    5. Werte aus Text und Mittelwert berechnen
    • haus-automatisierung
      haus-automatisierung Developer Most Active @JoJo58 last edited by
      @jojo58 So z.B.
      Geht aber bestimmt auch eleganter
        <variables>
          <variable id="0qMo2W}Kq_]r}pKv?1vm">text</variable>
          <variable id="x7~jx3L$wieq,D+zr=!(">temps</variable>
          <variable id="MLf-it[+Dt[|c@mAEe4(">zeile</variable>
        </variables>
        <block type="variables_set" id="7Ucg_OX_*N)bq0%Kl_a)" x="163" y="63">
          <field name="VAR" id="0qMo2W}Kq_]r}pKv?1vm">text</field>
            <block type="text_multiline" id="cy;o?qx~`eF^UN]UqZul">
              <field name="TEXT">Package id 0:&amp;#10;Core 0: +59.0°C&amp;#10;Core 1: +58.0°C&amp;#10;Core 2: +64.0°C&amp;#10;Core 3: +62.0°C&amp;#10;Core 4: +58.0°C&amp;#10;Core 5: +54.0°C</field>
            <block type="variables_set" id="IH)|e{lmuaE)T]`@I^?a">
              <field name="VAR" id="x7~jx3L$wieq,D+zr=!(">temps</field>
                <block type="lists_create_with" id="=|s:yEwawraI%,*eZ9H/">
                <block type="controls_forEach" id="J_ad`K%~~2dNftid)]P)">
                  <field name="VAR" id="MLf-it[+Dt[|c@mAEe4(">zeile</field>
                  <value name="LIST">
                    <block type="lists_split" id="~F$]Wk0FMe,c)^2h3@K?">
                      <mutation mode="SPLIT"></mutation>
                      <field name="MODE">SPLIT</field>
                      <value name="INPUT">
                        <block type="variables_get" id="=o8Hj9[I8fwhA:o_lf+z">
                      <value name="DELIM">
                        <shadow type="text" id="c%6LCj4K8ve~$$wD$m|X">
                          <field name="TEXT">,</field>
                        <block type="text_newline" id="n~rV|d@73=w?eZH2gnra">
                          <field name="Type">\n</field>
                  <statement name="DO">
                    <block type="controls_if" id="v]2Q`|tZh4mqq%7=-h-)">
                        <block type="text_contains" id="fm:,r?W2bP3^!SDLwOKN">
                            <block type="variables_get" id="R|}r:]vxm8.]0_d/`tVx">
                          <value name="FIND">
                            <shadow type="text" id="B;Qv*h90:L8HiNMh#*W(">
                              <field name="TEXT">Core </field>
                        <block type="lists_setIndex" id="eMS@W;3A2[OeDKBTII!B">
                          <mutation at="false"></mutation>
                          <field name="WHERE">LAST</field>
                          <value name="LIST">
                            <block type="variables_get" id="K6K?kt4G_-$McHeXdr1b">
                          <value name="TO">
                            <block type="convert_tonumber" id="K`iJtTg^1c%cbK?=Rl)0">
                                <block type="text_getSubstring" id="pm7jmow)[[g=`U^Sv2ZA" inline="false">
                                  <mutation at1="true" at2="true"></mutation>
                                  <field name="WHERE1">FROM_START</field>
                                  <field name="WHERE2">FROM_START</field>
                                  <value name="STRING">
                                    <block type="variables_get" id="LC[^)s9n=+eRjpY$$m73">
                                  <value name="AT1">
                                    <block type="math_arithmetic" id="C_=(CgSmAJLu}7^q%.=q">
                                      <field name="OP">ADD</field>
                                        <shadow type="math_number" id=",@QKm_VOfV.Smev`PfNS">
                                          <field name="NUM">1</field>
                                        <block type="text_indexOf" id="6+agAoxdPGQr15}plp|g">
                                          <field name="END">FIRST</field>
                                            <block type="variables_get" id="9TfSPs[3$eFU=@Fi`v6*">
                                          <value name="FIND">
                                            <shadow type="text" id=";aX65G3Gjkzv}4t^vIrk">
                                              <field name="TEXT">+</field>
