    4. [Aufruf] deConz Adapter Testen 1.1.2
    • Jey Cee
      Muss wohl mindestens in node v8 sonst würde der Adapter gar nicht laufen. Scheint wohl erst in v6 oder später übernommen worden zu sein.
      Gesendet von Unterwegs
      • V
        vtwo last edited by
        ich bekomme den Adapter nicht eingebunden:
        host.raspberrypi	2018-01-24 23:41:31.425	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        iobroker	2018-01-24 23:41:31.120	info	exit 0
        iobroker	2018-01-24 23:41:30.877	info	optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        iobroker	2018-01-24 23:41:30.875	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN
        iobroker	2018-01-24 23:41:30.872	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connecti
        iobroker	2018-01-24 23:41:30.869	info	npm
        iobroker	2018-01-24 23:41:30.830	info	iobroker@1.0.0 /opt/iobroker└── iobroker.deconz@0.1.2
        iobroker	2018-01-24 23:41:10.343	info	gyp ERR! not ok
        iobroker	2018-01-24 23:41:10.343	info	gyp ERR! node-gyp -v v3.4.0
        iobroker	2018-01-24 23:41:10.343	info	gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v6.12.2
        iobroker	2018-01-24 23:41:10.337	info	gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        iobroker	2018-01-24 23:41:10.334	info	at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
        iobroker	2018-01-24 23:41:10.332	info	gyp ERR! stack
        iobroker	2018-01-24 23:41:10.332	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
        iobroker	2018-01-24 23:41:10.332	info	gyp ERR! stack at emitTwo (events.js:106:13)
        iobroker	2018-01-24 23:41:10.332	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        iobroker	2018-01-24 23:41:10.329	info	gyp
        iobroker	2018-01-24 23:41:10.314	info	ERR! build error
        iobroker	2018-01-24 23:41:10.311	info
        iobroker	2018-01-24 23:41:10.305	info	gyp
        iobroker	2018-01-24 23:41:10.287	info	make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
        iobroker	2018-01-24 23:41:10.287	info	authenticate_pam.target.mk:92: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheitertemake: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlass
        iobroker	2018-01-24 23:41:09.524	info	compilation terminated.
        iobroker	2018-01-24 23:41:09.524	info	^
        iobroker	2018-01-24 23:41:09.524	info	../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
        iobroker	2018-01-24 23:41:08.113	info	CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
        iobroker	2018-01-24 23:41:08.105	info	make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
        iobroker	2018-01-24 23:41:03.001	info	> node-gyp rebuild
        iobroker	2018-01-24 23:41:03.001	info	> authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
        iobroker	2018-01-24 23:39:36.069	info	npm install https://github.com/Jey-Cee/ioBroker.deconz/tarball/master --production --prefix "/opt/iobroker" (System call)
        iobroker	2018-01-24 23:39:35.613	info	install https://github.com/Jey-Cee/ioBroker.deconz/tarball/master
        iobroker	2018-01-24 23:39:34.114	info	url "https://github.com/Jey-Cee/ioBroker.deconz" --debug
        host.raspberrypi	2018-01-24 23:30:12.216	info	instance system.adapter.ical.0 terminated with code 0 (OK)
        ical.0	2018-01-24 23:30:06.293	info	processing URL: New1 http://p02-calendarws.icloud.com/ca/subscribe/1/M5pFw_zOJPXNrjAV2_A_UQdOCo-s9E4jN60a9fjkwmK4r4Rh0eu3Y02LufunhZ3MQlLxEclad2E1NoVXWT8yI9K_PQbioQnG6EugMOpoySs
