    4. Minor js-controller 7.0.7 Update in latest repo
    • Feuersturm
      Feuersturm @Bluefox last edited by
      @bluefox @foxriver76
      Ich habe gerade js-controller 7.0.7 auf meinem Testsystem installiert.
      Nach dem jsc Update und dem Betriebssystem update, hab ich das ganze System neu gestartet.
      Während des Shutdownprozesses kommt folgender Fehler im Log:
      2025-04-18 11:20:07.168 - error: host.ioB-Prod-Testsystem Caught by controller[0]: (node:14512) [DEP0044] DeprecationWarning: The `util.isArray` API is deprecated. Please use `Array.isArray()` instead.
      2025-04-18 11:20:07.168 - error: host.ioB-Prod-Testsystem Caught by controller[0]: (Use `node --trace-deprecation ...` to show where the warning was created)
      2025-04-18 11:20:07.168 - error: host.ioB-Prod-Testsystem Caught by controller[1]: (node:14512) [DEP0055] DeprecationWarning: The `util.isRegExp` API is deprecated. Please use `arg instanceof RegExp` instead.
      2025-04-18 11:20:07.169 - error: host.ioB-Prod-Testsystem Caught by controller[1]: (node:14512) [DEP0047] DeprecationWarning: The `util.isDate` API is deprecated. Please use `arg instanceof Date` instead.
      2025-04-18 11:20:06.863 - info: host.ioB-Prod-Testsystem instance system.adapter.unifi.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:06.877 - info: host.ioB-Prod-Testsystem instance system.adapter.scenes.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:06.937 - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:06.977 - info: host.ioB-Prod-Testsystem instance system.adapter.fully-tablet-control.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:06.990 - info: host.ioB-Prod-Testsystem instance system.adapter.trashschedule.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.019 - info: host.ioB-Prod-Testsystem instance system.adapter.ws.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.040 - info: host.ioB-Prod-Testsystem instance system.adapter.worx.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.108 - info: host.ioB-Prod-Testsystem instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.157 - info: host.ioB-Prod-Testsystem instance system.adapter.esphome.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.169 - info: host.ioB-Prod-Testsystem instance system.adapter.radar-trap.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.178 - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.220 - info: host.ioB-Prod-Testsystem instance system.adapter.samsung.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.383 - info: host.ioB-Prod-Testsystem stopInstance timeout system.adapter.web.0 killing pid 14217
      2025-04-18 11:20:07.384 - info: host.ioB-Prod-Testsystem stopInstance timeout system.adapter.web.1 killing pid 14448
      2025-04-18 11:20:07.384 - info: host.ioB-Prod-Testsystem stopInstance timeout system.adapter.echarts.0 killing pid 14496
      2025-04-18 11:20:07.397 - info: host.ioB-Prod-Testsystem instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.407 - info: host.ioB-Prod-Testsystem instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.490 - info: host.ioB-Prod-Testsystem instance system.adapter.javascript.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.500 - info: host.ioB-Prod-Testsystem instance system.adapter.scheduler.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.509 - info: host.ioB-Prod-Testsystem instance system.adapter.fritzbox.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.521 - info: host.ioB-Prod-Testsystem instance system.adapter.valloxmv.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.533 - info: host.ioB-Prod-Testsystem instance system.adapter.proxmox.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.542 - info: host.ioB-Prod-Testsystem instance system.adapter.tr-064.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.569 - info: host.ioB-Prod-Testsystem instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.570 - info: host.ioB-Prod-Testsystem instance system.adapter.sonos.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.578 - info: host.ioB-Prod-Testsystem instance system.adapter.notification-manager.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.591 - info: host.ioB-Prod-Testsystem instance system.adapter.lgtv.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.604 - info: host.ioB-Prod-Testsystem instance system.adapter.tankerkoenig.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.614 - info: host.ioB-Prod-Testsystem instance system.adapter.nina.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.626 - info: host.ioB-Prod-Testsystem instance system.adapter.fullcalendar.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.639 - info: host.ioB-Prod-Testsystem instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.648 - info: host.ioB-Prod-Testsystem instance system.adapter.jsonconfig-demo.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.660 - info: host.ioB-Prod-Testsystem instance system.adapter.hue.0 terminated with code 0 (NO_ERROR)
      2025-04-18 11:20:07.661 - info: host.ioB-Prod-Testsystem All instances are stopped.
      2025-04-18 11:20:07.717 - warn: host.ioB-Prod-Testsystem instance system.adapter.web.0 terminated due to SIGKILL
      2025-04-18 11:20:07.717 - info: host.ioB-Prod-Testsystem instance system.adapter.web.0 terminated with code null ()
      2025-04-18 11:20:07.717 - info: host.ioB-Prod-Testsystem All instances are stopped.
