    4. Test/Support Adapter SqueezeboxRPC
    • OliverIO
      OliverIO @Hansi1234 last edited by OliverIO
      @hansi1234
      ich habe mal lmsannounce mal probiert und folgendes szenario ausprobiert.
      es läuft eine song baraza und an lms announce wird der befehl geschickt eine andere datei (also olivaartest.mp3) abzuspielen.
      im folgenden sind die detailausgaben der telnet signale des LMS
      2024-11-30 13:35:13.231  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist play file%3A%2F%2F%2Fmusic%2Fbaraza.mp3
      2024-11-30 13:35:13.278  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist open file%3A%2F%2F%2Fmusic%2Fbaraza.mp3
      00%3A00%3A0%3A24%3A9a%3A8d menustatus ARRAY(0x55be62b2e5b8) add 00%3A00%3A0%3A24%3A9a%3A8d
      2024-11-30 13:35:14.126  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist newsong baraza 0
      2024-11-30 13:35:20.920  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlists new name%3AannounceTTS playlist_id%3A20320
      2024-11-30 13:35:20.982  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlists edit cmd%3Aadd playlist_id%3A20320 title%3AannounceTTS%20message url%3Afile%3A%2F%2F%2Fmusic%2Folivaartest.mp3
      00%3A00%3A0%3A24%3A9a%3A8d playlist preview url%3AannounceTTS
      00%3A00%3A0%3A24%3A9a%3A8d playlist save tempplaylist_000000249a8d silent%3A1
      00%3A00%3A0%3A24%3A9a%3A8d playlist play %2Fplaylist%2FannounceTTS.m3u
      00%3A00%3A0%3A24%3A9a%3A8d playlist stop
      00%3A00%3A0%3A24%3A9a%3A8d playlist jump 0  0
      00%3A00%3A0%3A24%3A9a%3A8d playlist open file%3A%2F%2F%2Fmusic%2Folivaartest.mp3
      00%3A00%3A0%3A24%3A9a%3A8d playlist load_done
      00%3A00%3A0%3A24%3A9a%3A8d playlists delete playlist_id%3A20320
      2024-11-30 13:35:21.045  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist newsong announceTTS%20message 0
      2024-11-30 13:35:36.722  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist stop
      2024-11-30 13:35:36.781  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist resume %2Fplaylist%2Ftempplaylist_000000249a8d.m3u noplay%3A0
      00%3A00%3A0%3A24%3A9a%3A8d time 6.50511415672302
      2024-11-30 13:35:38.898  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist newsong baraza 0
      2024-11-30 13:35:42.419  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d pause
      2024-11-30 13:35:42.461  - debug: squeezeboxrpc.0 (33460) doTelnet received Data: 00%3A00%3A0%3A24%3A9a%3A8d playlist pause 1
      00%3A00%3A0%3A24%3A9a%3A8d menustatus ARRAY(0x55be62b2c160) add 00%3A00%3A0%3A24%3A9a%3A8d
      generell kannst du natürlich auf die Änderung der Datenpunkte im iobroker horchen und bspw auf den titel Datenpunkt eines Players.
      Da ändert sich der Titel dann auf "announceTTS message" wenn da eine Nachricht abgespielt wird. Der Titel wird glaube ich nur alle 10 Sekunden abgerufen, da könnte es , je nach Länge des Announcements, dann auch mal durchgehen
      Alternativ könnte man, wie optional im Adapter möglich, einen Telnetserver aufmachen, der an auf die Detailereignisse horcht.
      oder ich glaube es gibt einen weiteren Adapter oder Möglichkeit im javascript-Adapter auf die Meldungen im Log zu horchen
      Halte mich mal auf dem laufen was du da weiter tun möchtest, evtl kann man das als UseCase im Readme beschreiben.
      PS. Die Telnetfunktionalität muss man erst in den Einstellungen aktivieren.
      Auch die Ausgabe muss man erst mit den debug Server in den Einstellungen aktivieren.
        Hansi1234 @OliverIO last edited by
        @oliverio ich schau gerade, ob mir das addon reicht, oder es schon nett wäre, wenn es im iobroker Adapter integriert ist. BTW auf deiner Github Seite ist ein Rechtschreibfehler 😉 "iobroker upload squeezeboxpc"
        • OliverIO
          @hansi1234
          Rechtschreibfehler
          Danke, werde ich korrigieren
          Der Befehl zum überwachen des Logs im JavaScript Adapter ist onLog
          Eine reine Umsetzung als Skript wäre auch denkbar. Hängt davon ab was du genau willst.
