    3. Off Topic
    4. Pflege des Betriebssystems
    5. Meldung über Zeitfehler - Was ist das ?
    • dogfight76
      dogfight76 @Homoran last edited by
      Habe bei der Instanz vom mqtt die Protokollebene von Info umgestellt auf debug.
      Dann Neustart gemacht:
      2025-04-05 17:39:34.253 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 17:39:34.261 - info: mqtt.0 (14718) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 17:39:34.264 - info: mqtt.0 (14718) terminating
      2025-04-05 17:39:34.267 - info: mqtt.0 (14718) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 17:39:34.301 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 17:39:34.771 - info: mqtt.0 (14718) terminating
      2025-04-05 17:39:34.827 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 17:39:38.220 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15640
      2025-04-05 17:39:40.700 - info: mqtt.0 (15640) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 17:39:41.096 - info: mqtt.0 (15640) Starting MQTT server on 0.0.0.0:8885
      2025-04-05 17:40:10.282 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
      2025-04-05 17:40:29.977 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:41:04.982 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
      2025-04-05 17:41:13.785 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:42:03.791 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
      2025-04-05 17:42:14.083 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:42:14.646 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:42:14.663 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
      2025-04-05 17:43:34.311 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:43:50.324 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:44:21.817 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:44:30.719 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:44:36.373 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:44:41.182 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:45:48.615 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:45:59.136 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:46:06.525 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
      2025-04-05 17:46:11.861 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 web
      2025-04-05 17:47:09.996 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 17:47:10.005 - info: mqtt.0 (15640) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 17:47:10.007 - info: mqtt.0 (15640) terminating
      2025-04-05 17:47:10.010 - info: mqtt.0 (15640) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 17:47:10.045 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 17:47:10.512 - info: mqtt.0 (15640) terminating
      2025-04-05 17:47:10.575 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 17:47:13.210 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15942
      2025-04-05 17:47:15.035 - debug: mqtt.0 (15942) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-04-05 17:47:15.089 - debug: mqtt.0 (15942) Objects client ready ... initialize now
      2025-04-05 17:47:15.100 - debug: mqtt.0 (15942) Objects create System PubSub Client
      2025-04-05 17:47:15.103 - debug: mqtt.0 (15942) Objects create User PubSub Client
      2025-04-05 17:47:15.127 - debug: mqtt.0 (15942) Objects client initialize lua scripts
      2025-04-05 17:47:15.137 - debug: mqtt.0 (15942) Objects connected to redis: 127.0.0.1:9001
      2025-04-05 17:47:15.160 - debug: mqtt.0 (15942) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-04-05 17:47:15.230 - debug: mqtt.0 (15942) States create System PubSub Client
      2025-04-05 17:47:15.237 - debug: mqtt.0 (15942) States create User PubSub Client
      2025-04-05 17:47:15.298 - debug: mqtt.0 (15942) States connected to redis: 127.0.0.1:9000
      2025-04-05 17:47:15.334 - debug: mqtt.0 (15942) Plugin sentry Initialize Plugin (enabled=true)
      2025-04-05 17:47:15.762 - info: mqtt.0 (15942) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 17:47:16.086 - info: mqtt.0 (15942) Starting MQTT server on 0.0.0.0:8885
      2025-04-05 17:47:16.165 - debug: mqtt.0 (15942) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743868036160,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
