    4. VIS-2 Inventwo Bilder werde nicht angezeigt
    • Longbow
      Longbow @Ro75 last edited by
      @longbow
      ========== Start marking the full check here ===========
      ```bash
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: iobroker-Final
             Icon name: computer-container
               Chassis: container ☐
        Virtualization: lxc
                Kernel: Linux 6.2.16-3-pve
          Architecture: x86-64
      OS is similar to:
      model name      : Intel(R) Core(TM) i5-4590T CPU @ 2.00GHz
      Docker          : false
      Virtualization  : lxc
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       17:08:52 up 36 days,  7:31,  2 users,  load average: 0.42, 1.45, 1.87
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Sat 2025-04-19 17:08:52 CEST
                 Universal time: Sat 2025-04-19 15:08:52 UTC
                       RTC time: n/a
                    NTP service: inactive
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      longbow
      HOME=/home/XXXXXx
      GROUPS=l≈≈≈≈≈≈ sudo users iobroker
      js-controller is not running
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:             12G        394M         10G         65K        1.7G         12G
      Swap:           8.6G        7.6M        8.6G
      Total:           21G        401M         19G
      Active iob-Instances:   1
              12288 M total memory
                375 M used memory
               1350 M active memory
                290 M inactive memory
              10293 M free memory
                  0 M buffer memory
               1618 M swap cache
               8191 M total swap
                  7 M used swap
               8184 M free swap
      top - 17:08:52 up 36 days,  7:31,  2 users,  load average: 0.47, 1.44, 1.87
      Tasks:  26 total,   1 running,  25 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  12288.0 total,  10292.0 free,    377.6 used,   1618.4 buff/cache
      MiB Swap:   8192.0 total,   8184.7 free,      7.3 used.  11910.4 avail Mem
      *** FAILED SERVICES ***
        UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
      * iobroker.service     loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      2 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      dmesg: read kernel buffer failed: Operation not permitted
      No critical errors detected
      *** FILESYSTEM ***
      Filesystem                       Type      Size  Used Avail Use% Mounted on
      /dev/mapper/pve-vm--240--disk--0 ext4       94G   21G   69G  23% /
      none                             tmpfs     492K  4.0K  488K   1% /dev
      udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
      tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs                            tmpfs     3.2G  116K  3.2G   1% /run
      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
      Show mounted filesystems:
      TARGET SOURCE                           FSTYPE OPTIONS
      /      /dev/mapper/pve-vm--240--disk--0 ext4   rw,relatime,stripe=16
      /var:
      4.5G    /var/
      3.6G    /var/log/journal/4482dacb35484bddab24b914a301d279
      3.6G    /var/log
      713M    /var/cache
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      4.6G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      2.2G    /opt/iobroker/iobroker-data/
      1.6G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      39M     /opt/iobroker/iobroker-data/objects.jsonl
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      36M     /opt/iobroker/iobroker-data/states.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.1
      /usr/bin/node           v20.18.1
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.29.4
      nodejs:
        Installed: 20.18.1-1nodesource1
        Candidate: 20.19.0-1nodesource1
        Version table:
           20.19.0-1nodesource1 600
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
           20.18.3-1nodesource1 600
           20.18.2-1nodesource1 600
       *** 20.18.1-1nodesource1 600
              100 /var/lib/dpkg/status
           20.18.0-1nodesource1 600
           20.17.0-1nodesource1 600
           20.16.0-1nodesource1 600
           20.15.1-1nodesource1 600
           20.15.0-1nodesource1 600
           20.14.0-1nodesource1 600
           20.13.1-1nodesource1 600
           20.13.0-1nodesource1 600
           20.12.2-1nodesource1 600
           20.12.1-1nodesource1 600
           20.12.0-1nodesource1 600
           20.11.1-1nodesource1 600
           20.11.0-1nodesource1 600
           20.10.0-1nodesource1 600
           20.9.0-1nodesource1 600
           20.8.1-1nodesource1 600
           20.8.0-1nodesource1 600
           20.7.0-1nodesource1 600
           20.6.1-1nodesource1 600
           20.6.0-1nodesource1 600
           20.5.1-1nodesource1 600
           20.5.0-1nodesource1 600
           20.4.0-1nodesource1 600
           20.3.1-1nodesource1 600
           20.3.0-1nodesource1 600
           20.2.0-1nodesource1 600
           20.1.0-1nodesource1 600
           20.0.0-1nodesource1 600
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker-Final      iobroker-Final (version: 7.0.6, hostname: iobroker-Final, alive, uptime: 3137282)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     4
      +-- iobroker.airquality@0.1.4 (git+ssh://git@github.com/raschy/ioBroker.airquality.git#25be1740d4910797afe57688f20a55855da1dcf4)
      +-- iobroker.shelly@8.5.1 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.shelly.git#75f39ca06cd056d49ed4f51a65237aac9f9fa3c4)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#fd3b7f9f362a348741cbe18d70a130d2bfee6727)
      +-- iobroker.vw-connect@0.6.1 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#309769f6889c08b0789f21d327b98743f7147d3d)
      Adapter State
        system.adapter.accuweather.0            : accuweather           : iobroker-Final                           -  enabled
        system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.airquality.0             : airquality            : iobroker-Final                           -  enabled
        system.adapter.alarm.0                  : alarm                 : iobroker-Final                           -  enabled
        system.adapter.alias-manager.0          : alias-manager         : iobroker-Final                           - disabled
        system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
        system.adapter.bidirectional-counter.0  : bidirectional-counter : iobroker-Final                           - disabled
        system.adapter.chromecast.0             : chromecast            : iobroker-Final                           - disabled
