    4. IoB web page nicht erreichbar Update Admin adapter
    • I
      ichwersonst @Thomas Braun last edited by
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: RaspberryPV
             Icon name: computer
                Kernel: Linux 6.6.74+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.5
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       10:23:13 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-04-03 10:23:13 CEST
                 Universal time: Thu 2025-04-03 08:23:13 UTC
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      wib
      HOME=/home/wib
      GROUPS=wib adm dialout cdrom sudo audio video plugdev games users input render n        etdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        795M        1.9G        1.3M        1.4G        3.2G
      Swap:           536M          0B        536M
      Total:          4.5G        795M        2.4G
      Active iob-Instances:   6
               3790 M total memory
                758 M used memory
                802 M active memory
                947 M inactive memory
               1811 M free memory
                162 M buffer memory
               1135 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 10:23:14 up 2 days, 31 min,  3 users,  load average: 0.31, 0.21, 0.18
      Tasks: 169 total,   1 running, 168 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 14.3 sy,  0.0 ni, 71.4 id, 14.3 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3790.9 total,   1810.1 free,    759.4 used,   1298.4 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3031.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  1.3M  378M   1% /run
      /dev/sda2      ext4       56G  7.3G   46G  14% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/sda1      vfat      510M   56M  455M  11% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      Show mounted filesystems:
      TARGET           SOURCE    FSTYPE OPTIONS
      /                /dev/sda2 ext4   rw,noatime
      `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.7G    /var/
      715M    /var/log/journal/952349f4f3da4e138b5320ebf14f2a46
      715M    /var/log
      271M    /var/cache
      Archived and active journals take up 714.1M in the file system.
      /opt/iobroker/backups:
      62M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      768M    /opt/iobroker/iobroker-data/
      717M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s.map
      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.j        s
      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb        0.chunk.js.map
      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae        1.chunk.js.map
      7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34        a.chunk.js.map
      USB-Devices by-id:
      USB-Sticks -  Avoid direct links to /dev/tty* in your adapter setups, please alw        ays prefer the links 'by-id':
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.0-1nodesource1
        Candidate: 20.19.0-1nodesource1
        Version table:
       *** 20.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
              500 http://deb.debian.org/debian-security bookworm-security/main arm64 P        ackages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      RaspberryPV         RaspberryPV (version: 7.0.6, hostname: RaspberryPV   , alive, uptime: 99371)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : RaspberryPV                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : RaspberryPV                              -  enabled
      + system.adapter.javascript.0             : javascript            : RaspberryPV                              -  enabled
        system.adapter.modbus.0                 : modbus                : RaspberryPV                              - disabled
        system.adapter.modbus.1                 : modbus                : RaspberryPV                              - disabled
        system.adapter.modbus.2                 : modbus                : RaspberryPV                              - disabled
        system.adapter.modbus.3                 : modbus                : RaspberryPV                              - disabled
        system.adapter.ping.0                   : ping                  : RaspberryPV                              - disabled
      + system.adapter.rpi2.0                   : rpi2                  : RaspberryPV                              -  enabled
      + system.adapter.web.0                    : web                   : RaspberryPV                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "rpi2"         : 2.3.1    , installed 2.3.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        630
      States:         470
      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Get:6 https://pkgs.tailscale.com/stable/debian bookworm InRelease
      Fetched 6581 B in 1s (4879 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       306438     56308/iobroker.js-c
      tcp        0      0 100.71.28.54:35475      0.0.0.0:*               LISTEN      0          315720     63047/tailscaled
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       306433     56308/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          4858       585/sshd: /usr/sbin
      tcp6       0      0 :::37541                :::*                    LISTEN      1001       682313     56382/io.backitup.0
      tcp6       0      0 fd7a:115c:a1e0::d:52087 :::*                    LISTEN      0          315724     63047/tailscaled
      tcp6       0      0 :::22                   :::*                    LISTEN      0          4860       585/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       305694     56326/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       322619     68840/io.web.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        2930       454/avahi-daemon: r
      udp        0      0 0.0.0.0:41641           0.0.0.0:*                           0          637048     63047/tailscaled
      udp        0      0 0.0.0.0:45779           0.0.0.0:*                           104        2932       454/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        2931       454/avahi-daemon: r
      udp6       0      0 :::38177                :::*                                104        2933       454/avahi-daemon: r
      udp6       0      0 :::41641                :::*                                0          637047     63047/tailscaled
      2025-04-03 01:47:04.762  - info: host.RaspberryPV Delete log file iobroker.2025-03-26.log.gz
      2025-04-03 01:47:04.780  - error: host.RaspberryPV Cannot delete file "/opt/iobroker/log/iobroker.2025-03-26.log.gz": Error: ENOENT: no such file or directory, unlink '/opt/iobroker/log/iobroker.2025-03-26.log.gz'
      2025-04-03 06:47:10.853  - info: admin.0 (56326) Adapter rating updated
      2025-04-03 07:03:34.573  - error: admin.0 (56326) socket.io [init] Cannot detect user
      2025-04-03 07:05:33.116  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
      2025-04-03 09:42:13.773  - info: admin.0 (56326) ==> Connected system.user.admin from ::ffff:192.168.50.250
      2025-04-03 09:43:32.158  - info: admin.0 (56326) <== Disconnect system.user.admin from ::ffff:192.168.50.250 backitup
      iob diag has finished.
