    4. Tester für Zigbee Adapter 2.0.x gesucht
      Homoran Global Moderator Administrators @Asgothian last edited by
      @asgothian sagte in Tester für Zigbee Adapter 2.0.x gesucht:
      Kannst du das mit der 3.0 aus dem latest testen ?
      komm ich notfalls zurück?
      ist mein produktives System.
      wenn ja mache ich es morgen gerne mal.
        @asgothian ich hab's gewagt!
        gleiches Problem
        zigbee.0
           2025-04-22 22:11:48.251	error	uncaught exception: request.headers.split is not a function
        zigbee.0
           2025-04-22 22:11:48.252	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
        zigbee.0
           2025-04-22 22:11:48.252	error	request.headers.split is not a function
        zigbee.0
           2025-04-22 22:11:48.268	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        host.ioBrokerpi5
           2025-04-22 22:11:48.430	error	Caught by controller[0]: TypeError: request.headers.split is not a function
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
        host.ioBrokerpi5
           2025-04-22 22:11:48.431	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
        host.ioBrokerpi5
           2025-04-22 22:11:48.432	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
        host.ioBrokerpi5
           2025-04-22 22:11:48.432	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
        Asgothian arteck 2 Replies Last reply Reply Quote 0
        • Asgothian
          Asgothian Developer @Homoran last edited by
          @homoran schalt mal bitte den sentry aus für zigbee. (In der Instanz-Ansicht, ganz rechts das Icon)
          Und ja, du kommst problemlos zurück.
            arteck Developer Most Active @Homoran last edited by arteck
            @homoran das ist sentry..was da spinnt..
            klickmal
            • Fabio
              Fabio @Homoran last edited by Fabio
              @homoran sagte in Tester für Zigbee Adapter 2.0.x gesucht:
              Welche Versionen hast du (js-Controller, nodeJS ?
              7.0.6
              20.18.3
              ich habe die 7.0.6 und Node.js: v20.19.0
              und Sentry ist bei beiden Instanzen bei mir an und macht keine Probleme. Echt komisch.
              Evtl. mal die ganze Kiste sauber runterfahren und neu starten.
              Fabio
                Homoran Global Moderator Administrators @arteck last edited by Homoran
                @arteck sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                das war das einzige im log das ich zuordnen konnte!
                Also jetzt
                sentry aus!
                Check gestartet!
                Das übliche 😞
                zigbee.0
                	2025-04-23 07:51:14.338	warn	readNvBackup called
                zigbee.0
                	2025-04-23 07:51:14.344	warn	readNvBackup returns {"channel":11,"precfgkey":"weg damit","extPanID":"geändert","panID":auch}
                zigbee.0
                	2025-04-23 07:52:35.533	warn	readNvBackup called
                zigbee.0
                	2025-04-23 07:52:35.534	warn	readNvBackup returns {"channel":11,"precfgkey":"weg damit","extPanID":"geändert","panID":auch}
                zigbee.0
                	2025-04-23 07:52:45.070	error	uncaught exception: request.headers.split is not a function
                zigbee.0
                	2025-04-23 07:52:45.070	error	TypeError: request.headers.split is not a function at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39) at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7) at Channel.publish (node:diagnostics_channel:150:9) at new Request (node:internal/deps/undici/undici:2008:27) at Client.[dispatch] (node:internal/deps/undici/undici:7802:25) at Intercept (node:internal/deps/undici/undici:7535:20) at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16) at Client.dispatch (node:internal/deps/undici/undici:588:44) at Pool.[dispatch] (node:internal/deps/undici/undici:819:32) at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                zigbee.0
                	2025-04-23 07:52:45.070	error	request.headers.split is not a function
                zigbee.0
                	2025-04-23 07:52:45.085	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                host.ioBrokerpi5
                	2025-04-23 07:52:45.272	error	Caught by controller[0]: TypeError: request.headers.split is not a function
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at setHeadersOnRequest (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:312:39)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at _onRequestCreate (/opt/iobroker/node_modules/@sentry/src/integrations/undici/index.ts:223:7)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Channel.publish (node:diagnostics_channel:150:9)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at new Request (node:internal/deps/undici/undici:2008:27)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Client.[dispatch] (node:internal/deps/undici/undici:7802:25)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Intercept (node:internal/deps/undici/undici:7535:20)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Client.[Intercepted Dispatch] (node:internal/deps/undici/undici:572:16)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.275	error	Caught by controller[0]: at Client.dispatch (node:internal/deps/undici/undici:588:44)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.276	error	Caught by controller[0]: at Pool.[dispatch] (node:internal/deps/undici/undici:819:32)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.276	error	Caught by controller[0]: at Pool.[Intercepted Dispatch] (node:internal/deps/undici/undici:565:33)
                host.ioBrokerpi5
                	2025-04-23 07:52:45.276	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                (die warn kamen mit der v3)
                Fabio Asgothian 2 Replies Last reply Reply Quote 0
                • Fabio
                  @homoran hast du dein Sytem mal neu gestartet?
                    Homoran Global Moderator Administrators @Fabio last edited by
                    @fabio ja!
                    mach ich aber später gerne nochmal, muss gleich weg.
                    Fabio 1 Reply Last reply Reply Quote 0
                    • Fabio
                      @homoran das brauchst du nicht wenn du es schon gemacht hast, da hängt wohl noch was anderes. Sonst läuft dein System stabil? Ich denke ja 😉
                      Herzliche Grüße
                      Fabio
                        arteck Developer Most Active @Fabio last edited by
                        @fabio sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                        und das liesst du woraus ??
                        • Asgothian
                          Ja, die sind in der V3 noch drin. Werden es aber nicht ins Stable schaffen.