        system.adapter.cloud.0                  : cloud                 : iobroker-Final                           - disabled
        system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
        system.adapter.device-watcher.0         : device-watcher        : iobroker-Final                           -  enabled
        system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
        system.adapter.doorbird.0               : doorbird              : iobroker-Final                           -  enabled
        system.adapter.drag-indicator.0         : drag-indicator        : iobroker-Final                           - disabled
        system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
        system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker-Final                           -  enabled
        system.adapter.eusec.0                  : eusec                 : iobroker-Final                           - disabled
        system.adapter.eventlist.0              : eventlist             : iobroker-Final                           - disabled
        system.adapter.fullcalendar.0           : fullcalendar          : iobroker-Final                           - disabled
        system.adapter.geofency.0               : geofency              : iobroker-Final                           -  enabled, port: 7999, bind: 0.0.0.0
        system.adapter.hiob.0                   : hiob                  : iobroker-Final                           - disabled, port: 8090
        system.adapter.history.0                : history               : iobroker-Final                           -  enabled
        system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
        system.adapter.hm-rega.1                : hm-rega               : iobroker-Final                           - disabled
        system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 18701
        system.adapter.hm-rpc.1                 : hm-rpc                : iobroker-Final                           -  enabled, port: 12001
        system.adapter.hm-rpc.2                 : hm-rpc                : iobroker-Final                           -  enabled, port: 12001
        system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
        system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
        system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           - disabled
        system.adapter.icons-freepic.0          : icons-freepic         : iobroker-Final                           - disabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           - disabled
        system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           - disabled
        system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker-Final                           - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
        system.adapter.info.0                   : info                  : iobroker-Final                           -  enabled
        system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
        system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
        system.adapter.klf200.0                 : klf200                : iobroker-Final                           - disabled
        system.adapter.lightcontrol.0           : lightcontrol          : iobroker-Final                           - disabled
        system.adapter.linkeddevices.0          : linkeddevices         : iobroker-Final                           - disabled
        system.adapter.modbus.0                 : modbus                : iobroker-Final                           -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker-Final                           -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
        system.adapter.net-tools.0              : net-tools             : iobroker-Final                           -  enabled
        system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
        system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
        system.adapter.notification-manager.0   : notification-manager  : iobroker-Final                           -  enabled
        system.adapter.onvif.0                  : onvif                 : iobroker-Final                           - disabled, port: 80, 7575, 8000, 8080, 8081, 8899, 888
        system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
        system.adapter.operating-hours.0        : operating-hours       : iobroker-Final                           -  enabled
        system.adapter.ping.0                   : ping                  : iobroker-Final                           - disabled
        system.adapter.places.0                 : places                : iobroker-Final                           - disabled
        system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
        system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
        system.adapter.puppeteer.0              : puppeteer             : iobroker-Final                           - disabled
        system.adapter.pushover.0               : pushover              : iobroker-Final                           -  enabled
        system.adapter.pvforecast.0             : pvforecast            : iobroker-Final                           - disabled
        system.adapter.reolink.0                : reolink               : iobroker-Final                           - disabled
        system.adapter.reolink.1                : reolink               : iobroker-Final                           - disabled
        system.adapter.reolink.2                : reolink               : iobroker-Final                           - disabled
        system.adapter.robonect.0               : robonect              : iobroker-Final                           - disabled
        system.adapter.roborock.0               : roborock              : iobroker-Final                           - disabled
        system.adapter.scenes.0                 : scenes                : iobroker-Final                           -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker-Final                           - disabled, port: 1882, bind: 192.168.7.240
        system.adapter.shelly.1                 : shelly                : iobroker-Final                           - disabled, port: 1882, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker-Final                           -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
        system.adapter.sonos.0                  : sonos                 : iobroker-Final                           - disabled
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker-Final                           -  enabled