      Press any key for a summary
        legro @Thomas Braun last edited by legro
        Mühsam ernährt sich das Eichhörnchen.😖
        Ich habe in der Zwischenzeit fleißig getestet ..
        Wenn ich die Website mit dem Admin-Adapters auf dem MacBook offen lasse, so wird vermutlich irgendwann einmal die sog. Session-Key ungültig. Im Gegensatz zum alten Admin-Adapter genügte ein Neuladen der Seite und diese erschien wieder - ggf. musste man sich zusätzlich neu anmelden. Dies ist nun nicht mehr der Fall. Safari meldet, dass der Server nicht (mehr) erreichbar sei.
        Obwohl sich der Admin-Adapter mit dieser Fehlermeldung nicht mehr aufrufen lässt, kann man sehr wohl noch die VIS aufrufen. Alles damit verbundene funktioniert nach wie vor.
        Zwei Methoden helfen ..
        • Ich rufe die Seite von einem zweiten Gerät (z.B. iPad) ab, dann funktioniert i.d.R. auch wieder ein Aufruf auf dem MacBook.
        • Ich beende Safari auf dem MacBook komplett. Nach dem Neustart von Safari geht die Verbindung zum Admin-Adapter wieder.
        Nachdem ich nun weiß, wie ich damit umgehen muss, ist für mich alles wieder gut.🙂
        Codierknecht Thomas Braun 2 Replies Last reply Reply Quote 0
        • Codierknecht
          Codierknecht Developer Most Active @legro last edited by
          @legro sagte in IoB web page nicht erreichbar Update Admin adapter:
          Oder Methode 3: Ohne Login arbeiten 😉
            Thomas Braun Most Active @legro last edited by
            @legro
            Das ist aber kein Bug, das ist das durch die Absicherung der Verbindung geforderte und erwartete Verhalten.
            • I
              Konnte jemand anhand meiner iob diag Ausgabe etwas erkennen, warum ich nach einer Zeit nicht mehr im Webinterface agieren kann?
                Thomas Braun Most Active @ichwersonst last edited by
                @ichwersonst
                Da steht nichts auffälliges drin.
                • I
                  Was ist mit dem Fehler gemeint bzw. wie entsteht er?
                  admin.0 2025-04-07 06:27:34.308	error	socket.io [init] Cannot detect user
                  Vielleicht hat es ja etwas damit zutun
                  Thomas Braun mcm1957 2 Replies Last reply Reply Quote 0
                    @ichwersonst sagte in IoB web page nicht erreichbar Update Admin adapter:
                    Weiß ich nicht. Hab ich auf meinen Systemen auch nicht.
                    Allerdings fahre ich auch keine verschlüsselten Kisten.
                    • I
                      Ich fahre eine verschlüsselte Kiste? Was ist denn an meiner Kiste verschlüsselt? Wo ließt du das raus?
                      Socket.io ist automatisch installiert. Jedenfalls hab ich das nicht selber installiert.
                        @ichwersonst
                        Hab ich mit was anderem verwechselt. Ich dachte du hättest da eine SSL-Verschlüsselung am Start.
                        • mcm1957
                          mcm1957 @ichwersonst last edited by
                          @ichwersonst said in IoB web page nicht erreichbar Update Admin adapter:
                          Kann ignoriert werden (= nur optisches Problem).
                          Ist mit admin 7.6.4 behoben.
                          https://github.com/ioBroker/ioBroker.admin/issues/3030
                          seidmaxi created this issue in ioBroker/ioBroker.admin
                          closed [bug]: Admin Adapter 7.6.3 - socket.io [init] Cannot detect user #3030
                          • I
                            ichwersonst @mcm1957 last edited by ichwersonst
                            @mcm1957
                            ich habe bereits 7.6.3 installiert, der Error kommt dennoch.
                            • mcm1957
                              @ichwersonst
                              lies den letzten Beitrag bitte nochmals.
                              • I
                                @mcm1957
                                hoppala 😂
                                1671