      2025-04-18 11:20:07.728 - warn: host.ioB-Prod-Testsystem instance system.adapter.web.1 terminated due to SIGKILL
      2025-04-18 11:20:07.728 - info: host.ioB-Prod-Testsystem instance system.adapter.web.1 terminated with code null ()
      2025-04-18 11:20:07.728 - info: host.ioB-Prod-Testsystem All instances are stopped.
      2025-04-18 11:20:07.740 - warn: host.ioB-Prod-Testsystem instance system.adapter.echarts.0 terminated due to SIGKILL
      2025-04-18 11:20:07.741 - info: host.ioB-Prod-Testsystem instance system.adapter.echarts.0 terminated with code null ()
      2025-04-18 11:20:07.741 - info: host.ioB-Prod-Testsystem All instances are stopped.
      2025-04-18 11:20:07.836 - info: host.ioB-Prod-Testsystem terminated
      2025-04-18 11:20:12.401 - info: host.ioB-Prod-Testsystem iobroker.js-controller version 7.0.7 js-controller starting
      2025-04-18 11:20:12.403 - info: host.ioB-Prod-Testsystem Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-04-18 11:20:12.403 - info: host.ioB-Prod-Testsystem hostname: ioB-Prod-Testsystem, node: v22.14.0
      2025-04-18 11:20:12.404 - info: host.ioB-Prod-Testsystem ip addresses: 192.168.178.105 fe80::be24:11ff:fe8c:71a4
      2025-04-18 11:20:12.997 - info: host.ioB-Prod-Testsystem connected to Objects and States
      2025-04-18 11:20:13.006 - info: host.ioB-Prod-Testsystem added notifications configuration of host
      2025-04-18 11:20:13.296 - info: host.ioB-Prod-Testsystem 68 instances found
      2025-04-18 11:20:13.311 - info: host.ioB-Prod-Testsystem starting 50 instances
      Bluefox 1 Reply Last reply Reply Quote 0
      • Bluefox
        Bluefox @mcm1957 last edited by Bluefox
        @mcm1957
        "encrytedNative": [
        "myTab.myPassword"]
        • Bluefox
          Bluefox @Feuersturm last edited by
          @feuersturm Hm... an dem wurde nichts gemacht. Liegt vermutlich an super neuer Node.JS version?
          • Feuersturm
            @bluefox sagte in Minor js-controller 7.0.7 Update in latest repo:
            Folgendes ist auf dem Testsystem installiert:
            Node.js: v22.14.0
            NPM: 10.9.2
            padrino 1 Reply Last reply Reply Quote 0
            • padrino
              padrino Most Active @Feuersturm last edited by
              Muss jetzt mal doof fragen, sorry...
              Was ist denn der Unterschied zwischen js-controller und dem javascript adapter? 😌
              Homoran Feuersturm 2 Replies Last reply Reply Quote 0
                Homoran Global Moderator Administrators @padrino last edited by Homoran
                @padrino sagte in Minor js-controller 7.0.7 Update in latest repo:
                der js-controller ist das Herz von ioBroker
                der koordiniert und steuert alle Adapter
                • mcm1957
                  mcm1957 @Homoran last edited by
                  @Bluefox
                  Kann bitte einer von euch noch im ersten Beitrag "aktuelle stable version" auf "aktuelle beta version" ändern?
                    Homoran Global Moderator Administrators @mcm1957 last edited by
                    @mcm1957 erledigt
                    • mcm1957
                      mcm1957 @Bluefox last edited by
                      @bluefox said in Minor js-controller 7.0.7 Update in latest repo:
                      @mcm1957
                      "encrytedNative": [
                      "myTab.myPassword"]
                      Danke.
                      Wie / wo sind dann die Beispiele
                          "devices": [
                              {"name": "device1", "password": "MyPassword1"},
                              {"name": "device2"},
                              {"name": "device3", "password": "MyPassword3"},
                      zu verstehen? Ist das ein Eintrag / ein Arrayelement von protectedNative? Oder was anders? Und wie seht dazu this.config.xxx Teil bzw. die Config aus? Stammt aus einem Adapter? Wenn ja bitte welchem da kann ich dann ja direkt nachsehen.
                      Irgendwie steh ich auf der Leitung 🙂 Sorry.
                      • Feuersturm
                        Feuersturm @padrino last edited by
                        Wenn du auf dieser Seite https://www.iobroker.net/#de/documentation etwas nach unten scrollst siehst du eine Grafik. Der js-controller entspricht dem grauen Bereich wo "ioBroker Software" steht. Der JavaScript Adapter ist ein möglicher Adapter der zur Gruppe "Adapter Logikprogrammierung" gehört.
