    4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
    • OliverIO
      OliverIO @Oli last edited by OliverIO
      @oli
      ok
      ich habe mal reingeschaut,
      da ist etwas. Muss das aber genauer analysieren.
      In der Entwicklungsumgebung funktioniert es,
      im fertigen Adapter scheint was zu fehen.
        trojanhector @OliverIO last edited by
        @oliverio
        Das scheint sich auch auf das JSON Widget 0.1.9 auszuwirken. Habe hier auch Fehlermeldungen mit Bezug auf RSS-FEED (3.3.1).
        Hier der Log aus der Console.
        load script:41
                   GET http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js net::ERR_ABORTED 404 (Not Found)
        (anonymous) @ load script:41
        (anonymous) @ jsonp chunk loading:43
        (anonymous) @ ensure chunk:6
        (anonymous) @ ensure chunk:5
        ./RSSArticleMarqueeV5 @ container-entry:6
        a @ container-entry:28
        (anonymous) @ visLoadWidgets.tsx:144
        await in (anonymous)
        (anonymous) @ visLoadWidgets.tsx:177
        a @ visLoadWidgets.tsx:173
        (anonymous) @ visLoadWidgets.tsx:326
        Promise.then
        (anonymous) @ visLoadWidgets.tsx:254
        Promise.then
        r @ visLoadWidgets.tsx:225
        (anonymous) @ visWidgetsCatalog.tsx:302
        c @ helpers.ts:98
        setTimeout
        (anonymous) @ browserapierrors.ts:109
        (anonymous) @ visWidgetsCatalog.tsx:301
        collectRxInformation @ visWidgetsCatalog.tsx:300
        onWidgetsLoaded @ Editor.jsx:813
        onLoaded @ Editor.jsx:1028
        loadWidgets @ visEngine.jsx:1529
        await in loadWidgets
        (anonymous) @ visEngine.jsx:208
        Promise.then
        O @ visEngine.jsx:196
        cs @ react-dom.production.min.js:184
        Vs @ react-dom.production.min.js:197
        Hi @ react-dom.production.min.js:291
        Ml @ react-dom.production.min.js:279
        gl @ react-dom.production.min.js:279
        fl @ react-dom.production.min.js:279
        rl @ react-dom.production.min.js:267
        S @ scheduler.production.min.js:13
        T @ scheduler.production.min.js:14Understand this errorAI
        load script:41
                   GET http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_colors_blue_js-node_modules_mui_material_colors_common_js-n-6f5860.f842f4ec.chunk.js net::ERR_ABORTED 404 (Not Found)
        Promise.then
        Promise.then
        c @ helpers.ts:98
        setTimeout
        Promise.then
        console.ts:40 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: ChunkLoadError: Loading chunk vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64 failed.
        (error: http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js)
        (anonymous) @ console.ts:40
        (anonymous) @ visLoadWidgets.tsx:197
        Promise.catch
        (anonymous) @ visLoadWidgets.tsx:196
        Promise.then
        Promise.then
        c @ helpers.ts:98
        setTimeout
        Promise.then
        console.ts:40 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {"message":"Loading chunk vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64 failed.\n(error: http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js)","name":"ChunkLoadError","type":"error","request":"http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js"}
        • OliverIO
          OliverIO @trojanhector last edited by OliverIO
          @trojanhector
          Ja
          Das neue Widget wurde in der kompilation nicht mit übernommen.
          Irgendwas wurde an den basisbibliotheken für den Build verändert, was ich aber noch herausfinden muss.
          Bluefox will/hat auf ein komplett neues Build-System umstellen (vite), hat aber bisher erst für typescript adapter Beispiele. Für JavaScript müsste es auch funktionieren, benötige da aber wieder mal F+E Zeit, die gerade nicht da ist.
          Daher aktuell bitte noch v4 verwenden. Da fehlt halt daspopup Feature. Die neue Version v5 habe ich gemacht, das der Wechsel bewusst erfolgt, da nun mehr Eigenschaften für das Widget eingegeben werden müssen.
          • OliverIO
            Neue Version rssfeed 3.5.0
            Das Update betrifft aktuell nur den rssfeed adapter + die vis1 widgets, nicht den vis-2 adapter
            • in den templates des jsonTemplate widgets können nun auch async/await funktionen verwendet werden. Siehe Beispiel in der Dokumentation: JSON Template mit async/await
            • OliverIO
              OliverIO last edited by OliverIO
              Neue Version vis-2-widgets-rssfeed 1.1.2
              Die build-Probleme konnte ich beheben, auch wenn mir die Ursache dafür unerklärlich ist.
              Somit wäre das popup-Feature für das Marquee Widget (widget version 5) auch funktionsfähig.
              @Oli Bitte testen
              @trojanhector sagte in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
              Das JSON widget dürfte das unter vis2 nicht betreffen, da dieses widget sich nun im adapter vis-2-widgets-ovarous befindet. Aber du hast wahrscheinlich beide installiert, somit siehst du die rssfeed fehlermeldungen.
