    4. Back It Up - Back up kann nicht erstellt werden
      Homoran Global Moderator Administrators @xxx_turbo_xxx last edited by Homoran
      @xxx_turbo_xxx sagte in Back It Up - Back up kann nicht erstellt werden:
      @thomas-braun da geht's schon los 🙂
      pi@raspberrypi:/usr/bin $ iob diag
      /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
      dann ist die Installation krumm.
      wiedo sthst du in /usr/bin?
      geht denn iob fix?
      xxx_turbo_xxx 2 Replies Last reply Reply Quote 0
      • xxx_turbo_xxx
        xxx_turbo_xxx @Homoran last edited by
        @homoran ja, läuft durch
        pi@raspberrypi:/usr/bin $ iob fix
        library: loaded
        Library version=2024-10-22
            Welcome to the ioBroker installation fixer!
            Script version: 205-02-02
            You might need to enter your password a couple of times.
            Installing prerequisites (1/5)
        Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
        Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
        Hit:4 https://repos.influxdata.com/debian stable InRelease
        Hit:5 https://apt.grafana.com stable InRelease
        Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
        Hit:8 https://repo.ebusd.eu/apt/nomqtt/bookworm bookworm InRelease
        Get:9 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [246 kB]
        Fetched 349 kB in 1s (584 kB/s)
        Reading package lists... Done
            Checking ioBroker user and directory permissions (2/5)
        Created /etc/sudoers.d/iobroker
        Fixing directory permissions...
            Check and cleanup npm temporary directories (3/5)
        Done.
            Database maintenance (4/5)
        Checking for uncompressed JSONL databases... This might take a while!
        Compressing /opt/iobroker/iobroker-data/states.jsonl
        Compressing /opt/iobroker/iobroker-data/objects.jsonl
        Compressed 2 JSONL files. Done
            Checking autostart (5/5)
        ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ====
        Authentication is required to stop 'iobroker.service'.
        Authenticating as: ,,, (pi)
        Password:
        ==== AUTHENTICATION COMPLETE ====
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        • xxx_turbo_xxx
          @homoran jetzt läuft auch diag
                                  v.2025-02-23
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.6.74+rpt-rpi-2712
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    0
          Nodejs-Installation:
          /usr/bin/nodejs         v20.19.0
          /usr/bin/node           v20.19.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.31.0
          Recommended versions are nodejs 20.19.0 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            8.5G        2.7G        3.2G        5.7M        2.7G        5.7G
          Swap:           1.1G          0B        1.1G
          Total:          9.5G        2.7G        4.2G
          Active iob-Instances:   26
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.6.3
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                29210
          States:                 22773
          Size of iob-Database:
          24M     /opt/iobroker/iobroker-data/objects.jsonl
          7.0M    /opt/iobroker/iobroker-data/states.jsonl
          Operating System is the current Debian stable version codenamed 'bookworm'!
          === Mark text until here for copying ===
            Das war der Plan!
            ist leider nur fie Zusammenfassung, nicht die Langfassung
            xxx_turbo_xxx 1 Reply Last reply Reply Quote 0
            • xxx_turbo_xxx
              ========== Start marking the full check here ===========
              ```bash
              Script v.2025-02-23
              *** BASE SYSTEM ***
                     Icon name: computer
                  Architecture: arm64
              OS is similar to:
              Model           : Raspberry Pi 5 Model B Rev 1.0
              Docker          : false
              Virtualization  : none
              Kernel          : aarch64
              Userland        : 64 bit
              Systemuptime and Load:
               14:23:32 up  5:52,  2 users,  load average: 0.29, 0.35, 0.34
              CPU threads: 4
              *** LIFE CYCLE STATUS ***
              *** RASPBERRY THROTTLING ***
              Current issues:
              Previously detected issues:
              ~ Under-voltage has occurred
              ~ Arm frequency capping has occurred
              ~ Throttling has occurred
              ~ Soft temperature limit has occurred
              *** TIME AND TIMEZONES ***
                             Local time: Thu 2025-04-03 14:23:32 CEST
                         Universal time: Thu 2025-04-03 12:23:32 UTC
                               RTC time: Thu 2025-04-03 12:23:32
                            NTP service: active
                        RTC in local TZ: no
              *** Users and Groups ***
              User that called 'iob diag':
              pi
              HOME=/home/pi
              GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              iobroker
              HOME=/home/iobroker
              GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
              *** DISPLAY-SERVER SETUP ***
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Mem:            8.5G        2.8G        2.9G        5.7M        2.8G        5.6G
              Swap:           1.1G          0B        1.1G
              Total:          9.5G        2.8G        4.0G
                       8064 M total memory
                       2697 M used memory
                       2871 M active memory
                       1963 M inactive memory
                       2761 M free memory
                       1048 M buffer memory
                       1649 M swap cache
                       1023 M total swap
                          0 M used swap
                       1023 M free swap
              top - 14:23:33 up  5:52,  2 users,  load average: 0.29, 0.35, 0.34
              Tasks: 204 total,   1 running, 203 sleeping,   0 stopped,   0 zombie
              %Cpu(s):  0.0 us, 33.3 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
              MiB Mem :   8064.1 total,   2761.8 free,   2697.6 used,   2698.0 buff/cache
              MiB Swap:   1024.0 total,   1024.0 free,      0.0 used.   5366.6 avail Mem
              *** FAILED SERVICES ***
                UNIT                     LOAD   ACTIVE SUB    DESCRIPTION
              * nvmf-autoconnect.service loaded failed failed Connect NVMe-oF subsystems automatically during boot
              LOAD   = Reflects whether the unit definition was properly loaded.
