    3. Off Topic
    4. Pflege des Betriebssystems
    5. Meldung über Zeitfehler - Was ist das ?
    • dogfight76
      dogfight76 @Thomas Braun last edited by dogfight76
      Moment.....
      Edit Ergebnis @Thomas-braun
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: ioBroker-neu
             Icon name: computer
                Kernel: Linux 6.12.20+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       11:21:44 up 23 min,  2 users,  load average: 0.23, 0.27, 0.32
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-04-05 11:21:44 CEST
                 Universal time: Sat 2025-04-05 09:21:44 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      dogfight76
      HOME=/home/dogfight76
      GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        1.1G        2.2G        1.2M        808M        2.9G
      Swap:           536M          0B        536M
      Total:          4.5G        1.1G        2.7G
      Active iob-Instances:   14
               3791 M total memory
               1003 M used memory
                971 M active memory
                490 M inactive memory
               2093 M free memory
                100 M buffer memory
                670 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 11:21:45 up 23 min,  2 users,  load average: 0.23, 0.27, 0.32
      Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3791.4 total,   2094.0 free,   1003.5 used,    770.7 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2787.9 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4      117G  5.7G  106G   6% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Apr  5 10:58:20 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:0D:BC:95 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d72bd49f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
      [Sat Apr  5 10:58:23 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
      [Sat Apr  5 10:58:24 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      936M    /var/
      204M    /var/cache
      199M    /var/cache/apt
      167M    /var/lib
      135M    /var/lib/apt/lists
      Archived and active journals take up 52.0M in the file system.
      /opt/iobroker/backups:
      8.5M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      740M    /opt/iobroker/iobroker-data/
      727M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      12M     /opt/iobroker/iobroker-data/objects.jsonl
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.0-1nodesource1
        Candidate: 20.19.0-1nodesource1
        Version table:
       *** 20.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker-neu        ioBroker-neu (version: 7.0.6, hostname: ioBroker-neu  , alive, uptime: 1188)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     1
      +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker-neu                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : ioBroker-neu                             -  enabled
      + system.adapter.chromecast.0             : chromecast            : ioBroker-neu                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker-neu                             -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker-neu                             - disabled
        system.adapter.fritzdect.0              : fritzdect             : ioBroker-neu                             - disabled
      + system.adapter.history.0                : history               : ioBroker-neu                             -  enabled
        system.adapter.hm-rega.0                : hm-rega               : ioBroker-neu                             - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-neu                             - disabled, port: 18701
        system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12001
        system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12010
        system.adapter.influxdb.0               : influxdb              : ioBroker-neu                             - disabled, port: 8086
      + system.adapter.jarvis.0                 : jarvis                : ioBroker-neu                             -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker-neu                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker-neu                             -  enabled, port: 8885, bind: 192.168.178.174
      + system.adapter.net-tools.0              : net-tools             : ioBroker-neu                             -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker-neu                             -  enabled
        system.adapter.solarlog.0               : solarlog              : ioBroker-neu                             - disabled, port: 80
      + system.adapter.time-switch.0            : time-switch           : ioBroker-neu                             -  enabled
        system.adapter.tr-064.0                 : tr-064                : ioBroker-neu                             - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-neu                             -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-neu                             - disabled
        system.adapter.vis.0                    : vis                   : ioBroker-neu                             -  enabled
      + system.adapter.web.0                    : web                   : ioBroker-neu                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects:        1150
      States:         883
      Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:3 http://deb.debian.org/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.174:8885    0.0.0.0:*               LISTEN      1001       26077      4548/io.mqtt.0
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       11133      2261/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4810       600/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11712      2059/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11707      2059/iobroker.js-co
      tcp6       0      0 :::22                   :::*                    LISTEN      0          4812       600/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11777      2077/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13592      2377/io.web.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12637      2173/io.chromecast.