          Mit TTS kenne ich mich aktuell nicht aus.
            Aufschlagzuender @OliverIO last edited by
            @oliverio sagte in Test/Support Adapter SqueezeboxRPC:
            Sieht eigentlich gut aus.
            Hast du das neue Widget mal probiert?
            Dazu musst du erst das Player Widget platziere
            Dann das playlist Widget platzieren und die widget id des Player Widgets dort auswählen
            Dann müsste die playlist angezeigt werden
            Ich habe mich jetzt noch einmal bei Tageslicht mit der Sache beschäftigt und den Fehler gefunden.
            So wie es aussieht hat der Adapter neue Ordner für die einzelnen Player angelegt.
            Wenn ich dann im falschen Ordner/Player arbeite ist es auch kein Wunder das nichts funktioniert.
            Das muss passiert sein als ich die v1.5.1 installiert habe.
            Die Player/Ordner Namen werden jetzt alle mit Unterstrichen satt Leerzeichen geschrieben.
            @oliverio
            Hast Du das bewusst angepasst?
            Bleibt das jetzt so?
            Möchte ungerne meine Scripte alle anpassen und dann kommt mit dem nächsten Update die alte Schreibweise zurück.
            "cmdGeneral" funktioniert dann jetzt mit der Playlist ID.
            Das Widget kann ich nicht ausprobieren.
            Ich habe keine VIS, bzw. verwende ich Jarvis als Visualisierung.
            OliverIO 2 Replies Last reply Reply Quote 0
            • OliverIO
              OliverIO @Aufschlagzuender last edited by OliverIO
              @aufschlagzuender
              ja, musste ich leider.
              Eigentlich sollte das schon länger (letztes Jahr?) so sein. War aber nicht an allen Stellen wirksam.
              Problem ist mit in Datenpunkten nicht gültige Zeichen (letztes Jahr war es #, weiter oben war es []). Daher wandle ich alle nicht gültigen Zeichen nun in _ um.
              Regex gegen welches validiert wird ist
              /[^\d\w_]+/gm;
              Ich muss dran denken, bei so grundsätzlichen Änderungen besser darauf hinzuweisen.
              • OliverIO
                @aufschlagzuender sagte in Test/Support Adapter SqueezeboxRPC:
                Hast du dann den neuen sendTo Befehl zum Abruf der Playlist ausprobiert?
                hsteinme 1 Reply Last reply Reply Quote 0
                • hsteinme
                  hsteinme @OliverIO last edited by
                  Ich habe ein Skript im Einsatz, das das Abspielen einer Squeezebox startet, sobald ein Präsenzmelder eine menschliche Anwesenheit meldet.
                  if presence reported {
                  	.Power = 1
                  	.cmdGeneral  = playlist clear
                  	.Volume = 70
                  	.cmdGeneral = randomplay 2
                  	.state = 1
                  Leider erreicht diese Routine nicht immer ihren Zweck. Meine eigenen Debug-Logs belegen, dass der Präsenzmelder korrekt meldet und dass die obige Routine korrekt durchlaufen wird - auch in den Fällen, wo die Squeezebox nicht startet.
                  Eine anschließend eingefügte Prüfroutine zeigt auf, dass die Musik nicht startet, wenn vom Adapter das AckFlag für .state nicht auf true gesetzt wird.
                  Daher meine Frage an Dich, Oliver: Welches Kriterium veranlasst den Adapter, das Ack-Flag zu setzen oder halt nicht zu setzen?
                  Eingesetzte Adapter-Version: 1.5.2
                  • OliverIO
                    OliverIO @hsteinme last edited by OliverIO
                    @hsteinme
                    so wie es eigentlich auch vorgesehen ist.
                    wenn du bspw den play/stop/pause datenpunkt mit der bezeichnung state beschreibst (mit ack=false),
                    dann wird zunächst intern der befehl an den LMS/Lyrion-Server abgesetzt.
                    Der Adapter pollt kontinuierlich den Status vom Server.
                    Hat dann LMS/Lyrion in seinen Meldungen selbst den Status verändert, dann wird über das Polling das registriert und der state-Datenpunkt aktualisiert, allerdings dann mit dem ack=true flag, da ja nun die Information vom Gerät bestätigt wurde.
                    Das Polling erfolgt in unterschiedlichen Datenzusammenstellungen in unterschiedlichen Zeitabständen.
                    Wenn du da ein Fehlverhalten feststellst, dann bitte hier nochmal schreiben. Der Playstatus sollte aber minimal jede Sekunde abgefragt werden.
