    4. [Gelöst]Zigbee seit update auf 2.x nicht mehr funktionsfähig
    • Haifeif 0
      Haifeif 0 @crunchip last edited by Homoran
      @crunchip iob diag:
                              v.2025-02-23
         Static hostname: raspberrypi
               Icon name: computer
        Operating System: Debian GNU/Linux 11 (bullseye)
                  Kernel: Linux 6.1.21-v8+
            Architecture: arm64
      Installation:           native
      Kernel:                 aarch64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Display-Server:         false
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Pending iob updates:    0
      Nodejs-Installation:
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      Recommended versions are nodejs 20.19.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:            3.8G        2.1G        838M        1.0M        817M        1.6G
      Swap:            99M          0B         99M
      Total:          3.9G        2.1G        938M
      Active iob-Instances:   27
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.6.3
      Objects type: jsonl
      States  type: jsonl
      + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Objects:                12837
      States:                 9328
      Size of iob-Database:
      22M     /opt/iobroker/iobroker-data/objects.jsonl
      8.4M    /opt/iobroker/iobroker-data/states.jsonl
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      • Haifeif 0
        Haifeif 0 @crunchip last edited by Haifeif 0
        @crunchip Adapter:
        COM Anschluss: /dev/serial/by-id/usb-Texas_Instruments_XDS110__03.00.00.36__Embed_with_CMSIS-DAP_L1100M66-if00
        Typ: TI Z-Stack/CCxxxx
        Network: AFAFAFAFAFAFAFAF
        Pan ID: 38
        Kanal: 11
        Transportschlüssel: 01030507090B0D0F00020406080A0CFF
        Log warning on Zigbee device announcment: Ja
          Thomas Braun Most Active @Haifeif 0 last edited by
          @haifeif-0 sagte in Zigbee seit update auf 2.x nicht mehr funktionsfähig:
          Wie bekomme ich die log auf Zigbee beschränkt? Die log datei ist MB groß!
          iob logs zigbee
            Installier da NEU Debian 12 'Bookworm'.
            • Asgothian
              Asgothian Developer @Haifeif 0 last edited by
              @crunchip Adapter:
              Pan ID: 38
              Kanal: 11
              folgendes machen:
              • Zigbee Adapter anhalten
              • sicherstellen das der Zigbee Adapter auf info steht (nicht debug)
              • log löschen
              • adapter starten
              • 60 sekunden warten
              • log herunter laden und hier (als text, in code tags (</>) posten.
              Der Vorschlag
              @thomas-braun sagte in Zigbee seit update auf 2.x nicht mehr funktionsfähig:
              ist auf lange Sicht Sinnvoll, bringt aber für das aktuelle Problem erst einmal wenig - es ist zu klären ob es da Probleme gibt. Mir ist nicht bekannt das der Adapter unter bullseye nicht läuft.
              A.
              Thomas Braun Haifeif 0 2 Replies Last reply Reply Quote 0
                Thomas Braun Most Active @Asgothian last edited by
                @asgothian sagte in Zigbee seit update auf 2.x nicht mehr funktionsfähig:
                Das habe ich auch nicht behauptet.
                Es ist nur wenig sinnvoll, auf abgekündigten Versionen zu verharren. Macht das weitere Leben nämlich nicht einfacher.
                • Asgothian
                  Asgothian Developer @Thomas Braun last edited by
                  Da sind wir uns einig. Trotzdem gilt aus meiner Sicht die folgende Reihenfolge:
                  1. Analyse. So wenig wie möglich verändern und schauen was los ist.
                  2. Mit minimalen Maßnahmen schauen das das System läuft so das ein sauberes Backup gezogen werden kann
                  3. Neu Installation oder große Updates am Unterbau.
                  A.
                  Haifeif 0 1 Reply Last reply Reply Quote 1
                  • Haifeif 0
                    Haifeif 0 @Asgothian last edited by Haifeif 0
                    @asgothian Sorry, hatte in der Zwischenzeit bookworm angefangen zu installieren bzw. zu updaten. Melde mich, wenn das System wieder läuft ...
                    • Asgothian
                      Ich hoffe du hast ein sauberes Backup vom zigbee adapter (config, shepherd.db, nvbackup.json)
                      A.
                      Haifeif 0 1 Reply Last reply Reply Quote 0
                      • Haifeif 0
                        @asgothian Läuft alle 2 Tage, also denke ich ja!