        system.adapter.sourceanalytix.1         : sourceanalytix        : iobroker-Final                           -  enabled
        system.adapter.sql.0                    : sql                   : iobroker-Final                           -  enabled
        system.adapter.statistics.0             : statistics            : iobroker-Final                           -  enabled
        system.adapter.systeminfo.0             : systeminfo            : iobroker-Final                           -  enabled
        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
        system.adapter.telegram.0               : telegram              : iobroker-Final                           - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
        system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
        system.adapter.tuya.1                   : tuya                  : iobroker-Final                           -  enabled
        system.adapter.tuya.2                   : tuya                  : iobroker-Final                           -  enabled
        system.adapter.unifi.0                  : unifi                 : iobroker-Final                           - disabled
        system.adapter.upnp.0                   : upnp                  : iobroker-Final                           -  enabled
        system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker-Final                           -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           - disabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Final                           - disabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Final                           -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
        system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker-Final                           - disabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker-Final                           - disabled
        system.adapter.vis-map.0                : vis-map               : iobroker-Final                           - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker-Final                           -  enabled
        system.adapter.vis-metro.0              : vis-metro             : iobroker-Final                           - disabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker-Final                           -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker-Final                           - disabled
        system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
        system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
        system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           -  enabled
        system.adapter.weather-warnings.0       : weather-warnings      : iobroker-Final                           -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           -  enabled
        system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.webcal.0                 : webcal                : iobroker-Final                           -  enabled
        system.adapter.welcome.0                : welcome               : iobroker-Final                           -  enabled, port: 80, bind: 0.0.0.0, run as: admin
        system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
        system.adapter.wolf.0                   : wolf                  : iobroker-Final                           - disabled, port: 12004, bind: 192.168.7.240
        system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
        system.adapter.zigbee.0                 : zigbee                : iobroker-Final                           -  enabled, port: /dev/ttyUSB0
        system.adapter.zigbee2mqtt.0            : zigbee2mqtt           : iobroker-Final                           - disabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "accuweather"  : 2.1.0    , installed 1.5.0  [Updatable]
      Adapter    "admin"        : 7.6.3    , installed 7.4.10 [Updatable]
      Adapter    "airquality"   : 0.1.4    , installed 0.1.4
      Adapter    "alarm"        : 3.6.8    , installed 3.6.7  [Updatable]
      Adapter    "alias-manager": 2.0.0    , installed 2.0.0
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "bidirectional-counter": 2.4.0, installed 2.3.0 [Updatable]
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.2  [Updatable]
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "doorbird"     : 3.0.0    , installed 2.0.0  [Updatable]
      Adapter    "drag-indicator": 2.4.0   , installed 2.3.0  [Updatable]
      Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
      Adapter    "eusec"        : 1.3.3    , installed 1.3.3
      Adapter    "eventlist"    : 2.0.1    , installed 2.0.1
      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
      Adapter    "geofency"     : 1.2.4    , installed 1.2.4
      Adapter    "hiob"         : 0.1.6    , installed 0.1.6
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "hue"          : 3.16.1   , installed 3.13.1 [Updatable]
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-freepic": 1.0.0    , installed 1.0.0
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-smarthome": 1.0.0  , installed 1.0.0
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "klf200"       : 1.3.5    , installed 1.3.5
      Adapter    "lightcontrol" : 1.0.1    , installed 1.0.1
      Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
      Adapter    "net-tools"    : 1.0.11   , installed 1.0.11
      Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "notification-manager": 1.2.1, installed 1.2.1
      Adapter    "onvif"        : 1.1.4    , installed 1.1.4
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "operating-hours": 1.3.0  , installed 1.2.0  [Updatable]
      Adapter    "places"       : 1.2.0    , installed 1.2.0
      Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
      Adapter    "proxmox"      : 2.4.0    , installed 2.3.0  [Updatable]
      Adapter    "puppeteer"    : 0.4.0    , installed 0.4.0
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "pvforecast"   : 4.1.0    , installed 4.1.0
      Adapter    "reolink"      : 1.2.1    , installed 1.1.2  [Updatable]
      Adapter    "robonect"     : 1.4.2    , installed 1.4.2
      Adapter    "roborock"     : 0.6.18   , installed 0.6.18
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 9.2.0    , installed 8.5.1  [Updatable]
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "smartgarden"  : 2.0.1    , installed 2.0.1
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonos"        : 3.0.0    , installed 3.0.0