              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
              SUB    = The low-level unit activation state, values depend on unit type.
              1 loaded units listed.
              *** DMESG CRITICAL ERRORS ***
              No critical errors detected
              *** FILESYSTEM ***
              udev           devtmpfs  4.0G     0  4.0G   0% /dev
              tmpfs          tmpfs     807M  5.4M  802M   1% /run
              /dev/nvme0n1p2 ext4      457G   17G  417G   4% /
              tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
              tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
              /dev/nvme0n1p1 vfat      511M   56M  456M  11% /boot/firmware
              tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
              [Thu Apr  3 08:30:42 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:5F:BA:D2 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=c47e601e-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
              [Thu Apr  3 08:30:46 2025] EXT4-fs (nvme0n1p2): mounted filesystem 0224b804-3566-4bfa-94fe-19d07c84e5a7 ro with ordered data mode. Quota mode: none.
              [Thu Apr  3 08:30:47 2025] EXT4-fs (nvme0n1p2): re-mounted 0224b804-3566-4bfa-94fe-19d07c84e5a7 r/w. Quota mode: none.
              Show mounted filesystems:
              TARGET           SOURCE         FSTYPE OPTIONS
              /                /dev/nvme0n1p2 ext4   rw,noatime
              `-/boot/firmware /dev/nvme0n1p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
              /var:
              9.0G    /var/
              4.3G    /var/lib
              4.1G    /var/lib/influxdb/data
              4.0G    /var/lib/influxdb/data/iobroker_db/autogen
              Archived and active journals take up 2.7G in the file system.
              /opt/iobroker/backups:
              1.6G    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              970M    /opt/iobroker/iobroker-data/
              840M    /opt/iobroker/iobroker-data/files
              617M    /opt/iobroker/iobroker-data/files/javascript.admin
              560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
              558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
              38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
              29M     /opt/iobroker/iobroker-data/objects.jsonl
              27M     /opt/iobroker/iobroker-data/states.jsonl
              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
              24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
              USB-Devices by-id:
              /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D306YVGN-if00-port0
              /dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_D306Z6KP-if00-port0
              Zigbee Network Settings on your coordinator/in nvbackup are:
              zigbee.X
              Extended Pan ID:
              *** MASKED ***
              Pan ID:
              *** MASKED ***
              Channel:
              *** MASKED ***
              Network Key:
              *** MASKED ***
              To unmask the settings run 'iob diag --unmask'
              *** NodeJS-Installation ***
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              nodejs:
                Installed: 20.19.0-1nodesource1
                Candidate: 20.19.0-1nodesource1
                Version table:
               *** 20.19.0-1nodesource1 1001
                      500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                      100 /var/lib/dpkg/status
                   20.18.3-1nodesource1 1001
                   20.18.2-1nodesource1 1001
                   20.18.1-1nodesource1 1001
                   20.18.0-1nodesource1 1001
                   20.17.0-1nodesource1 1001
                   20.16.0-1nodesource1 1001
                   20.15.1-1nodesource1 1001
                   20.15.0-1nodesource1 1001
                   20.14.0-1nodesource1 1001
                   20.13.1-1nodesource1 1001
                   20.13.0-1nodesource1 1001
                   20.12.2-1nodesource1 1001
                   20.12.1-1nodesource1 1001
                   20.12.0-1nodesource1 1001
                   20.11.1-1nodesource1 1001
                   20.11.0-1nodesource1 1001
                   20.10.0-1nodesource1 1001
                   20.9.0-1nodesource1 1001
                   20.8.1-1nodesource1 1001
                   20.8.0-1nodesource1 1001
                   20.7.0-1nodesource1 1001
                   20.6.1-1nodesource1 1001
                   20.6.0-1nodesource1 1001
                   20.5.1-1nodesource1 1001
                   20.5.0-1nodesource1 1001
                   20.4.0-1nodesource1 1001
                   20.3.1-1nodesource1 1001
                   20.3.0-1nodesource1 1001
                   20.2.0-1nodesource1 1001
                   20.1.0-1nodesource1 1001
                   20.0.0-1nodesource1 1001
                   18.19.0+dfsg-6~deb12u2 500
                   18.19.0+dfsg-6~deb12u1 500
              No problems detected
              Errors in npm tree: 0
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Hosts:
              raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 7862)
              Core adapters versions
              js-controller:  7.0.6
              admin:          7.6.3
              javascript:     8.8.3
              nodejs modules from github:     3
              +-- iobroker.apsystems-ecu@0.2.9 (git+ssh://git@github.com/npeter/ioBroker.apsystems-ecu.git#645ddb58b56564f873e78271762f84033e9f2d7a)
