    3. Off Topic
    4. Pflege des Betriebssystems
    5. Meldung über Zeitfehler - Was ist das ?
    • dogfight76
      dogfight76 @Thomas Braun last edited by
      @thomas-braun "Auf stand bringen"
      Den ioBroker aktualsieren ? Oder was meinst damit genau ?
        Thomas Braun Most Active @dogfight76 last edited by
        @dogfight76
        Dein System ist mindestens bei nodejs nicht auf dem aktuellsten Stand.
        Näheres könnte man sagen, wenn man die vollständige (Langfassung) Ausgabe von
        iob diag
        sehen würde.
        dogfight76 1 Reply Last reply Reply Quote 0
        • dogfight76
          dogfight76 @Thomas Braun last edited by dogfight76
          @thomas-braun said in Meldung über Zeitfehler - Was ist das ?:
          Ausgabe von
          Im putty den Befehl ausführen ?
          EDIT: Die Ausgabe des Befehl in putty:
          ========== Start marking the full check here ===========
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
             Static hostname: iobroker
                   Icon name: computer
            Operating System: Debian GNU/Linux 11 (bullseye)
                      Kernel: Linux 6.1.21-v8+
                Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.2
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           14:52:43 up 2 days,  1:59,  2 users,  load average: 0.29, 0.13, 0.07
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Fri 2025-04-04 14:52:43 CEST
                     Universal time: Fri 2025-04-04 12:52:43 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          dogfight76
          HOME=/home/dogfight76
          GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            3.8G        918M        1.9G        1.0M        935M        2.8G
          Swap:            99M          0B         99M
          Total:          3.9G        918M        2.0G
          Active iob-Instances:   14
                   3794 M total memory
                    918 M used memory
                   1064 M active memory
                    641 M inactive memory
                   1939 M free memory
                    126 M buffer memory
                    809 M swap cache
                     99 M total swap
                      0 M used swap
                     99 M free swap
          top - 14:52:44 up 2 days,  1:59,  2 users,  load average: 0.29, 0.13, 0.07
          Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3794.3 total,   1940.0 free,    918.2 used,    936.2 buff/cache
          MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2799.5 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          /dev/root      ext4       59G  9.0G   47G  17% /
          devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
          tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
          tmpfs          tmpfs     759M  1.2M  758M   1% /run
          /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
          tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
          [Wed Apr  2 12:53:00 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Wed Apr  2 12:53:01 2025] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
          [Wed Apr  2 12:53:01 2025] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
          [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
          [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
          [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): recovery complete
          [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Wed Apr  2 12:53:02 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
          [Wed Apr  2 12:53:04 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE         FSTYPE OPTIONS
          /       /dev/mmcblk0p2 ext4   rw,noatime
          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          2.3G    /var/
          1.3G    /var/log/journal/7d1338ad4ea145258230302c11232948
          1.3G    /var/log
          734M    /var/cache
          Archived and active journals take up 1.2G in the file system.
          /opt/iobroker/backups:
          93M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          791M    /opt/iobroker/iobroker-data/
          728M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          17M     /opt/iobroker/iobroker-data/objects.jsonl
          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
          7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.0
          /usr/bin/node           v20.18.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          nodejs:
            Installed: 20.18.0-1nodesource1
            Candidate: 20.18.3-1nodesource1
            Version table:
               20.18.3-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
           *** 20.18.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               12.22.12~dfsg-1~deb11u6 500
                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
               12.22.12~dfsg-1~deb11u4 500
                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 25418)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.6.3
          javascript:     8.8.3
          nodejs modules from github:     1
          +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
          Adapter State
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
          + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
            system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
          + system.adapter.history.0                : history               : iobroker                                 -  enabled
            system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
            system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
            system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
            system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
            system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
            system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
          + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
            system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.6.3    , installed 7.6.3
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        1150
          States:         885
          Hit:1 http://deb.debian.org/debian bullseye InRelease
          Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 93
          *** Listening Ports ***
          tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       1146617    115154/io.mqtt.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15374      564/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          942202     94334/cupsd
          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1148504    115241/io.jarvis.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1147461    114977/iobroker.js-
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1147466    114977/iobroker.js-
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1149410    114995/io.admin.0
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1149599    115203/io.web.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          942201     94334/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          15376      564/sshd: /usr/sbin
          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14987      479/dhcpcd
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1147680    115132/io.chromecas
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14601      403/avahi-daemon: r
          udp        0      0 0.0.0.0:36388           0.0.0.0:*                           108        14603      403/avahi-daemon: r
          udp6       0      0 :::546                  :::*                                0          15860      479/dhcpcd
          udp6       0      0 :::44044                :::*                                108        14604      403/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                108        14602      403/avahi-daemon: r
          2025-04-04 14:45:15.296  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:19)
          2025-04-04 14:45:15.297  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
          2025-04-04 14:45:15.298  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2025-04-04 14:45:15.298  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
          2025-04-04 14:45:15.299  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
          2025-04-04 14:45:15.300  - info: javascript.0 (115051) script.js.common.Meine_Geraete.Heizung.Akt_VL: null
          2025-04-04 14:45:15.300  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.26" not found (3)
          2025-04-04 14:45:15.303  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
          2025-04-04 14:45:15.303  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
          2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
          2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
          2025-04-04 14:46:45.183  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.25" not found (3)
          2025-04-04 14:46:45.185  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:19)
          2025-04-04 14:46:45.185  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
          2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
          2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
          2025-04-04 14:46:45.187  - info: javascript.0 (115051) script.js.common.Meine_Geraete.Heizung.Akt_VL: null
          2025-04-04 14:46:45.187  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.25" not found (3)
          2025-04-04 14:46:45.188  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
          2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
          2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
          2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
          2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
          iob diag has finished.
