    4. [gelöst] Miele CloudService Fehler bei Anmeldung
      Matt77CHE @Homoran last edited by Matt77CHE
      host.iobroker
      2025-04-13 11:44:47.572	info	Do not restart adapter system.adapter.mielecloudservice.0 because disabled or deleted
      host.iobroker
      2025-04-13 11:44:47.571	error	instance system.adapter.mielecloudservice.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
      mielecloudservice.0
      2025-04-13 11:44:46.645	warn	Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
      mielecloudservice.0
      2025-04-13 11:44:46.644	debug	Plugin sentry destroyed
      mielecloudservice.0
      2025-04-13 11:44:46.642	error	adapter disabled
      mielecloudservice.0
      2025-04-13 11:44:46.527	debug	Plugin sentry Initialize Plugin (enabled=true)
      host.iobroker
      2025-04-13 11:44:18.411	info	"system.adapter.mielecloudservice.0" disabled
      host.iobroker
      2025-04-13 11:44:13.686	info	Restart adapter system.adapter.mielecloudservice.0 because enabled
      host.iobroker
      2025-04-13 11:44:13.686	error	instance system.adapter.mielecloudservice.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2025-04-13 11:44:13.686	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
      host.iobroker
      2025-04-13 11:44:13.686	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
      host.iobroker
      2025-04-13 11:44:13.686	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
      host.iobroker
      2025-04-13 11:44:13.686	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
      host.iobroker
      2025-04-13 11:44:13.686	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
      host.iobroker
      2025-04-13 11:44:13.686	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
      host.iobroker
      2025-04-13 11:44:13.685	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
      host.iobroker
      2025-04-13 11:44:13.685	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
      host.iobroker
      2025-04-13 11:44:13.685	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:200:7)
      host.iobroker
      2025-04-13 11:44:13.685	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:289:39)
      host.iobroker
      2025-04-13 11:44:13.685	error	Caught by controller[0]: TypeError: request.headers.split is not a function
      mielecloudservice.0
      2025-04-13 11:44:13.225	error	request.headers.split is not a function
      mielecloudservice.0
      2025-04-13 11:44:13.225	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:289:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:200:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
      mielecloudservice.0
      2025-04-13 11:44:13.225	error	uncaught exception: request.headers.split is not a function
      mielecloudservice.0
      2025-04-13 11:44:13.206	info	Initializing SSE watchdog.
      mielecloudservice.0
      2025-04-13 11:44:13.198	info	Registering for all appliance events at Miele API.
      mielecloudservice.0
      2025-04-13 11:44:13.198	info	Access token expires on: 5/13/2025, 11:44:00 AM
      mielecloudservice.0
      2025-04-13 11:44:12.523	info	Login attempt #1 @Miele-API
      mielecloudservice.0
      2025-04-13 11:44:12.503	info	starting. Version 6.5.10 (non-npm: Grizzelbee/ioBroker.mielecloudservice) in /opt/iobroker/node_modules/iobroker.mielecloudservice, node: v20.19.0, js-controller: 7.0.6
      mielecloudservice.0
      2025-04-13 11:44:12.324	debug	Plugin sentry Initialize Plugin (enabled=true)
      mielecloudservice.0
      2025-04-13 11:44:12.293	debug	States connected to redis: 192.xxx.x.xxx:6379
      mielecloudservice.0
      2025-04-13 11:44:12.288	debug	States create User PubSub Client
      mielecloudservice.0
      2025-04-13 11:44:12.288	debug	States create System PubSub Client
      mielecloudservice.0
      2025-04-13 11:44:12.283	debug	Redis States: Use Redis connection: 192.xxx.x.xxx:6379
      mielecloudservice.0
      2025-04-13 11:44:12.048	debug	Objects connected to redis: 192.xxx.x.xxx:6379
      mielecloudservice.0
      2025-04-13 11:44:12.044	debug	Objects client initialize lua scripts
      mielecloudservice.0
      2025-04-13 11:44:11.710	debug	Objects create User PubSub Client
      mielecloudservice.0
      2025-04-13 11:44:11.709	debug	Objects create System PubSub Client
      mielecloudservice.0
      2025-04-13 11:44:11.708	debug	Objects client ready ... initialize now
      mielecloudservice.0
      2025-04-13 11:44:11.696	debug	Redis Objects: Use Redis connection: 192.xxx.x.xxx:6379
      host.iobroker
      2025-04-13 11:44:10.950	info	instance system.adapter.mielecloudservice.0 in version "6.5.10" (non-npm: Grizzelbee/ioBroker.mielecloudservice) started with pid 263915
      host.iobroker
      2025-04-13 11:44:08.744	info	"system.adapter.mielecloudservice.0" enabled
      Edit: Adapter auf debug; Log auf debug
        Homoran Global Moderator Administrators @Matt77CHE last edited by Homoran
        @matt77che sagte in Miele CloudService Fehler bei Anmeldung:
        sehe ich 😉
        und IP Adressen sind keine privaten Daten.
        Das war auf Zugangsdaten o.ä. bezogen
        Immerhin sieht man jetzt, dass die Zugangsdaten wohl stimmen, Der Token passt, aber
        bleibt leider.
        Hast du die Instanz denn vollständig konfiguriert?
          da bin ich davon ausgegangen, nachdem ich die Felder, email, pw, api client id, secret, land, sprache ausgewählt hatte....
            die Geräte müssen nirgendwo angegeben werden?
            dann kann ich dir leider nicht weiterhelfen.
              danke dir trotzdem für zumindest den Versuch! 👍
                @matt77che
                einer geht noch!
