    4. Backup von InfluxDB scheitert [gelöst]
      Thomas Braun Most Active @legro last edited by Thomas Braun
      @legro sagte in Backup von InfluxDB scheitert:
      Meinst du dieses Komma nach dem Passwort und vor //192.168.4.1.. ?
      Natürlich.
      Optionen werden mit Komma getrennt, Quelle und Ziel per Leerzeichen.
      Manuell gemountet schaut das in meinem System dann exakt so aus:
      echad@chet:~ $ ls -la /opt/iobroker/backups/
      total 8
      drwxrwxr-x+ 2 iobroker iobroker 4096 Feb  3 17:23 .
      drwxrwxr-x+ 6 iobroker iobroker 4096 Feb 24 17:09 ..
      echad@chet:~ $ sudo mount -t cifs -o credentials=/home/iobroker/.smbcredentials,users,noserverino,noauto,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0770,dir_mode=0770,vers=3.1.1 //192.168.178.1/FRITZ.NAS/Hitachi-HTS545012B9SA00-01/iobbackups/chet /opt/iobroker/backups
      total 3723612
      drwxrwx---  2 iobroker iobroker         0 Apr 20 03:45 .
      -rwxrwx---  1 iobroker iobroker   8655225 Apr 11 03:43 historyDB_2025_04_11-03_43_50_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker   8670718 Apr 12 03:43 historyDB_2025_04_12-03_43_51_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker   8681214 Apr 13 03:43 historyDB_2025_04_13-03_43_51_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker   8686182 Apr 14 03:43 historyDB_2025_04_14-03_43_51_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker  10739821 Apr 15 03:43 historyDB_2025_04_15-03_43_51_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker  10783462 Apr 16 03:43 historyDB_2025_04_16-03_43_51_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker  10836132 Apr 17 03:43 historyDB_2025_04_17-03_43_52_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker  10912480 Apr 18 03:43 historyDB_2025_04_18-03_43_52_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker  10976863 Apr 19 03:43 historyDB_2025_04_19-03_43_51_chet_backupiobroker.tar.gz
      -rwxrwx---  1 iobroker iobroker  10938976 Apr 20 03:43 historyDB_2025_04_20-03_43_50_chet_backupiobroker.tar.gz
      Das ganze auf einer FritzBox 6660 mit FRITZ!OS: 8.03
      • Ro75
        Ro75 last edited by
        @legro Mit Verbindungstyp "CIFS" oder "Experte" funktionierte das bei mir auch nicht, betraf nicht nur InfluxDB - sondern ALLES. Obwohl alle Einstellungen, Parameter, Werte korrekt waren, funktionierte es nicht. Manuell mounten ging, aber via Backitup-Adapter - nein. Entweder ging kein mount oder wenn dann doch, ging am Ende kein unmount.
        Ich habe viel versucht, am Ende habe ich das ganze in die fstab gepackt und das läuft ohne Probleme zu 100%. Damit läuft es quasi "lokal", wird aber auf dem NAS abgelegt - so wie ich es haben möchte.
        Ro75.
          Thomas Braun Most Active @Ro75 last edited by
          @ro75 sagte in Backup von InfluxDB scheitert:
          Ich mounte das ja auch über die fstab. Dürfen dann wegen der Option users halt auch einfache user mounten und den Befehl mount /opt/iobroker/backups hab ich in den Experten-Optionen drin. Funktioniert 1a bei mir.
            legro @Thomas Braun last edited by legro
            Du hattest recht, es war das besagte Komma. Aber ich frage mich, wie sollte ich das als Laie in Sachen Linux alles wissen?😕
            pi@raspiBullseye:~ $ sudo mount -t cifs -o username=ioBroker,password='<Passwort>' //192.168.4.1/SanDisk /mnt/share
            pi@raspiBullseye:~ $ ls /mnt/share -a
            .  ..  Bilder  Dokumente  ._.DS_Store  .DS_Store  FRITZ  Musik  SanDisk  Videos
            Erst letzte Woche habe ich stundenlang versucht, unseren SAT-Receiver (VU+ DUO 4K SE) mit unserer neuen Synology 923+ zu verbinden. Es wollte - genau so wie hier mit BackItUp - einfach nicht gelingen, obwohl über Windows MacOS und auch iOS alles bestens funktionierte. Am Ende stellte sich heraus, dass der Receiver von Haus aus bloß SMB 1 unterstützt; dabei kann er durchaus auch SMB 2.0, nur muss man das bei der Konfiguration angeben: rw,vers=2.0 - also ganz wie im Mount-String von BackItUp.