                        • Haifeif 0
                          @asgothian
                          zigbee.0
                          4307	2025-04-15 14:54:11.169	info	terminating
                          zigbee.0
                          4307	2025-04-15 14:54:11.108	warn	Device 0x84ba20fffed421c0 "SEA801-Zigbee/SEA802-Zigbee" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:11.107	warn	Device 0x84ba20fffee21b92 "SEA801-Zigbee/SEA802-Zigbee" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:11.106	warn	Device 0x540f57fffebc6638 "SEA801-Zigbee/SEA802-Zigbee" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:11.106	warn	Device 0x540f57fffebc6659 "SEA801-Zigbee/SEA802-Zigbee" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:11.105	warn	Device 0xcc86ecfffea50cb0 "SEA801-Zigbee/SEA802-Zigbee" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.950	warn	Device 0xa4c138b1cd1f6edd "HG08673" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.949	warn	Device 0xa4c138b66c5e5878 "HG08673" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.942	warn	Device 0x60a423fffe04ed68 "HG06337" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.942	warn	Device 0x680ae2fffe71c4da "HG06338" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.941	warn	Device 0xbc33acfffe67f002 "HG06337" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.940	warn	Device 0xbc33acfffe330e88 "HG06338" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.932	warn	Device 0x0c4314fffe67f8d2 "HG07834B/HG09155B/HG08131B" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.893	warn	Device 0xbc33acfffe616871 "FB20-002" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.888	warn	Device 0x5c0272fffe0a5f07 "HG06104A" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.884	warn	Device 0x588e81fffec8c6f6 "HG06104A" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.883	warn	Device 0xa4c138546cec3386 "33952" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.816	warn	Device 0x000b57fffee1d8c8 "LED1546G12" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.816	warn	Device 0x44e2f8fffe1eb403 "LED2111G6" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.815	warn	Device 0x6cfd22fffe7fe988 "E2134" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.815	warn	Device 0xd44867fffe5b0f06 "E2202" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.814	warn	Device 0x38398ffffe0af87d "E2202" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.814	warn	Device 0x588e81fffef7817e "HG06492A/HG08130A" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.813	warn	Device 0x90fd9ffffe710186 "LED1650R5" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.813	warn	Device 0xec1bbdfffeb4da16 "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.812	warn	Device 0x00158d0008913421 "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.812	warn	Device 0xec1bbdfffea02ef6 "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.811	warn	Device 0x54ef4410001a0b66 "VOCKQJK11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.811	warn	Device 0x00158d0008a6eaa6 "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.810	warn	Device 0xec1bbdfffe8d2a81 "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.809	warn	Device 0x0c4314fffe148ef7 "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.809	warn	Device 0x540f57fffeeeb05f "E1743" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.808	warn	Device 0xec1bbdfffeac2e9a "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.808	warn	Device 0xec1bbdfffeac27b4 "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.807	warn	Device 0xec1bbdfffeb077f8 "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.807	warn	Device 0x0c4314fffeb56b21 "E1744" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.806	warn	Device 0x5c0272fffe626d92 "E1766" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.806	warn	Device 0x90fd9ffffe6dc583 "E1524/E1810" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.805	warn	Device 0xb4e3f9fffe53e7ba "ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.805	warn	Device 0x842e14fffe61c5b6 "HG06336" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.804	warn	Device 0x54ef441000295e46 "MCCGQ14LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.803	warn	Device 0x943469fffe3d5847 "E1743" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.803	warn	Device 0x04cd15fffe4397eb "E1743" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.802	warn	Device 0x00158d00073a3d69 "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.802	warn	Device 0x00158d0007558132 "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.801	warn	Device 0x00158d0007558147 "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.801	warn	Device 0x00158d0007559e6f "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.800	warn	Device 0x00158d00073c0f8e "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.800	warn	Device 0x842e14fffea80b55 "E1746" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.799	warn	Device 0x804b50fffe2b31fb "E1746" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.798	warn	Device 0x000d6f0011b41851 "4058075816459" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.798	warn	Device 0x8cf681fffe50551b "E1743" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.797	warn	Device 0x8cf681fffe5054f8 "E1743" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.797	warn	Device 0x842e14fffe5c8503 "E2001/E2002" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.796	warn	Device 0x000b57fffee2c696 "LED1546G12" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.795	warn	Device 0x000d6f00136f3e46 "4058075816459" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.794	warn	Device 0x680ae2fffed41c07 "E1926" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.794	warn	Device 0x804b50fffe2d3240 "E1926" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.793	warn	Device 0x804b50fffe5f8f51 "E1766" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.793	warn	Device 0x00158d0006f7e82e "WSDCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.792	warn	Device 0x00158d00070061bf "MCCGQ11LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.791	warn	Device 0x943469fffe3d6ee0 "E1743" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.790	warn	Device 0x54ef441000284a50 "MCCGQ14LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.789	warn	Device 0x84fd27fffed09178 "E160x/E170x/E190x" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.789	warn	Device 0xcc86ecfffe9aa3b5 "E160x/E170x/E190x" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.788	warn	Device 0x000b57fffee2d143 "E1524/E1810" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.787	warn	Device 0x50325ffffe6ea38b "E1744" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.787	warn	Device 0x000b57fffeece1f3 "L1528" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.786	warn	Device 0x54ef4410002841c7 "MCCGQ14LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.779	warn	Device 0x00158d0006eb96db "MFKZQ01LM" not found.