        ical.0	2018-01-24 23:30:03.668	info	starting. Version 1.4.0 in /opt/iobroker/node_modules/iobroker.ical, node: v6.12.2
        host.raspberrypi	2018-01-24 23:30:00.056	info	instance system.adapter.ical.0 started with pid 25514
        host.raspberrypi	2018-01-24 23:28:28.238	warn	warning: Cannot read "http://download.iobroker.net/sources-dist-latest.json"
        host.raspberrypi	2018-01-24 23:28:16.837	info	Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
        iobroker	2018-01-24 23:28:14.325	info	exit 0
        iobroker	2018-01-24 23:28:14.201	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        iobroker	2018-01-24 23:28:14.199	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm
        iobroker	2018-01-24 23:28:14.192	info	WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connecti
        iobroker	2018-01-24 23:28:14.190	info	npm
        iobroker	2018-01-24 23:28:02.807	info	gyp ERR! not ok
        iobroker	2018-01-24 23:28:02.807	info	gyp ERR! node-gyp -v v3.4.0
        iobroker	2018-01-24 23:28:02.807	info	gyp ERR! node -v v6.12.2
        iobroker	2018-01-24 23:28:02.807	info	gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
        iobroker	2018-01-24 23:28:02.807	info	gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        iobroker	2018-01-24 23:28:02.799	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
        iobroker	2018-01-24 23:28:02.799	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
        iobroker	2018-01-24 23:28:02.799	info	gyp ERR! stack at emitTwo (events.js:106:13)
        iobroker	2018-01-24 23:28:02.799	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        iobroker	2018-01-24 23:28:02.788	info	gyp ERR! build error
        iobroker	2018-01-24 23:28:02.777	info	make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
        iobroker	2018-01-24 23:28:02.010	info	compilation terminated.
        iobroker	2018-01-24 23:28:02.010	info	^
        iobroker	2018-01-24 23:28:02.010	info	../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
        iobroker	2018-01-24 23:26:17.674	info	npm install https://github.com/Jey-Cee/ioBroker.deconz/tarball/master --production --prefix "/opt/iobroker" (System call)
        iobroker	2018-01-24 23:26:17.218	info	install https://github.com/Jey-Cee/ioBroker.deconz/tarball/master
        iobroker	2018-01-24 23:26:15.539	info	url "https://github.com/Jey-Cee/ioBroker.deconz"
        host.raspberrypi	2018-01-24 23:00:10.732	info	instance system.adapter.ical.0 terminated with code 0 (O
        Ich verwende das Aufsteckmodul. Soweit läuft es auch meine Osram Lampen hat es gefunden aber in io bekomme ich es nicht eingebunden… 😞
          apollon77 last edited by
          Was genau tut denn nicht? Installation war erfolgreich. Jetzt unter Adapter in der deconz Zeile auf das + um eine Instanz anzulegen.
          • V
            vtwo last edited by
            OMG Danke ich bin Blind es war wohl doch schon zu spät. Soweit läuft er wohl nun. Aber unter den Objekten finde ich die angelernten Lampen nicht oder muss ich diese neu anlernen?
            • Jey Cee
              Hast du mal den Admin neu aufgerufen?
              Adapter ist Grün?
              Wenn beides ja Starte den Adapter neu.
              • V
                vtwo last edited by
                Ja neu Aufgerufen, Adapter ist Grün und AuthCode ist auch drinnen. Alles neu gestartet aber es kommt nix sehe nur den gateway unter Objektive. In der Webansicht von Wireless Light sind die Lampen jedoch da und schaltbar.
                • Jey Cee
                  Ok mehr infos Bitte.