      2025-04-05 17:47:16.217 - debug: mqtt.0 (15942) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743868036212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
      2025-04-05 17:47:48.123 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 17:47:48.137 - info: mqtt.0 (15942) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 17:47:48.143 - info: mqtt.0 (15942) terminating
      2025-04-05 17:47:48.146 - debug: mqtt.0 (15942) Plugin sentry destroyed
      2025-04-05 17:47:48.149 - info: mqtt.0 (15942) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 17:47:48.174 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 17:47:48.652 - info: mqtt.0 (15942) terminating
      2025-04-05 17:47:48.711 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 17:47:52.106 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 15988
      2025-04-05 17:47:54.611 - info: mqtt.0 (15988) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 17:47:54.938 - info: mqtt.0 (15988) Starting MQTT server on 0.0.0.0:8885
      2025-04-05 17:48:42.390 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 17:48:42.403 - info: mqtt.0 (15988) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 17:48:42.407 - info: mqtt.0 (15988) terminating
      2025-04-05 17:48:42.412 - info: mqtt.0 (15988) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 17:48:42.456 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 17:48:42.914 - info: mqtt.0 (15988) terminating
      2025-04-05 17:48:42.971 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 17:48:45.831 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 16045
      2025-04-05 17:48:47.733 - debug: mqtt.0 (16045) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-04-05 17:48:47.767 - debug: mqtt.0 (16045) Objects client ready ... initialize now
      2025-04-05 17:48:47.770 - debug: mqtt.0 (16045) Objects create System PubSub Client
      2025-04-05 17:48:47.771 - debug: mqtt.0 (16045) Objects create User PubSub Client
      2025-04-05 17:48:47.797 - debug: mqtt.0 (16045) Objects client initialize lua scripts
      2025-04-05 17:48:47.807 - debug: mqtt.0 (16045) Objects connected to redis: 127.0.0.1:9001
      2025-04-05 17:48:47.845 - debug: mqtt.0 (16045) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-04-05 17:48:47.856 - debug: mqtt.0 (16045) States create System PubSub Client
      2025-04-05 17:48:47.858 - debug: mqtt.0 (16045) States create User PubSub Client
      2025-04-05 17:48:47.914 - debug: mqtt.0 (16045) States connected to redis: 127.0.0.1:9000
      2025-04-05 17:48:47.950 - debug: mqtt.0 (16045) Plugin sentry Initialize Plugin (enabled=true)
      2025-04-05 17:48:48.364 - info: mqtt.0 (16045) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 17:48:48.725 - info: mqtt.0 (16045) Starting MQTT server on 0.0.0.0:8885
      2025-04-05 17:48:48.813 - debug: mqtt.0 (16045) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743868128808,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
      2025-04-05 17:48:48.864 - debug: mqtt.0 (16045) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743868128860,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
      Hoffe das hilft warum keine Verbindung zur Heishamon aufgebaut wird.
        Homoran Global Moderator Administrators @dogfight76 last edited by Homoran
        @dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
        wie oft??
        bitte nur einen Neustart.
        laut log wurde die Instanz 3x neu gestartet
        dogfight76 1 Reply Last reply Reply Quote 0
        • dogfight76
          Das kann wohl sein , weil ich kucken musste wie man debug-log macht
          Aber was zu erkennen warum er die heishamon nicht verbinden kann ?
          Noch eine Idee ?
          Wo muss man die neue IP noch eintragen und gegen die alte IP tauscht.
          Habe bei den Instanzen alle setup durchgeschaut. Keine IP Einträge gefunden ! In der heishamon habe ich es angepasst.
          Irgendwo muss der Fehler ja liegen….
            nein.
            kann man an der Platine die Verbindung testen?
            sonst lass mal das log auf debug und starte die Platine neu.
