    4. Backitup: Aktuelle Backups werden nicht angezeigt
    • N
      Nas007 @simatec last edited by Nas007
      @simatec Ich habe nicht relevante Informationen unkenntlich gemacht (Nicht aber die Einstellungen)
        "_id": "system.adapter.backitup.0",
        "common": {
          "name": "backitup",
          "version": "2.6.23",
          "title": "BackItUp",
          "authors": [
            "simatec <backitup@simateccloud.de>",
            "bluefox <dogafox@gmail.com>"
          "osDependencies": {
            "linux": [
              "cifs-utils",
              "nfs-common"
          "docs": {
            "en": "docs/en/backitup.md",
            "de": "docs/de/backitup.md"
          "platform": "Javascript/Node.js",
          "mode": "daemon",
          "compact": true,
          "icon": "backitup.png",
          "materialize": true,
          "messagebox": true,
          "stopBeforeUpdate": true,
          "connectionType": "local",
          "dataSource": "assumption",
          "materializeTab": true,
          "adminTab": {
            "name": {
              "en": "Backup",
              "de": "Backup",
              "ru": "Резервное копирование",
              "pt": "Cópia de segurança",
              "nl": "Back-up",
              "fr": "Sauvegarde",
              "it": "Backup",
              "es": "Respaldo",
              "pl": "Utworzyć kopię zapasową"
            "ignoreConfigUpdate": true,
            "singleton": false,
            "fa-icon": "</i><img style='width:24px;margin-bottom:-6px;' src='/adapter/backitup/backitup.svg'><i>"
          "adminUI": {
            "config": "materialize",
            "tab": "materialize"
          "enabled": true,
          "extIcon": "https://raw.githubusercontent.com/simatec/ioBroker.backitup/master/admin/backitup.png",
          "keywords": [
            "Backup",
            "IoBroker",
            "Homematic"
          "readme": "https://github.com/simatec/ioBroker.backitup/blob/master/README.md",
          "loglevel": "debug",
          "type": "general",
          "license": "MIT",
          "plugins": {
            "sentry": {
              "dsn": "https://e8510540c3a343aa8ce5678a4b3c8107@sentry.iobroker.net/36"
          "installedFrom": "iobroker.backitup@2.6.23",
          "installedVersion": "2.6.23",
          "host": "host",
          "logLevel": "info",
          "dependencies": [
              "js-controller": ">=4.0.0"
          "globalDependencies": [
              "admin": ">=6.0.0"
          "messages": [
              "condition": {
                "operand": "and",
                "rules": [
                  "oldVersion<2.5.0",
                  "newVersion>=2.5.0"
              "title": {
                "en": "Re-authenticate Google Drive after Update!",
                "de": "Re-authenticate Google Drive nach Update!",
                "ru": "Re-аутентификация Google Drive после обновления!",
                "pt": "Re-autenticação Google Drive após atualização!",
                "nl": "Re-authentic Google Drive na Update!",
                "fr": "Re-authenticate Google Drive après mise à jour!",
                "it": "Rinforzo Google Drive dopo Aggiornamento!",
                "es": "Reauthenticate Google Drive after Update!",
                "pl": "Ponowny autentyczny Google Drive (ang.)!",
                "uk": "Реабілітація Google Диск після оновлення!",
                "zh-cn": "逮捕 谷歌博士在最新情况之后!"
              "text": {
                "en": "After installing this update the google drive access token needs to be re-authenticated in the Instance-Settings! Of course, only if google drive is used.",
                "de": "Nach der Installation dieses Updates muss der google drive access token in den Instanz-Settings neu authentifiziert werden! Natürlich nur, wenn Google-Drive verwendet wird.",
                "ru": "После установки этого обновления токен доступа Google для доступа должен быть повторно авторизован в Instance-Settings! Конечно, только если Google Drive используется.",
                "pt": "Depois de instalar esta atualização o token de acesso de unidade do google precisa ser re-autenticado nas configurações de instância! Claro, só se o Google Drive é usado.",
                "nl": "Na het installeren van deze update moet de Google drive toegang tot token opnieuw geauthenticeerd worden in de Instance-Settings! Natuurlijk, alleen als Google Drive gebruikt wordt.",
                "fr": "Après l'installation de cette mise à jour, le jeton d'accès au lecteur google doit être réauthentifié dans le cas-Settings! Bien sûr, seulement si le lecteur de google est utilisé.",
                "it": "Dopo l'installazione di questo aggiornamento l'accesso a Google Drive token ha bisogno di essere ri-authenticated nelle Impostazioni di istanza! Naturalmente, solo se Google Drive viene utilizzato.",
                "es": "Después de instalar esta actualización, el acceso de la unidad de Google token tiene que ser re-authenticated en la Instance-Settings! Por supuesto, sólo si se utiliza la unidad de Google.",
                "pl": "Po zainstalowaniu tej aktualizacji znak dostępu do google musi zostać przywrócony w Instance-Settings! Z biegiem tylko wtedy, gdy używa się google.",
                "uk": "Після встановлення цього оновлення токени доступу Google повинні бути переоцінені в Instance-Settings! Звичайно, тільки якщо використовується Google Drive.",
                "zh-cn": "在安装这一最新消息之后,在Setting-Settings需要重新得到治疗。 当然,只使用了防污。."