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "systeminfo"   : 1.2.0    , installed 1.2.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.0.0  [Updatable]
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "virtualpowermeter": 1.5.0, installed 1.5.0
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
      Adapter    "vis-material" : 0.2.0    , installed 0.2.0
      Adapter    "vis-weather"  : 2.5.11   , installed 2.5.9  [Updatable]
      Adapter    "weather-warnings": 0.7.3 , installed 0.7.3
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
      Adapter    "webcal"       : 1.3.10   , installed 1.3.10
      Adapter    "welcome"      : 1.0.2    , installed 1.0.2
      Adapter    "wolf"         : 1.7.0    , installed 1.7.0
      Adapter    "wolf-smartset": 1.2.4    , installed 1.2.4
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
      Adapter    "zigbee2mqtt"  : 3.0.2    , installed 3.0.2
      Objects and States
      Objects:        57325
      States:         45887
      Hit:1 http://security.debian.org bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 2
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          32544      328/master
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          32287      1/systemd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          32388      1/systemd
      tcp6       0      0 :::111                  :::*                    LISTEN      0          32289      1/systemd
      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          32545      328/master
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          32288      1/systemd
      udp6       0      0 :::111                  :::*                                0          32290      1/systemd
      2025-04-19 17:05:38.415  - info: host.iobroker-Final instance system.adapter.statistics.0 terminated with code 0 (NO_ERROR)
      2025-04-19 17:05:38.416  - info: host.iobroker-Final instance system.adapter.sourceanalytix.1 terminated with code 0 (NO_ERROR)
      2025-04-19 17:05:38.461  - info: host.iobroker-Final instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
      2025-04-19 17:05:38.462  - info: host.iobroker-Final instance system.adapter.hm-rpc.1 terminated with code 0 (NO_ERROR)
      2025-04-19 17:05:38.567  - info: host.iobroker-Final instance system.adapter.hm-rpc.0 terminated with code 0 (NO_ERROR)
      2025-04-19 17:05:38.567  - info: host.iobroker-Final instance system.adapter.hm-rpc.2 terminated with code 0 (NO_ERROR)
      2025-04-19 17:05:38.567  - warn: host.iobroker-Final instance system.adapter.zigbee.0 terminated due to SIGKILL
      2025-04-19 17:05:38.567  - info: host.iobroker-Final instance system.adapter.zigbee.0 terminated with code null ()
      2025-04-19 17:05:38.589  - warn: host.iobroker-Final instance system.adapter.smartgarden.0 terminated due to SIGKILL
      2025-04-19 17:05:38.589  - info: host.iobroker-Final instance system.adapter.smartgarden.0 terminated with code null ()
      2025-04-19 17:05:38.589  - warn: host.iobroker-Final instance system.adapter.weather-warnings.0 terminated due to SIGKILL
      2025-04-19 17:05:38.589  - info: host.iobroker-Final instance system.adapter.weather-warnings.0 terminated with code null ()
      2025-04-19 17:05:38.600  - warn: host.iobroker-Final instance system.adapter.web.0 terminated due to SIGKILL
      2025-04-19 17:05:38.600  - info: host.iobroker-Final instance system.adapter.web.0 terminated with code null ()
      2025-04-19 17:05:38.918  - warn: host.iobroker-Final instance system.adapter.tuya.0 terminated due to SIGKILL
      2025-04-19 17:05:38.918  - info: host.iobroker-Final instance system.adapter.tuya.0 terminated with code null ()
      2025-04-19 17:05:38.918  - warn: host.iobroker-Final instance system.adapter.tuya.1 terminated due to SIGKILL
      2025-04-19 17:05:38.918  - info: host.iobroker-Final instance system.adapter.tuya.1 terminated with code null ()
      2025-04-19 17:05:38.929  - warn: host.iobroker-Final instance system.adapter.tuya.2 terminated due to SIGKILL
      2025-04-19 17:05:38.929  - info: host.iobroker-Final instance system.adapter.tuya.2 terminated with code null ()
      2025-04-19 17:05:41.882  - info: host.iobroker-Final stopInstance timeout 10000 system.adapter.sql.0 killing pid 629
      2025-04-19 17:05:41.983  - warn: host.iobroker-Final instance system.adapter.sql.0 terminated due to SIGKILL
      2025-04-19 17:05:41.983  - info: host.iobroker-Final instance system.adapter.sql.0 terminated with code null ()
      2025-04-19 17:05:41.983  - info: host.iobroker-Final All instances are stopped.
      2025-04-19 17:05:42.186  - info: host.iobroker-Final terminated
      iob diag has finished.
      bash
                              v.2025-02-23
        Virtualization: lxc
      Installation:           lxc
      Kernel:                 x86_64
      Userland:               64 bit
      Timezone:               Europe/Berlin (CEST, +0200)
      User-ID:                1000
      Boot Target:            graphical.target
      Pending OS-Updates:     2
      Pending iob updates:    16
      Nodejs-Installation:
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      Recommended versions are nodejs 20.19.0 and npm 10.8.2
      nodeJS installation is correct
      MEMORY:
      Mem:             12G        393M         10G         65K        1.7G         12G
      Total:           21G        401M         19G
      ioBroker Core:          js-controller           7.0.6
                              admin                   7.4.10
      ioBroker Status:        iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Objects:                57325
      States:                 45887
      Size of iob-Database:
      === Mark text until here for copying ===
      Web: 7.0.8
      VIS-2: 2.9.64
      Admin: 7.6.3
      JS-Conroller: 8.8.3
      Ro75 1 Reply Last reply Reply Quote 0
      • Ro75
        Ro75 @Longbow last edited by
        @longbow sagte in VIS-2 Inventwo Bilder werde nicht angezeigt:
        Adapter "vis" : 1.5.6 , installed 1.5.6
        Installiert ist alles für VIS (1), aber oben im Bild VIS-2??
        Admin: 7.6.3
        laut iob diag
        admin:          7.4.10
        Was stimmt denn nun?
        Ro75.
        • Longbow
          @ro75
          Also laut der Adapter Übersicht habe ich Admin 7.6.3 installiert.
          Ja Vis-2, aber denke das dies das Problem ist, habe VIS1 ja noch installiert, aber genutzt. Daher denke ich das ist bei der Update auf VIS-2 mit installiert/übernommen wurden in der VIS-2.
          Gibt es in VIS 2 ein Widget das ich sagen true/false Bild so oder so dann?