            @dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
            Das kannst du schon mal auf Version 12 'Bookworm' bringen. Geht beim Raspberry aber nur per Neuinstallation.
            Das Dateisystem hat einen Treffer:
            Da könnten auch deine Probleme mit dem System herrühren.
            System regelmäßiger auf Stand bringen:
            Pending Updates: 93
            Es darf da keine fast 3stellige Zahl an Updates anstehen.
            dogfight76 2 Replies Last reply Reply Quote 0
            • dogfight76
              Ok, das bedeutet jetzt wieviel Aufwand ?
              ioBroker Backup werden ja autom. gemacht.
              Aber das bedeutet praktisch bei Null anfangen, richtig ?
                Keine Ahnung. Hängt halt davon ab wie sattelfest du dabei bist und was da alles konfiguriert wurde. Ist ja dein System.
                Wenn es nur der ioBroker ist, dann ist das ganze Ding in einer Stunde gehalten.
                • dogfight76
                  @thomas-braun Auf dem Pi läuft nur ioBroker für die VIS Steuerung der Wärmepumpe
                  Das mit den Updates verstehe ich nicht. Deine Befehle mal eingeben aus deiner letzten Hilfestellung für mich, mit dem Ergebnis:
                  Befehle waren diese, in der Reihenfolge:
                  sudo apt update
                  sudo apt full-upgrade
                  sudo reboot
                  Da keine Updates gemeldet wurden dann diese hinterher:
                  iob update
                  iob upgrade all -y
                  Das Ergebnis siehst du auf dem Screenshot
                    @dogfight76
                    KEINE Screenshots.
                    • dogfight76
                      @thomas-braun Sorry, aber ich kann ich nicht mehr kopieren.
                      Aber mehr als auf dem Screenshot stand da nicht.
                        Ich lese keine Screenshots.
                        dogfight76 1 Reply Last reply Reply Quote 1
                        • dogfight76
                          @thomas-braun Und was soll ich jetzt machen ? Bekomme den Text da ja nicht mehr rauskopiert um es in das Code-Fenster zu kopieren.
                          Bin eh angefangen den ioBroker mit dem Debian GNU/Linux 12 'Bookworm auf einen Pi 4 Version A zu installieren.
                          Dann Backup drauf und alles ist aktuell.
                          • dogfight76
                            so, habe das Upgrade auf die aktuelle Version Bookworm gemacht. Dann Updates installiert , von Bookworm und auch iobroker.
                            Wollte dir die Ausgabe von "iob diag" zeigen, aber da kommt diese Meldung:
                            dogfight76@ioBroker-neu:~ $ iob update
                            dogfight76@ioBroker-neu:~ $ iob diag
                            /usr/bin/iob: line 21: /home/iobroker/iob_diag.log: Permission denied
                            dogfight76@ioBroker-neu:~ $ sudo iob diag
                            ***For security reasons ioBroker should not be run or administrated as root.***
                            By default only a user that is member of iobroker group can execute ioBroker commands.
                            Please read the Documentation on how to set up such a user, if not done yet.
                            Only in very special cases you can run iobroker commands by adding the --allow-root option at the end of the command line.
                            Please note that this option may be disabled in the future, so please change your setup accordingly now.
                              Homoran Global Moderator Administrators @dogfight76 last edited by
                              Bei RaspiOS kann man dieses Upgrade nicht (so einfach) durchführen.
                              Da geht im Prinzip nur Neuinstallation!
                              • dogfight76
                                dogfight76 @Homoran last edited by
                                Ist eine komplette Neusinatllation gemacht worden !
                                Hatte einen Pi 4 Modell A rumliegen , mit 128GB miscroSD und daruaf alles frisch aufgesetzt ! Bis halt zu dem Punkt "iob diag"
                                  @dogfight76 wie hast du den user angelegt?
                                  wie hast du iobroker installiert?
                                  • mit welchem user?
                                    Permission denied
                                    Der user dogfight76 ist vermutlich nicht in der richtigen Gruppe. Oder der wurde nach der Installation noch nicht neueingeloggt.
                                    • dogfight76
                                      Guten morgen,
                                      @homoran said in Meldung über Zeitfehler - Was ist das ?:
                                      Nach dieser Anleitung hier aus dem Forum:
                                      https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                                      Und danach mein ioBroker-Backup eingespielt.
                                        und die Antwort auf die zweite Frage?
                                        @homoran sagte in Meldung über Zeitfehler - Was ist das ?:
                                        mit welchem user?
                                          @dogfight76
                                          Hast du unmittelbar nach der Installation den dogfight76 abgemeldet?
                                          Hast du unmittelbar nach der Installation den iob fix ausgefürht?
                                          Zeig die Ausgabe von
                                          groups
                                          ls -l /home
                                          • dogfight76
                                            angemldet im ioBroker ? Ist der User gemeint ?
                                            Im ioBroker angemeldet mit vergebenem User und meinem vergebenem Passwort.
                                            Die Anleitung einfach bis zum Ende abgearbeitet ,dann die Update/Upgrade Befehle ausgeführt
                                            Danach im ioBroker angemeldet und das Backup eingespielt.
                                            Dann wollte ich über putty den Befehle "iob diag" durchlaufen lassen um das Ergebnis hier für die Kontrolle einzufügen.
                                            Da kam der Fehler......
                                            1.0k
                                            81.1k
                                            6327