            @Ro75
            Was du da schilderst, hört sich für mich gar nicht gut an. Da fühle ich mich schlichtweg überfordert. Wäre es nicht an @simatec sich das einmal anzuschauen? Er wird gewiss für Abhilfe sorgen können; schließlich hat zuvor doch alles jahrelang funktioniert.
            Vielen Dank allen für die tolle Unterstützung.👍
            Da habe ich wieder ganz schön etwas dazulernen können und müssen.
            simatec Thomas Braun Homoran 3 Replies Last reply Reply Quote 0
            • simatec
              simatec Developer Most Active @legro last edited by simatec
              @legro Mir ist aktuell nichts bekannt, dass es mit dem Standard mount Probleme mit der Fritzbox gibt.
              Wenn es irgendwelche Probleme oder Änderungen gibt, gerne ein Issue aufmachen
                In dem man das nachliest und sich damit beschäftigt. Eine plötzliche Eingebung gibt es da nicht.
                Die Dokumentation ist doch sehr gut, insbesondere bei solchen Grundfunktionen.
                  Homoran Global Moderator Administrators @legro last edited by Homoran
                  @legro Wie genau ist denn die Bezeichnung der Freigabe auf der Fritzbox?
                  Bitte zeigen
                  Hab ich nirgendwo finden können.
                    legro @simatec last edited by
                    @simatec sagte in Backup von InfluxDB scheitert:
                    So ganz verstehe ich dich jetzt nicht. Ist nicht all das, was ich hier in diesem Thread beschrieben habe, ausreichend? Aufgrund meiner bescheidenen Kenntnisse in Sachen Linux kann ich wohl kaum mehr dazu beitragen. Meine Vermutung ist nach wie vor, dass das Ganze mit dem Update der Fritz!Box zusammenhängen vermag, schließlich hat dein BackItUp bei mir über Jahre einwandfrei funktioniert.
                    Der von dir in BackItUp verwendete Mount-Befehl will bei mir nicht mehr funktionieren - warum auch immer. Den Rat von @Thomas-Braun befolgend, habe ich mit einem stark abgespeckten Mount eine Verbindung aufbauen können.
                      Deswegen sollst du das ja auch von Hand mounten und mit den diversen Optionen herumspielen.
                        warum auch immer.
                        um das herauszufinden ist leider nicht
                        Da sind so viele Fragen unbeantwortet
                          legro @Homoran last edited by legro
                          @homoran sagte in Backup von InfluxDB scheitert:
                          Bitte zeigen
                          In diesem Beitrag steht doch der verwendete Mount, der schließlich auch funktioniert. .🙂
                            @legro Das ständige Springen zwische verschiedenen Dingen hilft doch auch nicht!
                            Es geht doch um den mount mit drm
                            hat.
                              @thomas-braun sagte in Backup von InfluxDB scheitert:
                              Hab ich doch!☺
                              Apropos nachlesen. Ich habe dann wohl stets die falschen Quellen erwischt.😉
                                Welches hast du denn erwischt?
                                man-pages? Ubuntu Wiki? Ein Buch wie z. B. den 'Kofler'?
                                  Jetzt fügst du Optionen hinzu und schaust mit welcher das mounten nicht mehr funktioniert.
                                    @thomas-braun wenn ich das richtig sehe hat er ein Verzeichnis /mnt/share auf dem ioBroker angelegt.
                                    (wobei mir diese Benennung nicht geheuer ist)
                                    Von dem mountpunkt scheint er auf die den Backups übergeordnete Struktur auf der Fritte zu kommen.
                                    für mich gibt es jetzt zwei Möglichkeiten.
                                    • die weitere Struktur hst falsche Rechte
                                    • der Standard Mountpunkt /opt/iobroker/backups ist nicht leer
                                      Den von dir gewünschten Mount habe ich im Laufe dieses Thread bereits mehrfach angegeben. Hier also nochmals der zuvor funktionierende Befehl ..
                                      "sudo mount -t cifs -o username=ioBroker,password=****,noserverino,cache=loose,rw,forceuid,uid=iobroker,forcegid,gid=iobroker,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.4.1/fritz.nas/SanDisk/SmartHomeBackup/ioBroker /opt/iobroker/backups"
                                      Nun werde ich @Thomas-Braun Rat nachgehen und Option für Option hinzufügen, bis es klemmt.
                                        @thomas-braun wenn ich das richtig sehe ..
                                        Siehst du nicht! 😉 Ich arbeite auf einem Raspberry Pi 4 über das Terminal via SSH von meinem MacBook.
                                          und?
                                          was ist damit anders als was ich schrieb?
                                          • simatec
                                            Und genau so erstellt Backitup den mount, wenn du alles richtig in der Config von Backitup hast.
                                            Genau aus dem Grund sage ich auch, dass es nicht an Backitup liegt
                                            3842