              "level": "warn",
              "buttons": [
                "agree",
                "cancel"
        "native": {
          "minimalEnabled": true,
          "ccuEnabled": false,
          "redisEnabled": false,
          "javascriptsEnabled": true,
          "zigbee2mqttEnabled": false,
          "zigbeeEnabled": false,
          "historyEnabled": false,
          "influxDBEnabled": true,
          "mySqlEnabled": false,
          "pgSqlEnabled": false,
          "sqliteEnabled": false,
          "grafanaEnabled": false,
          "noderedEnabled": false,
          "yahkaEnabled": false,
          "jarvisEnabled": false,
          "cifsEnabled": false,
          "ftpEnabled": false,
          "dropboxEnabled": false,
          "googledriveEnabled": false,
          "webdavEnabled": false,
          "onedriveEnabled": true,
          "notificationEnabled": true,
          "restoreTab": false,
          "debugLevel": true,
          "sentry_enable": false,
          "ignoreErrors": false,
          "historyEntriesNumber": "25",
          "fileSizeWarning": "1024",
          "fileSizeError": "512",
          "hostType": "Single",
          "slaveInstance": [],
          "slaveNameSuffix": "",
          "stopSlaveAfter": false,
          "minimalTime": "21:00",
          "minimalEveryXDays": "1",
          "minimalDeleteAfter": "30",
          "minimalNameSuffix": "",
          "ccuTime": "01:30",
          "ccuEveryXDays": "3",
          "ccuDeleteAfter": "10",
          "ccuHost": "",
          "ccuUser": "Admin",
          "ccuPassword": "",
          "ccuUsehttps": false,
          "ccuSignedCertificates": true,
          "ccuMulti": false,
          "mySqlHost": "",
          "mySqlPort": "",
          "mySqlName": "",
          "mySqlUser": "",
          "mySqlPassword": "",
          "mySqlDumpExe": "",
          "mysqlQuick": false,
          "mysqlSingleTransaction": false,
          "mySqlMulti": false,
          "pgSqlHost": "",
          "pgSqlPort": "5432",
          "pgSqlName": "",
          "pgSqlUser": "",
          "pgSqlPassword": "",
          "pgSqlDumpExe": "",
          "pgSqlMulti": false,
          "grafanaHost": "",
          "grafanaPort": "3000",
          "grafanaProtocol": "http",
          "grafanaUsername": "",
          "grafanaPassword": "",
          "grafanaApiKey": "",
          "grafanaSignedCertificates": true,
          "influxDBType": "local",
          "influxDBHost": "localhost",
          "influxDBPort": "8090",
          "influxDBProtocol": "http",
          "influxDBVersion": "1.x",
          "influxDBName": "",
          "influxDBDumpExe": "",
          "influxDBToken": "",
          "influxDBMulti": false,
          "deleteOldDataBase": false,
          "sqlitePath": "/opt/sqlite/data.db",
          "sqliteDumpExe": "",
          "redisType": "local",
          "redisPath": "/var/lib/redis",
          "redisAOFactive": false,
          "redisHost": "",
          "redisPort": "6379",
          "redisUser": "",
          "redisPassword": "",
          "historyPath": "media/usb/history",
          "zigbee2mqttPath": "/var/lib/docker/volumes/zigbee2mqtt/_data",
          "notificationsType": "Telegram",
          "telegramInstance": "telegram.0",
          "telegramUser": "allTelegramUsers",
          "telegramNoticeType": "longTelegramNotice",
          "telegramWaitToSend": "0",
          "telegramSilentNotice": true,
          "telegramOnlyError": false,
          "whatsappInstance": "",
          "whatsappNoticeType": "longWhatsappNotice",
          "whatsappWaitToSend": "0",
          "whatsappOnlyError": false,
          "signalInstance": "",
          "signalNoticeType": "longSignalNotice",