          • Ro75
            Das glaube ich nicht. Ich bin eher davon überzeugt, dass in deinem System was VIS-1 und VIS-2 betrifft ordentlich quer liegt.
            Ro75.
            Longbow 1 Reply Last reply Reply Quote 0
            • Longbow
              @ro75 Kann Du mir helfen oder Tipps geben?
              • Ro75
                @longbow Da ich VIS-2 nicht einsetze, kann ich dir an dieser Stelle nicht helfen. Wie gesagt, für mich liegt hier was quer.
                Ro75.
                • Longbow
                  @ro75
                  Ja sorry, das Iob Diag war von meinem alten System.
                  bash
                  Script v.2025-02-23
                  *** BASE SYSTEM ***
                    Virtualization: lxc
                  OS is similar to:
                  Docker          : false
                  Kernel          : x86_64
                  Userland        : 64 bit
                   19:22:03 up 36 days,  9:44,  2 users,  load average: 1.12, 1.05, 1.09
                  CPU threads: 4
                  Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                 Local time: Sat 2025-04-19 19:22:03 CEST
                             Universal time: Sat 2025-04-19 17:22:03 UTC
                                   RTC time: n/a
                            RTC in local TZ: no
                  longbow
                  HOME=/home/longbow
                  GROUPS=longbow adm dialout sudo audio video plugdev users iobroker
                  iobroker
                  HOME=/home/iobroker
                  GROUPS=iobroker tty dialout audio video plugdev
                  Desktop:
                  Terminal:
                  *** MEMORY ***
                  Mem:             12G        5.1G        6.4G         61K        1.4G        7.8G
                  Swap:           8.6G        589M        8.0G
                  Total:           21G        5.7G         14G
                  Active iob-Instances:   56
                           4873 M used memory
                           2803 M active memory
                           3131 M inactive memory
                           6104 M free memory
                              0 M buffer memory
                           1309 M swap cache
                           8191 M total swap
                            562 M used swap
                           7629 M free swap
                  top - 19:22:04 up 36 days,  9:44,  2 users,  load average: 1.12, 1.05, 1.09
                  Tasks:  81 total,   2 running,  79 sleeping,   0 stopped,   0 zombie
                  %Cpu(s): 50.0 us, 50.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                  MiB Mem :  12288.0 total,   6102.5 free,   4875.6 used,   1309.9 buff/cache
                  MiB Swap:   8192.0 total,   7629.5 free,    562.5 used.   7412.4 avail Mem
                  1 loaded units listed.
                  *** FILESYSTEM ***
                  /dev/mapper/pve-vm--251--disk--0 ext4       98G   11G   83G  11% /
                  tmpfs                            tmpfs     3.2G  108K  3.2G   1% /run
                  /      /dev/mapper/pve-vm--251--disk--0 ext4   rw,relatime,stripe=16
                  /var:
                  464M    /var/
                  249M    /var/cache
                  245M    /var/cache/apt
                  170M    /var/cache/apt/archives
                  147M    /var/lib
                  Archived and active journals take up 66.8M in the file system.
                  477M    /opt/iobroker/backups/
                  1.8G    /opt/iobroker/iobroker-data/
                  1.5G    /opt/iobroker/iobroker-data/files
                  30M     /opt/iobroker/iobroker-data/states.jsonl
                  28M     /opt/iobroker/iobroker-data/objects.jsonl
                  24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
                  USB-Devices by-id:
                  zigbee.X
                  Extended Pan ID:
                  *** MASKED ***
                  Pan ID:
                  *** MASKED ***
                  Channel:
                  *** MASKED ***
                  Network Key:
                  *** MASKED ***
                  /usr/bin/nodejs         v20.18.2
                  /usr/bin/node           v20.18.2
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  nodejs:
                    Installed: 20.18.2-1nodesource1
                    Candidate: 20.18.2-1nodesource1
                    Version table:
                   *** 20.18.2-1nodesource1 1001
                       20.18.1-1nodesource1 1001
                       20.18.0-1nodesource1 1001
                       20.17.0-1nodesource1 1001
                       20.16.0-1nodesource1 1001
                       20.15.1-1nodesource1 1001
                       20.15.0-1nodesource1 1001
                       20.14.0-1nodesource1 1001
                       20.13.1-1nodesource1 1001
                       20.13.0-1nodesource1 1001
                       20.12.2-1nodesource1 1001
                       20.12.1-1nodesource1 1001
                       20.12.0-1nodesource1 1001
                       20.11.1-1nodesource1 1001
                       20.11.0-1nodesource1 1001
                       20.10.0-1nodesource1 1001
                       20.9.0-1nodesource1 1001
                       20.8.1-1nodesource1 1001
                       20.8.0-1nodesource1 1001
                       20.7.0-1nodesource1 1001
                       20.6.1-1nodesource1 1001
                       20.6.0-1nodesource1 1001
                       20.5.1-1nodesource1 1001
                       20.5.0-1nodesource1 1001
                       20.4.0-1nodesource1 1001
                       20.3.1-1nodesource1 1001
                       20.3.0-1nodesource1 1001
                       20.2.0-1nodesource1 1001
                       20.1.0-1nodesource1 1001
                       20.0.0-1nodesource1 1001
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  Hosts:
                  iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 3145460)
                  admin:          7.6.3
                  javascript:     8.8.3
                  nodejs modules from github:     9
                  +-- iobroker.admin-mono@ (git+ssh://git@github.com/ioBroker/ioBroker.admin.git#7e5105aa55efa26cd86e055a5b5f2397d1709f7c)
                  +-- iobroker.airquality@0.1.4 (git+ssh://git@github.com/raschy/ioBroker.airquality.git#85cb93370312cece68403b1fcdc2a2b3143643f5)
                  +-- iobroker.navimow@0.0.1 (git+ssh://git@github.com/TA2k/ioBroker.navimow.git#f92d4950c454a421747bdab62a34a157f6cf508f)
                  +-- iobroker.smartthings@0.2.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#ae0bab043d7ad2d3b46d8224b9e51f8feb0dc529)
                  +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
                  | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
                  +-- iobroker.vis-2-widgets-collection@1.7.7 (git+ssh://git@github.com/Steiger04/ioBroker.vis-2-widgets-collection.git#e9300fb723bb0166ce3c9ea5cbfd9c5c0681fca3)
                  +-- iobroker.vis-2-widgets-inventwo@0.1.12 (git+ssh://git@github.com/inventwo/ioBroker.vis-2-widgets-inventwo.git#8dc2430ac2f6df5717d7613b7c43a067493e5866)
                  +-- iobroker.vw-connect@0.7.9 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#2016fd566615d92168d20afae1794f237209e569)
                  Adapter State
                  + system.adapter.accuweather.0            : accuweather           : iobroker                                 -  enabled
                  + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    system.adapter.airquality.0             : airquality            : iobroker                                 -  enabled
                  + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