                          Homoran Global Moderator Administrators @Feuersturm last edited by
                          @feuersturm sagte in Minor js-controller 7.0.7 Update in latest repo:
                          nicht eher dem blauen Zylinder darin?
                          • Feuersturm
                            Feuersturm @Homoran last edited by
                            @homoran sagte in Minor js-controller 7.0.7 Update in latest repo:
                            Die Diskussion sollten wir dann lieber hier https://forum.iobroker.net/topic/51919/brainstorming-doku-abschnitt-willkommen/18 fortführen 😉
                            • wendy2702
                              Gerade mal das Upgrade gemacht. Was sagen mir denn diese Meldungen:
                              The following notifications happened during sync:
                              - Ignoring Directory "backitup.admin" because officially not created as meta object. Please remove directory!
                              - Ignoring Directory "onvif.admin" because officially not created as meta object. Please remove directory!
                              - Ignoring Directory "sayit.3" because officially not created as meta object. Please remove directory!
                              - Ignoring Directory "terminal" because officially not created as meta object. Please remove directory!
                              - Ignoring Directory "terminal.admin" because officially not created as meta object. Please remove directory!
                              - Ignoring Directory "wetty.admin" because officially not created as meta object. Please remove directory!
                              EDIT:
                              War jetzt bisschen unterwegs und als ich gerade nach Hause komme sieht mein VIS-2 in der Runtime z.B. so aus:
                              59d2fedf-3f02-4512-9de4-425a9cdc318c-grafik.png !
                              Im Editor fast noch alles "richtig":
                              Zurück auf 7.0.6 wieder alles da:
                              Alle Widgets die z.B. Zahlenwerte anzeigen sollen hatten nur noch ein NaN ausser der Energiefluss Adapter Erweitert.
                              EDIT: so gestern war bisschen spät. Anbei mal ein iob diag mit 7.0.6.
                              Soll ich ein issue öffnen oder jemand eine Idee wo ich suchen soll bzw. was bei mir falsch läuft?
                              Script v.2025-02-23
                              *** BASE SYSTEM ***
                               Static hostname: iobroker
                                     Icon name: computer-container
                                       Chassis: container ☐
                                Virtualization: lxc
                                        Kernel: Linux 6.8.12-9-pve
                                  Architecture: x86-64
                              OS is similar to:
                              model name      : Intel(R) Pentium(R) Silver J5040 CPU @ 2.00GHz
                              Docker          : false
                              Virtualization  : lxc
                              Kernel          : x86_64
                              Userland        : 64 bit
                              Systemuptime and Load:
                               09:42:13 up 8 days,  9:27,  2 users,  load average: 1.93, 1.51, 1.43
                              CPU threads: 4
                              *** LIFE CYCLE STATUS ***
                              Operating System is the current Debian stable version codenamed 'bookworm'!
                              *** TIME AND TIMEZONES ***
                                             Local time: Fri 2025-05-09 09:42:14 CEST
                                         Universal time: Fri 2025-05-09 07:42:14 UTC
                                               RTC time: n/a
                                            NTP service: inactive
                                        RTC in local TZ: no
                              *** Users and Groups ***
                              User that called 'iob diag':
                              mirko
                              HOME=/home/mirko
                              GROUPS=mirko sudo iobroker
                              iobroker
                              HOME=/home/iobroker
                              GROUPS=iobroker tty dialout audio video plugdev
                              *** DISPLAY-SERVER SETUP ***
                              Display-Server: false
                              Desktop:
                              Terminal:       tty
                              System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
                              *** MEMORY ***
                              Mem:             17G        5.1G         11G        102K        305M         12G
                              Swap:             0B          0B          0B
                              Total:           17G        5.1G         11G
                              Active iob-Instances:   63
                                      16384 M total memory
                                       4845 M used memory
                                       4512 M active memory
                                        349 M inactive memory
                                      11247 M free memory
                                          0 M buffer memory
                                        291 M swap cache
                                          0 M total swap
                                          0 M used swap
                                          0 M free swap
                              top - 09:42:14 up 8 days,  9:27,  2 users,  load average: 1.93, 1.51, 1.43
                              Tasks:  91 total,   6 running,  85 sleeping,   0 stopped,   0 zombie
                              %Cpu(s): 50.0 us, 33.3 sy,  0.0 ni, 16.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                              MiB Mem :  16384.0 total,  11245.4 free,   4847.4 used,    291.3 buff/cache
                              MiB Swap:      0.0 total,      0.0 free,      0.0 used.  11536.6 avail Mem
                              *** FAILED SERVICES ***
                                UNIT                    LOAD   ACTIVE SUB    DESCRIPTION
                              * sys-kernel-config.mount loaded failed failed Kernel Configuration File System
                              * sys-kernel-debug.mount  loaded failed failed Kernel Debug File System
                              LOAD   = Reflects whether the unit definition was properly loaded.
