Meldung über Zeitfehler - Was ist das ?
@dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
system.adapter.mqtt.0 : mqtt : ioBroker-neu - enabled, port: 8885, bind: 192.168.178.174
@homoran said in Meldung über Zeitfehler - Was ist das ?:
Ok, das sagt mir was ?
sonst lass mal das log auf debug und starte die Platine neu.
2025-04-05 18:25:13.433 - info: cloud.0 (8859) User accessed from cloud: fn7ejk8WjN-vkr_8AUdq 2025-04-05 18:25:30.681 - info: cloud.0 (8859) User disconnected from cloud: vis.0 2025-04-05 18:55:46.278 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin 2025-04-05 18:56:59.362 - info: web.0 (9020) <== Disconnect system.user.admin from ::ffff:192.168.178.130 vis.0 2025-04-05 19:00:00.083 - debug: mqtt.0 (16045) stateChange mqtt.0.Waermepumpe.commands.SetOperationMode: {"val":0,"ack":false,"ts":1743872400072,"q":0,"c":"script.js.common.Meine_Geraete.Heizung.Warmwassertimer","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1743872400072} 2025-04-05 19:00:00.086 - debug: mqtt.0 (16045) onStateChange mqtt.0.Waermepumpe.commands.SetOperationMode: {"val":0,"ack":false,"ts":1743872400072,"q":0,"c":"script.js.common.Meine_Geraete.Heizung.Warmwassertimer","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1743872400072} 2025-04-05 19:00:00.091 - debug: mqtt.0 (16045) stateChange mqtt.0.Waermepumpe.commands.SetHeatpump: {"val":1,"ack":false,"ts":1743872400072,"q":0,"c":"script.js.common.Meine_Geraete.Heizung.Warmwassertimer","from":"system.adapter.javascript.0","user":"system.user.admin","lc":1743844119907} 2025-04-05 19:06:38.992 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130 2025-04-05 19:06:40.578 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin 2025-04-05 19:06:43.672 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130 2025-04-05 19:06:43.720 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin 2025-04-05 19:06:44.184 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130 2025-04-05 19:06:45.170 - info: admin.0 (8745) <== Disconnect system.user.admin from ::ffff:192.168.178.130 admin 2025-04-05 19:07:41.584 - info: web.0 (9020) ==> Connected system.user.admin from ::ffff:192.168.178.130 2025-04-05 19:07:53.127 - info: admin.0 (8745) ==> Connected system.user.admin from ::ffff:192.168.178.130 2025-04-05 19:08:46.050 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true) 2025-04-05 19:08:46.065 - info: mqtt.0 (16045) Got terminate signal TERMINATE_YOURSELF 2025-04-05 19:08:46.071 - info: mqtt.0 (16045) terminating 2025-04-05 19:08:46.074 - debug: mqtt.0 (16045) Plugin sentry destroyed 2025-04-05 19:08:46.075 - info: mqtt.0 (16045) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-04-05 19:08:46.109 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal 2025-04-05 19:08:46.578 - info: mqtt.0 (16045) terminating 2025-04-05 19:08:46.646 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-04-05 19:08:50.022 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 19192 2025-04-05 19:08:52.441 - debug: mqtt.0 (19192) Redis Objects: Use Redis connection: 127.0.0.1:9001 2025-04-05 19:08:52.485 - debug: mqtt.0 (19192) Objects client ready ... initialize now 2025-04-05 19:08:52.488 - debug: mqtt.0 (19192) Objects create System PubSub Client 2025-04-05 19:08:52.490 - debug: mqtt.0 (19192) Objects create User PubSub Client 2025-04-05 19:08:52.516 - debug: mqtt.0 (19192) Objects client initialize lua scripts 2025-04-05 19:08:52.528 - debug: mqtt.0 (19192) Objects connected to redis: 127.0.0.1:9001 2025-04-05 19:08:52.554 - debug: mqtt.0 (19192) Redis States: Use Redis connection: 127.0.0.1:9000 2025-04-05 19:08:52.566 - debug: mqtt.0 (19192) States create System PubSub Client 2025-04-05 19:08:52.568 - debug: mqtt.0 (19192) States create User PubSub Client 2025-04-05 19:08:52.626 - debug: mqtt.0 (19192) States connected to redis: 127.0.0.1:9000 2025-04-05 19:08:52.663 - debug: mqtt.0 (19192) Plugin sentry Initialize Plugin (enabled=true) 2025-04-05 19:08:53.097 - info: mqtt.0 (19192) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6 2025-04-05 19:08:53.281 - info: mqtt.0 (19192) Starting MQTT authenticated server on 0.0.0.0:8885 2025-04-05 19:08:53.361 - debug: mqtt.0 (19192) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743872933357,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234} 2025-04-05 19:08:53.412 - debug: mqtt.0 (19192) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872933408,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251} 