                                        <shadow type="math_number" id="19L}i~!w}b%7(p^$aY+w">
                                  <value name="AT2">
                                    <block type="math_arithmetic" id="WqSv1/!M4VF=h,po@jzT">
                                        <shadow type="math_number" id="6f#D0qeMn7wuECIxM+o0">
                                        <block type="text_indexOf" id="ZC!j*$!D(SQ(B1?`M({c">
                                            <block type="variables_get" id="/8m[T=GWFR99Z=|*+tH#">
                                          <value name="FIND">
                                            <shadow type="text" id="3:oJ2zHC}31[^9jGLs{i">
                                              <field name="TEXT">°C</field>
                                        <shadow type="math_number" id="_sHFhGfp6/o-k7UvGy$s">
                    <block type="debug" id="%Yk%{UA$F03t$BnC3FWE">
                      <field name="Severity">info</field>
                      <value name="TEXT">
                        <shadow type="text" id="FhVtLn]]J=wJtP`=tv]9">
                        <block type="math_rndfixed" id="hZ8W0k{Jt/ICe_9Ab5Ui">
                          <field name="n">2</field>
                          <value name="x">
                            <shadow type="math_number" id="]80=H[TgUUt[jq:Z2whZ">
                              <field name="NUM">3.1234</field>
                            <block type="math_on_list" id="I7Z)L3kX|jp@uzt~|;9L">
                              <mutation op="AVERAGE"></mutation>
                              <field name="OP">AVERAGE</field>
                              <value name="LIST">
                                <block type="variables_get" id="He)C|$TZ3m*3Ll_?)3C=">
      haus-automatisierung Homoran 2 Replies Last reply Reply Quote 1
        haus-automatisierung Developer Most Active @haus-automatisierung last edited by
        Per JavaScript natürlich deutlich kürzer:
        const text = `
        Package id 0:
        Core 0: +59.0°C
        Core 1: +58.0°C
        Core 2: +64.0°C
        Core 3: +62.0°C
        Core 4: +58.0°C
        Core 5: +54.0°C
        const temps = [...text.matchAll(/Core \d+: \+([\d.]+)°C/g)].map(match => parseFloat(match[1]));
        const average = temps.reduce((sum, temp) => sum + temp, 0) / temps.length;
        console.log(`Durchschnittstemperatur: ${average.toFixed(2)}`);
          paul53 @JoJo58 last edited by paul53
          @jojo58 sagte: Wie bekomme ich da jetzt den Mittelwert raus?
          Eine Version:
            Homoran Global Moderator Administrators @haus-automatisierung last edited by Homoran
            @haus-automatisierung sagte in Werte aus Text und Mittelwert berechnen:
            warum dann nicht doch
            @jojo58 sagte in Werte aus Text und Mittelwert berechnen:
            Einfach alle Werte addieren und dann durch 6 teilen
            ich halte das Arbeiten mit der Liste in diesem Fall für zu umständlich.
            EDIT:
            Wenn ich auf die Lösung von @Paul53 gekommen wäte, sähe die Aussage anders aus 😁
              haus-automatisierung Developer Most Active @Homoran last edited by haus-automatisierung
              @homoran sagte in Werte aus Text und Mittelwert berechnen:
              Vorteil ist halt, dass man die Länge / Anzahl der Elemente auch direkt kennt und nicht noch eine Zähl-Variable mitschleppen muss. Also einfach zur Liste hinzufügen und am Ende mit dem Baustein den Mittelwert holen...
              Meine Variante funktioniert immer. Egal ob 2 oder 24 Cores. Und ob die erste Zeile des Textes enthalten ist oder nicht spielt auch keine Rolle.
              JoJo58 1 Reply Last reply Reply Quote 1
              • JoJo58
                JoJo58 @haus-automatisierung last edited by JoJo58
                Das Blockly von dir verstehe ich nach kurzem Nachdenken sogar 😉 (und es funktioniert), bei dem von @paul53 sieht es schon anders aus, das wird bestimmt auch funktionieren, aber ich verstehe nicht wie? 😲
                @haus-automatisierung Kann ich die Liste "temps" auch direkt nutzen um daraus den JSON DP zu erzeugen?