          "signalWaitToSend": "0",
          "signalOnlyError": false,
          "matrixInstance": "",
          "matrixNoticeType": "longMatrixNotice",
          "matrixWaitToSend": "0",
          "matrixOnlyError": false,
          "pushoverInstance": "",
          "pushoverNoticeType": "longPushoverNotice",
          "pushoverWaitToSend": "0",
          "pushoverDeviceID": "",
          "pushoverSilentNotice": false,
          "pushoverOnlyError": false,
          "emailReceiver": "xxx@xxx.com",
          "emailSender": "xxx@xxx.com",
          "emailInstance": "",
          "emailNoticeType": "longEmailNotice",
          "emailWaitToSend": "0",
          "emailOnlyError": false,
          "connectType": "CIFS",
          "cifsMount": "192.xxx.xxx.xx",
          "cifsDomain": "",
          "smbType": "vers=2.0",
          "cifsUser": "rasp",
          "cifsPassword": "q@\\\\qa\u0007U_\r\u001f",
          "noserverino": false,
          "sudoMount": true,
          "cifsDeleteOldBackup": false,
          "cifsOwnDir": false,
          "wakeOnLAN": false,
          "macAd": "20:DE:19:AB:01:DE",
          "wolWait": "25",
          "cifsMinimalDir": "/Raspberry_Pi/IoBroker",
          "cifsCcuDir": "/Raspberry_Pi/IoBroker",
          "cifsDir": "Raspberry_Pi/IoBroker",
          "ftpHost": "ftp.xxxxx.xxxxx.com",
          "ftpPort": "21",
          "ftpUser": "xxxx",
          "ftpPassword": "p@XO|Vv\u0016+Y\u0014",
          "ftpDeleteOldBackup": false,
          "ftpSecure": false,
          "ftpOwnDir": false,
          "ftpSignedCertificates": true,
          "ftpMinimalDir": "/backupDir/iobroker",
          "ftpCcuDir": "/backupDir/ccu",
          "ftpDir": "/Privat/02_IoBroker",
          "webdavURL": "https://webdav.xxxxxxxx.com",
          "webdavUsername": "safe-xxxx",
          "webdavPassword": "p@XO|Vv\u0005\u0006aPf\u0014",
          "webdavSignedCertificates": true,
          "webdavDeleteOldBackup": false,
          "webdavOwnDir": false,
          "webdavMinimalDir": "/backupDir/iobroker",
          "webdavCcuDir": "/backupDir/ccu",
          "webdavDir": "/users/xxxx/02_IoBroker/ ",
          "dropboxTokenType": "custom",
          "dropboxAccessJson": "",
          "dropboxCodeChallenge": "",
          "dropboxAccessToken": "",
          "dropboxDeleteOldBackup": false,
          "dropboxOwnDir": false,
          "dropboxMinimalDir": "/backupDir/iobroker",
          "dropboxCcuDir": "/backupDir/ccu",
          "dropboxDir": "/backupDir",
          "onedriveAccessJson": "M.C107_BL2.-CTZ6cIi16cb8ERkUBs7pNS*myVrf98JBFbl9R!NBET3MksS3zdWk*ggaJ4xyUgep71L9iCYC87Tp746ubv6OdlGySnEJJ0vY5sjZl7yIWUx7UbJlSRoMoRTQHs6azJZ8oPJsjBFrHN6dNzTBxfYdp3BbRe9X!mzpaY8AXw$",
          "onedriveDeleteOldBackup": true,
          "onedriveOwnDir": true,
          "onedriveMinimalDir": "100_Iobroker/iobroker",
          "onedriveCcuDir": "100_Iobroker/ccu",
          "onedriveDir": "backupDir",
          "googledriveAccessTokens": "",
          "googledriveDeleteOldBackup": false,
          "googledriveOwnDir": false,
          "googledriveMinimalDir": "/backupDir/iobroker",
          "googledriveCcuDir": "/backupDir/ccu",
          "googledriveDir": "/backupDir",
          "restoreSource": "local",
          "startAllRestore": false,
          "ccuEvents": [],
          "influxDBEvents": [],
          "mySqlEvents": [],
          "pgSqlEvents": []
      • simatec
        simatec Developer Most Active @Nas007 last edited by
        @nas007 sagte in Backitup: Aktuelle Backups werden nicht angezeigt:
        Nach dem gestrigen automatischen Backup wurde das aber nicht umgesetzt. Es sind immer noch je 37 Backups vorhanden.
