    3. Einsteigerfragen
    4. Nach Stromausfall merkwürdige Meldungen. Wer kann helfen ?
    • dogfight76
      dogfight76 last edited by
      Es gab noch ein 1x Script, um die Commnads zu erzeugen. Wenn das hilft:
      Das ist aber zu lang für das "Code-Fenster"
      commands_erzeugen.txt
      • dogfight76
        dogfight76 @Homoran last edited by dogfight76
        @homoran said in Nach Stromausfall merkwürdige Meldungen. Wer kann helfen ?:
        @dogfight76 hast du den verlinkten Thread gelesen?
        Bitte nachholen und erst einmal die Langfassung von iob diag posten
        ABER NICHT ALS SCREENSHOT
        Hier die putty Ausgabe des Befehls:
        ========== Start marking the full check here ===========
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Debian GNU/Linux 11 (bullseye)
                    Kernel: Linux 6.1.21-v8+
              Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         14:52:43 up 2 days,  1:59,  2 users,  load average: 0.29, 0.13, 0.07
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Fri 2025-04-04 14:52:43 CEST
                   Universal time: Fri 2025-04-04 12:52:43 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        dogfight76
        HOME=/home/dogfight76
        GROUPS=dogfight76 adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:            3.8G        918M        1.9G        1.0M        935M        2.8G
        Swap:            99M          0B         99M
        Total:          3.9G        918M        2.0G
        Active iob-Instances:   14
                 3794 M total memory
                  918 M used memory
                 1064 M active memory
                  641 M inactive memory
                 1939 M free memory
                  126 M buffer memory
                  809 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        top - 14:52:44 up 2 days,  1:59,  2 users,  load average: 0.29, 0.13, 0.07
        Tasks: 176 total,   1 running, 175 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  1.4 us,  2.8 sy,  0.0 ni, 95.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3794.3 total,   1940.0 free,    918.2 used,    936.2 buff/cache
        MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2799.5 avail Mem
        *** FAILED SERVICES ***
        0 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4       59G  9.0G   47G  17% /
        devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        tmpfs          tmpfs     759M  1.2M  758M   1% /run
        /dev/mmcblk0p1 vfat      255M   31M  225M  13% /boot
        tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
        [Wed Apr  2 12:53:00 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:98:E4:44 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e31b91e6-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
        [Wed Apr  2 12:53:01 2025] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
        [Wed Apr  2 12:53:01 2025] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
        [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
        [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): 2 orphan inodes deleted
        [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): recovery complete
        [Wed Apr  2 12:53:02 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
        [Wed Apr  2 12:53:02 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Apr  2 12:53:04 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
        Show mounted filesystems:
        TARGET  SOURCE         FSTYPE OPTIONS
        /       /dev/mmcblk0p2 ext4   rw,noatime
        `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        2.3G    /var/
        1.3G    /var/log/journal/7d1338ad4ea145258230302c11232948
        1.3G    /var/log
        734M    /var/cache
        Archived and active journals take up 1.2G in the file system.