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        561        461/avahi-daemon: r
      udp        0      0 0.0.0.0:34298           0.0.0.0:*                           104        563        461/avahi-daemon: r
      udp6       0      0 fe80::6a9e:ba30:f44:546 :::*                                0          767        539/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        562        461/avahi-daemon: r
      udp6       0      0 :::44980                :::*                                104        564        461/avahi-daemon: r
      2025-04-05 11:14:36.201  - info: mqtt.0 (4120) terminating
      2025-04-05 11:14:36.264  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 11:14:39.629  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4139
      2025-04-05 11:14:42.180  - info: mqtt.0 (4139) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 11:14:42.542  - info: mqtt.0 (4139) Starting MQTT server on 0.0.0.0:8885
      2025-04-05 11:14:42.547  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 11:14:42.560  - info: mqtt.0 (4139) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 11:14:42.564  - info: mqtt.0 (4139) terminating
      2025-04-05 11:14:42.566  - info: mqtt.0 (4139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 11:14:42.619  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 11:14:43.069  - info: mqtt.0 (4139) terminating
      2025-04-05 11:14:43.138  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 11:14:46.552  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4185
      2025-04-05 11:14:49.095  - info: mqtt.0 (4185) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 11:14:49.433  - info: mqtt.0 (4185) Starting MQTT server on 0.0.0.0:8885
      2025-04-05 11:19:36.808  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 11:19:36.815  - info: mqtt.0 (4185) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 11:19:36.819  - info: mqtt.0 (4185) terminating
      2025-04-05 11:19:36.821  - info: mqtt.0 (4185) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 11:19:36.853  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 11:19:37.324  - info: mqtt.0 (4185) terminating
      2025-04-05 11:19:37.402  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 11:19:40.810  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4548
      2025-04-05 11:19:43.269  - info: mqtt.0 (4548) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 11:19:43.590  - info: mqtt.0 (4548) Starting MQTT server on 192.168.178.174:8885
      Thomas Braun dogfight76 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @dogfight76 last edited by
        @dogfight76
        Jetzt ist es sauber.
        • dogfight76
          Da der Pi ja ein anderer ist als vorher , hat sich die IP geändert auf 192.168.178.174 (vorher .140)
          Jetzt meckert die MQTT-Instanz , weil dort ja die .140 eingetragen war.
          Ich also in den Settings von mqtt die IP im Auswahlfenster geändert auf:
          (ipv4) 192.168.178.174-wlan0 , beim Port steht ja die 8885.
          Muss das der Port sein wo man die VIS aufruft ?
          Thomas Braun 1Topf 2 Replies Last reply Reply Quote 0
            @dogfight76
            mqtt hat mit der vis nix zu schaffen. Natürlich lauschen die Dienste auf unterschiedlichen Ports.
            • dogfight76
              Ok, danke.
              Aber warum zeigt mir die Instanz vom mqtt jetzt an:
              Verbunden - grün
              Lebenszeichen - grün
              Verbunden - rot
              Die Einstellungen in der Instanz mit der neuen IP stimmen doch, oder nicht ?
                @dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
                Aber warum
                Schau in das Log.
                dogfight76 1 Reply Last reply Reply Quote 0
                • dogfight76
                  Im Log vom ioBroker steht was den mqtt betrifft:
                  mqtt.0
                  	2025-04-05 12:03:05.677	info	Starting MQTT server on 192.168.178.174:8885
                  mqtt.0
                  	2025-04-05 12:03:05.278	info	starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                  mqtt.0
                  	2025-04-05 12:02:58.680	info	terminating
                  mqtt.0
                  	2025-04-05 12:02:58.177	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  mqtt.0
                  	2025-04-05 12:02:58.175	info	terminating
                  mqtt.0
                  	2025-04-05 12:02:58.173	info	Got terminate signal TERMINATE_YOURSELF
                    Homoran Global Moderator Administrators @dogfight76 last edited by
                    @dogfight76 wissen die clients von der neuen IP?
                    • dogfight76
                      dogfight76 @Homoran last edited by
                      Wo stelle ich die neue IP für Clients ein ?
                      Hatte jetzt nur an den mqqt gedacht ?
                        nicht für!
                        Bei den Clients
                        • dogfight76
                          Ok, gefunden jetzt noch das in der Heishamon -PLatine noch die neue IP eingetragen werden musste !
                          Gemacht und dort ist ja im mqqt-Instanz auch die Port für eingetragen
                          Heishamonm rebootet und mqqt neu gestartet.
                          Aber in der ioBroker-Instanz vom mqqt steht immer
                          Verbunden - grün
                          Verbunden - rot
                          Oder muss da die IP von der Heishamon Platine rein ?
                            wo?
                            du sagst ja nicht was du
                            gefunden
                            hast
                            • dogfight76
                              Mit „Gefunden“ meinte ich die eine Stellen in der heishamon-Einstellung !
                              Geändert auf die .174 , aber die Instanz im iobroker sagt immer noch:
                              Verbunden - grün
                              Verbunden - rot
                              Und die Temperatur im iobroker stimmt nicht überein mit der Anzeige im heishamon.
