    3. Off Topic
    4. Pflege des Betriebssystems
    5. Meldung über Zeitfehler - Was ist das ?
    • dogfight76
      dogfight76 @Homoran last edited by
      @homoran said in Meldung über Zeitfehler - Was ist das ?:
      Das war auch bevor du die Einstellungen geändert hast
      Ok, stimmt.
      Hier ein ganz frisches:
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: ioBroker-neu
             Icon name: computer
                Kernel: Linux 6.12.20+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       19:15:20 up  7:34,  2 users,  load average: 0.10, 0.15, 0.15
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-04-05 19:15:20 CEST
                 Universal time: Sat 2025-04-05 17:15:20 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      dogfight76
      HOME=/home/dogfight76
      GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        1.1G        2.5G        1.2M        473M        2.9G
      Swap:           536M          0B        536M
      Total:          4.5G        1.1G        3.0G
      Active iob-Instances:   14
               3791 M total memory
               1072 M used memory
               1113 M active memory
                217 M inactive memory
               2340 M free memory
                 52 M buffer memory
                399 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 19:15:21 up  7:34,  2 users,  load average: 0.10, 0.15, 0.15
      Tasks: 183 total,   1 running, 182 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3791.4 total,   2340.5 free,   1072.7 used,    451.9 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2718.7 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.2M  379M   1% /run
      /dev/mmcblk0p2 ext4      117G  5.8G  106G   6% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Sat Apr  5 11:41:17 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=inter                             leave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:0D:BC:95 vc_mem.mem_base=0x3ec00000                              vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=d72bd49f-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_reg                             dom=DE
      [Sat Apr  5 11:41:19 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
      [Sat Apr  5 11:41:20 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      968M    /var/
      204M    /var/cache
      199M    /var/cache/apt
      167M    /var/lib
      135M    /var/lib/apt/lists
      Archived and active journals take up 84.0M in the file system.
      /opt/iobroker/backups:
      8.5M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      752M    /opt/iobroker/iobroker-data/
      727M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
      7.3M    /opt/iobroker/iobroker-data/states.jsonl
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.0-1nodesource1
        Candidate: 20.19.0-1nodesource1
        Version table:
       *** 20.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      ioBroker-neu        ioBroker-neu (version: 7.0.6, hostname: ioBroker-neu  , alive, uptime: 15753)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     1
      +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
      Adapter State
      + system.adapter.admin.0                  : admin                 : ioBroker-neu                             -  enabled, port: 8081, bind: 0.0.0.0, run                              as: admin
      + system.adapter.backitup.0               : backitup              : ioBroker-neu                             -  enabled
      + system.adapter.chromecast.0             : chromecast            : ioBroker-neu                             -  enabled
      + system.adapter.cloud.0                  : cloud                 : ioBroker-neu                             -  enabled
        system.adapter.discovery.0              : discovery             : ioBroker-neu                             - disabled
        system.adapter.fritzdect.0              : fritzdect             : ioBroker-neu                             - disabled
      + system.adapter.history.0                : history               : ioBroker-neu                             -  enabled
        system.adapter.hm-rega.0                : hm-rega               : ioBroker-neu                             - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : ioBroker-neu                             - disabled, port: 18701
        system.adapter.hm-rpc.1                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12001
        system.adapter.hm-rpc.2                 : hm-rpc                : ioBroker-neu                             - disabled, port: 12010
        system.adapter.influxdb.0               : influxdb              : ioBroker-neu                             - disabled, port: 8086
      + system.adapter.jarvis.0                 : jarvis                : ioBroker-neu                             -  enabled
      + system.adapter.javascript.0             : javascript            : ioBroker-neu                             -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : ioBroker-neu                             -  enabled, port: 8885, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : ioBroker-neu                             -  enabled
      + system.adapter.ping.0                   : ping                  : ioBroker-neu                             -  enabled
        system.adapter.solarlog.0               : solarlog              : ioBroker-neu                             - disabled, port: 80
      + system.adapter.time-switch.0            : time-switch           : ioBroker-neu                             -  enabled
        system.adapter.tr-064.0                 : tr-064                : ioBroker-neu                             - disabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : ioBroker-neu                             -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : ioBroker-neu                             - disabled
        system.adapter.vis.0                    : vis                   : ioBroker-neu                             -  enabled
      + system.adapter.web.0                    : web                   : ioBroker-neu                             -  enabled, port: 8082, bind: 0.0.0.0, run                              as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects:        1196
      States:         915
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 3
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8885            0.0.0.0:*               LISTEN      1001       202366     19207/io.mqtt.0