                              ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                              SUB    = The low-level unit activation state, values depend on unit type.
                              2 loaded units listed.
                              *** DMESG CRITICAL ERRORS ***
                              dmesg: read kernel buffer failed: Operation not permitted
                              No critical errors detected
                              *** FILESYSTEM ***
                              Filesystem                       Type      Size  Used Avail Use% Mounted on
                              /dev/mapper/pve-vm--101--disk--0 ext4       30G   15G   13G  54% /
                              none                             tmpfs     492K  4.0K  488K   1% /dev
                              udev                             devtmpfs   16G     0   16G   0% /dev/tty
                              tmpfs                            tmpfs      16G     0   16G   0% /dev/shm
                              tmpfs                            tmpfs     6.3G   96K  6.3G   1% /run
                              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                              tmpfs                            tmpfs     3.2G     0  3.2G   0% /run/user/1001
                              Show mounted filesystems:
                              TARGET SOURCE                           FSTYPE OPTIONS
                              /      /dev/mapper/pve-vm--101--disk--0 ext4   rw,relatime,stripe=16
                              /var:
                              1.4G    /var/
                              1.1G    /var/log/journal/c5b67cb2fb4c49678a4fd62f7e4a2b20
                              1.1G    /var/log
                              244M    /var/lib
                              Archived and active journals take up 171.8M in the file system.
                              /opt/iobroker/backups:
                              230M    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              1.6G    /opt/iobroker/iobroker-data/
                              838M    /opt/iobroker/iobroker-data/files
                              462M    /opt/iobroker/iobroker-data/backup-objects
                              171M    /opt/iobroker/iobroker-data/files/vis
                              163M    /opt/iobroker/iobroker-data/files/vis/widgets
                              70M     /opt/iobroker/iobroker-data/states.jsonl
                              52M     /opt/iobroker/iobroker-data/objects.jsonl
                              35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
                              27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                              26M     /opt/iobroker/iobroker-data/objects.json.migrated
                              USB-Devices by-id:
                              No Devices found 'by-id'
                              Zigbee Network Settings on your coordinator/in nvbackup are:
                              zigbee.X
                              Extended Pan ID:
                              *** MASKED ***
                              Pan ID:
                              *** MASKED ***
                              Channel:
                              *** MASKED ***
                              Network Key:
                              *** MASKED ***
                              To unmask the settings run 'iob diag --unmask'
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v20.19.1
                              /usr/bin/node           v20.19.1
                              /usr/bin/npm            10.8.2
                              /usr/bin/npx            10.8.2
                              /usr/bin/corepack       0.31.0
                              nodejs:
                                Installed: 20.19.1-1nodesource1
                                Candidate: 20.19.1-1nodesource1
                                Version table:
                               *** 20.19.1-1nodesource1 1001
                                      500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                      100 /var/lib/dpkg/status
                                   20.19.0-1nodesource1 1001
                                   20.18.3-1nodesource1 1001
                                   20.18.2-1nodesource1 1001
                                   20.18.1-1nodesource1 1001
                                   20.18.0-1nodesource1 1001
                                   20.17.0-1nodesource1 1001
                                   20.16.0-1nodesource1 1001
                                   20.15.1-1nodesource1 1001
                                   20.15.0-1nodesource1 1001
                                   20.14.0-1nodesource1 1001
                                   20.13.1-1nodesource1 1001
                                   20.13.0-1nodesource1 1001
                                   20.12.2-1nodesource1 1001
                                   20.12.1-1nodesource1 1001
                                   20.12.0-1nodesource1 1001
                                   20.11.1-1nodesource1 1001
                                   20.11.0-1nodesource1 1001
                                   20.10.0-1nodesource1 1001
                                   20.9.0-1nodesource1 1001
                                   20.8.1-1nodesource1 1001
                                   20.8.0-1nodesource1 1001
                                   20.7.0-1nodesource1 1001
                                   20.6.1-1nodesource1 1001
                                   20.6.0-1nodesource1 1001
                                   20.5.1-1nodesource1 1001
                                   20.5.0-1nodesource1 1001
                                   20.4.0-1nodesource1 1001
                                   20.3.1-1nodesource1 1001
                                   20.3.0-1nodesource1 1001
                                   20.2.0-1nodesource1 1001
                                   20.1.0-1nodesource1 1001
                                   20.0.0-1nodesource1 1001
                                   18.19.0+dfsg-6~deb12u2 500
                                      500 http://deb.debian.org/debian bookworm/main amd64 Packages
                                   18.19.0+dfsg-6~deb12u1 500
                                      500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
                              No problems detected
                              Errors in npm tree: 0
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Hosts:
                              iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 37147)
                              pi-iobroker         pi-iobroker (version: 7.0.7, hostname: pi-iobroker   , alive, uptime: 69534)
                              Core adapters versions
                              js-controller:  7.0.6
                              admin:          7.6.16
                              javascript:     8.9.1
                              nodejs modules from github:     1
                              +-- iobroker.smartstate@0.0.4 (git+ssh://git@github.com/ChriD/ioBroker.smartstate.git#aa448478fd656fff055532b33decd1138d9222e3)
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                system.adapter.admin.1                  : admin                 : pi-iobroker                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
                                system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
                                system.adapter.birthdays.1              : birthdays             : iobroker                                 -  enabled
                                system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                                system.adapter.devices.0                : devices               : iobroker                                 -  enabled
                                system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                              + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                              + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                              + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                              + system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
                              + system.adapter.enocean.0                : enocean               : pi-iobroker                              -  enabled
                                system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                                system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                              + system.adapter.frigate.0                : frigate               : iobroker                                 -  enabled
                                system.adapter.fritzbox.0               : fritzbox              : iobroker                                 - disabled
                                system.adapter.habpanel.0               : habpanel              : iobroker                                 -  enabled