                          zigbee.0
                          4307	2025-04-15 14:54:10.773	info	terminating
                          zigbee.0
                          4307	2025-04-15 14:54:10.701	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                          zigbee.0
                          4307	2025-04-15 14:54:10.183	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                          zigbee.0
                          4307	2025-04-15 14:54:10.181	info	terminating
                          zigbee.0
                          4307	2025-04-15 14:54:10.180	info	Saved local configuration data
                          zigbee.0
                          4307	2025-04-15 14:54:10.178	info	local config saved
                          zigbee.0
                          4307	2025-04-15 14:54:10.176	info	cleaned everything up...
                          zigbee.0
                          4307	2025-04-15 14:54:10.121	error	undefined
                          zigbee.0
                          4307	2025-04-15 14:54:10.120	error	unhandled promise rejection: undefined
                          zigbee.0
                          4307	2025-04-15 14:54:10.120	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                          zigbee.0
                          4307	2025-04-15 14:54:10.118	error	Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
                          zigbee.0
                          4307	2025-04-15 14:54:09.950	info	Unable to obtain herdsman settings
                          zigbee.0
                          4307	2025-04-15 14:53:43.475	info	Starting Zigbee-Herdsman
                          zigbee.0
                          4307	2025-04-15 14:53:43.473	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.1)
                          zigbee.0
                          4307	2025-04-15 14:53:43.407	info	Starting Adapter npm ...
                          zigbee.0
                          4307	2025-04-15 14:53:43.405	info	--- creating device debug ---
                          zigbee.0
                          4307	2025-04-15 14:53:43.396	info	delete old Backup files. keep only last 10
                          zigbee.0
                          4307	2025-04-15 14:53:43.380	info	--> transmitPower : normal
                          zigbee.0
                          4307	2025-04-15 14:53:43.370	info	init localConfig
                          zigbee.0
                          4307	2025-04-15 14:53:43.337	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                          • Asgothian
                            Du hast ein Problem mit der Kommunikation mit der Firmware auf deinem Koordinator.
                            • Bist du sicher das du den korrekten Port angegeben hast ? Das TI Board hat meines Wissens 2 davon.
                            • bist du sicher das das Kabel zum Koordinator in Ordnung ist ?
                            A.
                            • Haifeif 0
                              @asgothian
                              Ich denke, Du meinst das hier?
                              pi@raspberrypi:~ $ ls /dev/serial/by-id
                              usb-Texas_Instruments_XDS110__03.00.00.36__Embed_with_CMSIS-DAP_L1100M66-if03
                              Ich habe wie vorher die erste (if00) genommen, das kabel wurde seit 3 Jahren nicht angefasst (alles in einem 3D Druck Gehäuse)
                              • Asgothian
                                @asgothian
                                ja
                                • Haifeif 0
                                  @asgothian
                                  Wie Du Dir wahrscheinlich vorstellen kannst, ist eine Wohnung, die plötzlich auf Zigbee / ioBroker Komfort verzichten muss, plötzlich eine Höhle. 😊
                                  Daher habe ich meine eigenen Schritte noch einmal nachvollzogen und die Firmware nocheinmal überprüft und erneut eingespielt.