            ein iob diag in der Langfassung schadet nie
            • dogfight76
              dogfight76 @dogfight76 last edited by
              @dogfight76 said in Meldung über Zeitfehler - Was ist das ?:
              Jetzt geht auch der Befehl:
              "iob diag"
              Läuft gerade, Ergebnis kommt sofort
              Edit für Ergebnis:
              Copy text starting here:
              ```bash
                                      v.2025-02-23
               Static hostname: ioBroker-neu
                     Icon name: computer
                        Kernel: Linux 6.12.20+rpt-rpi-v8
                  Architecture: arm64
              Installation:           native
              Kernel:                 aarch64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1000
              Display-Server:         false
              Boot Target:            multi-user.target
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:
              /usr/bin/nodejs         v20.19.0
              /usr/bin/node           v20.19.0
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              /usr/bin/corepack       0.31.0
              Recommended versions are nodejs 20.19.0 and npm 10.8.2
              nodeJS installation is correct
              MEMORY:
              Mem:            4.0G        1.1G        2.2G        1.2M        807M        2.9G
              Swap:           536M          0B        536M
              Total:          4.5G        1.1G        2.7G
              Active iob-Instances:   13
              Upgrade policy: none
              ioBroker Core:          js-controller           7.0.6
                                      admin                   7.6.3
              Objects type: jsonl
              States  type: jsonl
              + system.adapter.admin.0                  : admin                 : ioBroker-neu                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.web.0                    : web                   : ioBroker-neu                             -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              Objects:                1150
              States:                 882
              Size of iob-Database:
              12M     /opt/iobroker/iobroker-data/objects.jsonl
              684K    /opt/iobroker/iobroker-data/states.jsonl
              Operating System is the current Debian stable version codenamed 'bookworm'!
              Das Ergebniss Fenster ist neu in der Version "Bookworm" ?
              Das iob diag von vorhin ! Ist sauber……
                ist aber immer noch nicht zur Langfassung mutiert!
                • dogfight76
                  Moment.....
                  Edit Ergebnis @Thomas-braun
                  ========== Start marking the full check here ===========
                  ```bash
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                         Icon name: computer
                      Architecture: arm64
                  OS is similar to:
                  Model           : Raspberry Pi 4 Model B Rev 1.1
                  Docker          : false
                  Virtualization  : none
                  Kernel          : aarch64
                  Userland        : 64 bit
                  Systemuptime and Load:
                   11:21:44 up 23 min,  2 users,  load average: 0.23, 0.27, 0.32
                  CPU threads: 4
                  *** LIFE CYCLE STATUS ***
                  *** RASPBERRY THROTTLING ***
                  Current issues:
                  Previously detected issues:
                  *** TIME AND TIMEZONES ***
                                 Local time: Sat 2025-04-05 11:21:44 CEST
                             Universal time: Sat 2025-04-05 09:21:44 UTC
                                   RTC time: n/a
                                NTP service: active
                            RTC in local TZ: no
                  *** Users and Groups ***
                  User that called 'iob diag':
                  dogfight76
                  HOME=/home/dogfight76
                  GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                  *** DISPLAY-SERVER SETUP ***
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Mem:            4.0G        1.1G        2.2G        1.2M        808M        2.9G
                  Swap:           536M          0B        536M
                  Active iob-Instances:   14
                           3791 M total memory
                           1003 M used memory
                            971 M active memory
                            490 M inactive memory
                           2093 M free memory
                            100 M buffer memory
                            670 M swap cache
                            511 M total swap
                              0 M used swap
                            511 M free swap
                  top - 11:21:45 up 23 min,  2 users,  load average: 0.23, 0.27, 0.32
                  Tasks: 182 total,   1 running, 181 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 20.0 us,  0.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :   3791.4 total,   2094.0 free,   1003.5 used,    770.7 buff/cache
                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2787.9 avail Mem
                  *** FAILED SERVICES ***
                  0 loaded units listed.
                  *** DMESG CRITICAL ERRORS ***
                  No critical errors detected
                  *** FILESYSTEM ***
                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                  tmpfs          tmpfs     380M  1.2M  379M   1% /run
                  /dev/mmcblk0p2 ext4      117G  5.7G  106G   6% /
                  tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                  /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                  [Sat Apr  5 10:58:20 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:0D:BC:95 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d72bd49f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                  [Sat Apr  5 10:58:23 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                  [Sat Apr  5 10:58:24 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                  Show mounted filesystems:
                  TARGET           SOURCE         FSTYPE OPTIONS
                  /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  936M    /var/
                  204M    /var/cache
                  199M    /var/cache/apt
                  167M    /var/lib
                  135M    /var/lib/apt/lists
                  Archived and active journals take up 52.0M in the file system.