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       91535      8929/io.jarvis.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       90278      8727/iobroker.js-co
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       90283      8727/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          3938       595/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       89781      9020/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       91245      8745/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          3940       595/sshd: /usr/sbin
      udp        0      0 0.0.0.0:44223           0.0.0.0:*                           104        5622       456/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       153775     14695/io.chromecast
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        5620       456/avahi-daemon: r
      udp6       0      0 :::38634                :::*                                104        5623       456/avahi-daemon: r
      udp6       0      0 fe80::6a9e:ba30:f44:546 :::*                                0          4996       534/NetworkManager
      udp6       0      0 :::5353                 :::*                                104        5621       456/avahi-daemon: r
      2025-04-05 19:08:53.412  - debug: mqtt.0 (19192) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872933408,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
      2025-04-05 19:09:09.522  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 (force=false, process=true)
      2025-04-05 19:09:09.533  - info: mqtt.0 (19192) Got terminate signal TERMINATE_YOURSELF
      2025-04-05 19:09:09.538  - info: mqtt.0 (19192) terminating
      2025-04-05 19:09:09.540  - debug: mqtt.0 (19192) Plugin sentry destroyed
      2025-04-05 19:09:09.542  - info: mqtt.0 (19192) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-05 19:09:09.570  - info: host.ioBroker-neu stopInstance system.adapter.mqtt.0 send kill signal
      2025-04-05 19:09:10.046  - info: mqtt.0 (19192) terminating
      2025-04-05 19:09:10.124  - info: host.ioBroker-neu instance system.adapter.mqtt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-05 19:09:13.466  - info: host.ioBroker-neu instance system.adapter.mqtt.0 in version "6.1.2" started with pid 19207
      2025-04-05 19:09:15.327  - debug: mqtt.0 (19207) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2025-04-05 19:09:15.381  - debug: mqtt.0 (19207) Objects client ready ... initialize now
      2025-04-05 19:09:15.392  - debug: mqtt.0 (19207) Objects create System PubSub Client
      2025-04-05 19:09:15.395  - debug: mqtt.0 (19207) Objects create User PubSub Client
      2025-04-05 19:09:15.418  - debug: mqtt.0 (19207) Objects client initialize lua scripts
      2025-04-05 19:09:15.428  - debug: mqtt.0 (19207) Objects connected to redis: 127.0.0.1:9001
      2025-04-05 19:09:15.450  - debug: mqtt.0 (19207) Redis States: Use Redis connection: 127.0.0.1:9000
      2025-04-05 19:09:15.461  - debug: mqtt.0 (19207) States create System PubSub Client
      2025-04-05 19:09:15.462  - debug: mqtt.0 (19207) States create User PubSub Client
      2025-04-05 19:09:15.518  - debug: mqtt.0 (19207) States connected to redis: 127.0.0.1:9000
      2025-04-05 19:09:15.556  - debug: mqtt.0 (19207) Plugin sentry Initialize Plugin (enabled=true)
      2025-04-05 19:09:15.967  - info: mqtt.0 (19207) starting. Version 6.1.2 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.19.0, js-controller: 7.0.6
      2025-04-05 19:09:16.136  - info: mqtt.0 (19207) Starting MQTT authenticated server on 0.0.0.0:8885
      2025-04-05 19:09:16.217  - debug: mqtt.0 (19207) stateChange mqtt.0.info.clients.HeishaMon: {"val":false,"ack":true,"ts":1743872956212,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862234}
      2025-04-05 19:09:16.269  - debug: mqtt.0 (19207) stateChange mqtt.0.info.connection: {"val":"","ack":true,"ts":1743872956265,"q":0,"from":"system.adapter.mqtt.0","user":"system.user.admin","lc":1743788862251}
      Hoffe es gibt aufschluss.....
      • dogfight76
        dogfight76 last edited by
        Die Einstellungen sind doch korrekt, oder ??
        Homoran W 2 Replies Last reply Reply Quote 0
          Homoran Global Moderator Administrators @dogfight76 last edited by
          @dogfight76 sagte in Meldung über Zeitfehler - Was ist das ?:
          weiss ich nicht.
          jetzt hast du user passwort!
          ist das auch auf der Platine bekannt
          dogfight76 1 Reply Last reply Reply Quote 0
          • dogfight76
            Ich muss ja etwas probieren , also User und Passwort bei beiden eingetragen ! Ist auf den Screenshots extra festgehalten.
            Denn anscheinend geben die Logs auch keine Hinweise. Oder jemand etwas entdeckt ?
            Eigentlich hat sich ja nur die IP Endung von .140 auf .174 geändert.
            Kein Plan warum mqtt die heishamon nicht findet
              Wildbill @dogfight76 last edited by
              Du hast da bei der IP im Heisha einen Zahlendreher. Dein iobroker hat hinten 174, Du hast aber 147 drin. So kann es ja nix werden!
              Gruss, Jürgen
              dogfight76 1 Reply Last reply Reply Quote 2
              • dogfight76
                dogfight76 @Wildbill last edited by
                @wildbill
                Fuck my life.......
                Natürlich, das war´s !
                Vor lauter Bäumen......
                Danke , jetzt ist natürlich Verbindung da !!
                • 1Topf
                  1Topf @dogfight76 last edited by
                  Da der Pi ja ein anderer ist als vorher , hat sich die IP geändert auf 192.168.178.174 (vorher .140)
                  Wäre es nicht einfacher gewesen, dem neuen Pi die Adresse des alten Pi zu verpassen? 🤔
                  • dogfight76
                    dogfight76 @1Topf last edited by
                    @1topf
                    Ja im nachhinein wäre es wohl klüger gewesen.....
                    Aber jetzt läuft ja alles wieder 😉
                    Danke für eure Hilferstellung
                      Thomas Braun Most Active @dogfight76 last edited by
                      @dogfight76
                      Oder man verwendet hostnames statt IPs.
                        @thomas-braun Das geht aber in die Hose, wenn alle Raspis "raspberrypi" heißen
                          Thomas Braun Most Active @Homoran last edited by Thomas Braun
                          Hostnames müssen natürlich im Netzwerk eindeutig sein. Ist aber eine grundlegende Netzwerktechnik.
                          Kann/sollte/müsste man wissen.
                          1.0k
                          81.1k
                          6327
