    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    • I
      ichderarnd @tombox last edited by ichderarnd
      @tombox
      Ich habe gestern die 0.7.9 nochmal über die Katze installiert. Hier das Ergebnis für die Instanz 0 (eGolf und ID.Buzz):
      2025-04-18 14:10:08.148 - info: host.pi-Home instance system.adapter.vw-connect.0 in version "0.7.9" (non-npm: ta2k/ioBroker.vw-connect) started with pid 31441
      2025-04-18 14:10:12.568 - debug: vw-connect.0 (31441) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2025-04-18 14:10:12.671 - debug: vw-connect.0 (31441) Objects client ready ... initialize now
      2025-04-18 14:10:12.710 - debug: vw-connect.0 (31441) Objects create System PubSub Client
      2025-04-18 14:10:12.712 - debug: vw-connect.0 (31441) Objects create User PubSub Client
      2025-04-18 14:10:12.948 - debug: vw-connect.0 (31441) Objects client initialize lua scripts
      2025-04-18 14:10:12.968 - debug: vw-connect.0 (31441) Objects connected to redis: 0.0.0.0:9001
      2025-04-18 14:10:13.132 - debug: vw-connect.0 (31441) Redis States: Use Redis connection: 0.0.0.0:9000
      2025-04-18 14:10:13.226 - debug: vw-connect.0 (31441) States create System PubSub Client
      2025-04-18 14:10:13.228 - debug: vw-connect.0 (31441) States create User PubSub Client
      2025-04-18 14:10:13.359 - debug: vw-connect.0 (31441) States connected to redis: 0.0.0.0:9000
      2025-04-18 14:10:13.511 - debug: vw-connect.0 (31441) Plugin sentry Initialize Plugin (enabled=true)
      2025-04-18 14:10:14.415 - info: vw-connect.0 (31441) starting. Version 0.7.9 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v20.18.1, js-controller: 7.0.7
      2025-04-18 14:10:14.454 - info: vw-connect.0 (31441) Login in with id
      2025-04-18 14:10:15.309 - debug: vw-connect.0 (31441) parseEmailForm
      2025-04-18 14:10:15.509 - debug: vw-connect.0 (31441) emailPasswordForm2
      2025-04-18 14:10:15.758 - debug: vw-connect.0 (31441) ""
      2025-04-18 14:10:15.759 - debug: vw-connect.0 (31441) {"date":"Fri, 18 Apr 2025 12:10:15 GMT","content-length":"0","connection":"keep-alive", ...
      2025-04-18 14:10:16.196 - debug: vw-connect.0 (31441) Error: Invalid protocol: weconnect:
      2025-04-18 14:10:16.317 - info: vw-connect.0 (31441) History limit: -1, set to -1 to disable wallcharging login
      2025-04-18 14:10:16.318 - info: vw-connect.0 (31441) History limit is set to -1, no wall charging login
      2025-04-18 14:10:16.320 - info: vw-connect.0 (31441) Login successful
      2025-04-18 14:10:16.966 - debug: vw-connect.0 (31441) {"data":[...
      2025-04-18 14:10:16.966 - info: vw-connect.0 (31441) Found 2 vehicles
      2025-04-18 14:10:17.184 - info: vw-connect.0 (31441) Create vehicle WV2ZZZEBXSH...
      2025-04-18 14:10:17.777 - info: vw-connect.0 (31441) Create vehicle WVWZZZAUZLW...
      2025-04-18 14:10:17.787 - debug: vw-connect.0 (31441) getHomeRegion
      2025-04-18 14:10:17.910 - debug: vw-connect.0 (31441) getHomeRegion
      2025-04-18 14:10:18.209 - debug: vw-connect.0 (31441) WV2ZZZEBXSH...: set default homeregion
      2025-04-18 14:10:18.217 - debug: vw-connect.0 (31441) WVWZZZAUZLW...: set default homeregion
      2025-04-18 14:10:18.618 - debug: vw-connect.0 (31441) {"access":{"accessStatus":...