                  /opt/iobroker/backups:
                  8.5M    /opt/iobroker/backups/
                  /opt/iobroker/iobroker-data:
                  740M    /opt/iobroker/iobroker-data/
                  727M    /opt/iobroker/iobroker-data/files
                  617M    /opt/iobroker/iobroker-data/files/javascript.admin
                  560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                  558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                  8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                  8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
                  7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
                  USB-Devices by-id:
                  No Devices found 'by-id'
                  Zigbee Network Settings on your coordinator/in nvbackup are:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  To unmask the settings run 'iob diag --unmask'
                  *** NodeJS-Installation ***
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Installed: 20.19.0-1nodesource1
                    Candidate: 20.19.0-1nodesource1
                    Version table:
                   *** 20.19.0-1nodesource1 1001
                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                          100 /var/lib/dpkg/status
                       20.18.3-1nodesource1 1001
                       20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                       18.19.0+dfsg-6~deb12u2 500
                       18.19.0+dfsg-6~deb12u1 500
                  No problems detected
                  Errors in npm tree: 0
                  *** ioBroker-Installation ***
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  ioBroker-neu        ioBroker-neu (version: 7.0.6, hostname: ioBroker-neu  , alive, uptime: 1188)
                  Core adapters versions
                  admin:          7.6.3
                  javascript:     8.8.3
                  nodejs modules from github:     1
                  +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
                  Adapter State
                  + system.adapter.backitup.0               : backitup              : ioBroker-neu                             -  enabled
                  + system.adapter.chromecast.0             : chromecast            : ioBroker-neu                             -  enabled
                  + system.adapter.cloud.0                  : cloud                 : ioBroker-neu                             -  enabled
                    system.adapter.discovery.0              : discovery             : ioBroker-neu                             - disabled
                    system.adapter.fritzdect.0              : fritzdect             : ioBroker-neu                             - disabled
                  + system.adapter.history.0                : history               : ioBroker-neu                             -  enabled
                    system.adapter.hm-rega.0                : hm-rega               : ioBroker-neu                             - disabled
                    system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-neu                             - disabled, port: 18701
                    system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12001
                    system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12010
                    system.adapter.influxdb.0               : influxdb              : ioBroker-neu                             - disabled, port: 8086
                  + system.adapter.jarvis.0                 : jarvis                : ioBroker-neu                             -  enabled
                  + system.adapter.javascript.0             : javascript            : ioBroker-neu                             -  enabled
                  + system.adapter.mqtt.0                   : mqtt                  : ioBroker-neu                             -  enabled, port: 8885, bind: 192.168.178.174
                  + system.adapter.net-tools.0              : net-tools             : ioBroker-neu                             -  enabled
                  + system.adapter.ping.0                   : ping                  : ioBroker-neu                             -  enabled
                    system.adapter.solarlog.0               : solarlog              : ioBroker-neu                             - disabled, port: 80
                  + system.adapter.time-switch.0            : time-switch           : ioBroker-neu                             -  enabled
                    system.adapter.tr-064.0                 : tr-064                : ioBroker-neu                             - disabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-neu                             -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-neu                             - disabled
                    system.adapter.vis.0                    : vis                   : ioBroker-neu                             -  enabled
                  + instance is alive
                  ioBroker-Repositories
                  Active repo(s): stable
                  Installed ioBroker-Adapters
                  Used repository: stable
                  Adapter    "admin"        : 7.6.3    , installed 7.6.3
                  Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                  Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                  Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
                  Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                  Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                  Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
                  Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                  Controller "js-controller": 7.0.6    , installed 7.0.6
                  Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                  Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
                  Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                  Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
                  Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                  Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Adapter    "ws"           : 2.6.2    , installed 3.0.19
                  Objects and States
                  Objects:        1150
                  States:         883
                  Hit:1 http://archive.raspberrypi.com/debian bookworm InRelease
                  Hit:2 https://deb.nodesource.com/node_20.x nodistro InRelease
                  Hit:3 http://deb.debian.org/debian bookworm InRelease
                  Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
                  Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                  Reading package lists...