                  • Namen der Lampen, die den e ein n der WebApp angezeigt werden
                  • Objekte vom Adapter löschen, Adapter Loglevel auf Debug und dann das Log hier Posten
                  • V
                    vtwo last edited by
                    Hi Sorry,
                    die Namen:
                    Küche und Flur
                    Das Log Spuckt nur aus:
                    deconz.0 2018-01-25 14:36:02.833 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                    deconz.0 2018-01-25 14:35:57.395 info terminating
                    deconz.0 2018-01-25 12:49:39.436 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                    deconz.0 2018-01-25 12:49:34.006 info terminating
                    Die Instanz selbst ist grün und hat auch einen Api Key
                    Grüße Clemens
                    • V
                      vtwo last edited by
                      So jetzt kommt was, die lampen sind da lassen sich aber nicht schalten:
                      deconz.0	2018-01-25 22:08:43.138	error	SyntaxError: Unexpected token u in JSON at position 0 at Object.parse (native) at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:370:28) at self.callback (/opt/iobro
                      deconz.0	2018-01-25 22:08:43.136	error	uncaught exception: Unexpected token u in JSON at position 0
                      deconz.0	2018-01-25 22:08:43.129	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                      deconz.0	2018-01-25 22:08:21.890	info	terminating
                      deconz.0	2018-01-25 22:08:21.376	error	at emitOne (events.js:96:13)
                      deconz.0	2018-01-25 22:08:21.376	error	at Socket.socketErrorListener (_http_client.js:310:9)
                      deconz.0	2018-01-25 22:08:21.376	error	at ClientRequest.emit (events.js:188:7)
                      deconz.0	2018-01-25 22:08:21.376	error	at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:878:8)
                      deconz.0	2018-01-25 22:08:21.376	error	at Request.emit (events.js:188:7)
                      deconz.0	2018-01-25 22:08:21.376	error	at self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                      deconz.0	2018-01-25 22:08:21.376	error	at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:370:28)
                      deconz.0	2018-01-25 22:08:21.376	error	at Object.parse (native)
                      deconz.0	2018-01-25 22:08:21.376	error	SyntaxError: Unexpected token u in JSON at position 0
                      deconz.0	2018-01-25 22:08:21.374	error	uncaught exception: Unexpected token u in JSON at position 0
                      deconz.0	2018-01-25 22:08:21.244	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                      deconz.0	2018-01-25 22:07:56.860	info	terminating
                      deconz.0	2018-01-25 22:07:56.349	error	at emitOne (events.js:96:13)
                      deconz.0	2018-01-25 22:07:56.349	error	at Socket.socketErrorListener (_http_client.js:310:9)
                      deconz.0	2018-01-25 22:07:56.349	error	at ClientRequest.emit (events.js:188:7)
                      deconz.0	2018-01-25 22:07:56.349	error	at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:878:8)
                      deconz.0	2018-01-25 22:07:56.349	error	at Request.emit (events.js:188:7)
                      deconz.0	2018-01-25 22:07:56.349	error	at self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                      deconz.0	2018-01-25 22:07:56.349	error	at Request._callback (/opt/iobroker/node_modules/iobroker.deconz/main.js:370:28)
                      deconz.0	2018-01-25 22:07:56.349	error	at Object.parse (native)
                      deconz.0	2018-01-25 22:07:56.349	error	SyntaxError: Unexpected token u in JSON at position 0
                      deconz.0	2018-01-25 22:07:56.348	error	uncaught exception: Unexpected token u in JSON at position 0
                      deconz.0	2018-01-25 22:07:56.224	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                        Thorsten last edited by
                        Inwiefern sind Schalter bzw. Dimmer mit dem Adapter überhaupt nutzbar?
                        Der Adapter legt bei mir Objekte für aller Lampen und Schalter an. Bei den Lampen sehe ich auch den korrekten Status (z.B. für On) und kann diesen auch manuell ober über JavaScript ändern. Aber der Status der Fernbedienungen (Hue und Tradfri) ändert sich nicht. 'Last Changed' ist auf das Datum gesetzt an dem der Adapter das Objekt angelegt hat. Außerdem gibt es nur eine 'On' Property - obwohl die Fernbedienungen 4 (Hue) bzw. 5 (Tradfri) Tasten haben.
                        Ist es überhaupt möglich über den Adapter Tastendrück der Fernbedienung auszuwerten?
                        • Jey Cee
                          Es sollte möglich sein die Taster zu verwenden. Ich hab Das Blind programmiert, anhand der API Doku, weil ich keine Taster und Sensoren habe.