                                  Es geht immer noch nicht, aber die Log Informationen haben sich verändert:
                                  zigbee.0
                                  PID
                                  Zeit
                                  debug
                                  Nachricht
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.753	warn	Device 0x84ba20fffed421c0 "SEA801-Zigbee/SEA802-Zigbee" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.753	warn	Device 0x84ba20fffee21b92 "SEA801-Zigbee/SEA802-Zigbee" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.752	warn	Device 0x540f57fffebc6638 "SEA801-Zigbee/SEA802-Zigbee" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.752	warn	Device 0x540f57fffebc6659 "SEA801-Zigbee/SEA802-Zigbee" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.751	warn	Device 0xcc86ecfffea50cb0 "SEA801-Zigbee/SEA802-Zigbee" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.626	warn	Device 0xa4c138b1cd1f6edd "HG08673" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.626	warn	Device 0xa4c138b66c5e5878 "HG08673" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.619	warn	Device 0x60a423fffe04ed68 "HG06337" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.618	warn	Device 0x680ae2fffe71c4da "HG06338" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.618	warn	Device 0xbc33acfffe67f002 "HG06337" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.617	warn	Device 0xbc33acfffe330e88 "HG06338" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.610	warn	Device 0x0c4314fffe67f8d2 "HG07834B/HG09155B/HG08131B" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.578	warn	Device 0xbc33acfffe616871 "FB20-002" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.573	warn	Device 0x5c0272fffe0a5f07 "HG06104A" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.569	warn	Device 0x588e81fffec8c6f6 "HG06104A" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.568	warn	Device 0xa4c138546cec3386 "33952" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.485	warn	Device 0x000b57fffee1d8c8 "LED1546G12" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.485	warn	Device 0x44e2f8fffe1eb403 "LED2111G6" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.484	warn	Device 0x6cfd22fffe7fe988 "E2134" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.484	warn	Device 0xd44867fffe5b0f06 "E2202" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.483	warn	Device 0x38398ffffe0af87d "E2202" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.483	warn	Device 0x588e81fffef7817e "HG06492A/HG08130A" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.482	warn	Device 0x90fd9ffffe710186 "LED1650R5" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.482	warn	Device 0xec1bbdfffeb4da16 "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.481	warn	Device 0x00158d0008913421 "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.481	warn	Device 0xec1bbdfffea02ef6 "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.480	warn	Device 0x54ef4410001a0b66 "VOCKQJK11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.480	warn	Device 0x00158d0008a6eaa6 "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.479	warn	Device 0xec1bbdfffe8d2a81 "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.479	warn	Device 0x0c4314fffe148ef7 "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.478	warn	Device 0x540f57fffeeeb05f "E1743" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.478	warn	Device 0xec1bbdfffeac2e9a "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.477	warn	Device 0xec1bbdfffeac27b4 "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.477	warn	Device 0xec1bbdfffeb077f8 "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.476	warn	Device 0x0c4314fffeb56b21 "E1744" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.476	warn	Device 0x5c0272fffe626d92 "E1766" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.475	warn	Device 0x90fd9ffffe6dc583 "E1524/E1810" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.475	warn	Device 0xb4e3f9fffe53e7ba "ICPSHC24-10EU-IL-1/ICPSHC24-10EU-IL-2" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.474	warn	Device 0x842e14fffe61c5b6 "HG06336" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.474	warn	Device 0x54ef441000295e46 "MCCGQ14LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.473	warn	Device 0x943469fffe3d5847 "E1743" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.472	warn	Device 0x04cd15fffe4397eb "E1743" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.472	warn	Device 0x00158d00073a3d69 "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.471	warn	Device 0x00158d0007558132 "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.471	warn	Device 0x00158d0007558147 "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.470	warn	Device 0x00158d0007559e6f "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.469	warn	Device 0x00158d00073c0f8e "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.467	warn	Device 0x842e14fffea80b55 "E1746" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.466	warn	Device 0x804b50fffe2b31fb "E1746" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.464	warn	Device 0x000d6f0011b41851 "4058075816459" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.463	warn	Device 0x8cf681fffe50551b "E1743" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.461	warn	Device 0x8cf681fffe5054f8 "E1743" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.460	warn	Device 0x842e14fffe5c8503 "E2001/E2002" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.459	warn	Device 0x000b57fffee2c696 "LED1546G12" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.458	warn	Device 0x000d6f00136f3e46 "4058075816459" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.456	warn	Device 0x680ae2fffed41c07 "E1926" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.455	warn	Device 0x804b50fffe2d3240 "E1926" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.454	warn	Device 0x804b50fffe5f8f51 "E1766" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.454	warn	Device 0x00158d0006f7e82e "WSDCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.452	warn	Device 0x00158d00070061bf "MCCGQ11LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.452	warn	Device 0x943469fffe3d6ee0 "E1743" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.451	warn	Device 0x54ef441000284a50 "MCCGQ14LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.450	warn	Device 0x84fd27fffed09178 "E160x/E170x/E190x" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.450	warn	Device 0xcc86ecfffe9aa3b5 "E160x/E170x/E190x" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.449	warn	Device 0x000b57fffee2d143 "E1524/E1810" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.448	warn	Device 0x50325ffffe6ea38b "E1744" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.447	warn	Device 0x000b57fffeece1f3 "L1528" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.446	warn	Device 0x54ef4410002841c7 "MCCGQ14LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.440	warn	Device 0x00158d0006eb96db "MFKZQ01LM" not found.
