    3. Off Topic
    4. Pflege des Betriebssystems
    5. BackitUp Fehler
    BackitUp Fehler
      ps1304 last edited by
      Hallo Forum, bekomme folgenden Fehler bei Backup, egal ob Local oder NAS oder FTP:
      13:27:24.774
      INFO
      gui
      Backup gestartet ...
      13:27:36.788
      DEBUG
      iobroker
      host.iobroker 6116 objects saved
      13:27:37.829
      DEBUG
      iobroker
      host.iobroker "config.json" is valid
      13:27:37.834
      DEBUG
      iobroker
      host.iobroker "objects.jsonl" exists
      13:27:37.864
      DEBUG
      iobroker
      host.iobroker "states.jsonl" exists
      13:27:37.869
      ERROR
      iobroker
      host.iobroker Backup not created: objectsFd.readLines is not a function
      13:27:38.066
      DEBUG
      iobroker
      Cannot create backup: objectsFd.readLines is not a function
      13:27:39.133
      DEBUG
      iobroker
      done
      13:27:42.477
      DEBUG
      clean
      done
      13:27:42.614
      DEBUG
      historyHTML
      new history html values created
      13:27:42.718
      DEBUG
      historyHTML
      done
      13:27:42.883
      DEBUG
      historyJSON
      new history json values created
      13:27:42.930
      DEBUG
      historyJSON
      done
      13:27:46.865
      WARN
      gui
      Das Backup konnte nicht vollständig erstellt werden!
      Das ist das Setup:
      Hat jemend nen Tipp?
      • Meister Mopper
        Meister Mopper @ps1304 last edited by
        @ps1304
        Dein System scheint veraltet zu sein. Was sagt iob diag (bitte die Langfassung in </> codetags hier reinstellen).
        P 2 Replies Last reply Reply Quote 0
          ps1304 @Meister Mopper last edited by ps1304
          @meister-mopper Danke Dir:
          hier erstmal die Summary:
                                  v.2025-02-23
           Static hostname: iobroker
                 Icon name: computer
          Operating System: Ubuntu 22.10
                    Kernel: Linux 5.19.0-1022-raspi
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1001
          Display-Server:         false
          Boot Target:            graphical.target
          Pending OS-Updates:     0
          Pending iob updates:    2
          Nodejs-Installation:
          /usr/bin/nodejs         v18.7.0
          /usr/bin/node           v18.7.0
          /usr/bin/npm            8.18.0
          /usr/bin/npx            8.18.0
          corepack:       N/A
          Recommended versions are nodejs 20.19.1 and npm 10.8.2
          *** nodejs is NOT correctly installed ***
          Wrong installation path detected. This needs to be fixed.
          Please execute
          iob nodejs-update
          to fix these errors.
          MEMORY:
          Mem:            3.8G        1.4G        743M        3.0M        1.6G        2.2G
          Swap:             0B          0B          0B
          Total:          3.8G        1.4G        743M
          Active iob-Instances:   15
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.6.3
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                6114
          States:                 4961
          Size of iob-Database:
          21M     /opt/iobroker/iobroker-data/objects.jsonl
          8.0M    /opt/iobroker/iobroker-data/states.jsonl
          Ubuntu Release codenamed 'kinetic' reached its END OF LIFE and needs to be updated to the latest LTS release 'jammy' NOW!