                              + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
                              + system.adapter.hass.0                   : hass                  : iobroker                                 -  enabled, port: 8123
                                system.adapter.history.0                : history               : iobroker                                 - disabled
                              + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                              + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                              + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                system.adapter.homeconnect.0            : homeconnect           : iobroker                                 - disabled
                              + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                                system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
                                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : iobroker                                 - disabled
                                system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                                system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
                                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
                              + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                              + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                              + system.adapter.javascript.1             : javascript            : iobroker                                 -  enabled
                              + system.adapter.javascript.2             : javascript            : iobroker                                 -  enabled
                                system.adapter.js2fs.0                  : js2fs                 : iobroker                                 - disabled
                              + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                                system.adapter.matter.0                 : matter                : iobroker                                 - disabled
                              + system.adapter.mercedesme.0             : mercedesme            : iobroker                                 -  enabled
                              + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                              + system.adapter.modbus.1                 : modbus                : iobroker                                 -  enabled
                              + system.adapter.modbus.2                 : modbus                : iobroker                                 -  enabled
                              + system.adapter.modbus.3                 : modbus                : iobroker                                 -  enabled
                              + system.adapter.modbus.4                 : modbus                : iobroker                                 -  enabled
                              + system.adapter.modbus.5                 : modbus                : iobroker                                 -  enabled
                                system.adapter.modbus.6                 : modbus                : iobroker                                 - disabled
                              + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1889, bind: 0.0.0.0
                                system.adapter.notificationforandroidtv.0: notificationforandroidtv: iobroker                                 - disabled
                                system.adapter.nut.0                    : nut                   : iobroker                                 - disabled
                              + system.adapter.onvif.0                  : onvif                 : iobroker                                 -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                                system.adapter.ping.0                   : ping                  : iobroker                                 - disabled
                              + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                              + system.adapter.pushover.1               : pushover              : iobroker                                 -  enabled
                              + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                              + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
                                system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                              + system.adapter.sayit.0                  : sayit                 : iobroker                                 -  enabled, port: 0
                                system.adapter.sayit.1                  : sayit                 : iobroker                                 - disabled
                              + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled
                              + system.adapter.semp.0                   : semp                  : iobroker                                 -  enabled
                              + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.178.18
                              + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                              + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8091, bind: 192.168.178.18, run as: admin
                              + system.adapter.smartmeter.0             : smartmeter            : pi-iobroker                              -  enabled
                                system.adapter.smartstate.0             : smartstate            : iobroker                                 - disabled
                              + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 192.168.178.18, run as: admin
                              + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                              + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                              + system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker                                 -  enabled
                              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                              + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 192.168.178.18
                              + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
                              + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
                                system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                                system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                              + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                                system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
                                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                                system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
                                system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
                                system.adapter.vis-material-webfont.0   : vis-material-webfont  : iobroker                                 -  enabled
                                system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                                system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                                system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                                system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                              + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 8085, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.2                    : web                   : iobroker                                 -  enabled, port: 8086, bind: 0.0.0.0, run as: admin
                              + system.adapter.web.3                    : web                   : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                              + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                              + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                              + system.adapter.yahka.1                  : yahka                 : iobroker                                 -  enabled
                              + system.adapter.yahka.2                  : yahka                 : iobroker                                 -  enabled
                              + system.adapter.yahka.3                  : yahka                 : iobroker                                 -  enabled
                              + system.adapter.yahka.4                  : yahka                 : iobroker                                 -  enabled
                              + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
                                system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                              + instance is alive
                              ioBroker-Repositories
