    4. Szenen Adapter hängt sich auf *gelöst*
      gluecksmann @Feuersturm last edited by
      @feuersturm Da gab es doch einen Befehl, um das alles schön darstellen zu lassen.
      • Feuersturm
        Feuersturm @gluecksmann last edited by
        @gluecksmann korrekt
        iob diag
        der steht auch in dem von mir verlinkten Beitrag, welche Infos bereitgestellt werden sollen um ein Problem zu analysieren 😉
        Von dem Ergebnis iob diag wird die Langfassung benötigt.
          @feuersturm
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
           Static hostname: raspberrypi
                 Icon name: computer
                    Kernel: Linux 6.6.31+rpt-rpi-v8
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.4
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           10:36:25 up  7:35,  4 users,  load average: 0.57, 0.78, 0.76
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          ~ Under-voltage has occurred
          *** TIME AND TIMEZONES ***
                         Local time: Fri 2025-04-04 10:36:25 CEST
                     Universal time: Fri 2025-04-04 08:36:25 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          pi
          HOME=/home/pi
          GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Display-Server: true
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            8.2G        2.8G        4.2G         17M        1.3G        5.4G
          Swap:           209M          0B        209M
          Total:          8.4G        2.8G        4.4G
          Active iob-Instances:   35
                   7810 M total memory
                   2662 M used memory
                   2984 M active memory
                    599 M inactive memory
                   4034 M free memory
                     90 M buffer memory
                   1160 M swap cache
                    199 M total swap
                      0 M used swap
                    199 M free swap
          top - 10:36:26 up  7:35,  4 users,  load average: 0.57, 0.78, 0.76
          Tasks: 250 total,   2 running, 248 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 16.7 us,  0.0 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   7810.0 total,   4033.6 free,   2663.7 used,   1251.3 buff/cache
          MiB Swap:    200.0 total,    200.0 free,      0.0 used.   5146.3 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.6G     0  3.6G   0% /dev
          tmpfs          tmpfs     782M  1.3M  780M   1% /run
          /dev/mmcblk0p2 ext4       58G   12G   44G  21% /
          tmpfs          tmpfs     3.9G  140K  3.9G   1% /dev/shm
          /dev/mmcblk0p1 vfat      510M   75M  436M  15% /boot/firmware
          tmpfs          tmpfs     781M   40K  781M   1% /run/user/1000
          [Fri Apr  4 03:00:26 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:3D:9B:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9e5696c9-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles cfg80211.ieee80211_regdom=DE
          [Fri Apr  4 03:00:29 2025] EXT4-fs (mmcblk0p2): mounted filesystem 4aa56689-dcb4-4759-90e6-179beae559ac ro with ordered data mode. Quota mode: none.
          [Fri Apr  4 03:00:36 2025] EXT4-fs (mmcblk0p2): re-mounted 4aa56689-dcb4-4759-90e6-179beae559ac r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET               SOURCE         FSTYPE      OPTIONS
          /                    /dev/mmcblk0p2 ext4        rw,noatime,commit=600
          |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.7G    /var/
          776M    /var/cache
          763M    /var/cache/apt
          648M    /var/cache/apt/archives
          537M    /var/log
          Archived and active journals take up 535.5M in the file system.
          /opt/iobroker/backups:
          280M    /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.2G    /opt/iobroker/iobroker-data/
          937M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          80M     /opt/iobroker/iobroker-data/influxdata.json
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
          22M     /opt/iobroker/iobroker-data/states.jsonl
          USB-Devices by-id:
          /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
          *** ZigBee Settings ***
          Your zigbee.0 COM-Port is matching 'by-id'. Very good!