                    • hsteinme
                      @oliverio Danke, Oliver, für Dein schnelles Feedback.
                      Naja, ein Fehlverhalten liegt hier in jedem Fall vor. Zweck meiner gestrigen Anfrage war halt, festzustellen, ob der Adapter oder LMS hierfür verantwortlich ist. Nach Deiner obigen Erklärung sehe ich nun klar die Verantwortung bei LMS bzw. dem dahinter liegenden Squeeze Client.
                      Stellt meine o.e. Prüfroutine fest, dass kein Ack = true zurückgekommen ist, so wird .state mehrmals im Abstand einiger Sekunden erneut auf 1 gesetzt - jedoch bleibt dies auch ohne Erfolg.
                      Jetzt bin ich ziemlich ratlos, wie ich beim LMs (oder dahinter) das Problem weiter analysieren kann.
                      • OliverIO
                        @hsteinme
                        Ich teste das mal
                        • OliverIO
                          @hsteinme
                          ich habe mal getestet.
                          ich habe mit dem history adapter die aufzeichnung des datenpunkts state gestartet.
                          das kreuzchen für "Nur Änderungen aufzeichnen" habe ich deaktiviert, um evtl wiederholtes schreiben des datenpunkts mitzubekommen.
                          zunächst habe ich direkt in der LMS Oberfläche Play/Pause gedrückt. Das sind die Einträge ohne ack=false, da ja im iobroker nie was eingetragen worden ist, sondern der status direkt vom lms kommt
                          die nächsten paar einträge habe ich dann selbst manuell den datenpunkt state beschrieben, das sind dann die ack=false einträge, welches dann vom lms entsprechend bestätigt wurde und hier als ack=true sichtbar ist.
                          einen Eintrag kann ich mir allerdings nicht erklären ist der einzelne stop==2 Eintrag, den ich nicht selbst ausgelöst habe, sondern wahrscheinlich als Reaktion auf das zuvor angeforderte pause==0 Kommando. das trat aber nur das einzige mal auf, hat aber auf die nachfolgende Funktionalität keinen Einfluss.
                          timestamp value acknowledged
                          4/15/2025 3:20:46 PM.218 null true
                          4/15/2025 3:21:11 PM.624 1 true
                          4/15/2025 3:21:24 PM.771 0 true
                          4/15/2025 3:21:36 PM.330 1 true
                          4/15/2025 3:21:43 PM.040 0 true
                          4/15/2025 3:22:18 PM.449 1 false
                          4/15/2025 3:22:18 PM.536 1 true
                          4/15/2025 3:22:33 PM.373 0 false
                          4/15/2025 3:22:33 PM.865 0 true
                          4/15/2025 3:22:40 PM.567 2 true
                          4/15/2025 3:23:04 PM.824 0 false
                          4/15/2025 3:23:21 PM.261 1 false
                          4/15/2025 3:23:21 PM.841 1 true
                          4/15/2025 3:23:42 PM.740 0 false
                          4/15/2025 3:23:42 PM.908 0 true
                          4/15/2025 3:24:08 PM.744 2 false
                          4/15/2025 3:24:09 PM.722 2 true
                          4/15/2025 3:24:21 PM.493 1 false
                          4/15/2025 3:24:22 PM.188 1 true
                          4/15/2025 3:24:31 PM.678 0 false
                          4/15/2025 3:24:31 PM.801 0 true
                          Aus meiner Sicht funktioniert hier alles ordnungsgemäß.
                          Evtl kannst du ebenfalls mit history das mal nachvollziehen?
                          • hsteinme
                            @oliverio Danke für Dein Bemühen, Oliver!
                            Das hatte ich letzte Woche auch schon getan - ohne neue Erkenntnisse.
                            Das sehe ich - seit Deiner Eläuterung hier - auch genau so.
                            • OliverIO
                              @hsteinme
                              evtl mal zu deinem skript, kannst du das mal zeigen. das folgende ist ja wahrscheinlich nur pseudocode?