                              Die Verbindung scheint auch nicht stehen.
                              Weiß nicht warum !?
                              • dogfight76
                                @homoran said in Meldung über Zeitfehler - Was ist das ?:
                                nicht für!
                                Bei den Clients
                                Dann hilf mir bitte mal auf die Sprünge ? Was meinst du damit ?
                                Ich habe im Setuo der Heishamon-PLatine die IP auf die .174 geändert.
                                In den Topics der Heishamon stimmt auch die outside.temp mit 13 Grad
                                Aber die mqtt-Instanz im ioBroker stellt keine Verbindung her.
                                Bei der Auswahl der IP im Setup der Instanz ist das zur Auswahl:
                                Die IP der Heishamon-Platine wäre 192.168.178.68, die steht nircht zur Auswahl.
                                Daher fiel meine Wahl auf "Alle IP zulassen"
                                Verstehe nicht warum der ioBroker keine Verbindung zur Heishamon aufbauen kann.
                                Ihr eine Idee ?
                                  @dogfight76 was sagt denn das debug-log?
                                  • dogfight76
                                    Vom start der mqtt Instanz ?
                                    Wie mache ich ein log direkt davon ?
                                      ja!
                                      das kommt von selber wenn du startest
                                      • dogfight76
                                        Habe bei der Instanz vom mqtt die Protokollebene von Info umgestellt auf debug.
                                        Dann Neustart gemacht:
                                        2025-04-05 17:39:34.253 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                        2025-04-05 17:39:34.261 - info: mqtt.0 (14718) Got terminate signal TERMINATE_YOURSELF
                                        2025-04-05 17:39:34.264 - info: mqtt.0 (14718) terminating
                                        2025-04-05 17:39:34.267 - info: mqtt.0 (14718) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-04-05 17:39:34.301 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                        2025-04-05 17:39:34.771 - info: mqtt.0 (14718) terminating
                                        2025-04-05 17:39:34.827 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-04-05 17:39:38.220 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15640
                                        2025-04-05 17:39:40.700 - info: mqtt.0 (15640) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                        2025-04-05 17:39:41.096 - info: mqtt.0 (15640) Starting MQTT server on 0.0.0.0:8885
                                        2025-04-05 17:40:10.282 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                        2025-04-05 17:40:29.977 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:41:04.982 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                        2025-04-05 17:41:13.785 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:42:03.791 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                        2025-04-05 17:42:14.083 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:42:14.646 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:42:14.663 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                                        2025-04-05 17:43:34.311 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:43:50.324 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:44:21.817 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:44:30.719 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:44:36.373 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:44:41.182 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:45:48.615 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:45:59.136 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:46:06.525 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                                        2025-04-05 17:46:11.861 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 web
                                        2025-04-05 17:47:09.996 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                        2025-04-05 17:47:10.005 - info: mqtt.0 (15640) Got terminate signal TERMINATE_YOURSELF
                                        2025-04-05 17:47:10.007 - info: mqtt.0 (15640) terminating
                                        2025-04-05 17:47:10.010 - info: mqtt.0 (15640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-04-05 17:47:10.045 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                        2025-04-05 17:47:10.512 - info: mqtt.0 (15640) terminating
                                        2025-04-05 17:47:10.575 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-04-05 17:47:13.210 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15942
                                        2025-04-05 17:47:15.035 - debug: mqtt.0 (15942) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2025-04-05 17:47:15.089 - debug: mqtt.0 (15942) Objects client ready ... initialize now
                                        2025-04-05 17:47:15.100 - debug: mqtt.0 (15942) Objects create System PubSub Client
                                        2025-04-05 17:47:15.103 - debug: mqtt.0 (15942) Objects create User PubSub Client
                                        2025-04-05 17:47:15.127 - debug: mqtt.0 (15942) Objects client initialize lua scripts
                                        2025-04-05 17:47:15.137 - debug: mqtt.0 (15942) Objects connected to redis: 127.0.0.1:9001
                                        2025-04-05 17:47:15.160 - debug: mqtt.0 (15942) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2025-04-05 17:47:15.230 - debug: mqtt.0 (15942) States create System PubSub Client
                                        2025-04-05 17:47:15.237 - debug: mqtt.0 (15942) States create User PubSub Client
                                        2025-04-05 17:47:15.298 - debug: mqtt.0 (15942) States connected to redis: 127.0.0.1:9000