                          Von daher kann ich momentan nicht mehr dazu sagen.
                          Allgemein bitte ich momentan um Geduld da ich wenig Freizeit habe.
                            @Jey Cee:
                            Gesendet von Unterwegs `
                            Danke für die Antwort! Mir war nicht klar ob das überhaupt funktionieren sollte. Wenn ich irgendwie helfen kann dann gib Bescheid!
                            • V
                              vtwo last edited by
                              So habe das Repbee nun auf einem neuen Raspberry aufgesetzt. Aber ich bekomme es nicht eingebunden.
                              deconz.0	2018-01-27 15:48:06.051	error	at TCP._handle.close [as _onclose] (net.js:497:12)
                              deconz.0	2018-01-27 15:48:06.051	error	at Socket.emit (events.js:188:7)
                              deconz.0	2018-01-27 15:48:06.051	error	at emitOne (events.js:101:20)
                              deconz.0	2018-01-27 15:48:06.051	error	at Socket.socketCloseListener (_http_client.js:286:9)
                              deconz.0	2018-01-27 15:48:06.051	error	at ClientRequest.emit (events.js:188:7)
                              deconz.0	2018-01-27 15:48:06.051	error	at emitOne (events.js:96:13)
                              deconz.0	2018-01-27 15:48:06.051	error	at ClientRequest._req.on (/opt/iobroker/node_modules/ws/lib/WebSocket.js:644:18)
                              deconz.0	2018-01-27 15:48:06.051	error	TypeError: Cannot read property 'aborted' of null
                              deconz.0	2018-01-27 15:48:06.050	error	uncaught exception: Cannot read property 'aborted' of null
                              deconz.0	2018-01-27 15:48:06.042	error	at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1090:14)
                              deconz.0	2018-01-27 15:48:06.042	error	at exports._exceptionWithHostPort (util.js:1043:20)
                              deconz.0	2018-01-27 15:48:06.042	error	at Object.exports._errnoException (util.js:1020:11)
                              deconz.0	2018-01-27 15:48:06.042	error	Error: connect ECONNREFUSED 0.0.0.0:443
                              deconz.0	2018-01-27 15:48:06.039	error	uncaught exception: connect ECONNREFUSED 0.0.0.0:443
                              Wenn ich einen API Key anfordern will kann ich drücken wie ich will auf dem Rasbee es kommt keiner an. Das oben taucht im Log auf. Und
                              deconz.0	2018-01-27 15:52:45.605	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                              deconz.0	2018-01-27 15:52:12.742	error	TypeError: Cannot read property 'aborted' of null at ClientRequest._req.on (/opt/iobroker/node_modules/ws/lib/WebSocket.js:644:18) at emitOne (events.js:96:13) at ClientRequest.emit (event
                              deconz.0	2018-01-27 15:52:12.742	error	uncaught exception: Cannot read property 'aborted' of null
                              deconz.0	2018-01-27 15:52:12.741	error	Error: connect ECONNREFUSED 192.168.1.152:443 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at TCPConnectWrap.afterConnect [as onc
                              deconz.0	2018-01-27 15:52:12.738	error	uncaught exception: connect ECONNREFUSED 192.168.1.152:443
                              deconz.0	2018-01-27 15:52:02.670	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                              deconz.0	2018-01-27 15:51:29.802	error	TypeError: Cannot read property 'aborted' of null at ClientRequest._req.on (/opt/iobroker/node_modules/ws/lib/WebSocket.js:644:18) at emitOne (events.js:96:13) at ClientRequest.emit (event
                              deconz.0	2018-01-27 15:51:29.802	error	uncaught exception: Cannot read property 'aborted' of null
                              deconz.0	2018-01-27 15:51:29.801	error	Error: connect ECONNREFUSED 192.168.1.152:443 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at TCPConnectWrap.afterConnect [as onc
                              deconz.0	2018-01-27 15:51:29.798	error	uncaught exception: connect ECONNREFUSED 192.168.1.152:443