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.436	info	terminating
                                  zigbee.0
                                  3453	2025-04-16 08:11:11.326	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.763	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.761	info	terminating
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.759	info	Saved local configuration data
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.757	info	local config saved
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.755	info	cleaned everything up...
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.706	error	undefined
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.705	error	unhandled promise rejection: undefined
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.704	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.701	error	Starting zigbee-herdsman problem : startup failed - configuration-adapter mismatch - see logs above for more information
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.490	warn	Network parameters on Coordinator: panID=65534 channel=0 extendedPanID=833cf91200b42100
                                  zigbee.0
                                  3453	2025-04-16 08:11:10.489	warn	Network parameters in Config : panID=65534 channel=11 extendedPanID=
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.784	info	Starting Zigbee-Herdsman
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.781	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.1)
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.718	info	Starting Adapter npm ...
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.716	info	--- creating device debug ---
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.711	info	delete old Backup files. keep only last 10
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.696	info	--> transmitPower : normal
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.686	info	init localConfig
                                  zigbee.0
                                  3453	2025-04-16 08:11:09.655	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
                                  Hilft das weiter?
                                  LG Uwe
                                  Thomas Braun Asgothian 2 Replies Last reply Reply Quote 0
                                    D fehlt die extended PanID in den Einstellungen, würde ich behaupten.
                                    • Haifeif 0
                                      Haifeif 0 @Thomas Braun last edited by
                                        zigbee.0
                                        kein plan was du da veranstaltest aber die konfigurationen passen nicht zueinandner
                                        nach dem flashen hast du nicht lang genug gewartet bis der Adapter die Einstellungen wieder auf das Board kopiert hat
                                        somit passt das jetzt nach deinem fummeln nicht zusammen.
                                        • Asgothian
                                          Hilft das weiter?
                                          Bedingt. Die Ursache ist von @arteck und @Homoran bereits aufgezeigt. Da da aber Auffälligkeiten sind bitte ich dich folgendes zu tun:
                                          • die 3.0.0 beta installieren, dazu
                                            -- in den expertenmodus gehen (das 'kopf' Icon im Admin
                                            -- über den button unten rechts auf der im folgenden Bild die dargestellten Kachel durch 'manuelle Eingabe' die Version 3.0.0 installierenScreenshot 2025-04-16 at 09.42.16.png
                                          • Adapter starten
                                          • in die Adapter Konfiguration gehen, Tab Hardware Auswählen
                                          • Screenshot analog zum folgenden hier postenScreenshot 2025-04-16 at 09.47.12.png
                                          • über den button 'start/stop' das Zigbee-Subsystem starten
                                          • Meldungen des Startversuchs aus dem Textfeld unter den Knöpfen hier posten.
                                          A.
                                          • Haifeif 0
                                            @arteck Ok, ich bin kein Entwickler. Daher besteht die Chance, das ich etwas falsch gemacht habe. Tatsache aber ist, das nach dem Update auf die Adapterversion 2.x das Problem anfing. OHNE, das ich irgendetwas geändert habe. Alles nachfolgende war mein Versuch, die Sache wieder ans laufen zu bringen.
                                            Was ich nicht verstehe ist: Was meinst Du mit "nach dem flashen hast du nicht lang genug gewartet bis der Adapter die Einstellungen wieder auf das Board kopiert hat"? Anders gefragt - wie mache ich es richtig?
                                            3012