      2025-04-18 14:10:18.756 - debug: vw-connect.0 (31441) {"access":{"accessStatus":...
      2025-04-18 14:10:18.878 - debug: vw-connect.0 (31441) {"access":{"accessStatus":...
      2025-04-18 14:10:19.748 - debug: vw-connect.0 (31441) {"access":{"accessStatus":...
      2025-04-18 14:10:26.318 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.chargingCareSettings
      2025-04-18 14:10:26.353 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.chargingCareSettings
      2025-04-18 14:10:27.304 - debug: vw-connect.0 (31441) make state with ending writable : WVWZZZAUZLW.......status.chargingSettings
      2025-04-18 14:10:27.323 - debug: vw-connect.0 (31441) make state with ending writable : WVWZZZAUZLW.......status.chargingSettings
      2025-04-18 14:10:27.978 - debug: vw-connect.0 (31441) make state with ending writable : WVWZZZAUZLW.......status.climatisationSettings
      2025-04-18 14:10:27.992 - debug: vw-connect.0 (31441) make state with ending writable : WVWZZZAUZLW.......status.climatisationSettings
      2025-04-18 14:10:28.043 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.chargingSettings
      2025-04-18 14:10:28.045 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.chargingSettings
      2025-04-18 14:10:28.317 - info: sql.0 (9038) enabled logging of vw-connect.0.WV2ZZZEBXSH.......status.chargingSettings.targetSOC_pct, Alias=false, WriteNulls=false
      2025-04-18 14:10:28.756 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.charging_chargingCareSettings
      2025-04-18 14:10:29.038 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.climatisationSettings
      2025-04-18 14:10:29.042 - debug: vw-connect.0 (31441) make state with ending writable : WV2ZZZEBXSH.......status.climatisationSettings
      2025-04-18 14:10:36.790 - info: sql.0 (9038) enabled logging of vw-connect.0.WV2ZZZEBXSH.......status.temperatureOutsideStatus.temperatureOutside_K, Alias=false, WriteNulls=false
      2025-04-18 14:10:40.082 - debug: vw-connect.0 (31441) Set is car moving to false
      2025-04-18 14:10:40.083 - debug: vw-connect.0 (31441) {"data":{"lon":...
      2025-04-18 14:10:41.438 - debug: vw-connect.0 (31441) Set is car moving to false
      2025-04-18 14:10:41.439 - debug: vw-connect.0 (31441) {"data":{"lon":...
      2025-04-18 14:10:41.440 - debug: vw-connect.0 (31441) Skip last trip check because of last check was less than 15min ago
      2025-04-18 14:10:42.115 - debug: vw-connect.0 (31441) Set is car moving to false
      2025-04-18 14:10:42.115 - debug: vw-connect.0 (31441) {"data":{"lon":...
      2025-04-18 14:10:42.116 - debug: vw-connect.0 (31441) Skip last trip check because of last check was less than 15min ago
      2025-04-18 14:10:42.643 - debug: vw-connect.0 (31441) Set is car moving to false
      2025-04-18 14:10:42.649 - debug: vw-connect.0 (31441) {"data":{"lon":...
      2025-04-18 14:10:42.651 - debug: vw-connect.0 (31441) Skip last trip check because of last check was less than 15min ago
      2025-04-18 14:10:46.810 - debug: vw-connect.0 (31441) reverse pos started
      2025-04-18 14:10:46.867 - debug: vw-connect.0 (31441) No update lat ts 1744978242590 <-> lc 1744910234551, long ts 1744978242589 <-> lc 1744910234545
      2025-04-18 14:10:47.084 - debug: vw-connect.0 (31441) reverse pos received
      2025-04-18 14:10:47.085 - debug: vw-connect.0 (31441) {"place_id":...