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.0
          /usr/bin/node           v20.18.0
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.3
          nodejs:
            Installed: 20.18.0-1nodesource1
            Candidate: 20.19.0-1nodesource1
            Version table:
               20.19.0-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
               20.18.3-1nodesource1 1001
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
           *** 20.18.0-1nodesource1 1001
                  100 /var/lib/dpkg/status
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 27279)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.6.3
          javascript:     8.8.3
          nodejs modules from github:     1
          +-- iobroker.govee@0.0.6 (git+ssh://git@github.com/nbuenger/ioBroker.govee.git#73ec80b6350890015d95428dd3bbd3f72417a073)
          Adapter State
          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
            system.adapter.alias-manager.0          : alias-manager         : raspberrypi                              - disabled
          + system.adapter.awtrix-light.0           : awtrix-light          : raspberrypi                              -  enabled
          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
          + system.adapter.ble.0                    : ble                   : raspberrypi                              -  enabled
            system.adapter.chromecast.0             : chromecast            : raspberrypi                              - disabled
            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
            system.adapter.devices.0                : devices               : raspberrypi                              - disabled
          + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
          + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: raspberrypi                              -  enabled
          + system.adapter.fahrplan.0               : fahrplan              : raspberrypi                              -  enabled
          + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
          + system.adapter.govee.0                  : govee                 : raspberrypi                              -  enabled
          + system.adapter.gruenbeck.0              : gruenbeck             : raspberrypi                              -  enabled
            system.adapter.history.0                : history               : raspberrypi                              - disabled
          + system.adapter.homeconnect.0            : homeconnect           : raspberrypi                              -  enabled
          + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
            system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
            system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
            system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
          + system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
          + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
          + system.adapter.mielecloudservice.0      : mielecloudservice     : raspberrypi                              -  enabled
          + system.adapter.musiccast.0              : musiccast             : raspberrypi                              -  enabled
          + system.adapter.netatmo.0                : netatmo               : raspberrypi                              -  enabled
          + system.adapter.opendtu.0                : opendtu               : raspberrypi                              -  enabled
          + system.adapter.philips-air.0            : philips-air           : raspberrypi                              -  enabled
          + system.adapter.philips-air.1            : philips-air           : raspberrypi                              -  enabled
            system.adapter.ping.0                   : ping                  : raspberrypi                              - disabled
          + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
          + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
          + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : raspberrypi                              - disabled
          + system.adapter.signifylights.0          : signifylights         : raspberrypi                              -  enabled
          + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
          + system.adapter.sonos.0                  : sonos                 : raspberrypi                              -  enabled
          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
            system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              - disabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
            system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              - disabled
            system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              - disabled
            system.adapter.vis-players.0            : vis-players           : raspberrypi                              - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
            system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
          + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_34337ce2ac9ded11ab46cfa5a7669f5d-if00-port0
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.6.3    , installed 7.6.3
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "alias-manager": 2.0.0    , installed 2.0.0
          Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "ble"          : 0.14.0   , installed 0.14.0
          Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
          Adapter    "daswetter"    : 3.2.3    , installed 3.1.16 [Updatable]
          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
          Adapter    "fahrplan"     : 1.2.3    , installed 1.2.3
          Adapter    "fullybrowser" : 3.0.13   , installed 3.0.13
          Adapter    "gruenbeck"    : 0.0.43   , installed 0.0.43
          Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
          Adapter    "hue"          : 3.14.1   , installed 3.14.1
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "meross"       : 1.17.0   , installed 1.17.0
          Adapter    "mielecloudservice": 6.5.7, installed 6.5.7
          Adapter    "musiccast"    : 1.1.4    , installed 1.1.4
          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
          Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
          Adapter    "philips-air"  : 1.2.0    , installed 1.2.0
          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "shuttercontrol": 1.8.8   , installed 1.8.8
          Adapter    "signifylights": 0.4.2    , installed 0.4.2
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "sonos"        : 3.0.0    , installed 3.0.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
          Objects and States