                              │ (index) │ name               │ url                                                     │ auto upgrade │
                              │ 0       │ 'Stable (default)' │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                              │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
                              │ 2       │ 'Test'             │ 'http://iobroker.live/repo/sources-dist.json'           │ false        │
                              Active repo(s): Beta (latest)
                              Upgrade policy: none
                              Installed ioBroker-Adapters
                              Used repository: Beta (latest)
                              Adapter    "admin"        : 7.6.17   , installed 7.6.16 [Updatable]
                              Adapter    "alarm"        : 3.7.0    , installed 3.7.0
                              Adapter    "alias-manager": 2.0.0    , installed 2.0.0
                              Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                              Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                              Adapter    "devices"      : 1.2.6    , installed 1.1.5  [Updatable]
                              Adapter    "email"        : 2.0.4    , installed 2.0.4
                              Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                              Adapter    "energiefluss-erweitert": 0.7.4, installed 0.7.4
                              Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
                              Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
                              Adapter    "frigate"      : 1.3.2    , installed 1.3.2
                              Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
                              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                              Adapter    "harmony"      : 1.5.0    , installed 1.5.0
                              Adapter    "hass"         : 1.4.0    , installed 1.4.0
                              Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                              Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                              Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
                              Adapter    "hue"          : 3.16.2   , installed 3.16.2
                              Adapter    "ical"         : 1.16.1   , installed 1.16.1
                              Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
                              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
                              Adapter    "javascript"   : 8.9.2    , installed 8.9.1  [Updatable]
                              Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
                              Adapter    "linux-control": 1.1.5    , installed 1.1.5
                              Adapter    "matter"       : 0.5.0    , installed 0.5.0
                              Adapter    "mercedesme"   : 0.3.7    , installed 0.3.7
                              Adapter    "modbus"       : 6.4.0    , installed 6.4.0
                              Adapter    "mqtt"         : 6.1.4    , installed 6.1.3  [Updatable]
                              Adapter    "notificationforandroidtv": 3.0.4, installed 3.0.4
                              Adapter    "nut"          : 1.6.0    , installed 1.6.0
                              Adapter    "onvif"        : 1.1.4    , installed 1.1.4
                              Adapter    "ping"         : 1.7.9    , installed 1.7.9
                              Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                              Adapter    "reolink"      : 1.2.2    , installed 1.2.2
                              Adapter    "roborock"     : 0.6.19   , installed 0.6.19
                              Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                              Adapter    "semp"         : 1.4.8    , installed 1.4.8
                              Adapter    "shelly"       : 9.5.0    , installed 9.5.0
                              Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
                              Adapter    "simple-api"   : 3.0.6    , installed 3.0.6
                              Adapter    "smartmeter"   : 3.4.0    , installed 3.4.0
                              Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                              Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                              Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                              Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                              Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                              Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                              Adapter    "trashschedule": 4.0.0    , installed 4.0.0
                              Adapter    "vis-2"        : 2.12.8   , installed 2.12.8
                              Adapter    "vis-2-widgets-collection": 1.7.9, installed 1.7.9
                              Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                              Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                              Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                              Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                              Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                              Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                              Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                              Adapter    "vis-material" : 0.2.0    , installed 0.2.0
                              Adapter    "vis-material-webfont": 0.0.3, installed 0.0.3
                              Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                              Adapter    "web"          : 7.0.9    , installed 7.0.9
                              Adapter    "ws"           : 3.0.19   , installed 3.0.19
                              Adapter    "yahka"        : 1.1.4    , installed 1.1.2  [Updatable]
                              Adapter    "yamaha"       : 0.5.4    , installed 0.5.4
                              Adapter    "yr"           : 5.3.0    , installed 5.3.0
                              Objects and States
                              Objects:        43510
                              States:         38526
                              Hit:2 http://deb.debian.org/debian bookworm-updates InRelease
                              Hit:3 http://security.debian.org/debian-security bookworm-security InRelease
                              Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                              Reading package lists...
                              Pending Updates: 1
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:46225         0.0.0.0:*               LISTEN      1000       136399241  416209/io.yahka.0
                              tcp        0      0 192.168.178.18:8701     0.0.0.0:*               LISTEN      1000       136391162  416076/io.hm-rpc.1
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          84286152   175/sshd: /usr/sbin
                              tcp        0      0 192.168.178.18:42001    0.0.0.0:*               LISTEN      1000       136391097  416065/io.hm-rpc.0
                              tcp        0      0 192.168.178.18:42010    0.0.0.0:*               LISTEN      1000       136391165  416083/io.hm-rpc.2
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       136398049  416441/io.sonoff.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       136398016  416430/io.mqtt.0
                              tcp        0      0 0.0.0.0:1889            0.0.0.0:*               LISTEN      1000       136398925  416502/io.mqtt.1
                              tcp        0      0 127.0.0.1:44531         0.0.0.0:*               LISTEN      1000       136398729  416308/io.yahka.3
                              tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1000       136383208  415766/iobroker.js-
                              tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1000       136381242  415766/iobroker.js-
                              tcp        0      0 0.0.0.0:42261           0.0.0.0:*               LISTEN      1000       136391603  416308/io.yahka.3
                              tcp        0      0 192.168.178.18:1882     0.0.0.0:*               LISTEN      1000       136397161  416401/io.shelly.0
                              tcp        0      0 127.0.0.1:39093         0.0.0.0:*               LISTEN      1000       136397656  416285/io.yahka.2
                              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          84288085   323/master
                              tcp        0      0 127.0.0.1:33507         0.0.0.0:*               LISTEN      1000       136399992  416240/io.yahka.1
                              tcp        0      0 192.168.178.18:8084     0.0.0.0:*               LISTEN      1000       136404256  416718/io.socketio.