      2025-04-18 14:10:47.641 - debug: vw-connect.0 (31441) No update lat ts 1744978242590 <-> lc 1744910234551, long ts 1744978242589 <-> lc 1744910234545
      2025-04-18 14:10:47.646 - debug: vw-connect.0 (31441) No update lat ts 1744978242590 <-> lc 1744910234551, long ts 1744978242589 <-> lc 1744910234545
      2025-04-18 14:10:47.791 - debug: vw-connect.0 (31441) No update lat ts 1744978242937 <-> lc 1744889841205, long ts 1744978242936 <-> lc 1744889841205
      2025-04-18 14:10:47.827 - debug: vw-connect.0 (31441) No update lat ts 1744978242937 <-> lc 1744889841205, long ts 1744978242936 <-> lc 1744889841205
      2025-04-18 14:10:47.975 - debug: vw-connect.0 (31441) No update lat ts 1744978242937 <-> lc 1744889841205, long ts 1744978242936 <-> lc 1744889841205
      2025-04-18 14:10:47.978 - debug: vw-connect.0 (31441) No update lat ts 1744978242937 <-> lc 1744889841205, long ts 1744978242936 <-> lc 1744889841205
      Nach einer Stunde dann die Fehlermeldung, dass der Token abgelaufen ist. Er wird zwar erneuert, aber es werden dadurch keine Daten abgerufen. Erst 10 Min. später werden die Daten wieder übermittelt.
      2025-04-18 15:20:18.372 - error: vw-connect.0 (31441) Fetching status failed
      2025-04-18 15:20:18.372 - error: vw-connect.0 (31441) AxiosError: Request failed with status code 401
      2025-04-18 15:20:18.372 - error: vw-connect.0 (31441) {"error":{"message":"Unauthorized","info":"token is expired"}}
      2025-04-18 15:20:18.373 - error: vw-connect.0 (31441) get id status Failed
      2025-04-18 15:20:18.374 - debug: vw-connect.0 (31441) Token Refresh started
      2025-04-18 15:20:18.396 - error: vw-connect.0 (31441) Fetching status failed
      2025-04-18 15:20:18.397 - error: vw-connect.0 (31441) AxiosError: Request failed with status code 401
      2025-04-18 15:20:18.397 - error: vw-connect.0 (31441) {"error":{"message":"Unauthorized","info":"token is expired"}}
      2025-04-18 15:20:18.397 - error: vw-connect.0 (31441) get id status Failed
      2025-04-18 15:20:18.397 - debug: vw-connect.0 (31441) Token Refresh started
      2025-04-18 15:20:18.416 - debug: vw-connect.0 (31441) AxiosError: Request failed with status code 401
      2025-04-18 15:20:18.416 - debug: vw-connect.0 (31441) No parkingposition found
      2025-04-18 15:20:18.416 - debug: vw-connect.0 (31441) Skip last trip check because of last check was less than 15min ago
      2025-04-18 15:20:18.507 - debug: vw-connect.0 (31441) AxiosError: Request failed with status code 401
      2025-04-18 15:20:18.508 - debug: vw-connect.0 (31441) No parkingposition found
      2025-04-18 15:20:18.509 - debug: vw-connect.0 (31441) Skip last trip check because of last check was less than 15min ago
      2025-04-18 15:20:18.569 - debug: vw-connect.0 (31441) Token Refresh successful
      2025-04-18 15:20:18.603 - debug: vw-connect.0 (31441) Token Refresh successful
      2025-04-18 15:30:18.782 - debug: vw-connect.0 (31441) {"access":{"accessStatus":{"value":...
      2025-04-18 15:30:19.234 - debug: vw-connect.0 (31441) {"access":{"accessStatus":{"value":...
      2025-04-18 15:30:21.835 - debug: vw-connect.0 (31441) Set is car moving to false
      2025-04-18 15:30:21.835 - debug: vw-connect.0 (31441) {"data":{"lon":...
      2025-04-18 15:30:22.540 - debug: vw-connect.0 (31441) Set is car moving to false
      2025-04-18 15:30:22.541 - debug: vw-connect.0 (31441) {"data":{"lon":...