          Objects:        11931
          States:         9774
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:6 https://apt.grafana.com stable InRelease
          Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 170
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       11866      2376/io.sonoff.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1964       795/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7267       783/cupsd
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10225      1200/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11418      1200/iobroker.js-co
          tcp6       0      0 :::3500                 :::*                    LISTEN      1001       13496      2134/io.sonos.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        7537       1116/influxd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       11901      2441/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13356      2048/io.admin.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7266       783/cupsd
          tcp6       0      0 :::3000                 :::*                    LISTEN      112        10220      1199/grafana
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1966       795/sshd: /usr/sbin
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6854       578/avahi-daemon: r
          udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       11812      2324/io.shelly.0
          udp        0      0 0.0.0.0:59352           0.0.0.0:*                           1001       11782      2290/io.philips-air
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       14401      2335/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       14402      2335/io.tuya.0
          udp        0      0 0.0.0.0:52494           0.0.0.0:*                           104        6856       578/avahi-daemon: r
          udp        0      0 0.0.0.0:40277           0.0.0.0:*                           1001       13653      2275/io.philips-air
          udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       14765      2625/io.musiccast.0
          udp6       0      0 fe80::a6e1:3ab9:3bf:546 :::*                                0          9325       724/NetworkManager
          udp6       0      0 fe80::e996:6ae8:1bc:546 :::*                                0          7463       724/NetworkManager
          udp6       0      0 :::45824                :::*                                104        6857       578/avahi-daemon: r
          udp6       0      0 :::5353                 :::*                                104        6855       578/avahi-daemon: r
          2025-04-04 10:36:18.616  - info: philips-air.1 (2290) State value to set for "philips-air.1.filter.activeCarbonFilterReplaceInHours" has to be type "number" but received type "string"
          2025-04-04 10:36:20.210  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:25.216  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:26.438  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:36:30.216  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:35.217  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:36.200  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:36:40.217  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:45.220  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:46.085  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:36:50.217  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:55.217  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:36:56.545  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:37:00.221  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:05.220  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:06.403  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:37:10.224  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:15.225  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:16.894  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:37:20.223  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:25.226  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:26.110  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
          2025-04-04 10:37:30.227  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:35.236  - error: govee.0 (2538) AxiosError: Request failed with status code 429
          2025-04-04 10:37:36.106  - warn: fullybrowser.0 (2842) [REST] 192.168.2.148: Sending command get axiosGetDevicesInfo  failed: No response
            Thomas Braun Most Active @gluecksmann last edited by
            @gluecksmann sagte in Szenen Adapter hängt sich auf:
            DRINGEND in die Gegenwart holen.
            sudo apt update
            iob stop
            sudo apt full-upgrade
            sudo reboot
              gluecksmann @Thomas Braun last edited by
              @thomas-braun sagte in Szenen Adapter hängt sich auf:
              sudo reboot
              OK, Updates sind gemacht. Ich werde erst mal schauen ob das vielleicht schon was gebracht hat. Die Sache mit den Datenpunkten im Adapter... Ich musste, was wieder ein anderes Problem ist, eine Zigbee Komponente neu anlernen. Aber, nachdem ich den Adapter neu gestartet habe, wird die Szene ja richtig ausgeführt, mit eben dieser Komponente. Kann dann ja also nicht so falsch sein.
              • Feuersturm
                Feuersturm @gluecksmann last edited by Feuersturm
                @gluecksmann Betrachte bitte einmal deine Beiträge aus der Sicht einer Person die weder deine Szenen, noch deine Objekte oder Skripte kennen. Welche Informationen findest du, die dein System beschreiben?
                Poste doch einmal Screenshots von deinen Szenen, eine Beschreibung was die Szenen machen und zeigt die relevanten Datenpunkte. Gibt es Skripte welche ebenfalls etwas mit den Datenpunkten machen und somit Einfluss auf die Szenen haben?
                Edit: Dieses issue klingt ähnlich was du beschreibst https://github.com/ioBroker/ioBroker.scenes/issues/387
                ManniBac created this issue in ioBroker/ioBroker.scenes
                open adapter crash if link to a not existing data point #387
                  @feuersturm
                  Hallo, danke das DU dir mir dem Problem so viel Mühe gibst. Gibt es denn eine Möglichkeit die DAtenpunkte zu prüfen. Also durch einen Eintrag im Log?
                  • Feuersturm
                    @gluecksmann Zeig doch im ersten Schritt einmal Screenshots von deinen beiden Szenen.
                      @feuersturm
                      Hallo, dein Hinweis auf den issue war scheinbar richtig. Habe die Datenpunkte noch einmal neu zugewiesen. Seitdem läuft es wieder.
                      Feuersturm 1 Reply Last reply Reply Quote 1
                      • Feuersturm
                        @gluecksmann danke für die Rückmeldung
                        546