              +-- iobroker.vaillant@0.2.0 (git+ssh://git@github.com/TA2k/ioBroker.vaillant.git#88031f63ee95059780d2562f40fc605ac18d0910)
              +-- iobroker.vw-connect@0.7.7 (git+ssh://git@github.com/ta2k/ioBroker.vw-connect.git#551cdab82b4888a14072bf8ca7688eaecc952390)
              Adapter State
              + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
              + system.adapter.apsystems-ecu.0          : apsystems-ecu         : raspberrypi                              -  enabled
              + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                system.adapter.canbus.0                 : canbus                : raspberrypi                              - disabled
                system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
              + system.adapter.ds18b20.0                : ds18b20               : raspberrypi                              -  enabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
              + system.adapter.ebus.0                   : ebus                  : raspberrypi                              -  enabled
                system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
              + system.adapter.followthesun.0           : followthesun          : raspberrypi                              -  enabled
              + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
              + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
              + system.adapter.i2c.0                    : i2c                   : raspberrypi                              -  enabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
              + system.adapter.modbus.0                 : modbus                : raspberrypi                              -  enabled
              + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
                system.adapter.octoprint.0              : octoprint             : raspberrypi                              - disabled
                system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
                system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
              + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
              + system.adapter.pushover.0               : pushover              : raspberrypi                              -  enabled
              + system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              -  enabled
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
              + system.adapter.smartmeter.0             : smartmeter            : raspberrypi                              -  enabled
              + system.adapter.smartmeter.1             : smartmeter            : raspberrypi                              -  enabled
              + system.adapter.tado.0                   : tado                  : raspberrypi                              -  enabled
                system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
              + system.adapter.vaillant.0               : vaillant              : raspberrypi                              -  enabled
                system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
              + system.adapter.vw-connect.0             : vw-connect            : raspberrypi                              -  enabled
              + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
              + instance is alive
              ioBroker-Repositories
              Active repo(s): stable
              Installed ioBroker-Adapters
              Used repository: stable
              Adapter    "admin"        : 7.6.3    , installed 7.6.3
              Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
              Adapter    "backitup"     : 3.0.31   , installed 3.0.31
              Adapter    "canbus"       : 1.3.1    , installed 1.3.1
              Adapter    "ds18b20"      : 3.0.1    , installed 3.0.1
              Adapter    "ebus"         : 3.5.2    , installed 3.5.2
              Adapter    "followthesun" : 0.5.2    , installed 0.5.2
              Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
              Adapter    "hue"          : 3.14.1   , installed 3.14.1
              Adapter    "i2c"          : 1.2.1    , installed 1.2.1
              Adapter    "iot"          : 3.3.0    , installed 3.3.0
              Adapter    "javascript"   : 8.8.3    , installed 8.8.3
              Controller "js-controller": 7.0.6    , installed 7.0.6
              Adapter    "mobile"       : 1.0.1    , installed 1.0.1
              Adapter    "modbus"       : 6.3.2    , installed 6.3.2
              Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
              Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
              Adapter    "openweathermap": 1.1.2   , installed 1.1.2
              Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
              Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
              Adapter    "shelly"       : 8.5.1    , installed 8.5.1
              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
              Adapter    "socketio"     : 6.7.1    , installed 6.7.1
              Adapter    "tado"         : 0.7.2    , installed 0.7.2
              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
              Adapter    "upnp"         : 1.1.0    , installed 1.1.0
              Adapter    "web"          : 7.0.8    , installed 7.0.8
              Adapter    "ws"           : 2.6.2    , installed 2.6.2
              Adapter    "yahka"        : 1.0.3    , installed 1.0.3
              Objects and States
              Objects:        29210
              States:         22738
              Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
              Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
              Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
              Hit:5 https://repos.influxdata.com/debian stable InRelease
              Hit:6 https://apt.grafana.com stable InRelease
              Pending Updates: 0
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       138002     17425/iobroker.js-c
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       137997     17425/iobroker.js-c
              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       139645     17614/io.mqtt.0
              tcp        0      0 127.0.0.1:43077         0.0.0.0:*               LISTEN      1001       147914     17927/io.yahka.0
              tcp        0      0 0.0.0.0:34559           0.0.0.0:*               LISTEN      1001       140067     17927/io.yahka.0
              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5335       715/sshd: /usr/sbin
              tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        6447       837/influxd
              tcp        0      0 0.0.0.0:8888            0.0.0.0:*               LISTEN      0          6477       816/ebusd
              tcp        0      0 0.0.0.0:8889            0.0.0.0:*               LISTEN      0          6478       816/ebusd
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       136086     17443/io.admin.0
              tcp6       0      0 :::8086                 :::*                    LISTEN      999        1973       837/influxd
              tcp6       0      0 :::3000                 :::*                    LISTEN      106        2011       879/grafana
              tcp6       0      0 :::41993                :::*                    LISTEN      1001       140065     17927/io.yahka.0
              tcp6       0      0 :::22                   :::*                    LISTEN      0          5337       715/sshd: /usr/sbin
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3930       594/avahi-daemon: r
              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       141361     17644/io.shelly.0
              udp        0      0 0.0.0.0:56371           0.0.0.0:*                           104        3932       594/avahi-daemon: r
              udp6       0      0 :::54104                :::*                                104        3933       594/avahi-daemon: r
              udp6       0      0 :::5353                 :::*                                104        3931       594/avahi-daemon: r
              2025-04-03 14:23:15.050  - info: javascript.0 (17488) State value to set for "0_userdata.0.AP_Systems_Solar.Netzbezug" has to be type "string" but received type "number"
              2025-04-03 14:23:26.058  - warn: javascript.0 (17488) You are assigning a number to the state "0_userdata.0.AP_Systems_Solar.Netzbezug" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
              2025-04-03 14:23:26.059  - warn: javascript.0 (17488)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
              2025-04-03 14:23:26.059  - warn: javascript.0 (17488)     at Object.<anonymous> (script.js.common.Strom.Netzbezug:5:3)
              2025-04-03 14:23:26.059  - warn: javascript.0 (17488)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
              2025-04-03 14:23:26.059  - warn: javascript.0 (17488)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
              2025-04-03 14:23:26.059  - warn: javascript.0 (17488)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
              2025-04-03 14:23:26.059  - warn: javascript.0 (17488)     at processImmediate (node:internal/timers:483:21)
              2025-04-03 14:23:26.060  - info: javascript.0 (17488) State value to set for "0_userdata.0.AP_Systems_Solar.Netzbezug" has to be type "string" but received type "number"
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488) You are assigning a number to the state "0_userdata.0.AP_Systems_Solar.Netzbezug" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488)     at Object.<anonymous> (script.js.common.Strom.Netzbezug:5:3)
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
              2025-04-03 14:23:37.059  - warn: javascript.0 (17488)     at processImmediate (node:internal/timers:483:21)
              2025-04-03 14:23:37.061  - info: javascript.0 (17488) State value to set for "0_userdata.0.AP_Systems_Solar.Netzbezug" has to be type "string" but received type "number"
              2025-04-03 14:23:48.047  - warn: javascript.0 (17488) You are assigning a number to the state "0_userdata.0.AP_Systems_Solar.Netzbezug" which expects a string. Please fix your code to use a string or change the state type to number. This warning might become an error in future versions.
              2025-04-03 14:23:48.048  - warn: javascript.0 (17488)     at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:2090:20)
              2025-04-03 14:23:48.048  - warn: javascript.0 (17488)     at Object.<anonymous> (script.js.common.Strom.Netzbezug:5:3)
              2025-04-03 14:23:48.048  - warn: javascript.0 (17488)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
              2025-04-03 14:23:48.048  - warn: javascript.0 (17488)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
              2025-04-03 14:23:48.048  - warn: javascript.0 (17488)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
              2025-04-03 14:23:48.048  - warn: javascript.0 (17488)     at processImmediate (node:internal/timers:483:21)
              2025-04-03 14:23:48.049  - info: javascript.0 (17488) State value to set for "0_userdata.0.AP_Systems_Solar.Netzbezug" has to be type "string" but received type "number"
              iob diag has finished.