        /opt/iobroker/backups:
        93M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        791M    /opt/iobroker/iobroker-data/
        728M    /opt/iobroker/iobroker-data/files
        617M    /opt/iobroker/iobroker-data/files/javascript.admin
        560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
        558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        17M     /opt/iobroker/iobroker-data/objects.jsonl
        8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
        8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.a9c6d34a.chunk.js.map
        7.0M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/675.7e9d7842.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.18.0
        /usr/bin/node           v20.18.0
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.29.3
        nodejs:
          Installed: 20.18.0-1nodesource1
          Candidate: 20.18.3-1nodesource1
          Version table:
             20.18.3-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
         *** 20.18.0-1nodesource1 1001
                100 /var/lib/dpkg/status
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             12.22.12~dfsg-1~deb11u6 500
                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
             12.22.12~dfsg-1~deb11u4 500
                500 http://deb.debian.org/debian bullseye/main arm64 Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 25418)
        Core adapters versions
        js-controller:  7.0.6
        admin:          7.6.3
        javascript:     8.8.3
        nodejs modules from github:     1
        +-- iobroker.time-switch@2.2.2 (git+ssh://git@github.com/walli545/ioBroker.time-switch.git#45b5addb484d270dcac6d1bfdb1a9f86b444d80e)
        Adapter State
        + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        + system.adapter.chromecast.0             : chromecast            : iobroker                                 -  enabled
        + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
          system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
          system.adapter.fritzdect.0              : fritzdect             : iobroker                                 - disabled
        + system.adapter.history.0                : history               : iobroker                                 -  enabled
          system.adapter.hm-rega.0                : hm-rega               : iobroker                                 - disabled
          system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 - disabled, port: 18701
          system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 - disabled, port: 12001
          system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 - disabled, port: 12010
          system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
        + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 8885, bind: 192.168.178.140
        + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
        + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
          system.adapter.solarlog.0               : solarlog              : iobroker                                 - disabled, port: 80
        + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
          system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
        + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
          system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.6.3    , installed 7.6.3
        Adapter    "backitup"     : 3.0.31   , installed 3.0.31
        Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
        Adapter    "fritzdect"    : 2.5.11   , installed 2.5.11
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "jarvis"       : 3.1.8    , installed 3.1.8
        Adapter    "javascript"   : 8.8.3    , installed 8.8.3
        Controller "js-controller": 7.0.6    , installed 7.0.6
        Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
        Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "solarlog"     : 2.3.0    , installed 2.3.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        1150
        States:         885
        Hit:1 http://deb.debian.org/debian bullseye InRelease
        Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 93
        *** Listening Ports ***
        tcp        0      0 192.168.178.140:8885    0.0.0.0:*               LISTEN      1001       1146617    115154/io.mqtt.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15374      564/sshd: /usr/sbin
        tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          942202     94334/cupsd
        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1148504    115241/io.jarvis.0
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1147461    114977/iobroker.js-
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1147466    114977/iobroker.js-
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1149410    114995/io.admin.0
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1149599    115203/io.web.0
        tcp6       0      0 ::1:631                 :::*                    LISTEN      0          942201     94334/cupsd
        tcp6       0      0 :::22                   :::*                    LISTEN      0          15376      564/sshd: /usr/sbin
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14987      479/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1147680    115132/io.chromecas
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14601      403/avahi-daemon: r
        udp        0      0 0.0.0.0:36388           0.0.0.0:*                           108        14603      403/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          15860      479/dhcpcd
        udp6       0      0 :::44044                :::*                                108        14604      403/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        14602      403/avahi-daemon: r
        2025-04-04 14:45:15.296  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:19)
        2025-04-04 14:45:15.297  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-04-04 14:45:15.298  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-04-04 14:45:15.298  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-04-04 14:45:15.299  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
        2025-04-04 14:45:15.300  - info: javascript.0 (115051) script.js.common.Meine_Geraete.Heizung.Akt_VL: null
        2025-04-04 14:45:15.300  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.26" not found (3)
        2025-04-04 14:45:15.303  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
        2025-04-04 14:45:15.303  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-04-04 14:45:15.304  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
        2025-04-04 14:46:45.183  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.25" not found (3)
        2025-04-04 14:46:45.185  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:19)
        2025-04-04 14:46:45.185  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-04-04 14:46:45.186  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
        2025-04-04 14:46:45.187  - info: javascript.0 (115051) script.js.common.Meine_Geraete.Heizung.Akt_VL: null
        2025-04-04 14:46:45.187  - warn: javascript.0 (115051) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.25" not found (3)
        2025-04-04 14:46:45.188  - warn: javascript.0 (115051)     at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
        2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
        2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
        2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
        2025-04-04 14:46:45.189  - warn: javascript.0 (115051)     at processImmediate (node:internal/timers:483:21)
        iob diag has finished.