                  Pending Updates: 0
                  *** Listening Ports ***
                  tcp        0      0 192.168.178.174:8885    0.0.0.0:*               LISTEN      1001       26077      4548/io.mqtt.0
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       11133      2261/io.jarvis.0
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4810       600/sshd: /usr/sbin
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11712      2059/iobroker.js-co
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       11707      2059/iobroker.js-co
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          4812       600/sshd: /usr/sbin
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       11777      2077/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       13592      2377/io.web.0
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       12637      2173/io.chromecast.
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        561        461/avahi-daemon: r
                  udp        0      0 0.0.0.0:34298           0.0.0.0:*                           104        563        461/avahi-daemon: r
                  udp6       0      0 fe80::6a9e:ba30:f44:546 :::*                                0          767        539/NetworkManager
                  udp6       0      0 :::5353                 :::*                                104        562        461/avahi-daemon: r
                  udp6       0      0 :::44980                :::*                                104        564        461/avahi-daemon: r
                  2025-04-05 11:14:36.201  - info: mqtt.0 (4120) terminating
                  2025-04-05 11:14:36.264  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-04-05 11:14:39.629  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4139
                  2025-04-05 11:14:42.180  - info: mqtt.0 (4139) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                  2025-04-05 11:14:42.542  - info: mqtt.0 (4139) Starting MQTT server on 0.0.0.0:8885
                  2025-04-05 11:14:42.547  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                  2025-04-05 11:14:42.560  - info: mqtt.0 (4139) Got terminate signal TERMINATE_YOURSELF
                  2025-04-05 11:14:42.564  - info: mqtt.0 (4139) terminating
                  2025-04-05 11:14:42.566  - info: mqtt.0 (4139) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-04-05 11:14:42.619  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                  2025-04-05 11:14:43.069  - info: mqtt.0 (4139) terminating
                  2025-04-05 11:14:43.138  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-04-05 11:14:46.552  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4185
                  2025-04-05 11:14:49.095  - info: mqtt.0 (4185) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                  2025-04-05 11:14:49.433  - info: mqtt.0 (4185) Starting MQTT server on 0.0.0.0:8885
                  2025-04-05 11:19:36.808  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                  2025-04-05 11:19:36.815  - info: mqtt.0 (4185) Got terminate signal TERMINATE_YOURSELF
                  2025-04-05 11:19:36.819  - info: mqtt.0 (4185) terminating
                  2025-04-05 11:19:36.821  - info: mqtt.0 (4185) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-04-05 11:19:36.853  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                  2025-04-05 11:19:37.324  - info: mqtt.0 (4185) terminating
                  2025-04-05 11:19:37.402  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-04-05 11:19:40.810  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 4548
                  2025-04-05 11:19:43.269  - info: mqtt.0 (4548) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                  2025-04-05 11:19:43.590  - info: mqtt.0 (4548) Starting MQTT server on 192.168.178.174:8885
                  Sorry , das war die lange Fassung ! Aber wie er gerade sagte. Das war in Ordnung
                    Das war in Ordnung
                    Das war auch bevor du die Einstellungen geändert hast
                      • dogfight76
                        @homoran said in Meldung über Zeitfehler - Was ist das ?:
                        Ok, das sagt mir was ?