                Wenn du nicht den gesamten Adapter incl. Instanz löschen und neu installieren willst, mach mal ein upload des Adapters.
                Entweder per Konsole iob upload miele.....xxx oder auf der Seite Adapter im Expertenmodus auf der Rückseite der Kachel
                  Adapter & Instanz gelöscht und neu installiert habe ich bereits gemacht - mit dem gleichen ergebnis.....
                  Einen Upload eines Adapters habe ich noch nie gemacht - werde ich machen!
                  Edit: erledigt
                    erledigt
                    und mit welchem Ergebnis?
                      @homoran sagte in Miele CloudService Fehler bei Anmeldung:
                      erledigt
                      äähm - jetzt stehe ich auf dem Schlauch - Tschuldigung...
                      Wo sollte ich da ein Ergebnis sehen? - habe das noch nie gemacht sorry
                        falls du das Log meinst?:
                        host.iobroker
                        2025-04-13 14:34:36.479	info	iobroker exit 0
                        host.iobroker
                        2025-04-13 14:34:35.212	info	iobroker Updating objects from io-package.json for adapter "mielecloudservice" with version "6.5.10"
                        host.iobroker
                        2025-04-13 14:34:35.205	info	iobroker upload [0] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/words.js words.js application/javascript
                        host.iobroker
                        2025-04-13 14:34:35.202	info	iobroker upload [1] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/paypal-donate-button.png paypal-donate-button.png image/png
                        host.iobroker
                        2025-04-13 14:34:35.198	info	iobroker upload [2] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/mielecloudservice.svg mielecloudservice.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.195	info	iobroker upload [3] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/jsonConfig.json jsonConfig.json application/json
                        host.iobroker
                        2025-04-13 14:34:35.192	info	iobroker upload [4] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/info.svg icons/info.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.188	info	iobroker upload [5] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/eco_water.svg icons/eco_water.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.185	info	iobroker upload [6] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/eco_energy.svg icons/eco_energy.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.181	info	iobroker upload [7] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/eco.svg icons/eco.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.177	info	iobroker upload [8] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/cog.svg icons/cog.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.174	info	iobroker upload [9] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/8.svg icons/8.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.171	info	iobroker upload [10] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/7.svg icons/7.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.167	info	iobroker upload [11] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/67.svg icons/67.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.164	info	iobroker upload [12] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/45.svg icons/45.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.161	info	iobroker upload [13] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/43.svg icons/43.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.158	info	iobroker upload [14] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/42.svg icons/42.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.155	info	iobroker upload [15] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/41.svg icons/41.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.153	info	iobroker upload [16] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/40.svg icons/40.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.150	info	iobroker upload [17] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/39.svg icons/39.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.147	info	iobroker upload [18] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/34.svg icons/34.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.143	info	iobroker upload [19] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/33.svg icons/33.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.141	info	iobroker upload [20] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/32.svg icons/32.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.118	info	iobroker upload [30] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/icons/19.svg icons/19.svg image/svg+xml
                        host.iobroker
                        2025-04-13 14:34:35.082	info	iobroker upload [40] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                        host.iobroker
                        2025-04-13 14:34:35.045	info	iobroker upload [50] mielecloudservice.admin /opt/iobroker/node_modules/iobroker.mielecloudservice/admin/i18n/de/translations.json i18n/de/translations.json application/json
                        host.iobroker
                        2025-04-13 14:34:27.697	info	iobroker upload mielecloudservice --debug
                          ist die Fehlermeldung weg?
                            Nein
                            host.iobroker
                            2025-04-13 14:53:38.965	info	"system.adapter.mielecloudservice.0" disabled
                            host.iobroker
                            2025-04-13 14:53:31.012	info	Restart adapter system.adapter.mielecloudservice.0 because enabled
                            host.iobroker
                            2025-04-13 14:53:31.012	error	instance system.adapter.mielecloudservice.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:200:7)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:289:39)
                            host.iobroker
                            2025-04-13 14:53:31.011	error	Caught by controller[0]: TypeError: request.headers.split is not a function
                            mielecloudservice.0
                            2025-04-13 14:53:30.532	error	request.headers.split is not a function
                            mielecloudservice.0
                            2025-04-13 14:53:30.532	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:289:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:200:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                            mielecloudservice.0
                            2025-04-13 14:53:30.531	error	uncaught exception: request.headers.split is not a function
                            host.iobroker
                            2025-04-13 14:53:28.388	info	instance system.adapter.mielecloudservice.0 in version "6.5.10" started with pid 347082
                              @matt77che
                              Sehe ich ja jetzt erst!
                              den Adapter 6.5.10 installiert
                              Wieso insallierst du eine Betaversion?
                                @matt77che
                                Sehr gute Frage!
                                Ich hatte mit einigen Adaptern Probleme und hatte auf Beta gewechselt - jedoch leider nicht zurück....
                                Habe nun auf die Stable gewechselt.... 🙄 jetzt funktioniert es.... 👍
                                Vielen Dank für deinen Hinweis und deine Geduld & Zeit !
                                  @matt77che sagte in [gelöst] Miele CloudService Fehler bei Anmeldung:
                                  Das hättest du dir und uns ersparen können
                                    @homoran sagte in [gelöst] Miele CloudService Fehler bei Anmeldung:
                                    dem ist so - Entschuldigung
                                    585