      2025-04-18 15:30:22.542 - debug: vw-connect.0 (31441) Skip last trip check because of last check was less than 15min ago
      2025-04-18 15:30:26.911 - debug: vw-connect.0 (31441) No update lat ts 1744983021902 <-> lc 1744910234551, long ts 1744983021901 <-> lc 1744910234545
      2025-04-18 15:30:26.913 - debug: vw-connect.0 (31441) No update lat ts 1744983021902 <-> lc 1744910234551, long ts 1744983021901 <-> lc 1744910234545
      2025-04-18 15:30:28.054 - debug: vw-connect.0 (31441) No update lat ts 1744983023005 <-> lc 1744889841205, long ts 1744983022946 <-> lc 1744889841205
      2025-04-18 15:30:28.124 - debug: vw-connect.0 (31441) No update lat ts 1744983023005 <-> lc 1744889841205, long ts 1744983022946 <-> lc 1744889841205
      Der Token wird vermutlich unnötigerweise zweimal erneuert. Da zwei Fahrzeuge in dieser Instanz abgefragt werden, erfolgt auch zweimal die Expired-Meldung und daher wird wohl auch zweimal der Token erneuert?
      Instanz 1 (Enyaq):
      2025-04-18 14:10:15.688 - info: host.pi-Home "system.adapter.vw-connect.1" enabled
      2025-04-18 14:10:18.691 - info: host.pi-Home instance system.adapter.vw-connect.1 in version "0.7.9" (non-npm: ta2k/ioBroker.vw-connect) started with pid 31737
      2025-04-18 14:10:24.425 - debug: vw-connect.1 (31737) Redis Objects: Use Redis connection: 0.0.0.0:9001
      2025-04-18 14:10:24.569 - debug: vw-connect.1 (31737) Objects client ready ... initialize now
      2025-04-18 14:10:24.585 - debug: vw-connect.1 (31737) Objects create System PubSub Client
      2025-04-18 14:10:24.589 - debug: vw-connect.1 (31737) Objects create User PubSub Client
      2025-04-18 14:10:24.859 - debug: vw-connect.1 (31737) Objects client initialize lua scripts
      2025-04-18 14:10:24.899 - debug: vw-connect.1 (31737) Objects connected to redis: 0.0.0.0:9001
      2025-04-18 14:10:25.094 - debug: vw-connect.1 (31737) Redis States: Use Redis connection: 0.0.0.0:9000
      2025-04-18 14:10:25.226 - debug: vw-connect.1 (31737) States create System PubSub Client
      2025-04-18 14:10:25.228 - debug: vw-connect.1 (31737) States create User PubSub Client
      2025-04-18 14:10:25.461 - debug: vw-connect.1 (31737) States connected to redis: 0.0.0.0:9000
      2025-04-18 14:10:25.664 - debug: vw-connect.1 (31737) Plugin sentry Initialize Plugin (enabled=true)
      2025-04-18 14:10:27.468 - info: vw-connect.1 (31737) starting. Version 0.7.9 (non-npm: ta2k/ioBroker.vw-connect) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v20.18.1, js-controller: 7.0.7
      2025-04-18 14:10:27.526 - info: vw-connect.1 (31737) Login in with skodae
      2025-04-18 14:10:28.177 - debug: vw-connect.1 (31737) parseEmailForm
      2025-04-18 14:10:28.370 - debug: vw-connect.1 (31737) emailPasswordForm2
      2025-04-18 14:10:28.612 - debug: vw-connect.1 (31737) ""
      2025-04-18 14:10:28.615 - debug: vw-connect.1 (31737) {"date":"Fri, 18 Apr 2025 12:10:28 GMT","content-length":"0","connection":"keep-alive"...
      2025-04-18 14:10:29.051 - debug: vw-connect.1 (31737) Error: Invalid protocol: myskoda:
      2025-04-18 14:10:29.285 - info: vw-connect.1 (31737) History limit: -1, set to -1 to disable wallcharging login
      2025-04-18 14:10:29.286 - info: vw-connect.1 (31737) History limit is set to -1, no wall charging login
      2025-04-18 14:10:29.288 - info: vw-connect.1 (31737) Login successful
      2025-04-18 14:10:29.515 - debug: vw-connect.1 (31737) get user data {"id":...