                          Probier bitte mal folgendes:
                          • geh durch deine Zigbee Geräte durch. Meines Wissens sind es nicht so wahnsinnig viele
                          • Such Dir einen Geräte typ aus (T1). Deaktiviere alle Geräte die nicht vom Typ T1 sind. Dann scan. Das ganze wiederholen mit jedem Gerätetyp den du hast (ich sehe in Deiner Liste 3 Gerätetypen.
                          • sollte bei genau einem Gerätetyp (Tk) der Fehler auftreten und bei allen anderen nicht bleibt noch der 2. Test:
                            -- Reaktiviere alle Geräte.
                            -- Deaktiviere alle Geräte des Typs Tk bis auf eins. Testen. Das so lange wiederholen bis klar ist ob der Fehler an einem Gerät, einer Gruppe von Geräten oder einem Gerätetyp hängt.
                          Danach bitte alle Geräte wieder aktivieren - sonst funktionieren deine Smarten Dinge nicht.
                          A.
                          • Fabio
                            Fabio @arteck last edited by
                            @arteck das Resultat der Versuche zeigt wohl das es evtl. wo anders hängt.
                              Homoran Global Moderator Administrators @Asgothian last edited by Homoran
                              @asgothian Danke!
                              Wenn ich es richtig gemacht habe, bin ich jetzt verwirrt
                              richtig!
                              Eigentlich nur Steckdosen, Dann zum testen und helfen 1x IKEA RGB E27 und 1x IKEA FB.
                              Letztere beide zuerst deaktiviert.
                              War das einfachste
                              Dann alle Steckdosen deaktiviert und nur die FB aktiv und wachgehalten
                              nichts weiter gemacht, nur wieder deaktiviert und die RGB aktiviert
                              auch jetzt nichts weiter gemacht.
                              Würde jetzt wieder alles aktivieren und nochmal mit allem testen
                                War jetzt zu ungeduldig, weil ich schon wieder unter etwas "Zeitdruck" stehe.
                                Hab alle Geräte wieder aktiviert!
                                Das erste wa mir auffiel, war dass die Fernbedienung erstmalig den Batteriezustand anzeigte.
                                Der check lief durch, kein Absturz!
                                Die RGB und die FB zeigten das grüne Firmware verfügbar Icon, die Steckdosen den ok-Haken
                                hab beide angetippt und es sprang sofort auf den ok-Haken.
                                im log nur die warn, die anscheinend bei jedem umdrehen aller Kacheln kommen
                                Kein Hinweis auf irgendein Update.
                                Also nochmal check
                                Die Steckdosen zeigten sofort den ok-Haken, RGB und FB rödelten sich mit "checking" tot.
                                nichts im log
                                Also das ganze Spiel nochmal.
                                RGB und FB zeigten Download verfügbar.
                                Nur die FB gestartet, diesmal Haken in blau!
                                ins log gesehen und einen älteren Eintrag gefunden
                                zigbee.0
                                	2025-04-23 11:39:42.911	error	Update of '0x000b57fffebacd87' failed ([0x000b57fffebacd87 | TRADFRI remote control] Timeout. Device did not start/finish firmware download after being notified. (Timeout - 25594 - 1 - undefined - 25 - 3 after 150000ms))
                                zigbee.0
                                	2025-04-23 11:39:45.357	error	Update of '0xd0cf5efffe298051' failed ([0xd0cf5efffe298051 | TRADFRI bulb E27 CWS opal 600lm] Timeout. Device did not start/finish firmware download after being notified. (Timeout - 34907 - 1 - undefined - 25 - 3 after 150000ms))
                                war aber vorhin nicht da.
                                Kein weitere Hinweis auf update.
                                jetzt warte ich mal
                                  Das Leben ist wie eine Pralinenschachtel. Man weiss nie was man als nächstes bekommt!
                                  Hab einfach mutig weitergemacht!
                                  im Gegensatz zu
                                  @pk68 sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                                  dass sich am data code nichts geändert hat.
                                  hat sich bei mir etwas geändert.
                                  und zwar anscheinend mehrmals.
                                  Gab also mehrere Updates
                                  jetzt
                                  und
                                  von 2016 ... auf 2022
                                  Asgothian 1 Reply Last reply Reply Quote 1
                                  • Asgothian
                                    @homoran Das ist durchaus normal. Dadurch das der Durchsatz im Zigbee Netz massiv begrenzt ist dauert ein Firmware-Update gerne mal 10-60 Minuten, wenn es einmal gestartet wurde.
                                    Offensichtlich hast du es zu einem Zeitpunkt mal gestartet, und die Geräte haben das Update durchgezogen.
                                    A.
                                    Homoran 1 Reply Last reply Reply Quote 2
                                      im log war nie etwas zu sehen
                                      Aber warum der Controller den Adapter jedesmal gestoppt hatte wenn ich nach upgrades gesucht hatte kann ich nicht nachvollziehen.
                                      Hab eben auch nochmal versucht, nachdem ich erst vergessen hatte senty wieder zu aktivieren, diesmal mit sentry: auch slles ok 🤔
                                      • Asgothian
                                        Asgothian Developer last edited by
                                        @homoran ganz schwer zu sagen.
                                          @asgothian ist mir klar.
                                          es gibt ja keine entsprechenden Fakten
                                            Homoran Global Moderator Administrators @Fabio last edited by Homoran
                                            da war ich echt ins Schleudern geraten.
                                            hab gerade ein update gestartet
                                            Unpacking nodejs (20.19.1-1nodesource1) over (20.19.0-1nodesource1)
                                            also hätte, wie gedacht, 20.19.0 drauf sein müssen 🤔
                                            auch danach stand noch 20.18.3 im Reiter Hosts.
                                            erst nach erneutem iob restart war das aktuell
                                            zigbee 2.0.1
                                            50
                                            525
                                            70075