              O OliverIO 3 Replies Last reply Reply Quote 0
              • OliverIO
                Ich poste das hier auch mal rein.
                das Widget JSON Template für vis-2 befindet sich ja nun im Adapter vis-2-widgets-ovarious
                dafür gibt es nun ein Update
                Neue Version 1.0
                • das feature async/await wurde ergänzt, d.h. auch hier können nun Funktionen mit async/await definiert und verwendet werden.
                • OliverIO
                  Der Usecase für die interaktive Todolist mit direkter Datenbank-Kommunikation wurde nun hinzugefügt
                  https://github.com/oweitman/ioBroker.rssfeed?tab=readme-ov-file#use-case-for-a-database-supported-task-list
                  vlg auch hier
                  https://forum.iobroker.net/topic/80347/button-wert-aus-der-vis-in-sql-eintragen-speichern/11?_=1742498938735
                  • O
                    Oli @OliverIO last edited by
                    @oliverio
                    sorry für die späte Antwort. Das neue "marquee widget 5" wird jetzt mit angezeigt
                    • OliverIO
                      @oli
                      • OliverIO
                        OliverIO @OliverIO last edited by
                        Die Version 1.1.2 befindet sich nun im stable
                        @oliverio sagte in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
                        @Oli Bitte testen
                        • OliverIO
                          Diese Version ist nun auf Stable verfügbar
                          Neue Version rssfeed 3.5.2
                          • OliverIO
                            Neue Version iobroker.vis-2-widgets-rssfeed 1.2.0
                            • Das compiler framework wurde von CRA auf vite umgestellt
                            • Das deprecated widget RSSMarquee wurde entfernt. RSSMarquee5 ist bereits seit einigen Versionen verfügbar
                            Es wäre schön, wenn das noch jemand bei sich testen könnte, da die zugrundeliegenden Änderungen umfangreich waren. An der Nutzerfunktionalität dürfte sich nichts geändert haben.
                            • OliverIO
                              Diese Version befindet sich nun auch im stable repository
                                @oliverio Servus,
                                bei mir verschwinden die Widgets bei v 1.2.0. Sowohl im Editor für VIS als auch auf der Homepage.
                                Nach Rückstellen auf 1.1.2 sind sie wieder da.
                                Verfügbar: 7.0.6
                                Installiert: 7.0.6
                                Plattform: linux
                                Betriebssystem: linux
                                Architektur: arm64
                                Node.js: v20.19.3
                                RSS Feed: 3.5.2
                                NPM: 10.8.2
                                _npmNewest: 10.8.2
                                _nodeNewestNext: 20.19.3
                                _nodeNewest: 20.19.3
                                _npmCurrent: 10.8.2
                                _npmNewestNext: 10.8.2
                                _nodeCurrent: 20.19.3
                                • OliverIO
                                  @trojanhector
                                  Bitte einmal auf der Konsole
                                  iob upload all
                                  Und wenn dann immer noch nicht, dann bitte
                                  Evtl Fehlermeldungen auf der Browser Konsole mit f12 schauen
                                    @oliverio
                                    es geht nacht iob updload all leider immer noch nicht.
                                    Der Browser wirft folgende Fehlermeldungen:
                                    • OliverIO
                                      @trojanhector
                                      Ja das ist eigentlich der Fehler der mit Upload sich erledigt.
                                      Diendatei ist im aktuellen Paket auch enthalten und wurde im Beta bereits mehrfach installiert
                                      Starte bitte auch mal noch den vis-2 Adapter neu
                                      Iob Upload all dauert auch eine weile
                                      T O 2 Replies Last reply Reply Quote 0
                                        @oliverio
                                        Der Adapter wurde neu gestartet, die Homepage neu aufgerufen. Es gibt keine Änderung.
                                        T OliverIO 2 Replies Last reply Reply Quote 0
                                        • O
                                          @oliverio
                                          ich habe das gleiche Problem wie @trojanhector, ein "iob upload all" und ein Neustart des VIS-2 Adapters bringt keinen Erfolg.
                                          Installierte VIS-Version: 2.9.64
                                          Uncaught SyntaxError: Cannot use import statement outside a module
                                          visLoadWidgets.tsx:197  Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: Error: Cannot load vis2rssfeedWidgets from ./widgets/vis-2-widgets-rssfeed/customWidgets.js
                                          visLoadWidgets.tsx:198  Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {}
                                          (anonymous) @ visLoadWidgets.tsx:198
                                            trojanhector @trojanhector last edited by
                                            @trojanhector
                                            Ich habe auf VIS-2 2.12.10 upgedatet. Da sind die Widgets wieder da.
                                            adapter atom feed iobroker.rssfeed rdf rss vis widget
                                            34
                                            672
                                            140226