      2025-04-18 14:10:29.831 - debug: vw-connect.1 (31737) {"vehicles":[{"vin":"TMBJC9NY0MF......","name":"Enyaq",...
      2025-04-18 14:10:29.832 - info: vw-connect.1 (31737) Found 1 vehicles
      2025-04-18 14:10:30.244 - debug: vw-connect.1 (31737) Connecting to MQTT
      2025-04-18 14:10:30.562 - debug: vw-connect.1 (31737) Connected to MQTT
      2025-04-18 14:10:30.564 - debug: vw-connect.1 (31737) Connect to MQTT for TMBJC9NY0MF......
      2025-04-18 14:10:30.901 - debug: vw-connect.1 (31737) trip-statistics
      2025-04-18 14:10:30.902 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 500
      2025-04-18 14:10:30.903 - debug: vw-connect.1 (31737) "Internal server error"
      2025-04-18 14:10:30.904 - info: vw-connect.1 (31737) Server not available. For endpoint trip-statistics Please try again later:"Internal server error"
      2025-04-18 14:10:31.748 - debug: vw-connect.1 (31737) trip-statistics
      2025-04-18 14:10:31.749 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 500
      2025-04-18 14:10:31.750 - debug: vw-connect.1 (31737) "Internal server error"
      2025-04-18 14:10:31.750 - info: vw-connect.1 (31737) Server not available. For endpoint trip-statistics Please try again later:"Internal server error"
      2025-04-18 14:10:32.163 - debug: vw-connect.1 (31737) {"maintenanceReport":{"capturedAt":"2025-04-17T17:18:55.917Z",...
      2025-04-18 14:10:32.164 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.vehicle-maintenancevehicles
      2025-04-18 14:10:32.165 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:32.933 - debug: vw-connect.1 (31737) {"state":"OFF",...
      2025-04-18 14:10:32.934 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.air-conditioning
      2025-04-18 14:10:32.934 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:33.155 - debug: vw-connect.1 (31737) {"state":"INVALID","durationInSeconds":600,"timers":[],"errors":[{"type":"UNAVAILABLE_CLIMA_INFORMATION"}]}
      2025-04-18 14:10:33.155 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.air-conditioning.active-ventilation
      2025-04-18 14:10:33.156 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:33.156 - debug: vw-connect.1 (31737) [{"type":"UNAVAILABLE_CLIMA_INFORMATION"}]
      2025-04-18 14:10:33.655 - debug: vw-connect.1 (31737) air-conditioning /auxiliary-heating
      2025-04-18 14:10:33.655 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 500
      2025-04-18 14:10:33.656 - debug: vw-connect.1 (31737) "Unexpected data error occurred in AuxiliaryHeatingDto: \nstate must not be null"
      2025-04-18 14:10:33.657 - info: vw-connect.1 (31737) Server not available. For endpoint air-conditioning/auxiliary-heating Please try again later:"Unexpected data error occurred in AuxiliaryHeatingDto: \nstate must not be null"
      2025-04-18 14:10:33.657 - debug: vw-connect.1 (31737) Vehicle is not supporting air-conditioning /auxiliary-heating
      2025-04-18 14:10:33.690 - debug: vw-connect.1 (31737) air-conditioning /settings
      2025-04-18 14:10:33.691 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 403
      2025-04-18 14:10:33.692 - debug: vw-connect.1 (31737) ""
      2025-04-18 14:10:34.446 - debug: vw-connect.1 (31737) {"isVehicleInSavedLocation":false,"status":...
      2025-04-18 14:10:34.447 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.charging
      2025-04-18 14:10:34.448 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:34.489 - debug: vw-connect.1 (31737) charging /settings
      2025-04-18 14:10:34.492 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 404
      2025-04-18 14:10:34.494 - debug: vw-connect.1 (31737) {"timestamp":"2025-04-18T12:10:34.459+00:00","path":...