                              Evtl kann man da was optimieren, weil sich manche von der bedeutung überschneiden (power,randomplay,state, da würde einfach nur randomplay reichen)
                              randomplay ist wahrscheinlich falsch, da als nächster parameter nur einer der folgenden zulässig ist, kann aber durch plugins auch erweitert werden
                              tracks|albums|contributors|<wbr>year
                              auch playlist clear ist eigentlich nicht notwendig, weil wenn du direkt etwas anwählst ohne das du explizit sagst, das es der playlist hinzugefügt werden soll, die playlist geleert wird
                              	.Power = 1
                              	.Volume = 70
                              	.state = 1
                              • hsteinme
                                Aber gern doch:
                                 * Reaktion auf Start-Signal für eine SqueezeBox
                                function BearbeiteStartSignal(SqBoxNr) {
                                    var Spiel;
                                    var Art;
                                    if(parScharfGeschaltet) {
                                        if(getState(MySqueezeBoxIds[SqBoxNr] + '.Pause').val == false) {
                                            setState(AccessKeys[SqBoxNr] + '.Power' , 1);
                                            Log(true, MySqueezeBoxes[SqBoxNr] + ': Power = 1');
                                            setState(AccessKeys[SqBoxNr] + '.cmdGeneral', '"playlist", "clear"');
                                            Log(true, MySqueezeBoxes[SqBoxNr] + ': playlist clear');
                                            setState(AccessKeys[SqBoxNr] + '.Volume', getState(MySqueezeBoxIds[SqBoxNr] + '.AnfangsLautstaerke').val);
                                            Log(true, MySqueezeBoxes[SqBoxNr] + ': Volume = ' + getState(MySqueezeBoxIds[SqBoxNr] + '.AnfangsLautstaerke').val);
                                            Art = parLosTopf[getRndInteger(0, parLosTopf.length - 1)]
                                            switch(Art) {
                                                case artFAVORITE:
                                                    Spiel = MyFavoriteIds[getRndInteger(0, MyFavoriteIds.length - 1)];
                                                    setState(AccessKeys[SqBoxNr] + '.cmdPlayFavorite', Spiel);
                                                    Log(false, MySqueezeBoxes[SqBoxNr] + ': Favorit-Id = ' + Spiel);
                                                    break;
                                                case artTRACKS:
                                                case artALBUMS:
                                                case artARTISTS:
                                                case artYEAR:
                                                    Spiel = '"randomplay", "' + ArtKommandos[Art] + '"';
                                                    setState(AccessKeys[SqBoxNr] + '.cmdGeneral', Spiel);
                                                    Log(true, MySqueezeBoxes[SqBoxNr] + ': ' + Spiel);
                                                    break;
                                            setState(AccessKeys[SqBoxNr] + '.state', statePLAY);
                                            Log(true, MySqueezeBoxes[SqBoxNr] + ': play');
                                            for (var Count = 0; Count < 4; Count++) {
                                                setTimeout(CheckStateVolume, 3000 + Count * 1000, SqBoxNr);
                                Einige Erläuterungen:
                                • parScharfGeschaltet regelt, ob überhaupt bei einer Präsenzmeldung Musik eingeschaltet werden soll oder nicht.
                                • .Pause definiert (nächtliche) Pausenzeiten, zu denen der Präsenzmelder ignoriert werden soll.
                                • Über parLosTopf wird "ausgelost", ob ein zufälliger Favorit (was bei mir immer ein Radiosender ist) oder eine nach Titel, Alben, Interpreten oder Jahren zufällig ausgesuchte Playlist gestartet wird.
                                 * Ausgabe einer Art-Option für randomplay
                                function SetzeArtKommandos() {
                                    ArtKommandos[artTRACKS] = 'tracks';
                                    ArtKommandos[artALBUMS] = 'albums';
                                    ArtKommandos[artARTISTS] = 'contributors';
                                    ArtKommandos[artYEAR] = 'year';
                                • CheckStateVolume überprüft, ob die angesteuerten .Volume und .state Anweisungen umgesetzt worden sind. Falls nicht, werden diese Anweisungen erneut losgeschickt.
                                • Log(true, ...) nimmt nur dann einen Logeintrag vor, wenn ein skriptinternes Debug-Flag gesetzt ist.
                                • OliverIO
                                  OliverIO last edited by OliverIO
                                  Probier mal so
                                  ich habe mal die doppelt gemoppelten Befehle (also play Befehle, welche die anderen bereits beinhalten) entfernt.
                                  Ich bin jetzt da gerade nicht so firm. achte darauf, das du auf jedenfall von getState/setState immer nur die synchronen Versionen verwendest. Wenn asynchron ohne await garantiert nicht, das der Befehl dann schon fertig ist, wenn das die asynchronen versionen sind, dann noch await davor schreiben (und sobald in einer funktion await verwendet wird muss diese auch mit async versehen werden.)
                                  Falls das Problem anhält, probier mal ein await sleep(1000) zwischen den setStates zu setzen.
                                  die 1000 ist 1 Sekunde. Die Zeit kannst du auch noch variieren. Nicht das das schnell hintereinander setzen von States da irgendwas durcheinanderbringt im LMS. Aber das reduzieren der setStates hilft evtl auch schon.