                        • dogfight76
                          2025-04-05 18:25:13.433 - info: cloud.0 (8859) User accessed from cloud: fn7ejk8WjN-vkr_8AUdq
                          2025-04-05 18:25:30.681 - info: cloud.0 (8859) User disconnected from cloud: vis.0
                          2025-04-05 18:55:46.278 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                          2025-04-05 18:56:59.362 - info: web.0 (9020) <== Disconnect system.user.admin from ::ffff:192.168.178.130 vis.0
                          2025-04-05 19:00:00.083 - debug: mqtt.0 (16045) stateChange mqtt.0.Waermepumpe.commands.SetOperationMode: {"val":0,"ack":false,"ts":1743872400072,"q":0,"c":"script.js.common.Meine_Geraete.Heizung.Warmwassertimer","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1743872400072}
                          2025-04-05 19:00:00.086 - debug: mqtt.0 (16045) onStateChange mqtt.0.Waermepumpe.commands.SetOperationMode: {"val":0,"ack":false,"ts":1743872400072,"q":0,"c":"script.js.common.Meine_Geraete.Heizung.Warmwassertimer","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1743872400072}
                          2025-04-05 19:00:00.091 - debug: mqtt.0 (16045) stateChange mqtt.0.Waermepumpe.commands.SetHeatpump: {"val":1,"ack":false,"ts":1743872400072,"q":0,"c":"script.js.common.Meine_Geraete.Heizung.Warmwassertimer","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1743844119907}
                          2025-04-05 19:06:38.992 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                          2025-04-05 19:06:40.578 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                          2025-04-05 19:06:43.672 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                          2025-04-05 19:06:43.720 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                          2025-04-05 19:06:44.184 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                          2025-04-05 19:06:45.170 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin
                          2025-04-05 19:07:41.584 - info: web.0 (9020) ==> Connected system.user.admin from ::ffff:192.168.178.130
                          2025-04-05 19:07:53.127 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130
                          2025-04-05 19:08:46.050 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                          2025-04-05 19:08:46.065 - info: mqtt.0 (16045) Got terminate signal TERMINATE_YOURSELF
                          2025-04-05 19:08:46.071 - info: mqtt.0 (16045) terminating
                          2025-04-05 19:08:46.074 - debug: mqtt.0 (16045) Plugin sentry destroyed
                          2025-04-05 19:08:46.075 - info: mqtt.0 (16045) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-04-05 19:08:46.109 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                          2025-04-05 19:08:46.578 - info: mqtt.0 (16045) terminating
                          2025-04-05 19:08:46.646 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2025-04-05 19:08:50.022 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 19192
                          2025-04-05 19:08:52.441 - debug: mqtt.0 (19192) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2025-04-05 19:08:52.485 - debug: mqtt.0 (19192) Objects client ready ... initialize now
                          2025-04-05 19:08:52.488 - debug: mqtt.0 (19192) Objects create System PubSub Client
                          2025-04-05 19:08:52.490 - debug: mqtt.0 (19192) Objects create User PubSub Client
                          2025-04-05 19:08:52.516 - debug: mqtt.0 (19192) Objects client initialize lua scripts
                          2025-04-05 19:08:52.528 - debug: mqtt.0 (19192) Objects connected to redis: 127.0.0.1:9001
                          2025-04-05 19:08:52.554 - debug: mqtt.0 (19192) Redis States: Use Redis connection: 127.0.0.1:9000
                          2025-04-05 19:08:52.566 - debug: mqtt.0 (19192) States create System PubSub Client
                          2025-04-05 19:08:52.568 - debug: mqtt.0 (19192) States create User PubSub Client
                          2025-04-05 19:08:52.626 - debug: mqtt.0 (19192) States connected to redis: 127.0.0.1:9000
                          2025-04-05 19:08:52.663 - debug: mqtt.0 (19192) Plugin sentry Initialize Plugin (enabled=true)
                          2025-04-05 19:08:53.097 - info: mqtt.0 (19192) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                          2025-04-05 19:08:53.281 - info: mqtt.0 (19192) Starting MQTT authenticated server on 0.0.0.0:8885
                          2025-04-05 19:08:53.361 - debug: mqtt.0 (19192) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743872933357,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
                          2025-04-05 19:08:53.412 - debug: mqtt.0 (19192) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872933408,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
                          2025-04-05 19:09:09.522 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
                          2025-04-05 19:09:09.533 - info: mqtt.0 (19192) Got terminate signal TERMINATE_YOURSELF
                          2025-04-05 19:09:09.538 - info: mqtt.0 (19192) terminating