                              deconz.0	2018-01-27 15:51:19.740	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                              deconz.0	2018-01-27 15:50:46.837	error	TypeError: Cannot read property 'aborted' of null at ClientRequest._req.on (/opt/iobroker/node_modules/ws/lib/WebSocket.js:644:18) at emitOne (events.js:96:13) at ClientRequest.emit (event
                              deconz.0	2018-01-27 15:50:46.836	error	uncaught exception: Cannot read property 'aborted' of null
                              deconz.0	2018-01-27 15:50:46.836	error	Error: connect ECONNREFUSED 192.168.1.152:443 at Object.exports._errnoException (util.js:1020:11) at exports._exceptionWithHostPort (util.js:1043:20) at TCPConnectWrap.afterConnect [as onc
                              deconz.0	2018-01-27 15:50:46.834	error	uncaught exception: connect ECONNREFUSED 192.168.1.152:443
                              deconz.0	2018-01-27 15:50:36.805	info	starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.deconz, node: v6.12.2
                              deconz.0	2018-01-27 15:50:04.383	info	terminating
                              • Jey Cee
                                Hast du Speichern gedrückt nachdem du die IP vom RaspBee eingegeben hast?
                                Sonst klappt das nicht mit dem API key.
                                • V
                                  vtwo last edited by
                                  Hi, ja hatte ich. Ich habe jetzt alles gelöscht und neu Aufgesetzt. Das Modul auf einen eigenen Raspberry gesetzt und nochmal bei 0 Angefangen. Jetzt läuft alles 🙂 Soweit. Was nur komisch ist das die Lampen teilweise 3 mal auftauchen….
                                    @vtwo:
                                    Hi, ja hatte ich. Ich habe jetzt alles gelöscht und neu Aufgesetzt. Das Modul auf einen eigenen Raspberry gesetzt und nochmal bei 0 Angefangen. Jetzt läuft alles 🙂 Soweit. Was nur komisch ist das die Lampen teilweise 3 mal auftauchen…. `
                                    Das Problem hatte ich nachdem ich die Lampen in Phoscon oder der WebApp umbenannt hatte.
                                    • Jey Cee
                                      Ich hab dazu mal ein Issue auf Github erstellt.
                                      https://github.com/Jey-Cee/ioBroker.deconz/issues/8
                                      Jey-Cee created this issue in Jey-Cee/ioBroker.deconz
                                      closed Auto delete obsolet objects if renamed in deConz #8
                                      • V
                                        vtwo last edited by
                                        Ist es den Inzwischen möglich zu dimmen? Ich habe ja den wert 254 dort drinnen stehen, wir hatten bisher eine Routine die die Lampen im Wohnzimmer und co um 22 Uhr auf 50% abgesenkt haben.
                                        • Jey Cee
                                          Funktioniert das Dimmen nicht?
                                          50% = 127
                                          • Alex1808
                                            Alex1808 last edited by
                                            @Jey Cee:
                                            Hallo Jey Cee
                                            es ist jetzt möglich über Phoscon App auch Geräte vom Xiaomi einzubinden
                                            das ist BM vom Xiaomi, erkannt und Funktioniert
                                            ! ![](</s><URL url=)<link_text text="https://image.prntscr.com/image/GPWJvYl ... FcEkEA.png">https://image.prntscr.com/image/GPWJvYllTxiJbBxzFcEkEA.png</link_text>" /> ~~aber im deCONZ adapter sieht es so aus
                                            ! ![](</s><URL url=)<link_text text="https://image.prntscr.com/image/c9D1KgB ... gOjQ9g.png">https://image.prntscr.com/image/c9D1KgB9QCyHEXDygOjQ9g.png</link_text>" /> ~~Ist es möglich adapter auf Xiaomi Gräte zu erweitern?
                                            Danke!~~~~
                                            deconz zigbee
                                            57
                                            532
                                            118099