2025-04-05 19:09:09.522 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true) 2025-04-05 19:09:09.533 - info: mqtt.0 (19192) Got terminate signal TERMINATE_YOURSELF 2025-04-05 19:09:09.538 - info: mqtt.0 (19192) terminating 2025-04-05 19:09:09.540 - debug: mqtt.0 (19192) Plugin sentry destroyed 2025-04-05 19:09:09.542 - info: mqtt.0 (19192) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-04-05 19:09:09.570 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal 2025-04-05 19:09:10.046 - info: mqtt.0 (19192) terminating 2025-04-05 19:09:10.124 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-04-05 19:09:13.466 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 19207 2025-04-05 19:09:15.327 - debug: mqtt.0 (19207) Redis Objects: Use Redis connection: 127.0.0.1:9001 2025-04-05 19:09:15.381 - debug: mqtt.0 (19207) Objects client ready ... initialize now 2025-04-05 19:09:15.392 - debug: mqtt.0 (19207) Objects create System PubSub Client 2025-04-05 19:09:15.395 - debug: mqtt.0 (19207) Objects create User PubSub Client 2025-04-05 19:09:15.418 - debug: mqtt.0 (19207) Objects client initialize lua scripts 2025-04-05 19:09:15.428 - debug: mqtt.0 (19207) Objects connected to redis: 127.0.0.1:9001 2025-04-05 19:09:15.450 - debug: mqtt.0 (19207) Redis States: Use Redis connection: 127.0.0.1:9000 2025-04-05 19:09:15.461 - debug: mqtt.0 (19207) States create System PubSub Client 2025-04-05 19:09:15.462 - debug: mqtt.0 (19207) States create User PubSub Client 2025-04-05 19:09:15.518 - debug: mqtt.0 (19207) States connected to redis: 127.0.0.1:9000 2025-04-05 19:09:15.556 - debug: mqtt.0 (19207) Plugin sentry Initialize Plugin (enabled=true) 2025-04-05 19:09:15.967 - info: mqtt.0 (19207) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6 2025-04-05 19:09:16.136 - info: mqtt.0 (19207) Starting MQTT authenticated server on 0.0.0.0:8885 2025-04-05 19:09:16.217 - debug: mqtt.0 (19207) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743872956212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234} 2025-04-05 19:09:16.269 - debug: mqtt.0 (19207) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872956265,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}Erst die heishamon neu gestarttet und dann mqtt und das debug log hier oben
Das war auch bevor du die Einstellungen geändert hast
Ok, stimmt.
Hier ein ganz frisches:
========== Start marking the full check here =========== ```bash Script v.2025-02-23 *** BASE SYSTEM *** Static hostname: ioBroker-neu Icon name: computer Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.12.20+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.1 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 19:15:20 up 7:34, 2 users, load average: 0.10, 0.15, 0.15 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Sat 2025-04-05 19:15:20 CEST Universal time: Sat 2025-04-05 17:15:20 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': dogfight76 HOME=/home/dogfight76 GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 4.0G 1.1G 2.5G 1.2M 473M 2.9G Swap: 536M 0B 536M Total: 4.5G 1.1G 3.0G Active iob-Instances: 14 3791 M total memory 1072 M used memory 1113 M active memory 217 M inactive memory 2340 M free memory 52 M buffer memory 399 M swap cache 511 M total swap 0 M used swap 511 M free swap *** top - Table Of Processes *** top - 19:15:21 up 7:34, 2 users, load average: 0.10, 0.15, 0.15 Tasks: 183 total, 1 running, 182 sleeping, 0 stopped, 0 zombie %Cpu(s): 16.7 us, 16.7 sy, 0.0 ni, 66.7 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 3791.4 total, 2340.5 free, 1072.7 used, 451.9 buff/cache MiB Swap: 512.0 total, 512.0 free, 0.0 used. 2718.7 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 1.6G 0 1.6G 0% /dev tmpfs tmpfs 380M 1.2M 379M 1% /run /dev/mmcblk0p2 ext4 117G 5.8G 106G 6% / tmpfs tmpfs 1.9G 0 1.9G 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 56M 455M 11% /boot/firmware tmpfs tmpfs 380M 0 380M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Sat Apr 5 11:41:17 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=inter leave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:0D:BC:95 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=d72bd49f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_reg dom=DE [Sat Apr 5 11:41:19 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none. [Sat Apr 5 11:41:20 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime,commit=600 `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 968M /var/ 204M /var/cache 199M /var/cache/apt 167M /var/lib 135M /var/lib/apt/lists Archived and active journals take up 84.0M in the file system. /opt/iobroker/backups: 8.5M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 752M /opt/iobroker/iobroker-data/ 727M /opt/iobroker/iobroker-data/files 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 13M /opt/iobroker/iobroker-data/objects.jsonl 8.7M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map 8.6M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map 7.3M /opt/iobroker/iobroker-data/states.jsonl 7.0M /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.0 /usr/bin/node v20.19.0 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.31.0 nodejs: Installed: 20.19.0-1nodesource1 Candidate: 20.19.0-1nodesource1 Version table: *** 20.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 20.18.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: ioBroker-neu ioBroker-neu (version: 7.0.6, hostname: ioBroker-neu , alive, uptime: 15753) Core adapters versions js-controller: 7.0.6 admin: 7.6.3 javascript: 8.8.3 nodejs modules from github: 1 +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e) Adapter State + system.adapter.admin.0 : admin : ioBroker-neu - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : ioBroker-neu - enabled + system.adapter.chromecast.0 : chromecast : ioBroker-neu - enabled + system.adapter.cloud.0 : cloud : ioBroker-neu - enabled system.adapter.discovery.0 : discovery : ioBroker-neu - disabled system.adapter.fritzdect.0 : fritzdect : ioBroker-neu - disabled + system.adapter.history.0 : history : ioBroker-neu - enabled system.adapter.hm-rega.0 : hm-rega : ioBroker-neu - disabled system.adapter.hm-rpc.0 : hm-rpc : ioBroker-neu - disabled, port: 18701 system.adapter.hm-rpc.1 : hm-rpc : ioBroker-neu - disabled, port: 12001 system.adapter.hm-rpc.2 : hm-rpc : ioBroker-neu - disabled, port: 12010 system.adapter.influxdb.0 : influxdb : ioBroker-neu - disabled, port: 8086 + system.adapter.jarvis.0 : jarvis : ioBroker-neu - enabled + system.adapter.javascript.0 : javascript : ioBroker-neu - enabled + system.adapter.mqtt.0 : mqtt : ioBroker-neu - enabled, port: 8885, bind: 0.0.0.0 + system.adapter.net-tools.0 : net-tools : ioBroker-neu - enabled + system.adapter.ping.0 : ping : ioBroker-neu - enabled system.adapter.solarlog.0 : solarlog : ioBroker-neu - disabled, port: 80 + system.adapter.time-switch.0 : time-switch : ioBroker-neu - enabled system.adapter.tr-064.0 : tr-064 : ioBroker-neu - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : ioBroker-neu - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : ioBroker-neu - disabled system.adapter.vis.0 : vis : ioBroker-neu - enabled + system.adapter.web.0 : web : ioBroker-neu - enabled, port: 8082, bind: 0.0.0.0, run as: admin + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : ioBroker-neu - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.mqtt.0 : mqtt : ioBroker-neu - enabled, port: 8885, bind: 0.0.0.0 + system.adapter.web.0 : web : ioBroker-neu - enabled, port: 8082, bind: 0.0.0.0, run as: admin ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Adapter "admin" : 7.6.3 , installed 7.6.3 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "chromecast" : 4.0.0 , installed 4.0.0 Adapter "cloud" : 5.0.1 , installed 5.0.1 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "fritzdect" : 2.5.11 , installed 2.5.11 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "jarvis" : 3.1.8 , installed 3.1.8 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "net-tools" : 1.0.11 , installed 1.0.11 Adapter "ping" : 1.6.2 , installed 1.6.2 Adapter "socketio" : 6.7.1 , installed 7.0.8 Adapter "solarlog" : 2.3.0 , installed 2.3.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "ws" : 2.6.2 , installed 3.0.19 Objects and States Please stand by - This may take a while Objects: 1196 States: 915 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease Hit:4 http://deb.debian.org/debian bookworm-updates InRelease Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease Reading package lists... Pending Updates: 3 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:8885 0.0.0.0:* LISTEN 1001 202366 19207/io.mqtt.0 tcp 0 0 0.0.0.0:8400 0.0.0.0:* LISTEN 1001 91535 8929/io.jarvis.