                  + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                    system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                  + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                  + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  + system.adapter.doorbird.0               : doorbird              : iobroker                                 -  enabled
                    system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                    system.adapter.email.0                  : email                 : iobroker                                 - disabled
                  + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: iobroker                                 -  enabled
                  + system.adapter.energiefluss-erweitert.1 : energiefluss-erweitert: iobroker                                 -  enabled
                    system.adapter.eusec.0                  : eusec                 : iobroker                                 - disabled
                    system.adapter.eventlist.0              : eventlist             : iobroker                                 - disabled
                    system.adapter.flexcharts.0             : flexcharts            : iobroker                                 -  enabled
                  + system.adapter.history.0                : history               : iobroker                                 -  enabled
                  + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                  + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 18701
                  + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
                  + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                    system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                    system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 -  enabled
                    system.adapter.icons-eclipse-smarthome-classic.0: icons-eclipse-smarthome-classic: iobroker                                 -  enabled
                    system.adapter.icons-freepic.0          : icons-freepic         : iobroker                                 -  enabled
                    system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 -  enabled
                    system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 -  enabled
                    system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 -  enabled
                    system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 -  enabled
                    system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                    system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 -  enabled
                    system.adapter.icons-smarthome.0        : icons-smarthome       : iobroker                                 -  enabled
                    system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 -  enabled
                  + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                    system.adapter.iot.0                    : iot                   : iobroker                                 - disabled
                  + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                    system.adapter.klf200.0                 : klf200                : iobroker                                 -  enabled
                  + system.adapter.linkeddevices.0          : linkeddevices         : iobroker                                 -  enabled
                    system.adapter.luftdaten.0              : luftdaten             : iobroker                                 -  enabled
                    system.adapter.maveo.0                  : maveo                 : iobroker                                 - disabled
                  + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                    system.adapter.modbus.1                 : modbus                : iobroker                                 - disabled
                  + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                  + system.adapter.myenergi.0               : myenergi              : iobroker                                 -  enabled
                  + system.adapter.navimow.0                : navimow               : iobroker                                 -  enabled
                  + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                  + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                  + system.adapter.notification-manager.0   : notification-manager  : iobroker                                 -  enabled
                    system.adapter.onvif.0                  : onvif                 : iobroker                                 - disabled
                    system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                  + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                  + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                  + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                  + system.adapter.pvforecast.0             : pvforecast            : iobroker                                 -  enabled
                  + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                  + system.adapter.reolink.1                : reolink               : iobroker                                 -  enabled
                  + system.adapter.reolink.2                : reolink               : iobroker                                 -  enabled
                    system.adapter.roborock.0               : roborock              : iobroker                                 - disabled
                  + system.adapter.samsung_tizen.0          : samsung_tizen         : iobroker                                 -  enabled, port: 8002
                  + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                  + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 192.168.7.251
                  + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                  + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                  + system.adapter.smartgarden.0            : smartgarden           : iobroker                                 -  enabled
                    system.adapter.smartthings.0            : smartthings           : iobroker                                 - disabled
                    system.adapter.sonos.0                  : sonos                 : iobroker                                 - disabled
                  + system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
                  + system.adapter.statistics.0             : statistics            : iobroker                                 -  enabled
                  + system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
                  + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                  + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                  + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                  + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                  + system.adapter.tuya.1                   : tuya                  : iobroker                                 -  enabled
                  + system.adapter.tuya.2                   : tuya                  : iobroker                                 -  enabled
                    system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
                    system.adapter.upnp.0                   : upnp                  : iobroker                                 - disabled
                    system.adapter.vis-2-widgets-collection.0: vis-2-widgets-collection: iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-ovarious.0 : vis-2-widgets-ovarious: iobroker                                 -  enabled
                    system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker                                 -  enabled