                          2025-04-05 19:09:09.540 - debug: mqtt.0 (19192) Plugin sentry destroyed
                          2025-04-05 19:09:09.542 - info: mqtt.0 (19192) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2025-04-05 19:09:09.570 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
                          2025-04-05 19:09:10.046 - info: mqtt.0 (19192) terminating
                          2025-04-05 19:09:10.124 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2025-04-05 19:09:13.466 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 19207
                          2025-04-05 19:09:15.327 - debug: mqtt.0 (19207) Redis Objects: Use Redis connection: 127.0.0.1:9001
                          2025-04-05 19:09:15.381 - debug: mqtt.0 (19207) Objects client ready ... initialize now
                          2025-04-05 19:09:15.392 - debug: mqtt.0 (19207) Objects create System PubSub Client
                          2025-04-05 19:09:15.395 - debug: mqtt.0 (19207) Objects create User PubSub Client
                          2025-04-05 19:09:15.418 - debug: mqtt.0 (19207) Objects client initialize lua scripts
                          2025-04-05 19:09:15.428 - debug: mqtt.0 (19207) Objects connected to redis: 127.0.0.1:9001
                          2025-04-05 19:09:15.450 - debug: mqtt.0 (19207) Redis States: Use Redis connection: 127.0.0.1:9000
                          2025-04-05 19:09:15.461 - debug: mqtt.0 (19207) States create System PubSub Client
                          2025-04-05 19:09:15.462 - debug: mqtt.0 (19207) States create User PubSub Client
                          2025-04-05 19:09:15.518 - debug: mqtt.0 (19207) States connected to redis: 127.0.0.1:9000
                          2025-04-05 19:09:15.556 - debug: mqtt.0 (19207) Plugin sentry Initialize Plugin (enabled=true)
                          2025-04-05 19:09:15.967 - info: mqtt.0 (19207) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
                          2025-04-05 19:09:16.136 - info: mqtt.0 (19207) Starting MQTT authenticated server on 0.0.0.0:8885
                          2025-04-05 19:09:16.217 - debug: mqtt.0 (19207) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743872956212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
                          2025-04-05 19:09:16.269 - debug: mqtt.0 (19207) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872956265,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
                          Erst die heishamon neu gestarttet und dann mqtt und das debug log hier oben
                          • dogfight76
                            Ok, stimmt.
                            Hier ein ganz frisches:
                            ```bash
                            Script v.2025-02-23
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             19:15:20 up  7:34,  2 users,  load average: 0.10, 0.15, 0.15
                            CPU threads: 4
                            Current issues:
                                           Local time: Sat 2025-04-05 19:15:20 CEST
                                       Universal time: Sat 2025-04-05 17:15:20 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            dogfight76
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.0G        1.1G        2.5G        1.2M        473M        2.9G
                            Swap:           536M          0B        536M
                            Total:          4.5G        1.1G        3.0G
                                     3791 M total memory
                                     1072 M used memory
                                     1113 M active memory
                                      217 M inactive memory
                                     2340 M free memory
                                       52 M buffer memory
                                      399 M swap cache
                                      511 M total swap
                                        0 M used swap
                                      511 M free swap
                            top - 19:15:21 up  7:34,  2 users,  load average: 0.10, 0.15, 0.15
                            Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3791.4 total,   2340.5 free,   1072.7 used,    451.9 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2718.7 avail Mem
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4      117G  5.8G  106G   6% /
                            [Sat Apr  5 11:41:17 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=inter                             leave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:0D:BC:95 vc_mem.mem_base=0x3ec00000                              vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d72bd49f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_reg                             dom=DE
                            [Sat Apr  5 11:41:19 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                            [Sat Apr  5 11:41:20 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                            /var:
                            968M    /var/
                            204M    /var/cache
                            199M    /var/cache/apt
                            167M    /var/lib
                            Archived and active journals take up 84.0M in the file system.