        Hätte das nicht bei dem letzten automatischen Backup dann auf die 30 neusten reduziert werden müssen?
        Config sieht soweit gut aus... Hast du Fehler im automatischen Backup? Poste mal den Debuglog vom automatischen Backup.
        Wenn ein Fehler auftritt, wird aus Sicherheitsgründen nicht gelöscht.
        terraPole 1 Reply Last reply Reply Quote 0
        • terraPole
          terraPole @simatec last edited by
          @simatec
          Hallo, ich habe ein ähnliches Problem. Da meine alte MicroSD im raspi defekt war habe ich heute eine neue eingesetzt und IO Broker komplett neu installiert. Die Basis ist also ganz frisch und Backitup in Version 3.0.31.
          Ich kann jedoch keine alten Backups von 2024 auf Google Drive anzeigen lassen bzw wiederherstellen.
          Wenn ich im selben Drive Ordner wo auch die alten Backups liegen ein neues Backup anlege, wird es sofort erkannt.
          Also das System ansich scheint zu funktionieren aber kann es sein, dass es Kompatibilitätsprobleme gibt wenn das Backup zu alt ist?
          Mir wird kein einziges Backup aus 2024 angezeigt.
          Was kann ich tun?
          Danke schon mal für die Hilfe!
          Homoran simatec 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @terraPole last edited by
            @terrapole sagte in Backitup: Aktuelle Backups werden nicht angezeigt:
            nicht bei 6 Monaten!
            Da sind es eher die Rechte!
            kopier mal ein Backup (das letzte) von googke drive nach /opt/iobroker/backups und versuch das mal.
            • simatec
              simatec Developer Most Active @terraPole last edited by
              @terrapole Es gab im Oktober 2024 leider eine Änderung bei Google, was die Rechte angeht.
              Hier gibt es eine Möglichkeit, über Backitup das Verzeichnis zu ändern, damit in G-Drive ein neues Verzeichnis angelegt wird.
              Dort kannst du dann die alten Backups hin verschieben und sie sollten im Anschluss wieder angezeigt werden.
              Google hat leider ständig irgendwas an den Rechten geschraubt
              • Meister Mopper
                Meister Mopper last edited by Meister Mopper
                @simatec sagte in Backitup: Aktuelle Backups werden nicht angezeigt:
                Das habe ich gerade auch festgestellt. Die letzte Sicherung auf google drive ist vom 05.11.2024.
                Muss ich den neuen Ordner dort selbst händisch anlegen oder macht das der Adapter? Und muss ein neuer Token generiert werden?
                Edit:
                Egal, wie ich es mache (mit und ohne Erstellen des Ordners). Beim Backup bleibt das log bei
                14:14:55.241 DEBUG googledrive Google Drive: Copy iobroker_2025_04_24-14_14_03_backupiobroker.tar.gz...
                [DEBUG] [googledrive] start with {"type":"storage","source":"cifs","debugging":true,"deleteOldBackup":true,"googledriveDeleteAfter":10,"advancedDelete":false,"accessJson":"****","newToken":true,"ownDir":true,"bkpType":"Minimal","dir":"/backupDir/iobroker","dirMinimal":"/backupDir/iobroker","ignoreErrors":false,"deleteBackup
                stehen. Ein Backup wird aber auf google drive nicht gespeichert.
                • simatec
                  simatec Developer Most Active @Meister Mopper last edited by
                  @meister-mopper Welche Version von Backitup ist installiert?
                  Bitte erstelle einen neuen Ordner in Backitup
                  Bsp alt:
                  /backup/iobroker
                  Bsp neu:
                  /backup-neu/iobroker
                  Aber bitte neu von Backitup anlegen lassen und nicht umbenennen
                  Token sollest du zur Sicherheit auch erneuern
                  Meister Mopper 2 Replies Last reply Reply Quote 1
                  • Meister Mopper
                    Meister Mopper @simatec last edited by
                    v3.0.31
                    Ich versuche es mit neuem Token.
                    • Meister Mopper
                      @simatec
                      Ok danke, mit neuem Verzeichnis und neuem Token hat das 1a funktioniert. 👍
                      • simatec
                        @meister-mopper Ich schreibe dazu mal noch was im Wiki
                        backitup backitup kein backup
                        1061