          code_text
          und die Langfassung kommt gleich
            @meister-mopper hier die Langversion:
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-02-23
            *** BASE SYSTEM ***
                   Icon name: computer
                Architecture: arm64
            OS is similar to: debian
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             13:42:14 up 31 days,  2:56,  2 users,  load average: 1.32, 0.95, 0.66
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Tue 2025-04-22 13:42:14 CEST
                       Universal time: Tue 2025-04-22 11:42:14 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            hwh-iobroker
            HOME=/home/hwh-iobroker
            GROUPS=hwh-iobroker adm dialout sudo audio video plugdev users iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker adm tty dialout cdrom sudo audio video plugdev games users input render bluetooth netdev gpio spi i2c
            *** DISPLAY-SERVER SETUP ***
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:            3.8G        1.4G        780M        3.0M        1.6G        2.2G
            Swap:             0B          0B          0B
            Total:          3.8G        1.4G        780M
                     3789 M total memory
                     1390 M used memory
                      970 M active memory
                     1636 M inactive memory
                      780 M free memory
                      161 M buffer memory
                     1457 M swap cache
                        0 M total swap
                        0 M used swap
                        0 M free swap
            top - 13:42:15 up 31 days,  2:56,  2 users,  load average: 1.32, 0.95, 0.66
            Tasks: 175 total,   1 running, 174 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  1.2 us,  6.0 sy,  0.0 ni, 92.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3789.6 total,    780.5 free,   1390.4 used,   1618.7 buff/cache
            MiB Swap:      0.0 total,      0.0 free,      0.0 used.   2201.5 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            Filesystem                        Type   Size  Used Avail Use% Mounted on
            tmpfs                             tmpfs  379M  3.1M  376M   1% /run
            /dev/mmcblk0p2                    ext4    59G  8.6G   48G  16% /
            /dev/mmcblk0p1                    vfat   253M  148M  105M  59% /boot/firmware
            //192.168.0.50/01_privat/16Backup cifs    11T  6.3T  4.7T  58% /pibackup
            tmpfs                             tmpfs  379M  4.0K  379M   1% /run/user/1001
            [Sat Mar 22 09:46:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=0 bcm27c95xx.macaddr=DC:A6:32:FB:31:72 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 dwc_otg.lpm_enable=0 console=tty1 root=LABEL=writable rootfstype=ext4 rootwait fixrtc qui
            [Sat Mar 22 09:46:07 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
            [Sat Mar 22 09:46:10 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
            Show mounted filesystems:
            TARGET              SOURCE                            FSTYPE   OPTIONS
            /                   /dev/mmcblk0p2                    ext4     rw,relatime,discard,errors=remount-ro
            |-/boot/firmware    /dev/mmcblk0p1                    vfat     rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            |-/pibackup         //192.168.0.50/01_privat/16Backup cifs     rw,relatime,vers=2.0,cache=strict,username=pi,domain=workgroup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.0.50,file_mode=0755,dir_verino,mapposix,noperm,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
            |-/snap/core24/741  /dev/loop0                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/core22/1912 /dev/loop1                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/23259 /dev/loop7                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/core20/2503 /dev/loop2                        squashfs ro,nodev,relatime,errors=continue
            |-/snap/snapd/23772 /dev/loop3                        squashfs ro,nodev,relatime,errors=continue
            `-/snap/core24/892  /dev/loop4                        squashfs ro,nodev,relatime,errors=continue
            /var:
            2.4G    /var/
            1.5G    /var/lib
            1.2G    /var/lib/snapd
            861M    /var/log
            847M    /var/log/journal/62937dad92cb47fcb54acfa4b10117f1
            Archived and active journals take up 846.0M in the file system.
            /opt/iobroker/backups:
            51M     /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            894M    /opt/iobroker/iobroker-data/
            784M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
            11M     /opt/iobroker/iobroker-data/states.jsonl
            9.9M    /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js
            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/npm            8.18.0
            /usr/bin/npx            8.18.0
            corepack:       N/A
            nodejs:
              Installed: 18.7.0+dfsg-5ubuntu1
              Candidate: 18.7.0+dfsg-5ubuntu1
              Version table:
             *** 18.7.0+dfsg-5ubuntu1 100
                    100 /var/lib/dpkg/status
                 16.20.2-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x kinetic/main arm64 Packages
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 3787)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.6.3
            javascript:     8.8.3
            nodejs modules from github:     1
            +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#860bde5a0d4828af5e85cc4569c56d740523d767)
            Adapter State
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.influxdb.1               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
              system.adapter.material.0               : material              : iobroker                                 -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
            + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
            + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
              system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
            + system.adapter.viessmannapi.0           : viessmannapi          : iobroker                                 -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 -  enabled
              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            │ (index) │   name   │                           url                           │ auto upgrade │
            │    0    │ 'stable' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
            │    1    │  'beta'  │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
            Active repo(s): stable
            Installed ioBroker-Adapters
            Used repository: stable
            Adapter    "admin"        : 7.6.3    , installed 7.6.3
            Adapter    "backitup"     : 3.0.31   , installed 3.0.31
            Adapter    "fb-checkpresence": 1.3.1 , installed 1.3.1
            Adapter    "javascript"   : 8.8.3    , installed 8.8.3
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "material"     : 1.3.1    , installed 1.3.1
            Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
            Adapter    "shelly"       : 9.2.0    , installed 8.5.1  [Updatable]
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
            Adapter    "vis-icontwo"  : 1.11.0   , installed 0.96.0 [Updatable]
            Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Objects and States
            Objects:        6114
            States:         4961
            E: The repository 'http://mirrors.aliyun.com/ubuntu lunar Release' does not have a Release file.
            E: The repository 'http://mirrors.aliyun.com/ubuntu lunar-security Release' does not have a Release file.