              Press any key for a summary
              mcm1957 Homoran 2 Replies Last reply Reply Quote 0
              • mcm1957
                mcm1957 @xxx_turbo_xxx last edited by mcm1957
                Mal auf den ersten Blick:
                Netzteil zu schwach. Nicht irgendein Ladegerät verwenden sondern nach möglichkeit ein Original Raspi Netzteil.
                Kühlung ev. unzureichend
                https://www.heise.de/hintergrund/Alternative-Stromversorgung-fuer-Raspberry-Pi-5-500-10303849.html?seite=all (ganzer Artikel für nicht Heise Abbonenten kostenpflichtig)
                Das Raspi Netzteil korrigiert die Verluste die in der (fix angebrachten) Leitung entstehen während 0815 Handylader nur die Spannung an der Buchse regeln können. Und wenn dann noch ein billiges (= zu dünnes) Kabel zum Einsatz kommt kommen beim Raspi statt 5,1V nur mehr 4,9V oder weniger an. Lt. offizieller Spec liefert das Raspi Netzteil auch 5,1V ...
                Zitat:
                Der Raspi 5 hat zur Stromversorgung eine USB-C-Buchse und verwendet im Prinzip die Spezifikation für USB Power Delivery (USB-PD). Doch der Raspi 5 bürstet USB-PD ein wenig gegen den Strich. Denn im Kern zielt das Konzept von USB-PD eigentlich auf möglichst flexibel einsetzbare Netzteile. Der Raspi 5 harmoniert jedoch nur mit sehr wenigen. Die Ursache dafür ist, dass der Raspi 5 die für USB-PD ungewöhnliche Spannungs-Strom-Kombination von 5 Volt (V) und 5 Ampere (A) verlangt.
                Da gute Netzteile in Verbindung mit einem guten Kabel kaum billiger sind zahlt es sich m.E. außer in Sondersituationen (z.B Rackmontage) nicht aus irgendein Netzteil zu verwenden nur weil es ev. 5,- billiger ist.
                • mcm1957
                  mcm1957 @mcm1957 last edited by mcm1957
                  Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                  GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                  Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                  Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                  Und falls es irgendwie unklar ist:
                  ioBroker unterstützt folgende Arten von Installation:
                  • aus dem STABLE Repository
                    Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
                  • aus dem LATEST Repository
                    Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
                  • direkt von GITHUB
                    Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
                  • direkt von npm
                    Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
                  Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
                  @mcm1957
                    @xxx_turbo_xxx zusätzlich zu den Informationen von @mcm1957 wäre noch die Konfigurati8n deiner Backups interessant.
                    Die Meldung.... (die ich aus dem Screenshot nicht kopieren kann 😞 )
                    will ja irgendwas mit dem Backup machen was nicht klappt, weil irgendwas blockiert ist
                    • mcm1957
                      apsystems-ecu hat eine Reihe von Fehlern offen:
                      https://github.com/npeter/ioBroker.apsystems-ecu/issues/18
                      Vor allem dieser hier wird dir beim nächsten js-controller update wahrscheinlich Probleme machen. Adapter core < 3 wird dann nicht mehr unterstützt.
                      [E033] @iobroker/adapter-core 2.5.1 specified. 3.1.4 is required as minimum, 3.2.3 is recommended. Please update dependencies at package.json
                      Und da der Adapter in keine Repository ist wird das bei automatisierten Tests auch eher weniger auffallen. Ergo ein Grund mehr keien Github Only Installationen (außer auf Anraten des Devs für Testzwecke) zu verwenden - oder bei Problemen nicht zu heulen.
                      ioBroker-Bot created this issue in npeter/ioBroker.apsystems-ecu
                      open Please consider fixing issues detected by repository checker #18
                      • xxx_turbo_xxx
                        xxx_turbo_xxx @Homoran last edited by xxx_turbo_xxx
                          Thomas Braun Most Active @xxx_turbo_xxx last edited by
                          @xxx_turbo_xxx
                          Ich hoffe ganz stark, das die SMB-Version NICHT 1.0 ist.
                          Stell das mal auf den vom NAS gesprochenen Dialekt ein. Sollte > 3.0 sein.
                          • xxx_turbo_xxx
                            xxx_turbo_xxx @Thomas Braun last edited by
                            @thomas-braun Danke für die Info. Habs eingestellt und direkt ein Backup laufen lassen... Das hat schon mal funktioniert 🙂
                            494
