    3. Einsteigerfragen
    4. Automatisierung
    5. [gelöst] Log-Einträge nach Umzug doppelt vorhanden
    • Siggi0904
      Siggi0904 last edited by Homoran
      Hier auch noch der Output von iob diag in Lang
      Script v.2025-02-23
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-33-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _i440FX + PIIX, 1996_
      Firmware Version: rel-1.16.3-0-ga6ed6b701f0a-prebuilt.qemu.org
      OS is similar to:
      model name      : QEMU Virtual CPU version 2.5+
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       18:35:10 up 9 days,  2:00,  2 users,  load average: 0.05, 0.09, 0.08
      CPU threads: 2
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Mon 2025-04-21 18:35:10 CEST
                 Universal time: Mon 2025-04-21 16:35:10 UTC
                       RTC time: Mon 2025-04-21 16:35:10
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      mario
      HOME=/home/mario
      GROUPS=mario cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            8.3G        3.0G        906M        520K        4.7G        5.3G
      Swap:           1.0G        536K        1.0G
      Total:          9.3G        3.0G        1.9G
      Active iob-Instances:   29
               7941 M total memory
               2872 M used memory
                756 M active memory
               5833 M inactive memory
                864 M free memory
                346 M buffer memory
               4172 M swap cache
                974 M total swap
                  0 M used swap
                974 M free swap
      top - 18:35:10 up 9 days,  2:00,  2 users,  load average: 0.05, 0.09, 0.08
      Tasks: 126 total,   1 running, 125 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   7941.2 total,    863.2 free,   2873.6 used,   4519.0 buff/cache
      MiB Swap:    975.0 total,    974.5 free,      0.5 used.   5067.5 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  3.9G     0  3.9G   0% /dev
      tmpfs          tmpfs     795M  520K  794M   1% /run
      /dev/sda1      ext4       48G  5.7G   40G  13% /
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     795M     0  795M   0% /run/user/1000
      [Sat Apr 12 16:34:42 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Quota mode: none.
      [Sat Apr 12 16:34:42 2025] EXT4-fs (sda1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE    FSTYPE OPTIONS
      /      /dev/sda1 ext4   rw,relatime,errors=remount-ro
      /var:
      463M    /var/
      248M    /var/cache
      241M    /var/cache/apt
      175M    /var/lib
      165M    /var/cache/apt/archives
      Archived and active journals take up 8.0M in the file system.
      /opt/iobroker/backups:
      12M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1015M   /opt/iobroker/iobroker-data/
      854M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      34M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      11M     /opt/iobroker/iobroker-data/states.jsonl
      USB-Devices by-id:
      No Devices found 'by-id'
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.0-1nodesource1
        Candidate: 20.19.0-1nodesource1
        Version table:
       *** 20.19.0-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 783228)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
      + system.adapter.alexa-timer-vis.0        : alexa-timer-vis       : iobroker                                 -  enabled
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.awtrix-light.0           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.awtrix-light.1           : awtrix-light          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
      + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 8083
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
      + system.adapter.heatingcontrol.0         : heatingcontrol        : iobroker                                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
        system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3307
      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "alarm"        : 3.6.8    , installed 3.6.8
      Adapter    "alexa-timer-vis": 2.0.8  , installed 2.0.8
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "awtrix-light" : 1.4.1    , installed 1.4.1
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "deconz"       : 1.6.4    , installed 1.6.4
      Adapter    "email"        : 2.0.3    , installed 2.0.3
      Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
      Adapter    "heatingcontrol": 2.12.14 , installed 2.12.14
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 9.2.0    , installed 9.2.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Objects and States
      Objects:        10833
      States:         8896
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 192.168.178.64:2010     0.0.0.0:*               LISTEN      1001       956695     71926/io.hm-rpc.0
      tcp        0      0 192.168.178.64:2001     0.0.0.0:*               LISTEN      1001       955877     71909/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       63839      14657/io.sonoff.0