                  + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                    system.adapter.vis-bars.0               : vis-bars              : iobroker                                 -  enabled
                    system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 -  enabled
                    system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 -  enabled
                    system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 -  enabled
                    system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
                    system.adapter.vis-history.0            : vis-history           : iobroker                                 -  enabled
                    system.adapter.vis-homekittiles.0       : vis-homekittiles      : iobroker                                 -  enabled
                    system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 -  enabled
                    system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                  + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                    system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
                    system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                    system.adapter.vis-map.0                : vis-map               : iobroker                                 -  enabled
                    system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                    system.adapter.vis-material.0           : vis-material          : iobroker                                 -  enabled
                    system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                    system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 -  enabled
                    system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
                    system.adapter.vis-weather.0            : vis-weather           : iobroker                                 -  enabled
                    system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
                  + system.adapter.vw-connect.1             : vw-connect            : iobroker                                 -  enabled
                  + system.adapter.weather-warnings.0       : weather-warnings      : iobroker                                 -  enabled
                    system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                  + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                  + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker                                 -  enabled
                  + system.adapter.wolf.0                   : wolf                  : iobroker                                 -  enabled, port: 12004, bind: 192.168.7.251
                  + instance is alive
                  Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                  Adapter    "admin"        : 7.6.3    , installed 7.6.3
                  Adapter    "alarm"        : 3.6.8    , installed 3.6.8
                  Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                  Adapter    "doorbird"     : 3.0.0    , installed 3.0.0
                  Adapter    "email"        : 2.0.3    , installed 2.0.3
                  Adapter    "flexcharts"   : 0.4.0    , installed 0.4.0
                  Adapter    "hue"          : 3.16.1   , installed 3.16.1
                  Adapter    "icons-eclipse-smarthome-classic": 1.0.0, installed 1.0.0
                  Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
                  Adapter    "maveo"        : 0.0.5    , installed 0.0.5
                  Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                  Adapter    "reolink"      : 1.2.1    , installed 1.2.1
                  Adapter    "samsung_tizen": 1.1.0    , installed 1.1.0
                  Adapter    "shelly"       : 9.2.0    , installed 9.2.0
                  Adapter    "synology"     : 3.1.0    , installed 3.1.0
                  Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                  Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
                  Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                  Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
                  Adapter    "vis-2-widgets-inventwo": 0.1.11, installed 0.1.12
                  Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
                  Adapter    "vis-2-widgets-ovarious": 0.1.9, installed 0.1.9
                  Adapter    "vis-2-widgets-weather-and-heating": 0.10.0, installed 0.10.0
                  Adapter    "vis-homekittiles": 0.4.6 , installed 0.4.6
                  Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                  Objects and States
                  Objects:        37120
                  States:         31477
                  Hit:2 http://security.debian.org bookworm-security InRelease
                  Pending Updates: 41
                  tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          37659      1/init
                  tcp        0      0 192.168.7.251:8100      0.0.0.0:*               LISTEN      1001       810318221  425521/io.doorbird.
                  tcp        0      0 192.168.7.251:1882      0.0.0.0:*               LISTEN      1001       781068899  414140/io.shelly.0
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       39411      130/iobroker.js-con
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       38352      130/iobroker.js-con
                  tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          39286      294/master
                  tcp        0      0 192.168.7.251:18701     0.0.0.0:*               LISTEN      1001       409388958  271040/io.hm-rpc.0
                  tcp        0      0 192.168.7.251:12004     0.0.0.0:*               LISTEN      1001       106763316  113906/io.wolf.0
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          38104      1/init
                  tcp6       0      0 :::111                  :::*                    LISTEN      0          37661      1/init
                  tcp6       0      0 ::1:25                  :::*                    LISTEN      0          39287      294/master
                  tcp6       0      0 :::8087                 :::*                    LISTEN      1001       73172      1850/io.simple-api.
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       811192732  427222/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       674400133  375121/io.web.0
                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       781067127  414129/io.shelly.1
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       50817      943/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       50818      943/io.tuya.0
                  udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          37660      1/init
                  udp6       0      0 :::111                  :::*                                0          37662      1/init
                  2025-04-19 19:15:24.161  - info: dwd.0 (428824) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.6
                  2025-04-19 19:15:24.683  - info: dwd.0 (428824) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-04-19 19:15:25.203  - info: host.iobroker instance system.adapter.dwd.0 having pid 428824 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-04-19 19:15:56.023  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 428839
                  2025-04-19 19:15:58.171  - info: daswetter.0 (428839) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.6
                  2025-04-19 19:16:03.143  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:16:07.280  - info: daswetter.0 (428839) still wrong data structure from server received! repaired...