                                  @hsteinme sagte in Test/Support Adapter SqueezeboxRPC:
                                      var Spiel;
                                      var Art;
                                              switch(Art) {
                                                  case artFAVORITE:
                                                      break;
                                                  case artTRACKS:
                                                  case artALBUMS:
                                                  case artARTISTS:
                                                  case artYEAR:
                                                      break;
                                  hsteinme 2 Replies Last reply Reply Quote 0
                                  • hsteinme
                                    Danke, Oliver!
                                    Das gehe ich mal am langen Wochenende an.
                                    Im Script kommen weder asyync noch await vor.
                                    Das hatte ich mir auch schon überlegt und ebenfalls für das kommende Wochenende eingeplant.
                                    Ich melde mich demnächst wieder.
                                    • hsteinme
                                      hsteinme @OliverIO last edited by hsteinme
                                      Jau, Oliver, Deine Aufräumaktion ist der Bringer. Bei fast zwei Dutzend Testläufen gab's nur Erfolgserlebnisse. Auch hier sieht man's also mal wieder: Weniger kann mehr sein 😊 Ich hatte wohl mit meiner "Kommandoschwemme" den LMS ins Schwimmen gebracht.
                                      Ich sage Dir nochmals ganz herzlichen Dank für Deine Unterstützung. Ich finde es toll, wie tief Du in die von mir geschilderte Problematik meines Skripts eingestiegen bist. Das was Du hier im Forum leistest - nicht nur in "Deinen" Adaptern, sondern auch in anderen Themen - ist schon phantastisch. 👍 👏
                                      • OliverIO
                                        Neue Version 1.6.2
                                        • Neues Widget browser (aktuell nur alpha zum testen)
                                        • Behebung von Meldungen aus dem Adapter-Checker
                                        In diesem Release ist ein neues widget enthalten:
                                        Browser
                                        Dies zeigt Musik, Alben, Interpreten, Radiosender, Apps usw. vom Server an. Durch Klick auf ein Element kann in der Hierarchie tiefer gegangen werden, durch Klick auf den Pfad ganz oben kann wieder höher gegangen werden.
                                        Falls Verfügbar, sind für einzelne Elemente weitere Aktionen verfügbar (Play, Add Playlist,...)
                                        Da die Implementierung auf Seiten des LMS/Lyrion-Servers zwar funktioniert, aber mit extrem vielen und undurchsichtigen Sonderfällen versehen ist, stand dieses widget sehr lange auf dem Plan.
                                        Als technisches Vorbild stand das Material-Theme-Plugin für den LMS.
                                        Da der LMS/Lyrion-Server aber mit Plugins erweiterbar ist, konnten alle Fälle berücksichtigt werden. Daher bitte ich euch das einmal durchzutesten. Insbesondere mit den Unterbereichen, wo ihr Plugins installiert habt.
                                        Das widget ist aktuell mit erweiterten Debugging-Ausgaben ausgestattet. Für Tester diese beiden bitte in der widget Konfiguration aktivieren. Diese geben dann nochmal extra Informationen in der Browserkonsole (
                                        F12) aus, die dann helfen, Fehler oder fehlende Implementierungen herauszufinden und zu ergänzen.
                                        Wer mit testen möchte, dann bitte die Ergebnisse hier einfach im Thread hinterlassen. Auch Wünsche für weitere Funktionen bitte ebenfalls hier dokumentieren.
                                        Folgendes ist aktuell noch nicht eingebaut:
                                        • Eingabefelder innerhalb der Hierarchie
                                        • Der Hauptmenüpunkt "Extras"
                                          daPanic last edited by
                                          Moin,
                                          irgendwie stehe ich gerade auf dem Schlauch.
                                          Ich habe auf dem Server, auf dem auch der IOBroker läuft meinen Lyrion Server laufen.
                                          Alle meine Boxen (Squeezeboxen und Booms) laufen soweit.
                                          Jetzt wollte ich das Player Widget testen und in der Doku steht ich soll es mit der Instanz verbinden. Wie mache ich das?
                                          Ich kann ja nur auf Datenpunkte zugreifen.
                                          • OliverIO
                                            OliverIO @daPanic last edited by
                                            @dapanic
                                            ja korrekt.
                                            wähle einen beliebigen datenpunkt aus der instanz aus.
                                            der rest macht das widget und extrahiert dann die instanz aus dem datenpunkt
                                            squeezeboxrpc adapter
                                            29
                                            376
                                            61533