            E: The repository 'http://mirrors.aliyun.com/ubuntu lunar-updates Release' does not have a Release file.
            E: The repository 'http://mirrors.aliyun.com/ubuntu lunar-proposed Release' does not have a Release file.
            E: The repository 'http://mirrors.aliyun.com/ubuntu lunar-backports Release' does not have a Release file.
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       9747645    2381411/iobroker.js
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       9746845    2381411/iobroker.js
            tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1000       9749632    2381581/io.sonoff.0
            tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1000       9747048    2381562/io.shelly.0
            tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       9749587    2381539/io.mqtt.0
            tcp        0      0 127.0.0.54:53           0.0.0.0:*               LISTEN      104        17197      595/systemd-resolve
            tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        17195      595/systemd-resolve
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          18859      1/init
            tcp6       0      0 :::8082                 :::*                    LISTEN      1000       9747924    2381641/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1000       9748567    2381429/io.admin.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          17934      1/init
            tcp6       0      0 :::22                   :::*                    LISTEN      0          22643      1/init
            udp        0      0 0.0.0.0:49257           0.0.0.0:*                           112        22693      694/avahi-daemon: r
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18860      1/init
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           112        22691      694/avahi-daemon: r
            udp        0      0 127.0.0.54:53           0.0.0.0:*                           104        17196      595/systemd-resolve
            udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        17194      595/systemd-resolve
            udp        0      0 192.168.0.47:68         0.0.0.0:*                           100        9716352    682/systemd-network
            udp6       0      0 :::111                  :::*                                0          18861      1/init
            udp6       0      0 fe80::dea6:32ff:fef:546 :::*                                100        21100      682/systemd-network
            udp6       0      0 :::5353                 :::*                                112        22692      694/avahi-daemon: r
            udp6       0      0 :::49041                :::*                                112        22694      694/avahi-daemon: r
            2025-04-22 13:35:43.754  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data29.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:35:43.761  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data30.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:35:43.767  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data31.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:35:43.774  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data32.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:35:43.778  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data33.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:35:43.782  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data34.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:35:43.786  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data35.body.errorCode" has to be type "number" but received type "string"
            2025-04-22 13:35:43.790  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data36.body.errorCode" has to be type "number" but received type "string"
            2025-04-22 13:35:43.801  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data37.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:09.077  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 2382967
            2025-04-22 13:40:14.060  - info: dwd.0 (2382967) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.7.0, js-controller: 7.0.6
            2025-04-22 13:40:15.007  - info: dwd.0 (2382967) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2025-04-22 13:40:15.574  - info: host.iobroker instance system.adapter.dwd.0 having pid 2382967 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-04-22 13:40:43.440  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data26.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.454  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data27.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.461  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data28.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.468  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data29.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.476  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data30.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.489  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data31.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.503  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data32.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.514  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data33.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.520  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data34.body.errorCode" has to be type "string" but received type "number"
            2025-04-22 13:40:43.527  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data35.body.errorCode" has to be type "number" but received type "string"
            2025-04-22 13:40:43.553  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data36.body.errorCode" has to be type "number" but received type "string"
            2025-04-22 13:40:43.559  - info: viessmannapi.0 (2381667) State value to set for "viessmannapi.0.176254.events.data37.body.errorCode" has to be type "string" but received type "number"
              Thomas Braun Most Active @ps1304 last edited by Thomas Braun
              @ps1304 sagte in BackitUp Fehler:
              Muss aktualisiert werden. Und zwar KOMPLETT.
              Auf einem Raspberry würde ich auch kein Ubuntu fahren sondern RaspberryOS Lite -> Neuinstallation von RaspberryOS 'Bookworm'.
              Dann kommt da auch die korrekte nodejs-Version automatisch mit.
                ps1304 @Thomas Braun last edited by
                @thomas-braun habe ich befürchtet - hab den so übernommen zur "Betreuung"
                  @ps1304
                  Der ist aber nie 'betreut' worden. Sonst wäre die Kiste nicht so abgesoffen.
                    Hat in der Kategorie Forum nichts verloren.
                    Auch wenn backitup im Threadtitel steht, denke ich es ist hier besser aufgehoben
                      @thomas-braun korrekt, deshalb jetzt neu - hätte aber gerne das Backup eingespielt wegen den ganzen Einstellungen der Adapter.
                        @ps1304
                        Dann bring das jetzt noch soweit es geht auf den aktuellsten Stand, zieh dann davon ein Backup und spiel das im neuen System ein.
                        iob update
                        iob stop
                        iob fix
                        iob nodejs-update 20
                        447