                            752M    /opt/iobroker/iobroker-data/
                            13M     /opt/iobroker/iobroker-data/objects.jsonl
                            7.3M    /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            ioBroker-neu        ioBroker-neu (version: 7.0.6, hostname: ioBroker-neu  , alive, uptime: 15753)
                            admin:          7.6.3
                            javascript:     8.8.3
                            Adapter State
                            + system.adapter.mqtt.0                   : mqtt                  : ioBroker-neu                             -  enabled, port: 8885, bind: 0.0.0.0
                            + instance is alive
                            Objects and States
                            Objects:        1196
                            States:         915
                            Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                            Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                            Pending Updates: 3
                            tcp        0      0 0.0.0.0:8885            0.0.0.0:*               LISTEN      1001       202366     19207/io.mqtt.0
                            tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       91535      8929/io.jarvis.0
                            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       90278      8727/iobroker.js-co
                            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       90283      8727/iobroker.js-co
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3938       595/sshd: /usr/sbin
                            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       89781      9020/io.web.0
                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       91245      8745/io.admin.0
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          3940       595/sshd: /usr/sbin
                            udp        0      0 0.0.0.0:44223           0.0.0.0:*                           104        5622       456/avahi-daemon: r
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       153775     14695/io.chromecast
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5620       456/avahi-daemon: r
                            udp6       0      0 :::38634                :::*                                104        5623       456/avahi-daemon: r
                            udp6       0      0 fe80::6a9e:ba30:f44:546 :::*                                0          4996       534/NetworkManager
                            udp6       0      0 :::5353                 :::*                                104        5621       456/avahi-daemon: r
                            Hoffe es gibt aufschluss.....
                            • dogfight76
                              Die Einstellungen sind doch korrekt, oder ??
                              Homoran W 2 Replies Last reply Reply Quote 0
                                weiss ich nicht.
                                jetzt hast du user passwort!
                                ist das auch auf der Platine bekannt
                                • dogfight76
                                  Ich muss ja etwas probieren , also User und Passwort bei beiden eingetragen ! Ist auf den Screenshots extra festgehalten.
                                  Denn anscheinend geben die Logs auch keine Hinweise. Oder jemand etwas entdeckt ?
                                  Eigentlich hat sich ja nur die IP Endung von .140 auf .174 geändert.
                                  Kein Plan warum mqtt die heishamon nicht findet
                                    Wildbill @dogfight76 last edited by
                                    Du hast da bei der IP im Heisha einen Zahlendreher. Dein iobroker hat hinten 174, Du hast aber 147 drin. So kann es ja nix werden!
                                    Gruss, Jürgen
                                    dogfight76 1 Reply Last reply Reply Quote 2
                                    • dogfight76
                                      dogfight76 @Wildbill last edited by
                                      @wildbill
                                      Fuck my life.......
                                      Natürlich, das war´s !
                                      Vor lauter Bäumen......
                                      Danke , jetzt ist natürlich Verbindung da !!
                                      • 1Topf
                                        1Topf @dogfight76 last edited by
                                        Da der Pi ja ein anderer ist als vorher , hat sich die IP geändert auf 192.168.178.174 (vorher .140)
                                        Wäre es nicht einfacher gewesen, dem neuen Pi die Adresse des alten Pi zu verpassen? 🤔
                                        • dogfight76
                                          dogfight76 @1Topf last edited by
                                          @1topf
                                          Ja im nachhinein wäre es wohl klüger gewesen.....
                                          Aber jetzt läuft ja alles wieder 😉
                                          Danke für eure Hilferstellung
                                            Thomas Braun Most Active @dogfight76 last edited by
                                            @dogfight76
                                            Oder man verwendet hostnames statt IPs.
                                            1.2k
                                            81.1k
                                            6328