                  2025-04-19 19:16:09.673  - info: daswetter.0 (428839) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
                  2025-04-19 19:16:10.180  - info: daswetter.0 (428839) cleaned everything up...
                  2025-04-19 19:16:10.197  - info: host.iobroker instance system.adapter.daswetter.0 having pid 428839 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-04-19 19:17:02.914  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:18:03.040  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:19:03.383  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:20:03.068  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:20:05.930  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Der Energieertrag der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:20:08.893  - info: javascript.0 (346059) script.js.common.PV-Anlage.Sonnenstand: Script Sonnenstand; Erfolgreich gelaufen, Werte akzeptiert
                  2025-04-19 19:20:22.026  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 428948
                  2025-04-19 19:20:24.500  - info: dwd.0 (428948) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.6
                  2025-04-19 19:20:24.978  - info: dwd.0 (428948) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2025-04-19 19:20:25.493  - info: host.iobroker instance system.adapter.dwd.0 having pid 428948 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2025-04-19 19:21:03.209  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  2025-04-19 19:21:54.353  - info: admin.0 (427222) Request actual repository...
                  2025-04-19 19:21:54.709  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                  2025-04-19 19:21:59.483  - info: admin.0 (427222) Repository received successfully.
                  2025-04-19 19:22:03.029  - info: javascript.0 (346059) script.js.common.Scripte.SolarEdge.SolarEdge_Scripte_gross: Die aktuelle Lesitung der Anlage "2712611" wird verarbeitet.
                  bash
                                          v.2025-02-23
                    Virtualization: lxc
                  Installation:           lxc
                  Kernel:                 x86_64
                  Userland:               64 bit
                  User-ID:                1000
                  Pending OS-Updates:     41
                  Pending iob updates:    0
                  /usr/bin/npm            10.8.2
                  /usr/bin/npx            10.8.2
                  MEMORY:
                  Mem:             12G        4.3G        7.0G         61K        1.6G        8.5G
                  Total:           21G        4.9G         14G
                                          admin                   7.6.3
                  Objects type: jsonl
                  States  type: jsonl
                  Objects:                37120
                  States:                 31477
                  33M     /opt/iobroker/iobroker-data/objects.jsonl
                  33M     /opt/iobroker/iobroker-data/states.jsonl
                    sigi234 Forum Testing Most Active @Longbow last edited by sigi234
                    @longbow
                    Hast du ein neues Projekt für Vis2 erstellt,oder es von Vis1 importiert?
                    https://forum.iobroker.net/topic/74773/vis-vis-2-übersicht-widgetkompatibilität/2?_=1745102755925#
                    • Longbow
                      Longbow @sigi234 last edited by
                      @sigi234
                      Guten Morgen
                      Nein meines Projekt begonnen.
                      Gibt es keine Alternative oder wodran kann es liegen?
                      Frohe Ostern
                        @sigi234
                        Guten Morgen
                        Frohe Ostern
                        Danke, ebenfalls.
                        Eventuell mal die Betaversion von Vis2 installieren?
                        Wenn du ein Testsystem hast und dein System gesichert ist.
                        • Longbow
                          @sigi234
                          Wie meinst du das mit Beta Vis-2? Hab VIS2 installiert.
                            @longbow
                            Hast du die Inventwo Widgets auch als Vis2 Version installiert?
                              • Longbow
                                Longbow @sigi234 last edited by Longbow
                                @sigi234 Bei mir heiß es nur vis-inventwo hab es gerade gelöscht und auch wieder neu installiert.
                                Hab die gleiche Versionsnummer wie Du, aber es geht nicht....
                                Hab auf dem Proxmox Server ein neue Version von Iobroker installiert. Und VIS-2 vom Hause gleich mit.
                                Das gleich spiel, also wie geht es euch mit dem Adapter Inventwo Widget? Zeigt bei Euch das Bild an?
                                Es muss ein Fehler mit Bildern sein, die man haben möchte, denn Symbole gehen 😞
                                • Ro75
                                  Ro75 @Longbow last edited by Ro75
                                  @longbow schon mal bmp oder jpeg Dateien versucht? Oder auch svg?
                                  Ro75.
                                  • Longbow
                                    @ro75 Danke für den Hinweis. War gerade dabei da zu probieren, aber es bringt auch kein erfolg.
                                    • Ro75
                                      @longbow funktionieren diese Dateien in Verbindung mit anderen Widget?
                                      Ro75.
                                      • Longbow
                                        @ro75 Ja das geht. kann Sie auch einfach als Bild, oder so anzeigen lassen.
                                        • Ro75
                                          @longbow dann würde ich an deiner Stelle das auf Github mal als Fehler melden.
                                          Ro75.
                                          • Longbow
                                            @ro75 werde ich wohl machen, muss nur sehen wie das man das macht. Was mann da alles angeben muss. Aber was mich interessiert würde, ob ich er einzige bin der das Problem hat und es erst einmal kein Alternative Widget gibt, ob man ein rote und grünen Punkte auf Grund es Zustand anzeigen lassen kann in VIS.2
                                            1794