          Thomas Braun Most Active @dogfight76 last edited by
          @dogfight76
          Hab ich im Parallelthread schon analysiert. Installier das Ding neu und spiel ein Backup ein.
            arteck Developer Most Active @dogfight76 last edited by
            @dogfight76 sagte in Nach Stromausfall merkwürdige Meldungen. Wer kann helfen ?:
            0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.27
            und was erachtest du als merkwürdig.. den Datenpunkt gibbet nicht..
            • dogfight76
              da bin ich wieder ! Es wurde alles komplett neu installiert auf neuerer Raspberry-Hardware.
              Aber die Meldung taucht wieder auf.
              Diese Fehlermeldung, darüber das Datenpunkte nicht da sind wo sie sein sollten !
              Hier die Meldungen das oberhalb von 20 Grad VL-Temp keine Datenpunkte vorhanden sind.
              Und hier der nochmalige Beweis das sie wirklich nicht mehr da sind.
              Aber warum ?
              In der VIS geht die VL-Temp bis 48 Grad.
              Das einzige wo der Bereich von -15 bis nur 20 Grad geht ist in der Heizkurve. Die über ein Blockly als Script angelegt wurde.
              Das wird das Problem sein, da es über 20 Grad reale Aussen-Temp ist will die Heizkurve die VL-Temp bei 27 Grad Aussen-Temp weiter runter regeln. Geht aber nicht weil die Heizkurve ja nur bis +20 Grad ausgelegt ist.
              Was wäre eurer Lösungsansatz ?
              Homoran bahnuhr 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @dogfight76 last edited by
                logs in Code-tags posten und korrekte IDs verwenden.
                dogfight76 1 Reply Last reply Reply Quote 0
                • dogfight76
                  @homoran Log von was genau ?
                  Und welche korrekten ID´s ?
                  Die VL-Temp in dem Pfad wurden je bestimmt von dem Script der Heizkurve angelegt.
                  Bei über 2ß Grad muss die Wärmepumpe ja nicht mehr an sein, aber wie dann die Warnungen beseitigen ?
                  Samson71 Homoran 2 Replies Last reply Reply Quote 0
                  • Samson71
                    Samson71 Global Moderator @dogfight76 last edited by
                    Er meint die Mikro-Screenshots Deiner Logs, die Du nicht als Bild sondern vernünftig lesbar als Text in Code-Tags packen sollst, weil das so kein Schwein vernünftig lesen kann. Schon gar nicht an einem Mobilgerät.
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @dogfight76 last edited by
                      Du greift in einem Script auf einen DP zu den es nicht gibt.
                      Und zwar in Zeile 34; steht doch alles in der Meldung !
                      Hat dir @arteck aber schon geantwortet !
                        Homoran Global Moderator Administrators @dogfight76 last edited by Homoran
                        ich glaube nicht dass ° unbedingt ein zulässiges Zeichrn für eine ID ist.
                        in dem Screenshot der Objekte hat auch kein state eine ID damit
                          peterfido last edited by
                          Was heißt wurden bestimmt angelegt? Die Skripte solltest Du besser kennen als wir.
                          Deine beiden oben geposteten Skripte erzeugen einmal zig Objekte unter
                          mqtt.0.Waermepumpe.commands
                          geht immer weiter so
                          und einmal zig Objekte unter
                          0_userdata.0.Waermepumpe.Heizkurve.Temperaturverschiebung
                          Dieses, oder eine Kopie davon, kannst Du anpassen, um die fehlenden Objekte unter ...Heizkurve... zu erstellen.
                          Die Skripte, welche die Logik beinhalten und die Datenpunkte mit Leben füllen, fehlen. Welche Objekte die VIS-Steuerung womit füllt, und wer die dann abfragt, ist mir auch nicht schlüssig.
                          1.3k
                          1229