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 90278 8727/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 90283 8727/iobroker.js-co tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 3938 595/sshd: /usr/sbin tcp6 0 0 :::8082 :::* LISTEN 1001 89781 9020/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 91245 8745/io.admin.0 tcp6 0 0 :::22 :::* LISTEN 0 3940 595/sshd: /usr/sbin udp 0 0 0.0.0.0:44223 0.0.0.0:* 104 5622 456/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 153775 14695/io.chromecast udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 5620 456/avahi-daemon: r udp6 0 0 :::38634 :::* 104 5623 456/avahi-daemon: r udp6 0 0 fe80::6a9e:ba30:f44:546 :::* 0 4996 534/NetworkManager udp6 0 0 :::5353 :::* 104 5621 456/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-04-05 19:08:53.412 - debug: mqtt.0 (19192) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872933408,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251} 2025-04-05 19:09:09.522 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true) 2025-04-05 19:09:09.533 - info: mqtt.0 (19192) Got terminate signal TERMINATE_YOURSELF 2025-04-05 19:09:09.538 - info: mqtt.0 (19192) terminating 2025-04-05 19:09:09.540 - debug: mqtt.0 (19192) Plugin sentry destroyed 2025-04-05 19:09:09.542 - info: mqtt.0 (19192) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-04-05 19:09:09.570 - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal 2025-04-05 19:09:10.046 - info: mqtt.0 (19192) terminating 2025-04-05 19:09:10.124 - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2025-04-05 19:09:13.466 - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 19207 2025-04-05 19:09:15.327 - debug: mqtt.0 (19207) Redis Objects: Use Redis connection: 127.0.0.1:9001 2025-04-05 19:09:15.381 - debug: mqtt.0 (19207) Objects client ready ... initialize now 2025-04-05 19:09:15.392 - debug: mqtt.0 (19207) Objects create System PubSub Client 2025-04-05 19:09:15.395 - debug: mqtt.0 (19207) Objects create User PubSub Client 2025-04-05 19:09:15.418 - debug: mqtt.0 (19207) Objects client initialize lua scripts 2025-04-05 19:09:15.428 - debug: mqtt.0 (19207) Objects connected to redis: 127.0.0.1:9001 2025-04-05 19:09:15.450 - debug: mqtt.0 (19207) Redis States: Use Redis connection: 127.0.0.1:9000 2025-04-05 19:09:15.461 - debug: mqtt.0 (19207) States create System PubSub Client 2025-04-05 19:09:15.462 - debug: mqtt.0 (19207) States create User PubSub Client 2025-04-05 19:09:15.518 - debug: mqtt.0 (19207) States connected to redis: 127.0.0.1:9000 2025-04-05 19:09:15.556 - debug: mqtt.0 (19207) Plugin sentry Initialize Plugin (enabled=true) 2025-04-05 19:09:15.967 - info: mqtt.0 (19207) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6 2025-04-05 19:09:16.136 - info: mqtt.0 (19207) Starting MQTT authenticated server on 0.0.0.0:8885 2025-04-05 19:09:16.217 - debug: mqtt.0 (19207) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743872956212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234} 2025-04-05 19:09:16.269 - debug: mqtt.0 (19207) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872956265,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251} ============ Mark until here for C&P =============Hoffe es gibt aufschluss.....
Die Einstellungen sind doch korrekt, oder ??
weiss ich nicht.
jetzt hast du user passwort!
ist das auch auf der Platine bekannt -
Ich muss ja etwas probieren , also User und Passwort bei beiden eingetragen ! Ist auf den Screenshots extra festgehalten.Denn anscheinend geben die Logs auch keine Hinweise. Oder jemand etwas entdeckt ?
Eigentlich hat sich ja nur die IP Endung von .140 auf .174 geändert.
Kein Plan warum mqtt die heishamon nicht findetGruß
Du hast da bei der IP im Heisha einen Zahlendreher. Dein iobroker hat hinten 174, Du hast aber 147 drin. So kann es ja nix werden!
Gruss, Jürgen
Fuck my life.......
Natürlich, das war´s !
Vor lauter Bäumen......
Danke , jetzt ist natürlich Verbindung da !!
Da der Pi ja ein anderer ist als vorher , hat sich die IP geändert auf 192.168.178.174 (vorher .140)
Wäre es nicht einfacher gewesen, dem neuen Pi die Adresse des alten Pi zu verpassen?
Ja im nachhinein wäre es wohl klüger gewesen.....
Aber jetzt läuft ja alles wieder
Danke für eure Hilferstellung
Oder man verwendet hostnames statt IPs.
@thomas-braun Das geht aber in die Hose, wenn alle Raspis "raspberrypi" heißen
Hostnames müssen natürlich im Netzwerk eindeutig sein. Ist aber eine grundlegende Netzwerktechnik.
Kann/sollte/müsste man wissen.
