mit der Überarbeitung
      VG
      @TT-Tom , @ticaki und Armilar
      Chris_71 1 Reply Last reply Reply Quote 6
        TT-Tom last edited by TT-Tom
        Update TFT Version
        v 4.6.2
        Es gibt jetzt für den Fahrplan Adapter eine eigene Card. Dort werden jetzt bis zu 6 Abfahrten angezeigt. Damit haben wir das maximale an lesbaren rausgeholt.
        Es muss auf die TFT-Version 4.6.2 gewechselt werden und die DEV-NSPanel-Script version 4.6.0.2 um die Card zu nutzen.
        In der Pageconfig muss der Cardtyp geändert werden und 2 weitere PageItem eintragen.
        let Fahrplan: PageType = {
            type: 'cardSchedule',
            heading: 'Abfahrt',
            useColor: true,
            items: [
                { id: 'alias.0.NSPanel.FahrplanAnzeiger.Haltestelle0.Abfahrt0' },
                { id: 'alias.0.NSPanel.FahrplanAnzeiger.Haltestelle0.Abfahrt1' },
                { id: 'alias.0.NSPanel.FahrplanAnzeiger.Haltestelle0.Abfahrt2' },
                { id: 'alias.0.NSPanel.FahrplanAnzeiger.Haltestelle0.Abfahrt3' },
                { id: 'alias.0.NSPanel.FahrplanAnzeiger.Haltestelle0.Abfahrt4' },
                { id: 'alias.0.NSPanel.FahrplanAnzeiger.Haltestelle0.Abfahrt5' },
        Zusätzlich muss mein Script aktualisiert werden, welches die Daten vom Fahrplan Adapter einliest und für Panel-Script zur Verfügung stellt.
        Fahrplan_to_NSPanel
        Marc Berg 1 Reply Last reply Reply Quote 1
        • Marc Berg
          Marc Berg Most Active @TT-Tom last edited by Marc Berg
          @tt-tom sagte in SONOFF NSPanel mit Lovelace UI:
          Braucht es dazu noch ein Update des NSPanel-Skriptes?
          javascript.0
          	2025-04-01 23:03:04.651	error	script.js.NSPanels.nspanel1-4_6_0_1: TypeScript compilation failed: 'type': 'cardSchedule', ^ERROR: Type '"cardSchedule"' is not assignable to type '"cardChart" | "cardLChart" | "cardEntities" | "cardGrid" | "cardGrid2" | "cardGrid3" | "cardThermo" | "cardMedia" | "cardUnlock" | "cardQR" | "cardAlarm" | "cardPower"'.
            TT-Tom @Marc Berg last edited by TT-Tom
            @marc-berg
            Ja, das DEV-Panel-Script muss genutzt werden.
            Marc Berg A 2 Replies Last reply Reply Quote 1
            • Marc Berg
              @marc-berg
              Danke für's nachträgliche Reineditieren dieser Info.
                australien @TT-Tom last edited by
                @tt-tom Hallo Tom,
                ich habe jetzt das update durchgeführt und die DEV version installiert.
                Wenn ich die Fahrplanseite öffne, bekomme ich folgende Meldung im log
                javascript.0
                	2025-04-02 11:47:32.864	warn	script.js.NSPanel.Panel1_250402_4_6_2_1_DEV: error at trigger rceiving CustomRecv: Bad control character in string literal in JSON at position 40
                mqtt.0
                	2025-04-02 11:47:32.862	error	Client [NSPanel_1] Cannot parse "SmartHome/NSPanel_1/tele/RESULT": {"CustomRecv":"event,renderCurrentPagev ����"}
                • Armilar
                  Armilar Most Active Forum Testing @australien last edited by Armilar
                  @australien
                  @Marc-Berg
                  @TT-Tom
                  Die TFT ist ebenfalls neu... und die Release-Nummer der TFT wird ab Script-Version 4.6.2.1 aus dem HMI gezogen.
                  Daher ist mit der v4.6.2.1 zwingend ein:
                  FlashNextion http://nspanel.de/nspanel-v4.6.2.tft
                  erforderlich.