                                        2025-04-05 17:47:15.334 - debug: mqtt.0 (15942) Plugin sentry Initialize Plugin (enabled=true)
                                        2025-04-05 17:47:15.762 - info: mqtt.0 (15942) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                        2025-04-05 17:47:16.086 - info: mqtt.0 (15942) Starting MQTT server on 0.0.0.0:8885
                                        2025-04-05 17:47:16.165 - debug: mqtt.0 (15942) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743868036160,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
                                        2025-04-05 17:47:16.217 - debug: mqtt.0 (15942) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743868036212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
                                        2025-04-05 17:47:48.123 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                        2025-04-05 17:47:48.137 - info: mqtt.0 (15942) Got terminate signal TERMINATE_YOURSELF
                                        2025-04-05 17:47:48.143 - info: mqtt.0 (15942) terminating
                                        2025-04-05 17:47:48.146 - debug: mqtt.0 (15942) Plugin sentry destroyed
                                        2025-04-05 17:47:48.149 - info: mqtt.0 (15942) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-04-05 17:47:48.174 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                        2025-04-05 17:47:48.652 - info: mqtt.0 (15942) terminating
                                        2025-04-05 17:47:48.711 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-04-05 17:47:52.106 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15988
                                        2025-04-05 17:47:54.611 - info: mqtt.0 (15988) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                        2025-04-05 17:47:54.938 - info: mqtt.0 (15988) Starting MQTT server on 0.0.0.0:8885
                                        2025-04-05 17:48:42.390 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                                        2025-04-05 17:48:42.403 - info: mqtt.0 (15988) Got terminate signal TERMINATE_YOURSELF
                                        2025-04-05 17:48:42.407 - info: mqtt.0 (15988) terminating
                                        2025-04-05 17:48:42.412 - info: mqtt.0 (15988) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2025-04-05 17:48:42.456 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                                        2025-04-05 17:48:42.914 - info: mqtt.0 (15988) terminating
                                        2025-04-05 17:48:42.971 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2025-04-05 17:48:45.831 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 16045
                                        2025-04-05 17:48:47.733 - debug: mqtt.0 (16045) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                        2025-04-05 17:48:47.767 - debug: mqtt.0 (16045) Objects client ready ... initialize now
                                        2025-04-05 17:48:47.770 - debug: mqtt.0 (16045) Objects create System PubSub Client
                                        2025-04-05 17:48:47.771 - debug: mqtt.0 (16045) Objects create User PubSub Client
                                        2025-04-05 17:48:47.797 - debug: mqtt.0 (16045) Objects client initialize lua scripts
                                        2025-04-05 17:48:47.807 - debug: mqtt.0 (16045) Objects connected to redis: 127.0.0.1:9001
                                        2025-04-05 17:48:47.845 - debug: mqtt.0 (16045) Redis States: Use Redis connection: 127.0.0.1:9000
                                        2025-04-05 17:48:47.856 - debug: mqtt.0 (16045) States create System PubSub Client
                                        2025-04-05 17:48:47.858 - debug: mqtt.0 (16045) States create User PubSub Client
                                        2025-04-05 17:48:47.914 - debug: mqtt.0 (16045) States connected to redis: 127.0.0.1:9000
                                        2025-04-05 17:48:47.950 - debug: mqtt.0 (16045) Plugin sentry Initialize Plugin (enabled=true)
                                        2025-04-05 17:48:48.364 - info: mqtt.0 (16045) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                                        2025-04-05 17:48:48.725 - info: mqtt.0 (16045) Starting MQTT server on 0.0.0.0:8885
                                        2025-04-05 17:48:48.813 - debug: mqtt.0 (16045) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743868128808,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
                                        2025-04-05 17:48:48.864 - debug: mqtt.0 (16045) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743868128860,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
                                        Hoffe das hilft warum keine Verbindung zur Heishamon aufgebaut wird.
                                          Homoran Global Moderator Administrators @dogfight76 last edited by Homoran
                                          wie oft??
                                          bitte nur einen Neustart.
                                          laut log wurde die Instanz 3x neu gestartet
                                          • dogfight76
                                            Das kann wohl sein , weil ich kucken musste wie man debug-log macht
                                            Aber was zu erkennen warum er die heishamon nicht verbinden kann ?
                                            Noch eine Idee ?
                                            Wo muss man die neue IP noch eintragen und gegen die alte IP tauscht.
                                            Habe bei den Instanzen alle setup durchgeschaut. Keine IP Einträge gefunden ! In der heishamon habe ich es angepasst.
                                            Irgendwo muss der Fehler ja liegen….
                                            1.2k
                                            81.1k
                                            6328