      2025-04-18 14:10:34.495 - debug: vw-connect.1 (31737) Vehicle is not supporting charging /settings
      2025-04-18 14:10:34.798 - debug: vw-connect.1 (31737) {"overall":{"doorsLocked":"YES",...
      2025-04-18 14:10:34.800 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.vehicle-status
      2025-04-18 14:10:34.801 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:35.665 - debug: vw-connect.1 (31737) {"parkingPosition":...
      2025-04-18 14:10:35.666 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.position
      2025-04-18 14:10:35.667 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:35.668 - debug: vw-connect.1 (31737) Set is car moving to false
      2025-04-18 14:10:35.839 - debug: vw-connect.1 (31737) {"carType":"electric",...
      2025-04-18 14:10:35.840 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.vehicle-status.driving-range
      2025-04-18 14:10:35.841 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:35.968 - debug: vw-connect.1 (31737) {"capturedAt":"2025-04-17T17:18:55.917Z","inspectionDueInDays"...
      2025-04-18 14:10:35.969 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.vehicle-maintenancevehicles.report
      2025-04-18 14:10:35.970 - debug: vw-connect.1 (31737) 200
      2025-04-18 14:10:36.084 - debug: vw-connect.1 (31737) fueling/sessions
      2025-04-18 14:10:36.086 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 404
      2025-04-18 14:10:36.087 - debug: vw-connect.1 (31737) "Resource not found"
      2025-04-18 14:10:36.088 - debug: vw-connect.1 (31737) Vehicle is not supporting fueling/sessions
      2025-04-18 14:10:36.165 - debug: vw-connect.1 (31737) fueling/sessions /state
      2025-04-18 14:10:36.167 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 404
      2025-04-18 14:10:36.168 - debug: vw-connect.1 (31737) "Resource not found"
      2025-04-18 14:10:36.168 - debug: vw-connect.1 (31737) Vehicle is not supporting fueling/sessions /state
      2025-04-18 14:10:36.478 - debug: vw-connect.1 (31737) fueling/locations
      2025-04-18 14:10:36.482 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 404
      2025-04-18 14:10:36.483 - debug: vw-connect.1 (31737) "Resource not found"
      2025-04-18 14:10:36.493 - debug: vw-connect.1 (31737) Vehicle is not supporting fueling/locations
      2025-04-18 14:10:36.550 - debug: vw-connect.1 (31737) fueling/sessions /latest
      2025-04-18 14:10:36.551 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 404
      2025-04-18 14:10:36.551 - debug: vw-connect.1 (31737) {"timestamp":"2025-04-18T12:10:36.503+00:00","path":...
      2025-04-18 14:10:36.552 - debug: vw-connect.1 (31737) Vehicle is not supporting fueling/sessions /latest
      2025-04-18 14:10:36.629 - debug: vw-connect.1 (31737) {"devicePlatform":"WCAR","vehicleSpecification":{"title":"Škoda Enyaq",...
      2025-04-18 14:10:36.630 - debug: vw-connect.1 (31737) TMBJC9NY0MF.......status.vehicle-information
      2025-04-18 14:10:36.630 - debug: vw-connect.1 (31737) 200
      Eine Stunde später bricht dann wieder die MQTT Verbindung ab und nichts geht mehr:
      2025-04-18 15:11:29.021 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:11:29.179 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:11:29.181 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:12:29.182 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:12:29.320 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:12:29.322 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:13:29.323 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:13:29.500 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:13:29.502 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:14:29.503 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:14:29.637 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:14:29.640 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:15:29.640 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:15:29.769 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:15:29.771 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:16:29.772 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:16:29.903 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:16:29.906 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:17:29.906 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:17:30.070 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:17:30.074 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:18:30.074 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:18:30.200 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:18:30.204 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:19:30.204 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:19:30.316 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:19:30.319 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:20:30.319 - info: vw-connect.1 (31737) MQTT Reconnecting
      2025-04-18 15:20:30.471 - error: vw-connect.1 (31737) MQTT Error: ErrorWithReasonCode: Connection refused: Bad username or password
      2025-04-18 15:20:30.473 - info: vw-connect.1 (31737) MQTT Connection closed
      2025-04-18 15:20:30.574 - debug: vw-connect.1 (31737) trip-statistics
      2025-04-18 15:20:30.574 - debug: vw-connect.1 (31737) AxiosError: Request failed with status code 401
      2025-04-18 15:20:30.575 - debug: vw-connect.1 (31737) ""
      2025-04-18 15:20:30.575 - error: vw-connect.1 (31737) ""
      2025-04-18 15:20:30.575 - error: vw-connect.1 (31737) AxiosError: Request failed with status code 401
      2025-04-18 15:20:30.575 - error: vw-connect.1 (31737) https://mysmob.api.connect.skoda-auto.cz/api/v1/trip-statistics/TMBJC9NY0MF......
