    3. Off Topic
    4. Magic Mirror zusammen mit IOBroker
    • Kusselin
      Kusselin last edited by
      Hallo Zusammen, ich muss hier nochmal aufmachen.....die ganze zeit haben meine Aquara Temp´s immer schön angezeigt im MM udn auf einmal gehts nicht mehr......
      hier mal ein Auschnitt aus der config:
      		module: 'MMM-ioBroker',
      		position: 'top_left',
      		config: {
      		  host: '192.168.200.38',
      		  port: '8082',
      		  https: false,
      		  devices: [
                { name: 'EG-Ankleide',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                    { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
      		  { name: 'EG-Büro',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d0006d571bb.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                    { id: 'zigbee.0.00158d0006d571bb.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
      		  { name: 'EG-Bad',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d0006e3ee77.temperature', icon: 'wi wi-thermometer', suffix: '°' },
                                    { id: 'zigbee.0.00158d0006e3ee77.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
      		  { name: 'EG-Wohnzimmer',
                  deviceStates: [
                                    { id: 'hm-rpc.0.NEQ1522239.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'hm-rpc.0.NEQ1522239.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
      		{ name: 'Dach-Speicher',
                  deviceStates: [
                                    { id: 'hm-rpc.0.KEQ0242488.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'hm-rpc.0.KEQ0242488.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'Treppenhaus',
                  deviceStates: [
                                    { id: 'hm-rpc.0.LEQ0592936.1.TEMPERATURE', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'hm-rpc.0.LEQ0592936.1.HUMIDITY',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'OG-Bad',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d008b644f6f.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'zigbee.0.00158d008b644f6f.humidity',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'OG-Wohnzimmer',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d008b64556c.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'zigbee.0.00158d008b64556c.humidity',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'OG-Rumpelzimmer',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d008b644eff.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'zigbee.0.00158d008b644eff.humidity',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'OG-Esszimmer',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d008b6192cd.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'zigbee.0.00158d008b6192cd.humidity',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'OG-Schlafzimmer',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d008b69c067.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'zigbee.0.00158d008b69c067.humidity',     icon: 'wi wi-humidity', suffix: '%' }
      			{ name: 'UG-Waschküche',
                  deviceStates: [
                                    { id: 'zigbee.0.00158d008b619293.temperature', icon: 'wi wi-thermometer',  suffix: '°' },
                                    { id: 'zigbee.0.00158d008b619293.humidity',     icon: 'wi wi-humidity', suffix: '%' }
      im MM Forum weiss man auch nicht warum....
      eventuell hat einer hier im Board ne Idee wieso das nicht mehr angezeigt wird.?
      Im iobroker läuft alles gut...mit den Aquaras.
      Über ne Info herzlichen Dank.
      • haselchen
        haselchen Most Active @Kusselin last edited by haselchen
        @kusselin
        Die Homematic Teile sind anscheinend auch betroffen (z. B. Treppenhaus)
        Edit:
        Aus dem Nichts , passiert schonmal gar nichts 😉
        Ursache -> Wirkung
        Überleg was Du gemacht hast , Update gefahren ?
        Irgendwas aus aber nicht wieder angeschaltet ….
        Kusselin 1 Reply Last reply Reply Quote 0
        • Kusselin
          Kusselin @haselchen last edited by
          @haselchen danke erstmal......aber ich weiss es ums himmels willen nicht .....update nee..
          ich habe jetzt mal die config und costum.css gesichert udn den MM mal über sie proxmox scripte neu installiert......module entsprechend im Modulordner installiert....die config zurück....das gleiche....keine Anzeige mehr 😞
          • haselchen
            @kusselin
            Momentan kann ich Dir nicht richtig helfen. Bin am Handy.
            Allerdings benutze ich nun den Chromebrowser den ich mit der ersten VIS View starten lasse.
            • Kusselin
              @haselchen
              Das einzige was mir noch einfällt ist ich hsab den Zigbee Adapter geupdatet..kann es daran liegen? Hat sich da was in den Datenpunkten geändert?
              • haselchen
                @kusselin
                Und ich habe noch gefragt …..
                Das Forum ist voll von Threads mit Zigbee in den letzten Tagen .
                Natürlich hat sich was geändert.
                Allerdings werden Deine Homematic Geräte auch nicht angezeigt
                • Kusselin
                  Kusselin last edited by Kusselin
                  Kann das eventuell auch mal einer testen der den MM und iobroker Geräte anzeigen lässt, testen...
                  das wäre supernett
                  @haselchen : Ja das stimmt...auch Homeatic geht nicht....das habe ich nicht geupdatet...also kanns ja eigentlich nur am MM-ioBroker -Modul liegen...
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @Kusselin last edited by
                    @kusselin sagte in Magic Mirror zusammen mit IOBroker:
                    Homeatic
                    meinst du
                    Homematic ?
                    • Kusselin
                      Kusselin @bahnuhr last edited by
                      @bahnuhr ja genau danke für die Schreibinfo....
                      teste lieber mal 🙂
                      • Kusselin
                        Hallo, ich melde mich nochmal...also ich hab bissl recherchiert udn mir ist aufgefallen das ich den WEB Adapter in IObroker geupdatet habe. das war / ist das Problem...mit dem Update des WEB Adapters muss man für den MM den Simple Api Adapter mitinstallieren udn als Webanwendung mitlaufen lassen....was aber komisch ist ....wenn ich in den Einstellungen von Simple API bin udn web aktiviere uns speichern+neustarten auswähle dann bleibt der Rot!! 😞
                        MM funzt aber jetzt wieder......wie bekomme ich den simple api restful apdapter auf grün?
                          A Former User @Kusselin last edited by
                          @kusselin
                          auch den Simple-Api Adapter updaten... du verwendest ne uralte Version.. die passt nicht zum Webadapter..
                          Kann natuerlich sein, dass das eine im Stable ist, und das andere nicht.. 🙂 wuerd mich nicht wundern.. 😄
                          • Kusselin
                            Kusselin @Guest last edited by Kusselin
                            @neuschwansteini hi, zeigt mir das nicht iobroker an..bzgl. dem Update?
                            wie update ich den simple api adapter manuell?
                            ich habe den über iobroker installiert udn da ist die 2.8.0
                            muss ich den dann über github updaten?
                            EDIT: Hat über Github geklappt...hab jetzt die 3.0.6
                            magic mirror
                            24
                            224
                            41903