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          12174      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15585      507/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       58574      12686/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       58569      12686/iobroker.js-c
      tcp6       0      0 :::111                  :::*                    LISTEN      0          12176      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15596      507/sshd: /usr/sbin
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       64657      14817/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       58673      12715/io.admin.0
      udp        0      0 0.0.0.0:54816           0.0.0.0:*                           1001       68840      15381/io.javascript
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       63851      14668/io.shelly.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       173491     22040/io.deconz.0
      udp        0      0 0.0.0.0:35968           0.0.0.0:*                           1001       3268751    15381/io.javascript
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13996      372/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12175      1/init
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       66404      15198/io.mihome-vac
      udp        0      0 192.168.178.64:5353     0.0.0.0:*                           1001       64601      14758/io.tr-064.0
      udp6       0      0 :::1900                 :::*                                1001       173494     22040/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       173493     22040/io.deconz.0
      udp6       0      0 :::1900                 :::*                                1001       173492     22040/io.deconz.0
      udp6       0      0 :::111                  :::*                                0          12177      1/init
      2025-04-21 18:30:00.017  - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
      2025-04-21 18:30:00.020  - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
      2025-04-21 18:30:00.027  - info: javascript.0 (15381) script.js.Skripte.Wohnung.VerbrauchTasmota: Tasmota Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 6
      2025-04-21 18:30:00.043  - info: javascript.0 (15381) script.js.Skripte.Wohnung.VerbrauchShelly: Shelly Verbrauch: Verbrauchswerte aktualisiert: 0 | Reboots korrigiert: 0 | Unveränderte Werte: 1
      2025-04-21 18:30:00.072  - info: javascript.0 (15381) script.js.Skripte.Außen.AstroDaten: Astro: Gültige Zeiten: [aktueller Tag: 7] | [nächster Tag: 7] | [Aktualisiert: 0] | Aktuelle Tageszeit: Mittag | Kommende Tageszeit: früher Abend
      2025-04-21 18:30:00.147  - warn: alexa2.0 (568128) Smart Home device request blocked for ...entfernt....p_wg_f730P
      2025-04-21 18:30:00.931  - info: ical.0 (630427) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.0, js-controller: 7.0.6
      2025-04-21 18:30:01.511  - info: ical.0 (630427) processing URL: Müllkalender https://....entfernt....
      2025-04-21 18:30:01.556  - info: ical.0 (630427) processing URL: Urlaub ....entfernt....269fb571a/basic.ics
      2025-04-21 18:30:01.585  - info: ical.0 (630427) processing URL: Schichtplan-Roland https://calendar.google.com/calendar/ical/...entfernt...2/basic.ics
      2025-04-21 18:30:04.019  - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.3" started with pid 630445
      2025-04-21 18:30:04.830  - info: daswetter.0 (630445) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.0, js-controller: 7.0.6
      2025-04-21 18:30:06.596  - info: daswetter.0 (630445) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-04-21 18:30:06.636  - info: ical.0 (630427) Terminated (NO_ERROR): Without reason
      2025-04-21 18:30:07.101  - info: daswetter.0 (630445) cleaned everything up...
      2025-04-21 18:30:07.109  - info: host.iobroker instance system.adapter.daswetter.0 having pid 630445 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-21 18:30:07.149  - info: host.iobroker instance system.adapter.ical.0 having pid 630427 terminated with code 0 (NO_ERROR)
      2025-04-21 18:30:08.027  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 630462
      2025-04-21 18:30:08.882  - info: dwd.0 (630462) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.0, js-controller: 7.0.6
      2025-04-21 18:30:09.143  - info: dwd.0 (630462) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-21 18:30:09.654  - info: host.iobroker instance system.adapter.dwd.0 having pid 630462 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-04-21 18:35:06.009  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 630820
      2025-04-21 18:35:06.856  - info: dwd.0 (630820) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.19.0, js-controller: 7.0.6
      2025-04-21 18:35:07.127  - info: dwd.0 (630820) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-04-21 18:35:07.640  - info: host.iobroker instance system.adapter.dwd.0 having pid 630820 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      MOD-EDIT: private Daten entfernt!