      Benjamin Häublein 1 Reply Last reply Reply Quote 0
        kurt6908 @kurt6908 last edited by
        ich möchte meinen Post vom Juli 2024 nochmal rausholen. In der neuen Version 0.7.9 findet sich unter remote der Schalter weiterhin nicht. Wäre es nicht möglich, den dort wieder einzubauen?
        Vielen Dank.
        Kurt
        K K 2 Replies Last reply Reply Quote 0
          Kusi @kurt6908 last edited by
          Ich vermisse den Datenpunkt, welcher mir die Rückmeldung gibt, dass "kein Ladekabel" eingesteckt ist.
          Beim Datenpunkt "vw-connect.0.TMBGF9NY6PFxxxxxx.status.charging.status.state" erhalte ich nur die States
          "CONNECT_CABLE" (Ladekabel eingesteckt),
          "READY_FOR_CHARGING" (Bereit zum Laden) und
          "CHARGING" (am laden).
          Hat dieser jemand gefunden oder fehlt der seit der neuen Struktur?
            mading @Kusi last edited by
            @kusi sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
            Bei mir existiert dieser: vw-connect.0.xxx.status.chargingStatus.chargingState
              Kusi @mading last edited by Kusi
              @mading Bei mir fehlt dieser Datenpunkt.
              Das Fahrzeug ist zur Zeit NICHT eingesteckt.
                Kusi @Kusi last edited by
                Ich habe etwas unter "air-conditioning" gefunden, was es sein könnte...
                Momentan ist das Kabel eingesteckt, werde es spätestens morgen überprüfen.
                  kurt6908 @kurt6908 last edited by kurt6908
                  Ich meinte den Schalter für den reduzierten AC-Ladestrom.
                  Der Status taucht im Adapter aktuell unter
                  vw-connect.0.xxxxxxxx.status.chargingSettings.maxChargeCurrentAC
                  auf, fehlt jedoch unter remote.
                  Hant0r 1 Reply Last reply Reply Quote 0
                  • Hant0r
                    Hant0r @kurt6908 last edited by
                    @kurt6908 das hatte ich weiter oben auch schon angemerkt. Hat sich leider bisher nichts getan. Nutze den Schalter für die automatische Umschaltung je nach PV Ertrag... Leider aktuell nur manuell
                      Matis last edited by Matis
                      Ich fände es super hilfreich, wenn ich auch die Ladegrenze für zuhause ändern könnte:
                      vw-connect.1.WVGZZZE2ZNxxxxx.status.chargingProfilesStatus.profiles01.targetSOC_pct
                      Beschreibbar ist es ja, wird aber nicht von VW übernommen. Mache ich da was falsch oder geht das nicht?
                        mading @Matis last edited by
                        @matis sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                        Geht nicht, habe es auch schon versucht. Bzw. hat er es sporadisch übernommen.
                          Du könntest einmal den Adapter stoppen, den kompletten Baum löschen und den Adapter wieder starten, damit der Baum neu generiert wird. Eventuelle influx/ history Einstellungen an DPs sind dann aber weg.
                            @mading sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                            Das habe ich gemacht, danach musste ich die vis anpassen.