                EDIT:
                Ist Quatsch, das geht nicht so einfach, da ich dann nur die Spalte mit Werte ohne Zuordnung zu Core oder Mittelwert habe. Sorry, zu kurz gedacht. 😞
                • mickym
                  Mitt JSONATA und Blockly gehts noch kürzer, aber bevor ich dann wieder Kritik ernte, werde ich die Lösung nur auf Wunsch vorstellen.
                  JoJo58 1 Reply Last reply Reply Quote 0
                  • JoJo58
                    JoJo58 @mickym last edited by
                    @mickym
                    Wüßte nicht, warum ich deinen Vorschlag kritisieren sollte? Oder war das allgemein gemeint?
                    Ich habe es jetzt mit der Version von @haus-automatisierung gelöst und das läuft erst mal.
                    Danke für die schnelle Hilfe und eure Vorschläge. Hab gerade gesehen das @paul53 das noch mal angepasst hat, ich baue das auch noch nach, alleine schon um etwas zu lernen. 🙂
                    mickym 1 Reply Last reply Reply Quote 1
                      @jojo58 sagte: JSON erstellen, so das ich die aktuellen Werte inklusive Mittelwert in VIS darstellen kann.
                      Vorschlag:
                      JoJo58 2 Replies Last reply Reply Quote 0
                      • mickym
                        mickym Most Active @JoJo58 last edited by
                        Dann hier mal meine Lösung - ein neues Objekt zu erstellen ist damit auch sehr einfach, aber keine Ahnung, wie Du das haben willst.
                        Hier das JSONATA:
                        $match($,/\d+\.\d/).$number(match)~>$average()~>$round(2)
                        und hier das Blockly zum Import:
                         <variables>
                           <variable id="hu+F[F+=/+n6(w#b!bkk">Text</variable>
                         </variables>
                         <block type="variables_set" id="^~Sv#fxrrEl3v%:$_j(K" x="-137" y="63">
                           <field name="VAR" id="hu+F[F+=/+n6(w#b!bkk">Text</field>
                             <block type="text" id="}KJz}$Rs!%XxMZl%j4_w">
                               <field name="TEXT">Package id 0: Core 0: +59.0°C Core 1: +58.0°C Core 2: +64.0°C Core 3: +62.0°C Core 4: +58.0°C Core 5: +54.0°C</field>
                             <block type="debug" id="k08ZC410l/7`T|+g_+w@">
                               <value name="TEXT">
                                 <shadow type="text" id=",T!NCf4e|u/ADp:g1bn[">
                                 <block type="text_join" id="~F~v3J+nR#hK*ocxCF#X">
                                   <value name="ADD0">
                                     <block type="text" id="C}wpA(/bWjvr.r;!:{9q">
                                       <field name="TEXT">Mittelwert (gerundet 2 Dezimalstellen): </field>
                                   <value name="ADD1">
                                     <block type="convert_jsonata" id="u}[_Z`KWHAeHkdE@@V?=">
                                       <value name="EXPRESSION">
                                         <shadow type="text" id="eg-6.rV=oGTM`RArquVg">
                                           <field name="TEXT">$match($,/\d+\.\d/).$number(match)~&gt;$average()~&gt;$round(2)</field>
                                       <value name="TARGET">
                                         <block type="variables_get" id="n+aI}jp_T]nxZ439rGaK">
                         <block type="convert_json2object" id="1-ME3y(y.YrZvl:v}Pb`" x="388" y="438"></block>
                        • JoJo58
                          @mickym
                          Danke, werde ich auch ausprobieren. 🙂
                          • JoJo58
                            JoJo58 @paul53 last edited by
                            @paul53 sagte in Werte aus Text und Mittelwert berechnen:
                            Vorschlag:
                            Das wird ja immer besser. Danke... 🙂 👍 Ich sage Bescheid, sobald ich es nachgebaut habe. Werde aber wohl erst Montag dazu kommen, da wir ab morgen früh für ein paar Tage weg sind.
                            • JoJo58
                              Moin, bin eben erst dazu gekommen, das aus deinem Post nachzubauen. Es hat auf Anhieb funktioniert und hier mal das Blockly und das Ergebnis:
                              Danke für die Vorlage. Wieder etwas dazugelernt. 👍
                              295