        Homoran Global Moderator Administrators @Siggi0904 last edited by
        @siggi0904 sagte in Log-Einträge nach Umzug doppelt vorhanden:
        alle Einträge im LOG doppelt vorhanden, was die Hardware angeht.
        was meinst du damit?
                                2025-04-21 17:48:48.533 - info: javascript.0 (15381) script.js.Skripte.Wohnung.AnwesenheitTaster: Taster Anwesenheit kurz betätigt, Du bist Anwesend, schönen Tag.Schauriger Ekelklopper
        Das stammt von einem Skript
        Siggi0904 1 Reply Last reply Reply Quote 0
        • Siggi0904
          Siggi0904 @Homoran last edited by
          naja, irgendwie werden alle Scripte, die aufgrund eines Tasters, HMIP etc. kommen doppelt angezeigt.
          Ja, das kommt von einem Script, wie du auc im Log siehst, wird das gleich ein paar 100erstel später nochmal ausgeführt. Gleiches beim Script:
          2025-04-21 18:00:00.021 - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
          2025-04-21 18:00:00.023 - info: javascript.0 (15381) script.js.Skripte.Wohnzimmer.Luftqualität: Daten des Alexa-Luftqualitätsmonitors aktualisiert.
          wendy2702 Homoran 2 Replies Last reply Reply Quote 0
          • wendy2702
            wendy2702 @Siggi0904 last edited by
            @siggi0904 was triggert denn dein Skript?
            • Siggi0904
              Siggi0904 @wendy2702 last edited by
              @wendy2702 beim ersten script ein Taster. bei der Luftqualität ein Blockly mit Cron:
                <block type="comment" id="Uo8V0{:s:8nOJxIuEvw=" x="113" y="113">
                  <field name="COMMENT">Alexa Luftqualitätsmonitor updaten</field>
                    <block type="schedule" id="]W|DEXl(RwWEZ*+2Y=/3">
                      <field name="SCHEDULE">{"time":{"start":"00:00","end":"23:59","mode":"minutes","interval":15},"period":{"days":1}}</field>
                        <block type="comment" id="PB^%imT.@!r$JTct(^g`">
                          <field name="COMMENT">Daten neu einlesen</field>
                            <block type="toggle" id="ud~++Vw/;41!9,BD%@/d">
                              <field name="OID">alexa2.0.Smart-Home-Devices.771e6d85-a93c-48de-9a0a-21783668fe6a.#query</field>
                                <block type="comment" id="^-q,|pRBjF]1nFj!SAxZ">
                                  <field name="COMMENT">Log schreiben</field>
                                    <block type="debug" id="/S1+)X9,uAe:]YVVxS=+">
                                      <field name="Severity">info</field>
                                      <value name="TEXT">
                                        <shadow type="text" id="f!ffcmbF4BbA9W-i92wH">
                                          <field name="TEXT">Daten des Alexa-Luftqualitätsmonitors aktualisiert.</field>
                @siggi0904 dann wird wahrscheinlich nicht das log gedoppelt, sondern das Skript.
                Bitte die Ursache suchen, nicht das Ergebnis 😉
                • Siggi0904
                  @homoran es hat ja vor dem Neu aufstetzen alles funktioniert und ich habe an den Scripten nichts geändert.
                  • wendy2702
                    Ist Ruhe wenn du das Script beendest?
                    Sonst würde ich den Server mal neu starten.
                    Siggi0904 2 Replies Last reply Reply Quote 0
                    • Siggi0904
                      @wendy2702 ja, als gerade das Script gestoppt habe, kan es um 19:00 Uhr nicht wieder.
                      • Siggi0904
                        @wendy2702 Ich hab mal die VM neu gestartet. Hoffentlich bessert sich es.
                        • Siggi0904
                          Sieht bisher gut aus.
                          Hab die o.g. Scripte mal ausgelöst und den Cron abgewartet.
                          Dieser wird aktuell auch nur einmal ausgeführt.
                          Woher kommt sowas, dass das doppelt ausgeführt wird?
                          1.2k
                          81.1k
                          759