                              tcp        0      0 192.168.178.18:8091     0.0.0.0:*               LISTEN      1000       136399467  416598/io.simple-ap
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          84286154   175/sshd: /usr/sbin
                              tcp6       0      0 :::33361                :::*                    LISTEN      1000       136395826  416240/io.yahka.1
                              tcp6       0      0 :::1885                 :::*                    LISTEN      1000       136410497  416980/io.frigate.0
                              tcp6       0      0 :::39549                :::*                    LISTEN      1000       136396058  416337/io.yahka.4
                              tcp6       0      0 :::8086                 :::*                    LISTEN      1000       136408947  416904/io.web.2
                              tcp6       0      0 :::8087                 :::*                    LISTEN      1000       136411192  416917/io.web.3
                              tcp6       0      0 :::8085                 :::*                    LISTEN      1000       136407112  416785/io.web.1
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1000       136402583  416653/io.web.0
                              tcp6       0      0 :::8083                 :::*                    LISTEN      1000       136403831  416774/io.ws.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1000       136381394  415786/io.admin.0
                              tcp6       0      0 :::40785                :::*                    LISTEN      1000       136395888  416285/io.yahka.2
                              tcp6       0      0 :::41955                :::*                    LISTEN      1000       136391443  416209/io.yahka.0
                              tcp6       0      0 :::42251                :::*                    LISTEN      1000       136396057  416337/io.yahka.4
                              tcp6       0      0 :::9765                 :::*                    LISTEN      1000       136409549  416965/io.semp.0
                              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          84288086   323/master
                              tcp6       0      0 :::61991                :::*                    LISTEN      1000       136392733  416032/io.harmony.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          84287115   82/dhclient
                              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       136409551  416965/io.semp.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136396063  416337/io.yahka.4
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136396062  416337/io.yahka.4
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136391605  416308/io.yahka.3
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136391604  416308/io.yahka.3
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136395264  416285/io.yahka.2
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136395263  416285/io.yahka.2
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136395831  416240/io.yahka.1
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136395830  416240/io.yahka.1
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136391448  416209/io.yahka.0
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1000       136391447  416209/io.yahka.0
                              udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1000       136392734  416032/io.harmony.0
                              2025-05-09 09:40:08.435  - info: host.iobroker instance system.adapter.dwd.0 having pid 438523 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2025-05-09 09:40:12.361  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Aussentemperatur" has to be type "number" but received type "string"
                              2025-05-09 09:40:12.408  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Gefuehlte_Temperatur" has to be type "number" but received type "string"
                              2025-05-09 09:40:12.507  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Windboeen_max" has to be type "number" but received type "string"
                              2025-05-09 09:40:34.934  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Windboeen_max" has to be type "number" but received type "string"
                              2025-05-09 09:40:59.583  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Tag" has to be type "number" but received type "string"
                              2025-05-09 09:40:59.774  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Windboeen_max" has to be type "number" but received type "string"
                              2025-05-09 09:41:31.564  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Tag" has to be type "number" but received type "string"
                              2025-05-09 09:41:31.795  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Windboeen_max" has to be type "number" but received type "string"
                              2025-05-09 09:41:36.659  - info: linux-control.0 (416698) getting data from VIS-Kueche-PI (192.168.178.217:22)
                              2025-05-09 09:41:43.694  - info: linux-control.0 (416698) successful received data from VIS-Kueche-PI (192.168.178.217:22)
                              2025-05-09 09:41:48.539  - info: linux-control.0 (416698) getting data from VIS-EG-PI (192.168.178.216:22)
                              2025-05-09 09:41:55.814  - info: linux-control.0 (416698) successful received data from VIS-EG-PI (192.168.178.216:22)
                              2025-05-09 09:42:03.933  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Windboeen_max" has to be type "number" but received type "string"
                              2025-05-09 09:42:04.565  - info: admin.0 (415786) ==> Connected system.user.admin from ::ffff:192.168.178.30
                              2025-05-09 09:42:11.790  - info: javascript.0 (415848) script.js.common.Cameras.PIPUP_Haustür_AgentDVR: Haustür Bewegung
                              2025-05-09 09:42:11.793  - info: frigate.0 (416980) Notification sending active but no image available for type car state Event After
                              2025-05-09 09:42:21.748  - info: frigate.0 (416980) Notification sending active but no image available for type person state Event After
                              2025-05-09 09:42:37.277  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Info.Solarenergie_Woche" has to be type "number" but received type "string"