                              JMA @Kusi last edited by
                              @kusi deswegen arbeite ich bei solchen Sachen immer mit "alias"....
                                Maddm last edited by
                                Seit Mitte der Woche darf ich in diesem Thread auch "aktiv" mitmachen, da ich meinen Cupra Born abholen konnte.
                                Ich habe den Adapter 0.79 aus GitHub installiert und dann die Instanz konfiguriert und beim ersten aktivieren hat der Adapter auch fleissig Daten abgezogen.
                                Ich habe dann eine Änderung an der Konfig der Instanz gemacht (Position in Adresse wandeln, anzahl zu ladender Trips auf 10 erhöht) und "Langzeit" abgehakt) und bekomme jetzt die schon häufiger hier im Thread auftauchende Meldung
                                No Token received. Please try to logout and login in the latest MySkoda or MySeat App
                                Hier wurde geschrieben, dass es bei der 0.77 Version anscheinend geht - das würde ich gern ausprobieren, aber wie kann ich denn per GitHub eine "ältere" Version installieren?
                                Hant0r arteck 2 Replies Last reply Reply Quote 0
                                • Hant0r
                                  Hant0r @Maddm last edited by
                                  @maddm das wurde weiter oben schon mal gefragt und beantwortet 😉
                                    Hmm, es bleibt auch mit der 0.77 beim genannten "No token received" Fehler. Dann kann ich auch wieder die 0.79 nehmen und warten mal ne Stunde, scheint ja ne Art "zeitliches" Problem zu sein.
                                      arteck Developer Most Active @Maddm last edited by
                                      @maddm sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
                                      da ist noch melh im LOG als nur die eine Zeile..
                                        Maddm @arteck last edited by
                                        @arteck
                                        Ok, ich dachte dass die Fehlermeldung selbst das Aufschlussreichste wäre.
                                        Hier der komplette Logauszug, den der vw_connect Adapter nach dem Start von sich gibt:
                                        vw-connect.0
                                        2025-04-25 09:25:13.126	error	No Token received. Please try to logout and login in the latest MySkoda or MySeat App
                                        vw-connect.0
                                        2025-04-25 09:25:12.786	info	https://identity.vwgroup.io/signin-service/v1/consent/users/49b04725-05b2-4f3e-aaff-b935b350337e/99a5b77d-bd88-4d53-b4e5-a539c60694a3@apps_vw-dilab_com?scopes=openid%20profile%20nickname%20birthdate%20phone&relayState=de6ea779bc5f01a7d20470dbd28e201b660c3649&callback=https://identity.vwgroup.io/oidc/v1/oauth/client/callback&hmac=60e530133c6389e1b4fb6101dcf9207fe187d702792ea4ac5551efbb3a122cc5
                                        vw-connect.0
                                        2025-04-25 09:25:12.785	warn	No Token received visiting url and accept the permissions or login in the App and accept manually
                                        vw-connect.0
                                        2025-04-25 09:25:11.871	info	Login in with seatcupra
                                        vw-connect.0
                                        2025-04-25 09:25:11.859	info	starting. Version 0.7.9 (non-npm: TA2k/ioBroker.vw-connect#2187cb547af1f3414f2ee12675ed39e8a552caf0) in /opt/iobroker/node_modules/iobroker.vw-connect, node: v20.19.0, js-controller: 7.0.6
                                        Eine Ab- und Anmeldung in der MyCupra App habe ich gemacht.
                                        Im Log steht was von "accept the permissions" --> muss ich hier noch irgendwo in der App selbst etc. was freigeben/anhaken/aktivieren?
                                        K arteck 2 Replies Last reply Reply Quote 0
                                          Kusi @Maddm last edited by
                                          @maddm Im Internet auf der Website "CupraOffizial" anmelden.
                                            Maddm @Kusi last edited by
                                            @kusi Habe ich gemacht, ausser einem üblichen "welche Cookies willst du akzeptieren" kommt da nichts zum Thema "Nutzungsbedingungen", das ich bestätigen könnte 😞
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            401
                                            3117
                                            1622582