                  Wie @TT-Tom bereits geschrieben hat gibt es für den Fahrplanadapter eine eigene Page cardSchedule, welche angelehnt an die cardEntities ist, jedoch nur Text bereitstellt. Somit kann diese auch z.B. mit Alias-Channel vom Type info genutzt werden.
                    australien @Armilar last edited by
                    @armilar das aktuelle TFT ist bereits drauf und das neue Script für den Fahrplan wurde auch installiert, trotzdem kommt die Fehlermeldung.
                    Armilar 2 Replies Last reply Reply Quote 0
                    • Armilar
                      @australien
                      ja - interessant... Bin von der EMU (alles ordentlich) auf ein Live Panel gewechselt und habe es dort auch...
                      Muss das analysieren...
                      • Armilar
                        @australien
                        Mache bitte nochmal ein Update (ist unter gleicher Versionsnummer gefixed)
                          @armilar Super! Danke, jetzt läuft alles ohne Meldung.
                          T 1 Reply Last reply Reply Quote 2
                            @armilar
                            Wo war das Problem?
                              TT-Tom @australien last edited by
                              @australien
                              Perfekt. Kleiner Ausblick Richtung Adapter. Dort können noch mehr Einträge angesehen werden, durch eine Blätter Option, heißt du kannst dann runter scrollen. Zusätzlich testen wir bei Verspätungen die Meldungen im Hintergrund zu speichern und den einzelnen Abfahrten zu ordnen.
                              So unser Ziel im Adapter.
                              • Armilar
                                Armilar Most Active Forum Testing @TT-Tom last edited by Armilar
                                @tt-tom
                                Wo war das Problem?
                                Ah detailliert? Im Preinitialize Event der der cardSchedule (HMI) wurden nicht alle Types in der letzten for-Schleife bis 49 eingefangen... 😁
                                Ich denke das trifft es... Wolltest du wirklich diese Details? 😊
                                  TT-Tom @Armilar last edited by
                                  @armilar
                                  Na eigentlich noch genauer. 😂😂🤣
                                    matthesjimte last edited by matthesjimte
                                    Guten Abend
                                    Ich wollte nun auch auf den Zug aufspringen und habe mein NSPanel mit Lovelace UI geflascht.
                                    Nach anlegen der Scripte und Datenpunkte bekommen ich nun den folgenden Fehler angezeigt.
                                    "script.js.NSPanel.Panel1: TypeScript compilation failed: log(iconColor); ^ERROR: Argument of type 'number' is not assignable to parameter of type 'string'."
                                    Dies ist aber eigentlich gar kein Punkt der laut Doku konfiguriert wird.
                                    Habe das Script nochmals neu heruntergeladen, aber der Fehler bleibt weiterhin bestehen.
                                    Hat jemand eine Ahnung woher der Fehler kommt?
                                    • Armilar
                                      Armilar Most Active Forum Testing @matthesjimte last edited by Armilar
                                      @matthesjimte
                                      Herzlich willkommen,
                                      ist das NSPanelTS.ts in common und das IconScript in global?
                                      Weiter ist noch nichts konfiguriert? Nur das Originalskript?
                                      Sieht für mich so aus, als wäre da eine CIE-Lampe konfiguriert??? Falls das so wäre, würde mich die erstellte Seitenvariable interessieren...
                                        matthesjimte @Armilar last edited by
                                        Hi @armilar
                                        Ich habe nur CommanSend konfiguriert.
                                        Ja die Scripte sind in Global und common
                                        Sorry aber was ist eine CIE-Lampe?
                                        T Armilar 2 Replies Last reply Reply Quote 0
                                          ticaki @matthesjimte last edited by
                                          @matthesjimte
                                          Eine Lampe die CIE zur Steuerung der Farbe verwendet.
                                            matthesjimte @ticaki last edited by
                                            @ticaki
                                            Nein sowas habe ich nicht in IoBroker
                                            lovelace ui nspanel sonoff
                                            271
                                            7739
                                            6659745