                              2025-05-09 09:42:39.365  - info: simple-api.0 (416598) State value to set for "javascript.0.Wetterstation.Windboeen_max" has to be type "number" but received type "string"
                              2025-05-09 09:42:45.096  - info: frigate.0 (416980) Notification sending active but no image available for type person state Event After
                              2025-05-09 09:42:52.331  - info: javascript.0 (415848) script.js.common.Tablet_Steuerung.Display_EG_DIM_ON_OFF: VIS EG Bright
                              2025-05-09 09:42:52.505  - info: linux-control.0 (416698) state linux-control.0.VIS-EG-PI.VIS_EG_ScreenBright changed: true (ack = false)
                              2025-05-09 09:42:56.408  - info: javascript.0 (415848) script.js.common.Tablet_Steuerung.Display_ON_Flur_OG: VIS OG ON
                              2025-05-09 09:42:56.620  - info: linux-control.0 (416698) state linux-control.0.VIS-OG.VIS_OG_ScreenOn changed: true (ack = false)
                                australien last edited by
                                bei mir wird kein Update angeboten. Auch nicht bei anderen adaptern.
                                Die Einstellungen wurden aber nicht geändert. Mein aktueller Geräte Adapter ist 1.1.5, der sollte eigentlich bei 1.2.6 sein.
                                gibt es da einen Workaround?
                                  Thomas Braun Most Active @australien last edited by
                                  @australien
                                  iob update
                                  sagt?
                                    australien @Thomas Braun last edited by australien
                                    @thomas-braun ```
                                    Used repository: stable
                                    Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                                    Adapter    "admin"        : 7.6.3    , installed 7.6.3
                                    Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
                                    Adapter    "apg-info"     : 0.1.15   , installed 0.1.15
                                    Adapter    "awattar"      : 1.0.6    , installed 1.0.6
                                    Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                                    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                    Adapter    "echarts"      : 1.9.2    , installed 1.9.2
                                    Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
                                    Adapter    "fahrplan"     : 1.4.1    , installed 1.4.1
                                    Adapter    "fhem"         : 3.0.0    , installed 3.0.0
                                    Adapter    "followthesun" : 0.5.2    , installed 0.5.2
                                    Adapter    "fuelpricemonitor": 0.4.2 , installed 0.4.2
                                    Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                                    Controller "js-controller": 7.0.6    , installed 7.0.6
                                    Adapter    "mobile"       : 1.0.1    , installed 1.0.1
                                    Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
                                    Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                                    Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
                                    Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
                                    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                    Adapter    "parser"       : 2.2.4    , installed 2.2.4
                                    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                                    Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
                                    Adapter    "samsung"      : 0.6.1    , installed 0.6.1
                                    Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                    Adapter    "shelly"       : 9.2.0    , installed 9.2.0
                                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                    Adapter    "snmp"         : 3.2.0    , installed 3.2.0
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                    Adapter    "sonos"        : 3.0.0    , installed 3.0.0
                                    Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
                                    Adapter    "statistics"   : 2.4.0    , installed 3.1.0
                                    Adapter    "text2command" : 3.0.3    , installed 3.0.3
                                    Adapter    "trashschedule": 3.3.0    , installed 3.4.1
                                    Adapter    "unifi"        : 0.7.0    , installed 0.7.0
                                    Adapter    "vis-2"        : 2.9.64   , installed 2.10.8
                                    Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.1
                                    Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.11
                                    Adapter    "vis-2-widgets-weather-and-heating": 0.10.4, installed 0.10.4
                                    Adapter    "web"          : 7.0.8    , installed 7.0.8
                                    Adapter    "wled"         : 0.7.2    , installed 0.7.2
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                      Thomas Braun Most Active @australien last edited by Thomas Braun
                                      @australien
                                      Im von dir verwendeten stable-Repository liegt der in v 1.1.5 vor.
                                      devices
                                      github:	1.2.6
                                      latest:	1.2.6 for 19 days
                                      stable:	1.1.5 for 23 months
                                      js-controller:
                                      github:	7.0.8
                                      latest:	7.0.7 for 31 days
                                      stable:	7.0.6 for 5 months
                                      Passt also.
                                        Ok, verstanden. Hatte dann latest mit stable gendanklich vertauscht.
                                        Danke Dir!
                                        2064
